[U-Boot-Users] [PATCH 1/11] Fix miscellaneous typos
This patch fixes a few typos. No CHANGELOG entry due to trivial nature of patch
diff --git a/README b/README index 3ffef62..94d856c 100644 --- a/README +++ b/README @@ -1526,7 +1526,7 @@ The following options need to be configu
Adding this option adds support for Xilinx SystemACE chips attached via some sort of local bus. The address - of the chip must alsh be defined in the + of the chip must also be defined in the CFG_SYSTEMACE_BASE macro. For example:
#define CONFIG_SYSTEMACE @@ -1929,7 +1929,7 @@ to save the current settings. environment area within the total memory of your EEPROM.
- CFG_I2C_EEPROM_ADDR: - If defined, specified the chip address of the EEPROM device. + If defined, specifies the chip address of the EEPROM device. The default address is zero.
- CFG_EEPROM_PAGE_WRITE_BITS: diff --git a/lib_ppc/board.c b/lib_ppc/board.c index e68cf1f..2dfbca0 100644 --- a/lib_ppc/board.c +++ b/lib_ppc/board.c @@ -586,7 +586,7 @@ #endif * * This is the next part if the initialization sequence: we are now * running from RAM and have a "normal" C environment, i. e. global - * data can be written, BSS has been cleared, the stack size in not + * data can be written, BSS has been cleared, the stack size is not * that critical any more, etc. * ************************************************************************
Signed-off-by: Keith Outwater outwater4@comcast.net
Dear Keith,
I'm a bit unhappy about your patches.
First, I don't know how to make heads or tails out of it.
In this subject you write "PATCH 1/11" which looks as if this were a couple of related patches coming in 11 parts, but actually all of them seem to be completely independent?
Then, I received patches 5/11, 8/11, 2/11, 11/11, 6/11, 1/11, 9/11, and 4/11. What about parts 3, 5, 7, 9, and 10?
In message OFBEDA0037.AED1556F-ON07257165.005DED58-07257165.005E506A@mck.us.ray.com you wrote:
Where in the README does it say that a CHANGELOG entry is not necessary for simple patches? I need this for each and every patch.
Then, you are violating the Coding Style requirements in a couple of places (I didn't check carefully as I was not able to apply the patches [see below], but I've seen at least indentation with spaces instead of the required TABs, indentation not by multiples of 8, and trailing white space.
Then you add nasty editor commands to your sources, like this one: /* vim: set ts=4 tw=80 sw=4 cindent fo=tcroq: */
All of this is bad, but this one is fatal and forces me to reject all your patches as they are not usable: your patches are line-wrapped which makes it impossible to apply them; for example, in [PATCH 8/11] Add support for environment storage in SystemACE:
... +- CFG_ENV_IS_IN_SYSACE: + + Define this if you have a Compact Flash (CF) card connected to a + Xilinx SystemACE controller in which you wish to store the environment. + + - CFG_SYSTEMACE_ENV_DEV: + The device (instance) number of the SystemACE device you wich to use. + This is normally zero for a system with a single SystemACE. + + - CFG_ENV_SIZE: + The size of the environment in bytes. Note that presently this must ...
Please clean up and resubmit, but please the rules as documetned in the README. And make sure to configure your mailer correctly so that it doesn't corrupt your postings.
All patches rejected. Sorry.
wd@denx.de wrote on 05/05/2006 03:49:03 PM:
Dear Keith,
Independent, as you requested but with a poor choice of naming on my part. I'll staighten this out.
In message <OFBEDA0037.AED1556F-ON07257165.005DED58-07257165. 005E506A@mck.us.ray.com> you wrote:
nature of
patch
Saw someone else do this on the list a while back. Sorry. I'll put in CHANGELOG entries for all patches.
Some "imported code" had this stuff, and in other cases existing code was indented by 4. I'll take a look and try to clean things up.
I'll remove this stuff.
environment.
use.
- CFG_ENV_SIZE:
must ...
Crappy mail client. Is is OK to post all patches as attachements?
I'll address your issues and resubmit.
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de In C we had to code our own bugs, in C++ we can inherit them.
Keith J Outwater
