[PATCH V2 1/6] dt-bindings: Sync versaclock.h with upcoming 5.12-rc1
The versaclock doesn't have a driver yet, but there are a bunch of device tree updates for the Beacon RZ/G2 boards that won't compile without these. A driver is coming, so sync the bindings for now
Signed-off-by: Adam Ford aford173@gmail.com --- include/dt-bindings/clk/versaclock.h | 13 +++++++++++++ 1 file changed, 13 insertions(+)
V2: New to series in order to make series build
diff --git a/include/dt-bindings/clk/versaclock.h b/include/dt-bindings/clk/versaclock.h new file mode 100644 index 0000000000..c6a6a09465 --- /dev/null +++ b/include/dt-bindings/clk/versaclock.h @@ -0,0 +1,13 @@ +/* SPDX-License-Identifier: GPL-2.0 */ + +/* This file defines field values used by the versaclock 6 family + * for defining output type + */ + +#define VC5_LVPECL 0 +#define VC5_CMOS 1 +#define VC5_HCSL33 2 +#define VC5_LVDS 3 +#define VC5_CMOS2 4 +#define VC5_CMOSD 5 +#define VC5_HCSL25 6
Update the RZ/G2M dtsi and r8a774a1-beacon-rzg2m-kit kit from Renesas repo destined to become 5.12-rc1.
Signed-off-by: Adam Ford aford173@gmail.com --- arch/arm/dts/beacon-renesom-baseboard.dtsi | 359 ++++++++++++++++----- arch/arm/dts/beacon-renesom-som.dtsi | 57 +++- arch/arm/dts/r8a774a1-beacon-rzg2m-kit.dts | 59 +++- arch/arm/dts/r8a774a1.dtsi | 74 ++++- 4 files changed, 445 insertions(+), 104 deletions(-)
V2: No Change
diff --git a/arch/arm/dts/beacon-renesom-baseboard.dtsi b/arch/arm/dts/beacon-renesom-baseboard.dtsi index 8a472c057a..5f998d4706 100644 --- a/arch/arm/dts/beacon-renesom-baseboard.dtsi +++ b/arch/arm/dts/beacon-renesom-baseboard.dtsi @@ -5,35 +5,27 @@
#include <dt-bindings/gpio/gpio.h> #include <dt-bindings/input/input.h> +#include <dt-bindings/clk/versaclock.h>
/ { - aliases { - serial0 = &scif2; - serial1 = &hscif0; - serial2 = &hscif1; - serial3 = &scif0; - serial4 = &hscif2; - serial5 = &scif5; - spi0 = &msiof0; - spi1 = &msiof1; - spi2 = &msiof2; - spi3 = &msiof3; - ethernet0 = &avb; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - backlight: backlight { + backlight_lvds: backlight-lvds { compatible = "pwm-backlight"; power-supply = <®_lcd>; enable-gpios = <&gpio_exp1 3 GPIO_ACTIVE_HIGH>; - pwms = <&pwm0 0 50000>; + pwms = <&pwm2 0 25000>; brightness-levels = <0 4 8 16 32 64 128 255>; default-brightness-level = <6>; };
+ backlight_dpi: backlight-dpi { + compatible = "pwm-backlight"; + power-supply = <®_lcd>; + enable-gpios = <&gpio_exp1 7 GPIO_ACTIVE_LOW>; + pwms = <&pwm0 0 25000>; + brightness-levels = <0 25 33 50 63 75 88 100>; + default-brightness-level = <6>; + }; + hdmi0-out { compatible = "hdmi-connector"; type = "a"; @@ -48,38 +40,38 @@ keys { compatible = "gpio-keys";
- key-1 { + key-1 { /* S19 */ gpios = <&gpio4 6 GPIO_ACTIVE_LOW>; - linux,code = <KEY_1>; - label = "Switch-1"; + linux,code = <KEY_UP>; + label = "Up"; wakeup-source; debounce-interval = <20>; }; - key-2 { + key-2 { /*S20 */ gpios = <&gpio3 13 GPIO_ACTIVE_LOW>; - linux,code = <KEY_2>; - label = "Switch-2"; + linux,code = <KEY_LEFT>; + label = "Left"; wakeup-source; debounce-interval = <20>; }; - key-3 { + key-3 { /* S21 */ gpios = <&gpio5 17 GPIO_ACTIVE_LOW>; - linux,code = <KEY_3>; - label = "Switch-3"; + linux,code = <KEY_DOWN>; + label = "Down"; wakeup-source; debounce-interval = <20>; }; - key-4 { + key-4 { /* S22 */ gpios = <&gpio5 20 GPIO_ACTIVE_LOW>; - linux,code = <KEY_4>; - label = "Switch-4"; + linux,code = <KEY_RIGHT>; + label = "Right"; wakeup-source; debounce-interval = <20>; }; - key-5 { + key-5 { /* S23 */ gpios = <&gpio5 22 GPIO_ACTIVE_LOW>; - linux,code = <KEY_5>; - label = "Switch-4"; + linux,code = <KEY_ENTER>; + label = "Center"; wakeup-source; debounce-interval = <20>; }; @@ -98,17 +90,59 @@ led1 { gpios = <&gpio7 0 GPIO_ACTIVE_HIGH>; label = "LED1"; - linux,default-trigger = "heartbeat"; }; led2 { gpios = <&gpio7 1 GPIO_ACTIVE_HIGH>; label = "LED2"; - linux,default-trigger = "heartbeat"; }; led3 { gpios = <&gpio7 3 GPIO_ACTIVE_HIGH>; label = "LED3"; - linux,default-trigger = "heartbeat"; + }; + }; + + lvds { + compatible = "panel-lvds"; + power-supply = <®_lcd_reset>; + width-mm = <223>; + height-mm = <125>; + backlight = <&backlight_lvds>; + data-mapping = "vesa-24"; + + panel-timing { + /* 800x480@60Hz */ + clock-frequency = <30000000>; + hactive = <800>; + vactive = <480>; + hsync-len = <48>; + hfront-porch = <40>; + hback-porch = <40>; + vfront-porch = <13>; + vback-porch = <29>; + vsync-len = <1>; + hsync-active = <1>; + vsync-active = <3>; + de-active = <1>; + pixelclk-active = <0>; + }; + + port { + panel_in: endpoint { + remote-endpoint = <&lvds0_out>; + }; + }; + }; + + rgb { + /* Different LCD with compatible timings */ + compatible = "rocktech,rk070er9427"; + backlight = <&backlight_dpi>; + enable-gpios = <&gpio1 21 GPIO_ACTIVE_HIGH>; + power-supply = <®_lcd>; + port { + rgb_panel: endpoint { + remote-endpoint = <&du_out_rgb>; + }; }; };
@@ -117,7 +151,7 @@ regulator-name = "audio-1.8V"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; - gpio = <&gpio_exp2 7 GPIO_ACTIVE_HIGH>; + gpio = <&gpio_exp4 1 GPIO_ACTIVE_HIGH>; enable-active-high; };
@@ -167,15 +201,12 @@
vccq_sdhi0: regulator-vccq-sdhi0 { compatible = "regulator-gpio"; - regulator-name = "SDHI0 VccQ"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <3300000>; - gpios = <&gpio6 30 GPIO_ACTIVE_HIGH>; gpios-states = <1>; states = <3300000 1>, <1800000 0>; - regulator-always-on; };
/* External DU dot clocks */ @@ -190,10 +221,29 @@ #clock-cells = <0>; clock-frequency = <25000000>; }; -};
-&audio_clk_a { - clock-frequency = <22579200>; + connector { + compatible = "usb-c-connector"; + label = "USB-C"; + data-role = "dual"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + port@0 { + reg = <0>; + hs_ep: endpoint { + remote-endpoint = <&usb3_hs_ep>; + }; + }; + port@1 { + reg = <1>; + ss_ep: endpoint { + remote-endpoint = <&hd3ss3220_in_ep>; + }; + }; + }; + }; };
&audio_clk_b { @@ -214,30 +264,19 @@ status = "okay"; };
-&du { - pinctrl-0 = <&du_pins>; - pinctrl-names = "default"; - status = "okay"; - - clocks = <&cpg CPG_MOD 724>, - <&cpg CPG_MOD 723>, - <&cpg CPG_MOD 722>, - <&versaclock5 1>, - <&x302_clk>, - <&versaclock5 2>; - clock-names = "du.0", "du.1", "du.2", - "dclkin.0", "dclkin.1", "dclkin.2"; +&du_out_rgb { + remote-endpoint = <&rgb_panel>; };
&ehci0 { dr_mode = "otg"; status = "okay"; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>, <&versaclock5 3>, <&versaclock6_bb 4>; + clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>, <&versaclock5 3>; };
&ehci1 { status = "okay"; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>, <&versaclock5 4>; + clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; };
&hdmi0 { @@ -258,7 +297,6 @@ }; }; port@2 { - /* HDMI sound */ reg = <2>; dw_hdmi0_snd_in: endpoint { remote-endpoint = <&rsnd_endpoint1>; @@ -281,7 +319,7 @@
&i2c2 { status = "okay"; - clock-frequency = <100000>; + clock-frequency = <400000>; pinctrl-0 = <&i2c2_pins>; pinctrl-names = "default";
@@ -299,18 +337,49 @@ #gpio-cells = <2>; };
- versaclock6_bb: versaclock6_bb@6a { + gpio_exp4: gpio@23 { + compatible = "onnn,pca9654"; + reg = <0x23>; + gpio-controller; + #gpio-cells = <2>; + }; + + versaclock6_bb: clock-controller@6a { compatible = "idt,5p49v6965"; reg = <0x6a>; #clock-cells = <1>; clocks = <&x304_clk>; clock-names = "xin"; - /* CSI0_MCLK, CSI1_MCLK, AUDIO_CLKIN, USB_HUB_MCLK_BB */ + assigned-clocks = <&versaclock6_bb 1>, <&versaclock6_bb 2>, <&versaclock6_bb 3>, <&versaclock6_bb 4>; - assigned-clock-rates = <24000000>, <24000000>, <24000000>, <24000000>; + assigned-clock-rates = <24000000>, <24000000>, <24000000>, <24576000>; + + OUT1 { + idt,mode = <VC5_CMOS>; + idt,voltage-microvolt = <1800000>; + idt,slew-percent = <100>; + }; + + OUT2 { + idt,mode = <VC5_CMOS>; + idt,voltage-microvolt = <1800000>; + idt,slew-percent = <100>; + }; + + OUT3 { + idt,mode = <VC5_CMOS>; + idt,voltage-microvolt = <3300000>; + idt,slew-percent = <100>; + }; + + OUT4 { + idt,mode = <VC5_CMOS>; + idt,voltage-microvolt = <3300000>; + idt,slew-percent = <100>; + }; }; };
@@ -324,13 +393,14 @@
&i2c5 { status = "okay"; - clock-frequency = <100000>; + clock-frequency = <400000>; pinctrl-0 = <&i2c5_pins>; pinctrl-names = "default";
codec: wm8962@1a { compatible = "wlf,wm8962"; reg = <0x1a>; + clocks = <&versaclock6_bb 3>; DCVDD-supply = <®_audio>; DBVDD-supply = <®_audio>; AVDD-supply = <®_audio>; @@ -375,6 +445,49 @@ interrupts = <9 IRQ_TYPE_EDGE_RISING>; wakeup-source; }; + + hd3ss3220@47 { + compatible = "ti,hd3ss3220"; + reg = <0x47>; + interrupt-parent = <&gpio6>; + interrupts = <4 IRQ_TYPE_LEVEL_LOW>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + port@0 { + reg = <0>; + hd3ss3220_in_ep: endpoint { + remote-endpoint = <&ss_ep>; + }; + }; + port@1 { + reg = <1>; + hd3ss3220_out_ep: endpoint { + remote-endpoint = <&usb3_role_switch>; + }; + }; + }; + }; +}; + +&lvds0 { + status = "okay"; + + ports { + port@1 { + lvds0_out: endpoint { + remote-endpoint = <&panel_in>; + }; + }; + }; +}; + +&msiof1 { + pinctrl-0 = <&msiof1_pins>; + pinctrl-names = "default"; + status = "okay"; + cs-gpios = <&gpio3 10 GPIO_ACTIVE_LOW>; };
&ohci0 { @@ -440,6 +553,11 @@ function = "pwm0"; };
+ pwm2_pins: pwm2 { + groups = "pwm2_a"; + function = "pwm2"; + }; + sdhi0_pins: sd0 { groups = "sdhi0_data4", "sdhi0_ctrl"; function = "sdhi0"; @@ -458,7 +576,7 @@ };
sound_clk_pins: sound_clk { - groups = "audio_clk_a_a"; + groups = "audio_clk_a_a", "audio_clk_b_a"; function = "audio_clk"; };
@@ -490,6 +608,12 @@ status = "okay"; };
+&pwm2 { + pinctrl-0 = <&pwm2_pins>; + pinctrl-names = "default"; + status = "okay"; +}; + &rcar_sound { pinctrl-0 = <&sound_pins &sound_clk_pins>; pinctrl-names = "default"; @@ -503,23 +627,6 @@
