[PATCH 0/4] x86: Updates to SMBIOS
At present there are a few Kconfig options which allow SMBIOS fields to be specified at build time.
Not all fields are supported. Also, defining these at build-time is limiting since a factory system cannot insert values for particular boards or models without rebuilding U-Boot.
This series adds a way to set SMBIOS properties using the devicetree. With this approach, more fields are supported and it is easy to update values in the devicetree in the factory.
Simon Glass (4): x86: Pass an ofnode into each SMBIOS function smbios: Allow properties to come from the device tree smbios: Add more properties smbios: Add documentation and devicetree binding
doc/arch/x86.rst | 8 ++ doc/device-tree-bindings/board/board_x86.txt | 36 +++++++ include/smbios.h | 5 +- lib/smbios.c | 99 +++++++++++++++----- 4 files changed, 124 insertions(+), 24 deletions(-) create mode 100644 doc/device-tree-bindings/board/board_x86.txt
As a first step to obtaining SMBIOS information from the devicetree, add an ofnode parameter to the writing functions.
include/smbios.h | 5 ++++- lib/smbios.c | 40 +++++++++++++++++++++++----------------- 2 files changed, 27 insertions(+), 18 deletions(-)
diff --git a/include/smbios.h b/include/smbios.h index 97b9ddce237..c19afbe16c7 100644 --- a/include/smbios.h +++ b/include/smbios.h @@ -8,6 +8,8 @@ #ifndef _SMBIOS_H_ #define _SMBIOS_H_
+#include <dm/ofnode.h> + /* SMBIOS spec version implemented */ #define SMBIOS_MAJOR_VER 3 #define SMBIOS_MINOR_VER 0 @@ -222,9 +224,10 @@ static inline void fill_smbios_header(void *table, int type, * * @addr: start address to write the structure * @handle: the structure's handle, a unique 16-bit number + * @node: node containing the information to write (ofnode_null() if none) * @return: size of the structure */ -typedef int (*smbios_write_type)(ulong *addr, int handle); +typedef int (*smbios_write_type)(ulong *addr, int handle, ofnode node);
/** * write_smbios_table() - Write SMBIOS table diff --git a/lib/smbios.c b/lib/smbios.c index 11790443e1a..dd4b8841d6c 100644 --- a/lib/smbios.c +++ b/lib/smbios.c @@ -25,7 +25,7 @@ * * @start: string area start address * @str: string to add - * @return: string number in the string area + * @return: string number in the string area (1 or more) */ static int smbios_add_string(char *start, const char *str) { @@ -74,7 +74,7 @@ static int smbios_string_table_len(char *start) return len + 1; }
-static int smbios_write_type0(ulong *current, int handle) +static int smbios_write_type0(ulong *current, int handle, ofnode node) { struct smbios_type0 *t; int len = sizeof(struct smbios_type0); @@ -111,7 +111,7 @@ static int smbios_write_type0(ulong *current, int handle) return len; }
-static int smbios_write_type1(ulong *current, int handle) +static int smbios_write_type1(ulong *current, int handle, ofnode node) { struct smbios_type1 *t; int len = sizeof(struct smbios_type1); @@ -134,7 +134,7 @@ static int smbios_write_type1(ulong *current, int handle) return len; }
-static int smbios_write_type2(ulong *current, int handle) +static int smbios_write_type2(ulong *current, int handle, ofnode node) { struct smbios_type2 *t; int len = sizeof(struct smbios_type2); @@ -154,7 +154,7 @@ static int smbios_write_type2(ulong *current, int handle) return len; }
-static int smbios_write_type3(ulong *current, int handle) +static int smbios_write_type3(ulong *current, int handle, ofnode node) { struct smbios_type3 *t; int len = sizeof(struct smbios_type3); @@ -176,7 +176,7 @@ static int smbios_write_type3(ulong *current, int handle) return len; }
