[PATCH v6 0/7] tpm: rng: Move TPM RNG functionality to driver model
The TPM device provides the random number generator(RNG) functionality, whereby sending a command to the TPM device results in the TPM device responding with random bytes.
There was a discussion on the mailing list earlier[1], where it was explained that platforms with a TPM device can install the EFI_RNG_PROTOCOL for getting the random bytes instead of populating the dtb with the kaslr-seed property. That would make it possible to measure the dtb.
The TPM uclass driver adds the RNG child device as part of it's post_probe function.
Some additional changes have also been made to facilitate the use of the RNG devices, including extending the 'rng' command to take the RNG device as one of the command-line parameters.
This series depends on a patch[2] from Simon Glass for moving the TPM device version detection functions to the tpm_api.h header as static inline functions.
These patches were under discussion earlier, specifically the patch to add the RNG functionality under the TPM device as a child, either through manual binding or through the device tree. Ilias had commented on the discussion last[3]. The discussion can be resumed through this version.
I have dropped certain patches which were changing some of the TPM API functions to return an int instead of the current u32. These patches have been dropped due to review comments from Simon[4]. This work can be taken up separately, if desired.
[1] - https://lore.kernel.org/u-boot/20220103120738.47835-1-ilias.apalodimas@linar... [2] - https://lore.kernel.org/u-boot/20220301001125.1554442-2-sjg@chromium.org/T/#... [3] - https://lists.denx.de/pipermail/u-boot/2022-April/481708.html [4] - https://lists.denx.de/pipermail/u-boot/2022-March/477883.html
Simon Glass (1): tpm: Export the TPM-version functions
Sughosh Ganu (6): tpm: rng: Add driver model interface for TPM RNG device tpm: Add the RNG child device cmd: rng: Add support for selecting RNG device cmd: rng: Use a statically allocated array for random bytes doc: rng: Add documentation for the rng command test: rng: Add a UT testcase for the rng command
cmd/Kconfig | 1 + cmd/rng.c | 42 +++++++++++------ doc/usage/cmd/rng.rst | 26 +++++++++++ doc/usage/index.rst | 1 + drivers/rng/Kconfig | 11 +++++ drivers/rng/Makefile | 1 + drivers/rng/tpm_rng.c | 23 ++++++++++ drivers/tpm/tpm-uclass.c | 37 +++++++++++++-- include/tpm_api.h | 10 ++++ lib/Kconfig | 1 + lib/tpm-v1.c | 13 +++--- lib/tpm-v2.c | 6 +-- lib/tpm_api.c | 98 ++++++++++++++++++---------------------- test/dm/rng.c | 29 ++++++++++++ 14 files changed, 217 insertions(+), 82 deletions(-) create mode 100644 doc/usage/cmd/rng.rst create mode 100644 drivers/rng/tpm_rng.c
These functions should really be available outside the TPM code, so that other callers can find out which version the TPM is. Rename them to have a tpm_ prefix() and add them to the header file.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes since V5: None
include/tpm_api.h | 10 ++++++ lib/tpm_api.c | 92 +++++++++++++++++++++-------------------------- 2 files changed, 51 insertions(+), 51 deletions(-)
diff --git a/include/tpm_api.h b/include/tpm_api.h index ef45b43a8f..11aa14eb79 100644 --- a/include/tpm_api.h +++ b/include/tpm_api.h @@ -319,4 +319,14 @@ u32 tpm_write_lock(struct udevice *dev, u32 index); */ u32 tpm_resume(struct udevice *dev);
+static inline bool tpm_is_v1(struct udevice *dev) +{ + return IS_ENABLED(CONFIG_TPM_V1) && tpm_get_version(dev) == TPM_V1; +} + +static inline bool tpm_is_v2(struct udevice *dev) +{ + return IS_ENABLED(CONFIG_TPM_V2) && tpm_get_version(dev) == TPM_V2; +} + #endif /* __TPM_API_H */ diff --git a/lib/tpm_api.c b/lib/tpm_api.c index 4c662640a9..4ac4612c81 100644 --- a/lib/tpm_api.c +++ b/lib/tpm_api.c @@ -11,21 +11,11 @@ #include <tpm-v2.h> #include <tpm_api.h>
-static bool is_tpm1(struct udevice *dev) -{ - return IS_ENABLED(CONFIG_TPM_V1) && tpm_get_version(dev) == TPM_V1; -} - -static bool is_tpm2(struct udevice *dev) -{ - return IS_ENABLED(CONFIG_TPM_V2) && tpm_get_version(dev) == TPM_V2; -} - u32 tpm_startup(struct udevice *dev, enum tpm_startup_type mode) { - if (is_tpm1(dev)) { + if (tpm_is_v1(dev)) { return tpm1_startup(dev, mode); - } else if (is_tpm2(dev)) { + } else if (tpm_is_v2(dev)) { enum tpm2_startup_types type;
switch (mode) { @@ -47,9 +37,9 @@ u32 tpm_startup(struct udevice *dev, enum tpm_startup_type mode)
u32 tpm_resume(struct udevice *dev) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_startup(dev, TPM_ST_STATE); - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return tpm2_startup(dev, TPM2_SU_STATE); else return -ENOSYS; @@ -57,9 +47,9 @@ u32 tpm_resume(struct udevice *dev)
u32 tpm_self_test_full(struct udevice *dev) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_self_test_full(dev); - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return tpm2_self_test(dev, TPMI_YES); else return -ENOSYS; @@ -67,9 +57,9 @@ u32 tpm_self_test_full(struct udevice *dev)
u32 tpm_continue_self_test(struct udevice *dev) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_continue_self_test(dev); - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return tpm2_self_test(dev, TPMI_NO); else return -ENOSYS; @@ -86,7 +76,7 @@ u32 tpm_clear_and_reenable(struct udevice *dev) return ret; }
- if (is_tpm1(dev)) { + if (tpm_is_v1(dev)) { ret = tpm1_physical_enable(dev); if (ret != TPM_SUCCESS) { log_err("TPM: Can't set enabled state\n"); @@ -105,9 +95,9 @@ u32 tpm_clear_and_reenable(struct udevice *dev)
u32 tpm_nv_enable_locking(struct udevice *dev) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_nv_define_space(dev, TPM_NV_INDEX_LOCK, 0, 0); - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return -ENOSYS; else return -ENOSYS; @@ -115,9 +105,9 @@ u32 tpm_nv_enable_locking(struct udevice *dev)
u32 tpm_nv_read_value(struct udevice *dev, u32 index, void *data, u32 count) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_nv_read_value(dev, index, data, count); - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return tpm2_nv_read_value(dev, index, data, count); else return -ENOSYS; @@ -126,9 +116,9 @@ u32 tpm_nv_read_value(struct udevice *dev, u32 index, void *data, u32 count) u32 tpm_nv_write_value(struct udevice *dev, u32 index, const void *data, u32 count) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_nv_write_value(dev, index, data, count); - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return tpm2_nv_write_value(dev, index, data, count); else return -ENOSYS; @@ -141,9 +131,9 @@ u32 tpm_set_global_lock(struct udevice *dev)
