[U-Boot] [PATCH v9 0/9] Update SiFive Unleashed Drivers
This series update SiFive Unleashed clock driver and Cadence MACB driver so that: 1. It is in sync with upstream Linux driver 2. It uses latest DT bindings as-per upstream Linux driver
With this series, we can now use latest DT bindings with U-Boot. I have tested SiFive Serial driver and Cadence MACB ethernet driver with this changes and both work fine.
The legacy FSBL will still pass DTB with older DT bindings which will break the updated SiFive Unleashed clock driver. To tackle this, we have embedded DTB in OpenSBI FW_PAYLOAD firmware for SiFive Unleashed so that OpenSBI will override and pass updated DTB to U-Boot.
The updated DTB passed by OpenSBI is in fact the DTB build by upstream Linux so we can straight away pass this DTB to Linux as well.
This series can be found in riscv_unleashed_clk_sync_v9 branch at: https://github.com/avpatel/u-boot.git
To try this series use latest OpenSBI at: https://github.com/riscv/opensbi.git And Linux-5.2-rc1 from v5.2-rc1_unleashed branch at: https://github.com/avpatel/linux.git
Changes since v8: - Removed probe() from macb_config for PATCH6 - Renamed set_tx_clk() to clk_init() in macb_config for PATCH6
Changes since v7: - Update PATCH6 to not treat dma_burst_length = 0 as skip gmac_configure_dma() - Update PATCH9 to check endianess at runtime
Changes since v6: - Added separate patch to fix endianess check in gmac_configure_dma()
Changes since v5: - Addressed Ramon's comments in PATCH6 - Addressed Bin's comments in PATCH7
Changes since v4: - Rebased patches upon Ramon's MACB changes (Refer, https://patchwork.ozlabs.org/patch/1114025/) - Added PATCH7 to setup ethaddr based on board serial number read from OTP - Added PATCH8 to update documentation
Changes since v3: - Extend MACB ethernet driver for SiFive Unleashed board (just like Linux)
Changes since v2: - Dropped PATCH6 which adds new compatible string to MACB driver because more changes are required in MACB driver for different ethernet speeds
Changes since v1: - Dropped GEMGXL clock driver - Added new compatible string for SiFive MACB ethernet
Anup Patel (9): clk: sifive: Factor-out PLL library as separate module clk: sifive: Sync-up WRPLL library with upstream Linux clk: sifive: Sync-up DT bindings header with upstream Linux clk: sifive: Sync-up main driver with upstream Linux clk: sifive: Drop GEMGXL clock driver net: macb: Extend MACB driver for SiFive Unleashed board riscv: sifive: fu540: Setup ethaddr env variable using OTP doc: sifive-fu540: Update README for steps to create FW_PAYLOAD net: macb: Fix check for little-endian system in gmac_configure_dma()
board/sifive/fu540/Kconfig | 1 - board/sifive/fu540/fu540.c | 122 ++++++ configs/sifive_fu540_defconfig | 1 + doc/README.sifive-fu540 | 356 ++++++++---------- drivers/clk/Kconfig | 1 + drivers/clk/Makefile | 1 + drivers/clk/analogbits/Kconfig | 4 + drivers/clk/analogbits/Makefile | 3 + .../{sifive => analogbits}/wrpll-cln28hpc.c | 168 ++++----- drivers/clk/sifive/Kconfig | 10 - drivers/clk/sifive/Makefile | 4 - drivers/clk/sifive/fu540-prci.c | 123 +++--- drivers/clk/sifive/gemgxl-mgmt.c | 60 --- drivers/net/macb.c | 82 ++-- include/dt-bindings/clk/sifive-fu540-prci.h | 29 -- include/dt-bindings/clock/sifive-fu540-prci.h | 18 + .../linux/clk}/analogbits-wrpll-cln28hpc.h | 70 ++-- 17 files changed, 543 insertions(+), 510 deletions(-) create mode 100644 drivers/clk/analogbits/Kconfig create mode 100644 drivers/clk/analogbits/Makefile rename drivers/clk/{sifive => analogbits}/wrpll-cln28hpc.c (69%) delete mode 100644 drivers/clk/sifive/gemgxl-mgmt.c delete mode 100644 include/dt-bindings/clk/sifive-fu540-prci.h create mode 100644 include/dt-bindings/clock/sifive-fu540-prci.h rename {drivers/clk/sifive => include/linux/clk}/analogbits-wrpll-cln28hpc.h (52%)
-- 2.17.1
To match SiFive clock driver with latest Linux, we factor-out PLL library as separate module under drivers/clk/analogbits.
Signed-off-by: Anup Patel anup.patel@wdc.com Reviewed-by: Bin Meng bmeng.cn@gmail.com --- drivers/clk/Kconfig | 1 + drivers/clk/Makefile | 1 + drivers/clk/analogbits/Kconfig | 4 ++++ drivers/clk/analogbits/Makefile | 3 +++ drivers/clk/{sifive => analogbits}/wrpll-cln28hpc.c | 3 +-- drivers/clk/sifive/Kconfig | 3 --- drivers/clk/sifive/Makefile | 2 -- drivers/clk/sifive/fu540-prci.c | 3 +-- .../sifive => include/linux/clk}/analogbits-wrpll-cln28hpc.h | 0 9 files changed, 11 insertions(+), 9 deletions(-) create mode 100644 drivers/clk/analogbits/Kconfig create mode 100644 drivers/clk/analogbits/Makefile rename drivers/clk/{sifive => analogbits}/wrpll-cln28hpc.c (99%) rename {drivers/clk/sifive => include/linux/clk}/analogbits-wrpll-cln28hpc.h (100%)
diff --git a/drivers/clk/Kconfig b/drivers/clk/Kconfig index 96969b9e30..7b81eacf50 100644 --- a/drivers/clk/Kconfig +++ b/drivers/clk/Kconfig @@ -98,6 +98,7 @@ config CLK_STM32MP1 Enable the STM32 clock (RCC) driver. Enable support for manipulating STM32MP1's on-SoC clocks.
+source "drivers/clk/analogbits/Kconfig" source "drivers/clk/at91/Kconfig" source "drivers/clk/exynos/Kconfig" source "drivers/clk/imx/Kconfig" diff --git a/drivers/clk/Makefile b/drivers/clk/Makefile index 719b9b8e02..f0ced49e5a 100644 --- a/drivers/clk/Makefile +++ b/drivers/clk/Makefile @@ -8,6 +8,7 @@ obj-$(CONFIG_$(SPL_TPL_)CLK) += clk-uclass.o obj-$(CONFIG_$(SPL_TPL_)CLK) += clk_fixed_rate.o obj-$(CONFIG_$(SPL_TPL_)CLK) += clk_fixed_factor.o
+obj-y += analogbits/ obj-y += imx/ obj-y += tegra/ obj-$(CONFIG_ARCH_ASPEED) += aspeed/ diff --git a/drivers/clk/analogbits/Kconfig b/drivers/clk/analogbits/Kconfig new file mode 100644 index 0000000000..1d25e6f124 --- /dev/null +++ b/drivers/clk/analogbits/Kconfig @@ -0,0 +1,4 @@ +# SPDX-License-Identifier: GPL-2.0 + +config CLK_ANALOGBITS_WRPLL_CLN28HPC + bool diff --git a/drivers/clk/analogbits/Makefile b/drivers/clk/analogbits/Makefile new file mode 100644 index 0000000000..ec1bb4092b --- /dev/null +++ b/drivers/clk/analogbits/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-$(CONFIG_CLK_ANALOGBITS_WRPLL_CLN28HPC) += wrpll-cln28hpc.o diff --git a/drivers/clk/sifive/wrpll-cln28hpc.c b/drivers/clk/analogbits/wrpll-cln28hpc.c similarity index 99% rename from drivers/clk/sifive/wrpll-cln28hpc.c rename to drivers/clk/analogbits/wrpll-cln28hpc.c index d377849693..68eb1148b9 100644 --- a/drivers/clk/sifive/wrpll-cln28hpc.c +++ b/drivers/clk/analogbits/wrpll-cln28hpc.c @@ -35,8 +35,7 @@ #include <linux/err.h> #include <linux/log2.h> #include <linux/math64.h> - -#include "analogbits-wrpll-cln28hpc.h" +#include <linux/clk/analogbits-wrpll-cln28hpc.h>
/* MIN_INPUT_FREQ: minimum input clock frequency, in Hz (Fref_min) */ #define MIN_INPUT_FREQ 7000000 diff --git a/drivers/clk/sifive/Kconfig b/drivers/clk/sifive/Kconfig index 644881b948..d90be1943f 100644 --- a/drivers/clk/sifive/Kconfig +++ b/drivers/clk/sifive/Kconfig @@ -1,8 +1,5 @@ # SPDX-License-Identifier: GPL-2.0
-config CLK_ANALOGBITS_WRPLL_CLN28HPC - bool - config CLK_SIFIVE bool "SiFive SoC driver support" depends on CLK diff --git a/drivers/clk/sifive/Makefile b/drivers/clk/sifive/Makefile index f8263e79b7..0813360ca7 100644 --- a/drivers/clk/sifive/Makefile +++ b/drivers/clk/sifive/Makefile @@ -1,7 +1,5 @@ # SPDX-License-Identifier: GPL-2.0+
-obj-$(CONFIG_CLK_ANALOGBITS_WRPLL_CLN28HPC) += wrpll-cln28hpc.o - obj-$(CONFIG_CLK_SIFIVE_FU540_PRCI) += fu540-prci.o
obj-$(CONFIG_CLK_SIFIVE_GEMGXL_MGMT) += gemgxl-mgmt.o diff --git a/drivers/clk/sifive/fu540-prci.c b/drivers/clk/sifive/fu540-prci.c index 2d47ebc6b1..56084db2e6 100644 --- a/drivers/clk/sifive/fu540-prci.c +++ b/drivers/clk/sifive/fu540-prci.c @@ -37,10 +37,9 @@ #include <errno.h>
#include <linux/math64.h> +#include <linux/clk/analogbits-wrpll-cln28hpc.h> #include <dt-bindings/clk/sifive-fu540-prci.h>
-#include "analogbits-wrpll-cln28hpc.h" - /* * EXPECTED_CLK_PARENT_COUNT: how many parent clocks this driver expects: * hfclk and rtcclk diff --git a/drivers/clk/sifive/analogbits-wrpll-cln28hpc.h b/include/linux/clk/analogbits-wrpll-cln28hpc.h similarity index 100% rename from drivers/clk/sifive/analogbits-wrpll-cln28hpc.h rename to include/linux/clk/analogbits-wrpll-cln28hpc.h
Now that SiFive clock driver is merged in upstream Linux, we sync-up WRPLL library used by SiFive clock driver with upstream Linux sources.
