[U-Boot] [PATCH] common: fit: Allow U-Boot images to be booted
In certain circumstances it comes in handy to be able to boot into a second U-Boot. But as of now it is not possible to boot a U-Boot binary that is inside a FIT image, which is problematic for projects that e.g. need to guarantee a unbroken chain of trust from SOC all the way into the OS, since the FIT signing mechanism cannot be used.
This patch adds the capability to load such FIT images.
An example its snippet (utilizing signature verification) might look like the following:
images { kernel@1 { description = "2nd stage U-Boot image"; data = /incbin/("u-boot-dtb.img.gz"); type = "kernel"; arch = "arm"; os = "u-boot"; compression = "gzip"; load = <0x8FFFC0>; entry = <0x900000>; signature@1 { algo = "sha256,rsa4096"; key-name-hint = "key"; }; }; };
Signed-off-by: Mario Six mario.six@gdsys.cc --- common/image-fit.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/common/image-fit.c b/common/image-fit.c index 6f920da..0c7b400 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -1690,6 +1690,7 @@ int fit_image_load(bootm_headers_t *images, ulong addr,
os_ok = image_type == IH_TYPE_FLATDT || IH_TYPE_FPGA || fit_image_check_os(fit, noffset, IH_OS_LINUX) || + fit_image_check_os(fit, noffset, IH_OS_U_BOOT) || fit_image_check_os(fit, noffset, IH_OS_OPENRTOS);
/* -- 2.9.0
Isn't this type weird for u-boot itself?
The rest is good.
Thanks, Michal
The rest is good.
Thanks, Michal
It is, but the problem is that adding a new type, like "ubootimage," or something like that, would not be as easy as with the platform-specific image types (like, e.g. "rkimage"), which only appear in mkimage, because we'd have to account for this new type in common/bootm.c (essentially, add a lot of additional "|| images.os.type == IH_TYPE_UBOOT").
I didn't think that it was worth the hassle, and it would have the additional minor problem that it would effectively be a synonym of "kernel," so you could declare a regular kernel as having type "ubootimage," and U-Boot would happily boot it; to prevent that we'd have to do more checks, like, e.g. check the os value against the type and only boot if the combination makes sense or some such.
It would be nicer to have a dedicated type, but I think it's too much effort for such a fringe use case; should it become popular, though, I'll happily add a new type :-)
Mario
The rest is good.
Thanks, Michal
Is the type property even required for this case?
Thanks, Michal
The rest is good.
Thanks, Michal
Thanks, Michal
I just tried to boot one without the type, and apparently it is required:
## Loading kernel from FIT Image at 02000000 ... Using 'config@1' configuration Verifying Hash Integrity ... OK Trying 'kernel@1' kernel subimage Description: 2nd stage U-Boot image Type: Unknown Image Compression: gzip compressed Data Start: 0x020000d4 Data Size: 206485 Bytes = 201.6 KiB Sign algo: sha256,rsa4096:ccdc Sign value: ... Verifying Hash Integrity ... sha256,rsa4096:ccdc+ OK No U-Boot ARM Kernel Image Image ERROR: can't get kernel image!
That makes sense, since common/bootm.c checks the image type in several places.
Mario
Dear Mario,
In message CAN1kZorTfQcVoOz5O5J7-R-T5yTDbrCqDBHgC4gHaMX1sUh3YQ@mail.gmail.com you wrote:
There is no need for a new type. IH_TYPE_FIRMWARE should be used for this; see also comments around [1]
[1] http://git.denx.de/?p=u-boot.git;a=blob;f=include/image.h#l228
Hi Wolfgang,
On Tue, Jul 19, 2016 at 9:14 AM, Wolfgang Denk wd@denx.de wrote:
Dear Mario,
Ah, OK, I thought that IH_TYPE_FIRMWARE should exclusively be used for firmware updates, like the comment said, not for actually *running* the firmware. In that case the work is more manageable (there's still some changes needed, because common/image-fit.c refuses to boot images with firmware type, too).
I'll look into preparing a v2.
Thanks for the help!
Mario
Mario Six
Michal Simek