status = "okay";
- clocks = <&cpg CPG_MOD 1005>, - <&cpg CPG_MOD 1006>, <&cpg CPG_MOD 1007>, - <&cpg CPG_MOD 1008>, <&cpg CPG_MOD 1009>, - <&cpg CPG_MOD 1010>, <&cpg CPG_MOD 1011>, - <&cpg CPG_MOD 1012>, <&cpg CPG_MOD 1013>, - <&cpg CPG_MOD 1014>, <&cpg CPG_MOD 1015>, - <&cpg CPG_MOD 1022>, <&cpg CPG_MOD 1023>, - <&cpg CPG_MOD 1024>, <&cpg CPG_MOD 1025>, - <&cpg CPG_MOD 1026>, <&cpg CPG_MOD 1027>, - <&cpg CPG_MOD 1028>, <&cpg CPG_MOD 1029>, - <&cpg CPG_MOD 1030>, <&cpg CPG_MOD 1031>, - <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, - <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, - <&cpg CPG_MOD 1019>, <&cpg CPG_MOD 1018>, - <&audio_clk_a>, <&audio_clk_b>, <&audio_clk_c>, - <&cpg CPG_CORE R8A774A1_CLK_S0D4>; - ports { #address-cells = <1>; #size-cells = <0>; @@ -551,6 +658,11 @@ }; };
+&rwdt { + status = "okay"; + timeout-sec = <60>; +}; + &scif0 { pinctrl-0 = <&scif0_pins>; pinctrl-names = "default"; @@ -584,6 +696,26 @@ shared-pin; };
+&tmu0 { + status = "okay"; +}; + +&tmu1 { + status = "okay"; +}; + +&tmu2 { + status = "okay"; +}; + +&tmu3 { + status = "okay"; +}; + +&tmu4 { + status = "okay"; +}; + &usb2_phy0 { pinctrl-0 = <&usb0_pins>; pinctrl-names = "default"; @@ -595,3 +727,62 @@ pinctrl-names = "default"; status = "okay"; }; + +&usb3_peri0 { + companion = <&xhci0>; + status = "okay"; + usb-role-switch; + + ports { + #address-cells = <1>; + #size-cells = <0>; + port@0 { + reg = <0>; + usb3_hs_ep: endpoint { + remote-endpoint = <&hs_ep>; + }; + }; + port@1 { + reg = <1>; + usb3_role_switch: endpoint { + remote-endpoint = <&hd3ss3220_out_ep>; + }; + }; + }; +}; + +&usb3_phy0 { + status = "okay"; +}; + +&vin0 { + status = "okay"; +}; +&vin1 { + status = "okay"; +}; +&vin2 { + status = "okay"; +}; +&vin3 { + status = "okay"; +}; +&vin4 { + status = "okay"; +}; +&vin5 { + status = "okay"; +}; +&vin6 { + status = "okay"; +}; +&vin7 { + status = "okay"; +}; + +&xhci0 +{ + pinctrl-0 = <&usb30_pins>; + pinctrl-names = "default"; + status = "okay"; +}; diff --git a/arch/arm/dts/beacon-renesom-som.dtsi b/arch/arm/dts/beacon-renesom-som.dtsi index 6c16a2732a..9565495b49 100644 --- a/arch/arm/dts/beacon-renesom-som.dtsi +++ b/arch/arm/dts/beacon-renesom-som.dtsi @@ -4,17 +4,18 @@ */
#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/clk/versaclock.h>
/ { memory@48000000 { device_type = "memory"; /* first 128MB is reserved for secure area. */ - reg = <0x0 0x48000000 0x0 0x78000000>; + reg = <0x0 0x48000000 0x0 0xc000000>; };
- memory@600000000 { + memory@57000000 { device_type = "memory"; - reg = <0x6 0x00000000 0x0 0x80000000>; + reg = <0x0 0x57000000 0x0 0x29000000>; };
osc_32k: osc_32k { @@ -55,7 +56,8 @@ pinctrl-0 = <&avb_pins>; pinctrl-names = "default"; phy-handle = <&phy0>; - phy-mode = "rgmii-id"; + rx-internal-delay-ps = <1800>; + tx-internal-delay-ps = <2000>; status = "okay";
phy0: ethernet-phy@0 { @@ -88,7 +90,6 @@ pinctrl-names = "default"; uart-has-rtscts; status = "okay"; - max-speed = <4000000>;
bluetooth { compatible = "brcm,bcm43438-bt"; @@ -97,6 +98,7 @@ device-wakeup-gpios = <&pca9654 5 GPIO_ACTIVE_HIGH>; clocks = <&osc_32k>; clock-names = "extclk"; + max-speed = <4000000>; }; };
@@ -108,7 +110,7 @@
&i2c4 { status = "okay"; - clock-frequency = <400000>; + clock-frequency = <100000>;
pca9654: gpio@20 { compatible = "onnn,pca9654"; @@ -147,7 +149,7 @@ };
eeprom@50 { - compatible = "microchip, at24c64", "atmel,24c64"; + compatible = "microchip,at24c64", "atmel,24c64"; pagesize = <32>; read-only; /* Manufacturing EEPROM programmed at factory */ reg = <0x50>; @@ -169,7 +171,32 @@ <&versaclock5 2>, <&versaclock5 3>, <&versaclock5 4>; + assigned-clock-rates = <33333333>, <33333333>, <50000000>, <125000000>; + + OUT1 { + idt,mode = <VC5_CMOS>; + idt,voltage-microvolt = <1800000>; + idt,slew-percent = <100>; + }; + + OUT2 { + idt,mode = <VC5_CMOS>; + idt,voltage-microvolt = <1800000>; + idt,slew-percent = <100>; + }; + + OUT3 { + idt,mode = <VC5_CMOS>; + idt,voltage-microvolt = <1800000>; + idt,slew-percent = <100>; + }; + + OUT4 { + idt,mode = <VC5_CMOS>; + idt,voltage-microvolt = <3300000>; + idt,slew-percent = <100>; + }; }; };
@@ -295,18 +322,14 @@ status = "okay"; };
-&usb_extal_clk { - clock-frequency = <50000000>; +&usb2_clksel { + status = "okay"; + clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>, + <&versaclock5 3>, <&usb3s0_clk>; + clock-names = "ehci_ohci", "hs-usb-if", + "usb_extal", "usb_xtal"; };
&usb3s0_clk { clock-frequency = <100000000>; }; - -&vspb { - status = "okay"; -}; - -&vspi0 { - status = "okay"; -}; diff --git a/arch/arm/dts/r8a774a1-beacon-rzg2m-kit.dts b/arch/arm/dts/r8a774a1-beacon-rzg2m-kit.dts index e7ed5d4806..501cb05da2 100644 --- a/arch/arm/dts/r8a774a1-beacon-rzg2m-kit.dts +++ b/arch/arm/dts/r8a774a1-beacon-rzg2m-kit.dts @@ -10,6 +10,61 @@ #include "beacon-renesom-baseboard.dtsi"
/ { - model = "Beacon Embedded Works RZ/G2M Development Kit"; - compatible = "beacon,beacon-rzg2m", "renesas,r8a774a1"; + model = "Beacon EmbeddedWorks RZ/G2M Development Kit"; + compatible = "beacon,beacon-rzg2m", "renesas,r8a774a1"; + + aliases { + serial0 = &scif2; + serial1 = &hscif0; + serial2 = &hscif1; + serial3 = &scif0; + serial4 = &hscif2; + serial5 = &scif5; + ethernet0 = &avb; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + memory@600000000 { + device_type = "memory"; + reg = <0x6 0x00000000 0x0 0x80000000>; + }; +}; + +&du { + pinctrl-0 = <&du_pins>; + pinctrl-names = "default"; + status = "okay"; + + clocks = <&cpg CPG_MOD 724>, + <&cpg CPG_MOD 723>, + <&cpg CPG_MOD 722>, + <&versaclock5 1>, + <&x302_clk>, + <&versaclock5 2>; + clock-names = "du.0", "du.1", "du.2", + "dclkin.0", "dclkin.1", "dclkin.2"; +}; + +/* Reference versaclock instead of audio_clk_a */ +&rcar_sound { + clocks = <&cpg CPG_MOD 1005>, + <&cpg CPG_MOD 1006>, <&cpg CPG_MOD 1007>, + <&cpg CPG_MOD 1008>, <&cpg CPG_MOD 1009>, + <&cpg CPG_MOD 1010>, <&cpg CPG_MOD 1011>, + <&cpg CPG_MOD 1012>, <&cpg CPG_MOD 1013>, + <&cpg CPG_MOD 1014>, <&cpg CPG_MOD 1015>, + <&cpg CPG_MOD 1022>, <&cpg CPG_MOD 1023>, + <&cpg CPG_MOD 1024>, <&cpg CPG_MOD 1025>, + <&cpg CPG_MOD 1026>, <&cpg CPG_MOD 1027>, + <&cpg CPG_MOD 1028>, <&cpg CPG_MOD 1029>, + <&cpg CPG_MOD 1030>, <&cpg CPG_MOD 1031>, + <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, + <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, + <&cpg CPG_MOD 1019>, <&cpg CPG_MOD 1018>, + <&versaclock6_bb 4>, <&audio_clk_b>, + <&audio_clk_c>, + <&cpg CPG_CORE R8A774A1_CLK_S0D4>; }; diff --git a/arch/arm/dts/r8a774a1.dtsi b/arch/arm/dts/r8a774a1.dtsi index 8e80f50132..d64fb8b1b8 100644 --- a/arch/arm/dts/r8a774a1.dtsi +++ b/arch/arm/dts/r8a774a1.dtsi @@ -408,7 +408,7 @@ resets = <&cpg 905>; };
- pfc: pin-controller@e6060000 { + pfc: pinctrl@e6060000 { compatible = "renesas,pfc-r8a774a1"; reg = <0 0xe6060000 0 0x50c>; }; @@ -835,6 +835,21 @@ status = "disabled"; };
+ usb2_clksel: clock-controller@e6590630 { + compatible = "renesas,r8a774a1-rcar-usb2-clock-sel", + "renesas,rcar-gen3-usb2-clock-sel"; + reg = <0 0xe6590630 0 0x02>; + clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>, + <&usb_extal_clk>, <&usb3s0_clk>; + clock-names = "ehci_ohci", "hs-usb-if", + "usb_extal", "usb_xtal"; + #clock-cells = <0>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 703>, <&cpg 704>; + reset-names = "ehci_ohci", "hs-usb-if"; + status = "disabled"; + }; + usb_dmac0: dma-controller@e65a0000 { compatible = "renesas,r8a774a1-usb-dmac", "renesas,usb-dmac"; @@ -1115,6 +1130,8 @@ power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; resets = <&cpg 812>; phy-mode = "rgmii"; + rx-internal-delay-ps = <0>; + tx-internal-delay-ps = <0>; iommus = <&ipmmu_ds0 16>; #address-cells = <1>; #size-cells = <0>; @@ -2300,6 +2317,23 @@ status = "disabled"; };
+ rpc: spi@ee200000 { + compatible = "renesas,r8a774a1-rpc-if", + "renesas,rcar-gen3-rpc-if"; + reg = <0 0xee200000 0 0x200>, + <0 0x08000000 0 0x4000000>, + <0 0xee208000 0 0x100>; + reg-names = "regs", "dirmap", "wbuf"; + interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 917>; + clock-names = "rpc"; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + resets = <&cpg 917>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + gic: interrupt-controller@f1010000 { compatible = "arm,gic-400"; #interrupt-cells = <3>; @@ -2371,6 +2405,44 @@ status = "disabled"; };
+ pciec0_ep: pcie-ep@fe000000 { + compatible = "renesas,r8a774a1-pcie-ep", + "renesas,rcar-gen3-pcie-ep"; + reg = <0x0 0xfe000000 0 0x80000>, + <0x0 0xfe100000 0 0x100000>, + <0x0 0xfe200000 0 0x200000>, + <0x0 0x30000000 0 0x8000000>, + <0x0 0x38000000 0 0x8000000>; + reg-names = "apb-base", "memory0", "memory1", "memory2", "memory3"; + interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 319>; + clock-names = "pcie"; + resets = <&cpg 319>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + status = "disabled"; + }; + + pciec1_ep: pcie-ep@ee800000 { + compatible = "renesas,r8a774a1-pcie-ep", + "renesas,rcar-gen3-pcie-ep"; + reg = <0x0 0xee800000 0 0x80000>, + <0x0 0xee900000 0 0x100000>, + <0x0 0xeea00000 0 0x200000>, + <0x0 0xc0000000 0 0x8000000>, + <0x0 0xc8000000 0 0x8000000>; + reg-names = "apb-base", "memory0", "memory1", "memory2", "memory3"; + interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 318>; + clock-names = "pcie"; + resets = <&cpg 318>; + power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; + status = "disabled"; + }; + fdp1@fe940000 { compatible = "renesas,fdp1"; reg = <0 0xfe940000 0 0x2400>;
Update the RZ/G2H dtsi from Renesas repo destined to become 5.12-rc1.
