[U-Boot] [PATCH 1/2] config_cmd_all.h: added missing CONFIG_CMD_UBI and CONFIG_CMD_UBIFS
From: Frans Meulenbroeks fransmeulenbroeks@gmail.com
Signed-off-by: Frans Meulenbroeks fransmeulenbroeks@gmail.com --- include/config_cmd_all.h | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/include/config_cmd_all.h b/include/config_cmd_all.h index 058fdf1..1cb7067 100644 --- a/include/config_cmd_all.h +++ b/include/config_cmd_all.h @@ -79,6 +79,8 @@ #define CONFIG_CMD_SOURCE /* "source" command support */ #define CONFIG_CMD_SPI /* SPI utility */ #define CONFIG_CMD_TERMINAL /* built-in Serial Terminal */ +#define CONFIG_CMD_UBI /* UBI Support */ +#define CONFIG_CMD_UBIFS /* UBIFS Support */ #define CONFIG_CMD_UNIVERSE /* Tundra Universe Support */ #define CONFIG_CMD_UNZIP /* unzip from memory to memory */ #define CONFIG_CMD_USB /* USB Support */
Signed-off-by: Detlev Zundel dzu@denx.de --- include/config_cmd_all.h | 6 +++--- 1 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/include/config_cmd_all.h b/include/config_cmd_all.h index 1cb7067..746bf18 100644 --- a/include/config_cmd_all.h +++ b/include/config_cmd_all.h @@ -15,6 +15,7 @@
#define CONFIG_CMD_AMBAPP /* AMBA Plug & Play Bus print utility */ #define CONFIG_CMD_ASKENV /* ask for env variable */ +#define CONFIG_CMD_AT91_SPIMUX /* AT91 MMC/SPI Mux Support */ #define CONFIG_CMD_BDI /* bdinfo */ #define CONFIG_CMD_BEDBUG /* Include BedBug Debugger */ #define CONFIG_CMD_BMP /* BMP support */ @@ -33,7 +34,6 @@ #define CONFIG_CMD_EDITENV /* editenv */ #define CONFIG_CMD_EEPROM /* EEPROM read/write support */ #define CONFIG_CMD_ELF /* ELF (VxWorks) load/boot cmd */ -#define CONFIG_CMD_SAVEENV /* saveenv */ #define CONFIG_CMD_EXT2 /* EXT2 Support */ #define CONFIG_CMD_FAT /* FAT support */ #define CONFIG_CMD_FDC /* Floppy Disk Support */ @@ -55,6 +55,7 @@ #define CONFIG_CMD_LOADS /* loads */ #define CONFIG_CMD_MEMORY /* md mm nm mw cp cmp crc base loop mtest */ #define CONFIG_CMD_MFSL /* FSL support for Microblaze */ +#define CONFIG_CMD_MG_DISK /* mGine m(g)flash IO node support */ #define CONFIG_CMD_MII /* MII support */ #define CONFIG_CMD_MISC /* Misc functions like sleep etc*/ #define CONFIG_CMD_MMC /* MMC support */ @@ -70,6 +71,7 @@ #define CONFIG_CMD_REGINFO /* Register dump */ #define CONFIG_CMD_REISER /* Reiserfs support */ #define CONFIG_CMD_RUN /* run command in env variable */ +#define CONFIG_CMD_SAVEENV /* saveenv */ #define CONFIG_CMD_SAVES /* save S record dump */ #define CONFIG_CMD_SCSI /* SCSI Support */ #define CONFIG_CMD_SDRAM /* SDRAM DIMM SPD info printout */ @@ -86,7 +88,5 @@ #define CONFIG_CMD_USB /* USB Support */ #define CONFIG_CMD_VFD /* VFD support (TRAB) */ #define CONFIG_CMD_XIMG /* Load part of Multi Image */ -#define CONFIG_CMD_AT91_SPIMUX /* AT91 MMC/SPI Mux Support */ -#define CONFIG_CMD_MG_DISK /* mGine m(g)flash IO node support */
#endif /* _CONFIG_CMD_ALL_H */
Dear Detlev Zundel,
Thanks, applied.
Dear Detlev Zundel,
Thanks, applied.
Detlev Zundel
