[PATCH v3] ARM: dts: imx: Add support for Data Modul i.MX8M Mini eDM SBC
Add support for Data Modul i.MX8M Mini eDM SBC board. This is an evaluation board for various custom display units. Currently supported are serial console, ethernet, eMMC, SD, SPI NOR, USB host and USB OTG.
Reviewed-by: Fabio Estevam festevam@denx.de Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de --- V2: - Disable UHS mode support in SPL, the overhead incured by bringing up UHS mode in SPL does not make sense for loading less than 1 MiB u-boot.itb. - Select primary boot device based on boot device indicated by BootROM, either eMMC or SD boot device is supported. Always select the other boot device, SD or eMMC, as fallback boot device. - Set 'devnum' environment variable based on boot device indicated by BootROM unless the 'devnum' variable is already set. This way it is possible to boot from the same boot media from which BootROM started U-Boot SPL and U-Boot SPL started U-Boot itself. - Add RB from Fabio V3: - Drop CONFIG_SYS_PROMPT_HUSH_PS2 and CONFIG_SYS_I2C_SPEED which were since converted to Kconfig --- arch/arm/dts/Makefile | 1 + .../dts/imx8mm-data-modul-edm-sbc-u-boot.dtsi | 116 ++ arch/arm/dts/imx8mm-data-modul-edm-sbc.dts | 996 +++++++++ arch/arm/mach-imx/imx8m/Kconfig | 8 + board/data_modul/imx8mm_edm_sbc/Kconfig | 12 + board/data_modul/imx8mm_edm_sbc/MAINTAINERS | 8 + board/data_modul/imx8mm_edm_sbc/Makefile | 13 + board/data_modul/imx8mm_edm_sbc/common.c | 37 + .../imx8mm_data_modul_edm_sbc.c | 110 + board/data_modul/imx8mm_edm_sbc/imximage.cfg | 8 + .../data_modul/imx8mm_edm_sbc/lpddr4_timing.h | 14 + .../imx8mm_edm_sbc/lpddr4_timing_2G_32.c | 1845 +++++++++++++++++ .../imx8mm_edm_sbc/lpddr4_timing_4G_32.c | 1842 ++++++++++++++++ board/data_modul/imx8mm_edm_sbc/spl.c | 179 ++ configs/imx8mm_data_modul_edm_sbc_defconfig | 227 ++ include/configs/imx8mm_data_modul_edm_sbc.h | 130 ++ 16 files changed, 5546 insertions(+) create mode 100644 arch/arm/dts/imx8mm-data-modul-edm-sbc-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-data-modul-edm-sbc.dts create mode 100644 board/data_modul/imx8mm_edm_sbc/Kconfig create mode 100644 board/data_modul/imx8mm_edm_sbc/MAINTAINERS create mode 100644 board/data_modul/imx8mm_edm_sbc/Makefile create mode 100644 board/data_modul/imx8mm_edm_sbc/common.c create mode 100644 board/data_modul/imx8mm_edm_sbc/imx8mm_data_modul_edm_sbc.c create mode 100644 board/data_modul/imx8mm_edm_sbc/imximage.cfg create mode 100644 board/data_modul/imx8mm_edm_sbc/lpddr4_timing.h create mode 100644 board/data_modul/imx8mm_edm_sbc/lpddr4_timing_2G_32.c create mode 100644 board/data_modul/imx8mm_edm_sbc/lpddr4_timing_4G_32.c create mode 100644 board/data_modul/imx8mm_edm_sbc/spl.c create mode 100644 configs/imx8mm_data_modul_edm_sbc_defconfig create mode 100644 include/configs/imx8mm_data_modul_edm_sbc.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index cd9a820f956..f6034f0fcf9 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -900,6 +900,7 @@ dtb-$(CONFIG_ARCH_IMX8ULP) += \ imx8ulp-evk.dtb
dtb-$(CONFIG_ARCH_IMX8M) += \ + imx8mm-data-modul-edm-sbc.dtb \ imx8mm-evk.dtb \ imx8mm-icore-mx8mm-ctouch2.dtb \ imx8mm-icore-mx8mm-edimm2.2.dtb \ diff --git a/arch/arm/dts/imx8mm-data-modul-edm-sbc-u-boot.dtsi b/arch/arm/dts/imx8mm-data-modul-edm-sbc-u-boot.dtsi new file mode 100644 index 00000000000..184c30ab4a7 --- /dev/null +++ b/arch/arm/dts/imx8mm-data-modul-edm-sbc-u-boot.dtsi @@ -0,0 +1,116 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2022 Marek Vasut marex@denx.de + */ + +#include "imx8mm-u-boot.dtsi" + +/ { + aliases { + eeprom0 = &eeprom; + mmc0 = &usdhc3; /* eMMC */ + mmc1 = &usdhc2; /* MicroSD */ + }; + + config { + dmo,ram-coding-gpios = <&gpio2 8 0>, <&gpio2 1 0>, <&gpio2 0 0>; + }; + + wdt-reboot { + compatible = "wdt-reboot"; + wdt = <&wdog1>; + u-boot,dm-spl; + }; +}; + +&buck4_reg { + u-boot,dm-spl; +}; + +&buck5_reg { + u-boot,dm-spl; +}; + +&i2c1 { + u-boot,dm-spl; +}; + +&pinctrl_hog_sbc { + u-boot,dm-spl; +}; + +&pinctrl_i2c1 { + u-boot,dm-spl; +}; + +&pinctrl_i2c1_gpio { + u-boot,dm-spl; +}; + +&pinctrl_pmic { + u-boot,dm-spl; +}; + +&pinctrl_uart3 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc2 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc3 { + u-boot,dm-spl; +}; + +&pmic { + u-boot,dm-spl; + + regulators { + u-boot,dm-spl; + }; +}; + +&gpio1 { + u-boot,dm-spl; +}; + +&gpio2 { + u-boot,dm-spl; +}; + +&gpio3 { + u-boot,dm-spl; +}; + +&gpio4 { + u-boot,dm-spl; +}; + +&gpio5 { + u-boot,dm-spl; +}; + +&uart3 { + u-boot,dm-spl; +}; + +&usbotg1 { + dr_mode = "peripheral"; +}; + +&usdhc2 { + u-boot,dm-spl; + sd-uhs-sdr104; + sd-uhs-ddr50; +}; + +&usdhc3 { + u-boot,dm-spl; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; +}; + +&wdog1 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/imx8mm-data-modul-edm-sbc.dts b/arch/arm/dts/imx8mm-data-modul-edm-sbc.dts new file mode 100644 index 00000000000..154116d01c9 --- /dev/null +++ b/arch/arm/dts/imx8mm-data-modul-edm-sbc.dts @@ -0,0 +1,996 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright 2022 Marek Vasut marex@denx.de + */ + +/dts-v1/; + +#include <dt-bindings/net/qca-ar803x.h> +#include <dt-bindings/phy/phy-imx8-pcie.h> +#include "imx8mm.dtsi" + +/ { + model = "Data Modul i.MX8M Mini eDM SBC"; + compatible = "dmo,imx8mm-data-modul-edm-sbc", "fsl,imx8mm"; + + aliases { + rtc0 = &rtc; + rtc1 = &snvs_rtc; + }; + + chosen { + stdout-path = &uart3; + }; + + memory@40000000 { + device_type = "memory"; + /* There are 1/2/4 GiB options, adjusted by bootloader. */ + reg = <0x0 0x40000000 0 0x40000000>; + }; + + backlight: backlight { + compatible = "pwm-backlight"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_panel_backlight>; + brightness-levels = <0 1 10 20 30 40 50 60 70 75 80 90 100>; + default-brightness-level = <7>; + enable-gpios = <&gpio3 0 GPIO_ACTIVE_HIGH>; + pwms = <&pwm1 0 5000000>; + /* Disabled by default, unless display board plugged in. */ + status = "disabled"; + }; + + clk_xtal25: clk-xtal25 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <25000000>; + }; + + panel: panel { + backlight = <&backlight>; + power-supply = <®_panel_vcc>; + /* Disabled by default, unless display board plugged in. */ + status = "disabled"; + }; + + reg_panel_vcc: regulator-panel-vcc { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_panel_vcc_reg>; + regulator-name = "PANEL_VCC"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio3 6 0>; + enable-active-high; + /* Disabled by default, unless display board plugged in. */ + status = "disabled"; + }; + + reg_usdhc2_vcc: regulator-usdhc2-vcc { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc2_vcc_reg>; + regulator-name = "V_3V3_SD"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio2 19 0>; + enable-active-high; + }; + + watchdog-gpio { + /* TPS3813 */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_watchdog_gpio>; + compatible = "linux,wdt-gpio"; + always-enabled; + gpios = <&gpio1 8 GPIO_ACTIVE_HIGH>; + hw_algo = "level"; + /* Reset triggers in 2..3 seconds */ + hw_margin_ms = <1500>; + /* Disabled by default */ + status = "disabled"; + }; +}; + +&A53_0 { + cpu-supply = <&buck2_reg>; +}; + +&A53_1 { + cpu-supply = <&buck2_reg>; +}; + +&A53_2 { + cpu-supply = <&buck2_reg>; +}; + +&A53_3 { + cpu-supply = <&buck2_reg>; +}; + +&ddrc { + operating-points-v2 = <&ddrc_opp_table>; + + ddrc_opp_table: opp-table { + compatible = "operating-points-v2"; + + opp-25M { + opp-hz = /bits/ 64 <25000000>; + }; + + opp-100M { + opp-hz = /bits/ 64 <100000000>; + }; + + opp-750M { + opp-hz = /bits/ 64 <750000000>; + }; + }; +}; + +&ecspi1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ecspi1>; + cs-gpios = <&gpio5 9 GPIO_ACTIVE_LOW>; + status = "okay"; + + flash@0 { /* W25Q128FVSI */ + compatible = "jedec,spi-nor"; + m25p,fast-read; + spi-max-frequency = <50000000>; + reg = <0>; + }; +}; + +&ecspi2 { /* Feature connector SPI */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ecspi2>; + cs-gpios = <&gpio5 13 GPIO_ACTIVE_LOW>; + /* Disabled by default, unless feature board plugged in. */ + status = "disabled"; +}; + +&ecspi3 { /* Display connector SPI */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ecspi3>; + cs-gpios = <&gpio5 25 GPIO_ACTIVE_LOW>; + /* Disabled by default, unless display board plugged in. */ + status = "disabled"; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec1>; + phy-mode = "rgmii-id"; + phy-handle = <&fec1_phy>; + phy-supply = <&buck4_reg>; + fsl,magic-packet; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + /* Atheros AR8031 PHY */ + fec1_phy: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0>; + /* + * Dedicated ENET_WOL# signal is unused, the PHY + * can wake the SoC up via INT signal as well. + */ + interrupts-extended = <&gpio1 15 IRQ_TYPE_LEVEL_LOW>; + reset-gpios = <&gpio1 1 GPIO_ACTIVE_LOW>; + reset-assert-us = <10000>; + reset-deassert-us = <10000>; + qca,clk-out-frequency = <125000000>; + qca,clk-out-strength = <AR803X_STRENGTH_FULL>; + qca,keep-pll-enabled; + vddio-supply = <&vddio>; + + vddio: vddio-regulator { + regulator-name = "VDDIO"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + vddh: vddh-regulator { + regulator-name = "VDDH"; + }; + }; + }; +}; + +&gpio1 { + gpio-line-names = + "", "ENET_RST#", "WDOG_B#", "PMIC_INT#", + "", "M2-B_PCIE_RST#", "M2-B_PCIE_WAKE#", "RTC_IRQ#", + "WDOG_KICK#", "M2-B_PCIE_CLKREQ#", + "USB1_OTG_ID_3V3", "ENET_WOL#", + "", "", "", "ENET_INT#", + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", ""; +}; + +&gpio2 { + gpio-line-names = + "MEMCFG2", "MEMCFG1", "DSI_RESET_1V8#", "DSI_IRQ_1V8#", + "M2-B_FULL_CARD_PWROFF_1V8#", "EEPROM_WP_1V8#", + "PCIE_CLK_GEN_CLKPWRGD_PD_1V8#", "GRAPHICS_PRSNT_1V8#", + "MEMCFG0", "WDOG_EN", + "M2-B_W_DISABLE1_WWAN_1V8#", "M2-B_W_DISABLE2_GPS_1V8#", + "", "", "", "", + "", "", "", "SD2_RESET#", "", "", "", "", + "", "", "", "", "", "", "", ""; +}; + +&gpio3 { + gpio-line-names = + "BL_ENABLE_1V8", "PG_V_IN_VAR#", "", "", + "", "", "TFT_ENABLE_1V8", "GRAPHICS_GPIO0_1V8", + "CSI_PD_1V8", "CSI_RESET_1V8#", "", "", + "", "", "", "", + "", "", "", "M2-B_WAKE_WWAN_1V8#", + "M2-B_RESET_1V8#", "", "", "", + "", "", "", "", "", "", "", ""; +}; + +&gpio4 { + gpio-line-names = + "NC0", "NC1", "BOOTCFG0", "BOOTCFG1", + "BOOTCFG2", "BOOTCFG3", "BOOTCFG4", "BOOTCFG5", + "BOOTCFG6", "BOOTCFG7", "NC10", "NC11", + "BOOTCFG8", "BOOTCFG9", "BOOTCFG10", "BOOTCFG11", + "BOOTCFG12", "BOOTCFG13", "BOOTCFG14", "BOOTCFG15", + "NC20", "", "", "", + "", "CAN_INT#", "CAN_RST#", "GPIO4_IO27", + "DIS_USB_DN2", "", "", ""; +}; + +&gpio5 { + gpio-line-names = + "", "DIS_USB_DN1", "USBHUB_RESET#", "GPIO5_IO03", + "GPIO5_IO04", "", "", "", + "", "SPI1_CS#", "", "", + "", "SPI2_CS#", "I2C1_SCL_3V3", "I2C1_SDA_3V3", + "I2C2_SCL_3V3", "I2C2_SDA_3V3", "I2C3_SCL_3V3", "I2C3_SDA_3V3", + "I2C4_SCL_3V3", "I2C4_SDA_3V3", "", "", + "", "SPI3_CS#", "", "", "", "", "", ""; +}; + +&i2c1 { + /* IMX8MM ERRATA e7805 -- I2C is limited to 384 kHz due to SoC bug */ + clock-frequency = <100000>; + pinctrl-names = "default", "gpio"; + pinctrl-0 = <&pinctrl_i2c1>; + pinctrl-1 = <&pinctrl_i2c1_gpio>; + scl-gpios = <&gpio5 14 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; + sda-gpios = <&gpio5 15 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; + status = "okay"; + + pmic: pmic@4b { + compatible = "rohm,bd71847"; + reg = <0x4b>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pmic>; + interrupt-parent = <&gpio1>; + interrupts = <3 IRQ_TYPE_EDGE_FALLING>; + rohm,reset-snvs-powered; + + /* + * i.MX 8M Mini Data Sheet for Consumer Products + * 3.1.3 Operating ranges + * MIMX8MM4DVTLZAA + */ + regulators { + /* VDD_SOC */ + buck1_reg: BUCK1 { + regulator-name = "buck1"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <1250>; + }; + + /* VDD_ARM */ + buck2_reg: BUCK2 { + regulator-name = "buck2"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1050000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <1250>; + rohm,dvs-run-voltage = <1000000>; + rohm,dvs-idle-voltage = <950000>; + }; + + /* VDD_DRAM, BUCK5 */ + buck3_reg: BUCK3 { + regulator-name = "buck3"; + /* 1.5 GHz DDR bus clock */ + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1000000>; + regulator-boot-on; + regulator-always-on; + }; + + /* 3V3_VDD, BUCK6 */ + buck4_reg: BUCK4 { + regulator-name = "buck4"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + /* 1V8_VDD, BUCK7 */ + buck5_reg: BUCK5 { + regulator-name = "buck5"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + /* 1V1_NVCC_DRAM, BUCK8 */ + buck6_reg: BUCK6 { + regulator-name = "buck6"; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-boot-on; + regulator-always-on; + }; + + /* 1V8_NVCC_SNVS */ + ldo1_reg: LDO1 { + regulator-name = "ldo1"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + /* 0V8_VDD_SNVS */ + ldo2_reg: LDO2 { + regulator-name = "ldo2"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <800000>; + regulator-boot-on; + regulator-always-on; + }; + + /* 1V8_VDDA */ + ldo3_reg: LDO3 { + regulator-name = "ldo3"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + /* 0V9_VDD_PHY */ + ldo4_reg: LDO4 { + regulator-name = "ldo4"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + regulator-boot-on; + regulator-always-on; + }; + + /* 1V2_VDD_PHY */ + ldo6_reg: LDO6 { + regulator-name = "ldo6"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-boot-on; + regulator-always-on; + }; + }; + }; +}; + +&i2c2 { + /* IMX8MM ERRATA e7805 -- I2C is limited to 384 kHz due to SoC bug */ + clock-frequency = <320000>; + pinctrl-names = "default", "gpio"; + pinctrl-0 = <&pinctrl_i2c2>; + pinctrl-1 = <&pinctrl_i2c2_gpio>; + scl-gpios = <&gpio5 16 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; + sda-gpios = <&gpio5 17 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; + status = "okay"; + + usb-hub@2c { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb_hub>; + compatible = "microchip,usb2514bi"; + reg = <0x2c>; + individual-port-switching; + reset-gpios = <&gpio5 2 GPIO_ACTIVE_LOW>; + self-powered; + }; + + eeprom: eeprom@50 { + compatible = "atmel,24c32"; + reg = <0x50>; + pagesize = <32>; + }; + + rtc: rtc@68 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_rtc>; + compatible = "st,m41t62"; + reg = <0x68>; + interrupts-extended = <&gpio1 7 IRQ_TYPE_LEVEL_LOW>; + }; + + pcieclk: clk@6a { + compatible = "renesas,9fgv0241"; + reg = <0x6a>; + clocks = <&clk_xtal25>; + #clock-cells = <1>; + }; +}; + +&i2c3 { /* Display connector I2C */ + /* IMX8MM ERRATA e7805 -- I2C is limited to 384 kHz due to SoC bug */ + clock-frequency = <320000>; + pinctrl-names = "default", "gpio"; + pinctrl-0 = <&pinctrl_i2c3>; + pinctrl-1 = <&pinctrl_i2c3_gpio>; + scl-gpios = <&gpio5 18 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; + sda-gpios = <&gpio5 19 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; + status = "okay"; +}; + +&i2c4 { /* Feature connector I2C */ + /* IMX8MM ERRATA e7805 -- I2C is limited to 384 kHz due to SoC bug */ + clock-frequency = <320000>; + pinctrl-names = "default", "gpio"; + pinctrl-0 = <&pinctrl_i2c4>; + pinctrl-1 = <&pinctrl_i2c4_gpio>; + scl-gpios = <&gpio5 20 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; + sda-gpios = <&gpio5 21 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; + status = "okay"; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog_feature>, <&pinctrl_hog_misc>, + <&pinctrl_hog_panel>, <&pinctrl_hog_sbc>, + <&pinctrl_panel_expansion>; + + pinctrl_ecspi1: ecspi1-grp { + fsl,pins = < + MX8MM_IOMUXC_ECSPI1_SCLK_ECSPI1_SCLK 0x44 + MX8MM_IOMUXC_ECSPI1_MOSI_ECSPI1_MOSI 0x44 + MX8MM_IOMUXC_ECSPI1_MISO_ECSPI1_MISO 0x44 + MX8MM_IOMUXC_ECSPI1_SS0_GPIO5_IO9 0x40 + >; + }; + + pinctrl_ecspi2: ecspi2-grp { + fsl,pins = < + MX8MM_IOMUXC_ECSPI2_SCLK_ECSPI2_SCLK 0x44 + MX8MM_IOMUXC_ECSPI2_MOSI_ECSPI2_MOSI 0x44 + MX8MM_IOMUXC_ECSPI2_MISO_ECSPI2_MISO 0x44 + MX8MM_IOMUXC_ECSPI2_SS0_GPIO5_IO13 0x40 + >; + }; + + pinctrl_ecspi3: ecspi3-grp { + fsl,pins = < + MX8MM_IOMUXC_UART1_RXD_ECSPI3_SCLK 0x44 + MX8MM_IOMUXC_UART1_TXD_ECSPI3_MOSI 0x44 + MX8MM_IOMUXC_UART2_RXD_ECSPI3_MISO 0x44 + MX8MM_IOMUXC_UART2_TXD_GPIO5_IO25 0x40 + >; + }; + + pinctrl_fec1: fec1-grp { + fsl,pins = < + MX8MM_IOMUXC_ENET_MDC_ENET1_MDC 0x3 + MX8MM_IOMUXC_ENET_MDIO_ENET1_MDIO 0x3 + MX8MM_IOMUXC_ENET_RD0_ENET1_RGMII_RD0 0x91 + MX8MM_IOMUXC_ENET_RD1_ENET1_RGMII_RD1 0x91 + MX8MM_IOMUXC_ENET_RD2_ENET1_RGMII_RD2 0x91 + MX8MM_IOMUXC_ENET_RD3_ENET1_RGMII_RD3 0x91 + MX8MM_IOMUXC_ENET_RXC_ENET1_RGMII_RXC 0x91 + MX8MM_IOMUXC_ENET_RX_CTL_ENET1_RGMII_RX_CTL 0x91 + MX8MM_IOMUXC_ENET_TD0_ENET1_RGMII_TD0 0x1f + MX8MM_IOMUXC_ENET_TD1_ENET1_RGMII_TD1 0x1f + MX8MM_IOMUXC_ENET_TD2_ENET1_RGMII_TD2 0x1f + MX8MM_IOMUXC_ENET_TD3_ENET1_RGMII_TD3 0x1f + MX8MM_IOMUXC_ENET_TXC_ENET1_RGMII_TXC 0x1f + MX8MM_IOMUXC_ENET_TX_CTL_ENET1_RGMII_TX_CTL 0x1f + /* ENET_RST# */ + MX8MM_IOMUXC_GPIO1_IO01_GPIO1_IO1 0x6 + /* ENET_WOL# */ + MX8MM_IOMUXC_GPIO1_IO11_GPIO1_IO11 0x40000090 + /* ENET_INT# */ + MX8MM_IOMUXC_GPIO1_IO15_GPIO1_IO15 0x40000090 + >; + }; + + pinctrl_hog_feature: hog-feature-grp { + fsl,pins = < + /* GPIO4_IO27 */ + MX8MM_IOMUXC_SAI2_MCLK_GPIO4_IO27 0x40000006 + /* GPIO5_IO03 */ + MX8MM_IOMUXC_SPDIF_TX_GPIO5_IO3 0x40000006 + /* GPIO5_IO04 */ + MX8MM_IOMUXC_SPDIF_RX_GPIO5_IO4 0x40000006 + + /* CAN_INT# */ + MX8MM_IOMUXC_SAI2_TXC_GPIO4_IO25 0x40000090 + /* CAN_RST# */ + MX8MM_IOMUXC_SAI2_TXD0_GPIO4_IO26 0x26 + >; + }; + + pinctrl_hog_panel: hog-panel-grp { + fsl,pins = < + /* GRAPHICS_GPIO0_1V8 */ + MX8MM_IOMUXC_NAND_DATA01_GPIO3_IO7 0x26 + >; + }; + + pinctrl_hog_misc: hog-misc-grp { + fsl,pins = < + /* PG_V_IN_VAR# */ + MX8MM_IOMUXC_NAND_CE0_B_GPIO3_IO1 0x40000000 + /* CSI_PD_1V8 */ + MX8MM_IOMUXC_NAND_DATA02_GPIO3_IO8 0x0 + /* CSI_RESET_1V8# */ + MX8MM_IOMUXC_NAND_DATA03_GPIO3_IO9 0x0 + + /* DIS_USB_DN1 */ + MX8MM_IOMUXC_SAI3_TXD_GPIO5_IO1 0x0 + /* DIS_USB_DN2 */ + MX8MM_IOMUXC_SAI3_RXFS_GPIO4_IO28 0x0 + + /* EEPROM_WP_1V8# */ + MX8MM_IOMUXC_SD1_DATA3_GPIO2_IO5 0x100 + /* PCIE_CLK_GEN_CLKPWRGD_PD_1V8# */ + MX8MM_IOMUXC_SD1_DATA4_GPIO2_IO6 0x0 + /* GRAPHICS_PRSNT_1V8# */ + MX8MM_IOMUXC_SD1_DATA5_GPIO2_IO7 0x40000000 + + /* CLK_CCM_CLKO1_3V3 */ + MX8MM_IOMUXC_GPIO1_IO14_CCMSRCGPCMIX_CLKO1 0x10 + >; + }; + + pinctrl_hog_sbc: hog-sbc-grp { + fsl,pins = < + /* MEMCFG[0..2] straps */ + MX8MM_IOMUXC_SD1_DATA6_GPIO2_IO8 0x40000140 + MX8MM_IOMUXC_SD1_CMD_GPIO2_IO1 0x40000140 + MX8MM_IOMUXC_SD1_CLK_GPIO2_IO0 0x40000140 + + /* BOOT_CFG[0..15] straps */ + MX8MM_IOMUXC_SAI1_RXD0_GPIO4_IO2 0x40000000 + MX8MM_IOMUXC_SAI1_RXD1_GPIO4_IO3 0x40000000 + MX8MM_IOMUXC_SAI1_RXD2_GPIO4_IO4 0x40000000 + MX8MM_IOMUXC_SAI1_RXD3_GPIO4_IO5 0x40000000 + MX8MM_IOMUXC_SAI1_RXD4_GPIO4_IO6 0x40000000 + MX8MM_IOMUXC_SAI1_RXD5_GPIO4_IO7 0x40000000 + MX8MM_IOMUXC_SAI1_RXD6_GPIO4_IO8 0x40000000 + MX8MM_IOMUXC_SAI1_RXD7_GPIO4_IO9 0x40000000 + MX8MM_IOMUXC_SAI1_TXD0_GPIO4_IO12 0x40000000 + MX8MM_IOMUXC_SAI1_TXD1_GPIO4_IO13 0x40000000 + MX8MM_IOMUXC_SAI1_TXD2_GPIO4_IO14 0x40000000 + MX8MM_IOMUXC_SAI1_TXD3_GPIO4_IO15 0x40000000 + MX8MM_IOMUXC_SAI1_TXD4_GPIO4_IO16 0x40000000 + MX8MM_IOMUXC_SAI1_TXD5_GPIO4_IO17 0x40000000 + MX8MM_IOMUXC_SAI1_TXD6_GPIO4_IO18 0x40000000 + MX8MM_IOMUXC_SAI1_TXD7_GPIO4_IO19 0x40000000 + + /* Not connected pins */ + MX8MM_IOMUXC_SAI1_MCLK_GPIO4_IO20 0x0 + MX8MM_IOMUXC_SAI1_TXFS_GPIO4_IO10 0x0 + MX8MM_IOMUXC_SAI1_TXC_GPIO4_IO11 0x0 + MX8MM_IOMUXC_SAI1_RXFS_GPIO4_IO0 0x0 + MX8MM_IOMUXC_SAI1_RXC_GPIO4_IO1 0x0 + >; + }; + + pinctrl_i2c1: i2c1-grp { + fsl,pins = < + MX8MM_IOMUXC_I2C1_SCL_I2C1_SCL 0x40000084 + MX8MM_IOMUXC_I2C1_SDA_I2C1_SDA 0x40000084 + >; + }; + + pinctrl_i2c1_gpio: i2c1-gpio-grp { + fsl,pins = < + MX8MM_IOMUXC_I2C1_SCL_GPIO5_IO14 0x84 + MX8MM_IOMUXC_I2C1_SDA_GPIO5_IO15 0x84 + >; + }; + + pinctrl_i2c2: i2c2-grp { + fsl,pins = < + MX8MM_IOMUXC_I2C2_SCL_I2C2_SCL 0x40000084 + MX8MM_IOMUXC_I2C2_SDA_I2C2_SDA 0x40000084 + >; + }; + + pinctrl_i2c2_gpio: i2c2-gpio-grp { + fsl,pins = < + MX8MM_IOMUXC_I2C2_SCL_GPIO5_IO16 0x84 + MX8MM_IOMUXC_I2C2_SDA_GPIO5_IO17 0x84 + >; + }; + + pinctrl_i2c3: i2c3-grp { + fsl,pins = < + MX8MM_IOMUXC_I2C3_SCL_I2C3_SCL 0x40000084 + MX8MM_IOMUXC_I2C3_SDA_I2C3_SDA 0x40000084 + >; + }; + + pinctrl_i2c3_gpio: i2c3-gpio-grp { + fsl,pins = < + MX8MM_IOMUXC_I2C3_SCL_GPIO5_IO18 0x84 + MX8MM_IOMUXC_I2C3_SDA_GPIO5_IO19 0x84 + >; + }; + + pinctrl_i2c4: i2c4-grp { + fsl,pins = < + MX8MM_IOMUXC_I2C4_SCL_I2C4_SCL 0x40000084 + MX8MM_IOMUXC_I2C4_SDA_I2C4_SDA 0x40000084 + >; + }; + + pinctrl_i2c4_gpio: i2c4-gpio-grp { + fsl,pins = < + MX8MM_IOMUXC_I2C4_SCL_GPIO5_IO20 0x84 + MX8MM_IOMUXC_I2C4_SDA_GPIO5_IO21 0x84 + >; + }; + + pinctrl_panel_backlight: panel-backlight-grp { + fsl,pins = < + /* BL_ENABLE_1V8 */ + MX8MM_IOMUXC_NAND_ALE_GPIO3_IO0 0x104 + >; + }; + + pinctrl_panel_expansion: panel-expansion-grp { + fsl,pins = < + /* DSI_RESET_1V8# */ + MX8MM_IOMUXC_SD1_DATA0_GPIO2_IO2 0x2 + /* DSI_IRQ_1V8# */ + MX8MM_IOMUXC_SD1_DATA1_GPIO2_IO3 0x40000090 + >; + }; + + pinctrl_panel_vcc_reg: panel-vcc-grp { + fsl,pins = < + /* TFT_ENABLE_1V8 */ + MX8MM_IOMUXC_NAND_DATA00_GPIO3_IO6 0x104 + >; + }; + + pinctrl_panel_pwm: panel-pwm-grp { + fsl,pins = < + /* BL_PWM_3V3 */ + MX8MM_IOMUXC_SPDIF_EXT_CLK_PWM1_OUT 0x12 + >; + }; + + pinctrl_pcie0: pcie-grp { + fsl,pins = < + /* M2-B_RESET_1V8# */ + MX8MM_IOMUXC_SAI5_RXC_GPIO3_IO20 0x102 + /* M2-B_PCIE_RST# */ + MX8MM_IOMUXC_GPIO1_IO05_GPIO1_IO5 0x2 + /* M2-B_FULL_CARD_PWROFF_1V8# */ + MX8MM_IOMUXC_SD1_DATA2_GPIO2_IO4 0x102 + /* M2-B_W_DISABLE1_WWAN_1V8# */ + MX8MM_IOMUXC_SD1_RESET_B_GPIO2_IO10 0x102 + /* M2-B_W_DISABLE2_GPS_1V8# */ + MX8MM_IOMUXC_SD1_STROBE_GPIO2_IO11 0x102 + /* CLK_M2_32K768 */ + MX8MM_IOMUXC_GPIO1_IO00_ANAMIX_REF_CLK_32K 0x14 + /* M2-B_WAKE_WWAN_1V8# */ + MX8MM_IOMUXC_SAI5_RXFS_GPIO3_IO19 0x40000140 + /* M2-B_PCIE_WAKE# */ + MX8MM_IOMUXC_GPIO1_IO06_GPIO1_IO6 0x40000140 + /* M2-B_PCIE_CLKREQ# */ + MX8MM_IOMUXC_GPIO1_IO09_GPIO1_IO9 0x40000140 + >; + }; + + pinctrl_pmic: pmic-grp { + fsl,pins = < + MX8MM_IOMUXC_GPIO1_IO03_GPIO1_IO3 0x40000090 + >; + }; + + pinctrl_rtc: rtc-grp { + fsl,pins = < + /* RTC_IRQ# */ + MX8MM_IOMUXC_GPIO1_IO07_GPIO1_IO7 0x40000090 + >; + }; + + pinctrl_sai5: sai5-grp { + fsl,pins = < + MX8MM_IOMUXC_SAI5_MCLK_SAI5_MCLK 0x100 + MX8MM_IOMUXC_SAI5_RXD0_SAI5_RX_DATA0 0x0 + MX8MM_IOMUXC_SAI5_RXD1_SAI5_TX_SYNC 0x100 + MX8MM_IOMUXC_SAI5_RXD2_SAI5_TX_BCLK 0x100 + MX8MM_IOMUXC_SAI5_RXD3_SAI5_TX_DATA0 0x100 + >; + }; + + pinctrl_uart1: uart1-grp { + fsl,pins = < + MX8MM_IOMUXC_SAI2_RXC_UART1_DCE_RX 0x90 + MX8MM_IOMUXC_SAI2_RXD0_UART1_DCE_RTS_B 0x90 + MX8MM_IOMUXC_SAI2_RXFS_UART1_DCE_TX 0x50 + MX8MM_IOMUXC_SAI2_TXFS_UART1_DCE_CTS_B 0x50 + >; + }; + + pinctrl_uart2: uart2-grp { + fsl,pins = < + MX8MM_IOMUXC_SAI3_RXC_UART2_DCE_CTS_B 0x50 + MX8MM_IOMUXC_SAI3_RXD_UART2_DCE_RTS_B 0x90 + MX8MM_IOMUXC_SAI3_TXC_UART2_DCE_TX 0x50 + MX8MM_IOMUXC_SAI3_TXFS_UART2_DCE_RX 0x90 + >; + }; + + pinctrl_uart3: uart3-grp { + fsl,pins = < + MX8MM_IOMUXC_UART3_RXD_UART3_DCE_RX 0x40 + MX8MM_IOMUXC_UART3_TXD_UART3_DCE_TX 0x40 + >; + }; + + pinctrl_uart4: uart4-grp { + fsl,pins = < + MX8MM_IOMUXC_UART4_RXD_UART4_DCE_RX 0x40 + MX8MM_IOMUXC_UART4_TXD_UART4_DCE_TX 0x40 + >; + }; + + pinctrl_usb_hub: usb-hub-grp { + fsl,pins = < + /* USBHUB_RESET# */ + MX8MM_IOMUXC_SAI3_MCLK_GPIO5_IO2 0x4 + >; + }; + + pinctrl_usb_otg1: usb-otg1-grp { + fsl,pins = < + MX8MM_IOMUXC_GPIO1_IO10_GPIO1_IO10 0x40000000 + MX8MM_IOMUXC_GPIO1_IO12_USB1_OTG_PWR 0x4 + MX8MM_IOMUXC_GPIO1_IO13_USB1_OTG_OC 0x40000090 + >; + }; + + pinctrl_usdhc2_vcc_reg: usdhc2-vcc-reg-grp { + fsl,pins = < + MX8MM_IOMUXC_SD2_RESET_B_GPIO2_IO19 0x4 + >; + }; + + pinctrl_usdhc2: usdhc2-grp { + fsl,pins = < + MX8MM_IOMUXC_SD2_CLK_USDHC2_CLK 0x190 + MX8MM_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d0 + MX8MM_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d0 + MX8MM_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d0 + MX8MM_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d0 + MX8MM_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d0 + MX8MM_IOMUXC_SD2_WP_USDHC2_WP 0x400000d6 + MX8MM_IOMUXC_SD2_CD_B_USDHC2_CD_B 0x0d6 + MX8MM_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 + >; + }; + + pinctrl_usdhc2_100mhz: usdhc2-100mhz-grp { + fsl,pins = < + MX8MM_IOMUXC_SD2_CLK_USDHC2_CLK 0x194 + MX8MM_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d4 + MX8MM_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d4 + MX8MM_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d4 + MX8MM_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d4 + MX8MM_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d4 + MX8MM_IOMUXC_SD2_WP_USDHC2_WP 0x400000d6 + MX8MM_IOMUXC_SD2_CD_B_USDHC2_CD_B 0x0d6 + MX8MM_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 + >; + }; + + pinctrl_usdhc2_200mhz: usdhc2-200mhz-grp { + fsl,pins = < + MX8MM_IOMUXC_SD2_CLK_USDHC2_CLK 0x196 + MX8MM_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d6 + MX8MM_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d6 + MX8MM_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d6 + MX8MM_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d6 + MX8MM_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d6 + MX8MM_IOMUXC_SD2_WP_USDHC2_WP 0x400000d6 + MX8MM_IOMUXC_SD2_CD_B_USDHC2_CD_B 0x0d6 + MX8MM_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 + >; + }; + + pinctrl_usdhc3: usdhc3-grp { + fsl,pins = < + MX8MM_IOMUXC_NAND_WE_B_USDHC3_CLK 0x190 + MX8MM_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d0 + MX8MM_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d0 + MX8MM_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d0 + MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d0 + MX8MM_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d0 + MX8MM_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d0 + MX8MM_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d0 + MX8MM_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d0 + MX8MM_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d0 + MX8MM_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x190 + MX8MM_IOMUXC_NAND_READY_B_SD3_RESET_B 0x40 + >; + }; + + pinctrl_usdhc3_100mhz: usdhc3-100mhz-grp { + fsl,pins = < + MX8MM_IOMUXC_NAND_WE_B_USDHC3_CLK 0x194 + MX8MM_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d4 + MX8MM_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d4 + MX8MM_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d4 + MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d4 + MX8MM_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d4 + MX8MM_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d4 + MX8MM_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d4 + MX8MM_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d4 + MX8MM_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d4 + MX8MM_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x194 + MX8MM_IOMUXC_NAND_READY_B_SD3_RESET_B 0x40 + >; + }; + + pinctrl_usdhc3_200mhz: usdhc3-200mhz-grp { + fsl,pins = < + MX8MM_IOMUXC_NAND_WE_B_USDHC3_CLK 0x196 + MX8MM_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d6 + MX8MM_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d6 + MX8MM_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d6 + MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d6 + MX8MM_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d6 + MX8MM_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d6 + MX8MM_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d6 + MX8MM_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d6 + MX8MM_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d6 + MX8MM_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x196 + MX8MM_IOMUXC_NAND_READY_B_SD3_RESET_B 0x40 + >; + }; + + pinctrl_watchdog_gpio: watchdog-gpio-grp { + fsl,pins = < + /* WDOG_B# */ + MX8MM_IOMUXC_GPIO1_IO02_GPIO1_IO2 0x26 + /* WDOG_EN -- ungate WDT RESET# signal propagation */ + MX8MM_IOMUXC_SD1_DATA7_GPIO2_IO9 0x6 + /* WDOG_KICK# / WDI */ + MX8MM_IOMUXC_GPIO1_IO08_GPIO1_IO8 0x26 + >; + }; +}; + +&pcie_phy { + fsl,clkreq-unsupported; /* CLKREQ_B is not connected to suitable input */ + fsl,refclk-pad-mode = <IMX8_PCIE_REFCLK_PAD_INPUT>; + fsl,tx-deemph-gen1 = <0x2d>; + fsl,tx-deemph-gen2 = <0xf>; + clocks = <&pcieclk 0>; + status = "okay"; +}; + +&pcie0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pcie0>; + reset-gpio = <&gpio1 5 GPIO_ACTIVE_LOW>; + clocks = <&clk IMX8MM_CLK_PCIE1_ROOT>, <&clk IMX8MM_CLK_PCIE1_AUX>, + <&pcieclk 0>; + clock-names = "pcie", "pcie_aux", "pcie_bus"; + assigned-clocks = <&clk IMX8MM_CLK_PCIE1_AUX>, + <&clk IMX8MM_CLK_PCIE1_CTRL>; + assigned-clock-rates = <10000000>, <250000000>; + assigned-clock-parents = <&clk IMX8MM_SYS_PLL2_50M>, + <&clk IMX8MM_SYS_PLL2_250M>; + status = "okay"; +}; + +&pwm1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_panel_pwm>; + /* Disabled by default, unless display board plugged in. */ + status = "disabled"; +}; + +&sai5 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sai5>; + fsl,sai-mclk-direction-output; + /* Input into codec PLL */ + assigned-clocks = <&clk IMX8MM_CLK_SAI5>; + assigned-clock-parents = <&clk IMX8MM_AUDIO_PLL2_OUT>; + assigned-clock-rates = <22579200>; + /* Disabled by default, unless display board plugged in. */ + status = "disabled"; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + uart-has-rtscts; + status = "disabled"; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + status = "disabled"; +}; + +&uart3 { /* A53 Debug */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + status = "okay"; +}; + +&uart4 { /* M4 Debug */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart4>; + /* UART4 is reserved for CM and RDC blocks CA access to UART4. */ + status = "disabled"; +}; + +&usbotg1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb_otg1>; + dr_mode = "otg"; + status = "okay"; +}; + +&usbotg2 { + dr_mode = "host"; + status = "okay"; +}; + +&usdhc2 { /* MicroSD */ + assigned-clocks = <&clk IMX8MM_CLK_USDHC2_ROOT>; + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc2>; + pinctrl-1 = <&pinctrl_usdhc2_100mhz>; + pinctrl-2 = <&pinctrl_usdhc2_200mhz>; + bus-width = <4>; + vmmc-supply = <®_usdhc2_vcc>; + status = "okay"; +}; + +&usdhc3 { /* eMMC */ + assigned-clocks = <&clk IMX8MM_CLK_USDHC3_ROOT>; + assigned-clock-rates = <400000000>; + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc3>; + pinctrl-1 = <&pinctrl_usdhc3_100mhz>; + pinctrl-2 = <&pinctrl_usdhc3_200mhz>; + bus-width = <8>; + non-removable; + vmmc-supply = <&buck4_reg>; + vqmmc-supply = <&buck5_reg>; + status = "okay"; +}; + +&wdog1 { + status = "okay"; +}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index fae70499953..7f09d7b26a8 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -46,6 +46,13 @@ config TARGET_IMX8MQ_PHANBELL select IMX8MQ select IMX8M_LPDDR4
+config TARGET_IMX8MM_DATA_MODUL_EDM_SBC + bool "Data Modul eDM SBC i.MX8M Mini" + select BINMAN + select IMX8MM + select IMX8M_LPDDR4 + select SUPPORT_SPL + config TARGET_IMX8MM_EVK bool "imx8mm LPDDR4 EVK board" select BINMAN @@ -209,6 +216,7 @@ source "board/advantech/imx8mp_rsb3720a1/Kconfig" source "board/beacon/imx8mm/Kconfig" source "board/beacon/imx8mn/Kconfig" source "board/compulab/imx8mm-cl-iot-gate/Kconfig" +source "board/data_modul/imx8mm_edm_sbc/Kconfig" source "board/engicam/imx8mm/Kconfig" source "board/freescale/imx8mq_evk/Kconfig" source "board/freescale/imx8mm_evk/Kconfig" diff --git a/board/data_modul/imx8mm_edm_sbc/Kconfig b/board/data_modul/imx8mm_edm_sbc/Kconfig new file mode 100644 index 00000000000..df9871c2240 --- /dev/null +++ b/board/data_modul/imx8mm_edm_sbc/Kconfig @@ -0,0 +1,12 @@ +if TARGET_IMX8MM_DATA_MODUL_EDM_SBC + +config SYS_BOARD + default "imx8mm_edm_sbc" + +config SYS_VENDOR + default "data_modul" + +config SYS_CONFIG_NAME + default "imx8mm_data_modul_edm_sbc" + +endif diff --git a/board/data_modul/imx8mm_edm_sbc/MAINTAINERS b/board/data_modul/imx8mm_edm_sbc/MAINTAINERS new file mode 100644 index 00000000000..72659c081e2 --- /dev/null +++ b/board/data_modul/imx8mm_edm_sbc/MAINTAINERS @@ -0,0 +1,8 @@ +Data Modul eDM SBC i.MX8M Mini +M: Marek Vasut marex@denx.de +S: Maintained +F: arch/arm/dts/imx8mm-data-modul-edm-sbc.dts +F: arch/arm/dts/imx8mm-data-modul-edm-sbc-u-boot.dtsi +F: board/data_modul/imx8mm_data_modul_edm_sbc/ +F: configs/imx8mm_data_modul_edm_sbc_defconfig +F: include/configs/imx8mm_data_modul_edm_sbc.h diff --git a/board/data_modul/imx8mm_edm_sbc/Makefile b/board/data_modul/imx8mm_edm_sbc/Makefile new file mode 100644 index 00000000000..eaba85d65b8 --- /dev/null +++ b/board/data_modul/imx8mm_edm_sbc/Makefile @@ -0,0 +1,13 @@ +# +# Copyright (C) 2022 Marek Vasut marex@denx.de +# +# SPDX-License-Identifier: GPL-2.0+ +# + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o lpddr4_timing_2G_32.o lpddr4_timing_4G_32.o +else +obj-y += imx8mm_data_modul_edm_sbc.o +endif + +obj-y += common.o diff --git a/board/data_modul/imx8mm_edm_sbc/common.c b/board/data_modul/imx8mm_edm_sbc/common.c new file mode 100644 index 00000000000..713f789da67 --- /dev/null +++ b/board/data_modul/imx8mm_edm_sbc/common.c @@ -0,0 +1,37 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2022 Marek Vasut marex@denx.de + */ + +#include <common.h> +#include <asm/io.h> +#include <asm-generic/gpio.h> + +#include "lpddr4_timing.h" + +DECLARE_GLOBAL_DATA_PTR; + +u8 dmo_get_memcfg(void) +{ + struct gpio_desc gpio[4]; + u8 memcfg = 0; + ofnode node; + int i, ret; + + node = ofnode_path("/config"); + if (!ofnode_valid(node)) { + printf("%s: no /config node?