Signed-off-by: Adam Ford aford173@gmail.com --- arch/arm/dts/r8a774e1.dtsi | 1374 +++++++++++++++++++++++++++++++++++- 1 file changed, 1347 insertions(+), 27 deletions(-)
V2: No Change
diff --git a/arch/arm/dts/r8a774e1.dtsi b/arch/arm/dts/r8a774e1.dtsi index 0f86cfd524..8eb006cbd9 100644 --- a/arch/arm/dts/r8a774e1.dtsi +++ b/arch/arm/dts/r8a774e1.dtsi @@ -28,6 +28,12 @@ clock-frequency = <0>; };
+ audio_clk_b: audio_clk_b { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + audio_clk_c: audio_clk_c { compatible = "fixed-clock"; #clock-cells = <0>; @@ -127,6 +133,7 @@ power-domains = <&sysc R8A774E1_PD_CA57_CPU0>; next-level-cache = <&L2_CA57>; enable-method = "psci"; + cpu-idle-states = <&CPU_SLEEP_0>; dynamic-power-coefficient = <854>; clocks = <&cpg CPG_CORE R8A774E1_CLK_Z>; operating-points-v2 = <&cluster0_opp>; @@ -141,6 +148,7 @@ power-domains = <&sysc R8A774E1_PD_CA57_CPU1>; next-level-cache = <&L2_CA57>; enable-method = "psci"; + cpu-idle-states = <&CPU_SLEEP_0>; clocks = <&cpg CPG_CORE R8A774E1_CLK_Z>; operating-points-v2 = <&cluster0_opp>; capacity-dmips-mhz = <1024>; @@ -154,6 +162,7 @@ power-domains = <&sysc R8A774E1_PD_CA57_CPU2>; next-level-cache = <&L2_CA57>; enable-method = "psci"; + cpu-idle-states = <&CPU_SLEEP_0>; clocks = <&cpg CPG_CORE R8A774E1_CLK_Z>; operating-points-v2 = <&cluster0_opp>; capacity-dmips-mhz = <1024>; @@ -167,6 +176,7 @@ power-domains = <&sysc R8A774E1_PD_CA57_CPU3>; next-level-cache = <&L2_CA57>; enable-method = "psci"; + cpu-idle-states = <&CPU_SLEEP_0>; clocks = <&cpg CPG_CORE R8A774E1_CLK_Z>; operating-points-v2 = <&cluster0_opp>; capacity-dmips-mhz = <1024>; @@ -180,6 +190,7 @@ power-domains = <&sysc R8A774E1_PD_CA53_CPU0>; next-level-cache = <&L2_CA53>; enable-method = "psci"; + cpu-idle-states = <&CPU_SLEEP_1>; #cooling-cells = <2>; dynamic-power-coefficient = <277>; clocks = <&cpg CPG_CORE R8A774E1_CLK_Z2>; @@ -194,6 +205,7 @@ power-domains = <&sysc R8A774E1_PD_CA53_CPU1>; next-level-cache = <&L2_CA53>; enable-method = "psci"; + cpu-idle-states = <&CPU_SLEEP_1>; clocks = <&cpg CPG_CORE R8A774E1_CLK_Z2>; operating-points-v2 = <&cluster1_opp>; capacity-dmips-mhz = <535>; @@ -206,6 +218,7 @@ power-domains = <&sysc R8A774E1_PD_CA53_CPU2>; next-level-cache = <&L2_CA53>; enable-method = "psci"; + cpu-idle-states = <&CPU_SLEEP_1>; clocks = <&cpg CPG_CORE R8A774E1_CLK_Z2>; operating-points-v2 = <&cluster1_opp>; capacity-dmips-mhz = <535>; @@ -218,6 +231,7 @@ power-domains = <&sysc R8A774E1_PD_CA53_CPU3>; next-level-cache = <&L2_CA53>; enable-method = "psci"; + cpu-idle-states = <&CPU_SLEEP_1>; clocks = <&cpg CPG_CORE R8A774E1_CLK_Z2>; operating-points-v2 = <&cluster1_opp>; capacity-dmips-mhz = <535>; @@ -236,6 +250,28 @@ cache-unified; cache-level = <2>; }; + + idle-states { + entry-method = "psci"; + + CPU_SLEEP_0: cpu-sleep-0 { + compatible = "arm,idle-state"; + arm,psci-suspend-param = <0x0010000>; + local-timer-stop; + entry-latency-us = <400>; + exit-latency-us = <500>; + min-residency-us = <4000>; + }; + + CPU_SLEEP_1: cpu-sleep-1 { + compatible = "arm,idle-state"; + arm,psci-suspend-param = <0x0010000>; + local-timer-stop; + entry-latency-us = <700>; + exit-latency-us = <700>; + min-residency-us = <5000>; + }; + }; };
extal_clk: extal { @@ -427,7 +463,7 @@ resets = <&cpg 905>; };
- pfc: pin-controller@e6060000 { + pfc: pinctrl@e6060000 { compatible = "renesas,pfc-r8a774e1"; reg = <0 0xe6060000 0 0x50c>; }; @@ -838,18 +874,76 @@ };
hsusb: usb@e6590000 { + compatible = "renesas,usbhs-r8a774e1", + "renesas,rcar-gen3-usbhs"; reg = <0 0xe6590000 0 0x200>; + interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 704>, <&cpg CPG_MOD 703>; + dmas = <&usb_dmac0 0>, <&usb_dmac0 1>, + <&usb_dmac1 0>, <&usb_dmac1 1>; + dma-names = "ch0", "ch1", "ch2", "ch3"; + renesas,buswait = <11>; + phys = <&usb2_phy0 3>; + phy-names = "usb"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 704>, <&cpg 703>; status = "disabled"; + };
- /* placeholder */ + usb2_clksel: clock-controller@e6590630 { + compatible = "renesas,r8a774e1-rcar-usb2-clock-sel", + "renesas,rcar-gen3-usb2-clock-sel"; + reg = <0 0xe6590630 0 0x02>; + clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>, + <&usb_extal_clk>, <&usb3s0_clk>; + clock-names = "ehci_ohci", "hs-usb-if", + "usb_extal", "usb_xtal"; + #clock-cells = <0>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 703>, <&cpg 704>; + reset-names = "ehci_ohci", "hs-usb-if"; + status = "disabled"; + }; + + usb_dmac0: dma-controller@e65a0000 { + compatible = "renesas,r8a774e1-usb-dmac", + "renesas,usb-dmac"; + reg = <0 0xe65a0000 0 0x100>; + interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "ch0", "ch1"; + clocks = <&cpg CPG_MOD 330>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 330>; + #dma-cells = <1>; + dma-channels = <2>; + }; + + usb_dmac1: dma-controller@e65b0000 { + compatible = "renesas,r8a774e1-usb-dmac", + "renesas,usb-dmac"; + reg = <0 0xe65b0000 0 0x100>; + interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "ch0", "ch1"; + clocks = <&cpg CPG_MOD 331>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 331>; + #dma-cells = <1>; + dma-channels = <2>; };
usb3_phy0: usb-phy@e65ee000 { + compatible = "renesas,r8a774e1-usb3-phy", + "renesas,rcar-gen3-usb3-phy"; reg = <0 0xe65ee000 0 0x90>; + clocks = <&cpg CPG_MOD 328>, <&usb3s0_clk>, + <&usb_extal_clk>; + clock-names = "usb3-if", "usb3s_clk", "usb_extal"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 328>; #phy-cells = <0>; status = "disabled"; - - /* placeholder */ };
dmac0: dma-controller@e6700000 { @@ -1139,6 +1233,8 @@ power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; resets = <&cpg 812>; phy-mode = "rgmii"; + rx-internal-delay-ps = <0>; + tx-internal-delay-ps = <0>; iommus = <&ipmmu_ds0 16>; #address-cells = <1>; #size-cells = <0>; @@ -1203,11 +1299,73 @@ };
pwm0: pwm@e6e30000 { + compatible = "renesas,pwm-r8a774e1", "renesas,pwm-rcar"; reg = <0 0xe6e30000 0 0x8>; + clocks = <&cpg CPG_MOD 523>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 523>; #pwm-cells = <2>; status = "disabled"; + };
- /* placeholder */ + pwm1: pwm@e6e31000 { + compatible = "renesas,pwm-r8a774e1", "renesas,pwm-rcar"; + reg = <0 0xe6e31000 0 0x8>; + clocks = <&cpg CPG_MOD 523>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 523>; + #pwm-cells = <2>; + status = "disabled"; + }; + + pwm2: pwm@e6e32000 { + compatible = "renesas,pwm-r8a774e1", "renesas,pwm-rcar"; + reg = <0 0xe6e32000 0 0x8>; + clocks = <&cpg CPG_MOD 523>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 523>; + #pwm-cells = <2>; + status = "disabled"; + }; + + pwm3: pwm@e6e33000 { + compatible = "renesas,pwm-r8a774e1", "renesas,pwm-rcar"; + reg = <0 0xe6e33000 0 0x8>; + clocks = <&cpg CPG_MOD 523>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 523>; + #pwm-cells = <2>; + status = "disabled"; + }; + + pwm4: pwm@e6e34000 { + compatible = "renesas,pwm-r8a774e1", "renesas,pwm-rcar"; + reg = <0 0xe6e34000 0 0x8>; + clocks = <&cpg CPG_MOD 523>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 523>; + #pwm-cells = <2>; + status = "disabled"; + }; + + pwm5: pwm@e6e35000 { + compatible = "renesas,pwm-r8a774e1", "renesas,pwm-rcar"; + reg = <0 0xe6e35000 0 0x8>; + clocks = <&cpg CPG_MOD 523>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 523>; + #pwm-cells = <2>; + status = "disabled"; + }; + + pwm6: pwm@e6e36000 { + compatible = "renesas,pwm-r8a774e1", "renesas,pwm-rcar"; + reg = <0 0xe6e36000 0 0x8>; + clocks = <&cpg CPG_MOD 523>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 523>; + #pwm-cells = <2>; + status = "disabled"; };
scif0: serial@e6e60000 { @@ -1372,7 +1530,260 @@ status = "disabled"; };
+ vin0: video@e6ef0000 { + compatible = "renesas,vin-r8a774e1"; + reg = <0 0xe6ef0000 0 0x1000>; + interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 811>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 811>; + renesas,id = <0>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin0csi20: endpoint@0 { + reg = <0>; + remote-endpoint = <&csi20vin0>; + }; + vin0csi40: endpoint@2 { + reg = <2>; + remote-endpoint = <&csi40vin0>; + }; + }; + }; + }; + + vin1: video@e6ef1000 { + compatible = "renesas,vin-r8a774e1"; + reg = <0 0xe6ef1000 0 0x1000>; + interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 810>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 810>; + renesas,id = <1>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin1csi20: endpoint@0 { + reg = <0>; + remote-endpoint = <&csi20vin1>; + }; + vin1csi40: endpoint@2 { + reg = <2>; + remote-endpoint = <&csi40vin1>; + }; + }; + }; + }; + + vin2: video@e6ef2000 { + compatible = "renesas,vin-r8a774e1"; + reg = <0 0xe6ef2000 0 0x1000>; + interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 809>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 809>; + renesas,id = <2>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin2csi20: endpoint@0 { + reg = <0>; + remote-endpoint = <&csi20vin2>; + }; + vin2csi40: endpoint@2 { + reg = <2>; + remote-endpoint = <&csi40vin2>; + }; + }; + }; + }; + + vin3: video@e6ef3000 { + compatible = "renesas,vin-r8a774e1"; + reg = <0 0xe6ef3000 0 