[PATCH 0/2] PINE64 Rock64 board: Add SPI Flash support
This patch series adds SPI Flash support for the PINE64 Rock64 board.
Tested with the version 2.0 of the board.
Johannes Krottmayer (2): ARM: dts: rk3328-rock64: Add SPI Flash support configs: rock64-rk3328_defconfig: Add SPI Flash support
arch/arm/dts/rk3328-rock64-u-boot.dtsi | 6 ++++++ configs/rock64-rk3328_defconfig | 2 ++ 2 files changed, 8 insertions(+)
Add U-Boot SPI Flash support for the PINE64 Rock64 board
Signed-off-by: Johannes Krottmayer krjdev@gmail.com Cc: Matwey V. Kornilov matwey.kornilov@gmail.com --- arch/arm/dts/rk3328-rock64-u-boot.dtsi | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/dts/rk3328-rock64-u-boot.dtsi b/arch/arm/dts/rk3328-rock64-u-boot.dtsi index f076075076..7340ef95f1 100644 --- a/arch/arm/dts/rk3328-rock64-u-boot.dtsi +++ b/arch/arm/dts/rk3328-rock64-u-boot.dtsi @@ -46,3 +46,9 @@ &vcc_sd { u-boot,dm-spl; }; + +&spi0 { + spi_flash: spiflash@0 { + u-boot,dm-pre-reloc; + }; +};
Reviewed-by: Kever Yangkever.yang@rock-chips.com
Thanks, - Kever
+&spi0 {
- spi_flash: spiflash@0 {
Signed-off-by: Johannes Krottmayer krjdev@gmail.com Cc: Matwey V. Kornilov matwey.kornilov@gmail.com --- configs/rock64-rk3328_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/rock64-rk3328_defconfig b/configs/rock64-rk3328_defconfig index f123826358..0a51e51a0c 100644 --- a/configs/rock64-rk3328_defconfig +++ b/configs/rock64-rk3328_defconfig @@ -97,3 +97,5 @@ CONFIG_SPL_TINY_MEMSET=y CONFIG_TPL_TINY_MEMSET=y CONFIG_ERRNO_STR=y CONFIG_SMBIOS_MANUFACTURER="pine64" +CONFIG_ROCKCHIP_SPI=y +CONFIG_SPI_FLASH_GIGADEVICE=y
Thanks, - Kever
Applied to u-boot-rockchip master for this patch set, thanks.
Johannes Krottmayer
Kever Yang
