[U-Boot] [PATCH] 85xx: Add CPU 2 errata workaround to all 8548 boards
All mpc8548-based boards should implement the suggested workaround to CPU 2 errata. Without the workaround, its possible for the 8548's core to hang while executing a msync or mbar 0 instruction and a snoopable transaction from an I/O master tagged to make quick forward progress is present.
Signed-off-by: Peter Tyser ptyser@xes-inc.com --- Changes since v1: - Use out/in _be32 access functions
board/freescale/mpc8548cds/mpc8548cds.c | 12 ------------ board/sbc8548/sbc8548.c | 7 ------- cpu/mpc85xx/cpu_init.c | 13 +++++++++++++ 3 files changed, 13 insertions(+), 19 deletions(-)
diff --git a/board/freescale/mpc8548cds/mpc8548cds.c b/board/freescale/mpc8548cds/mpc8548cds.c index 6eb62ea..6f56208 100644 --- a/board/freescale/mpc8548cds/mpc8548cds.c +++ b/board/freescale/mpc8548cds/mpc8548cds.c @@ -56,7 +56,6 @@ int checkboard (void) uint pci_slot = get_pci_slot ();
uint cpu_board_rev = get_cpu_board_revision (); - uint svr;
printf ("Board: CDS Version 0x%02x, PCI Slot %d\n", get_board_version (), pci_slot); @@ -69,17 +68,6 @@ int checkboard (void) */ local_bus_init ();
- svr = get_svr(); - - /* - * Fix CPU2 errata: A core hang possible while executing a - * msync instruction and a snoopable transaction from an I/O - * master tagged to make quick forward progress is present. - * Fixed in Silicon Rev.2.1 - */ - if (!(SVR_MAJ(svr) >= 2 && SVR_MIN(svr) >= 1)) - ecm->eebpcr |= (1 << 16); - /* * Hack TSEC 3 and 4 IO voltages. */ diff --git a/board/sbc8548/sbc8548.c b/board/sbc8548/sbc8548.c index e27c92d..0ffbcb8 100644 --- a/board/sbc8548/sbc8548.c +++ b/board/sbc8548/sbc8548.c @@ -66,13 +66,6 @@ int checkboard (void) local_bus_init ();
/* - * Fix CPU2 errata: A core hang possible while executing a - * msync instruction and a snoopable transaction from an I/O - * master tagged to make quick forward progress is present. - */ - ecm->eebpcr |= (1 << 16); - - /* * Hack TSEC 3 and 4 IO voltages. */ gur->tsec34ioovcr = 0xe7e0; /* 1110 0111 1110 0xxx */ diff --git a/cpu/mpc85xx/cpu_init.c b/cpu/mpc85xx/cpu_init.c index 3a8aef2..5862bd6 100644 --- a/cpu/mpc85xx/cpu_init.c +++ b/cpu/mpc85xx/cpu_init.c @@ -174,6 +174,19 @@ void cpu_init_f (void) { volatile ccsr_lbc_t *memctl = (void *)(CONFIG_SYS_MPC85xx_LBC_ADDR); extern void m8560_cpm_reset (void); +#ifdef CONFIG_MPC8548 + ccsr_local_ecm_t *ecm = (void *)(CONFIG_SYS_MPC85xx_ECM_ADDR); + uint svr = get_svr(); + + /* + * CPU2 errata workaround: A core hang possible while executing + * a msync instruction and a snoopable transaction from an I/O + * master tagged to make quick forward progress is present. + * Fixed in silicon rev 2.1. + */ + if ((SVR_MAJ(svr) == 1) || ((SVR_MAJ(svr) == 2 && SVR_MIN(svr) == 0x0))) + out_be32(&ecm->eebpcr, in_be32(&ecm->eebpcr) | (1 << 16)); +#endif
disable_tlb(14); disable_tlb(15);
Applied, thanks
Andy
Andy Fleming
Peter Tyser