0x1000>; + interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 808>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 808>; + renesas,id = <3>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin3csi20: endpoint@0 { + reg = <0>; + remote-endpoint = <&csi20vin3>; + }; + vin3csi40: endpoint@2 { + reg = <2>; + remote-endpoint = <&csi40vin3>; + }; + }; + }; + }; + + vin4: video@e6ef4000 { + compatible = "renesas,vin-r8a774e1"; + reg = <0 0xe6ef4000 0 0x1000>; + interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 807>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 807>; + renesas,id = <4>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin4csi20: endpoint@0 { + reg = <0>; + remote-endpoint = <&csi20vin4>; + }; + }; + }; + }; + + vin5: video@e6ef5000 { + compatible = "renesas,vin-r8a774e1"; + reg = <0 0xe6ef5000 0 0x1000>; + interrupts = <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 806>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 806>; + renesas,id = <5>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin5csi20: endpoint@0 { + reg = <0>; + remote-endpoint = <&csi20vin5>; + }; + }; + }; + }; + + vin6: video@e6ef6000 { + compatible = "renesas,vin-r8a774e1"; + reg = <0 0xe6ef6000 0 0x1000>; + interrupts = <GIC_SPI 176 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 805>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 805>; + renesas,id = <6>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin6csi20: endpoint@0 { + reg = <0>; + remote-endpoint = <&csi20vin6>; + }; + }; + }; + }; + + vin7: video@e6ef7000 { + compatible = "renesas,vin-r8a774e1"; + reg = <0 0xe6ef7000 0 0x1000>; + interrupts = <GIC_SPI 171 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 804>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 804>; + renesas,id = <7>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin7csi20: endpoint@0 { + reg = <0>; + remote-endpoint = <&csi20vin7>; + }; + }; + }; + }; + rcar_sound: sound@ec500000 { + /* + * #sound-dai-cells is required + * + * Single DAI : #sound-dai-cells = <0>; <&rcar_sound>; + * Multi DAI : #sound-dai-cells = <1>; <&rcar_sound N>; + */ + /* + * #clock-cells is required for audio_clkout0/1/2/3 + * + * clkout : #clock-cells = <0>; <&rcar_sound>; + * clkout0/1/2/3: #clock-cells = <1>; <&rcar_sound N>; + */ + compatible = "renesas,rcar_sound-r8a774e1", "renesas,rcar_sound-gen3"; reg = <0 0xec500000 0 0x1000>, /* SCU */ <0 0xec5a0000 0 0x100>, /* ADG */ <0 0xec540000 0 0x1000>, /* SSIU */ @@ -1380,71 +1791,569 @@ <0 0xec760000 0 0x200>; /* Audio DMAC peri peri*/ reg-names = "scu", "adg", "ssiu", "ssi", "audmapp";
+ clocks = <&cpg CPG_MOD 1005>, + <&cpg CPG_MOD 1006>, <&cpg CPG_MOD 1007>, + <&cpg CPG_MOD 1008>, <&cpg CPG_MOD 1009>, + <&cpg CPG_MOD 1010>, <&cpg CPG_MOD 1011>, + <&cpg CPG_MOD 1012>, <&cpg CPG_MOD 1013>, + <&cpg CPG_MOD 1014>, <&cpg CPG_MOD 1015>, + <&cpg CPG_MOD 1022>, <&cpg CPG_MOD 1023>, + <&cpg CPG_MOD 1024>, <&cpg CPG_MOD 1025>, + <&cpg CPG_MOD 1026>, <&cpg CPG_MOD 1027>, + <&cpg CPG_MOD 1028>, <&cpg CPG_MOD 1029>, + <&cpg CPG_MOD 1030>, <&cpg CPG_MOD 1031>, + <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, + <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, + <&cpg CPG_MOD 1019>, <&cpg CPG_MOD 1018>, + <&audio_clk_a>, <&audio_clk_b>, + <&audio_clk_c>, + <&cpg CPG_CORE R8A774E1_CLK_S0D4>; + clock-names = "ssi-all", + "ssi.9", "ssi.8", "ssi.7", "ssi.6", + "ssi.5", "ssi.4", "ssi.3", "ssi.2", + "ssi.1", "ssi.0", + "src.9", "src.8", "src.7", "src.6", + "src.5", "src.4", "src.3", "src.2", + "src.1", "src.0", + "mix.1", "mix.0", + "ctu.1", "ctu.0", + "dvc.0", "dvc.1", + "clk_a", "clk_b", "clk_c", "clk_i"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 1005>, + <&cpg 1006>, <&cpg 1007>, + <&cpg 1008>, <&cpg 1009>, + <&cpg 1010>, <&cpg 1011>, + <&cpg 1012>, <&cpg 1013>, + <&cpg 1014>, <&cpg 1015>; + reset-names = "ssi-all", + "ssi.9", "ssi.8", "ssi.7", "ssi.6", + "ssi.5", "ssi.4", "ssi.3", "ssi.2", + "ssi.1", "ssi.0"; status = "disabled";
- /* placeholder */ + rcar_sound,dvc { + dvc0: dvc-0 { + dmas = <&audma1 0xbc>; + dma-names = "tx"; + }; + dvc1: dvc-1 { + dmas = <&audma1 0xbe>; + dma-names = "tx"; + }; + }; + + rcar_sound,mix { + mix0: mix-0 { }; + mix1: mix-1 { }; + }; + + rcar_sound,ctu { + ctu00: ctu-0 { }; + ctu01: ctu-1 { }; + ctu02: ctu-2 { }; + ctu03: ctu-3 { }; + ctu10: ctu-4 { }; + ctu11: ctu-5 { }; + ctu12: ctu-6 { }; + ctu13: ctu-7 { }; + }; + + rcar_sound,src { + src0: src-0 { + interrupts = <GIC_SPI 352 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x85>, <&audma1 0x9a>; + dma-names = "rx", "tx"; + }; + src1: src-1 { + interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x87>, <&audma1 0x9c>; + dma-names = "rx", "tx"; + }; + src2: src-2 { + interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x89>, <&audma1 0x9e>; + dma-names = "rx", "tx"; + }; + src3: src-3 { + interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x8b>, <&audma1 0xa0>; + dma-names = "rx", "tx"; + }; + src4: src-4 { + interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x8d>, <&audma1 0xb0>; + dma-names = "rx", "tx"; + }; + src5: src-5 { + interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x8f>, <&audma1 0xb2>; + dma-names = "rx", "tx"; + }; + src6: src-6 { + interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x91>, <&audma1 0xb4>; + dma-names = "rx", "tx"; + }; + src7: src-7 { + interrupts = <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x93>, <&audma1 0xb6>; + dma-names = "rx", "tx"; + }; + src8: src-8 { + interrupts = <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x95>, <&audma1 0xb8>; + dma-names = "rx", "tx"; + }; + src9: src-9 { + interrupts = <GIC_SPI 361 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x97>, <&audma1 0xba>; + dma-names = "rx", "tx"; + }; + }; + + rcar_sound,ssiu { + ssiu00: ssiu-0 { + dmas = <&audma0 0x15>, <&audma1 0x16>; + dma-names = "rx", "tx"; + }; + ssiu01: ssiu-1 { + dmas = <&audma0 0x35>, <&audma1 0x36>; + dma-names = "rx", "tx"; + }; + ssiu02: ssiu-2 { + dmas = <&audma0 0x37>, <&audma1 0x38>; + dma-names = "rx", "tx"; + }; + ssiu03: ssiu-3 { + dmas = <&audma0 0x47>, <&audma1 0x48>; + dma-names = "rx", "tx"; + }; + ssiu04: ssiu-4 { + dmas = <&audma0 0x3F>, <&audma1 0x40>; + dma-names = "rx", "tx"; + }; + ssiu05: ssiu-5 { + dmas = <&audma0 0x43>, <&audma1 0x44>; + dma-names = "rx", "tx"; + }; + ssiu06: ssiu-6 { + dmas = <&audma0 0x4F>, <&audma1 0x50>; + dma-names = "rx", "tx"; + }; + ssiu07: ssiu-7 { + dmas = <&audma0 0x53>, <&audma1 0x54>; + dma-names = "rx", "tx"; + }; + ssiu10: ssiu-8 { + dmas = <&audma0 0x49>, <&audma1 0x4a>; + dma-names = "rx", "tx"; + }; + ssiu11: ssiu-9 { + dmas = <&audma0 0x4B>, <&audma1 0x4C>; + dma-names = "rx", "tx"; + }; + ssiu12: ssiu-10 { + dmas = <&audma0 0x57>, <&audma1 0x58>; + dma-names = "rx", "tx"; + }; + ssiu13: ssiu-11 { + dmas = <&audma0 0x59>, <&audma1 0x5A>; + dma-names = "rx", "tx"; + }; + ssiu14: ssiu-12 { + dmas = <&audma0 0x5F>, <&audma1 0x60>; + dma-names = "rx", "tx"; + }; + ssiu15: ssiu-13 { + dmas = <&audma0 0xC3>, <&audma1 0xC4>; + dma-names = "rx", "tx"; + }; + ssiu16: ssiu-14 { + dmas = <&audma0 0xC7>, <&audma1 0xC8>; + dma-names = "rx", "tx"; + }; + ssiu17: ssiu-15 { + dmas = <&audma0 0xCB>, <&audma1 0xCC>; + dma-names = "rx", "tx"; + }; + ssiu20: ssiu-16 { + dmas = <&audma0 0x63>, <&audma1 0x64>; + dma-names = "rx", "tx"; + }; + ssiu21: ssiu-17 { + dmas = <&audma0 0x67>, <&audma1 0x68>; + dma-names = "rx", "tx"; + }; + ssiu22: ssiu-18 { + dmas = <&audma0 0x6B>, <&audma1 0x6C>; + dma-names = "rx", "tx"; + }; + ssiu23: ssiu-19 { + dmas = <&audma0 0x6D>, <&audma1 0x6E>; + dma-names = "rx", "tx"; + }; + ssiu24: ssiu-20 { + dmas = <&audma0 0xCF>, <&audma1 0xCE>; + dma-names = "rx", "tx"; + }; + ssiu25: ssiu-21 { + dmas = <&audma0 0xEB>, <&audma1 0xEC>; + dma-names = "rx", "tx"; + }; + ssiu26: ssiu-22 { + dmas = <&audma0 0xED>, <&audma1 0xEE>; + dma-names = "rx", "tx"; + }; + ssiu27: ssiu-23 { + dmas = <&audma0 0xEF>, <&audma1 0xF0>; + dma-names = "rx", "tx"; + }; + ssiu30: ssiu-24 { + dmas = <&audma0 0x6f>, <&audma1 0x70>; + dma-names = "rx", "tx"; + }; + ssiu31: ssiu-25 { + dmas = <&audma0 0x21>, <&audma1 0x22>; + dma-names = "rx", "tx"; + }; + ssiu32: ssiu-26 { + dmas = <&audma0 0x23>, <&audma1 0x24>; + dma-names = "rx", "tx"; + }; + ssiu33: ssiu-27 { + dmas = <&audma0 0x25>, <&audma1 0x26>; + dma-names = "rx", "tx"; + }; + ssiu34: ssiu-28 { + dmas = <&audma0 0x27>, <&audma1 0x28>; + dma-names = "rx", "tx"; + }; + ssiu35: ssiu-29 { + dmas = <&audma0 0x29>, <&audma1 0x2A>; + dma-names = "rx", "tx"; + }; + ssiu36: ssiu-30 { + dmas = <&audma0 0x2B>, <&audma1 0x2C>; + dma-names = "rx", "tx"; + }; + ssiu37: ssiu-31 { + dmas = <&audma0 0x2D>, <&audma1 0x2E>; + dma-names = "rx", "tx"; + }; + ssiu40: ssiu-32 { + dmas = <&audma0 0x71>, <&audma1 0x72>; + dma-names = "rx", "tx"; + }; + ssiu41: ssiu-33 { + dmas = <&audma0 0x17>, <&audma1 0x18>; + dma-names = "rx", "tx"; + }; + ssiu42: ssiu-34 { + dmas = <&audma0 0x19>, <&audma1 0x1A>; + dma-names = "rx", "tx"; + }; + ssiu43: ssiu-35 { + dmas = <&audma0 0x1B>, <&audma1 0x1C>; + dma-names = "rx", "tx"; + }; + ssiu44: ssiu-36 { + dmas = <&audma0 0x1D>, <&audma1 0x1E>; + dma-names = "rx", "tx"; + }; + ssiu45: ssiu-37 { + dmas = <&audma0 0x1F>, <&audma1 0x20>; + dma-names = "rx", "tx"; + }; + ssiu46: ssiu-38 { + dmas = <&audma0 0x31>, <&audma1 0x32>; + dma-names = "rx", "tx"; + }; + ssiu47: ssiu-39 { + dmas = <&audma0 0x33>, <&audma1 0x34>; + dma-names = "rx", "tx"; + }; + ssiu50: ssiu-40 { + dmas = <&audma0 0x73>, <&audma1 0x74>; + dma-names = "rx", "tx"; + }; + ssiu60: ssiu-41 { + dmas = <&audma0 0x75>, <&audma1 0x76>; + dma-names = "rx", "tx"; + }; + ssiu70: ssiu-42 { + dmas = <&audma0 0x79>, <&audma1 0x7a>; + dma-names = "rx", "tx"; + }; + ssiu80: ssiu-43 { + dmas = <&audma0 0x7b>, <&audma1 0x7c>; + dma-names = "rx", "tx"; + }; + ssiu90: ssiu-44 { + dmas = <&audma0 0x7d>, <&audma1 0x7e>; + dma-names = "rx", "tx"; + }; + ssiu91: ssiu-45 { + dmas = <&audma0 0x7F>, <&audma1 0x80>; + dma-names = "rx", "tx"; + }; + ssiu92: ssiu-46 { + dmas = <&audma0 0x81>, <&audma1 0x82>; + dma-names = "rx", "tx"; + }; + ssiu93: ssiu-47 { + dmas = <&audma0 0x83>, <&audma1 0x84>; + dma-names = "rx", "tx"; + }; + ssiu94: ssiu-48 { + dmas = <&audma0 0xA3>, <&audma1 0xA4>; + dma-names = "rx", "tx"; + }; + ssiu95: ssiu-49 { + dmas = <&audma0 0xA5>, <&audma1 0xA6>; + dma-names = "rx", "tx"; + }; + ssiu96: ssiu-50 { + dmas = <&audma0 0xA7>, <&audma1 0xA8>; + dma-names = "rx", "tx"; + }; + ssiu97: ssiu-51 { + dmas = <&audma0 0xA9>, <&audma1 0xAA>; + dma-names = "rx", "tx"; + }; + };
rcar_sound,ssi { + ssi0: ssi-0 { + interrupts = <GIC_SPI 370 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x01>, <&audma1 0x02>; + dma-names = "rx", "tx"; + }; + ssi1: ssi-1 { + interrupts = <GIC_SPI 371 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x03>, <&audma1 0x04>; + dma-names = "rx", "tx"; + }; ssi2: ssi-2 { - /* placeholder */ + interrupts = <GIC_SPI 372 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x05>, <&audma1 0x06>; + dma-names = "rx", "tx"; + }; + ssi3: ssi-3 { + interrupts = <GIC_SPI 373 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x07>, <&audma1 0x08>; + dma-names = "rx", "tx"; + }; + ssi4: ssi-4 { + interrupts = <GIC_SPI 374 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x09>, <&audma1 0x0a>; + dma-names = "rx", "tx"; + }; + ssi5: ssi-5 { + interrupts = <GIC_SPI 375 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x0b>, <&audma1 0x0c>; + dma-names = "rx", "tx"; + }; + ssi6: ssi-6 { + interrupts = <GIC_SPI 376 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x0d>, <&audma1 0x0e>; + dma-names = "rx", "tx"; + }; + ssi7: ssi-7 { + interrupts = <GIC_SPI 377 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x0f>, <&audma1 0x10>; + dma-names = "rx", "tx"; + }; + ssi8: ssi-8 { + interrupts = <GIC_SPI 378 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x11>, <&audma1 0x12>; + dma-names = "rx", "tx"; + }; + ssi9: ssi-9 { + interrupts = <GIC_SPI 379 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&audma0 0x13>, <&audma1 0x14>; + dma-names = "rx", "tx"; }; }; };
+ audma0: dma-controller@ec700000 { + compatible = "renesas,dmac-r8a774e1", + "renesas,rcar-dmac"; + reg = <0 0xec700000 0 0x10000>; + interrupts = <GIC_SPI 350 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 333 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "error", + "ch0", "ch1", "ch2", "ch3", + "ch4", "ch5", "ch6", "ch7", + "ch8", "ch9", "ch10", "ch11", + "ch12", "ch13", "ch14", "ch15"; + clocks = <&cpg CPG_MOD 502>; + clock-names = "fck"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 502>; + #dma-cells = <1>; + dma-channels = <16>; + iommus = <&ipmmu_mp0 0>, <&ipmmu_mp0 1>, + <&ipmmu_mp0 2>, <&ipmmu_mp0 3>, + <&ipmmu_mp0 4>, <&ipmmu_mp0 5>, + <&ipmmu_mp0 6>, <&ipmmu_mp0 7>, + <&ipmmu_mp0 8>, <&ipmmu_mp0 9>, + <&ipmmu_mp0 10>, <&ipmmu_mp0 11>, + <&ipmmu_mp0 12>, <&ipmmu_mp0 13>, + <&ipmmu_mp0 14>, <&ipmmu_mp0 15>; + }; + + audma1: dma-controller@ec720000 { + compatible = "renesas,dmac-r8a774e1", + "renesas,rcar-dmac"; + reg = <0 0xec720000 0 0x10000>; + interrupts = <GIC_SPI 351 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 344 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 345 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 346 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 347 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 348 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 349 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 382 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 383 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "error", + "ch0", "ch1", "ch2", "ch3", + "ch4", "ch5", "ch6", "ch7", + "ch8", "ch9", "ch10", "ch11", + "ch12", "ch13", "ch14", "ch15"; + clocks = <&cpg CPG_MOD 501>; + clock-names = "fck"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 501>; + #dma-cells = <1>; + dma-channels = <16>; + iommus = <&ipmmu_mp0 16>, <&ipmmu_mp0 17>, + <&ipmmu_mp0 18>, <&ipmmu_mp0 19>, + <&ipmmu_mp0 20>, <&ipmmu_mp0 21>, + <&ipmmu_mp0 22>, <&ipmmu_mp0 23>, + <&ipmmu_mp0 24>, <&ipmmu_mp0 25>, + <&ipmmu_mp0 26>, <&ipmmu_mp0 27>, + <&ipmmu_mp0 28>, <&ipmmu_mp0 29>, + <&ipmmu_mp0 30>, <&ipmmu_mp0 31>; + }; + xhci0: usb@ee000000 { + compatible = "renesas,xhci-r8a774e1", + "renesas,rcar-gen3-xhci"; reg = <0 0xee000000 0 0xc00>; + interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 328>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 328>; status = "disabled"; - - /* placeholder */ };
usb3_peri0: usb@ee020000 { + compatible = "renesas,r8a774e1-usb3-peri", + "renesas,rcar-gen3-usb3-peri"; reg = <0 0xee020000 0 0x400>; + interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 328>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 328>; status = "disabled"; - - /* placeholder */ };
ohci0: usb@ee080000 { + compatible = "generic-ohci"; reg = <0 0xee080000 0 0x100>; + interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; + phys = <&usb2_phy0 1>; + phy-names = "usb"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 703>, <&cpg 704>; status = "disabled"; - - /* placeholder */ };
ohci1: usb@ee0a0000 { + compatible = "generic-ohci"; reg = <0 0xee0a0000 0 0x100>; + interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 702>; + phys = <&usb2_phy1 1>; + phy-names = "usb"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 702>; status = "disabled"; - - /* placeholder */ };
ehci0: usb@ee080100 { + compatible = "generic-ehci"; reg = <0 0xee080100 0 0x100>; + interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; + phys = <&usb2_phy0 2>; + phy-names = "usb"; + companion = <&ohci0>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 703>, <&cpg 704>; status = "disabled"; - - /* placeholder */ };
ehci1: usb@ee0a0100 { + compatible = "generic-ehci"; reg = <0 0xee0a0100 0 0x100>; + interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 702>; + phys = <&usb2_phy1 2>; + phy-names = "usb"; + companion = <&ohci1>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 702>; status = "disabled"; - - /* placeholder */ };
usb2_phy0: usb-phy@ee080200 { + compatible = "renesas,usb2-phy-r8a774e1", + "renesas,rcar-gen3-usb2-phy"; reg = <0 0xee080200 0 0x700>; + interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 703>, <&cpg 704>; + #phy-cells = <1>; status = "disabled"; - - /* placeholder */ };
usb2_phy1: usb-phy@ee0a0200 { + compatible = "renesas,usb2-phy-r8a774e1", + "renesas,rcar-gen3-usb2-phy"; reg = <0 0xee0a0200 0 0x700>; + clocks = <&cpg CPG_MOD 702>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 702>; + #phy-cells = <1>; status = "disabled"; - - /* placeholder */ };
sdhi0: mmc@ee100000 { @@ -1499,6 +2408,35 @@ status = "disabled"; };
+ rpc: spi@ee200000 { + compatible = "renesas,r8a774e1-rpc-if", + "renesas,rcar-gen3-rpc-if"; + reg = <0 0xee200000 0 0x200>, + <0 0x08000000 0 0x4000000>, + <0 0xee208000 0 0x100>; + reg-names = "regs", "dirmap", "wbuf"; + interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 917>; + clock-names = "rpc"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 917>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + sata: sata@ee300000 { + compatible = "renesas,sata-r8a774e1", + "renesas,rcar-gen3-sata"; + reg = <0 0xee300000 0 0x200000>; + interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 815>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 815>; + iommus = <&ipmmu_hc 2>; + status = "disabled"; + }; + gic: interrupt-controller@f1010000 { compatible = "arm,gic-400"; #interrupt-cells = <3>; @@ -1517,53 +2455,435 @@ };
pciec0: pcie@fe000000 { + compatible = "renesas,pcie-r8a774e1", + "renesas,pcie-rcar-gen3"; reg = <0 0xfe000000 0 0x80000>; #address-cells = <3>; #size-cells = <2>; + bus-range = <0x00 0xff>; + device_type = "pci"; + ranges = <0x01000000 0 0x00000000 0 0xfe100000 0 0x00100000>, + <0x02000000 0 0xfe200000 0 0xfe200000 0 0x00200000>, + <0x02000000 0 0x30000000 0 0x30000000 0 0x08000000>, + <0x42000000 0 0x38000000 0 0x38000000 0 0x08000000>; + /* Map all possible DDR as inbound ranges */ + dma-ranges = <0x42000000 0 0x40000000 0 0x40000000 0 0x80000000>; + interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 0>; + interrupt-map = <0 0 0 0 &gic GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 319>, <&pcie_bus_clk>; + clock-names = "pcie", "pcie_bus"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 319>; status = "disabled"; + };
