[U-Boot] [PATCH V2 1/3] sunxi: Use clrsetbits_le32 instead of multiple instruction
Signed-off-by: Michael Trimarchi michael@amarulasolutions.com ---
V1->V2: none
--- arch/arm/mach-sunxi/dram_sun8i_a33.c | 8 ++------ 1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-sunxi/dram_sun8i_a33.c b/arch/arm/mach-sunxi/dram_sun8i_a33.c index 1da2727f98..83212aaddf 100644 --- a/arch/arm/mach-sunxi/dram_sun8i_a33.c +++ b/arch/arm/mach-sunxi/dram_sun8i_a33.c @@ -148,12 +148,8 @@ static void auto_set_timing_para(struct dram_para *para) reg_val = (tcksrx << 24) | (tcksre << 16) | (tckesr << 8) | (tcke << 0); writel(reg_val, &mctl_ctl->dramtmg5); /* Set two rank timing and exit self-refresh timing */ - reg_val = readl(&mctl_ctl->dramtmg8); - reg_val &= ~(0xff << 8); - reg_val &= ~(0xff << 0); - reg_val |= (0x33 << 8); - reg_val |= (0x8 << 0); - writel(reg_val, &mctl_ctl->dramtmg8); + clrsetbits_le32(&mctl_ctl->dramtmg8, (0xff << 8) | (0xff << 0), + 0x33 << 8 | (0x8 << 0)); /* Set phy interface time */ reg_val = (0x2 << 24) | (t_rdata_en << 16) | (0x1 << 8) | (wr_latency << 0);
Change the size create a glitch in the clken signal on second bank. According to the ddr manual the clken need to be sent accros the reset signal coming the cpu. The rank is calculated just before this function is called and the mctl_set_cr should not change this value anymore
V1->V2: Adjust commit description
--- arch/arm/mach-sunxi/dram_sun8i_a33.c | 3 --- 1 file changed, 3 deletions(-)
diff --git a/arch/arm/mach-sunxi/dram_sun8i_a33.c b/arch/arm/mach-sunxi/dram_sun8i_a33.c index 83212aaddf..d73a93a132 100644 --- a/arch/arm/mach-sunxi/dram_sun8i_a33.c +++ b/arch/arm/mach-sunxi/dram_sun8i_a33.c @@ -45,14 +45,12 @@ static void mctl_set_cr(struct dram_para *para)
static void auto_detect_dram_size(struct dram_para *para) { - u8 orig_rank = para->rank; int rows, columns;
/* Row detect */ para->page_size = 512; para->seq = 1; para->rows = 16; - para->rank = 1; mctl_set_cr(para); for (rows = 11 ; rows < 16 ; rows++) { if (mctl_mem_matches(1 << (rows + 9))) /* row-column */ @@ -69,7 +67,6 @@ static void auto_detect_dram_size(struct dram_para *para) }
para->seq = 0; - para->rank = orig_rank; para->rows = rows; para->page_size = 1 << columns; mctl_set_cr(para);
Set two rank timing and exit self-refresh timing seems not done properly. We know use the same write that we are using on H5 silicon. Tested was done in A33 allwinner cpu, dual rank connection connected with two MT41K512M16HA-125:A memory model. Memory is configure as DDR3 1.5V
V1->V2: adjust commit message
--- arch/arm/mach-sunxi/dram_sun8i_a33.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-sunxi/dram_sun8i_a33.c b/arch/arm/mach-sunxi/dram_sun8i_a33.c index d73a93a132..355fe30aba 100644 --- a/arch/arm/mach-sunxi/dram_sun8i_a33.c +++ b/arch/arm/mach-sunxi/dram_sun8i_a33.c @@ -146,7 +146,7 @@ static void auto_set_timing_para(struct dram_para *para) writel(reg_val, &mctl_ctl->dramtmg5); /* Set two rank timing and exit self-refresh timing */ clrsetbits_le32(&mctl_ctl->dramtmg8, (0xff << 8) | (0xff << 0), - 0x33 << 8 | (0x8 << 0)); + 0x33 << 8 | (0x10 << 0)); /* Set phy interface time */ reg_val = (0x2 << 24) | (t_rdata_en << 16) | (0x1 << 8) | (wr_latency << 0);
On 14.02.2019, at 16:58, Michael Trimarchi michael@amarulasolutions.com wrote:
How exactly does the change in constants match up with the commit message? What is the field at “<< 0”?
Are you configuring the IOs to 1.5V with this write (as the commit message would suggest)?
/* Set phy interface time */ reg_val = (0x2 << 24) | (t_rdata_en << 16) | (0x1 << 8) | (wr_latency << 0); -- 2.17.1
Hi Philipp
On Thu, Feb 14, 2019 at 5:36 PM Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
I just reduce the code change. Ok, forget to mention in the commit message that I don't have documentation of the cpu. So my fix is based on allwinner architecture comparison and the fact that it fix my issue. I was having a failure rate of 7% before.
