[U-Boot] [PATCH 1/2] net: reject Bootp/DHCP packets with bad OP value
Rename check_packet to check_reply_packet to make its function more obvious. The check for DHCP_* values is completely off, as it should compare against DHCP option 53 (Message Type). Only valid value for any Bootp/DHCP reply is BOOTREPLY.
Signed-off-by: Stefan Brüns stefan.bruens@rwth-aachen.de --- net/bootp.c | 13 +++++-------- 1 file changed, 5 insertions(+), 8 deletions(-)
diff --git a/net/bootp.c b/net/bootp.c index 43466af..e6eba12 100644 --- a/net/bootp.c +++ b/net/bootp.c @@ -109,7 +109,8 @@ static bool bootp_match_id(ulong id) return false; }
-static int check_packet(uchar *pkt, unsigned dest, unsigned src, unsigned len) +static int check_reply_packet(uchar *pkt, unsigned dest, unsigned src, + unsigned len) { struct bootp_hdr *bp = (struct bootp_hdr *)pkt; int retval = 0; @@ -118,11 +119,7 @@ static int check_packet(uchar *pkt, unsigned dest, unsigned src, unsigned len) retval = -1; else if (len < sizeof(struct bootp_hdr) - OPT_FIELD_SIZE) retval = -2; - else if (bp->bp_op != OP_BOOTREQUEST && - bp->bp_op != OP_BOOTREPLY && - bp->bp_op != DHCP_OFFER && - bp->bp_op != DHCP_ACK && - bp->bp_op != DHCP_NAK) + else if (bp->bp_op != OP_BOOTREPLY) retval = -3; else if (bp->bp_htype != HWT_ETHER) retval = -4; @@ -343,7 +340,7 @@ static void bootp_handler(uchar *pkt, unsigned dest, struct in_addr sip, bp = (struct bootp_hdr *)pkt;
/* Filter out pkts we don't want */ - if (check_packet(pkt, dest, src, len)) + if (check_reply_packet(pkt, dest, src, len)) return;
/* @@ -958,7 +955,7 @@ static void dhcp_handler(uchar *pkt, unsigned dest, struct in_addr sip, src, dest, len, dhcp_state);
debug("DHCPHandler: got DHCP packet: (src=%d, dst=%d, len=%d) state: "
Hi Stefan,
On Thu, Aug 27, 2015 at 4:53 PM, Stefan Brüns stefan.bruens@rwth-aachen.de wrote:
Applied to u-boot-net/master, thanks! -Joe
Joe Hershberger
Stefan Brüns