-static void smbios_write_type4_dm(struct smbios_type4 *t) +static void smbios_write_type4_dm(struct smbios_type4 *t, ofnode node) { u16 processor_family = SMBIOS_PROCESSOR_FAMILY_UNKNOWN; const char *vendor = "Unknown"; @@ -185,20 +185,20 @@ static void smbios_write_type4_dm(struct smbios_type4 *t) #ifdef CONFIG_CPU char processor_name[49]; char vendor_name[49]; - struct udevice *dev = NULL; + struct udevice *cpu = NULL;
- uclass_find_first_device(UCLASS_CPU, &dev); - if (dev) { - struct cpu_platdata *plat = dev_get_parent_platdata(dev); + uclass_find_first_device(UCLASS_CPU, &cpu); + if (cpu) { + struct cpu_platdata *plat = dev_get_parent_platdata(cpu);
if (plat->family) processor_family = plat->family; t->processor_id[0] = plat->id[0]; t->processor_id[1] = plat->id[1];
- if (!cpu_get_vendor(dev, vendor_name, sizeof(vendor_name))) + if (!cpu_get_vendor(cpu, vendor_name, sizeof(vendor_name))) vendor = vendor_name; - if (!cpu_get_desc(dev, processor_name, sizeof(processor_name))) + if (!cpu_get_desc(cpu, processor_name, sizeof(processor_name))) name = processor_name; } #endif @@ -208,7 +208,7 @@ static void smbios_write_type4_dm(struct smbios_type4 *t) t->processor_version = smbios_add_string(t->eos, name); }
-static int smbios_write_type4(ulong *current, int handle) +static int smbios_write_type4(ulong *current, int handle, ofnode node) { struct smbios_type4 *t; int len = sizeof(struct smbios_type4); @@ -217,7 +217,7 @@ static int smbios_write_type4(ulong *current, int handle) memset(t, 0, sizeof(struct smbios_type4)); fill_smbios_header(t, SMBIOS_PROCESSOR_INFORMATION, len, handle); t->processor_type = SMBIOS_PROCESSOR_TYPE_CENTRAL; - smbios_write_type4_dm(t); + smbios_write_type4_dm(t, node); t->status = SMBIOS_PROCESSOR_STATUS_ENABLED; t->processor_upgrade = SMBIOS_PROCESSOR_UPGRADE_NONE; t->l1_cache_handle = 0xffff; @@ -232,7 +232,7 @@ static int smbios_write_type4(ulong *current, int handle) return len; }
-static int smbios_write_type32(ulong *current, int handle) +static int smbios_write_type32(ulong *current, int handle, ofnode node) { struct smbios_type32 *t; int len = sizeof(struct smbios_type32); @@ -247,7 +247,7 @@ static int smbios_write_type32(ulong *current, int handle) return len; }
-static int smbios_write_type127(ulong *current, int handle) +static int smbios_write_type127(ulong *current, int handle, ofnode node) { struct smbios_type127 *t; int len = sizeof(struct smbios_type127); @@ -274,7 +274,9 @@ static smbios_write_type smbios_write_funcs[] = {
ulong write_smbios_table(ulong addr) { + ofnode node = ofnode_null(); struct smbios_entry *se; + struct udevice *dev; ulong table_addr; ulong tables; int len = 0; @@ -284,6 +286,10 @@ ulong write_smbios_table(ulong addr) int isize; int i;
+ uclass_first_device(UCLASS_BOARD, &dev); + if (dev) + node = dev_read_subnode(dev, "smbios"); + /* 16 byte align the table address */ addr = ALIGN(addr, 16);
@@ -296,7 +302,7 @@ ulong write_smbios_table(ulong addr)
/* populate minimum required tables */ for (i = 0; i < ARRAY_SIZE(smbios_write_funcs); i++) { - int tmp = smbios_write_funcs[i]((ulong *)&addr, handle++); + int tmp = smbios_write_funcs[i]((ulong *)&addr, handle++, node);
max_struct_size = max(max_struct_size, tmp); len += tmp;
Support a way to put SMBIOS properties in the device tree. These can be placed in a 'board' device in an 'smbios' subnode.
