[U-Boot] [PATCH v2] MPC837x: set i2c1_clk
Running on mpc837x without CONFIG_FSL_ESDHC leads to i2c1_clk not being set at all. It is bound to clock of encryption module. fix this.
Signed-off-by: Andre Schwarz andre.schwarz@matrix-vision.de --- Changes for v2: - fix commit message mangling in subject line.
arch/powerpc/cpu/mpc83xx/speed.c | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/arch/powerpc/cpu/mpc83xx/speed.c b/arch/powerpc/cpu/mpc83xx/speed.c index 5e616dd..1eca1a8 100644 --- a/arch/powerpc/cpu/mpc83xx/speed.c +++ b/arch/powerpc/cpu/mpc83xx/speed.c @@ -327,6 +327,8 @@ int get_clocks(void) i2c1_clk = enc_clk; #elif defined(CONFIG_FSL_ESDHC) i2c1_clk = sdhc_clk; +#elif defined(CONFIG_MPC837x) + i2c1_clk = enc_clk; #endif #if !defined(CONFIG_MPC832x) i2c2_clk = csb_clk; /* i2c-2 clk is equal to csb clk */
On Thu, 14 Apr 2011 14:57:40 +0200 Andre Schwarz andre.schwarz@matrix-vision.de wrote:
Changes for v2:
thanks for listing change matter, subsequent versions of patches should inherit prior versions "In-reply-to:" and "References:" headers.
- i2c1_clk = enc_clk;
#endif
can you consolidate this and the other i2c1_clk-to-enc_clk assignments in one #elif defined(...) || defined(...), etc.
not sure if the FSL_ESDHC ifdef would need to be moved above that.
btw, subjects in this patchseries should be of the form [PATCH x/y].
Thanks,
Kim
applied to u-boot-mpc83xx.
Thanks,
Kim
Andre Schwarz
Kim Phillips