u32 tpm_write_lock(struct udevice *dev, u32 index) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return -ENOSYS; - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return tpm2_write_lock(dev, index); else return -ENOSYS; @@ -152,9 +142,9 @@ u32 tpm_write_lock(struct udevice *dev, u32 index) u32 tpm_pcr_extend(struct udevice *dev, u32 index, const void *in_digest, void *out_digest) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_extend(dev, index, in_digest, out_digest); - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return tpm2_pcr_extend(dev, index, TPM2_ALG_SHA256, in_digest, TPM2_DIGEST_LEN); else @@ -163,9 +153,9 @@ u32 tpm_pcr_extend(struct udevice *dev, u32 index, const void *in_digest,
u32 tpm_pcr_read(struct udevice *dev, u32 index, void *data, size_t count) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_pcr_read(dev, index, data, count); - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return -ENOSYS; else return -ENOSYS; @@ -173,14 +163,14 @@ u32 tpm_pcr_read(struct udevice *dev, u32 index, void *data, size_t count)
u32 tpm_tsc_physical_presence(struct udevice *dev, u16 presence) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_tsc_physical_presence(dev, presence);
/* * Nothing to do on TPM2 for this; use platform hierarchy availability * instead. */ - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return 0; else return -ENOSYS; @@ -188,11 +178,11 @@ u32 tpm_tsc_physical_presence(struct udevice *dev, u16 presence)
u32 tpm_finalise_physical_presence(struct udevice *dev) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_finalise_physical_presence(dev);
/* Nothing needs to be done with tpm2 */ - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return 0; else return -ENOSYS; @@ -200,9 +190,9 @@ u32 tpm_finalise_physical_presence(struct udevice *dev)
u32 tpm_read_pubek(struct udevice *dev, void *data, size_t count) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_read_pubek(dev, data, count); - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return -ENOSYS; /* not implemented yet */ else return -ENOSYS; @@ -210,9 +200,9 @@ u32 tpm_read_pubek(struct udevice *dev, void *data, size_t count)
u32 tpm_force_clear(struct udevice *dev) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_force_clear(dev); - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return tpm2_clear(dev, TPM2_RH_PLATFORM, NULL, 0); else return -ENOSYS; @@ -220,11 +210,11 @@ u32 tpm_force_clear(struct udevice *dev)
u32 tpm_physical_enable(struct udevice *dev) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_physical_enable(dev);
/* Nothing needs to be done with tpm2 */ - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return 0; else return -ENOSYS; @@ -232,11 +222,11 @@ u32 tpm_physical_enable(struct udevice *dev)
u32 tpm_physical_disable(struct udevice *dev) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_physical_disable(dev);
/* Nothing needs to be done with tpm2 */ - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return 0; else return -ENOSYS; @@ -244,10 +234,10 @@ u32 tpm_physical_disable(struct udevice *dev)
u32 tpm_physical_set_deactivated(struct udevice *dev, u8 state) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_physical_set_deactivated(dev, state); /* Nothing needs to be done with tpm2 */ - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return 0; else return -ENOSYS; @@ -256,9 +246,9 @@ u32 tpm_physical_set_deactivated(struct udevice *dev, u8 state) u32 tpm_get_capability(struct udevice *dev, u32 cap_area, u32 sub_cap, void *cap, size_t count) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_get_capability(dev, cap_area, sub_cap, cap, count); - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return tpm2_get_capability(dev, cap_area, sub_cap, cap, count); else return -ENOSYS; @@ -266,9 +256,9 @@ u32 tpm_get_capability(struct udevice *dev, u32 cap_area, u32 sub_cap,
u32 tpm_get_permissions(struct udevice *dev, u32 index, u32 *perm) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_get_permissions(dev, index, perm); - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return -ENOSYS; /* not implemented yet */ else return -ENOSYS; @@ -276,9 +266,9 @@ u32 tpm_get_permissions(struct udevice *dev, u32 index, u32 *perm)
u32 tpm_get_random(struct udevice *dev, void *data, u32 count) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_get_random(dev, data, count); - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return -ENOSYS; /* not implemented yet */ else return -ENOSYS;
- if (tpm_is_v1(dev)) { return tpm1_startup(dev, mode);
switch (mode) {
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_startup(dev, TPM_ST_STATE);
- else if (tpm_is_v2(dev)) return tpm2_startup(dev, TPM2_SU_STATE); else return -ENOSYS;
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_self_test_full(dev);
- else if (tpm_is_v2(dev)) return tpm2_self_test(dev, TPMI_YES); else return -ENOSYS;
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_continue_self_test(dev);
- else if (tpm_is_v2(dev)) return tpm2_self_test(dev, TPMI_NO); else return -ENOSYS;
- if (tpm_is_v1(dev)) { ret = tpm1_physical_enable(dev); if (ret != TPM_SUCCESS) { log_err("TPM: Can't set enabled state\n");
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_nv_define_space(dev, TPM_NV_INDEX_LOCK, 0, 0);
- else if (tpm_is_v2(dev)) return -ENOSYS; else return -ENOSYS;
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_nv_read_value(dev, index, data, count);
- else if (tpm_is_v2(dev)) return tpm2_nv_read_value(dev, index, data, count); else return -ENOSYS;
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_nv_write_value(dev, index, data, count);
- else if (tpm_is_v2(dev)) return tpm2_nv_write_value(dev, index, data, count); else return -ENOSYS;
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return -ENOSYS;
- else if (tpm_is_v2(dev)) return tpm2_write_lock(dev, index); else return -ENOSYS;
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_extend(dev, index, in_digest, out_digest);
- else if (tpm_is_v2(dev)) return tpm2_pcr_extend(dev, index, TPM2_ALG_SHA256, in_digest, TPM2_DIGEST_LEN); else
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_pcr_read(dev, index, data, count);
- if (is_tpm1(dev))
- Nothing to do on TPM2 for this; use platform hierarchy availability
- instead.
