[U-Boot] [PATCH] Exynos5250: I2C: Fix driver as per new I2C multibus/multiadapter support
This patch fixes the S3C24xx I2C driver as per new I2C multibus/multiadapter support for Exynos5250.
Change-Id: I95873fef7d312310670e3bb33ad9532c10f60463 Signed-off-by: Rajeshwari S Shinde rajeshwari.s@samsung.com --- drivers/i2c/s3c24x0_i2c.c | 14 +++++++------- include/configs/exynos5250-dt.h | 3 ++- 2 files changed, 9 insertions(+), 8 deletions(-)
diff --git a/drivers/i2c/s3c24x0_i2c.c b/drivers/i2c/s3c24x0_i2c.c index cd09c78..5fdb85f 100644 --- a/drivers/i2c/s3c24x0_i2c.c +++ b/drivers/i2c/s3c24x0_i2c.c @@ -53,7 +53,7 @@ static unsigned int g_current_bus __attribute__((section(".data"))); #ifdef CONFIG_OF_CONTROL static int i2c_busses __attribute__((section(".data"))); -static struct s3c24x0_i2c_bus i2c_bus[CONFIG_MAX_I2C_NUM] +static struct s3c24x0_i2c_bus i2c_bus_data[CONFIG_SYS_NUM_I2C_BUSES] __attribute__((section(".data"))); #endif
@@ -160,7 +160,7 @@ int i2c_set_bus_num(unsigned int bus) { struct s3c24x0_i2c *i2c;
- if ((bus < 0) || (bus >= CONFIG_MAX_I2C_NUM)) { + if ((bus < 0) || (bus >= CONFIG_SYS_NUM_I2C_BUSES)) { debug("Bad bus: %d\n", bus); return -1; } @@ -503,12 +503,12 @@ int i2c_write(uchar chip, uint addr, int alen, uchar *buffer, int len) void board_i2c_init(const void *blob) { int i; - int node_list[CONFIG_MAX_I2C_NUM]; + int node_list[CONFIG_SYS_NUM_I2C_BUSES]; int count;
count = fdtdec_find_aliases_for_id(blob, "i2c", COMPAT_SAMSUNG_S3C2440_I2C, node_list, - CONFIG_MAX_I2C_NUM); + CONFIG_SYS_NUM_I2C_BUSES);
for (i = 0; i < count; i++) { struct s3c24x0_i2c_bus *bus; @@ -516,7 +516,7 @@ void board_i2c_init(const void *blob)
if (node <= 0) continue; - bus = &i2c_bus[i]; + bus = &i2c_bus_data[i]; bus->regs = (struct s3c24x0_i2c *) fdtdec_get_addr(blob, node, "reg"); bus->id = pinmux_decode_periph_id(blob, node); @@ -529,7 +529,7 @@ void board_i2c_init(const void *blob) static struct s3c24x0_i2c_bus *get_bus(unsigned int bus_idx) { if (bus_idx < i2c_busses) - return &i2c_bus[bus_idx]; + return &i2c_bus_data[bus_idx];
debug("Undefined bus: %d\n", bus_idx); return NULL; @@ -540,7 +540,7 @@ int i2c_get_bus_num_fdt(int node) int i;
for (i = 0; i < i2c_busses; i++) { - if (node == i2c_bus[i].node) + if (node == i2c_bus_data[i].node) return i; }
diff --git a/include/configs/exynos5250-dt.h b/include/configs/exynos5250-dt.h index 2b93a45..e6a2cd0 100644 --- a/include/configs/exynos5250-dt.h +++ b/include/configs/exynos5250-dt.h @@ -254,8 +254,9 @@ #define CONFIG_SYS_I2C_SPEED 100000 /* 100 Kbps */ #define CONFIG_DRIVER_S3C24X0_I2C #define CONFIG_I2C_MULTI_BUS -#define CONFIG_MAX_I2C_NUM 8 #define CONFIG_SYS_I2C_SLAVE 0x0 +#define CONFIG_SYS_I2C_MAX_HOPS 1 +#define CONFIG_SYS_NUM_I2C_BUSES 8 #define CONFIG_I2C_EDID
/* PMIC */
Hello Rajeshwari,
Am 03.09.2013 08:20, schrieb Rajeshwari S Shinde:
Change-Id: I95873fef7d312310670e3bb33ad9532c10f60463 Signed-off-by: Rajeshwari S Shinderajeshwari.s@samsung.com
Hmm.. could you switch to the new i2c framework instead fixing the old state of the driver?
Also there is another board which uses this driver:
[hs@pollux u-boot]$ grep -lr CONFIG_DRIVER_S3C24X0_I2C include/configs/ include/configs/exynos5250-dt.h include/configs/VCMA9.h [hs@pollux u-boot]$
Please fix this too, if switching to the new framework ... thanks!
- if ((bus< 0) || (bus>= CONFIG_MAX_I2C_NUM)) {
- if ((bus< 0) || (bus>= CONFIG_SYS_NUM_I2C_BUSES)) { debug("Bad bus: %d\n", bus); return -1; }
for (i = 0; i< count; i++) { struct s3c24x0_i2c_bus *bus;
if (node<= 0) continue;
bus =&i2c_bus[i];
bus->regs = (struct s3c24x0_i2c *) fdtdec_get_addr(blob, node, "reg"); bus->id = pinmux_decode_periph_id(blob, node);bus =&i2c_bus_data[i];
@@ -529,7 +529,7 @@ void board_i2c_init(const void *blob) static struct s3c24x0_i2c_bus *get_bus(unsigned int bus_idx) { if (bus_idx< i2c_busses)
return&i2c_bus[bus_idx];
return&i2c_bus_data[bus_idx];
for (i = 0; i< i2c_busses; i++) {
}if (node == i2c_bus_data[i].node) return i;
no longer needed, if you use the new framework ...
you do not need the CONFIG_SYS_I2C_MAX_HOPS define, this define is only needed, if using muxes and using the new framework ...
no longer needed if you use the new framework ...
/* PMIC */
I prefer to switch to the new framework, such it is done for the tegra driver, see commit:
http://git.denx.de/?p=u-boot.git;a=commitdiff;h=1f2ba722ac06393d6abe6d473482...
maybe a fix like this is for you also necessary, as you use fdt:
http://git.denx.de/?p=u-boot.git;a=commitdiff;h=cdce889959c611876690a9f0a3c7...
bye, Heiko
Hi Heiko,
Ok will work on same and get back to you in-case of any doubts.
Regards, Rajehswari
On Tue, Sep 3, 2013 at 12:31 PM, Heiko Schocher hs@denx.de wrote:
Hello Rajeshwari,
int node_list[CONFIG_SYS_NUM_I2C_BUSES]; int count; count = fdtdec_find_aliases_for_id(blob, "i2c", COMPAT_SAMSUNG_S3C2440_I2C, node_list,
CONFIG_SYS_NUM_I2C_BUSES); for (i = 0; i< count; i++) { struct s3c24x0_i2c_bus *bus;
bus =&i2c_bus[i];
bus =&i2c_bus_data[i]; bus->regs = (struct s3c24x0_i2c *) fdtdec_get_addr(blob, node, "reg"); bus->id = pinmux_decode_periph_id(blob, node);
return&i2c_bus_data[bus_idx]; debug("Undefined bus: %d\n", bus_idx); return NULL;
/* PMIC */
bye, Heiko -- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany
Heiko Schocher
Rajeshwari Birje
Rajeshwari S Shinde
