[U-Boot] [PATCH] dm: timer: Avoid using timer before it is ready
At present bootstage will try to read the timer very early after relocation. When driver model it used to provide the timer, we cannot read it until driver model is ready. Correct this by adding a separate stage for the post-relocation bootstage init.
This fixes booting on chromebook_link.
common/board_r.c | 10 +++++++++- 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/common/board_r.c b/common/board_r.c index f7118e8..a41fb54 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -109,7 +109,6 @@ static int initr_reloc(void) { /* tell others: relocation done */ gd->flags |= GD_FLG_RELOC | GD_FLG_FULL_MALLOC_INIT; - bootstage_mark_name(BOOTSTAGE_ID_START_UBOOT_R, "board_init_r");
return 0; } @@ -310,6 +309,14 @@ static int initr_dm(void) } #endif
+static int initr_bootstage(void) +{ + /* We cannot do this before initr_dm() */ + bootstage_mark_name(BOOTSTAGE_ID_START_UBOOT_R, "board_init_r"); + + return 0; +} + __weak int power_init_board(void) { return 0; @@ -748,6 +755,7 @@ init_fnc_t init_sequence_r[] = { #ifdef CONFIG_DM initr_dm, #endif + initr_bootstage, #if defined(CONFIG_ARM) || defined(CONFIG_NDS32) board_init, /* Setup chipselects */ #endif
Hi Simon,
Acked-by: Thomas Chou thomas@wytron.com.tw
Hi Simon,
When driver model is
bootstage_mark_name(BOOTSTAGE_ID_START_UBOOT_R, "board_init_r"); return 0;
initr_bootstage,
#endif
Regards, Bin
Reviewed-by: Mugunthan V N mugunthanvnm@ti.com
Regards Mugunthan V N
Applied to u-boot-dm.
Bin Meng
Mugunthan V N
Thomas Chou