- else if (tpm_is_v2(dev)) return 0; else return -ENOSYS;
- if (is_tpm1(dev))
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_read_pubek(dev, data, count);
- else if (tpm_is_v2(dev)) return -ENOSYS; /* not implemented yet */ else return -ENOSYS;
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_force_clear(dev);
- else if (tpm_is_v2(dev)) return tpm2_clear(dev, TPM2_RH_PLATFORM, NULL, 0); else return -ENOSYS;
- if (is_tpm1(dev))
- if (is_tpm1(dev))
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_physical_set_deactivated(dev, state); /* Nothing needs to be done with tpm2 */
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_get_capability(dev, cap_area, sub_cap, cap, count);
- else if (tpm_is_v2(dev)) return tpm2_get_capability(dev, cap_area, sub_cap, cap, count); else return -ENOSYS;
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_get_permissions(dev, index, perm);
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_get_random(dev, data, count);
-- 2.25.1
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
The TPM device has a builtin random number generator(RNG) functionality. Expose the RNG functions of the TPM device to the driver model so that they can be used by the EFI_RNG_PROTOCOL if the protocol is installed.
Also change the function arguments and return type of the random number functions to comply with the driver model api.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org --- Changes since V5: * Use the dev_get_parent() interface for getting the TPM device when calling the tpm_get_random() function
drivers/rng/Kconfig | 11 +++++++++++ drivers/rng/Makefile | 1 + drivers/rng/tpm_rng.c | 23 +++++++++++++++++++++++ lib/Kconfig | 1 + lib/tpm-v1.c | 13 +++++++------ lib/tpm-v2.c | 6 +++--- lib/tpm_api.c | 6 +++--- 7 files changed, 49 insertions(+), 12 deletions(-) create mode 100644 drivers/rng/tpm_rng.c
diff --git a/drivers/rng/Kconfig b/drivers/rng/Kconfig index c10f7d345b..67c65311c7 100644 --- a/drivers/rng/Kconfig +++ b/drivers/rng/Kconfig @@ -58,4 +58,15 @@ config RNG_IPROC200 depends on DM_RNG help Enable random number generator for RPI4. + +config TPM_RNG + bool "Enable random number generator on TPM device" + depends on TPM + default y + help + The TPM device has an inbuilt random number generator + functionality. Enable random number generator on TPM + devices. + + endif diff --git a/drivers/rng/Makefile b/drivers/rng/Makefile index 435b3b965a..e4ca9c4149 100644 --- a/drivers/rng/Makefile +++ b/drivers/rng/Makefile @@ -11,3 +11,4 @@ obj-$(CONFIG_RNG_OPTEE) += optee_rng.o obj-$(CONFIG_RNG_STM32MP1) += stm32mp1_rng.o obj-$(CONFIG_RNG_ROCKCHIP) += rockchip_rng.o obj-$(CONFIG_RNG_IPROC200) += iproc_rng200.o +obj-$(CONFIG_TPM_RNG) += tpm_rng.o diff --git a/drivers/rng/tpm_rng.c b/drivers/rng/tpm_rng.c new file mode 100644 index 0000000000..1a5e9e2e4b --- /dev/null +++ b/drivers/rng/tpm_rng.c @@ -0,0 +1,23 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * Copyright (c) 2022, Linaro Limited + */ + +#include <dm.h> +#include <rng.h> +#include <tpm_api.h> + +static int rng_tpm_random_read(struct udevice *dev, void *data, size_t count) +{ + return tpm_get_random(dev_get_parent(dev), data, count); +} + +static const struct dm_rng_ops tpm_rng_ops = { + .read = rng_tpm_random_read, +}; + +U_BOOT_DRIVER(tpm_rng) = { + .name = "tpm-rng", + .id = UCLASS_RNG, + .ops = &tpm_rng_ops, +}; diff --git a/lib/Kconfig b/lib/Kconfig index acc0ac081a..17efaa4c80 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -358,6 +358,7 @@ source lib/crypt/Kconfig config TPM bool "Trusted Platform Module (TPM) Support" depends on DM + imply DM_RNG help This enables support for TPMs which can be used to provide security features for your board. The TPM can be connected via LPC or I2C diff --git a/lib/tpm-v1.c b/lib/tpm-v1.c index 22a769c587..f7091e5bc7 100644 --- a/lib/tpm-v1.c +++ b/lib/tpm-v1.c @@ -9,12 +9,13 @@ #include <common.h> #include <dm.h> #include <log.h> -#include <asm/unaligned.h> -#include <u-boot/sha1.h> #include <tpm-common.h> #include <tpm-v1.h> #include "tpm-utils.h"
+#include <asm/unaligned.h> +#include <u-boot/sha1.h> + #ifdef CONFIG_TPM_AUTH_SESSIONS