lib/smbios.c | 55 ++++++++++++++++++++++++++++++++++++++++++++++------ 1 file changed, 49 insertions(+), 6 deletions(-)
diff --git a/lib/smbios.c b/lib/smbios.c index dd4b8841d6c..1b5f43ef989 100644 --- a/lib/smbios.c +++ b/lib/smbios.c @@ -52,6 +52,42 @@ static int smbios_add_string(char *start, const char *str) } }
+/** + * smbios_add_prop_default() - Add a property from the device tree or default + * + * @start: string area start address + * @node: node containing the information to write (ofnode_null() if none) + * @prop: property to write + * @def: default string if the node has no such property + * @return 0 if not found, else SMBIOS string number (1 or more) + */ +static int smbios_add_prop_default(char *start, ofnode node, const char *prop, + const char *def) +{ + const char *str; + + str = ofnode_read_string(node, prop); + if (str) + return smbios_add_string(start, str); + else if (def) + return smbios_add_string(start, def); + + return 0; +} + +/** + * smbios_add_prop() - Add a property from the device tree + * + * @start: string area start address + * @node: node containing the information to write (ofnode_null() if none) + * @prop: property to write + * @return 0 if not found, else SMBIOS string number (1 or more) + */ +static int smbios_add_prop(char *start, ofnode node, const char *prop) +{ + return smbios_add_prop_default(start, node, prop, NULL); +} + /** * smbios_string_table_len() - compute the string area size * @@ -120,11 +156,15 @@ static int smbios_write_type1(ulong *current, int handle, ofnode node) t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type1)); fill_smbios_header(t, SMBIOS_SYSTEM_INFORMATION, len, handle); - t->manufacturer = smbios_add_string(t->eos, CONFIG_SMBIOS_MANUFACTURER); - t->product_name = smbios_add_string(t->eos, CONFIG_SMBIOS_PRODUCT_NAME); + t->manufacturer = smbios_add_prop_default(t->eos, node, "manufactuer", + CONFIG_SMBIOS_MANUFACTURER); + t->product_name = smbios_add_prop_default(t->eos, node, "product", + CONFIG_SMBIOS_PRODUCT_NAME); if (serial_str) { - strncpy((char *)t->uuid, serial_str, sizeof(t->uuid)); t->serial_number = smbios_add_string(t->eos, serial_str); + strncpy((char *)t->uuid, serial_str, sizeof(t->uuid)); + } else { + t->serial_number = smbios_add_prop(t->eos, node, "serial"); }
len = t->length + smbios_string_table_len(t->eos); @@ -142,8 +182,10 @@ static int smbios_write_type2(ulong *current, int handle, ofnode node) t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type2)); fill_smbios_header(t, SMBIOS_BOARD_INFORMATION, len, handle); - t->manufacturer = smbios_add_string(t->eos, CONFIG_SMBIOS_MANUFACTURER); - t->product_name = smbios_add_string(t->eos, CONFIG_SMBIOS_PRODUCT_NAME); + t->manufacturer = smbios_add_prop_default(t->eos, node, "manufactuer", + CONFIG_SMBIOS_MANUFACTURER); + t->product_name = smbios_add_prop_default(t->eos, node, "product", + CONFIG_SMBIOS_PRODUCT_NAME); t->feature_flags = SMBIOS_BOARD_FEATURE_HOSTING; t->board_type = SMBIOS_BOARD_MOTHERBOARD;
@@ -162,7 +204,8 @@ static int smbios_write_type3(ulong *current, int handle, ofnode node) t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type3)); fill_smbios_header(t, SMBIOS_SYSTEM_ENCLOSURE, len, handle); - t->manufacturer = smbios_add_string(t->eos, CONFIG_SMBIOS_MANUFACTURER); + t->manufacturer = smbios_add_prop_default(t->eos, node, "manufactuer", + CONFIG_SMBIOS_MANUFACTURER); t->chassis_type = SMBIOS_ENCLOSURE_DESKTOP; t->bootup_state = SMBIOS_STATE_SAFE; t->power_supply_state = SMBIOS_STATE_SAFE;
The current tables only support a subset of the available fields defined by the SMBIOS spec. Add a few more.
