[PULL] u-boot-sh/master
The following changes since commit 8e5e64d55de9ed97875a0c1b7f293a0286d64312:
Merge patch series "fs: ext4: implement opendir, readdir, closedir" (2024-11-01 13:38:05 -0600)
https://source.denx.de/u-boot/custodians/u-boot-sh.git master
for you to fetch changes up to e2635570e08199bb5644ce164def2a46d1dee9c0:
ARM: renesas: Deduplicate common Renesas defconfig (2024-11-03 12:25:57 +0100)
---------------------------------------------------------------- Marek Vasut (6): clk: renesas: Fix missing unbind on driver look up failure ARM: renesas: Deduplicate Renesas R-Car Gen2 defconfigs ARM: renesas: Deduplicate Renesas R-Car Gen3 defconfigs ARM: renesas: Deduplicate Renesas R-Car Gen4 defconfigs ARM: renesas: Deduplicate Renesas R-Car 64bit defconfigs ARM: renesas: Deduplicate common Renesas defconfig
configs/alt_defconfig | 71 ++---------------------------------- configs/blanche_defconfig | 69 +---------------------------------- configs/gose_defconfig | 71 ++---------------------------------- configs/hihope_rzg2_defconfig | 49 ++----------------------- configs/koelsch_defconfig | 71 ++---------------------------------- configs/lager_defconfig | 71 ++---------------------------------- configs/porter_defconfig | 71 ++---------------------------------- configs/r8a77970_eagle_defconfig | 49 ++----------------------- configs/r8a77970_v3msk_defconfig | 49 ++----------------------- configs/r8a77980_condor_defconfig | 49 ++----------------------- configs/r8a77980_v3hsk_defconfig | 49 ++----------------------- configs/r8a77990_ebisu_defconfig | 49 ++----------------------- configs/r8a77995_draak_defconfig | 49 ++----------------------- configs/r8a779a0_falcon_defconfig | 60 ++---------------------------- configs/r8a779f0_spider_defconfig | 58 ++--------------------------- configs/r8a779g0_whitehawk_defconfig | 58 ++--------------------------- configs/r8a779h0_grayhawk_defconfig | 58 ++--------------------------- configs/rcar3_salvator-x_defconfig | 49 ++----------------------- configs/rcar3_ulcb_defconfig | 49 ++----------------------- configs/renesas_rcar.config | 27 ++++++++++++++ configs/renesas_rcar2.config | 42 +++++++++++++++++++++ configs/renesas_rcar3.config | 6 +++ configs/renesas_rcar4.config | 17 +++++++++ configs/renesas_rcar64.config | 14 +++++++ configs/rzg2_beacon_defconfig | 47 ++---------------------- configs/silinux_ek874_defconfig | 49 ++----------------------- configs/silk_defconfig | 71 ++---------------------------------- configs/stout_defconfig | 71 ++---------------------------------- drivers/clk/renesas/clk-rcar-gen3.c | 19 +++++----- 29 files changed, 195 insertions(+), 1267 deletions(-) create mode 100644 configs/renesas_rcar.config create mode 100644 configs/renesas_rcar2.config create mode 100644 configs/renesas_rcar3.config create mode 100644 configs/renesas_rcar4.config create mode 100644 configs/renesas_rcar64.config