- /* placeholder */ + pciec1: pcie@ee800000 { + compatible = "renesas,pcie-r8a774e1", + "renesas,pcie-rcar-gen3"; + reg = <0 0xee800000 0 0x80000>; + #address-cells = <3>; + #size-cells = <2>; + bus-range = <0x00 0xff>; + device_type = "pci"; + ranges = <0x01000000 0 0x00000000 0 0xee900000 0 0x00100000>, + <0x02000000 0 0xeea00000 0 0xeea00000 0 0x00200000>, + <0x02000000 0 0xc0000000 0 0xc0000000 0 0x08000000>, + <0x42000000 0 0xc8000000 0 0xc8000000 0 0x08000000>; + /* Map all possible DDR as inbound ranges */ + dma-ranges = <0x42000000 0 0x40000000 0 0x40000000 0 0x80000000>; + interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 0>; + interrupt-map = <0 0 0 0 &gic GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 318>, <&pcie_bus_clk>; + clock-names = "pcie", "pcie_bus"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 318>; + status = "disabled"; + }; + + pciec0_ep: pcie-ep@fe000000 { + compatible = "renesas,r8a774e1-pcie-ep", + "renesas,rcar-gen3-pcie-ep"; + reg = <0x0 0xfe000000 0 0x80000>, + <0x0 0xfe100000 0 0x100000>, + <0x0 0xfe200000 0 0x200000>, + <0x0 0x30000000 0 0x8000000>, + <0x0 0x38000000 0 0x8000000>; + reg-names = "apb-base", "memory0", "memory1", "memory2", "memory3"; + interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 319>; + clock-names = "pcie"; + resets = <&cpg 319>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + status = "disabled"; + }; + + pciec1_ep: pcie-ep@ee800000 { + compatible = "renesas,r8a774e1-pcie-ep", + "renesas,rcar-gen3-pcie-ep"; + reg = <0x0 0xee800000 0 0x80000>, + <0x0 0xee900000 0 0x100000>, + <0x0 0xeea00000 0 0x200000>, + <0x0 0xc0000000 0 0x8000000>, + <0x0 0xc8000000 0 0x8000000>; + reg-names = "apb-base", "memory0", "memory1", "memory2", "memory3"; + interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 318>; + clock-names = "pcie"; + resets = <&cpg 318>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + status = "disabled"; + }; + + vspbc: vsp@fe920000 { + compatible = "renesas,vsp2"; + reg = <0 0xfe920000 0 0x8000>; + interrupts = <GIC_SPI 465 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 624>; + power-domains = <&sysc R8A774E1_PD_A3VP>; + resets = <&cpg 624>; + + renesas,fcp = <&fcpvb1>; + }; + + vspbd: vsp@fe960000 { + compatible = "renesas,vsp2"; + reg = <0 0xfe960000 0 0x8000>; + interrupts = <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 626>; + power-domains = <&sysc R8A774E1_PD_A3VP>; + resets = <&cpg 626>; + + renesas,fcp = <&fcpvb0>; + }; + + vspd0: vsp@fea20000 { + compatible = "renesas,vsp2"; + reg = <0 0xfea20000 0 0x5000>; + interrupts = <GIC_SPI 466 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 623>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 623>; + + renesas,fcp = <&fcpvd0>; + }; + + vspd1: vsp@fea28000 { + compatible = "renesas,vsp2"; + reg = <0 0xfea28000 0 0x5000>; + interrupts = <GIC_SPI 467 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 622>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 622>; + + renesas,fcp = <&fcpvd1>; + }; + + vspi0: vsp@fe9a0000 { + compatible = "renesas,vsp2"; + reg = <0 0xfe9a0000 0 0x8000>; + interrupts = <GIC_SPI 444 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 631>; + power-domains = <&sysc R8A774E1_PD_A3VP>; + resets = <&cpg 631>; + + renesas,fcp = <&fcpvi0>; + }; + + vspi1: vsp@fe9b0000 { + compatible = "renesas,vsp2"; + reg = <0 0xfe9b0000 0 0x8000>; + interrupts = <GIC_SPI 445 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 630>; + power-domains = <&sysc R8A774E1_PD_A3VP>; + resets = <&cpg 630>; + + renesas,fcp = <&fcpvi1>; + }; + + fdp1@fe940000 { + compatible = "renesas,fdp1"; + reg = <0 0xfe940000 0 0x2400>; + interrupts = <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 119>; + power-domains = <&sysc R8A774E1_PD_A3VP>; + resets = <&cpg 119>; + renesas,fcp = <&fcpf0>; + }; + + fdp1@fe944000 { + compatible = "renesas,fdp1"; + reg = <0 0xfe944000 0 0x2400>; + interrupts = <GIC_SPI 263 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 118>; + power-domains = <&sysc R8A774E1_PD_A3VP>; + resets = <&cpg 118>; + renesas,fcp = <&fcpf1>; + }; + + fcpf0: fcp@fe950000 { + compatible = "renesas,fcpf"; + reg = <0 0xfe950000 0 0x200>; + clocks = <&cpg CPG_MOD 615>; + power-domains = <&sysc R8A774E1_PD_A3VP>; + resets = <&cpg 615>; + }; + + fcpf1: fcp@fe951000 { + compatible = "renesas,fcpf"; + reg = <0 0xfe951000 0 0x200>; + clocks = <&cpg CPG_MOD 614>; + power-domains = <&sysc R8A774E1_PD_A3VP>; + resets = <&cpg 614>; + }; + + fcpvb0: fcp@fe96f000 { + compatible = "renesas,fcpv"; + reg = <0 0xfe96f000 0 0x200>; + clocks = <&cpg CPG_MOD 607>; + power-domains = <&sysc R8A774E1_PD_A3VP>; + resets = <&cpg 607>; + }; + + fcpvb1: fcp@fe92f000 { + compatible = "renesas,fcpv"; + reg = <0 0xfe92f000 0 0x200>; + clocks = <&cpg CPG_MOD 606>; + power-domains = <&sysc R8A774E1_PD_A3VP>; + resets = <&cpg 606>; + }; + + fcpvi0: fcp@fe9af000 { + compatible = "renesas,fcpv"; + reg = <0 0xfe9af000 0 0x200>; + clocks = <&cpg CPG_MOD 611>; + power-domains = <&sysc R8A774E1_PD_A3VP>; + resets = <&cpg 611>; + }; + + fcpvi1: fcp@fe9bf000 { + compatible = "renesas,fcpv"; + reg = <0 0xfe9bf000 0 0x200>; + clocks = <&cpg CPG_MOD 610>; + power-domains = <&sysc R8A774E1_PD_A3VP>; + resets = <&cpg 610>; + }; + + fcpvd0: fcp@fea27000 { + compatible = "renesas,fcpv"; + reg = <0 0xfea27000 0 0x200>; + clocks = <&cpg CPG_MOD 603>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 603>; + }; + + fcpvd1: fcp@fea2f000 { + compatible = "renesas,fcpv"; + reg = <0 0xfea2f000 0 0x200>; + clocks = <&cpg CPG_MOD 602>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 602>; + }; + + csi20: csi2@fea80000 { + compatible = "renesas,r8a774e1-csi2"; + reg = <0 0xfea80000 0 0x10000>; + interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 714>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 714>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + csi20vin0: endpoint@0 { + reg = <0>; + remote-endpoint = <&vin0csi20>; + }; + csi20vin1: endpoint@1 { + reg = <1>; + remote-endpoint = <&vin1csi20>; + }; + csi20vin2: endpoint@2 { + reg = <2>; + remote-endpoint = <&vin2csi20>; + }; + csi20vin3: endpoint@3 { + reg = <3>; + remote-endpoint = <&vin3csi20>; + }; + csi20vin4: endpoint@4 { + reg = <4>; + remote-endpoint = <&vin4csi20>; + }; + csi20vin5: endpoint@5 { + reg = <5>; + remote-endpoint = <&vin5csi20>; + }; + csi20vin6: endpoint@6 { + reg = <6>; + remote-endpoint = <&vin6csi20>; + }; + csi20vin7: endpoint@7 { + reg = <7>; + remote-endpoint = <&vin7csi20>; + }; + }; + }; + }; + + csi40: csi2@feaa0000 { + compatible = "renesas,r8a774e1-csi2"; + reg = <0 0xfeaa0000 0 0x10000>; + interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 716>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 716>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + csi40vin0: endpoint@0 { + reg = <0>; + remote-endpoint = <&vin0csi40>; + }; + csi40vin1: endpoint@1 { + reg = <1>; + remote-endpoint = <&vin1csi40>; + }; + csi40vin2: endpoint@2 { + reg = <2>; + remote-endpoint = <&vin2csi40>; + }; + csi40vin3: endpoint@3 { + reg = <3>; + remote-endpoint = <&vin3csi40>; + }; + }; + }; };
hdmi0: hdmi@fead0000 { + compatible = "renesas,r8a774e1-hdmi", + "renesas,rcar-gen3-hdmi"; reg = <0 0xfead0000 0 0x10000>; + interrupts = <GIC_SPI 389 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 729>, + <&cpg CPG_CORE R8A774E1_CLK_HDMI>; + clock-names = "iahb", "isfr"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 729>; status = "disabled";
- /* placeholder */ - ports { #address-cells = <1>; #size-cells = <0>;
port@0 { reg = <0>; + dw_hdmi0_in: endpoint { + remote-endpoint = <&du_out_hdmi0>; + }; }; port@1 { reg = <1>; }; port@2 { + /* HDMI sound */ reg = <2>; }; }; };
du: display@feb00000 { + compatible = "renesas,du-r8a774e1"; reg = <0 0xfeb00000 0 0x80000>; + interrupts = <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 270 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 724>, + <&cpg CPG_MOD 723>, + <&cpg CPG_MOD 721>; + clock-names = "du.0", "du.1", "du.3"; + resets = <&cpg 724>, <&cpg 722>; + reset-names = "du.0", "du.3"; status = "disabled";
- /* placeholder */ + renesas,vsps = <&vspd0 0>, <&vspd1 0>, <&vspd0 1>; + ports { #address-cells = <1>; #size-cells = <0>;
port@0 { reg = <0>; + du_out_rgb: endpoint { + }; }; port@1 { reg = <1>; + du_out_hdmi0: endpoint { + remote-endpoint = <&dw_hdmi0_in>; + }; }; port@2 { reg = <2>; + du_out_lvds0: endpoint { + remote-endpoint = <&lvds0_in>; + }; + }; + }; + }; + + lvds0: lvds@feb90000 { + compatible = "renesas,r8a774e1-lvds"; + reg = <0 0xfeb90000 0 0x14>; + clocks = <&cpg CPG_MOD 727>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 727>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + lvds0_in: endpoint { + remote-endpoint = <&du_out_lvds0>; + }; + }; + port@1 { + reg = <1>; + lvds0_out: endpoint { + }; }; }; };
Update the RZ/G2N dtsi from Renesas repo destined to become 5.12-rc1.