\n", __func__); + return BIT(2) | BIT(0); + } + + ret = gpio_request_list_by_name_nodev(node, + "dmo,ram-coding-gpios", + gpio, ARRAY_SIZE(gpio), + GPIOD_IS_IN); + for (i = 0; i < ret; i++) + memcfg |= !!dm_gpio_get_value(&(gpio[i])) << i; + + gpio_free_list_nodev(gpio, ret); + + return memcfg; +} diff --git a/board/data_modul/imx8mm_edm_sbc/imx8mm_data_modul_edm_sbc.c b/board/data_modul/imx8mm_edm_sbc/imx8mm_data_modul_edm_sbc.c new file mode 100644 index 00000000000..46cb6f77b59 --- /dev/null +++ b/board/data_modul/imx8mm_edm_sbc/imx8mm_data_modul_edm_sbc.c @@ -0,0 +1,110 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2022 Marek Vasut marex@denx.de + */ + +#include <common.h> +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> +#include <asm/io.h> +#include <asm/mach-imx/boot_mode.h> +#include <dm.h> +#include <i2c_eeprom.h> +#include <malloc.h> +#include <net.h> +#include <spl.h> + +#include "lpddr4_timing.h" + +DECLARE_GLOBAL_DATA_PTR; + +int mach_cpu_init(void) +{ + icache_enable(); + return 0; +} + +int board_phys_sdram_size(phys_size_t *size) +{ + u8 memcfg = dmo_get_memcfg(); + + *size = (4ULL >> ((memcfg >> 1) & 0x3)) * SZ_1G; + + return 0; +} + +/* IMX8M SNVS registers needed for the bootcount functionality */ +#define SNVS_BASE_ADDR 0x30370000 +#define SNVS_LPSR 0x4c +#define SNVS_LPLVDR 0x64 +#define SNVS_LPPGDR_INIT 0x41736166 + +static void setup_snvs(void) +{ + /* Enable SNVS clock */ + clock_enable(CCGR_SNVS, 1); + /* Initialize glitch detect */ + writel(SNVS_LPPGDR_INIT, SNVS_BASE_ADDR + SNVS_LPLVDR); + /* Clear interrupt status */ + writel(0xffffffff, SNVS_BASE_ADDR + SNVS_LPSR); +} + +static void setup_mac_address(void) +{ + unsigned char enetaddr[6]; + struct udevice *dev; + int off, ret; + + ret = eth_env_get_enetaddr("ethaddr", enetaddr); + if (ret) /* ethaddr is already set */ + return; + + off = fdt_path_offset(gd->fdt_blob, "eeprom0"); + if (off < 0) { + printf("%s: No eeprom0 path offset\n", __func__); + return; + } + + ret = uclass_get_device_by_of_offset(UCLASS_I2C_EEPROM, off, &dev); + if (ret) { + printf("Cannot find EEPROM!\n"); + return; + } + + ret = i2c_eeprom_read(dev, 0xb0, enetaddr, 0x6); + if (ret) { + printf("Error reading configuration EEPROM!\n"); + return; + } + + if (is_valid_ethaddr(enetaddr)) + eth_env_set_enetaddr("ethaddr", enetaddr); +} + +static void setup_boot_device(void) +{ + int boot_device = get_boot_device(); + char *devnum; + + devnum = env_get("devnum"); + if (devnum) /* devnum is already set */ + return; + + if (boot_device == MMC3_BOOT) /* eMMC */ + env_set_ulong("devnum", 0); + else + env_set_ulong("devnum", 1); +} + +int board_init(void) +{ + setup_snvs(); + return 0; +} + +int board_late_init(void) +{ + setup_boot_device(); + setup_mac_address(); + return 0; +} diff --git a/board/data_modul/imx8mm_edm_sbc/imximage.cfg b/board/data_modul/imx8mm_edm_sbc/imximage.cfg new file mode 100644 index 00000000000..fa0b618128a --- /dev/null +++ b/board/data_modul/imx8mm_edm_sbc/imximage.cfg @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 NXP + */ + +FIT +BOOT_FROM sd +LOADER u-boot-spl-ddr.bin 0x7E1000 diff --git a/board/data_modul/imx8mm_edm_sbc/lpddr4_timing.h b/board/data_modul/imx8mm_edm_sbc/lpddr4_timing.h new file mode 100644 index 00000000000..1fab9b14051 --- /dev/null +++ b/board/data_modul/imx8mm_edm_sbc/lpddr4_timing.h @@ -0,0 +1,14 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2022 Marek Vasut marex@denx.de + */ + +#ifndef __LPDDR4_TIMING_H__ +#define __LPDDR4_TIMING_H__ + +extern struct dram_timing_info dmo_imx8mm_sbc_dram_timing_16_32; +extern struct dram_timing_info dmo_imx8mm_sbc_dram_timing_32_32; + +u8 dmo_get_memcfg(void); + +#endif /* __LPDDR4_TIMING_H__ */ diff --git a/board/data_modul/imx8mm_edm_sbc/lpddr4_timing_2G_32.c b/board/data_modul/imx8mm_edm_sbc/lpddr4_timing_2G_32.c new file mode 100644 index 00000000000..c2abcb54895 --- /dev/null +++ b/board/data_modul/imx8mm_edm_sbc/lpddr4_timing_2G_32.c @@ -0,0 +1,1845 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 NXP + * + * Generated code from MX8M_DDR_tool + * Align with uboot version: + * imx_v2018.03_4.14.78_1.0.0_ga ~ imx_v2018.04_4.19.35_1.0.0_ga + */ + +#include <linux/kernel.h> +#include <asm/arch/ddr.h> + +static struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + { 0x3d400304, 0x1 }, + { 0x3d400030, 0x1 }, + { 0x3d400000, 0xa1080020 }, + { 0x3d400020, 0x203 }, + { 0x3d400024, 0x3a980 }, + { 0x3d400064, 0x5b00d2 }, + { 0x3d4000d0, 0xc00305ba }, + { 0x3d4000d4, 0x940000 }, + { 0x3d4000dc, 0xd4002d }, + { 0x3d4000e0, 0x310000 }, + { 0x3d4000e8, 0x66004d }, + { 0x3d4000ec, 0x16004d }, + { 0x3d400100, 0x191e1920 }, + { 0x3d400104, 0x60630 }, + { 0x3d40010c, 0xb0b000 }, + { 0x3d400110, 0xe04080e }, + { 0x3d400114, 0x2040c0c }, + { 0x3d400118, 0x1010007 }, + { 0x3d40011c, 0x401 }, + { 0x3d400130, 0x20600 }, + { 0x3d400134, 0xc100002 }, + { 0x3d400138, 0xd8 }, + { 0x3d400144, 0x96004b }, + { 0x3d400180, 0x2ee0017 }, + { 0x3d400184, 0x2605b8e }, + { 0x3d400188, 0x0 }, + { 0x3d400190, 0x497820a }, + { 0x3d400194, 0x80303 }, + { 0x3d4001b4, 0x170a }, + { 0x3d4001a0, 0xe0400018 }, + { 0x3d4001a4, 0xdf00e4 }, + { 0x3d4001a8, 0x80000000 }, + { 0x3d4001b0, 0x11 }, + { 0x3d4001c0, 0x1 }, + { 0x3d4001c4, 0x1 }, + { 0x3d4000f4, 0xc99 }, + { 0x3d400108, 0x70e1617 }, + { 0x3d400200, 0x1f }, + { 0x3d40020c, 0x0 }, + { 0x3d400210, 0x1f1f }, + { 0x3d400204, 0x80808 }, + { 0x3d400214, 0x7070707 }, + { 0x3d400218, 0x7070707 }, + { 0x3d400250, 0x29001701 }, + { 0x3d400254, 0x2c }, + { 0x3d40025c, 0x4000030 }, + { 0x3d400264, 0x900093e7 }, + { 0x3d40026c, 0x2005574 }, + { 0x3d400400, 0x111 }, + { 0x3d400408, 0x72ff }, + { 0x3d400494, 0x2100e07 }, + { 0x3d400498, 0x620096 }, + { 0x3d40049c, 0x1100e07 }, + { 0x3d4004a0, 0xc8012c }, + { 0x3d402020, 0x1 }, + { 0x3d402024, 0x7d00 }, + { 0x3d402050, 0x20d040 }, + { 0x3d402064, 0xc001c }, + { 0x3d4020dc, 0x840000 }, + { 0x3d4020e0, 0x310000 }, + { 0x3d4020e8, 0x66004d }, + { 0x3d4020ec, 0x16004d }, + { 0x3d402100, 0xa040305 }, + { 0x3d402104, 0x30407 }, + { 0x3d402108, 0x203060b }, + { 0x3d40210c, 0x505000 }, + { 0x3d402110, 0x2040202 }, + { 0x3d402114, 0x2030202 }, + { 0x3d402118, 0x1010004 }, + { 0x3d40211c, 0x301 }, + { 0x3d402130, 0x20300 }, + { 0x3d402134, 0xa100002 }, + { 0x3d402138, 0x1d }, + { 0x3d402144, 0x14000a }, + { 0x3d402180, 0x640004 }, + { 0x3d402190, 0x3818200 }, + { 0x3d402194, 0x80303 }, + { 0x3d4021b4, 0x100 }, + { 0x3d4020f4, 0xc99 }, + { 0x3d403020, 0x1 }, + { 0x3d403024, 0x1f40 }, + { 0x3d403050, 0x20d040 }, + { 0x3d403064, 0x30007 }, + { 0x3d4030dc, 0x840000 }, + { 0x3d4030e0, 0x310000 }, + { 0x3d4030e8, 0x66004d }, + { 