[PATCH] ARM: am3517-evm: Remove more non-DM legacy ethernet reset code
The ethernet controller is DM compliant, and the device tree defines it. There is no need to manually handle pulling the ethernet out of reset.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/board/logicpd/am3517evm/am3517evm.c b/board/logicpd/am3517evm/am3517evm.c index f014165928..e787441c74 100644 --- a/board/logicpd/am3517evm/am3517evm.c +++ b/board/logicpd/am3517evm/am3517evm.c @@ -117,17 +117,10 @@ static void am3517_evm_musb_init(void) */ int misc_init_r(void) { - u32 reset; - omap_die_id_display();
am3517_evm_musb_init();
- /* ensure that the Ethernet module is out of reset */ - reset = readl(AM3517_IP_SW_RESET); - reset &= (~CPGMACSS_SW_RST); - writel(reset, AM3517_IP_SW_RESET); - return 0; }
@@ -142,7 +135,6 @@ void set_muxconf_regs(void) MUX_AM3517EVM(); }
- #if defined(CONFIG_USB_ETHER) && defined(CONFIG_USB_MUSB_GADGET) int board_eth_init(struct bd_info *bis) {
u32 reset;
omap_die_id_display(); am3517_evm_musb_init();
#if defined(CONFIG_USB_ETHER) && defined(CONFIG_USB_MUSB_GADGET) int board_eth_init(struct bd_info *bis) { -- 2.34.1
Ethernet continues to work on AM3517 Zoom eXperimenter.
Tested-by: Derald D. Woods woods.technical@gmail.com
Signed-off-by: Adam Ford aford173@gmail.com Tested-by: Derald D. Woods woods.technical@gmail.com
Adam Ford
Derald Woods
