[PATCH] ARM: renesas: Demote overlap memory nodes message to debug on Gen3
The R-Car DTs might contains multiple /memory@* nodes from various sources, i.e. prior firmware, u-boot itself or the OS
The duplicates are likely to happen so the messages are not meaningful in the default setting since we have already handled that.
Reduce the message to debug level.
Reviewed-by: Marek Vasut marek.vasut+renesas@mailbox.org Signed-off-by: Hai Pham hai.pham.ud@renesas.com Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- board/renesas/rcar-common/common.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/board/renesas/rcar-common/common.c b/board/renesas/rcar-common/common.c index daa1beb14f8..0ddae95e230 100644 --- a/board/renesas/rcar-common/common.c +++ b/board/renesas/rcar-common/common.c @@ -73,9 +73,9 @@ static int is_mem_overlap(void *blob, int first_mem_node, int curr_mem_node) if (curr_mem_res.start >= first_mem_res.end) continue;
- printf("Overlap found: 0x%llx..0x%llx / 0x%llx..0x%llx\n", - first_mem_res.start, first_mem_res.end, - curr_mem_res.start, curr_mem_res.end); + log_debug("Overlap found: 0x%llx..0x%llx / 0x%llx..0x%llx\n", + first_mem_res.start, first_mem_res.end, + curr_mem_res.start, curr_mem_res.end);
return 1; }
