[PATCH] net: fastboot: make UDP port net: configurable
The fastboot protocol uses per default the UDP port 5554. In some cases it might be needed to change the used port. The fastboot utility provides a way to specifiy an other port number to use already.
fastboot -s udp:192.168.1.76:1234 boot fastboot.img
Signed-off-by: Christian Gmeiner christian.gmeiner@gmail.com --- drivers/fastboot/Kconfig | 7 +++++++ net/fastboot.c | 5 +---- 2 files changed, 8 insertions(+), 4 deletions(-)
diff --git a/drivers/fastboot/Kconfig b/drivers/fastboot/Kconfig index d5e4a02098..b97c67bf60 100644 --- a/drivers/fastboot/Kconfig +++ b/drivers/fastboot/Kconfig @@ -21,6 +21,13 @@ config UDP_FUNCTION_FASTBOOT help This enables the fastboot protocol over UDP.
+config UDP_FUNCTION_FASTBOOT_PORT + depends on UDP_FUNCTION_FASTBOOT + int "Define FASTBOOT UDP port" + default 5554 + help + The fastboot protocol requires a UDP port number. + if FASTBOOT
config FASTBOOT_BUF_ADDR diff --git a/net/fastboot.c b/net/fastboot.c index 7e7a601b9f..139233b86c 100644 --- a/net/fastboot.c +++ b/net/fastboot.c @@ -9,9 +9,6 @@ #include <net.h> #include <net/fastboot.h>
-/* Fastboot port # defined in spec */ -#define WELL_KNOWN_PORT 5554 - enum { FASTBOOT_ERROR = 0, FASTBOOT_QUERY = 1, @@ -310,7 +307,7 @@ void fastboot_start_server(void) printf("Using %s device\n", eth_get_name()); printf("Listening for fastboot command on %pI4\n", &net_ip);
- fastboot_our_port = WELL_KNOWN_PORT; + fastboot_our_port = CONFIG_UDP_FUNCTION_FASTBOOT_PORT;
#if CONFIG_IS_ENABLED(FASTBOOT_FLASH) fastboot_set_progress_callback(fastboot_timed_send_info);
Hello Christian,
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
On Thu, Jan 13, 2022 at 2:02 PM Heiko Schocher hs@denx.de wrote:
Hello Christian,
bye, Heiko -- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-52 Fax: +49-8142-66989-80 Email: hs@denx.de
Reviewed-by: Ramon Fried rfried.dev@gmail.com
Hello Christian,
Applied to u-boot-net/next Thanks !
Christian Gmeiner
Heiko Schocher
Ramon Fried