Signed-off-by: Adam Ford aford173@gmail.com --- arch/arm/dts/r8a774b1.dtsi | 76 +++++++++++++++++++++++++++++++++++++- 1 file changed, 74 insertions(+), 2 deletions(-)
V2: No Change
diff --git a/arch/arm/dts/r8a774b1.dtsi b/arch/arm/dts/r8a774b1.dtsi index 23119c0ae7..5b05474dc2 100644 --- a/arch/arm/dts/r8a774b1.dtsi +++ b/arch/arm/dts/r8a774b1.dtsi @@ -2,7 +2,7 @@ /* * Device Tree Source for the r8a774b1 SoC * - * Copyright (C) 2020 Renesas Electronics Corp. + * Copyright (C) 2019 Renesas Electronics Corp. */
#include <dt-bindings/interrupt-controller/irq.h> @@ -282,7 +282,7 @@ resets = <&cpg 905>; };
- pfc: pin-controller@e6060000 { + pfc: pinctrl@e6060000 { compatible = "renesas,pfc-r8a774b1"; reg = <0 0xe6060000 0 0x50c>; }; @@ -709,6 +709,21 @@ status = "disabled"; };
+ usb2_clksel: clock-controller@e6590630 { + compatible = "renesas,r8a774b1-rcar-usb2-clock-sel", + "renesas,rcar-gen3-usb2-clock-sel"; + reg = <0 0xe6590630 0 0x02>; + clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>, + <&usb_extal_clk>, <&usb3s0_clk>; + clock-names = "ehci_ohci", "hs-usb-if", + "usb_extal", "usb_xtal"; + #clock-cells = <0>; + power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; + resets = <&cpg 703>, <&cpg 704>; + reset-names = "ehci_ohci", "hs-usb-if"; + status = "disabled"; + }; + usb_dmac0: dma-controller@e65a0000 { compatible = "renesas,r8a774b1-usb-dmac", "renesas,usb-dmac"; @@ -989,6 +1004,8 @@ power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; resets = <&cpg 812>; phy-mode = "rgmii"; + rx-internal-delay-ps = <0>; + tx-internal-delay-ps = <0>; iommus = <&ipmmu_ds0 16>; #address-cells = <1>; #size-cells = <0>; @@ -2158,6 +2175,23 @@ status = "disabled"; };
+ rpc: spi@ee200000 { + compatible = "renesas,r8a774b1-rpc-if", + "renesas,rcar-gen3-rpc-if"; + reg = <0 0xee200000 0 0x200>, + <0 0x08000000 0 0x4000000>, + <0 0xee208000 0 0x100>; + reg-names = "regs", "dirmap", "wbuf"; + interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 917>; + clock-names = "rpc"; + power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; + resets = <&cpg 917>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + sata: sata@ee300000 { compatible = "renesas,sata-r8a774b1", "renesas,rcar-gen3-sata"; @@ -2240,6 +2274,44 @@ status = "disabled"; };
+ pciec0_ep: pcie-ep@fe000000 { + compatible = "renesas,r8a774b1-pcie-ep", + "renesas,rcar-gen3-pcie-ep"; + reg = <0x0 0xfe000000 0 0x80000>, + <0x0 0xfe100000 0 0x100000>, + <0x0 0xfe200000 0 0x200000>, + <0x0 0x30000000 0 0x8000000>, + <0x0 0x38000000 0 0x8000000>; + reg-names = "apb-base", "memory0", "memory1", "memory2", "memory3"; + interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 319>; + clock-names = "pcie"; + resets = <&cpg 319>; + power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; + status = "disabled"; + }; + + pciec1_ep: pcie-ep@ee800000 { + compatible = "renesas,r8a774b1-pcie-ep", + "renesas,rcar-gen3-pcie-ep"; + reg = <0x0 0xee800000 0 0x80000>, + <0x0 0xee900000 0 0x100000>, + <0x0 0xeea00000 0 0x200000>, + <0x0 0xc0000000 0 0x8000000>, + <0x0 0xc8000000 0 0x8000000>; + reg-names = "apb-base", "memory0", "memory1", "memory2", "memory3"; + interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 318>; + clock-names = "pcie"; + resets = <&cpg 318>; + power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; + status = "disabled"; + }; + fdp1@fe940000 { compatible = "renesas,fdp1"; reg = <0 0xfe940000 0 0x2400>;
The Beacon EmbeddedWorks kit is based on the R8A774B1 SoC also known as the RZ/G2N.
The kit consists of a SOM + Baseboard and supports microSD, eMMC, Ethernet, a couple celular radios, two CAN interfaces, Bluetooth and WiFi. It shares much of the same design as the RZ/G2M dev kit.
Signed-off-by: Adam Ford aford173@gmail.com --- arch/arm/dts/Makefile | 1 + .../dts/r8a774b1-beacon-rzg2n-kit-u-boot.dtsi | 34 +++++++++ arch/arm/dts/r8a774b1-beacon-rzg2n-kit.dts | 66 +++++++++++++++++ arch/arm/mach-rmobile/Kconfig.64 | 5 ++ board/beacon/beacon-rzg2m/Kconfig | 2 +- configs/r8a774b1_beacon_defconfig | 71 +++++++++++++++++++ 6 files changed, 178 insertions(+), 1 deletion(-)
V2: Fix MMC location of env
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 858b79ac97..71f49cc79b 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -809,6 +809,7 @@ dtb-$(CONFIG_RCAR_GEN2) += \
dtb-$(CONFIG_RCAR_GEN3) += \ r8a774a1-beacon-rzg2m-kit.dtb \ + r8a774b1-beacon-rzg2n-kit.dtb \ r8a77950-ulcb-u-boot.dtb \ r8a77950-salvator-x-u-boot.dtb \ r8a77960-ulcb-u-boot.dtb \ diff --git a/arch/arm/dts/r8a774b1-beacon-rzg2n-kit-u-boot.dtsi b/arch/arm/dts/r8a774b1-beacon-rzg2n-kit-u-boot.dtsi new file mode 100644 index 0000000000..a0c0a7f35c --- /dev/null +++ b/arch/arm/dts/r8a774b1-beacon-rzg2n-kit-u-boot.dtsi @@ -0,0 +1,34 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright 2020 Compass Electronics Group, LLC + */ + +/ { + soc { + u-boot,dm-pre-reloc; + }; +}; + +&cpg { + u-boot,dm-pre-reloc; +}; + +&extal_clk { + u-boot,dm-pre-reloc; +}; + +&prr { + u-boot,dm-pre-reloc; +}; + +&extalr_clk { + u-boot,dm-pre-reloc; +}; + +&sdhi0 { + /delete-property/ cd-gpios; +}; + +&sdhi2 { + status = "disabled"; +}; diff --git a/arch/arm/dts/r8a774b1-beacon-rzg2n-kit.dts b/arch/arm/dts/r8a774b1-beacon-rzg2n-kit.dts new file mode 100644 index 0000000000..71763f4402 --- /dev/null +++ b/arch/arm/dts/r8a774b1-beacon-rzg2n-kit.dts @@ -0,0 +1,66 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright 2020, Compass Electronics Group, LLC + */ + +/dts-v1/; + +#include "r8a774b1.dtsi" +#include "beacon-renesom-som.dtsi" +#include "beacon-renesom-baseboard.dtsi" + +/ { + model = "Beacon Embedded Works RZ/G2N Development Kit"; + compatible = "beacon,beacon-rzg2n", "renesas,r8a774b1"; + + aliases { + serial0 = &scif2; + serial1 = &hscif0; + serial2 = &hscif1; + serial3 = &scif0; + serial4 = &hscif2; + serial5 = &scif5; + serial6 = &scif4; + ethernet0 = &avb; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; +}; + +&du { + pinctrl-0 = <&du_pins>; + pinctrl-names = "default"; + status = "okay"; + + clocks = <&cpg CPG_MOD 724>, + <&cpg CPG_MOD 723>, + <&cpg CPG_MOD 721>, + <&versaclock5 1>, + <&x302_clk>, + <&versaclock5 2>; + clock-names = "du.0", "du.1", "du.3", + "dclkin.0", "dclkin.1", "dclkin.3"; +}; + +/* Reference versaclock instead of audio_clk_a */ +&rcar_sound { + clocks = <&cpg CPG_MOD 1005>, + <&cpg CPG_MOD 1006>, <&cpg CPG_MOD 1007>, + <&cpg CPG_MOD 1008>, <&cpg CPG_MOD 1009>, + <&cpg CPG_MOD 1010>, <&cpg CPG_MOD 1011>, + <&cpg CPG_MOD 1012>, <&cpg CPG_MOD 1013>, + <&cpg CPG_MOD 1014>, <&cpg CPG_MOD 1015>, + <&cpg CPG_MOD 1022>, <&cpg CPG_MOD 1023>, + <&cpg CPG_MOD 1024>, <&cpg CPG_MOD 1025>, + <&cpg CPG_MOD 1026>, <&cpg CPG_MOD 1027>, + <&cpg CPG_MOD 1028>, <&cpg CPG_MOD 1029>, + <&cpg CPG_MOD 1030>, <&cpg CPG_MOD 1031>, + <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, + <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, + <&cpg CPG_MOD 1019>, <&cpg CPG_MOD 1018>, + <&versaclock6_bb 4>, <&audio_clk_b>, + <&audio_clk_c>, + <&cpg CPG_CORE R8A774B1_CLK_S0D4>; +}; diff --git a/arch/arm/mach-rmobile/Kconfig.64 b/arch/arm/mach-rmobile/Kconfig.64 index 0ef6cf619b..35354126e4 100644 --- a/arch/arm/mach-rmobile/Kconfig.64 +++ b/arch/arm/mach-rmobile/Kconfig.64 @@ -65,6 +65,11 @@ config TARGET_BEACON_RZG2M select R8A774A1 select PINCTRL_PFC_R8A774A1
+config TARGET_BEACON_RZG2N + bool "Beacon EmbeddedWorks RZ/G2N Dev Kit" + select R8A774B1 + select PINCTRL_PFC_R8A774B1 + config TARGET_CONDOR bool "Condor board" imply R8A77980 diff --git a/board/beacon/beacon-rzg2m/Kconfig b/board/beacon/beacon-rzg2m/Kconfig index c03857cf2f..9c653e386e 100644 --- a/board/beacon/beacon-rzg2m/Kconfig +++ b/board/beacon/beacon-rzg2m/Kconfig @@ -1,4 +1,4 @@ -if TARGET_BEACON_RZG2M +if TARGET_BEACON_RZG2M || TARGET_BEACON_RZG2N
config SYS_SOC default "rmobile" diff --git a/configs/r8a774b1_beacon_defconfig b/configs/r8a774b1_beacon_defconfig new file mode 100644 index 0000000000..e12ca4d433 --- /dev/null +++ b/configs/r8a774b1_beacon_defconfig @@ -0,0 +1,71 @@ +CONFIG_ARM=y +CONFIG_ARCH_RMOBILE=y +CONFIG_SYS_TEXT_BASE=0x50000000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_OFFSET=0x0 +CONFIG_DM_GPIO=y +CONFIG_RCAR_GEN3=y +CONFIG_R8A774B1=y +CONFIG_TARGET_BEACON_RZG2N=y +# CONFIG_SPL is not set +CONFIG_DEFAULT_DEVICE_TREE="r8a774b1-beacon-rzg2n-kit" +CONFIG_FIT=y +CONFIG_SUPPORT_RAW_INITRD=y +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_DEFAULT_FDT_FILE="r8a774b1-beacon-rzg2n-kit.dtb" +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_MMC_ENV_DEV=1 +CONFIG_SYS_MMC_ENV_PART=2 +CONFIG_VERSION_VARIABLE=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y +CONFIG_CLK=y +CONFIG_CLK_RENESAS=y +CONFIG_RCAR_GPIO=y +CONFIG_DM_PCA953X=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_RCAR_I2C=y +CONFIG_SYS_I2C_RCAR_IIC=y +CONFIG_DM_MMC=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS200_SUPPORT=y +CONFIG_RENESAS_SDHI=y +CONFIG_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_BITBANGMII=y +CONFIG_PHY_REALTEK=y +CONFIG_DM_ETH=y +CONFIG_RENESAS_RAVB=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_SCIF_CONSOLE=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_RENESAS_RPC_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_STORAGE=y +CONFIG_OF_LIBFDT_OVERLAY=y
The Beacon EmbeddedWorks kit is based on the R8A774E1 SoC also known as the RZ/G2H.
