[U-Boot] [PATCH 2/3] net, phy: fix NULL pointer deference
if phydev is a NULL pointer, code crash, so add check if phydev != NULL
Signed-off-by: Heiko Schocher hs@denx.de Cc: Andy Fleming afleming@freescale.com Cc: Kumar Gala galak@kernel.crashing.org Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Tom Rini trini@ti.com
--- Found on the dxr2 board with no phy connected to the board, U-Boot crashes with:
U-Boot# tftp 0x80200000 /tftpboot/dxr2/u-boot.bin data abort
MAYBE you should read doc/README.arm-unaligned-accesses
pc : [<87f80ffc>] lr : [<87f7fbdc>] sp : 86f5ace0 ip : ffffff00 fp : 87f9a2c2 r10: 00000000 r9 : 87f9a2c7 r8 : 86f5af30 r7 : 00000000 r6 : 86f5f750 r5 : 86f5f7f0 r4 : 86f5f750 r3 : 86f5f804 r2 : 86f5f7f0 r1 : 00000014 r0 : 00000000 Flags: Nzcv IRQs off FIQs on Mode SVC_32 Resetting CPU ...
resetting ... --- drivers/net/phy/phy.c | 30 ++++++++++++++++++++++++++++++ 1 Datei geändert, 30 Zeilen hinzugefügt(+)
diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c index 62925bb..4885100 100644 --- a/drivers/net/phy/phy.c +++ b/drivers/net/phy/phy.c @@ -36,6 +36,9 @@ static int genphy_config_advert(struct phy_device *phydev) int oldadv, adv; int err, changed = 0;
+ if (!phydev) + return -1; + /* Only allow advertising what * this PHY supports */ phydev->advertising &= phydev->supported; @@ -114,6 +117,9 @@ static int genphy_setup_forced(struct phy_device *phydev) int err; int ctl = 0;
+ if (!phydev) + return -1; + phydev->pause = phydev->asym_pause = 0;
if (SPEED_1000 == phydev->speed) @@ -166,6 +172,9 @@ int genphy_config_aneg(struct phy_device *phydev) { int result;
+ if (!phydev) + return -1; + if (AUTONEG_ENABLE != phydev->autoneg) return genphy_setup_forced(phydev);
@@ -206,6 +215,9 @@ int genphy_update_link(struct phy_device *phydev) { unsigned int mii_reg;
+ if (!phydev) + return -1; + /* * Wait if the link is up, and autonegotiation is in progress * (ie - we're capable and it's not done) @@ -274,6 +286,9 @@ int genphy_parse_link(struct phy_device *phydev) { int mii_reg = phy_read(phydev, MDIO_DEVAD_NONE, MII_BMSR);
+ if (!phydev) + return -1; + /* We're using autonegotiation */ if (mii_reg & BMSR_ANEGCAPABLE) { u32 lpa = 0; @@ -365,6 +380,9 @@ int genphy_config(struct phy_device *phydev) int val; u32 features;
+ if (!phydev) + return -1; + /* For now, I'll claim that the generic driver supports * all possible port types */ features = (SUPPORTED_TP | SUPPORTED_MII @@ -495,6 +513,9 @@ static int phy_probe(struct phy_device *phydev) { int err = 0;
+ if (!phydev) + return -1; + phydev->advertising = phydev->supported = phydev->drv->features; phydev->mmds = phydev->drv->mmds;
@@ -782,6 +803,9 @@ struct phy_device *phy_connect(struct mii_dev *bus, int addr, */ int phy_startup(struct phy_device *phydev) { + if (!phydev) + return -1; + if (phydev->drv->startup) return phydev->drv->startup(phydev);
@@ -790,6 +814,9 @@ int phy_startup(struct phy_device *phydev)
static int __board_phy_config(struct phy_device *phydev) { + if (!phydev) + return -1; + if (phydev->drv->config) return phydev->drv->config(phydev); return 0; @@ -808,6 +835,9 @@ int phy_config(struct phy_device *phydev)
int phy_shutdown(struct phy_device *phydev) { + if (!phydev) + return -1; + if (phydev->drv->shutdown) phydev->drv->shutdown(phydev);
Heiko Schocher