Signed-off-by: Anup Patel anup.patel@wdc.com Reviewed-by: Bin Meng bmeng.cn@gmail.com --- drivers/clk/analogbits/wrpll-cln28hpc.c | 165 ++++++++---------- drivers/clk/sifive/fu540-prci.c | 26 +-- include/linux/clk/analogbits-wrpll-cln28hpc.h | 70 +++----- 3 files changed, 107 insertions(+), 154 deletions(-)
diff --git a/drivers/clk/analogbits/wrpll-cln28hpc.c b/drivers/clk/analogbits/wrpll-cln28hpc.c index 68eb1148b9..776ead319a 100644 --- a/drivers/clk/analogbits/wrpll-cln28hpc.c +++ b/drivers/clk/analogbits/wrpll-cln28hpc.c @@ -1,20 +1,9 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (c) 2019 Western Digital Corporation or its affiliates. - * - * Copyright (C) 2018 SiFive, Inc. + * Copyright (C) 2018-2019 SiFive, Inc. * Wesley Terpstra * Paul Walmsley * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * * This library supports configuration parsing and reprogramming of * the CLN28HPC variant of the Analog Bits Wide Range PLL. The * intention is for this library to be reusable for any device that @@ -29,6 +18,7 @@ * References: * - Analog Bits "Wide Range PLL Datasheet", version 2015.10.01 * - SiFive FU540-C000 Manual v1p0, Chapter 7 "Clocking and Reset" + * https://static.dev.sifive.com/FU540-C000-v1.0.pdf */
#include <linux/bug.h> @@ -84,40 +74,38 @@ * range selection. * * Return: The RANGE value to be presented to the PLL configuration inputs, - * or -1 upon error. + * or a negative return code upon error. */ static int __wrpll_calc_filter_range(unsigned long post_divr_freq) { - u8 range; - if (post_divr_freq < MIN_POST_DIVR_FREQ || post_divr_freq > MAX_POST_DIVR_FREQ) { WARN(1, "%s: post-divider reference freq out of range: %lu", __func__, post_divr_freq); - return -1; + return -ERANGE; }
- if (post_divr_freq < 11000000) - range = 1; - else if (post_divr_freq < 18000000) - range = 2; - else if (post_divr_freq < 30000000) - range = 3; - else if (post_divr_freq < 50000000) - range = 4; - else if (post_divr_freq < 80000000) - range = 5; - else if (post_divr_freq < 130000000) - range = 6; - else - range = 7; - - return range; + switch (post_divr_freq) { + case 0 ... 10999999: + return 1; + case 11000000 ... 17999999: + return 2; + case 18000000 ... 29999999: + return 3; + case 30000000 ... 49999999: + return 4; + case 50000000 ... 79999999: + return 5; + case 80000000 ... 129999999: + return 6; + } + + return 7; }
/** * __wrpll_calc_fbdiv() - return feedback fixed divide value - * @c: ptr to a struct analogbits_wrpll_cfg record to read from + * @c: ptr to a struct wrpll_cfg record to read from * * The internal feedback path includes a fixed by-two divider; the * external feedback path does not. Return the appropriate divider @@ -132,7 +120,7 @@ static int __wrpll_calc_filter_range(unsigned long post_divr_freq) * Return: 2 if internal feedback is enabled or 1 if external feedback * is enabled. */ -static u8 __wrpll_calc_fbdiv(struct analogbits_wrpll_cfg *c) +static u8 __wrpll_calc_fbdiv(const struct wrpll_cfg *c) { return (c->flags & WRPLL_FLAGS_INT_FEEDBACK_MASK) ? 2 : 1; } @@ -172,7 +160,7 @@ static u8 __wrpll_calc_divq(u32 target_rate, u64 *vco_rate) *vco_rate = MIN_VCO_FREQ; } else { divq = ilog2(s); - *vco_rate = target_rate << divq; + *vco_rate = (u64)target_rate << divq; }
wcd_out: @@ -181,7 +169,7 @@ wcd_out:
/** * __wrpll_update_parent_rate() - update PLL data when parent rate changes - * @c: ptr to a struct analogbits_wrpll_cfg record to write PLL data to + * @c: ptr to a struct wrpll_cfg record to write PLL data to * @parent_rate: PLL input refclk rate (pre-R-divider) * * Pre-compute some data used by the PLL configuration algorithm when @@ -189,46 +177,40 @@ wcd_out: * computation when the parent rate remains constant - expected to be * the common case. * - * Returns: 0 upon success or -1 if the reference clock rate is out of range. + * Returns: 0 upon success or -ERANGE if the reference clock rate is + * out of range. */ -static int __wrpll_update_parent_rate(struct analogbits_wrpll_cfg *c, +static int __wrpll_update_parent_rate(struct wrpll_cfg *c, unsigned long parent_rate) { u8 max_r_for_parent;
if (parent_rate > MAX_INPUT_FREQ || parent_rate < MIN_POST_DIVR_FREQ) - return -1; + return -ERANGE;
- c->_parent_rate = parent_rate; + c->parent_rate = parent_rate; max_r_for_parent = div_u64(parent_rate, MIN_POST_DIVR_FREQ); - c->_max_r = min_t(u8, MAX_DIVR_DIVISOR, max_r_for_parent); + c->max_r = min_t(u8, MAX_DIVR_DIVISOR, max_r_for_parent);
- /* Round up */ - c->_init_r = div_u64(parent_rate + MAX_POST_DIVR_FREQ - 1, - MAX_POST_DIVR_FREQ); + c->init_r = DIV_ROUND_UP_ULL(parent_rate, MAX_POST_DIVR_FREQ);
return 0; }
-/* - * Public functions - */ - /** - * analogbits_wrpll_configure() - compute PLL configuration for a target rate - * @c: ptr to a struct analogbits_wrpll_cfg record to write into + * wrpll_configure() - compute PLL configuration for a target rate + * @c: ptr to a struct wrpll_cfg record to write into * @target_rate: target PLL output clock rate (post-Q-divider) * @parent_rate: PLL input refclk rate (pre-R-divider) * - * Given a pointer to a PLL context @c, a desired PLL target output - * rate @target_rate, and a reference clock input rate @parent_rate, - * compute the appropriate PLL signal configuration values. PLL - * reprogramming is not glitchless, so the caller should switch any - * downstream logic to a different clock source or clock-gate it - * before presenting these values to the PLL configuration signals. + * Compute the appropriate PLL signal configuration values and store + * in PLL context @c. PLL reprogramming is not glitchless, so the + * caller should switch any downstream logic to a different clock + * source or clock-gate it before presenting these values to the PLL + * configuration signals. * * The caller must pass this function a pre-initialized struct - * analogbits_wrpll_cfg record: either initialized to zero (with the + * wrpll_cfg record: either initialized to zero (with the * exception of the .name and .flags fields) or read from the PLL. * * Context: Any context. Caller must protect the memory pointed to by @c @@ -236,41 +218,26 @@ static int __wrpll_update_parent_rate(struct analogbits_wrpll_cfg *c, * * Return: 0 upon success; anything else upon failure. */ -int analogbits_wrpll_configure_for_rate(struct analogbits_wrpll_cfg *c, - u32 target_rate, - unsigned long parent_rate) +int wrpll_configure_for_rate(struct wrpll_cfg *c, u32 target_rate, + unsigned long parent_rate) { unsigned long ratio; u64 target_vco_rate, delta, best_delta, f_pre_div, vco, vco_pre; - u32 best_f, f, post_divr_freq, fbcfg; + u32 best_f, f, post_divr_freq; u8 fbdiv, divq, best_r, r; - - if (!c) - return -1; + int range;
if (c->flags == 0) { WARN(1, "%s called with uninitialized PLL config", __func__); - return -1; - } - - fbcfg = WRPLL_FLAGS_INT_FEEDBACK_MASK | WRPLL_FLAGS_EXT_FEEDBACK_MASK; - if ((c->flags & fbcfg) == fbcfg) { - WARN(1, "%s called with invalid PLL config", __func__); - return -1; - } - - if (c->flags == WRPLL_FLAGS_EXT_FEEDBACK_MASK) { - WARN(1, "%s: external feedback mode not currently supported", - __func__); - return -1; + return -EINVAL; }
/* Initialize rounding data if it hasn't been initialized already */ - if (parent_rate != c->_parent_rate) { + if (parent_rate != c->parent_rate) { if (__wrpll_update_parent_rate(c, parent_rate)) { pr_err("%s: PLL input rate is out of range\n", __func__); - return -1; + return -ERANGE; } }
@@ -281,11 +248,12 @@ int analogbits_wrpll_configure_for_rate(struct analogbits_wrpll_cfg *c, c->flags |= WRPLL_FLAGS_BYPASS_MASK; return 0; } + c->flags &= ~WRPLL_FLAGS_BYPASS_MASK;
/* Calculate the Q shift and target VCO rate */ divq = __wrpll_calc_divq(target_rate, &target_vco_rate); - if (divq == 0) + if (!divq) return -1; c->divq = divq;
@@ -301,8 +269,7 @@ int analogbits_wrpll_configure_for_rate(struct analogbits_wrpll_cfg *c, * Consider all values for R which land within * [MIN_POST_DIVR_FREQ, MAX_POST_DIVR_FREQ]; prefer smaller R */ - for (r = c->_init_r; r <= c->_max_r; ++r) { - /* What is the best F we can pick in this case? */ + for (r = c->init_r; r <= c->max_r; ++r) { f_pre_div = ratio * r; f = (f_pre_div + (1 << ROUND_SHIFT)) >> ROUND_SHIFT; f >>= (fbdiv - 1); @@ -334,46 +301,54 @@ int analogbits_wrpll_configure_for_rate(struct analogbits_wrpll_cfg *c, post_divr_freq = div_u64(parent_rate, best_r);
/* Pick the best PLL jitter filter */ - c->range = __wrpll_calc_filter_range(post_divr_freq); + range = __wrpll_calc_filter_range(post_divr_freq); + if (range < 0) + return range; + c->range = range;
return 0; }
/** - * analogbits_wrpll_calc_output_rate() - calculate the PLL's target output rate - * @c: ptr to a struct analogbits_wrpll_cfg record to read from + * wrpll_calc_output_rate() - calculate the PLL's target output rate + * @c: ptr to a struct wrpll_cfg record to read from * @parent_rate: PLL refclk rate * * Given a pointer to the PLL's current input configuration @c and the * PLL's input reference clock rate @parent_rate (before the R * pre-divider), calculate the PLL's output clock rate (after the Q - * post-divider) + * post-divider). * * Context: Any context. Caller must protect the memory pointed to by @c * from simultaneous modification. * - * Return: the PLL's output clock rate, in Hz. + * Return: the PLL's output clock rate, in Hz. The return value from + * this function is intended to be convenient to pass directly + * to the Linux clock framework; thus there is no explicit + * error return value. */ -unsigned long analogbits_wrpll_calc_output_rate(struct analogbits_wrpll_cfg *c, - unsigned long parent_rate) +unsigned long wrpll_calc_output_rate(const struct wrpll_cfg *c, + unsigned long parent_rate) { u8 fbdiv; u64 n;
- WARN(c->flags & WRPLL_FLAGS_EXT_FEEDBACK_MASK, - "external feedback mode not yet supported"); + if (c->flags & WRPLL_FLAGS_EXT_FEEDBACK_MASK) { + WARN(1, "external feedback mode not yet supported"); + return ULONG_MAX; + }
fbdiv = __wrpll_calc_fbdiv(c); n = parent_rate * fbdiv * (c->divf + 1); - n = div_u64(n, (c->divr + 1)); + n = div_u64(n, c->divr + 1); n >>= c->divq;
return n; }
/** - * analogbits_wrpll_calc_max_lock_us() - return the time for the PLL to lock - * @c: ptr to a struct analogbits_wrpll_cfg record to read from + * wrpll_calc_max_lock_us() - return the time for the PLL to lock + * @c: ptr to a struct wrpll_cfg record to read from * * Return the minimum amount of time (in microseconds) that the caller * must wait after reprogramming the PLL to ensure that it is locked @@ -383,7 +358,7 @@ unsigned long analogbits_wrpll_calc_output_rate(struct analogbits_wrpll_cfg *c, * Return: the minimum amount of time the caller must wait for the PLL * to lock (in microseconds) */ -unsigned int analogbits_wrpll_calc_max_lock_us(struct analogbits_wrpll_cfg *c) +unsigned int wrpll_calc_max_lock_us(const struct wrpll_cfg *c) { return MAX_LOCK_US; } diff --git a/drivers/clk/sifive/fu540-prci.c b/drivers/clk/sifive/fu540-prci.c index 56084db2e6..cdbf35e871 100644 --- a/drivers/clk/sifive/fu540-prci.c +++ b/drivers/clk/sifive/fu540-prci.c @@ -174,7 +174,7 @@ struct __prci_data { * bypass mux is not glitchless. */ struct __prci_wrpll_data { - struct analogbits_wrpll_cfg c; + struct wrpll_cfg c; void (*bypass)(struct __prci_data *pd); void (*no_bypass)(struct __prci_data *pd); u8 cfg0_offs; @@ -244,7 +244,7 @@ static void __prci_writel(u32 v, u32 offs, struct __prci_data *pd)