#ifndef CONFIG_SHA1 @@ -892,19 +893,19 @@ u32 tpm1_get_random(struct udevice *dev, void *data, u32 count) if (pack_byte_string(buf, sizeof(buf), "sd", 0, command, sizeof(command), length_offset, this_bytes)) - return TPM_LIB_ERROR; + return -EIO; err = tpm_sendrecv_command(dev, buf, response, &response_length); if (err) return err; if (unpack_byte_string(response, response_length, "d", data_size_offset, &data_size)) - return TPM_LIB_ERROR; + return -EIO; if (data_size > count) - return TPM_LIB_ERROR; + return -EIO; if (unpack_byte_string(response, response_length, "s", data_offset, out, data_size)) - return TPM_LIB_ERROR; + return -EIO;
count -= data_size; out += data_size; diff --git a/lib/tpm-v2.c b/lib/tpm-v2.c index 1bf627853a..abca9a14b0 100644 --- a/lib/tpm-v2.c +++ b/lib/tpm-v2.c @@ -585,19 +585,19 @@ u32 tpm2_get_random(struct udevice *dev, void *data, u32 count) if (pack_byte_string(buf, sizeof(buf), "sw", 0, command_v2, sizeof(command_v2), sizeof(command_v2), this_bytes)) - return TPM_LIB_ERROR; + return -EIO; err = tpm_sendrecv_command(dev, buf, response, &response_length); if (err) return err; if (unpack_byte_string(response, response_length, "w", data_size_offset, &data_size)) - return TPM_LIB_ERROR; + return -EIO; if (data_size > this_bytes) return TPM_LIB_ERROR; if (unpack_byte_string(response, response_length, "s", data_offset, out, data_size)) - return TPM_LIB_ERROR; + return -EIO;
count -= data_size; out += data_size; diff --git a/lib/tpm_api.c b/lib/tpm_api.c index 4ac4612c81..032f383ca0 100644 --- a/lib/tpm_api.c +++ b/lib/tpm_api.c @@ -269,7 +269,7 @@ u32 tpm_get_random(struct udevice *dev, void *data, u32 count) if (tpm_is_v1(dev)) return tpm1_get_random(dev, data, count); else if (tpm_is_v2(dev)) - return -ENOSYS; /* not implemented yet */ - else - return -ENOSYS; + return tpm2_get_random(dev, data, count); + + return -ENOSYS; }
Hi Sughosh,
Changes since V5:
- Use the dev_get_parent() interface for getting the TPM device when calling the tpm_get_random() function
The API change should not be needed. The code that calls the TPM routines should adapt for that.
hi Simon,
On Tue, 5 Jul 2022 at 15:17, Simon Glass sjg@chromium.org wrote:
Hi Sughosh,
Changes since V5:
Are you referring to the changes made in tpm[1,2]_get_random functions? If so, those changes in the return values have been made based on review comments from Heinrich[1]. If you are referring to some other changes, please let me know. Thanks.
-sughosh
[1] - https://lists.denx.de/pipermail/u-boot/2022-February/476085.html
Hi Sughosh,
On Tue, 5 Jul 2022 at 11:23, Sughosh Ganu sughosh.ganu@linaro.org wrote:
hi Simon,
Hi Sughosh,
Changes since V5:
I think Heinrich might have the wrong end of the stick.
The TPM API returns a positive error code. We should not change it. The tpm_rng module can handle any conversion.
-sughosh
Changes since V5:
+config TPM_RNG
- bool "Enable random number generator on TPM device"
- depends on TPM
- default y
- help
devices.
Maybe we discussed this on a previous version, but why do we want to have this as a config option? Code size? A TPM will always be able to generate a random number. Couldn't we compile this based on an existing TPM Kconfig option?
- Copyright (c) 2022, Linaro Limited
- return tpm_get_random(dev_get_parent(dev), data, count);
- .read = rng_tpm_random_read,
- .name = "tpm-rng",
- .id = UCLASS_RNG,
- .ops = &tpm_rng_ops,
- imply DM_RNG help This enables support for TPMs which can be used to provide security features for your board. The TPM can be connected via LPC or I2C
err = tpm_sendrecv_command(dev, buf, response, &response_length); if (err) return err; if (unpack_byte_string(response, response_length, "d", data_size_offset, &data_size))return -EIO;
if (data_size > count)return -EIO;
if (unpack_byte_string(response, response_length, "s", data_offset, out, data_size))return -EIO;
return -EIO;
err = tpm_sendrecv_command(dev, buf, response, &response_length); if (err) return err; if (unpack_byte_string(response, response_length, "w", data_size_offset, &data_size))return -EIO;
if (data_size > this_bytes) return TPM_LIB_ERROR; if (unpack_byte_string(response, response_length, "s", data_offset, out, data_size))return -EIO;
return -EIO;
- else
return -ENOSYS;
- return -ENOSYS;
2.25.1
Thanks /Ilias
The TPM device comes with the random number generator(RNG) functionality which is built into the TPM device. Add logic to add the RNG child device in the TPM uclass post probe callback.
