[U-Boot] [PATCH 1/2] cmd_fat: add FAT write command
Once CONFIG_FAT_WRITE is defined, users can invoke 'fatwrite' command that saves data in RAM as a FAT file.
This patch also removes compile error after patch of 'fs/fat: Fix FAT detection to support non-DOS partition tables'.
Signed-off-by: Donggeun Kim <dg77.kim <at> samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park <at> samsung.com> --- common/cmd_fat.c | 57 ++++++++++++++++++++++++++++++++++++++++++++++++++++ fs/fat/fat_write.c | 20 +++++++----------- 2 files changed, 65 insertions(+), 12 deletions(-)
diff --git a/common/cmd_fat.c b/common/cmd_fat.c index 0220494..fef1c82 100644 --- a/common/cmd_fat.c +++ b/common/cmd_fat.c @@ -184,3 +184,60 @@ U_BOOT_CMD( "<interface> <dev[:part]>\n" " - print information about filesystem from 'dev' on 'interface'" ); + +#ifdef CONFIG_FAT_WRITE +static int do_fat_fswrite(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + long size; + unsigned long addr; + unsigned long count; + block_dev_desc_t *dev_desc = NULL; + int dev = 0; + int part = 1; + char *ep; + + if (argc < 5) + return cmd_usage(cmdtp); + + dev = (int)simple_strtoul(argv[2], &ep, 16); + dev_desc = get_dev(argv[1], dev); + if (dev_desc == NULL) { + puts("\n** Invalid boot device **\n"); + return 1; + } + if (*ep) { + if (*ep != ':') { + puts("\n** Invalid boot device, use `dev[:part]' **\n"); + return 1; + } + part = (int)simple_strtoul(++ep, NULL, 16); + } + if (fat_register_device(dev_desc, part) != 0) { + printf("\n** Unable to use %s %d:%d for fatwrite **\n", + argv[1], dev, part); + return 1; + } + addr = simple_strtoul(argv[3], NULL, 16); + count = simple_strtoul(argv[5], NULL, 16); + + size = file_fat_write(argv[4], (void *)addr, count); + if (size == -1) { + printf("\n** Unable to write "%s" from %s %d:%d **\n", + argv[4], argv[1], dev, part); + return 1; + } + + printf("%ld bytes write\n", size); + + return 0; +} + +U_BOOT_CMD( + fatwrite, 6, 0, do_fat_fswrite, + "write file into a dos filesystem", + "<interface> <dev[:part]> <addr> <filename> <bytes>\n" + " - write file 'filename' from the address 'addr' in RAM\n" + " to 'dev' on 'interface'" +); +#endif diff --git a/fs/fat/fat_write.c b/fs/fat/fat_write.c index 3bfc1c4..16f8400 100644 --- a/fs/fat/fat_write.c +++ b/fs/fat/fat_write.c @@ -41,23 +41,19 @@ static void uppercase(char *str, int len) }
static int total_sector; -static int disk_write(__u32 startblock, __u32 getsize, __u8 *bufptr) +static int disk_write(__u32 block, __u32 nr_blocks, void *buf) { - if (cur_dev == NULL) + if (!cur_dev || !cur_dev->block_write) return -1;
- if (startblock + getsize > total_sector) { + if (cur_part_info.start + block + nr_blocks > + cur_part_info.start + total_sector) { printf("error: overflow occurs\n"); return -1; }
- startblock += part_offset; - - if (cur_dev->block_read) { - return cur_dev->block_write(cur_dev->dev, startblock, getsize, - (unsigned long *) bufptr); - } - return -1; + return cur_dev->block_write(cur_dev->dev, + cur_part_info.start + block, nr_blocks, buf); }
/* @@ -797,7 +793,7 @@ static int check_overflow(fsdata *mydata, __u32 clustnum, unsigned long size) if (size % mydata->sect_size) sect_num++;
- if (startsect + sect_num > total_sector) + if (startsect + sect_num > cur_part_info.start + total_sector) return -1;
return 0; @@ -947,7 +943,7 @@ static int do_fat_write(const char *filename, void *buffer,
total_sector = bs.total_sect; if (total_sector == 0) - total_sector = part_size; + total_sector = cur_part_info.size;
root_cluster = bs.root_cluster;
The following must be defined:
CONFIG_ENV_IS_IN_FAT Enable this saving environment to FAT.