The kit consists of a SOM + Baseboard and supports microSD, eMMC, Ethernet, a couple celular radios, two CAN interfaces, Bluetooth and WiFi. It shares much of the same design as the RZ/G2M and RZ/G2N dev kits.
Signed-off-by: Adam Ford aford173@gmail.com --- arch/arm/dts/Makefile | 1 + .../dts/r8a774e1-beacon-rzg2h-kit-u-boot.dtsi | 44 ++++++++++++ arch/arm/dts/r8a774e1-beacon-rzg2h-kit.dts | 71 +++++++++++++++++++ arch/arm/mach-rmobile/Kconfig.64 | 5 ++ board/beacon/beacon-rzg2m/Kconfig | 2 +- configs/r8a774e1_beacon_defconfig | 67 +++++++++++++++++ 6 files changed, 189 insertions(+), 1 deletion(-)
V2: No Change
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 71f49cc79b..50b52b901a 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -810,6 +810,7 @@ dtb-$(CONFIG_RCAR_GEN2) += \ dtb-$(CONFIG_RCAR_GEN3) += \ r8a774a1-beacon-rzg2m-kit.dtb \ r8a774b1-beacon-rzg2n-kit.dtb \ + r8a774e1-beacon-rzg2h-kit.dtb \ r8a77950-ulcb-u-boot.dtb \ r8a77950-salvator-x-u-boot.dtb \ r8a77960-ulcb-u-boot.dtb \ diff --git a/arch/arm/dts/r8a774e1-beacon-rzg2h-kit-u-boot.dtsi b/arch/arm/dts/r8a774e1-beacon-rzg2h-kit-u-boot.dtsi new file mode 100644 index 0000000000..eef200af2d --- /dev/null +++ b/arch/arm/dts/r8a774e1-beacon-rzg2h-kit-u-boot.dtsi @@ -0,0 +1,44 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright 2020 Compass Electronics Group, LLC + */ + +/ { + soc { + u-boot,dm-pre-reloc; + }; +}; + +&cpg { + u-boot,dm-pre-reloc; +}; + +&extal_clk { + u-boot,dm-pre-reloc; +}; + +&prr { + u-boot,dm-pre-reloc; +}; + +&extalr_clk { + u-boot,dm-pre-reloc; +}; + +&sdhi0 { + /delete-property/ cd-gpios; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr104; + max-frequency = <208000000>; +}; + +&sdhi2 { + status = "disabled"; +}; + +&sdhi3 { + mmc-ddr-1_8v; + mmc-hs200-1_8v; + mmc-hs400-1_8v; +}; diff --git a/arch/arm/dts/r8a774e1-beacon-rzg2h-kit.dts b/arch/arm/dts/r8a774e1-beacon-rzg2h-kit.dts new file mode 100644 index 0000000000..273f062f29 --- /dev/null +++ b/arch/arm/dts/r8a774e1-beacon-rzg2h-kit.dts @@ -0,0 +1,71 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright 2020, Compass Electronics Group, LLC + */ + +/dts-v1/; + +#include "r8a774e1.dtsi" +#include "beacon-renesom-som.dtsi" +#include "beacon-renesom-baseboard.dtsi" + +/ { + model = "Beacon Embedded Works RZ/G2H Development Kit"; + compatible = "beacon,beacon-rzg2h", "renesas,r8a774e1"; + + aliases { + serial0 = &scif2; + serial1 = &hscif0; + serial2 = &hscif1; + serial3 = &scif0; + serial4 = &hscif2; + serial5 = &scif5; + serial6 = &scif4; + ethernet0 = &avb; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + memory@500000000 { + device_type = "memory"; + reg = <0x5 0x00000000 0x0 0x80000000>; + }; +}; + +&du { + pinctrl-0 = <&du_pins>; + pinctrl-names = "default"; + status = "okay"; + + clocks = <&cpg CPG_MOD 724>, + <&cpg CPG_MOD 723>, + <&cpg CPG_MOD 721>, + <&versaclock5 1>, + <&x302_clk>, + <&versaclock5 2>; + clock-names = "du.0", "du.1", "du.3", + "dclkin.0", "dclkin.1", "dclkin.3"; +}; + +/* Reference versaclock instead of audio_clk_a */ +&rcar_sound { + clocks = <&cpg CPG_MOD 1005>, + <&cpg CPG_MOD 1006>, <&cpg CPG_MOD 1007>, + <&cpg CPG_MOD 1008>, <&cpg CPG_MOD 1009>, + <&cpg CPG_MOD 1010>, <&cpg CPG_MOD 1011>, + <&cpg CPG_MOD 1012>, <&cpg CPG_MOD 1013>, + <&cpg CPG_MOD 1014>, <&cpg CPG_MOD 1015>, + <&cpg CPG_MOD 1022>, <&cpg CPG_MOD 1023>, + <&cpg CPG_MOD 1024>, <&cpg CPG_MOD 1025>, + <&cpg CPG_MOD 1026>, <&cpg CPG_MOD 1027>, + <&cpg CPG_MOD 1028>, <&cpg CPG_MOD 1029>, + <&cpg CPG_MOD 1030>, <&cpg CPG_MOD 1031>, + <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, + <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, + <&cpg CPG_MOD 1019>, <&cpg CPG_MOD 1018>, + <&versaclock6_bb 4>, <&audio_clk_b>, + <&audio_clk_c>, + <&cpg CPG_CORE R8A774E1_CLK_S0D4>; +}; diff --git a/arch/arm/mach-rmobile/Kconfig.64 b/arch/arm/mach-rmobile/Kconfig.64 index 35354126e4..b95c8e8d29 100644 --- a/arch/arm/mach-rmobile/Kconfig.64 +++ b/arch/arm/mach-rmobile/Kconfig.64 @@ -60,6 +60,11 @@ choice prompt "Renesas ARM64 SoCs board select" optional
+config TARGET_BEACON_RZG2H + bool "Beacon EmbeddedWorks RZ/G2H Dev Kit" + select R8A774E1 + select PINCTRL_PFC_R8A774E1 + config TARGET_BEACON_RZG2M bool "Beacon EmbeddedWorks RZ/G2M Dev Kit" select R8A774A1 diff --git a/board/beacon/beacon-rzg2m/Kconfig b/board/beacon/beacon-rzg2m/Kconfig index 9c653e386e..99c23a3d14 100644 --- a/board/beacon/beacon-rzg2m/Kconfig +++ b/board/beacon/beacon-rzg2m/Kconfig @@ -1,4 +1,4 @@ -if TARGET_BEACON_RZG2M || TARGET_BEACON_RZG2N +if TARGET_BEACON_RZG2H || TARGET_BEACON_RZG2M || TARGET_BEACON_RZG2N
config SYS_SOC default "rmobile" diff --git a/configs/r8a774e1_beacon_defconfig b/configs/r8a774e1_beacon_defconfig new file mode 100644 index 0000000000..1c2e86ea2a --- /dev/null +++ b/configs/r8a774e1_beacon_defconfig @@ -0,0 +1,67 @@ +CONFIG_ARM=y +CONFIG_ARCH_RMOBILE=y +CONFIG_SYS_TEXT_BASE=0x50000000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_OFFSET=0x0 +CONFIG_DM_GPIO=y +CONFIG_RCAR_GEN3=y +CONFIG_R8A774E1=y +CONFIG_TARGET_BEACON_RZG2H=y +# CONFIG_SPL is not set +CONFIG_DEFAULT_DEVICE_TREE="r8a774e1-beacon-rzg2h-kit" +CONFIG_FIT=y +CONFIG_SUPPORT_RAW_INITRD=y +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_DEFAULT_FDT_FILE="r8a774e1-beacon-rzg2h-kit.dtb" +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_MMC_ENV_DEV=1 +CONFIG_SYS_MMC_ENV_PART=2 +CONFIG_VERSION_VARIABLE=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y +CONFIG_CLK=y +CONFIG_CLK_RENESAS=y +CONFIG_RCAR_GPIO=y +CONFIG_DM_PCA953X=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_RCAR_I2C=y +CONFIG_SYS_I2C_RCAR_IIC=y +CONFIG_DM_MMC=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS200_SUPPORT=y +CONFIG_RENESAS_SDHI=y +CONFIG_BITBANGMII=y +CONFIG_PHY_REALTEK=y +CONFIG_DM_ETH=y +CONFIG_RENESAS_RAVB=y +CONFIG_PINCTRL_PFC_R8A774E1=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_SCIF_CONSOLE=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_STORAGE=y +CONFIG_OF_LIBFDT_OVERLAY=y
Adam Ford
