[U-Boot] [PATCH 1/2] mx6cuboxi: consolidate board detection and add som revision checking
In order to properly detect the board the checks need to be done in a specific order. Move these tests back into a single enum function that will always return the proper the board it is checking.
This also adds the best test we have for detecting the rev 1.5 som, and it simplifies the device-tree filename building.
Signed-off-by: Jon Nettleton jon@solid-run.com Signed-off-by: Baruch Siach baruch@tkos.co.il --- board/solidrun/mx6cuboxi/mx6cuboxi.c | 136 +++++++++++++++++---------- include/configs/mx6cuboxi.h | 24 ++--- 2 files changed, 98 insertions(+), 62 deletions(-)
diff --git a/board/solidrun/mx6cuboxi/mx6cuboxi.c b/board/solidrun/mx6cuboxi/mx6cuboxi.c index 1fb3c69edeb5..1567cf0c91af 100644 --- a/board/solidrun/mx6cuboxi/mx6cuboxi.c +++ b/board/solidrun/mx6cuboxi/mx6cuboxi.c @@ -57,6 +57,13 @@ DECLARE_GLOBAL_DATA_PTR; #define ETH_PHY_RESET IMX_GPIO_NR(4, 15) #define USB_H1_VBUS IMX_GPIO_NR(1, 0)
+enum board_type { + CUBOXI = 0x00, + HUMMINGBOARD = 0x01, + HUMMINGBOARD2 = 0x02, + UNKNOWN = 0x03, +}; + int dram_init(void) { gd->ram_size = imx_ddr_size(); @@ -77,10 +84,17 @@ static iomux_v3_cfg_t const usdhc2_pads[] = { IOMUX_PADS(PAD_SD2_DAT3__SD2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), };
-static iomux_v3_cfg_t const hb_cbi_sense[] = { +static iomux_v3_cfg_t const board_detect[] = { /* These pins are for sensing if it is a CuBox-i or a HummingBoard */ IOMUX_PADS(PAD_KEY_ROW1__GPIO4_IO09 | MUX_PAD_CTRL(UART_PAD_CTRL)), IOMUX_PADS(PAD_EIM_DA4__GPIO3_IO04 | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_SD4_DAT0__GPIO2_IO08 | MUX_PAD_CTRL(UART_PAD_CTRL)), +}; + +static iomux_v3_cfg_t const som_rev_detect[] = { + /* These pins are for sensing if it is a CuBox-i or a HummingBoard */ + IOMUX_PADS(PAD_CSI0_DAT14__GPIO6_IO00 | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_CSI0_DAT18__GPIO6_IO04 | MUX_PAD_CTRL(UART_PAD_CTRL)), };
static iomux_v3_cfg_t const usb_pads[] = { @@ -333,88 +347,110 @@ int board_init(void) return ret; }
-static bool is_hummingboard(void) +static enum board_type board_type(void) { - int val1, val2; + int val1, val2, val3;
- SETUP_IOMUX_PADS(hb_cbi_sense); - - gpio_direction_input(IMX_GPIO_NR(4, 9)); - gpio_direction_input(IMX_GPIO_NR(3, 4)); - - val1 = gpio_get_value(IMX_GPIO_NR(4, 9)); - val2 = gpio_get_value(IMX_GPIO_NR(3, 4)); + SETUP_IOMUX_PADS(board_detect);
/* * Machine selection - - * Machine val1, val2 - * ------------------------- - * HB2 x x - * HB rev 3.x x 0 - * CBi 0 1 - * HB 1 1 + * Machine val1, val2, val3 + * ---------------------------- + * HB2 x x 0 + * HB rev 3.x x 0 x + * CBi 0 1 x + * HB 1 1 x */
- if (val2 == 0) - return true; - else if (val1 == 0) - return false; - else - return true; -} + gpio_direction_input(IMX_GPIO_NR(2, 8)); + val3 = gpio_get_value(IMX_GPIO_NR(2, 8));
-static bool is_hummingboard2(void) -{ - int val1; + if (val3 == 0) + return HUMMINGBOARD2;