FAT_ENV_INTERFACE Interface the FAT resides on (e.g. mmc).
FAT_ENV_DEVICE The interface device number (e.g. 0 for mmc0)
FAT_ENV_PART The device part (e.g. 1 for mmc0:1)
FAT_ENV_FILE The filename of the environment file. --- common/Makefile | 1 + common/cmd_nvedit.c | 3 +- common/env_fat.c | 158 +++++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 161 insertions(+), 1 deletions(-) create mode 100644 common/env_fat.c
diff --git a/common/Makefile b/common/Makefile index 2a31c62..7fcb108 100644 --- a/common/Makefile +++ b/common/Makefile @@ -54,6 +54,7 @@ COBJS-$(CONFIG_ENV_IS_IN_NVRAM) += env_embedded.o COBJS-$(CONFIG_ENV_IS_IN_FLASH) += env_flash.o COBJS-$(CONFIG_ENV_IS_IN_MG_DISK) += env_mgdisk.o COBJS-$(CONFIG_ENV_IS_IN_MMC) += env_mmc.o +COBJS-$(CONFIG_ENV_IS_IN_FAT) += env_fat.o COBJS-$(CONFIG_ENV_IS_IN_NAND) += env_nand.o COBJS-$(CONFIG_ENV_IS_IN_NVRAM) += env_nvram.o COBJS-$(CONFIG_ENV_IS_IN_ONENAND) += env_onenand.o diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index 22f9821..b1494dc 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -61,13 +61,14 @@ DECLARE_GLOBAL_DATA_PTR; !defined(CONFIG_ENV_IS_IN_DATAFLASH) && \ !defined(CONFIG_ENV_IS_IN_MG_DISK) && \ !defined(CONFIG_ENV_IS_IN_MMC) && \ + !defined(CONFIG_ENV_IS_IN_FAT) && \ !defined(CONFIG_ENV_IS_IN_NAND) && \ !defined(CONFIG_ENV_IS_IN_NVRAM) && \ !defined(CONFIG_ENV_IS_IN_ONENAND) && \ !defined(CONFIG_ENV_IS_IN_SPI_FLASH) && \ !defined(CONFIG_ENV_IS_NOWHERE) # error Define one of CONFIG_ENV_IS_IN_{EEPROM|FLASH|DATAFLASH|ONENAND|\ -SPI_FLASH|MG_DISK|NVRAM|MMC} or CONFIG_ENV_IS_NOWHERE +SPI_FLASH|MG_DISK|NVRAM|MMC|FAT} or CONFIG_ENV_IS_NOWHERE #endif
#define XMK_STR(x) #x diff --git a/common/env_fat.c b/common/env_fat.c new file mode 100644 index 0000000..a1bba3c --- /dev/null +++ b/common/env_fat.c @@ -0,0 +1,158 @@ +/* + * (c) Copyright 2011 by Tigris Elektronik GmbH + * + * Author: + * Maximilian Schwerin mvs@tigris.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* #define DEBUG */ + +#include <common.h> + +#include <command.h> +#include <environment.h> +#include <linux/stddef.h> +#include <malloc.h> +#include <search.h> +#include <errno.h> +#include <fat.h> +#include <mmc.h> + +char *env_name_spec = "FAT"; + +env_t *env_ptr; + +DECLARE_GLOBAL_DATA_PTR; + +uchar env_get_char_spec(int index) +{ + return *((uchar *)(gd->env_addr + index)); +} + +int env_init(void) +{ + /* use default */ + gd->env_addr = (ulong)&default_environment[0]; + gd->env_valid = 1; + + return 0; +} + +#ifdef CONFIG_CMD_SAVEENV +int saveenv(void) +{ + env_t env_new; + ssize_t len; + char *res; + block_dev_desc_t *dev_desc = NULL; + int dev = FAT_ENV_DEVICE; + int part = FAT_ENV_PART; + + res = (char *)&env_new.data; + len = hexport_r(&env_htab, '\0', &res, ENV_SIZE, 0, NULL); + if (len < 0) { + error("Cannot export environment: errno = %d\n", errno); + return 1; + } + +#ifdef CONFIG_MMC + if (strcmp (FAT_ENV_INTERFACE, "mmc") == 0) { + struct mmc *mmc = find_mmc_device(dev); + + if (!mmc) { + printf("no mmc device at slot %x\n", dev); + return 1; + } + + mmc->has_init = 0; + mmc_init(mmc); + } +#endif /* CONFIG_MMC */ + + dev_desc = get_dev(FAT_ENV_INTERFACE, dev); + if (dev_desc == NULL) { + printf("Failed to find %s%d\n", + FAT_ENV_INTERFACE, dev); + return 1; + } + if (fat_register_device(dev_desc, part) != 0) { + printf("Failed to register %s%d:%d\n", + FAT_ENV_INTERFACE, dev, part); + return 1; + } + + env_new.crc = crc32(0, env_new.data, ENV_SIZE); + if (file_fat_write(FAT_ENV_FILE, (void *)&env_new, sizeof(env_t)) == -1) { + printf("\n** Unable to write "%s" from %s%d:%d **\n", + FAT_ENV_FILE, FAT_ENV_INTERFACE, dev, part); + return 1; + } + + puts("done\n"); + return 0; +} +#endif /* CONFIG_CMD_SAVEENV */ + +void env_relocate_spec(void) +{ + char buf[CONFIG_ENV_SIZE]; + block_dev_desc_t *dev_desc = NULL; + int dev = FAT_ENV_DEVICE; + int part = FAT_ENV_PART; + +#ifdef CONFIG_MMC + if (strcmp (FAT_ENV_INTERFACE, "mmc") == 0) { + struct mmc *mmc = find_mmc_device(dev); + + if (!mmc) { + printf("no mmc device at slot %x\n", dev); + set_default_env(NULL); + return; + } + + mmc->has_init = 0; + mmc_init(mmc); + } +#endif /* CONFIG_MMC */ + + dev_desc = get_dev(FAT_ENV_INTERFACE, dev); + if (dev_desc == NULL) { + printf("Failed to find %s%d\n", + FAT_ENV_INTERFACE, dev); + set_default_env(NULL); + return; + } + if (fat_register_device(dev_desc, part) != 0) { + printf("Failed to register %s%d:%d\n", + FAT_ENV_INTERFACE, dev, part); + set_default_env(NULL); + return; + } + + if (file_fat_read(FAT_ENV_FILE, (unsigned char *)&buf, CONFIG_ENV_SIZE) == -1) { + printf("\n** Unable to read "%s" from %s%d:%d **\n", + FAT_ENV_FILE, FAT_ENV_INTERFACE, dev, part); + set_default_env(NULL); + return; + } + + env_import(buf, 1); +}
Dear Maximilian Schwerin,
Applied, thanks.
As your SoB was missing, I signed it. I also removed the dead "/* #define DEBUG */" line.
Dear Maximilian,
Thanks for picking up this patch. A few minor comments:
Please add documentation for the new CONFIG_FAT_WRITE config option to the top level README.
Which compile error would that be? I am not aware of any such error.
If ther eis one, the fix should be in a separate patch; otherwise this comment should be removed.
Thanks!
This patch removes compile errors introduced by 'fs/fat: Fix FAT detection to support non-DOS partition tables'.