0x3d4030ec, 0x16004d }, + { 0x3d403100, 0xa010102 }, + { 0x3d403104, 0x30404 }, + { 0x3d403108, 0x203060b }, + { 0x3d40310c, 0x505000 }, + { 0x3d403110, 0x2040202 }, + { 0x3d403114, 0x2030202 }, + { 0x3d403118, 0x1010004 }, + { 0x3d40311c, 0x301 }, + { 0x3d403130, 0x20300 }, + { 0x3d403134, 0xa100002 }, + { 0x3d403138, 0x8 }, + { 0x3d403144, 0x50003 }, + { 0x3d403180, 0x190004 }, + { 0x3d403190, 0x3818200 }, + { 0x3d403194, 0x80303 }, + { 0x3d4031b4, 0x100 }, + { 0x3d4030f4, 0xc99 }, + { 0x3d400028, 0x0 }, +}; + +/* PHY Initialize Configuration */ +static struct dram_cfg_param ddr_ddrphy_cfg[] = { + { 0x100a0, 0x6 }, + { 0x100a1, 0x7 }, + { 0x100a2, 0x0 }, + { 0x100a3, 0x1 }, + { 0x100a4, 0x3 }, + { 0x100a5, 0x2 }, + { 0x100a6, 0x4 }, + { 0x100a7, 0x5 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x1 }, + { 0x110a2, 0x5 }, + { 0x110a3, 0x3 }, + { 0x110a4, 0x2 }, + { 0x110a5, 0x4 }, + { 0x110a6, 0x6 }, + { 0x110a7, 0x7 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x1 }, + { 0x120a2, 0x5 }, + { 0x120a3, 0x3 }, + { 0x120a4, 0x2 }, + { 0x120a5, 0x4 }, + { 0x120a6, 0x6 }, + { 0x120a7, 0x7 }, + { 0x130a0, 0x6 }, + { 0x130a1, 0x7 }, + { 0x130a2, 0x0 }, + { 0x130a3, 0x1 }, + { 0x130a4, 0x3 }, + { 0x130a5, 0x2 }, + { 0x130a6, 0x4 }, + { 0x130a7, 0x5 }, + { 0x1005f, 0x1ff }, + { 0x1015f, 0x1ff }, + { 0x1105f, 0x1ff }, + { 0x1115f, 0x1ff }, + { 0x1205f, 0x1ff }, + { 0x1215f, 0x1ff }, + { 0x1305f, 0x1ff }, + { 0x1315f, 0x1ff }, + { 0x11005f, 0x1ff }, + { 0x11015f, 0x1ff }, + { 0x11105f, 0x1ff }, + { 0x11115f, 0x1ff }, + { 0x11205f, 0x1ff }, + { 0x11215f, 0x1ff }, + { 0x11305f, 0x1ff }, + { 0x11315f, 0x1ff }, + { 0x21005f, 0x1ff }, + { 0x21015f, 0x1ff }, + { 0x21105f, 0x1ff }, + { 0x21115f, 0x1ff }, + { 0x21205f, 0x1ff }, + { 0x21215f, 0x1ff }, + { 0x21305f, 0x1ff }, + { 0x21315f, 0x1ff }, + { 0x55, 0x1ff }, + { 0x1055, 0x1ff }, + { 0x2055, 0x1ff }, + { 0x3055, 0x1ff }, + { 0x4055, 0x1ff }, + { 0x5055, 0x1ff }, + { 0x6055, 0x1ff }, + { 0x7055, 0x1ff }, + { 0x8055, 0x1ff }, + { 0x9055, 0x1ff }, + { 0x200c5, 0x19 }, + { 0x1200c5, 0x7 }, + { 0x2200c5, 0x7 }, + { 0x2002e, 0x2 }, + { 0x12002e, 0x2 }, + { 0x22002e, 0x2 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x20024, 0x1ab }, + { 0x2003a, 0x0 }, + { 0x120024, 0x1ab }, + { 0x2003a, 0x0 }, + { 0x220024, 0x1ab }, + { 0x2003a, 0x0 }, + { 0x20056, 0x3 }, + { 0x120056, 0x3 }, + { 0x220056, 0x3 }, + { 0x1004d, 0xe00 }, + { 0x1014d, 0xe00 }, + { 0x1104d, 0xe00 }, + { 0x1114d, 0xe00 }, + { 0x1204d, 0xe00 }, + { 0x1214d, 0xe00 }, + { 0x1304d, 0xe00 }, + { 0x1314d, 0xe00 }, + { 0x11004d, 0xe00 }, + { 0x11014d, 0xe00 }, + { 0x11104d, 0xe00 }, + { 0x11114d, 0xe00 }, + { 0x11204d, 0xe00 }, + { 0x11214d, 0xe00 }, + { 0x11304d, 0xe00 }, + { 0x11314d, 0xe00 }, + { 0x21004d, 0xe00 }, + { 0x21014d, 0xe00 }, + { 0x21104d, 0xe00 }, + { 0x21114d, 0xe00 }, + { 0x21204d, 0xe00 }, + { 0x21214d, 0xe00 }, + { 0x21304d, 0xe00 }, + { 0x21314d, 0xe00 }, + { 0x10049, 0xeba }, + { 0x10149, 0xeba }, + { 0x11049, 0xeba }, + { 0x11149, 0xeba }, + { 0x12049, 0xeba }, + { 0x12149, 0xeba }, + { 0x13049, 0xeba }, + { 0x13149, 0xeba }, + { 0x110049, 0xeba }, + { 0x110149, 0xeba }, + { 0x111049, 0xeba }, + { 0x111149, 0xeba }, + { 0x112049, 0xeba }, + { 0x112149, 0xeba }, + { 0x113049, 0xeba }, + { 0x113149, 0xeba }, + { 0x210049, 0xeba }, + { 0x210149, 0xeba }, + { 0x211049, 0xeba }, + { 0x211149, 0xeba }, + { 0x212049, 0xeba }, + { 0x212149, 0xeba }, + { 0x213049, 0xeba }, + { 0x213149, 0xeba }, + { 0x43, 0x63 }, + { 0x1043, 0x63 }, + { 0x2043, 0x63 }, + { 0x3043, 0x63 }, + { 0x4043, 0x63 }, + { 0x5043, 0x63 }, + { 0x6043, 0x63 }, + { 0x7043, 0x63 }, + { 0x8043, 0x63 }, + { 0x9043, 0x63 }, + { 0x20018, 0x3 }, + { 0x20075, 0x4 }, + { 0x20050, 0x0 }, + { 0x20008, 0x2ee }, + { 0x120008, 0x64 }, + { 0x220008, 0x19 }, + { 0x20088, 0x9 }, + { 0x200b2, 0xdc }, + { 0x10043, 0x5a1 }, + { 0x10143, 0x5a1 }, + { 0x11043, 0x5a1 }, + { 0x11143, 0x5a1 }, + { 0x12043, 0x5a1 }, + { 0x12143, 0x5a1 }, + { 0x13043, 0x5a1 }, + { 0x13143, 0x5a1 }, + { 0x1200b2, 0xdc }, + { 0x110043, 0x5a1 }, + { 0x110143, 0x5a1 }, + { 0x111043, 0x5a1 }, + { 0x111143, 0x5a1 }, + { 0x112043, 0x5a1 }, + { 0x112143, 0x5a1 }, + { 0x113043, 0x5a1 }, + { 0x113143, 0x5a1 }, + { 0x2200b2, 0xdc }, + { 0x210043, 0x5a1 }, + { 0x210143, 0x5a1 }, + { 0x211043, 0x5a1 }, + { 0x211143, 0x5a1 }, + { 0x212043, 0x5a1 }, + { 0x212143, 0x5a1 }, + { 0x213043, 0x5a1 }, + { 0x213143, 0x5a1 }, + { 0x200fa, 0x1 }, + { 0x1200fa, 0x1 }, + { 0x2200fa, 0x1 }, + { 0x20019, 0x1 }, + { 0x120019, 0x1 }, + { 0x220019, 0x1 }, + { 0x200f0, 0x660 }, + { 0x200f1, 0x0 }, + { 0x200f2, 0x4444 }, + { 0x200f3, 0x8888 }, + { 0x200f4, 0x5665 }, + { 0x200f5, 0x0 }, + { 0x200f6, 0x0 }, + { 0x200f7, 0xf000 }, + { 0x20025, 0x0 }, + { 0x2002d, 0x0 }, + { 0x12002d, 0x0 }, + { 0x22002d, 0x0 }, + { 0x200c7, 0x21 }, + { 0x1200c7, 0x21 }, + { 0x2200c7, 0x21 }, + { 0x200ca, 0x24 }, + { 0x1200ca, 0x24 }, + { 0x2200ca, 0x24 }, +}; + +/* ddr phy trained csr */ +static struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + { 0x200b2, 0x0 }, + { 0x1200b2, 0x0 }, + { 0x2200b2, 0x0 }, + { 0x200cb, 0x0 }, + { 0x10043, 0x0 }, + { 0x110043, 0x0 }, + { 0x210043, 0x0 }, + { 0x10143, 0x0 }, + { 0x110143, 0x0 }, + { 0x210143, 0x0 }, + { 0x11043, 0x0 }, + { 0x111043, 0x0 }, + { 0x211043, 0x0 }, + { 0x11143, 0x0 }, + { 0x111143, 0x0 }, + { 0x211143, 0x0 }, + { 0x12043, 0x0 }, + { 0x112043, 0x0 }, + { 0x212043, 0x0 }, + { 0x12143, 0x0 }, + { 0x112143, 0x0 }, + { 0x212143, 0x0 }, + { 0x13043, 0x0 }, + { 0x113043, 0x0 }, + { 0x213043, 0x0 }, + { 0x13143, 0x0 }, + { 0x113143, 0x0 }, + { 0x213143, 0x0 }, + { 0x80, 0x0 }, + { 0x100080, 0x0 }, + { 0x200080, 0x0 }, + { 0x1080, 0x0 }, + { 0x101080, 0x0 }, + { 0x201080, 0x0 }, + { 0x2080, 0x0 }, + { 0x102080, 0x0 }, + { 0x202080, 0x0 }, + { 0x3080, 0x0 }, + { 0x103080, 0x0 }, + { 0x203080, 0x0 }, + { 0x4080, 0x0 }, + { 0x104080, 0x0 }, + { 0x204080, 0x0 }, + { 0x5080, 0x0 }, + { 0x105080, 0x0 }, + { 0x205080, 0x0 }, + { 0x6080, 0x0 }, + { 0x106080, 0x0 }, + { 0x206080, 0x0 }, + { 0x7080, 0x0 }, + { 0x107080, 0x0 }, + { 0x207080, 0x0 }, + { 0x8080, 0x0 }, + { 0x108080, 0x0 }, + { 0x208080, 0x0 }, + { 0x9080, 0x0 }, + { 0x109080, 0x0 }, + { 0x209080, 0x0 }, + { 0x10080, 0x0 }, + { 0x110080, 0x0 }, + { 0x210080, 0x0 }, + { 0x10180, 0x0 }, + { 0x110180, 0x0 }, + { 0x210180, 0x0 }, + { 0x11080, 0x0 }, + { 0x111080, 0x0 }, + { 0x211080, 0x0 }, + { 0x11180, 0x0 }, + { 0x111180, 0x0 }, + { 0x211180, 0x0 }, + { 0x12080, 0x0 }, + { 0x112080, 0x0 }, + { 0x212080, 0x0 }, + { 0x12180, 0x0 }, + { 0x112180, 0x0 }, + { 0x212180, 0x0 }, + { 0x13080, 0x0 }, + { 0x113080, 0x0 }, + { 0x213080, 0x0 }, + { 0x13180, 0x0 }, + { 0x113180, 