The RNG device can then be used to pass a set of random bytes to the linux kernel, need for address space randomisation through the EFI_RNG_PROTOCOL interface.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org --- Changes since V5: * Check if the TPM RNG device has already been added, through a call to device_find_first_child_by_uclass()
drivers/tpm/tpm-uclass.c | 37 +++++++++++++++++++++++++++++++++---- 1 file changed, 33 insertions(+), 4 deletions(-)
diff --git a/drivers/tpm/tpm-uclass.c b/drivers/tpm/tpm-uclass.c index f67fe1019b..e1f1ef01e1 100644 --- a/drivers/tpm/tpm-uclass.c +++ b/drivers/tpm/tpm-uclass.c @@ -11,10 +11,15 @@ #include <log.h> #include <linux/delay.h> #include <linux/unaligned/be_byteshift.h> +#include <tpm_api.h> #include <tpm-v1.h> #include <tpm-v2.h> #include "tpm_internal.h"
+#include <dm/lists.h> + +#define TPM_RNG_DRV_NAME "tpm-rng" + int tpm_open(struct udevice *dev) { struct tpm_ops *ops = tpm_get_ops(dev); @@ -136,12 +141,36 @@ int tpm_xfer(struct udevice *dev, const uint8_t *sendbuf, size_t send_size, return 0; }
+static int tpm_uclass_post_probe(struct udevice *dev) +{ + int ret; + const char *drv = TPM_RNG_DRV_NAME; + struct udevice *child; + + if (CONFIG_IS_ENABLED(TPM_RNG)) { + ret = device_find_first_child_by_uclass(dev, UCLASS_RNG, + &child); + + if (ret != -ENODEV) { + log_debug("RNG child already added to the TPM device\n"); + return ret; + } + + ret = device_bind_driver(dev, drv, "tpm-rng0", &child); + if (ret) + return log_msg_ret("bind", ret); + } + + return 0; +} + UCLASS_DRIVER(tpm) = { - .id = UCLASS_TPM, - .name = "tpm", - .flags = DM_UC_FLAG_SEQ_ALIAS, + .id = UCLASS_TPM, + .name = "tpm", + .flags = DM_UC_FLAG_SEQ_ALIAS, #if CONFIG_IS_ENABLED(OF_REAL) - .post_bind = dm_scan_fdt_dev, + .post_bind = dm_scan_fdt_dev, #endif + .post_probe = tpm_uclass_post_probe, .per_device_auto = sizeof(struct tpm_chip_priv), };
Hi Sughosh,
Changes since V5:
- Check if the TPM RNG device has already been added, through a call to device_find_first_child_by_uclass()
int ret;
&child);
This may return -EIO (for example) in which case your log message is incorrect.
return ret;
if (ret)
.id = UCLASS_TPM,
.name = "tpm",
.id = UCLASS_TPM,
.name = "tpm",
#endif
2.25.1
The driver needs a compatible string so it can be in the device tree.
Hi Simon,
.id = UCLASS_TPM,
.name = "tpm",
.id = UCLASS_TPM,
.name = "tpm",
#endif
2.25.1
Why? I've tried to hint this on the previous iteration of the patch. The RNG here is not a *device*. The TPM is the device and you are guaranteed to have an RNG. The way to get a random number is send a special command to the TPM. So all that we should do here is leverage the fact that the TPM is already in the device tree.
And fwiw we should stick to try to stick to what the DT spec defines as much as possible. I personally don't see this as a special usecase were deviating from the spec is justified.
Regards /Ilias
Hi Ilias,
On Fri, 8 Jul 2022 at 02:24, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Simon,
.id = UCLASS_TPM,
.name = "tpm",
.id = UCLASS_TPM,
.name = "tpm",
#endif
2.25.1
This is not a deviation from a spec. What spec? Also, I don't want to get into another discussion about what a device is. We can disagree on that if you like.
One reason is that U-Boot generally requires compatible strings, e.g. with of-platdata. But also we can refer to the rand device from elsewhere in the tree. I know that Linux does lots of ad-hoc device creation and doesn't really have the concept of a uclass consistently applied, but this is U-Boot.
So please add a compatible string sow e can use it in the DT.
\Regards, Simon
On Tue, Jul 12, 2022 at 5:04 AM Simon Glass sjg@chromium.org wrote:
Hi Ilias,
Hi Simon,
.id = UCLASS_TPM,
.name = "tpm",
.id = UCLASS_TPM,
.name = "tpm",
#endif
2.25.1
You are letting client/OS details define your binding. Doing so doesn't result in OS agnostic bindings. Sure, it would be nice if DT nodes and drivers were always a nice clean 1:1 ratio, but h/w is messy sometimes and DT is not an abstraction layer. The general guidance on whether there are child nodes for sub-blocks is do they have their own resources in DT or are the sub-blocks reusable on multiple devices. Neither of those are the case here.
Besides, we already have TPM device bindings defined. Requiring binding changes when adding a new client/OS feature is not good practice either.
Rob
Hi Rob,
Hi Ilias,
Hi Simon,
.id = UCLASS_TPM,
.name = "tpm",
.id = UCLASS_TPM,
.name = "tpm",
#endif
2.25.1
I'm not sure what to do with this, but in general the practice of implied subnodes is not friendly to U-Boot. Yet it seems like a common feature of the bindings at present, for example GPIOs.
The device tree is how U-Boot determines which random-number generator to use for a particular function. For example, for VBE, if we need to generate some random numbers we'd like to specify which device creates them. It can't just be 'use the TPM if you find one'. I'm not sure how that works in Linux?
Regards, SImon
On Wed, Jul 13, 2022 at 09:28:16AM -0600, Simon Glass wrote:
Hi Rob,
Hi Ilias,
Hi Simon,
.id = UCLASS_TPM,
.name = "tpm",
.id = UCLASS_TPM,
.name = "tpm",
#endif
2.25.1
Why can't it be "use the TPM if you find one" since a TPM is a superset of an RNG?
