[U-Boot] [PATCH] fw_env: Make env flash lock optional
Since locking flash is horribly broken on some platforms, offer an option to build fw_env tools without locking.
Signed-off-by: Dirk Eibach dirk.eibach@gdsys.cc
tools/env/fw_env.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/tools/env/fw_env.c b/tools/env/fw_env.c index 06cf63d..e47232a 100644 --- a/tools/env/fw_env.c +++ b/tools/env/fw_env.c @@ -908,8 +908,10 @@ static int flash_write_buf (int dev, int fd, void *buf, size_t count, return -1; }
+#ifndef NO_MEMLOCK if (mtd_type != MTD_ABSENT) ioctl(fd, MEMLOCK, &erase); +#endif
processed += erasesize; block_seek = 0; @@ -941,7 +943,9 @@ static int flash_flag_obsolete (int dev, int fd, off_t offset) } ioctl (fd, MEMUNLOCK, &erase); rc = write (fd, &obsolete_flag, sizeof (obsolete_flag)); +#ifndef NO_MEMLOCK ioctl (fd, MEMLOCK, &erase); +#endif if (rc < 0) perror ("Could not set obsolete flag");
On Thu, 2 Jun 2016 09:09:14 +0200 dirk.eibach@gdsys.cc dirk.eibach@gdsys.cc wrote: ...
when MEMLOCK ist broken on a platform and disabled by your patch, shouldn't MEMUNLOCK be isolated as well?
-- Anatolij
Hi Anatolij,
2016-06-02 10:14 GMT+02:00 Anatolij Gustschin agust@denx.de: ...
There are cornercases where lock/unlock works properly in the kernel but not in u-boot. So we might have an environment that was locked by u-boot and are able to unlock it with fw_env.
Cheers Dirk
I faced the same problem a while back, thanks for taking a look at this. Does it have to be compiled in? Why not make it a command line option, evtl. making the default a compile time option.
/Andi
2016-06-02 10:27 GMT+02:00 Dirk Eibach dirk.eibach@gdsys.cc:
Hi Anatolij,
Cheers Dirk
Dear Dirk,
In message CANVMifJG+MdmMSjBpciuk0xcfdhMDywDkg9WZ4Skrez0ccFwYw@mail.gmail.com you wrote:
But then such a "fix" looks wrong to me. If it works in Linux, why not fix the code so it works in U-Boot, too? I mean, if you have a working example, that should be possible, or not?
Hi Wolfgang,
2016-06-02 15:36 GMT+02:00 Wolfgang Denk wd@denx.de:
But then such a "fix" looks wrong to me. If it works in Linux, why not fix the code so it works in U-Boot, too? I mean, if you have a working example, that should be possible, or not? ...
Sometimes I simply need a tool to repair a device in the field where updating u-boot or kernel is not an option. But uploading modified fw_env tools is.
Cheers Dirk
On Thu, Jun 02, 2016 at 08:57:05PM +0200, Dirk Eibach wrote:
Hi Wolfgang,
So in sum, things are already in a bad state and this is the only way to correct things? Can you please make this a cli option instead with appropriately scary help/man text? Thanks!
Dear Dirk,
In message CANVMifL_VKFX-G9Xsm7yJ-Bu6YrUPOqFbpbSus+f3OL184A0-w@mail.gmail.com you wrote:
Understood.
Am I interpreting this correctly, that the root cause is fixed in recent versions of U-Boot, and you need it only to fix old, broken versions?
Or is the problem still present in current mainline, too?
Hi Dirk,
What type of flash are you referring to: NAND, SPI NOR, parallel NOR?
participants (7)
Anatolij Gustschin
Andreas Fenkart
Dirk Eibach
Fabio Estevam