/** * __prci_wrpll_unpack() - unpack WRPLL configuration registers into parameters - * @c: ptr to a struct analogbits_wrpll_cfg record to write config into + * @c: ptr to a struct wrpll_cfg record to write config into * @r: value read from the PRCI PLL configuration register * * Given a value @r read from an FU540 PRCI PLL configuration register, @@ -256,7 +256,7 @@ static void __prci_writel(u32 v, u32 offs, struct __prci_data *pd) * * Context: Any context. */ -static void __prci_wrpll_unpack(struct analogbits_wrpll_cfg *c, u32 r) +static void __prci_wrpll_unpack(struct wrpll_cfg *c, u32 r) { u32 v;
@@ -287,7 +287,7 @@ static void __prci_wrpll_unpack(struct analogbits_wrpll_cfg *c, u32 r)
/** * __prci_wrpll_pack() - pack PLL configuration parameters into a register value - * @c: pointer to a struct analogbits_wrpll_cfg record containing the PLL's cfg + * @c: pointer to a struct wrpll_cfg record containing the PLL's cfg * * Using a set of WRPLL configuration values pointed to by @c, * assemble a PRCI PLL configuration register value, and return it to @@ -300,7 +300,7 @@ static void __prci_wrpll_unpack(struct analogbits_wrpll_cfg *c, u32 r) * Returns: a value suitable for writing into a PRCI PLL configuration * register */ -static u32 __prci_wrpll_pack(struct analogbits_wrpll_cfg *c) +static u32 __prci_wrpll_pack(struct wrpll_cfg *c) { u32 r = 0;
@@ -348,11 +348,11 @@ static void __prci_wrpll_read_cfg(struct __prci_data *pd, */ static void __prci_wrpll_write_cfg(struct __prci_data *pd, struct __prci_wrpll_data *pwd, - struct analogbits_wrpll_cfg *c) + struct wrpll_cfg *c) { __prci_writel(__prci_wrpll_pack(c), pwd->cfg0_offs, pd);
- memcpy(&pwd->c, c, sizeof(struct analogbits_wrpll_cfg)); + memcpy(&pwd->c, c, sizeof(struct wrpll_cfg)); }
/* Core clock mux control */ @@ -403,7 +403,7 @@ static unsigned long sifive_fu540_prci_wrpll_recalc_rate( { struct __prci_wrpll_data *pwd = pc->pwd;
- return analogbits_wrpll_calc_output_rate(&pwd->c, parent_rate); + return wrpll_calc_output_rate(&pwd->c, parent_rate); }
static unsigned long sifive_fu540_prci_wrpll_round_rate( @@ -412,13 +412,13 @@ static unsigned long sifive_fu540_prci_wrpll_round_rate( unsigned long *parent_rate) { struct __prci_wrpll_data *pwd = pc->pwd; - struct analogbits_wrpll_cfg c; + struct wrpll_cfg c;
memcpy(&c, &pwd->c, sizeof(c));
- analogbits_wrpll_configure_for_rate(&c, rate, *parent_rate); + wrpll_configure_for_rate(&c, rate, *parent_rate);
- return analogbits_wrpll_calc_output_rate(&c, *parent_rate); + return wrpll_calc_output_rate(&c, *parent_rate); }
static int sifive_fu540_prci_wrpll_set_rate(struct __prci_clock *pc, @@ -429,7 +429,7 @@ static int sifive_fu540_prci_wrpll_set_rate(struct __prci_clock *pc, struct __prci_data *pd = pc->pd; int r;
- r = analogbits_wrpll_configure_for_rate(&pwd->c, rate, parent_rate); + r = wrpll_configure_for_rate(&pwd->c, rate, parent_rate); if (r) return -ERANGE;
@@ -438,7 +438,7 @@ static int sifive_fu540_prci_wrpll_set_rate(struct __prci_clock *pc,
__prci_wrpll_write_cfg(pd, pwd, &pwd->c);
- udelay(analogbits_wrpll_calc_max_lock_us(&pwd->c)); + udelay(wrpll_calc_max_lock_us(&pwd->c));
if (pwd->no_bypass) pwd->no_bypass(pd); diff --git a/include/linux/clk/analogbits-wrpll-cln28hpc.h b/include/linux/clk/analogbits-wrpll-cln28hpc.h index 4432e24749..03279097e1 100644 --- a/include/linux/clk/analogbits-wrpll-cln28hpc.h +++ b/include/linux/clk/analogbits-wrpll-cln28hpc.h @@ -1,19 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* - * Copyright (c) 2019 Western Digital Corporation or its affiliates. - * - * Copyright (C) 2018 SiFive, Inc. + * Copyright (C) 2018-2019 SiFive, Inc. * Wesley Terpstra * Paul Walmsley - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. */
#ifndef __LINUX_CLK_ANALOGBITS_WRPLL_CLN28HPC_H @@ -25,7 +14,7 @@ #define DIVQ_VALUES 6
/* - * Bit definitions for struct analogbits_wrpll_cfg.flags + * Bit definitions for struct wrpll_cfg.flags * * WRPLL_FLAGS_BYPASS_FLAG: if set, the PLL is either in bypass, or should be * programmed to enter bypass @@ -34,10 +23,6 @@ * feedback mode * WRPLL_FLAGS_EXT_FEEDBACK_FLAG: if set, the PLL is configured for external * feedback mode (not yet supported by this driver) - * - * The flags WRPLL_FLAGS_INT_FEEDBACK_FLAG and WRPLL_FLAGS_EXT_FEEDBACK_FLAG are - * mutually exclusive. If both bits are set, or both are zero, the struct - * analogbits_wrpll_cfg record is uninitialized or corrupt. */ #define WRPLL_FLAGS_BYPASS_SHIFT 0 #define WRPLL_FLAGS_BYPASS_MASK BIT(WRPLL_FLAGS_BYPASS_SHIFT) @@ -49,53 +34,46 @@ #define WRPLL_FLAGS_EXT_FEEDBACK_MASK BIT(WRPLL_FLAGS_EXT_FEEDBACK_SHIFT)
/** - * struct analogbits_wrpll_cfg - WRPLL configuration values - * @divr: reference divider value (6 bits), as presented to the PLL signals. - * @divf: feedback divider value (9 bits), as presented to the PLL signals. - * @divq: output divider value (3 bits), as presented to the PLL signals. - * @flags: PLL configuration flags. See above for more information. - * @range: PLL loop filter range. See below for more information. - * @_output_rate_cache: cached output rates, swept across DIVQ. - * @_parent_rate: PLL refclk rate for which values are valid - * @_max_r: maximum possible R divider value, given @parent_rate - * @_init_r: initial R divider value to start the search from + * struct wrpll_cfg - WRPLL configuration values + * @divr: reference divider value (6 bits), as presented to the PLL signals + * @divf: feedback divider value (9 bits), as presented to the PLL signals + * @divq: output divider value (3 bits), as presented to the PLL signals + * @flags: PLL configuration flags. See above for more information + * @range: PLL loop filter range. See below for more information + * @output_rate_cache: cached output rates, swept across DIVQ + * @parent_rate: PLL refclk rate for which values are valid + * @max_r: maximum possible R divider value, given @parent_rate + * @init_r: initial R divider value to start the search from * * @divr, @divq, @divq, @range represent what the PLL expects to see * on its input signals. Thus @divr and @divf are the actual divisors * minus one. @divq is a power-of-two divider; for example, 1 = * divide-by-2 and 6 = divide-by-64. 0 is an invalid @divq value. * - * When initially passing a struct analogbits_wrpll_cfg record, the + * When initially passing a struct wrpll_cfg record, the * record should be zero-initialized with the exception of the @flags * field. The only flag bits that need to be set are either * WRPLL_FLAGS_INT_FEEDBACK or WRPLL_FLAGS_EXT_FEEDBACK. - * - * Field names beginning with an underscore should be considered - * private to the wrpll-cln28hpc.c code. */ -struct analogbits_wrpll_cfg { +struct wrpll_cfg { u8 divr; u8 divq; u8 range; u8 flags; u16 divf; - u32 _output_rate_cache[DIVQ_VALUES]; - unsigned long _parent_rate; - u8 _max_r; - u8 _init_r; +/* private: */ + u32 output_rate_cache[DIVQ_VALUES]; + unsigned long parent_rate; + u8 max_r; + u8 init_r; };
-/* - * Function prototypes - */ - -int analogbits_wrpll_configure_for_rate(struct analogbits_wrpll_cfg *c, - u32 target_rate, - unsigned long parent_rate); +int wrpll_configure_for_rate(struct wrpll_cfg *c, u32 target_rate, + unsigned long parent_rate);
-unsigned int analogbits_wrpll_calc_max_lock_us(struct analogbits_wrpll_cfg *c); +unsigned int wrpll_calc_max_lock_us(const struct wrpll_cfg *c);
-unsigned long analogbits_wrpll_calc_output_rate(struct analogbits_wrpll_cfg *c, - unsigned long parent_rate); +unsigned long wrpll_calc_output_rate(const struct wrpll_cfg *c, + unsigned long parent_rate);
#endif /* __LINUX_CLK_ANALOGBITS_WRPLL_CLN28HPC_H */
The location and license header of DT bindings header for SiFive clock driver has changed in upstream Linux hence this patch.
Signed-off-by: Anup Patel anup.patel@wdc.com Reviewed-by: Bin Meng bmeng.cn@gmail.com --- drivers/clk/sifive/fu540-prci.c | 2 +- include/dt-bindings/clk/sifive-fu540-prci.h | 29 ------------------- include/dt-bindings/clock/sifive-fu540-prci.h | 18 ++++++++++++ 3 files changed, 19 insertions(+), 30 deletions(-) delete mode 100644 include/dt-bindings/clk/sifive-fu540-prci.h create mode 100644 include/dt-bindings/clock/sifive-fu540-prci.h
diff --git a/drivers/clk/sifive/fu540-prci.c b/drivers/clk/sifive/fu540-prci.c index cdbf35e871..ceb318e062 100644 --- a/drivers/clk/sifive/fu540-prci.c +++ b/drivers/clk/sifive/fu540-prci.c @@ -38,7 +38,7 @@
#include <linux/math64.h> #include <linux/clk/analogbits-wrpll-cln28hpc.h> -#include <dt-bindings/clk/sifive-fu540-prci.h> +#include <dt-bindings/clock/sifive-fu540-prci.h>
/* * EXPECTED_CLK_PARENT_COUNT: how many parent clocks this driver expects: diff --git a/include/dt-bindings/clk/sifive-fu540-prci.h b/include/dt-bindings/clk/sifive-fu540-prci.h deleted file mode 100644 index 531523ea62..0000000000 --- a/include/dt-bindings/clk/sifive-fu540-prci.h +++ /dev/null @@ -1,29 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (c) 2019 Western Digital Corporation or its affiliates. - * - * Copyright (C) 2018 SiFive, Inc. - * Wesley Terpstra - * Paul Walmsley - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#ifndef __LINUX_CLK_SIFIVE_FU540_PRCI_H -#define __LINUX_CLK_SIFIVE_FU540_PRCI_H - -/* Clock indexes for use by Device Tree data */ - -#define PRCI_CLK_COREPLL 0 -#define PRCI_CLK_DDRPLL 1 -#define PRCI_CLK_GEMGXLPLL 2 -#define PRCI_CLK_TLCLK 3 - -#endif diff --git a/include/dt-bindings/clock/sifive-fu540-prci.h b/include/dt-bindings/clock/sifive-fu540-prci.h new file mode 100644 index 0000000000..6a0b70a37d --- /dev/null +++ b/include/dt-bindings/clock/sifive-fu540-prci.h @@ -0,0 +1,18 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2018-2019 SiFive, Inc. + * Wesley Terpstra + * Paul Walmsley + */ + +#ifndef __DT_BINDINGS_CLOCK_SIFIVE_FU540_PRCI_H +#define __DT_BINDINGS_CLOCK_SIFIVE_FU540_PRCI_H + +/* Clock indexes for use by Device Tree data and the PRCI driver */ + +#define PRCI_CLK_COREPLL 0 +#define PRCI_CLK_DDRPLL 1 +#define PRCI_CLK_GEMGXLPLL 2 +#define PRCI_CLK_TLCLK 3 + +#endif
The DT bindings of SiFive clock driver in upstream Linux has changes. As-per latest DT bindings, the clock driver takes two parent clocks and compatible string has also changed.