- SETUP_IOMUX_PADS(hb_cbi_sense); + gpio_direction_input(IMX_GPIO_NR(3, 4)); + val2 = gpio_get_value(IMX_GPIO_NR(3, 4));
- gpio_direction_input(IMX_GPIO_NR(2, 8)); + if (val2 == 0) + return HUMMINGBOARD;
- val1 = gpio_get_value(IMX_GPIO_NR(2, 8)); + gpio_direction_input(IMX_GPIO_NR(4, 9)); + val1 = gpio_get_value(IMX_GPIO_NR(4, 9));
- /* - * Machine selection - - * Machine val1 - * ------------------- - * HB2 0 - * HB rev 3.x x - * CBi x - * HB x - */ + if (val1 == 0) { + return CUBOXI; + } else { + return HUMMINGBOARD; + } +} + +static bool is_rev_15_som(void) +{ + int val1, val2; + SETUP_IOMUX_PADS(som_rev_detect);
- if (val1 == 0) + val1 = gpio_get_value(IMX_GPIO_NR(6, 0)); + val2 = gpio_get_value(IMX_GPIO_NR(6, 4)); + + if (val1 == 1 && val2 == 0) return true; - else - return false; + + return false; }
int checkboard(void) { - if (is_hummingboard2()) - puts("Board: MX6 Hummingboard2\n"); - else if (is_hummingboard()) - puts("Board: MX6 Hummingboard\n"); + switch (board_type()) { + case CUBOXI: + puts("Board: MX6 Cubox-i"); + break; + case HUMMINGBOARD: + puts("Board: MX6 HummingBoard"); + break; + case HUMMINGBOARD2: + puts("Board: MX6 HummingBoard2"); + break; + case UNKNOWN: + default: + puts("Board: Unknown\n"); + goto out; + } + + if (is_rev_15_som()) + puts(" (som rev 1.5)\n"); else - puts("Board: MX6 Cubox-i\n"); + puts("\n");
+out: return 0; }
int board_late_init(void) { #ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - if (is_hummingboard2()) - env_set("board_name", "HUMMINGBOARD2"); - else if (is_hummingboard()) + switch (board_type()) { + case CUBOXI: + env_set("board_name", "CUBOXI"); + break; + case HUMMINGBOARD: env_set("board_name", "HUMMINGBOARD"); - else + break; + case HUMMINGBOARD2: + env_set("board_name", "HUMMINGBOARD2"); + break; + case UNKNOWN: + default: env_set("board_name", "CUBOXI"); + }
if (is_mx6dq()) env_set("board_rev", "MX6Q"); else env_set("board_rev", "MX6DL"); + + if (is_rev_15_som()) + env_set("som_rev", "V15"); #endif
return 0; diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index 6e2137769822..803661cfa843 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -101,18 +101,18 @@ "fi; " \ "fi\0" \ "findfdt="\ - "if test $board_name = HUMMINGBOARD2 && test $board_rev = MX6Q ; then " \ - "setenv fdtfile imx6q-hummingboard2.dtb; fi; " \ - "if test $board_name = HUMMINGBOARD2 && test $board_rev = MX6DL ; then " \ - "setenv fdtfile imx6dl-hummingboard2.dtb; fi; " \ - "if test $board_name = HUMMINGBOARD && test $board_rev = MX6Q ; then " \ - "setenv fdtfile imx6q-hummingboard.dtb; fi; " \ - "if test $board_name = HUMMINGBOARD && test $board_rev = MX6DL ; then " \ - "setenv fdtfile imx6dl-hummingboard.dtb; fi; " \ - "if test $board_name = CUBOXI && test $board_rev = MX6Q ; then " \ - "setenv fdtfile imx6q-cubox-i.dtb; fi; " \ - "if test $board_name = CUBOXI && test $board_rev = MX6DL ; then " \ - "setenv fdtfile imx6dl-cubox-i.dtb; fi; " \ + "if test $board_rev = MX6Q ; then " \ + "setenv fdtprefix imx6q; fi; " \ + "if test $board_rev = MX6DL ; then " \ + "setenv