Hi Tom,
Hi Rob,
Hi Ilias,
Hi Simon,
> + > UCLASS_DRIVER(tpm) = { > - .id = UCLASS_TPM, > - .name = "tpm", > - .flags = DM_UC_FLAG_SEQ_ALIAS, > + .id = UCLASS_TPM, > + .name = "tpm", > + .flags = DM_UC_FLAG_SEQ_ALIAS, > #if CONFIG_IS_ENABLED(OF_REAL) > - .post_bind = dm_scan_fdt_dev, > + .post_bind = dm_scan_fdt_dev, > #endif > + .post_probe = tpm_uclass_post_probe, > .per_device_auto = sizeof(struct tpm_chip_priv), > }; > -- > 2.25.1 >
You mean look through the available rand devices and choose the one whose parent is a TPM?
Sure. There are lots of things you can do. But device tree is supposed to provide the tree of devices and allow such things to be configured deterministically.
On Thu, Jul 14, 2022 at 04:21:58AM -0600, Simon Glass wrote:
Hi Tom,
Hi Rob,
Hi Ilias,
Hi Simon,
> > + > > UCLASS_DRIVER(tpm) = { > > - .id = UCLASS_TPM, > > - .name = "tpm", > > - .flags = DM_UC_FLAG_SEQ_ALIAS, > > + .id = UCLASS_TPM, > > + .name = "tpm", > > + .flags = DM_UC_FLAG_SEQ_ALIAS, > > #if CONFIG_IS_ENABLED(OF_REAL) > > - .post_bind = dm_scan_fdt_dev, > > + .post_bind = dm_scan_fdt_dev, > > #endif > > + .post_probe = tpm_uclass_post_probe, > > .per_device_auto = sizeof(struct tpm_chip_priv), > > }; > > -- > > 2.25.1 > > > > The driver needs a compatible string so it can be in the device tree.
No, I mean pick the TPM device because by definition it is an RNG.
Hi Tom,
Hi Tom,
Hi Rob,
Hi Ilias,
On Fri, 8 Jul 2022 at 02:24, Ilias Apalodimas ilias.apalodimas@linaro.org wrote: > > Hi Simon, > > [...] > > > > + > > > UCLASS_DRIVER(tpm) = { > > > - .id = UCLASS_TPM, > > > - .name = "tpm", > > > - .flags = DM_UC_FLAG_SEQ_ALIAS, > > > + .id = UCLASS_TPM, > > > + .name = "tpm", > > > + .flags = DM_UC_FLAG_SEQ_ALIAS, > > > #if CONFIG_IS_ENABLED(OF_REAL) > > > - .post_bind = dm_scan_fdt_dev, > > > + .post_bind = dm_scan_fdt_dev, > > > #endif > > > + .post_probe = tpm_uclass_post_probe, > > > .per_device_auto = sizeof(struct tpm_chip_priv), > > > }; > > > -- > > > 2.25.1 > > > > > > > The driver needs a compatible string so it can be in the device tree. > > Why? I've tried to hint this on the previous iteration of the patch. > The RNG here is not a *device*. The TPM is the device and you are > guaranteed to have an RNG. The way to get a random number is send a > special command to the TPM. So all that we should do here is leverage > the fact that the TPM is already in the device tree. > > And fwiw we should stick to try to stick to what the DT spec defines > as much as possible. I personally don't see this as a special usecase > were deviating from the spec is justified.
I think that is what I said, or meant. The TPM is not a rand device, it is the child of the TPM which might be. But for example, the Google cr50 may not be.
Hi Simon,
> > > The driver needs a compatible string so it can be in the device tree. > > > > Why? I've tried to hint this on the previous iteration of the patch. > > The RNG here is not a *device*. The TPM is the device and you are > > guaranteed to have an RNG. The way to get a random number is send a > > special command to the TPM. So all that we should do here is leverage > > the fact that the TPM is already in the device tree. > > > > And fwiw we should stick to try to stick to what the DT spec defines > > as much as possible. I personally don't see this as a special usecase > > were deviating from the spec is justified. > > This is not a deviation from a spec. What spec? Also, I don't want to > get into another discussion about what a device is. We can disagree on > that if you like. > > One reason is that U-Boot generally requires compatible strings, e.g. > with of-platdata. But also we can refer to the rand device from > elsewhere in the tree. I know that Linux does lots of ad-hoc device > creation and doesn't really have the concept of a uclass consistently > applied, but this is U-Boot.
The design principle of the tpm1.2 says that it must have an rng [1]. I think something similar is implied on 2.0 architecture as well [2]. Looking at the cr50 description is says "TPM-like" [3] not TPM. I assume an RNG exists internally since the TPM requires and RNG for nonces, key generation etc.
Any idea what happens if you run tpm_getrandom() against a cr50? If you get back garbage then we got a problem since you can't really tell if it's garbage or a random seed. But if it returns something sane along the lines of 'not supported' then I guess we can use that and try the next RNG?
[1] https://trustedcomputinggroup.org/wp-content/uploads/TPM-Main-Part-1-Design-... 4.2.5 random number generator [2] https://trustedcomputinggroup.org/wp-content/uploads/TPM-Rev-2.0-Part-1-Arch... 11.4.10 RNG module [3] https://www.kernel.org/doc/Documentation/devicetree/bindings/security/tpm/go...