This patch sync-up SiFive clock driver implementation as-per upstream Linux so that we now use latest DT bindings.
Signed-off-by: Anup Patel anup.patel@wdc.com Reviewed-by: Bin Meng bmeng.cn@gmail.com --- drivers/clk/sifive/fu540-prci.c | 96 ++++++++++++++++++++------------- 1 file changed, 60 insertions(+), 36 deletions(-)
diff --git a/drivers/clk/sifive/fu540-prci.c b/drivers/clk/sifive/fu540-prci.c index ceb318e062..ce0769f2d1 100644 --- a/drivers/clk/sifive/fu540-prci.c +++ b/drivers/clk/sifive/fu540-prci.c @@ -158,30 +158,32 @@ * PRCI per-device instance data */ struct __prci_data { - void *base; - struct clk parent; + void *va; + struct clk parent_hfclk; + struct clk parent_rtcclk; };
/** * struct __prci_wrpll_data - WRPLL configuration and integration data * @c: WRPLL current configuration record - * @bypass: fn ptr to code to bypass the WRPLL (if applicable; else NULL) - * @no_bypass: fn ptr to code to not bypass the WRPLL (if applicable; else NULL) + * @enable_bypass: fn ptr to code to bypass the WRPLL (if applicable; else NULL) + * @disable_bypass: fn ptr to code to not bypass the WRPLL (or NULL) * @cfg0_offs: WRPLL CFG0 register offset (in bytes) from the PRCI base address * - * @bypass and @no_bypass are used for WRPLL instances that contain a separate - * external glitchless clock mux downstream from the PLL. The WRPLL internal - * bypass mux is not glitchless. + * @enable_bypass and @disable_bypass are used for WRPLL instances + * that contain a separate external glitchless clock mux downstream + * from the PLL. The WRPLL internal bypass mux is not glitchless. */ struct __prci_wrpll_data { struct wrpll_cfg c; - void (*bypass)(struct __prci_data *pd); - void (*no_bypass)(struct __prci_data *pd); + void (*enable_bypass)(struct __prci_data *pd); + void (*disable_bypass)(struct __prci_data *pd); u8 cfg0_offs; };
struct __prci_clock;
+/* struct __prci_clock_ops - clock operations */ struct __prci_clock_ops { int (*set_rate)(struct __prci_clock *pc, unsigned long rate, @@ -197,8 +199,7 @@ struct __prci_clock_ops { * struct __prci_clock - describes a clock device managed by PRCI * @name: user-readable clock name string - should match the manual * @parent_name: parent name for this clock - * @ops: struct clk_ops for the Linux clock framework to use for control - * @hw: Linux-private clock data + * @ops: struct __prci_clock_ops for control * @pwd: WRPLL-specific data, associated with this clock (if not NULL) * @pd: PRCI-specific data associated with this clock (if not NULL) * @@ -232,12 +233,12 @@ struct __prci_clock { */ static u32 __prci_readl(struct __prci_data *pd, u32 offs) { - return readl(pd->base + offs); + return readl(pd->va + offs); }
static void __prci_writel(u32 v, u32 offs, struct __prci_data *pd) { - return writel(v, pd->base + offs); + writel(v, pd->va + offs); }
/* WRPLL-related private functions */ @@ -279,10 +280,8 @@ static void __prci_wrpll_unpack(struct wrpll_cfg *c, u32 r) c->flags &= (WRPLL_FLAGS_INT_FEEDBACK_MASK | WRPLL_FLAGS_EXT_FEEDBACK_MASK);
- if (r & PRCI_COREPLLCFG0_FSE_MASK) - c->flags |= WRPLL_FLAGS_INT_FEEDBACK_MASK; - else - c->flags |= WRPLL_FLAGS_EXT_FEEDBACK_MASK; + /* external feedback mode not supported */ + c->flags |= WRPLL_FLAGS_INT_FEEDBACK_MASK; }
/** @@ -300,7 +299,7 @@ static void __prci_wrpll_unpack(struct wrpll_cfg *c, u32 r) * Returns: a value suitable for writing into a PRCI PLL configuration * register */ -static u32 __prci_wrpll_pack(struct wrpll_cfg *c) +static u32 __prci_wrpll_pack(const struct wrpll_cfg *c) { u32 r = 0;
@@ -308,8 +307,9 @@ static u32 __prci_wrpll_pack(struct wrpll_cfg *c) r |= c->divf << PRCI_COREPLLCFG0_DIVF_SHIFT; r |= c->divq << PRCI_COREPLLCFG0_DIVQ_SHIFT; r |= c->range << PRCI_COREPLLCFG0_RANGE_SHIFT; - if (c->flags & WRPLL_FLAGS_INT_FEEDBACK_MASK) - r |= PRCI_COREPLLCFG0_FSE_MASK; + + /* external feedback mode not supported */ + r |= PRCI_COREPLLCFG0_FSE_MASK;
return r; } @@ -352,7 +352,7 @@ static void __prci_wrpll_write_cfg(struct __prci_data *pd, { __prci_writel(__prci_wrpll_pack(c), pwd->cfg0_offs, pd);
- memcpy(&pwd->c, c, sizeof(struct wrpll_cfg)); + memcpy(&pwd->c, c, sizeof(*c)); }
/* Core clock mux control */ @@ -431,17 +431,17 @@ static int sifive_fu540_prci_wrpll_set_rate(struct __prci_clock *pc,
r = wrpll_configure_for_rate(&pwd->c, rate, parent_rate); if (r) - return -ERANGE; + return r;
- if (pwd->bypass) - pwd->bypass(pd); + if (pwd->enable_bypass) + pwd->enable_bypass(pd);
- if (pwd->no_bypass) - pwd->no_bypass(pd); + if (pwd->disable_bypass) + pwd->disable_bypass(pd);
return 0; } @@ -483,8 +483,8 @@ static const struct __prci_clock_ops sifive_fu540_prci_tlclksel_clk_ops = {
static struct __prci_wrpll_data __prci_corepll_data = { .cfg0_offs = PRCI_COREPLLCFG0_OFFSET, - .bypass = __prci_coreclksel_use_hfclk, - .no_bypass = __prci_coreclksel_use_corepll, + .enable_bypass = __prci_coreclksel_use_hfclk, + .disable_bypass = __prci_coreclksel_use_corepll, };
static struct __prci_wrpll_data __prci_ddrpll_data = { @@ -525,6 +525,27 @@ static struct __prci_clock __prci_init_clocks[] = { }, };
+static ulong sifive_fu540_prci_parent_rate(struct __prci_clock *pc) +{ + ulong parent_rate; + struct __prci_clock *p; + + if (strcmp(pc->parent_name, "corepll") == 0) { + p = &__prci_init_clocks[PRCI_CLK_COREPLL]; + if (!p->pd || !p->ops->recalc_rate) + return -ENXIO; + + return p->ops->recalc_rate(p, sifive_fu540_prci_parent_rate(p)); + } + + if (strcmp(pc->parent_name, "rtcclk") == 0) + parent_rate = clk_get_rate(&pc->pd->parent_rtcclk); + else + parent_rate = clk_get_rate(&pc->pd->parent_hfclk); + + return parent_rate; +} + static ulong sifive_fu540_prci_get_rate(struct clk *clk) { struct __prci_clock *pc; @@ -536,7 +557,7 @@ static ulong sifive_fu540_prci_get_rate(struct clk *clk) if (!pc->pd || !pc->ops->recalc_rate) return -ENXIO;
- return pc->ops->recalc_rate(pc, clk_get_rate(&pc->pd->parent)); + return pc->ops->recalc_rate(pc, sifive_fu540_prci_parent_rate(pc)); }
static ulong sifive_fu540_prci_set_rate(struct clk *clk, ulong rate) @@ -551,7 +572,7 @@ static ulong sifive_fu540_prci_set_rate(struct clk *clk, ulong rate) if (!pc->pd || !pc->ops->set_rate) return -ENXIO;
- err = pc->ops->set_rate(pc, rate, clk_get_rate(&pc->pd->parent)); + err = pc->ops->set_rate(pc, rate, sifive_fu540_prci_parent_rate(pc)); if (err) return err;
@@ -564,11 +585,15 @@ static int sifive_fu540_prci_probe(struct udevice *dev) struct __prci_clock *pc; struct __prci_data *pd = dev_get_priv(dev);
- pd->base = (void *)dev_read_addr(dev); - if (IS_ERR(pd->base)) - return PTR_ERR(pd->base); + pd->va = (void *)dev_read_addr(dev); + if (IS_ERR(pd->va)) + return PTR_ERR(pd->va); + + err = clk_get_by_index(dev, 0, &pd->parent_hfclk); + if (err) + return err;
- err = clk_get_by_index(dev, 0, &pd->parent); + err = clk_get_by_index(dev, 1, &pd->parent_rtcclk); if (err) return err;
@@ -588,8 +613,7 @@ static struct clk_ops sifive_fu540_prci_ops = { };
static const struct udevice_id sifive_fu540_prci_ids[] = { - { .compatible = "sifive,fu540-c000-prci0" }, - { .compatible = "sifive,aloeprci0" }, + { .compatible = "sifive,fu540-c000-prci" }, { } };
The GEMGXL clock driver is now directly part of Cadence MACB ethernet driver in upstream Linux kernel. There is no separate GEMGXL clock driver in upstream Linux kernel hence we drop GEMGXL clock driver from U-Boot as well.