fdtprefix imx6dl; fi; " \ + "if test $som_rev = V15 ; then " \ + "setenv fdtsuffix -som-v15; fi; " \ + "if test $board_name = HUMMINGBOARD2 ; then " \ + "setenv fdtfile ${fdtprefix}-hummingboard2${fdtsuffix}.dtb; fi; " \ + "if test $board_name = HUMMINGBOARD ; then " \ + "setenv fdtfile ${fdtprefix}-hummingboard${fdtsuffix}.dtb; fi; " \ + "if test $board_name = CUBOXI ; then " \ + "setenv fdtfile ${fdtprefix}-cubox-i${fdtsuffix}.dtb; fi; " \ "if test $fdtfile = undefined; then " \ "echo WARNING: Could not determine dtb to use; fi; \0" \ BOOTENV
The soms with 4GB ddr have a rowaddr of 16 not 15, this allows the detection mechanism to properly identify them as 4GB. However these soms can be populated with whatever amount of memory the customer requests therefor we need a ram stride test. We can not use the get_ram_size() function because not all 4GB's of DDR is addressable on a 32-bit architecture. Therefore instead we use a memory stride of 128MB's and look for the address that the memory wraps. This function is used for all som types to catch most memory configurations.
This is a revised version of Rabeeh Khoury's original code.
Signed-off-by: Jon Nettleton jon@solid-run.com Signed-off-by: Rabeeh Khoury rabeeh@solid-run.com Signed-off-by: Baruch Siach baruch@tkos.co.il --- board/solidrun/mx6cuboxi/mx6cuboxi.c | 46 ++++++++++++++++++++++++++-- 1 file changed, 44 insertions(+), 2 deletions(-)
diff --git a/board/solidrun/mx6cuboxi/mx6cuboxi.c b/board/solidrun/mx6cuboxi/mx6cuboxi.c index 1567cf0c91af..38d89f0130bb 100644 --- a/board/solidrun/mx6cuboxi/mx6cuboxi.c +++ b/board/solidrun/mx6cuboxi/mx6cuboxi.c @@ -64,9 +64,51 @@ enum board_type { UNKNOWN = 0x03, };
+#define MEM_STRIDE 0x4000000 +static u32 get_ram_size_stride_test(u32 *base, u32 maxsize) +{ + volatile u32 *addr; + u32 save[64]; + u32 cnt; + u32 size; + int i = 0; + + /* First save the data */ + for (cnt = 0; cnt < maxsize; cnt += MEM_STRIDE) { + addr = (volatile u32 *)((u32)base + cnt); /* pointer arith! */ + sync (); + save[i++] = *addr; + sync (); + } + + /* First write a signature */ + * (volatile u32 *)base = 0x12345678; + for (size = MEM_STRIDE; size < maxsize; size += MEM_STRIDE) { + * (volatile u32 *)((u32)base + size) = size; + sync (); + if (* (volatile u32 *)((u32)base) == size) { /* We reached the overlapping address */ + break; + } + } + + /* Restore the data */ + for (cnt = (maxsize - MEM_STRIDE); i > 0; cnt -= MEM_STRIDE) { + addr = (volatile u32 *)((u32)base + cnt); /* pointer arith! */ + sync (); + *addr = save[i--]; + sync (); + } + + return (size); +} + int dram_init(void) { - gd->ram_size = imx_ddr_size(); + u32 max_size = imx_ddr_size(); + + gd->ram_size = get_ram_size_stride_test((u32 *) CONFIG_SYS_SDRAM_BASE, + (u32)max_size); + return 0; }
@@ -626,7 +668,7 @@ static struct mx6_ddr3_cfg mem_ddr_4g = { .density = 4, .width = 16, .banks = 8, - .rowaddr = 15, + .rowaddr = 16, .coladdr = 10, .pagesz = 2, .trcd = 1375,
Reviewed-by: Fabio Estevam fabio.estevam@nxp.com
Baruch Siach
Fabio Estevam