Regards /Ilias
On Thu, Jul 14, 2022 at 06:47:28PM +0300, Ilias Apalodimas wrote:
Hi Simon,
> > > > The driver needs a compatible string so it can be in the device tree. > > > > > > Why? I've tried to hint this on the previous iteration of the patch. > > > The RNG here is not a *device*. The TPM is the device and you are > > > guaranteed to have an RNG. The way to get a random number is send a > > > special command to the TPM. So all that we should do here is leverage > > > the fact that the TPM is already in the device tree. > > > > > > And fwiw we should stick to try to stick to what the DT spec defines > > > as much as possible. I personally don't see this as a special usecase > > > were deviating from the spec is justified. > > > > This is not a deviation from a spec. What spec? Also, I don't want to > > get into another discussion about what a device is. We can disagree on > > that if you like. > > > > One reason is that U-Boot generally requires compatible strings, e.g. > > with of-platdata. But also we can refer to the rand device from > > elsewhere in the tree. I know that Linux does lots of ad-hoc device > > creation and doesn't really have the concept of a uclass consistently > > applied, but this is U-Boot. > > You are letting client/OS details define your binding. Doing so > doesn't result in OS agnostic bindings. Sure, it would be nice if DT > nodes and drivers were always a nice clean 1:1 ratio, but h/w is messy > sometimes and DT is not an abstraction layer. The general guidance on > whether there are child nodes for sub-blocks is do they have their own > resources in DT or are the sub-blocks reusable on multiple devices. > Neither of those are the case here. > > Besides, we already have TPM device bindings defined. Requiring > binding changes when adding a new client/OS feature is not good > practice either.
What I'm saying is from what I understand a spec compliant TPM is an RNG, so we should be able to match on that existing compatible. What the cr50 does or doesn't do (or is or is not compliant about) would indeed make things more complex but I think also maybe helps the rest of us understand where you've been coming from.
On Wed, Jul 13, 2022 at 9:28 AM Simon Glass sjg@chromium.org wrote:
Hi Rob,
Hi Ilias,
Hi Simon,
.id = UCLASS_TPM,
.name = "tpm",
.id = UCLASS_TPM,
.name = "tpm",
#endif
2.25.1
It's perfectly normal for a single device to be multiple providers. A common example is clock AND reset blocks. They are both a clock and reset provider. So you could have either:
crm { compatible = "foo,soc-crm"; clock-controller { compatible = "foo,soc-crm-clocks"; #clock-cells = <1>; }; reset-controller { compatible = "foo,soc-crm-resets"; #reset-cells = <1>; }; };
or:
crm { compatible = "foo,soc-crm"; #clock-cells = <1>; #reset-cells = <1>; };
Which one's right? Well, depends on the h/w really. If clock and reset controls are interleaved bits or registers, then the first case really doesn't make sense.
In any case, this ship has sailed. There are tons of the latter case already, so either you have to figure out support 1 DT node to N drivers or you're going to be carrying a bunch of your own u-boot bindings.
Why not?
Not sure. I think Linux's answer is use all of the RNG sources and none of them directly.
Rob
Hi Rob,
Hi Ilias,
Hi Simon,
or:
Thanks for the info. I'm really only talking about this TPM issue here.
Why not?
It isn't deterministic. This is exactly the sort of selection that device tree is supposed to permit. It would be better to have a phandle from the board-config node, VBE method node, or something else that provides the devices to be used.
OK.
Re Ilias' question about cr50, I don't know.
Re Tom's point about matching on compatible strings, IMO it is cleaner for the driver to create a child device for the random-number device if it can provide one, as is done with PMIC when providing GPIOS and regulators, for example.
Since it seems that the TPM binding does not have this, my preference would be to add this to the TPM binding.
If that is not acceptable, then we have the TPM_RNG option which we can disable when we do have such a binding, perhaps only in U-Boot.
I think I have made my point here and people understand it, so I'll drop my objection to this patch and we can worry about it later if it causes problems.
The 'rng' u-boot command is used for printing a select number of random bytes on the console. Currently, the RNG device from which the random bytes are read is fixed. However, a platform can have multiple RNG devices, one example being qemu, which has a virtio RNG device and the RNG pseudo device through the TPM chip.
Extend the 'rng' command so that the user can provide the RNG device number from which the random bytes are to be read. This will be the device index under the RNG uclass.
Tested-by: Heinrich Schuchardt xypron.glpk@gmx.de Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org --- Changes since V5: None
cmd/rng.c | 31 +++++++++++++++++++++++-------- 1 file changed, 23 insertions(+), 8 deletions(-)
diff --git a/cmd/rng.c b/cmd/rng.c index 1ad5a096c0..2ddf27545f 100644 --- a/cmd/rng.c +++ b/cmd/rng.c @@ -13,19 +13,34 @@
static int do_rng(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - size_t n = 0x40; + size_t n; struct udevice *dev; void *buf; + int devnum; int ret = CMD_RET_SUCCESS;
- if (uclass_get_device(UCLASS_RNG, 0, &dev) || !dev) { + switch (argc) { + case 1: + devnum = 0; + n = 0x40; + break; + case 2: + devnum = hextoul(argv[1], NULL); + n = 0x40; + break; + case 3: + devnum = hextoul(argv[1], NULL); + n = hextoul(argv[2], NULL); + break; + default: + return CMD_RET_USAGE; + } + + if (uclass_get_device_by_seq(UCLASS_RNG, devnum, &dev) || !dev) { printf("No RNG device\n"); return CMD_RET_FAILURE; }
- if (argc >= 2) - n = hextoul(argv[1], NULL); - buf = malloc(n); if (!buf) { printf("Out of memory\n"); @@ -46,12 +61,12 @@ static int do_rng(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[])
#ifdef CONFIG_SYS_LONGHELP static char rng_help_text[] = - "[n]\n" - " - print n random bytes\n"; + "[dev [n]]\n" + " - print n random bytes read from dev\n"; #endif
U_BOOT_CMD( - rng, 2, 0, do_rng, + rng, 3, 0, do_rng, "print bytes from the hardware random number generator", rng_help_text );
Use a statically allocated buffer on stack instead of using malloc for reading the random bytes. Using a local array is faster than allocating heap memory on every initiation of the command.
