[U-Boot] pull request: u-boot-uniphier/master
Hi Tom,
Please pull UniPhier SoC updates: - Enable eMMC driver for LD11/LD20 SoCs - Refactoring of SoC init code - Bug fix of pinctrl driver
The following changes since commit 035ebf85b09cf11c820ae9eec414097420741abd:
Merge branch 'master' of git://git.denx.de/u-boot-spi (2017-01-15 13:33:30 -0500)
git://git.denx.de/u-boot-uniphier.git master
for you to fetch changes up to 2cfa35c47b9c9b80c8ff084f55391a03fd575956:
pinctrl: uniphier: fix Ethernet (RMII) pin-mux setting for LD20 (2017-01-18 01:24:14 +0900)
---------------------------------------------------------------- Masahiro Yamada (12): ARM: uniphier: enable Cadence eMMC controller for LD11/LD20 ARM: dts: uniphier: add UniPhier specific compatible to eMMC node ARM: uniphier: remove unneeded argument of uniphier_ld20_pll_init() ARM: uniphier: split out UMC clock enable ARM: uniphier: refactor MEMCONF init code ARM: uniphier: refactor SBC init code ARM: uniphier: refactor Support Card init code ARM: uniphier: make BCU init into void function ARM: uniphier: refactor board_init() ARM: uniphier: refactor spl_init_board() ARM: uniphier: move SBC and Support Card init code to U-Boot proper pinctrl: uniphier: fix Ethernet (RMII) pin-mux setting for LD20
arch/arm/dts/uniphier-ld11.dtsi | 3 +- arch/arm/dts/uniphier-ld20.dtsi | 3 +- arch/arm/mach-uniphier/Makefile | 10 +- arch/arm/mach-uniphier/bcu/bcu-ld4.c | 8 +- arch/arm/mach-uniphier/bcu/bcu-sld3.c | 8 +- arch/arm/mach-uniphier/board_init.c | 237 +++++++++++++------- arch/arm/mach-uniphier/clk/Makefile | 20 +- .../clk/{early-clk-ld11.c => clk-dram-ld11.c} | 11 +- .../clk/{early-clk-ld20.c => clk-dram-ld20.c} | 10 +- .../clk/{early-clk-pro5.c => clk-dram-pro5.c} | 11 +- .../clk/{early-clk-pxs2.c => clk-dram-pxs2.c} | 16 +- .../clk/{early-clk-ld4.c => clk-dram-sld3.c} | 12 +- arch/arm/mach-uniphier/clk/clk-early-ld11.c | 20 ++ arch/arm/mach-uniphier/clk/clk-early-sld3.c | 31 +++ arch/arm/mach-uniphier/clk/clk-ld20.c | 14 -- arch/arm/mach-uniphier/clk/dpll-pro5.c | 6 + arch/arm/mach-uniphier/clk/dpll-pxs2.c | 6 + arch/arm/mach-uniphier/clk/pll-ld20.c | 4 +- arch/arm/mach-uniphier/dram/Makefile | 2 + arch/arm/mach-uniphier/dram/umc-pro5.c | 12 + arch/arm/mach-uniphier/dram/umc-sld3.c | 6 + arch/arm/mach-uniphier/init.h | 57 ++--- arch/arm/mach-uniphier/init/Makefile | 15 -- arch/arm/mach-uniphier/init/init-ld11.c | 63 ------ arch/arm/mach-uniphier/init/init-ld20.c | 62 ----- arch/arm/mach-uniphier/init/init-ld4.c | 59 ----- arch/arm/mach-uniphier/init/init-pro4.c | 56 ----- arch/arm/mach-uniphier/init/init-pro5.c | 42 ---- arch/arm/mach-uniphier/init/init-pxs2.c | 50 ----- arch/arm/mach-uniphier/init/init-sld3.c | 49 ---- arch/arm/mach-uniphier/init/init-sld8.c | 59 ----- arch/arm/mach-uniphier/init/init.c | 71 ------ arch/arm/mach-uniphier/memconf.c | 163 ++++++++++++++ arch/arm/mach-uniphier/memconf/Makefile | 9 - arch/arm/mach-uniphier/memconf/memconf-pxs2.c | 68 ------ arch/arm/mach-uniphier/memconf/memconf-sld3.c | 60 ----- arch/arm/mach-uniphier/memconf/memconf.c | 107 --------- arch/arm/mach-uniphier/micro-support-card.c | 7 +- arch/arm/mach-uniphier/micro-support-card.h | 5 - arch/arm/mach-uniphier/sbc/Makefile | 17 +- arch/arm/mach-uniphier/sbc/sbc-admulti.c | 53 ----- arch/arm/mach-uniphier/sbc/sbc-ld11.c | 25 +++ arch/arm/mach-uniphier/sbc/sbc-ld4.c | 9 +- arch/arm/mach-uniphier/sbc/sbc-pxs2.c | 8 +- .../mach-uniphier/sbc/{sbc-savepin.c => sbc.c} | 38 +++- arch/arm/mach-uniphier/spl_board_init.c | 185 +++++++++++++++ configs/uniphier_ld11_defconfig | 4 +- configs/uniphier_ld20_defconfig | 2 + drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c | 2 +- 49 files changed, 739 insertions(+), 1056 deletions(-) rename arch/arm/mach-uniphier/clk/{early-clk-ld11.c => clk-dram-ld11.c} (59%) rename arch/arm/mach-uniphier/clk/{early-clk-ld20.c => clk-dram-ld20.c} (69%) rename arch/arm/mach-uniphier/clk/{early-clk-pro5.c => clk-dram-pro5.c} (69%) rename arch/arm/mach-uniphier/clk/{early-clk-pxs2.c => clk-dram-pxs2.c} (64%) rename arch/arm/mach-uniphier/clk/{early-clk-ld4.c => clk-dram-sld3.c} (59%) create mode 100644 arch/arm/mach-uniphier/clk/clk-early-ld11.c create mode 100644 arch/arm/mach-uniphier/clk/clk-early-sld3.c delete mode 100644 arch/arm/mach-uniphier/clk/clk-ld20.c create mode 100644 arch/arm/mach-uniphier/clk/dpll-pro5.c create mode 100644 arch/arm/mach-uniphier/clk/dpll-pxs2.c create mode 100644 arch/arm/mach-uniphier/dram/umc-pro5.c create mode 100644 arch/arm/mach-uniphier/dram/umc-sld3.c delete mode 100644 arch/arm/mach-uniphier/init/Makefile delete mode 100644 arch/arm/mach-uniphier/init/init-ld11.c delete mode 100644 arch/arm/mach-uniphier/init/init-ld20.c delete mode 100644 arch/arm/mach-uniphier/init/init-ld4.c delete mode 100644 arch/arm/mach-uniphier/init/init-pro4.c delete mode 100644 arch/arm/mach-uniphier/init/init-pro5.c delete mode 100644 arch/arm/mach-uniphier/init/init-pxs2.c delete mode 100644 arch/arm/mach-uniphier/init/init-sld3.c delete mode 100644 arch/arm/mach-uniphier/init/init-sld8.c delete mode 100644 arch/arm/mach-uniphier/init/init.c create mode 100644 arch/arm/mach-uniphier/memconf.c delete mode 100644 arch/arm/mach-uniphier/memconf/Makefile delete mode 100644 arch/arm/mach-uniphier/memconf/memconf-pxs2.c delete mode 100644 arch/arm/mach-uniphier/memconf/memconf-sld3.c delete mode 100644 arch/arm/mach-uniphier/memconf/memconf.c delete mode 100644 arch/arm/mach-uniphier/sbc/sbc-admulti.c create mode 100644 arch/arm/mach-uniphier/sbc/sbc-ld11.c rename arch/arm/mach-uniphier/sbc/{sbc-savepin.c => sbc.c} (55%) create mode 100644 arch/arm/mach-uniphier/spl_board_init.c
On Wed, Jan 18, 2017 at 01:36:38AM +0900, Masahiro Yamada wrote:
Hi Tom,
Masahiro Yamada