This patch was originally part of
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/121847
Reported-by: Donggeun Kim dg77.kim@samsung.com Cc: Kyungmin Park kyungmin.park@samsung.com --- fs/fat/fat_write.c | 20 ++++++++------------ 1 files changed, 8 insertions(+), 12 deletions(-)
Fix: fat_write.c: In function 'find_directory_entry': fat_write.c:826:8: warning: variable 'prevcksum' set but not used [-Wunused-but-set-variable] fat_write.c: In function 'do_fat_write': fat_write.c:933:6: warning: variable 'root_cluster' set but not used [-Wunused-but-set-variable] fat_write.c:925:12: warning: variable 'slotptr' set but not used [-Wunused-but-set-variable]
Signed-off-by: Anatolij Gustschin agust@denx.de Cc: Donggeun Kim dg77.kim@samsung.com --- fs/fat/fat_write.c | 10 +--------- 1 files changed, 1 insertions(+), 9 deletions(-)
diff --git a/fs/fat/fat_write.c b/fs/fat/fat_write.c index 16f8400..a6181e7 100644 --- a/fs/fat/fat_write.c +++ b/fs/fat/fat_write.c @@ -823,7 +823,6 @@ static dir_entry *empty_dentptr; static dir_entry *find_directory_entry(fsdata *mydata, int startsect, char *filename, dir_entry *retdent, __u32 start) { - __u16 prevcksum = 0xffff; __u32 curclust = (startsect - mydata->data_begin) / mydata->clust_size;
debug("get_dentfromdir: %s\n", filename); @@ -857,8 +856,6 @@ static dir_entry *find_directory_entry(fsdata *mydata, int startsect, #ifdef CONFIG_SUPPORT_VFAT if ((dentptr->attr & ATTR_VFAT) && (dentptr->name[0] & LAST_LONG_ENTRY_MASK)) { - prevcksum = - ((dir_slot *)dentptr)->alias_checksum; get_long_file_name(mydata, curclust, get_dentfromdir_block, &dentptr, l_name); @@ -922,7 +919,6 @@ static int do_fat_write(const char *filename, void *buffer, unsigned long size) { dir_entry *dentptr, *retdent; - dir_slot *slotptr; __u32 startsect; __u32 start_cluster; boot_sector bs; @@ -930,7 +926,7 @@ static int do_fat_write(const char *filename, void *buffer, fsdata datablock; fsdata *mydata = &datablock; int cursect; - int root_cluster, ret = -1, name_len; + int ret = -1, name_len; char l_filename[VFAT_MAXLEN_BYTES]; int write_size = size;
@@ -945,8 +941,6 @@ static int do_fat_write(const char *filename, void *buffer, if (total_sector == 0) total_sector = cur_part_info.size;
- root_cluster = bs.root_cluster; - if (mydata->fatsize == 32) mydata->fatlength = bs.fat32_length; else @@ -1047,8 +1041,6 @@ static int do_fat_write(const char *filename, void *buffer, goto exit; } } else { - slotptr = (dir_slot *)empty_dentptr; - /* Set short name to set alias checksum field in dir_slot */ set_name(empty_dentptr, filename); fill_dir_slot(mydata, &empty_dentptr, filename);
I'll push this patch through my staging branch if nobody objects.
Thanks, Anatolij
Hello Maximilian,
Applied to u-boot-staging/agust@denx.de after fixing commit log and all attribution tags.
NOTE: When submitting patches from other people you should preserve their authorship and SoB and add your SoB.
Thanks, Anatolij
Reported-by: Donggeun Kim dg77.kim@samsung.com Cc: Kyungmin Park kyungmin.park@samsung.com --- README | 8 +++++- common/cmd_fat.c | 57 ++++++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 63 insertions(+), 2 deletions(-)
diff --git a/README b/README index 1f8bd20..fe077b9 100644 --- a/README +++ b/README @@ -1250,8 +1250,12 @@ The following options need to be configured:
- FAT(File Allocation Table) filesystem write function support: CONFIG_FAT_WRITE - Support for saving memory data as a file - in FAT formatted partition + + Define this to enable support for saving memory data as a + file in FAT formatted partition. + + This will also enable the command "fatwrite" enabling the + user to write files to FAT.
