[U-Boot] [Patch 4/8] add at91 SoC access with c structures
* prepare AT91RM9200 arch for SoC access update
Signed-off-by: Jens Scharsig js_at_ng@scharsoft.de --- cpu/arm920t/at91rm9200/bcm5221.c | 4 ++-- cpu/arm920t/at91rm9200/dm9161.c | 3 +-- cpu/arm920t/at91rm9200/timer.c | 1 - cpu/arm920t/cpu.c | 4 ++++ include/asm-arm/arch-at91rm9200/AT91RM9200.h | 12 ++---------- 5 files changed, 9 insertions(+), 15 deletions(-)
diff --git a/cpu/arm920t/at91rm9200/bcm5221.c b/cpu/arm920t/at91rm9200/bcm5221.c index b52c615..8de3cba 100644 --- a/cpu/arm920t/at91rm9200/bcm5221.c +++ b/cpu/arm920t/at91rm9200/bcm5221.c @@ -28,10 +28,10 @@
#include <at91rm9200_net.h> #include <net.h> -#include <bcm5221.h> - #ifdef CONFIG_DRIVER_ETHER
+#include <bcm5221.h> + #if defined(CONFIG_CMD_NET)
/* diff --git a/cpu/arm920t/at91rm9200/dm9161.c b/cpu/arm920t/at91rm9200/dm9161.c index 1beb6e8..6d4384f 100644 --- a/cpu/arm920t/at91rm9200/dm9161.c +++ b/cpu/arm920t/at91rm9200/dm9161.c @@ -23,9 +23,8 @@
#include <at91rm9200_net.h> #include <net.h> -#include <dm9161.h> - #ifdef CONFIG_DRIVER_ETHER +#include <dm9161.h>
diff --git a/cpu/arm920t/at91rm9200/timer.c b/cpu/arm920t/at91rm9200/timer.c index 9c54bbe..e4203a6 100644 --- a/cpu/arm920t/at91rm9200/timer.c +++ b/cpu/arm920t/at91rm9200/timer.c @@ -33,7 +33,6 @@ #include <common.h> /*#include <asm/io.h>*/ #include <asm/arch/hardware.h> -/*#include <asm/proc/ptrace.h>*/
/* the number of clocks per CONFIG_SYS_HZ */ #define TIMER_LOAD_VAL (CONFIG_SYS_HZ_CLOCK/CONFIG_SYS_HZ) diff --git a/cpu/arm920t/cpu.c b/cpu/arm920t/cpu.c index 34adb11..be82c87 100644 --- a/cpu/arm920t/cpu.c +++ b/cpu/arm920t/cpu.c @@ -33,6 +33,10 @@ #include <command.h> #include <asm/system.h>
+#ifdef CONFIG_AT91_LEGACY +#warning Your board is using legacy AT91RM9200 SoC access. Please update! +#endif + static void cache_flush(void);
int cleanup_before_linux (void) diff --git a/include/asm-arm/arch-at91rm9200/AT91RM9200.h b/include/asm-arm/arch-at91rm9200/AT91RM9200.h index 00bae1c..a04cfa1 100644 --- a/include/asm-arm/arch-at91rm9200/AT91RM9200.h +++ b/include/asm-arm/arch-at91rm9200/AT91RM9200.h @@ -26,6 +26,7 @@ #define AT91RM9200_H
#ifndef __ASSEMBLY__ + typedef volatile unsigned int AT91_REG; /* Hardware register definition */
/*****************************************************************************/ @@ -749,19 +750,10 @@ typedef struct _AT91S_PDC #define AT91C_BASE_PIOC ((AT91PS_PIO) 0xFFFFF800) /* (PIOC) Base Address */ #define AT91C_BASE_PIOD ((AT91PS_PIO) 0xFFFFFA00) /* (PIOC) Base Address */ #define AT91C_BASE_PMC ((AT91PS_PMC) 0xFFFFFC00) /* (PMC) Base Address */ -#if 0 -#define AT91C_BASE_ST ((AT91PS_ST) 0xFFFFFD00) /* (PMC) Base Address */ -#define AT91C_BASE_RTC ((AT91PS_RTC) 0xFFFFFE00) /* (PMC) Base Address */ -#define AT91C_BASE_MC ((AT91PS_MC) 0xFFFFFF00) /* (PMC) Base Address */ -#endif
#define AT91C_BASE_TC0 ((AT91PS_TC) 0xFFFA0000) /* (TC0) Base Address */ #define AT91C_BASE_TC1 ((AT91PS_TC) 0xFFFA4000) /* (TC0) Base Address */ -#if 0 -#define AT91C_BASE_UDP ((AT91PS_UDP) 0xFFFB0000) /* (TC0) Base Address */ -#define AT91C_BASE_MCI ((AT91PS_MCI) 0xFFFB4000) /* (TC0) Base Address */ -#define AT91C_BASE_TWI ((AT91PS_TWI) 0xFFFB8000) /* (TC0) Base Address */ -#endif + #define AT91C_BASE_EMAC ((AT91PS_EMAC) 0xFFFBC000) /* (EMAC) Base Address */ #define AT91C_BASE_US0 ((AT91PS_USART) 0xFFFC0000) /* (US0) Base Address */ #define AT91C_BASE_US1 ((AT91PS_USART) 0xFFFC4000) /* (US1) Base Address */
Jens Scharsig