cmd/rng.c | 17 +++++++---------- 1 file changed, 7 insertions(+), 10 deletions(-)
diff --git a/cmd/rng.c b/cmd/rng.c index 2ddf27545f..81a23964b8 100644 --- a/cmd/rng.c +++ b/cmd/rng.c @@ -14,9 +14,9 @@ static int do_rng(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { size_t n; - struct udevice *dev; - void *buf; + u8 buf[64]; int devnum; + struct udevice *dev; int ret = CMD_RET_SUCCESS;
switch (argc) { @@ -41,11 +41,10 @@ static int do_rng(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) return CMD_RET_FAILURE; }
- buf = malloc(n); - if (!buf) { - printf("Out of memory\n"); - return CMD_RET_FAILURE; - } + if (!n) + return 0; + + n = min(n, sizeof(buf));
if (dm_rng_read(dev, buf, n)) { printf("Reading RNG failed\n"); @@ -54,15 +53,13 @@ static int do_rng(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) print_hex_dump_bytes("", DUMP_PREFIX_OFFSET, buf, n); }
- free(buf); - return ret; }
#ifdef CONFIG_SYS_LONGHELP static char rng_help_text[] = "[dev [n]]\n" - " - print n random bytes read from dev\n"; + " - print n random bytes(max 64) read from dev\n"; #endif
U_BOOT_CMD(
- void *buf;
switch (argc) {
- buf = malloc(n);
- if (!buf) {
if (!n)
- free(buf);
- return ret;
- " - print n random bytes(max 64) read from dev\n";
#endif
U_BOOT_CMD(
2.25.1
Add a usage document for the 'rng' u-boot command.
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org --- Changes since V5: None
doc/usage/cmd/rng.rst | 26 ++++++++++++++++++++++++++ doc/usage/index.rst | 1 + 2 files changed, 27 insertions(+) create mode 100644 doc/usage/cmd/rng.rst
diff --git a/doc/usage/cmd/rng.rst b/doc/usage/cmd/rng.rst new file mode 100644 index 0000000000..1a352da41a --- /dev/null +++ b/doc/usage/cmd/rng.rst @@ -0,0 +1,26 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +rng command +=========== + +Synopsis +-------- + +:: + + rng [devnum [n]] + +Description +----------- + +The *rng* command reads the random number generator(RNG) device and +prints the random bytes read on the console. A maximum of 64 bytes can +be read in one invocation of the command. + +devnum + The RNG device from which the random bytes are to be + read. Defaults to 0. + +n + Number of random bytes to be read and displayed on the + console. Default value is 0x40. Max value is 0x40. diff --git a/doc/usage/index.rst b/doc/usage/index.rst index 770418434a..ed3a78aa14 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -53,6 +53,7 @@ Shell commands cmd/pstore cmd/qfw cmd/reset + cmd/rng cmd/sbi cmd/sf cmd/scp03
The 'rng' command dumps a number of random bytes on the console. Add a set of tests for the 'rng' command. The test function performs basic sanity testing of the command.
Since a unit test is being added for the command, enable it by default in the sandbox platforms.
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org --- cmd/Kconfig | 1 + test/dm/rng.c | 29 +++++++++++++++++++++++++++++ 2 files changed, 30 insertions(+)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 09193b61b9..eee5d44348 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1916,6 +1916,7 @@ config CMD_GETTIME config CMD_RNG bool "rng command" depends on DM_RNG + default y if SANDBOX select HEXDUMP help Print bytes from the hardware random number generator. diff --git a/test/dm/rng.c b/test/dm/rng.c index 5b34c93ed6..6d1f68848d 100644 --- a/test/dm/rng.c +++ b/test/dm/rng.c @@ -25,3 +25,32 @@ static int dm_test_rng_read(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_rng_read, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT); + +/* Test the rng command */ +static int dm_test_rng_cmd(struct unit_test_state *uts) +{ + struct udevice *dev; + + ut_assertok(uclass_get_device(UCLASS_RNG, 0, &dev)); + ut_assertnonnull(dev); + + ut_assertok(console_record_reset_enable()); + + run_command("rng", 0); + ut_assert_nextlinen("00000000:"); + ut_assert_nextlinen("00000010:"); + ut_assert_nextlinen("00000020:"); + ut_assert_nextlinen("00000030:"); + ut_assert_console_end(); + + run_command("rng 0 10", 0); + ut_assert_nextlinen("00000000:"); + ut_assert_console_end(); + + run_command("rng 20", 0); + ut_assert_nextlinen("No RNG device"); + ut_assert_console_end(); + + return 0; +} +DM_TEST(dm_test_rng_cmd, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT | UT_TESTF_CONSOLE_REC);
- default y if SANDBOX select HEXDUMP help Print bytes from the hardware random number generator.
- ut_assertok(uclass_get_device(UCLASS_RNG, 0, &dev));
- ut_assertnonnull(dev);
- ut_assertok(console_record_reset_enable());
- run_command("rng", 0);
- ut_assert_nextlinen("00000000:");
- ut_assert_nextlinen("00000010:");
- ut_assert_nextlinen("00000020:");
- ut_assert_nextlinen("00000030:");
- ut_assert_console_end();
- run_command("rng 0 10", 0);
- run_command("rng 20", 0);
- ut_assert_nextlinen("No RNG device");
2.25.1
Acked-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Hi Sughosh,
-- 2.25.1
This looks OK to me.
participants (5)
Ilias Apalodimas
Rob Herring
Sughosh Ganu