No, the model of the memory is LPDDR3 but they can work as DDR3 compatible mode if they are powered at 1.5V. A33 has not support for LPDDR3 so make no sense to try to let them work as LPDDR3. I will update the commit message
Michael
-- 2.17.1
From looking at the ZynqMP register guide, which is reported to be close
to the various Allwinner DRAM controllers, bits [6:0] are tXS: Self refresh exit delay. Increasing that should not hurt, and if I understand it correctly it only affects the time after the self-refresh *exit*, which happens only after (re-)initialisation(?).
But it should be noted that this unconditionally affects all A33 boards.
I think the voltage is totally unrelated here, this is a pure timing register.
Cheers, Andre.
From looking at the ZynqMP register guide, which is reported to be close to the various Allwinner DRAM controllers, bits [6:0] are tXS: Self refresh exit delay. Increasing that should not hurt, and if I understand it correctly it only affects the time after the self-refresh *exit*, which happens only after (re-)initialisation(?).
The “set two rank timing” comment doesn’t match our expectation that this will be self-refresh timings, as on the ZynqMP or the A80. Self-refresh only happens, if someone puts the DRAM into self-refresh (i.e. “suspend to DRAM”) and then resumes it. I don’t see a reference to the error occurring from this.
That said, if the field indeed was the exit self-refresh timing, this would usually be tXSDLL, encoded as tXSDLL/32. JESD79 specifies tESXR as tXSDLL (which in turn is tDLLK(min)), which is 512 nCK always: 0x10 would be 512 and 0x08 would only be 256… then again, this should only matter when exiting self-refresh.
Note that the ‘auto-enter self-refresh’ functionality is controlled through BIT(3) in PWRCTL on the A33, according to Allwinner’s basic_loader. I don’t know whether that may be turned on by the driver (i.e. didn’t check).
OTOH, when working with an underdocumented DRAM register layout and once one has an educated guess at what register/setting may be affected, a DRAM protocol analyzer can provide conclusive answers by looking at the differences in behaviour with 0x8 and 0x10 in that bitfield…
Just my 2 cents.
Cheers, Andre.
U-Boot mailing list U-Boot@lists.denx.de mailto:U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot https://lists.denx.de/listinfo/u-boot
On Fri, 15 Feb 2019 11:18:38 +0100 Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
Hi Philipp,
So I was wondering about this as well. Indeed we don't seem to *explicitly* enter or exit Self-Refresh anywhere, but maybe this is done implicitly as part of some training phase? I might be wrong about this, but in some DDR3 documentation I see that changing the DLL state is connected to self refresh, and enabling the DLL is required as part of the initialisation? So is the DRAMC somehow triggering a self refresh exit "magically"? If I understand this correctly, our ranking test does reset the controller?
So I was looking at this: https://www.xilinx.com/html_docs/registers/ug1087/ddrc___dramtmg8.html and tXSDLL is bits [14:8], while the non-DLL tXS is bits [6:0].
I don't see us touching pwrctl for the A33 (but for the A23).
All I have is a multimeter and no A33 ;-)
Thanks for providing some background!
Cheers, Andre.
Just my 2 cents.
Cheers, Andre.
Dipl.-Ing. Dr.techn. Philipp Tomsich Theobroma Systems Design und Consulting GmbH Seestadtstrasse 27 (Aspern IQ), A-1220 Wien, Austria Phone: +43 1 2369893-401, Fax: +43 1 2369893-9-401 Cell phone: +43 664 8346109 http://www.theobroma-systems.com http://www.theobroma-systems.com/
Hi Philipp,
I’d need to reread JESD79 (a much more relaxing read than the daily news), to figure out whether there’s any valid reason to play with self-refresh during the training.
You are aware that was more of a philosophical rambling and not intended as a request to you… However, I am way more surprised that none of the parties having money riding on their A33 designs has gone through the required effort.
Cheers, Philipp.
Hi all
On Fri, Feb 15, 2019 at 12:40 PM Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
Hi Philipp,
I will fix the commit
- 0x33 << 8 | (0x10 << 0));
Seems that affect the initialization sequence.
The comment is the original one
What is the best option here? create a better commit or try to go in deep.
Nice to have but It's not my case. The best for me is update the commit message and give more info there. Add the memory components and the layout of my setup, ask to test other boards before get included
Michael
Cheers, Philipp.
On Fri, 15 Feb 2019 17:01:40 +0100 Michael Nazzareno Trimarchi michael@amarulasolutions.com wrote:
Hi all
Hi Philipp,
Well, we don't need to get this out of hand: 1) This change affects all A33 systems, unconditionally. We would need confirmation from owners of those other systems that it still works for them. 2) Yes, the commit message should be changed. Please state the issue you have seen, maybe roughly summarise our guesses here. Then mention that this changes the DRAM init part for all A33 users.
Cheers, Andre.
Michael
Cheers, Philipp.
On Thu, Feb 14, 2019 at 9:28 PM Michael Trimarchi michael@amarulasolutions.com wrote:
V1->V2: none
these are clr
these are set
participants (6)
Andre Przywara
André Przywara
Jagan Teki
Michael Trimarchi
Philipp Tomsich