Signed-off-by: Anup Patel anup.patel@wdc.com Reviewed-by: Bin Meng bmeng.cn@gmail.com --- board/sifive/fu540/Kconfig | 1 - drivers/clk/sifive/Kconfig | 7 ---- drivers/clk/sifive/Makefile | 2 -- drivers/clk/sifive/gemgxl-mgmt.c | 60 -------------------------------- 4 files changed, 70 deletions(-) delete mode 100644 drivers/clk/sifive/gemgxl-mgmt.c
diff --git a/board/sifive/fu540/Kconfig b/board/sifive/fu540/Kconfig index 8eb5e304ab..f46437901d 100644 --- a/board/sifive/fu540/Kconfig +++ b/board/sifive/fu540/Kconfig @@ -28,7 +28,6 @@ config BOARD_SPECIFIC_OPTIONS # dummy imply CMD_PING imply CLK_SIFIVE imply CLK_SIFIVE_FU540_PRCI - imply CLK_SIFIVE_GEMGXL_MGMT imply DOS_PARTITION imply EFI_PARTITION imply IP_DYN diff --git a/drivers/clk/sifive/Kconfig b/drivers/clk/sifive/Kconfig index d90be1943f..c4d0a1f9b1 100644 --- a/drivers/clk/sifive/Kconfig +++ b/drivers/clk/sifive/Kconfig @@ -14,10 +14,3 @@ config CLK_SIFIVE_FU540_PRCI Supports the Power Reset Clock interface (PRCI) IP block found in FU540 SoCs. If this kernel is meant to run on a SiFive FU540 SoC, enable this driver. - -config CLK_SIFIVE_GEMGXL_MGMT - bool "GEMGXL management for SiFive FU540 SoCs" - depends on CLK_SIFIVE - help - Supports the GEMGXL management IP block found in FU540 SoCs to - control GEM TX clock operation mode for 10/100/1000 Mbps. diff --git a/drivers/clk/sifive/Makefile b/drivers/clk/sifive/Makefile index 0813360ca7..b224279afb 100644 --- a/drivers/clk/sifive/Makefile +++ b/drivers/clk/sifive/Makefile @@ -1,5 +1,3 @@ # SPDX-License-Identifier: GPL-2.0+
obj-$(CONFIG_CLK_SIFIVE_FU540_PRCI) += fu540-prci.o - -obj-$(CONFIG_CLK_SIFIVE_GEMGXL_MGMT) += gemgxl-mgmt.o diff --git a/drivers/clk/sifive/gemgxl-mgmt.c b/drivers/clk/sifive/gemgxl-mgmt.c deleted file mode 100644 index eb37416b5e..0000000000 --- a/drivers/clk/sifive/gemgxl-mgmt.c +++ /dev/null @@ -1,60 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2019, Bin Meng bmeng.cn@gmail.com - */ - -#include <common.h> -#include <clk-uclass.h> -#include <dm.h> -#include <asm/io.h> - -struct gemgxl_mgmt_regs { - __u32 tx_clk_sel; -}; - -struct gemgxl_mgmt_platdata { - struct gemgxl_mgmt_regs *regs; -}; - -static int gemgxl_mgmt_ofdata_to_platdata(struct udevice *dev) -{ - struct gemgxl_mgmt_platdata *plat = dev_get_platdata(dev); - - plat->regs = (struct gemgxl_mgmt_regs *)dev_read_addr(dev); - - return 0; -} - -static ulong gemgxl_mgmt_set_rate(struct clk *clk, ulong rate) -{ - struct gemgxl_mgmt_platdata *plat = dev_get_platdata(clk->dev); - - /* - * GEMGXL TX clock operation mode: - * - * 0 = GMII mode. Use 125 MHz gemgxlclk from PRCI in TX logic - * and output clock on GMII output signal GTX_CLK - * 1 = MII mode. Use MII input signal TX_CLK in TX logic - */ - writel(rate != 125000000, &plat->regs->tx_clk_sel); - - return 0; -} - -const struct clk_ops gemgxl_mgmt_ops = { - .set_rate = gemgxl_mgmt_set_rate, -}; - -static const struct udevice_id gemgxl_mgmt_match[] = { - { .compatible = "sifive,cadencegemgxlmgmt0", }, - { /* sentinel */ } -}; - -U_BOOT_DRIVER(sifive_gemgxl_mgmt) = { - .name = "sifive-gemgxl-mgmt", - .id = UCLASS_CLK, - .of_match = gemgxl_mgmt_match, - .ofdata_to_platdata = gemgxl_mgmt_ofdata_to_platdata, - .platdata_auto_alloc_size = sizeof(struct gemgxl_mgmt_platdata), - .ops = &gemgxl_mgmt_ops, -};
The SiFive MACB ethernet has a custom TX_CLK_SEL register to select different TX clock for 1000mbps vs 10/100mbps.
This patch adds SiFive MACB compatible string and extends the MACB ethernet driver to change TX clock using TX_CLK_SEL register for SiFive MACB.
Signed-off-by: Anup Patel anup.patel@wdc.com Reviewed-by: Bin Meng bmeng.cn@gmail.com --- drivers/net/macb.c | 70 +++++++++++++++++++++++++++++++++++----------- 1 file changed, 53 insertions(+), 17 deletions(-)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index c072f99d8f..322302762a 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -83,7 +83,8 @@ struct macb_dma_desc {
struct macb_device { void *regs; - unsigned int dma_burst_length; + + const struct macb_config*config;
unsigned int rx_tail; unsigned int tx_head; @@ -123,6 +124,8 @@ struct macb_device {
struct macb_config { unsigned int dma_burst_length; + + int (*clk_init)(struct udevice *dev, ulong rate); };
#ifndef CONFIG_DM_ETH @@ -483,21 +486,38 @@ static int macb_phy_find(struct macb_device *macb, const char *name) * when operation failed. */ #ifdef CONFIG_DM_ETH +static int macb_sifive_clk_init(struct udevice *dev, ulong rate) +{ + fdt_addr_t addr; + void *gemgxl_regs; + + addr = dev_read_addr_index(dev, 1); + if (addr == FDT_ADDR_T_NONE) + return -ENODEV; + + gemgxl_regs = (void __iomem *)addr; + if (!gemgxl_regs) + return -ENODEV; + + /* + * SiFive GEMGXL TX clock operation mode: + * + * 0 = GMII mode. Use 125 MHz gemgxlclk from PRCI in TX logic + * and output clock on GMII output signal GTX_CLK + * 1 = MII mode. Use MII input signal TX_CLK in TX logic + */ + writel(rate != 125000000, gemgxl_regs); + return 0; +} + int __weak macb_linkspd_cb(struct udevice *dev, unsigned int speed) { #ifdef CONFIG_CLK + struct macb_device *macb = dev_get_priv(dev); struct clk tx_clk; ulong rate; int ret;
- /* - * "tx_clk" is an optional clock source for MACB. - * Ignore if it does not exist in DT. - */ - ret = clk_get_by_name(dev, "tx_clk", &tx_clk); - if (ret) - return 0; - switch (speed) { case _10BASET: rate = 2500000; /* 2.5 MHz */ @@ -513,6 +533,17 @@ int __weak macb_linkspd_cb(struct udevice *dev, unsigned int speed) return 0; }
+ if (macb->config->clk_init) + return macb->config->clk_init(dev, rate); + + /* + * "tx_clk" is an optional clock source for MACB. + * Ignore if it does not exist in DT. + */ + ret = clk_get_by_name(dev, "tx_clk", &tx_clk); + if (ret) + return 0; + if (tx_clk.dev) { ret = clk_set_rate(&tx_clk, rate); if (ret) @@ -705,8 +736,9 @@ static void gmac_configure_dma(struct macb_device *macb) dmacfg = gem_readl(macb, DMACFG) & ~GEM_BF(RXBS, -1L); dmacfg |= GEM_BF(RXBS, buffer_size);
- if (macb->dma_burst_length) - dmacfg = GEM_BFINS(FBLDO, macb->dma_burst_length, dmacfg); + if (macb->config->dma_burst_length) + dmacfg = GEM_BFINS(FBLDO, + macb->config->dma_burst_length, dmacfg);
dmacfg |= GEM_BIT(TXPBMS) | GEM_BF(RXBMS, -1L); dmacfg &= ~GEM_BIT(ENDIA_PKT); @@ -1173,11 +1205,10 @@ static const struct macb_config default_gem_config = {
static int macb_eth_probe(struct udevice *dev) { - const struct macb_config *macb_config; struct eth_pdata *pdata = dev_get_platdata(dev); struct macb_device *macb = dev_get_priv(dev); const char *phy_mode; - __maybe_unused int ret; + int ret;
phy_mode = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), "phy-mode", NULL); @@ -1190,11 +1221,10 @@ static int macb_eth_probe(struct udevice *dev)
macb->regs = (void *)pdata->iobase;
- macb_config = (struct macb_config *)dev_get_driver_data(dev); - if (!macb_config) - macb_config = &default_gem_config; + macb->config = (struct macb_config *)dev_get_driver_data(dev); + if (!macb->config) + macb->config = &default_gem_config;
- macb->dma_burst_length = macb_config->dma_burst_length; #ifdef CONFIG_CLK ret = macb_enable_clk(dev); if (ret) @@ -1259,6 +1289,11 @@ static const struct macb_config sama5d4_config = { .dma_burst_length = 4, };
+static const struct macb_config sifive_config = { + .dma_burst_length = 16, + .clk_init = macb_sifive_clk_init, +}; + static const struct udevice_id macb_eth_ids[] = { { .compatible = "cdns,macb" }, { .compatible = "cdns,at91sam9260-macb" }, @@ -1266,6 +1301,7 @@ static const struct udevice_id macb_eth_ids[] = { { .compatible = "atmel,sama5d3-gem" }, { .compatible = "atmel,sama5d4-gem", .data = (ulong)&sama5d4_config }, { .compatible = "cdns,zynq-gem" }, + { .compatible = "sifive,fu540-macb", .data = (ulong)&sifive_config }, { } };
- when operation failed.
- fdt_addr_t addr;
- void *gemgxl_regs;
- addr = dev_read_addr_index(dev, 1);
- if (addr == FDT_ADDR_T_NONE)
return -ENODEV;
- gemgxl_regs = (void __iomem *)addr;
- if (!gemgxl_regs)
return -ENODEV;
- writel(rate != 125000000, gemgxl_regs);
- int __weak macb_linkspd_cb(struct udevice *dev, unsigned int speed) { #ifdef CONFIG_CLK
- struct macb_device *macb = dev_get_priv(dev); struct clk tx_clk; ulong rate; int ret;
- if (ret)
- if (macb->config->clk_init)
- if (ret)
- if (tx_clk.dev) { ret = clk_set_rate(&tx_clk, rate); if (ret)
int ret;
- if (!macb_config)
- macb->config = (struct macb_config *)dev_get_driver_data(dev);
- if (!macb->config)
- .dma_burst_length = 16,
- .clk_init = macb_sifive_clk_init,
- static const struct udevice_id macb_eth_ids[] = { { .compatible = "cdns,macb" }, { .compatible = "cdns,at91sam9260-macb" },
- { .compatible = "sifive,fu540-macb", .data = (ulong)&sifive_config }, { } };
Reviewed-By: Ramon Fried rfried.dev@gmail.com
const struct macb_config*config; unsigned int rx_tail; unsigned int tx_head;
fdt_addr_t addr;
void *gemgxl_regs;
return -ENODEV;
if (!gemgxl_regs)
return -ENODEV;
if (ret)
if (ret)
macb->config->dma_burst_length, dmacfg); dmacfg |= GEM_BIT(TXPBMS) | GEM_BF(RXBMS, -1L); dmacfg &= ~GEM_BIT(ENDIA_PKT);
int ret; phy_mode = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), "phy-mode", NULL);
if (!macb_config)
if (!macb->config)
#ifdef CONFIG_CLK ret = macb_enable_clk(dev); if (ret)macb->dma_burst_length = macb_config->dma_burst_length;
};{ .compatible = "sifive,fu540-macb", .data = (ulong)&sifive_config }, { }
Hi Joe,
Can you consider this patch for v2019.10 ?
Regards, Anup
This patch extends SiFive FU540 board support to setup ethaddr env variable based on board serialnum read from OTP.