- Keyboard Support: CONFIG_ISA_KEYBOARD diff --git a/common/cmd_fat.c b/common/cmd_fat.c index 0220494..fef1c82 100644 --- a/common/cmd_fat.c +++ b/common/cmd_fat.c @@ -184,3 +184,60 @@ U_BOOT_CMD( "<interface> <dev[:part]>\n" " - print information about filesystem from 'dev' on 'interface'" ); + +#ifdef CONFIG_FAT_WRITE +static int do_fat_fswrite(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + long size; + unsigned long addr; + unsigned long count; + block_dev_desc_t *dev_desc = NULL; + int dev = 0; + int part = 1; + char *ep; + + if (argc < 5) + return cmd_usage(cmdtp); + + dev = (int)simple_strtoul(argv[2], &ep, 16); + dev_desc = get_dev(argv[1], dev); + if (dev_desc == NULL) { + puts("\n** Invalid boot device **\n"); + return 1; + } + if (*ep) { + if (*ep != ':') { + puts("\n** Invalid boot device, use `dev[:part]' **\n"); + return 1; + } + part = (int)simple_strtoul(++ep, NULL, 16); + } + if (fat_register_device(dev_desc, part) != 0) { + printf("\n** Unable to use %s %d:%d for fatwrite **\n", + argv[1], dev, part); + return 1; + } + addr = simple_strtoul(argv[3], NULL, 16); + count = simple_strtoul(argv[5], NULL, 16); + + size = file_fat_write(argv[4], (void *)addr, count); + if (size == -1) { + printf("\n** Unable to write "%s" from %s %d:%d **\n", + argv[4], argv[1], dev, part); + return 1; + } + + printf("%ld bytes write\n", size); + + return 0; +} + +U_BOOT_CMD( + fatwrite, 6, 0, do_fat_fswrite, + "write file into a dos filesystem", + "<interface> <dev[:part]> <addr> <filename> <bytes>\n" + " - write file 'filename' from the address 'addr' in RAM\n" + " to 'dev' on 'interface'" +); +#endif
Applied to u-boot-staging/agust@denx.de after fixing attribution tags and a typo. Thanks.
Hmm, emails to dg77.kim@samsung.com address are now rejected: Recipient address rejected: User unknown (in reply to RCPT TO command)
- printf("%ld bytes write\n", size);
typo fixed, s/write/written/
Thanks, Anatolij
FYI: Now Mr. Kim is left the company. So if any issue and codes from Mr. Kim, then let me follow up.
Thank you, Kyungmin Park
Thanks, Anatolij _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
On Mon, 26 Mar 2012 09:34:07 +0900 Kyungmin Park kyungmin.park@samsung.com wrote: ...
Thanks for the info. When compiling the FAT write code with newer GCC 4.6.1 I've seen some warnings and fixed them by this patch [1]. Could you please look at this patch and if it is okay, then send your Acked-by?
Thanks, Anatolij
-----Ursprüngliche Nachricht----- Von: Anatolij Gustschin [mailto:agust@denx.de] Gesendet: Montag, 26. März 2012 09:13 An: Kyungmin Park Cc: Maximilian Schwerin; u-boot@lists.denx.de Betreff: Re: [U-Boot] [PATCH 2/2] cmd_fat: add FAT write command
RCPT TO command)
Thanks, Anatolij
Acked-by: Maximilian Schwerin mvs@tigris.de
Acked-by: Kyungmin Park kyungmin.park@samsung.com
Maybe some debug codes are included.
Thanks, Anatolij
[1] http://patchwork.ozlabs.org/patch/148551/ _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
participants (5)
Anatolij Gustschin
Kyungmin Park
Maximilian Schwerin
Maximilian Schwerin