lib/smbios.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/lib/smbios.c b/lib/smbios.c index 1b5f43ef989..f3bbf7f02c8 100644 --- a/lib/smbios.c +++ b/lib/smbios.c @@ -160,12 +160,15 @@ static int smbios_write_type1(ulong *current, int handle, ofnode node) CONFIG_SMBIOS_MANUFACTURER); t->product_name = smbios_add_prop_default(t->eos, node, "product", CONFIG_SMBIOS_PRODUCT_NAME); + t->version = smbios_add_prop(t->eos, node, "version"); if (serial_str) { t->serial_number = smbios_add_string(t->eos, serial_str); strncpy((char *)t->uuid, serial_str, sizeof(t->uuid)); } else { t->serial_number = smbios_add_prop(t->eos, node, "serial"); } + t->sku_number = smbios_add_prop(t->eos, node, "sku"); + t->family = smbios_add_prop(t->eos, node, "family");
len = t->length + smbios_string_table_len(t->eos); *current += len; @@ -186,6 +189,7 @@ static int smbios_write_type2(ulong *current, int handle, ofnode node) CONFIG_SMBIOS_MANUFACTURER); t->product_name = smbios_add_prop_default(t->eos, node, "product", CONFIG_SMBIOS_PRODUCT_NAME); + t->asset_tag_number = smbios_add_prop(t->eos, node, "asset-tag"); t->feature_flags = SMBIOS_BOARD_FEATURE_HOSTING; t->board_type = SMBIOS_BOARD_MOTHERBOARD;
Add information about how to set SMBIOS properties using the devicetree.
doc/arch/x86.rst | 8 +++++ doc/device-tree-bindings/board/board_x86.txt | 36 ++++++++++++++++++++ 2 files changed, 44 insertions(+) create mode 100644 doc/device-tree-bindings/board/board_x86.txt
diff --git a/doc/arch/x86.rst b/doc/arch/x86.rst index c6b70ce61a3..45f9ba308c7 100644 --- a/doc/arch/x86.rst +++ b/doc/arch/x86.rst @@ -740,6 +740,14 @@ Note that this is a development feature only. It is not intended for use in production environments. Also it is not currently part of the automated tests so may break in the future.
+SMBIOS tables +------------- + +To generate SMBIOS tables in U-Boot, for use by the OS, enable the +CONFIG_GENERATE_SMBIOS_TABLE option. The easiest way to provide the values to +use is via the device tree. For details see +device-tree-bindings/board/board_x86.txt + TODO List --------- - Audio diff --git a/doc/device-tree-bindings/board/board_x86.txt b/doc/device-tree-bindings/board/board_x86.txt new file mode 100644 index 00000000000..3766751896a --- /dev/null +++ b/doc/device-tree-bindings/board/board_x86.txt @@ -0,0 +1,36 @@ +x86 board driver +================ + +This driver allows providing board-specific features such as power control +GPIOs. In addition, the SMBIOS values can be specified in the device tree, +as below: + +An optional 'smbios' subnode can be used to provide these properties. + +Optional properties: + - manufacturer: Product manufacturer for system / baseboard + - product: Product name + - version: Product version string + - serial: Serial number for system (note that this can be overridden by + the serial# environment variable) + - sku: Product SKU (Stock-Keeping Unit) + - family: Product family + - asset-tag: Asset tag for the motherboard, sometimes used in organisations + to track devices + + +Example: + + board { + compatible = "google,coral"; + + smbios { + manufacturer = "Google"; + product = "Coral"; + version = "rev2"; + serial = "123456789"; + sku = "sku3"; + family = "Google_Coral"; + asset-tag = "ABC123"; + }; + };