Signed-off-by: Anup Patel anup.patel@wdc.com Reviewed-by: Bin Meng bmeng.cn@gmail.com --- board/sifive/fu540/fu540.c | 122 +++++++++++++++++++++++++++++++++ configs/sifive_fu540_defconfig | 1 + 2 files changed, 123 insertions(+)
diff --git a/board/sifive/fu540/fu540.c b/board/sifive/fu540/fu540.c index 5adc4a3d4a..11daf1a75a 100644 --- a/board/sifive/fu540/fu540.c +++ b/board/sifive/fu540/fu540.c @@ -8,6 +8,128 @@
#include <common.h> #include <dm.h> +#include <linux/delay.h> +#include <linux/io.h> + +#ifdef CONFIG_MISC_INIT_R + +#define FU540_OTP_BASE_ADDR 0x10070000 + +struct fu540_otp_regs { + u32 pa; /* Address input */ + u32 paio; /* Program address input */ + u32 pas; /* Program redundancy cell selection input */ + u32 pce; /* OTP Macro enable input */ + u32 pclk; /* Clock input */ + u32 pdin; /* Write data input */ + u32 pdout; /* Read data output */ + u32 pdstb; /* Deep standby mode enable input (active low) */ + u32 pprog; /* Program mode enable input */ + u32 ptc; /* Test column enable input */ + u32 ptm; /* Test mode enable input */ + u32 ptm_rep;/* Repair function test mode enable input */ + u32 ptr; /* Test row enable input */ + u32 ptrim; /* Repair function enable input */ + u32 pwe; /* Write enable input (defines program cycle) */ +} __packed; + +#define BYTES_PER_FUSE 4 +#define NUM_FUSES 0x1000 + +static int fu540_otp_read(int offset, void *buf, int size) +{ + struct fu540_otp_regs *regs = (void __iomem *)FU540_OTP_BASE_ADDR; + unsigned int i; + int fuseidx = offset / BYTES_PER_FUSE; + int fusecount = size / BYTES_PER_FUSE; + u32 fusebuf[fusecount]; + + /* check bounds */ + if (offset < 0 || size < 0) + return -EINVAL; + if (fuseidx >= NUM_FUSES) + return -EINVAL; + if ((fuseidx + fusecount) > NUM_FUSES) + return -EINVAL; + + /* init OTP */ + writel(0x01, ®s->pdstb); /* wake up from stand-by */ + writel(0x01, ®s->ptrim); /* enable repair function */ + writel(0x01, ®s->pce); /* enable input */ + + /* read all requested fuses */ + for (i = 0; i < fusecount; i++, fuseidx++) { + writel(fuseidx, ®s->pa); + + /* cycle clock to read */ + writel(0x01, ®s->pclk); + mdelay(1); + writel(0x00, ®s->pclk); + mdelay(1); + + /* read the value */ + fusebuf[i] = readl(®s->pdout); + } + + /* shut down */ + writel(0, ®s->pce); + writel(0, ®s->ptrim); + writel(0, ®s->pdstb); + + /* copy out */ + memcpy(buf, fusebuf, size); + + return 0; +} + +static u32 fu540_read_serialnum(void) +{ + int ret; + u32 serial[2] = {0}; + + for (int i = 0xfe * 4; i > 0; i -= 8) { + ret = fu540_otp_read(i, serial, sizeof(serial)); + if (ret) { + printf("%s: error reading from OTP\n", __func__); + break; + } + if (serial[0] == ~serial[1]) + return serial[0]; + } + + return 0; +} + +static void fu540_setup_macaddr(u32 serialnum) +{ + /* Default MAC address */ + unsigned char mac[6] = { 0x70, 0xb3, 0xd5, 0x92, 0xf0, 0x00 }; + + /* + * We derive our board MAC address by ORing last three bytes + * of board serial number to above default MAC address. + * + * This logic of deriving board MAC address is taken from + * SiFive FSBL and is kept unchanged. + */ + mac[5] |= (serialnum >> 0) & 0xff; + mac[4] |= (serialnum >> 8) & 0xff; + mac[3] |= (serialnum >> 16) & 0xff; + + /* Update environment variable */ + eth_env_set_enetaddr("ethaddr", mac); +} + +int misc_init_r(void) +{ + /* Set ethaddr environment variable if not set */ + if (!env_get("ethaddr")) + fu540_setup_macaddr(fu540_read_serialnum()); + + return 0; +} + +#endif
int board_init(void) { diff --git a/configs/sifive_fu540_defconfig b/configs/sifive_fu540_defconfig index f78412398e..f19203745e 100644 --- a/configs/sifive_fu540_defconfig +++ b/configs/sifive_fu540_defconfig @@ -7,4 +7,5 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y +CONFIG_MISC_INIT_R=y CONFIG_OF_PRIOR_STAGE=y
Due changes in DT bindings, we now embed DTB from Linux-5.3 (or higher) in OpenSBI FW_PAYLOAD along with payload u-boot.bin. This patch updates SiFive FU540 README to reflect the changes in build and boot steps.
Signed-off-by: Anup Patel anup.patel@wdc.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Alistair Francis Alistair.Francis@wdc.com --- doc/README.sifive-fu540 | 356 ++++++++++++++++++---------------------- 1 file changed, 164 insertions(+), 192 deletions(-)
diff --git a/doc/README.sifive-fu540 b/doc/README.sifive-fu540 index fd9f2a8e46..33e03dc861 100644 --- a/doc/README.sifive-fu540 +++ b/doc/README.sifive-fu540 @@ -13,7 +13,8 @@ The support for following drivers are already enabled: 3. Cadence MACB ethernet driver for networking support.
TODO: -1. SPI driver is still missing. So MMC card can't be used in U-Boot as of now. +1. SPI host driver is still missing. +2. SPI MMC driver does not compile and needs a re-write using U-Boot DM. 2. U-Boot expects the serial console device entry to be present under /chosen DT node. Example: chosen { @@ -33,16 +34,21 @@ Building
Flashing ======== -The current U-Boot port is supported in S-mode only and loaded from DRAM. +The current U-Boot port is supported in S-mode only and loaded directly +into DRAM.
-A prior stage (M-mode) firmware/bootloader (e.g OpenSBI or BBL) is required to -load the u-boot.bin into memory and provide runtime services. The u-boot.bin -can be given as a payload to the prior stage (M-mode) firmware/bootloader. +A prior stage (M-mode) firmware/bootloader (e.g OpenSBI) is required to +boot the u-boot.bin in S-mode and provide M-mode runtime services.
-The description of steps required to build the firmware is beyond the scope of -this document. Please refer OpenSBI or BBL documenation. +Currently, the u-boot.bin is used as a payload of the OpenSBI FW_PAYLOAD +firmware. We need to compile OpenSBI with below command: +make PLATFORM=sifive/fu540 FW_PAYLOAD_PATH=<path to u-boot.bin> FW_PAYLOAD_FDT_PATH=<path to hifive-unleashed-a00.dtb from Linux> +(Note: Prefer hifive-unleashed-a00.dtb from Linux-5.3 or higher) +(Note: Linux-5.2 is also fine but it does not have ethernet DT node) + +More detailed description of steps required to build FW_PAYLOAD firmware +is beyond the scope of this document. Please refer OpenSBI documenation. (Note: OpenSBI git repo is at https://github.com/riscv/opensbi.git) -(Note: BBL git repo is at https://github.com/riscv/riscv-pk.git)
Once the prior stage firmware/bootloader binary is generated, it should be copied to the first partition of the sdcard. @@ -55,20 +61,18 @@ Once you plugin the sdcard and power up, you should see the U-Boot prompt.
Sample boot log from HiFive Unleashed board =========================================== -U-Boot 2019.01-00019-gc7953536-dirty (Jan 22 2019 - 11:05:40 -0800) +U-Boot 2019.07-rc4-00013-g1837f893b0 (Jun 20 2019 - 11:08:48 +0530)
CPU: rv64imafdc -Model: sifive,hifive-unleashed-a00 +Model: SiFive HiFive Unleashed A00 DRAM: 8 GiB In: serial@10010000 Out: serial@10010000 Err: serial@10010000 -Net: -Warning: ethernet@10090000 (eth0) using random MAC address - b6:75:4d:48:50:94 -eth0: ethernet@10090000 +Net: eth0: ethernet@10090000 Hit any key to stop autoboot: 0 => version -U-Boot 2019.01-00019-gc7953536-dirty (Jan 22 2019 - 11:05:40 -0800) +U-Boot 2019.07-rc4-00013-g1837f893b0 (Jun 20 2019 - 11:08:48 +0530)
riscv64-linux-gcc.br_real (Buildroot 2018.11-rc2-00003-ga0787e9) 8.2.0 GNU ld (GNU Binutils) 2.31.1 @@ -79,30 +83,19 @@ Now you can configure your networking, tftp server and use tftp boot method to load uImage.
========================================================================== -=> setenv ethaddr 70:B3:D5:92:F0:C2 -=> setenv ipaddr 10.196.157.189 -=> setenv serverip 10.11.143.218 -=> setenv gatewayip 10.196.156.1 +=> setenv ipaddr 10.206.5.241 => setenv netmask 255.255.252.0 -=> bdinfo -boot_params = 0x0000000000000000 -DRAM bank = 0x0000000000000000 --> start = 0x0000000080000000 --> size = 0x0000000200000000 -relocaddr = 0x00000000fff90000 -reloc off = 0x000000007fd90000 -ethaddr = 70:B3:D5:92:F0:C2 -IP addr = 10.196.157.189 -baudrate = 115200 bps -=> tftpboot uImage +=> setenv serverip 10.206.4.143 +=> setenv gateway 10.206.4.1 +=> tftpboot ${kernel_addr_r} /sifive/fu540/uImage ethernet@10090000: PHY present at 0 ethernet@10090000: Starting autonegotiation... ethernet@10090000: Autonegotiation complete -ethernet@10090000: link up, 1000Mbps full-duplex (lpa: 0x3800) +ethernet@10090000: link up, 1000Mbps full-duplex (lpa: 0x7c00) Using ethernet@10090000 device -TFTP from server 10.11.143.218; our IP address is 10.196.157.189; sending through gateway 10.196.156.1 -Filename 'uImage'. -Load address: 0x80200000 +TFTP from server 10.206.4.143; our IP address is 10.206.5.241 +Filename '/sifive/fu540/uImage'. +Load address: 0x80600000 Loading: ################################################################# ################################################################# ################################################################# @@ -112,192 +105,171 @@ Loading: ################################################################# ################################################################# ################################################################# ################################################################# + ######################################## + 1.5 MiB/s +done +Bytes transferred = 9162364 (8bce7c hex) +=> tftpboot ${ramdisk_addr_r} /sifive/fu540/uRamdisk +ethernet@10090000: PHY present at 0 +ethernet@10090000: Starting autonegotiation... +ethernet@10090000: Autonegotiation complete +ethernet@10090000: link up, 1000Mbps full-duplex (lpa: 0x7c00) +Using ethernet@10090000 device +TFTP from server 10.206.4.143; our IP address is 10.206.5.241 +Filename '/sifive/fu540/uRamdisk'. +Load address: 0x82500000 +Loading: ################################################################# ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ################################################################# - ########################################################## - 2.5 MiB/s + ################################## + 448.2 KiB/s done -Bytes transferred = 14939132 (e3f3fc hex) -=> bootm 0x80200000 - 0x82200000 -## Booting kernel from Legacy Image at 80200000 ... +Bytes transferred = 2398272 (249840 hex) +=> setenv bootargs "root=/dev/ram rw console=ttySIF0 earlycon=sbi" +=> bootm ${kernel_addr_r} ${ramdisk_addr_r} ${fdtcontroladdr} +## Booting kernel from Legacy Image at 80600000 ... Image Name: Linux Image Type: RISC-V Linux Kernel Image (uncompressed) - Data Size: 14939068 Bytes = 14.2 MiB + Data Size: 9162300 Bytes = 8.7 MiB Load Address: 80200000 Entry Point: 80200000 Verifying Checksum ... OK -## Flattened Device Tree blob at 82200000 - Booting using the fdt blob at 0x82200000 +## Loading init Ramdisk from Legacy Image at 82500000 ... + Image Name: Linux RootFS + Image Type: RISC-V Linux RAMDisk Image (uncompressed) + Data Size: 2398208 Bytes = 2.3 MiB + Load Address: 00000000 + Entry Point: 00000000 + Verifying Checksum ... OK +## Flattened Device Tree blob at ff795730 + Booting using the fdt blob at 0xff795730 Loading Kernel Image ... OK - Using Device Tree in place at 0000000082200000, end 0000000082205c69 + Using Device Tree in place at 00000000ff795730, end 00000000ff799dac
Starting kernel ...
