[U-Boot] [PATCH v3] mmc: atmel: Add atmel sdhci support
The SDHCI is introduced by sama5d2, named as Secure Digital Multimedia Card Controller(SDMMC). It supports the embedded MultiMedia Card (e.MMC) Specification V4.41, the SD Memory Card Specification V3.0, and the SDIO V3.0 specification. It is compliant with the SD Host Controller Standard V3.0 specification.
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com ---
Changes in v3: 1./ return -ENODEV instead of -1, when failing to get proper clock. 2./ add free host instance when failing to get proper clock.
Changes in v2: - According to Bo Shen's comments, 1./ change the macro ATMEL_SDHC_MIN_FRQ -> ATMEL_SDHC_MIN_FREQ. 2./ change the return value to -ENOMEM and print log for malloc failure. 3./ add the failed return and log for getting improper clock. 4./ add more commit log.
arch/arm/mach-at91/include/mach/atmel_sdhci.h | 13 ++++++++ drivers/mmc/Makefile | 1 + drivers/mmc/atmel_sdhci.c | 40 +++++++++++++++++++++++++ 3 files changed, 54 insertions(+) create mode 100644 arch/arm/mach-at91/include/mach/atmel_sdhci.h create mode 100644 drivers/mmc/atmel_sdhci.c
diff --git a/arch/arm/mach-at91/include/mach/atmel_sdhci.h b/arch/arm/mach-at91/include/mach/atmel_sdhci.h new file mode 100644 index 0000000..9652bc2 --- /dev/null +++ b/arch/arm/mach-at91/include/mach/atmel_sdhci.h @@ -0,0 +1,13 @@ +/* + * Copyright (c) 2015 Atmel Corporation + * Wenyou.Yang wenyou.yang@atmel.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ATMEL_SDHCI_H +#define __ATMEL_SDHCI_H + +int atmel_sdhci_init(void *regbase, u32 id); + +#endif diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 99d0295..5d35705 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -8,6 +8,7 @@ obj-$(CONFIG_DM_MMC) += mmc-uclass.o
obj-$(CONFIG_ARM_PL180_MMCI) += arm_pl180_mmci.o +obj-$(CONFIG_ATMEL_SDHCI) += atmel_sdhci.o obj-$(CONFIG_BCM2835_SDHCI) += bcm2835_sdhci.o obj-$(CONFIG_BFIN_SDH) += bfin_sdh.o obj-$(CONFIG_DAVINCI_MMC) += davinci_mmc.o diff --git a/drivers/mmc/atmel_sdhci.c b/drivers/mmc/atmel_sdhci.c new file mode 100644 index 0000000..185a36e --- /dev/null +++ b/drivers/mmc/atmel_sdhci.c @@ -0,0 +1,40 @@ +/* + * Copyright (C) 2015 Atmel Corporation + * Wenyou.Yang wenyou.yang@atmel.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <malloc.h> +#include <sdhci.h> +#include <asm/arch/clk.h> + +#define ATMEL_SDHC_MIN_FREQ 400000 + +int atmel_sdhci_init(void *regbase, u32 id) +{ + struct sdhci_host *host = NULL; + u32 max_clk, min_clk = ATMEL_SDHC_MIN_FREQ; + + host = (struct sdhci_host *)malloc(sizeof(struct sdhci_host)); + if (!host) { + printf("%s: sdhci_host malloc failed\n", __func__); + return -ENOMEM; + } + + host->name = "atmel_sdhci"; + host->ioaddr = (void *)regbase; + host->quirks = 0; + host->version = sdhci_readw(host, SDHCI_HOST_VERSION); + max_clk = at91_get_periph_generated_clk(id); + if (!max_clk) { + printf("%s: Failed to get the proper clock\n", __func__); + free(host); + return -ENODEV; + } + + add_sdhci(host, max_clk, min_clk); + + return 0; +}
Hi Wenyou,
Changes in v2:
- Copyright (c) 2015 Atmel Corporation
Wenyou.Yang <wenyou.yang@atmel.com>
- Copyright (C) 2015 Atmel Corporation
I think the regbase type should be u32, if you keep it as "void *", then the following don't need to be covert to "void *".
- struct sdhci_host *host = NULL;
I think it is no need to pass NULL to host.
- u32 max_clk, min_clk = ATMEL_SDHC_MIN_FREQ;
- host = (struct sdhci_host *)malloc(sizeof(struct sdhci_host));
Maybe calloc will be better.
- if (!host) {
return -ENOMEM;
- host->name = "atmel_sdhci";
- host->ioaddr = (void *)regbase;
Here no need to do covert if the original type is the same.
- host->quirks = 0;
- host->version = sdhci_readw(host, SDHCI_HOST_VERSION);
- max_clk = at91_get_periph_generated_clk(id);
- if (!max_clk) {
free(host);
return -ENODEV;
- add_sdhci(host, max_clk, min_clk);
Best Regards, Bo Shen
Hi Bo Shen,
Thank you for your review.
-----Original Message----- From: Bo Shen [mailto:voice.shen@gmail.com] Sent: 2015年10月28日 11:03 To: Yang, Wenyou Cc: U-Boot Mailing List; andreas.devel@googlemail.com; Pantelis Antoniou Subject: Re: [PATCH v3] mmc: atmel: Add atmel sdhci support
Hi Wenyou,
Changes in v2:
You are right. The following convert should be removed.
Yes, NULL is not needed.
calloc() is better, zero-initialized the buffer
- if (!host) {
return -ENOMEM;
Yes, removed.
- host->quirks = 0;
- if (!max_clk) {
free(host);
return -ENODEV;
Best Regards, Wenyou Yang
Bo Shen
Wenyou Yang
Yang, Wenyou
