[PATCH] firmware: ti_sci: Add missing LF in error message
The "Message not acknowledged" error message is missing a line feed, leading to the console log getting garbled and joined together with whatever the next output is in case this error happens:
"ti_sci system-controller@44043000: Message not acknowledgedAuthentication failed!"
Fix ths by adding the missing linefeed character.
Signed-off-by: Andreas Dannenberg dannenberg@ti.com --- drivers/firmware/ti_sci.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/firmware/ti_sci.c b/drivers/firmware/ti_sci.c index bd7379ae55..72f572d824 100644 --- a/drivers/firmware/ti_sci.c +++ b/drivers/firmware/ti_sci.c @@ -265,7 +265,7 @@ static int ti_sci_do_xfer(struct ti_sci_info *info, if (xfer->rx_len) { ret = ti_sci_get_response(info, xfer, &info->chan_rx); if (!ti_sci_is_response_ack(xfer->tx_message.buf)) { - dev_err(info->dev, "Message not acknowledged"); + dev_err(info->dev, "Message not acknowledged\n"); ret = -ENODEV; } }
s/ths/this
Good find,
Acked-by: Andrew Davis afd@ti.com
} }dev_err(info->dev, "Message not acknowledged\n"); ret = -ENODEV;
s/ths/this
Good find,
I'll do my best to remember to fix this before pushing (checkpatch will remind me, I think), no need to v2.
s/ths/this
This slipped through the cracks on my end...
Good find,
Thanks Tom, I appreciate it.
-- Andreas Dannenberg Texas Instruments Inc
-- Tom
Signed-off-by: Andreas Dannenberg dannenberg@ti.com Acked-by: Andrew Davis afd@ti.com
Andreas Dannenberg
Andrew Davis