[ 0.000000] OF: fdt: Ignoring memory range 0x80000000 - 0x80200000 -[ 0.000000] Linux version 5.0.0-rc1-00020-g4b51f736 (atish@jedi-01) (gcc version 7.2.0 (GCC)) #262 SMP Mon Jan 21 17:39:27 PST 2019 -[ 0.000000] initrd not found or empty - disabling initrd +[ 0.000000] Linux version 5.2.0-rc1-00003-gb9543e66e700 (anup@anup-lab-machine) (gcc version 8.2.0 (Buildroot 2018.11-rc2-00003-ga0787e9)) #1 SMP Thu Jun 20 11:41:26 IST 2019 +[ 0.000000] earlycon: sbi0 at I/O port 0x0 (options '') +[ 0.000000] printk: bootconsole [sbi0] enabled +[ 0.000000] Initial ramdisk at: 0x(____ptrval____) (2398208 bytes) [ 0.000000] Zone ranges: [ 0.000000] DMA32 [mem 0x0000000080200000-0x00000000ffffffff] -[ 0.000000] Normal [mem 0x0000000100000000-0x000027ffffffffff] +[ 0.000000] Normal [mem 0x0000000100000000-0x000000027fffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080200000-0x000000027fffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080200000-0x000000027fffffff] -[ 0.000000] software IO TLB: mapped [mem 0xfbfff000-0xfffff000] (64MB) -[ 0.000000] CPU with hartid=0 has a non-okay status of "masked" -[ 0.000000] CPU with hartid=0 has a non-okay status of "masked" +[ 0.000000] software IO TLB: mapped [mem 0xfb795000-0xff795000] (64MB) +[ 0.000000] CPU with hartid=0 is not available +[ 0.000000] CPU with hartid=0 is not available [ 0.000000] elf_hwcap is 0x112d -[ 0.000000] percpu: Embedded 15 pages/cpu @(____ptrval____) s29720 r0 d31720 u61440 +[ 0.000000] percpu: Embedded 17 pages/cpu s29592 r8192 d31848 u69632 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2067975 -[ 0.000000] Kernel command line: earlyprintk +[ 0.000000] Kernel command line: root=/dev/ram rw console=ttySIF0 earlycon=sbi [ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes) [ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes) [ 0.000000] Sorting __ex_table... -[ 0.000000] Memory: 8178760K/8386560K available (3309K kernel code, 248K rwdata, 872K rodata, 9381K init, 763K bss, 207800K reserved, 0K cma-reserved) +[ 0.000000] Memory: 8182056K/8386560K available (5753K kernel code, 357K rwdata, 1804K rodata, 204K init, 808K bss, 204504K reserved, 0K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Hierarchical RCU implementation. -[ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. -[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies. +[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 0, nr_irqs: 0, preallocated irqs: 0 -[ 0.000000] plic: mapped 53 interrupts to 4 (out of 9) handlers. -[ 0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [1] +[ 0.000000] plic: mapped 53 interrupts with 4 handlers for 9 contexts. +[ 0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [2] [ 0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 3526361616960 ns -[ 0.000008] sched_clock: 64 bits at 1000kHz, resolution 1000ns, wraps every 2199023255500ns -[ 0.000221] Console: colour dummy device 80x25 -[ 0.000902] printk: console [tty0] enabled -[ 0.000963] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000) -[ 0.001034] pid_max: default: 32768 minimum: 301 -[ 0.001541] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes) -[ 0.001912] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes) -[ 0.003542] rcu: Hierarchical SRCU implementation. -[ 0.004347] smp: Bringing up secondary CPUs ... -[ 1.040259] CPU1: failed to come online -[ 2.080483] CPU2: failed to come online -[ 3.120699] CPU3: failed to come online -[ 3.120765] smp: Brought up 1 node, 1 CPU -[ 3.121923] devtmpfs: initialized -[ 3.124649] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns -[ 3.124727] futex hash table entries: 1024 (order: 4, 65536 bytes) -[ 3.125346] random: get_random_u32 called from bucket_table_alloc+0x72/0x172 with crng_init=0 -[ 3.125578] NET: Registered protocol family 16 -[ 3.126400] sifive-u54-prci 10000000.prci: Registered U54 core clocks -[ 3.126649] sifive-gemgxl-mgmt 100a0000.cadence-gemgxl-mgmt: Registered clock switch 'cadence-gemgxl-mgmt' -[ 3.135572] vgaarb: loaded -[ 3.135858] SCSI subsystem initialized -[ 3.136193] usbcore: registered new interface driver usbfs -[ 3.136266] usbcore: registered new interface driver hub -[ 3.136348] usbcore: registered new device driver usb -[ 3.136446] pps_core: LinuxPPS API ver. 1 registered -[ 3.136484] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it -[ 3.136575] PTP clock support registered -[ 3.137256] clocksource: Switched to clocksource riscv_clocksource -[ 3.142711] NET: Registered protocol family 2 -[ 3.143322] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes) -[ 3.143634] TCP established hash table entries: 65536 (order: 7, 524288 bytes) -[ 3.145799] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes) -[ 3.149121] TCP: Hash tables configured (established 65536 bind 65536) -[ 3.149591] UDP hash table entries: 4096 (order: 5, 131072 bytes) -[ 3.150094] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes) -[ 3.150781] NET: Registered protocol family 1 -[ 3.230693] workingset: timestamp_bits=62 max_order=21 bucket_order=0 -[ 3.241224] io scheduler mq-deadline registered -[ 3.241269] io scheduler kyber registered -[ 3.242143] sifive_gpio 10060000.gpio: SiFive GPIO chip registered 16 GPIOs -[ 3.242357] pwm-sifivem 10020000.pwm: Unable to find controller clock -[ 3.242439] pwm-sifivem 10021000.pwm: Unable to find controller clock -[ 3.243228] xilinx-pcie 2000000000.pci: PCIe Link is DOWN -[ 3.243289] xilinx-pcie 2000000000.pci: host bridge /soc/pci@2000000000 ranges: -[ 3.243360] xilinx-pcie 2000000000.pci: No bus range found for /soc/pci@2000000000, using [bus 00-ff] -[ 3.243447] xilinx-pcie 2000000000.pci: MEM 0x40000000..0x5fffffff -> 0x40000000 -[ 3.243591] xilinx-pcie 2000000000.pci: PCI host bridge to bus 0000:00 -[ 3.243636] pci_bus 0000:00: root bus resource [bus 00-ff] -[ 3.243676] pci_bus 0000:00: root bus resource [mem 0x40000000-0x5fffffff] -[ 3.276547] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled -[ 3.277689] 10010000.serial: ttySIF0 at MMIO 0x10010000 (irq = 39, base_baud = 0) is a SiFive UART v0 -[ 3.786963] printk: console [ttySIF0] enabled -[ 3.791504] 10011000.serial: ttySIF1 at MMIO 0x10011000 (irq = 40, base_baud = 0) is a SiFive UART v0 -[ 3.801251] sifive_spi 10040000.spi: mapped; irq=41, cs=1 -[ 3.806362] m25p80 spi0.0: unrecognized JEDEC id bytes: 9d, 70, 19 -[ 3.812084] m25p80: probe of spi0.0 failed with error -2 -[ 3.817453] sifive_spi 10041000.spi: mapped; irq=42, cs=4 -[ 3.823027] sifive_spi 10050000.spi: mapped; irq=43, cs=1 -[ 3.828604] libphy: Fixed MDIO Bus: probed -[ 3.832623] macb: GEM doesn't support hardware ptp. -[ 3.837196] libphy: MACB_mii_bus: probed -[ 4.041156] Microsemi VSC8541 SyncE 10090000.ethernet-ffffffff:00: attached PHY driver [Microsemi VSC8541 SyncE] (mii_bus:phy_addr=10090000.ethernet-ffffffff:00, irq=POLL) -[ 4.055779] macb 10090000.ethernet eth0: Cadence GEM rev 0x10070109 at 0x10090000 irq 12 (70:b3:d5:92:f0:c2) -[ 4.065780] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver -[ 4.072033] ehci-pci: EHCI PCI platform driver -[ 4.076521] usbcore: registered new interface driver usb-storage -[ 4.082843] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0) -[ 4.127465] mmc_spi spi2.0: SD/MMC host mmc0, no DMA, no WP, no poweroff -[ 4.133645] usbcore: registered new interface driver usbhid -[ 4.138980] usbhid: USB HID core driver -[ 4.143017] NET: Registered protocol family 17 -[ 4.147885] pwm-sifivem 10020000.pwm: SiFive PWM chip registered 4 PWMs -[ 4.153945] pwm-sifivem 10021000.pwm: SiFive PWM chip registered 4 PWMs -[ 4.186407] Freeing unused kernel memory: 9380K -[ 4.190224] This architecture does not have kernel memory protection. -[ 4.196609] Run /init as init process -Starting logging: OK -Starting mdev... -[ 4.303785] mmc0: host does not support reading read-only switch, assuming write-enable -[ 4.311109] mmc0: new SDHC card on SPI -[ 4.317103] mmcblk0: mmc0:0000 SS08G 7.40 GiB -[ 4.386471] mmcblk0: p1 p2 -sort: /sys/devices/platform/Fixed: No such file or directory -modprobe: can't change directory to '/lib/modules': No such file or directory -Initializing random[ 4.759075] random: dd: uninitialized urandom read (512 bytes read) - number generator... done. -Starting network... -udhcpc (v1.24.2) started -Sending discover... -Sending discover... -[ 7.927510] macb 10090000.ethernet eth0: link up (1000/Full) -Sending discover... -Sending select for 10.196.157.190... -Lease of 10.196.157.190 obtained, lease time 499743 -deleting routers -adding dns 10.86.1.1 -adding dns 10.86.2.1 -/etc/init.d/S50dropbear -Starting dropbear sshd: [ 12.772393] random: dropbear: uninitialized urandom read (32 bytes read) -OK +[ 0.000007] sched_clock: 64 bits at 1000kHz, resolution 1000ns, wraps every 2199023255500ns +[ 0.008553] Console: colour dummy device 80x25 +[ 0.012990] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=4000) +[ 0.023103] pid_max: default: 32768 minimum: 301 +[ 0.028269] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes) +[ 0.035068] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes) +[ 0.042770] *** VALIDATE proc *** +[ 0.045610] *** VALIDATE cgroup1 *** +[ 0.049157] *** VALIDATE cgroup2 *** +[ 0.053743] rcu: Hierarchical SRCU implementation. +[ 0.058297] smp: Bringing up secondary CPUs ... +[ 0.064134] smp: Brought up 1 node, 4 CPUs +[ 0.069114] devtmpfs: initialized +[ 0.073281] random: get_random_u32 called from bucket_table_alloc.isra.10+0x4e/0x160 with crng_init=0 +[ 0.082157] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns +[ 0.091634] futex hash table entries: 1024 (order: 4, 65536 bytes) +[ 0.098480] NET: Registered protocol family 16 +[ 0.114101] vgaarb: loaded +[ 0.116397] SCSI subsystem initialized +[ 0.120358] usbcore: registered new interface driver usbfs +[ 0.125541] usbcore: registered new interface driver hub +[ 0.130936] usbcore: registered new device driver usb +[ 0.136618] clocksource: Switched to clocksource riscv_clocksource +[ 0.148108] NET: Registered protocol family 2 +[ 0.152358] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes) +[ 0.159928] TCP established hash table entries: 65536 (order: 7, 524288 bytes) +[ 0.169027] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes) +[ 0.178360] TCP: Hash tables configured (established 65536 bind 65536) +[ 0.184653] UDP hash table entries: 4096 (order: 5, 131072 bytes) +[ 0.190819] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes) +[ 0.197618] NET: Registered protocol family 1 +[ 0.201892] RPC: Registered named UNIX socket transport module. +[ 0.207395] RPC: Registered udp transport module. +[ 0.212159] RPC: Registered tcp transport module. +[ 0.216940] RPC: Registered tcp NFSv4.1 backchannel transport module. +[ 0.223445] PCI: CLS 0 bytes, default 64 +[ 0.227726] Unpacking initramfs... +[ 0.260556] Freeing initrd memory: 2336K +[ 0.264652] workingset: timestamp_bits=62 max_order=21 bucket_order=0 +[ 0.278452] NFS: Registering the id_resolver key type +[ 0.282841] Key type id_resolver registered +[ 0.287067] Key type id_legacy registered +[ 0.291155] nfs4filelayout_init: NFSv4 File Layout Driver Registering... +[ 0.298299] NET: Registered protocol family 38 +[ 0.302470] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254) +[ 0.309906] io scheduler mq-deadline registered +[ 0.314501] io scheduler kyber registered +[ 0.354134] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled +[ 0.360725] 10010000.serial: ttySIF0 at MMIO 0x10010000 (irq = 4, base_baud = 0) is a SiFive UART v0 +[ 0.369191] printk: console [ttySIF0] enabled +[ 0.369191] printk: console [ttySIF0] enabled +[ 0.377938] printk: bootconsole [sbi0] disabled +[ 0.377938] printk: bootconsole [sbi0] disabled +[ 0.387298] 10011000.serial: ttySIF1 at MMIO 0x10011000 (irq = 1, base_baud = 0) is a SiFive UART v0 +[ 0.396411] [drm] radeon kernel modesetting enabled. +[ 0.409818] loop: module loaded +[ 0.412606] libphy: Fixed MDIO Bus: probed +[ 0.416870] macb 10090000.ethernet: Registered clk switch 'sifive-gemgxl-mgmt' +[ 0.423570] macb: GEM doesn't support hardware ptp. +[ 0.428469] libphy: MACB_mii_bus: probed +[ 1.053009] Microsemi VSC8541 SyncE 10090000.ethernet-ffffffff:00: attached PHY driver [Microsemi VSC8541 SyncE] (mii_bus:phy_addr=10090000.ethernet-ffffffff:00, irq=POLL) +[ 1.067548] macb 10090000.ethernet eth0: Cadence GEM rev 0x10070109 at 0x10090000 irq 7 (70:b3:d5:92:f2:f3) +[ 1.077330] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k +[ 1.083069] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. +[ 1.089061] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver +[ 1.095485] ehci-pci: EHCI PCI platform driver +[ 1.099947] ehci-platform: EHCI generic platform driver +[ 1.105196] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver +[ 1.111286] ohci-pci: OHCI PCI platform driver +[ 1.115742] ohci-platform: OHCI generic platform driver +[ 1.121142] usbcore: registered new interface driver uas +[ 1.126269] usbcore: registered new interface driver usb-storage +[ 1.132331] mousedev: PS/2 mouse device common for all mice +[ 1.137978] usbcore: registered new interface driver usbhid +[ 1.143325] usbhid: USB HID core driver +[ 1.148022] NET: Registered protocol family 10 +[ 1.152609] Segment Routing with IPv6 +[ 1.155571] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver +[ 1.161927] NET: Registered protocol family 17 +[ 1.165907] Key type dns_resolver registered +[ 1.171694] Freeing unused kernel memory: 204K +[ 1.175375] This architecture does not have kernel memory protection. +[ 1.181792] Run /init as init process + _ _ + | ||_| + | | _ ____ _ _ _ _ + | || | _ | | | |\ / / + | || | | | | |_| |/ \ + |_||_|_| |_|____|_/_/ + + Busybox Rootfs
-Welcome to Buildroot -buildroot login: +Please press Enter to activate this console. +/ #
Instead of depending on CONFIG_SYS_LITTLE_ENDIAN, we check at runtime whether underlying system is little-endian or big-endian. This way we are not dependent on any U-Boot specific OR compiler specific macro to check system endianness.
Signed-off-by: Anup Patel anup.patel@wdc.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-By: Ramon Fried rfried.dev@gmail.com --- drivers/net/macb.c | 12 ++++++++---- 1 file changed, 8 insertions(+), 4 deletions(-)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index 322302762a..a4015e9bd5 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -84,6 +84,8 @@ struct macb_dma_desc { struct macb_device { void *regs;
+ bool is_big_endian; + const struct macb_config*config;
unsigned int rx_tail; @@ -743,11 +745,10 @@ static void gmac_configure_dma(struct macb_device *macb) dmacfg |= GEM_BIT(TXPBMS) | GEM_BF(RXBMS, -1L); dmacfg &= ~GEM_BIT(ENDIA_PKT);
-#ifdef CONFIG_SYS_LITTLE_ENDIAN - dmacfg &= ~GEM_BIT(ENDIA_DESC); -#else + if (macb->is_big_endian) dmacfg |= GEM_BIT(ENDIA_DESC); /* CPU in big endian */ -#endif + else + dmacfg &= ~GEM_BIT(ENDIA_DESC);
dmacfg &= ~GEM_BIT(ADDR64); gem_writel(macb, DMACFG, dmacfg); @@ -1221,6 +1222,9 @@ static int macb_eth_probe(struct udevice *dev)
+ macb->is_big_endian = (cpu_to_be32(0x12345678) == 0x12345678) ? + true : false; + macb->config = (struct macb_config *)dev_get_driver_data(dev); if (!macb->config) macb->config = &default_gem_config;
bool is_big_endian;
-#else
-#endif
else
dmacfg &= ~GEM_BIT(ENDIA_DESC); dmacfg &= ~GEM_BIT(ADDR64); gem_writel(macb, DMACFG, dmacfg);
true : false;
-- 2.17.1
Hi Joe,
Regards, Anup
On Tue, 2019-06-25 at 06:30 +0000, Anup Patel wrote:
This series update SiFive Unleashed clock driver and Cadence MACB driver so that:
- It is in sync with upstream Linux driver
- It uses latest DT bindings as-per upstream Linux driver
With this series, we can now use latest DT bindings with U-Boot. I have tested SiFive Serial driver and Cadence MACB ethernet driver with this changes and both work fine.
The legacy FSBL will still pass DTB with older DT bindings which will break the updated SiFive Unleashed clock driver. To tackle this, we have embedded DTB in OpenSBI FW_PAYLOAD firmware for SiFive Unleashed so that OpenSBI will override and pass updated DTB to U-Boot.
The updated DTB passed by OpenSBI is in fact the DTB build by upstream Linux so we can straight away pass this DTB to Linux as well.
This series can be found in riscv_unleashed_clk_sync_v9 branch at: https://github.com/avpatel/u-boot.git
To try this series use latest OpenSBI at: https://github.com/riscv/opensbi.git And Linux-5.2-rc1 from v5.2-rc1_unleashed branch at: https://github.com/avpatel/linux.git
I see the entire series has reviewed-by. Can this be queued for 2019-07 release or it's too late?
If it can be queued, it will easier for distros to upgrade everything at one shot. We can have all upstream boot flow for unleashed board.
OpenSBI (0.4) + Linux (5.2) + U-Boot (v2019-07)
Changes since v8:
- Removed probe() from macb_config for PATCH6
- Renamed set_tx_clk() to clk_init() in macb_config for PATCH6
Changes since v7:
- Update PATCH6 to not treat dma_burst_length = 0 as skip
gmac_configure_dma()
- Update PATCH9 to check endianess at runtime
Changes since v6:
- Added separate patch to fix endianess check in gmac_configure_dma()
Changes since v5:
- Addressed Ramon's comments in PATCH6
- Addressed Bin's comments in PATCH7
Changes since v4:
- Rebased patches upon Ramon's MACB changes (Refer, https://patchwork.ozlabs.org/patch/1114025/)
- Added PATCH7 to setup ethaddr based on board serial number read
from OTP
- Added PATCH8 to update documentation
Changes since v3:
- Extend MACB ethernet driver for SiFive Unleashed board (just like
Linux)
Changes since v2:
- Dropped PATCH6 which adds new compatible string to MACB driver
because more changes are required in MACB driver for different ethernet speeds
Changes since v1:
- Dropped GEMGXL clock driver
- Added new compatible string for SiFive MACB ethernet
Anup Patel (9): clk: sifive: Factor-out PLL library as separate module clk: sifive: Sync-up WRPLL library with upstream Linux clk: sifive: Sync-up DT bindings header with upstream Linux clk: sifive: Sync-up main driver with upstream Linux clk: sifive: Drop GEMGXL clock driver net: macb: Extend MACB driver for SiFive Unleashed board riscv: sifive: fu540: Setup ethaddr env variable using OTP doc: sifive-fu540: Update README for stepsgit.denx.de/u-boot- riscv.git to create FW_PAYLOAD net: macb: Fix check for little-endian system in gmac_configure_dma()
board/sifive/fu540/Kconfig | 1 - board/sifive/fu540/fu540.c | 122 ++++++ configs/sifive_fu540_defconfig | 1 + doc/README.sifive-fu540 | 356 ++++++++------
drivers/clk/Kconfig | 1 + drivers/clk/Makefile | 1 + drivers/clk/analogbits/Kconfig | 4 + drivers/clk/analogbits/Makefile | 3 + .../{sifive => analogbits}/wrpll-cln28hpc.c | 168 ++++----- drivers/clk/sifive/Kconfig | 10 - drivers/clk/sifive/Makefile | 4 - drivers/clk/sifive/fu540-prci.c | 123 +++--- drivers/clk/sifive/gemgxl-mgmt.c | 60 --- drivers/net/macb.c | 82 ++-- include/dt-bindings/clk/sifive-fu540-prci.h | 29 -- include/dt-bindings/clock/sifive-fu540-prci.h | 18 + .../linux/clk}/analogbits-wrpll-cln28hpc.h | 70 ++-- 17 files changed, 543 insertions(+), 510 deletions(-) create mode 100644 drivers/clk/analogbits/Kconfig create mode 100644 drivers/clk/analogbits/Makefile rename drivers/clk/{sifive => analogbits}/wrpll-cln28hpc.c (69%) delete mode 100644 drivers/clk/sifive/gemgxl-mgmt.c delete mode 100644 include/dt-bindings/clk/sifive-fu540-prci.h create mode 100644 include/dt-bindings/clock/sifive-fu540-prci.h rename {drivers/clk/sifive => include/linux/clk}/analogbits-wrpll- cln28hpc.h (52%)
-- 2.17.1
Anup Patel
Anup Patel
Atish Patra
Ramon Fried