0x0 }, + { 0x213180, 0x0 }, + { 0x10081, 0x0 }, + { 0x110081, 0x0 }, + { 0x210081, 0x0 }, + { 0x10181, 0x0 }, + { 0x110181, 0x0 }, + { 0x210181, 0x0 }, + { 0x11081, 0x0 }, + { 0x111081, 0x0 }, + { 0x211081, 0x0 }, + { 0x11181, 0x0 }, + { 0x111181, 0x0 }, + { 0x211181, 0x0 }, + { 0x12081, 0x0 }, + { 0x112081, 0x0 }, + { 0x212081, 0x0 }, + { 0x12181, 0x0 }, + { 0x112181, 0x0 }, + { 0x212181, 0x0 }, + { 0x13081, 0x0 }, + { 0x113081, 0x0 }, + { 0x213081, 0x0 }, + { 0x13181, 0x0 }, + { 0x113181, 0x0 }, + { 0x213181, 0x0 }, + { 0x100d0, 0x0 }, + { 0x1100d0, 0x0 }, + { 0x2100d0, 0x0 }, + { 0x101d0, 0x0 }, + { 0x1101d0, 0x0 }, + { 0x2101d0, 0x0 }, + { 0x110d0, 0x0 }, + { 0x1110d0, 0x0 }, + { 0x2110d0, 0x0 }, + { 0x111d0, 0x0 }, + { 0x1111d0, 0x0 }, + { 0x2111d0, 0x0 }, + { 0x120d0, 0x0 }, + { 0x1120d0, 0x0 }, + { 0x2120d0, 0x0 }, + { 0x121d0, 0x0 }, + { 0x1121d0, 0x0 }, + { 0x2121d0, 0x0 }, + { 0x130d0, 0x0 }, + { 0x1130d0, 0x0 }, + { 0x2130d0, 0x0 }, + { 0x131d0, 0x0 }, + { 0x1131d0, 0x0 }, + { 0x2131d0, 0x0 }, + { 0x100d1, 0x0 }, + { 0x1100d1, 0x0 }, + { 0x2100d1, 0x0 }, + { 0x101d1, 0x0 }, + { 0x1101d1, 0x0 }, + { 0x2101d1, 0x0 }, + { 0x110d1, 0x0 }, + { 0x1110d1, 0x0 }, + { 0x2110d1, 0x0 }, + { 0x111d1, 0x0 }, + { 0x1111d1, 0x0 }, + { 0x2111d1, 0x0 }, + { 0x120d1, 0x0 }, + { 0x1120d1, 0x0 }, + { 0x2120d1, 0x0 }, + { 0x121d1, 0x0 }, + { 0x1121d1, 0x0 }, + { 0x2121d1, 0x0 }, + { 0x130d1, 0x0 }, + { 0x1130d1, 0x0 }, + { 0x2130d1, 0x0 }, + { 0x131d1, 0x0 }, + { 0x1131d1, 0x0 }, + { 0x2131d1, 0x0 }, + { 0x10068, 0x0 }, + { 0x10168, 0x0 }, + { 0x10268, 0x0 }, + { 0x10368, 0x0 }, + { 0x10468, 0x0 }, + { 0x10568, 0x0 }, + { 0x10668, 0x0 }, + { 0x10768, 0x0 }, + { 0x10868, 0x0 }, + { 0x11068, 0x0 }, + { 0x11168, 0x0 }, + { 0x11268, 0x0 }, + { 0x11368, 0x0 }, + { 0x11468, 0x0 }, + { 0x11568, 0x0 }, + { 0x11668, 0x0 }, + { 0x11768, 0x0 }, + { 0x11868, 0x0 }, + { 0x12068, 0x0 }, + { 0x12168, 0x0 }, + { 0x12268, 0x0 }, + { 0x12368, 0x0 }, + { 0x12468, 0x0 }, + { 0x12568, 0x0 }, + { 0x12668, 0x0 }, + { 0x12768, 0x0 }, + { 0x12868, 0x0 }, + { 0x13068, 0x0 }, + { 0x13168, 0x0 }, + { 0x13268, 0x0 }, + { 0x13368, 0x0 }, + { 0x13468, 0x0 }, + { 0x13568, 0x0 }, + { 0x13668, 0x0 }, + { 0x13768, 0x0 }, + { 0x13868, 0x0 }, + { 0x10069, 0x0 }, + { 0x10169, 0x0 }, + { 0x10269, 0x0 }, + { 0x10369, 0x0 }, + { 0x10469, 0x0 }, + { 0x10569, 0x0 }, + { 0x10669, 0x0 }, + { 0x10769, 0x0 }, + { 0x10869, 0x0 }, + { 0x11069, 0x0 }, + { 0x11169, 0x0 }, + { 0x11269, 0x0 }, + { 0x11369, 0x0 }, + { 0x11469, 0x0 }, + { 0x11569, 0x0 }, + { 0x11669, 0x0 }, + { 0x11769, 0x0 }, + { 0x11869, 0x0 }, + { 0x12069, 0x0 }, + { 0x12169, 0x0 }, + { 0x12269, 0x0 }, + { 0x12369, 0x0 }, + { 0x12469, 0x0 }, + { 0x12569, 0x0 }, + { 0x12669, 0x0 }, + { 0x12769, 0x0 }, + { 0x12869, 0x0 }, + { 0x13069, 0x0 }, + { 0x13169, 0x0 }, + { 0x13269, 0x0 }, + { 0x13369, 0x0 }, + { 0x13469, 0x0 }, + { 0x13569, 0x0 }, + { 0x13669, 0x0 }, + { 0x13769, 0x0 }, + { 0x13869, 0x0 }, + { 0x1008c, 0x0 }, + { 0x11008c, 0x0 }, + { 0x21008c, 0x0 }, + { 0x1018c, 0x0 }, + { 0x11018c, 0x0 }, + { 0x21018c, 0x0 }, + { 0x1108c, 0x0 }, + { 0x11108c, 0x0 }, + { 0x21108c, 0x0 }, + { 0x1118c, 0x0 }, + { 0x11118c, 0x0 }, + { 0x21118c, 0x0 }, + { 0x1208c, 0x0 }, + { 0x11208c, 0x0 }, + { 0x21208c, 0x0 }, + { 0x1218c, 0x0 }, + { 0x11218c, 0x0 }, + { 0x21218c, 0x0 }, + { 0x1308c, 0x0 }, + { 0x11308c, 0x0 }, + { 0x21308c, 0x0 }, + { 0x1318c, 0x0 }, + { 0x11318c, 0x0 }, + { 0x21318c, 0x0 }, + { 0x1008d, 0x0 }, + { 0x11008d, 0x0 }, + { 0x21008d, 0x0 }, + { 0x1018d, 0x0 }, + { 0x11018d, 0x0 }, + { 0x21018d, 0x0 }, + { 0x1108d, 0x0 }, + { 0x11108d, 0x0 }, + { 0x21108d, 0x0 }, + { 0x1118d, 0x0 }, + { 0x11118d, 0x0 }, + { 0x21118d, 0x0 }, + { 0x1208d, 0x0 }, + { 0x11208d, 0x0 }, + { 0x21208d, 0x0 }, + { 0x1218d, 0x0 }, + { 0x11218d, 0x0 }, + { 0x21218d, 0x0 }, + { 0x1308d, 0x0 }, + { 0x11308d, 0x0 }, + { 0x21308d, 0x0 }, + { 0x1318d, 0x0 }, + { 0x11318d, 0x0 }, + { 0x21318d, 0x0 }, + { 0x100c0, 0x0 }, + { 0x1100c0, 0x0 }, + { 0x2100c0, 0x0 }, + { 0x101c0, 0x0 }, + { 0x1101c0, 0x0 }, + { 0x2101c0, 0x0 }, + { 0x102c0, 0x0 }, + { 0x1102c0, 0x0 }, + { 0x2102c0, 0x0 }, + { 0x103c0, 0x0 }, + { 0x1103c0, 0x0 }, + { 0x2103c0, 0x0 }, + { 0x104c0, 0x0 }, + { 0x1104c0, 0x0 }, + { 0x2104c0, 0x0 }, + { 0x105c0, 0x0 }, + { 0x1105c0, 0x0 }, + { 0x2105c0, 0x0 }, + { 0x106c0, 0x0 }, + { 0x1106c0, 0x0 }, + { 0x2106c0, 0x0 }, + { 0x107c0, 0x0 }, + { 0x1107c0, 0x0 }, + { 0x2107c0, 0x0 }, + { 0x108c0, 0x0 }, + { 0x1108c0, 0x0 }, + { 0x2108c0, 0x0 }, + { 0x110c0, 0x0 }, + { 0x1110c0, 0x0 }, + { 0x2110c0, 0x0 }, + { 0x111c0, 0x0 }, + { 0x1111c0, 0x0 }, + { 0x2111c0, 0x0 }, + { 0x112c0, 0x0 }, + { 0x1112c0, 0x0 }, + { 0x2112c0, 0x0 }, + { 0x113c0, 0x0 }, + { 0x1113c0, 0x0 }, + { 0x2113c0, 0x0 }, + { 0x114c0, 0x0 }, + { 0x1114c0, 0x0 }, + { 0x2114c0, 0x0 }, + { 0x115c0, 0x0 }, + { 0x1115c0, 0x0 }, + { 0x2115c0, 0x0 }, + { 0x116c0, 0x0 }, + { 0x1116c0, 0x0 }, + { 0x2116c0, 0x0 }, + { 0x117c0, 0x0 }, + { 0x1117c0, 0x0 }, + { 0x2117c0, 0x0 }, + { 0x118c0, 0x0 }, + { 0x1118c0, 0x0 }, + { 0x2118c0, 0x0 }, + { 0x120c0, 0x0 }, + { 0x1120c0, 0x0 }, + { 0x2120c0, 0x0 }, + { 0x121c0, 0x0 }, + { 0x1121c0, 0x0 }, + { 0x2121c0, 0x0 }, + { 0x122c0, 0x0 }, + { 0x1122c0, 0x0 }, + { 0x2122c0, 0x0 }, + { 0x123c0, 0x0 }, + { 0x1123c0, 0x0 }, + { 0x2123c0, 0x0 }, + { 0x124c0, 0x0 }, + { 0x1124c0, 0x0 }, + { 0x2124c0, 0x0 }, + { 0x125c0, 0x0 }, + { 0x1125c0, 0x0 }, + { 0x2125c0, 0x0 }, + { 0x126c0, 0x0 }, + { 0x1126c0, 0x0 }, + { 0x2126c0, 0x0 }, + { 0x127c0, 0x0 }, + { 0x1127c0, 0x0 }, + { 0x2127c0, 0x0 }, + { 0x128c0, 0x0 }, + { 0x1128c0, 0x0 }, + { 0x2128c0, 0x0 }, + { 0x130c0, 0x0 }, + { 0x1130c0, 0x0 }, + { 0x2130c0, 0x0 }, + { 0x131c0, 0x0 }, + { 0x1131c0, 0x0 }, + { 0x2131c0, 0x0 }, + { 0x132c0, 0x0 }, + { 0x1132c0, 0x0 }, + { 0x2132c0, 0x0 }, + { 0x133c0, 0x0 }, + { 0x1133c0, 0x0 }, + { 0x2133c0, 0x0 }, + { 0x134c0, 0x0 }, + { 0x1134c0, 0x0 }, + { 0x2134c0, 0x0 }, + { 0x135c0, 0x0 }, + { 0x1135c0, 0x0 }, + { 0x2135c0, 0x0 }, + { 0x136c0, 0x0 }, + { 0x1136c0, 0x0 }, + { 0x2136c0, 0x0 }, + { 0x137c0, 0x0 }, + { 0x1137c0, 0x0 }, + { 0x2137c0, 0x0 }, + { 0x138c0, 0x0 }, + { 0x1138c0, 0x0 }, + { 0x2138c0, 0x0 }, + { 0x100c1, 0x0 }, + { 0x1100c1, 0x0 }, + { 0x2100c1, 0x0 }, + { 0x101c1, 0x0 }, + { 0x1101c1, 0x0 }, + { 0x2101c1, 0x0 }, + { 0x102c1, 0x0 }, + { 0x1102c1, 0x0 }, + { 0x2102c1, 0x0 }, + { 0x103c1, 0x0 }, + { 0x1103c1, 0x0 }, + { 0x2103c1, 0x0 }, + { 0x104c1, 0x0 }, + { 0x1104c1, 0x0 }, + { 0x2104c1, 0x0 }, + { 0x105c1, 0x0 }, + { 0x1105c1, 0x0 }, + { 0x2105c1, 0x0 }, + { 0x106c1, 0x0 }, + { 0x1106c1, 0x0 }, + { 0x2106c1, 0x0 }, + { 0x107c1, 0x0 }, + { 0x1107c1, 0x0 }, + { 0x2107c1, 0x0 }, + { 0x108c1, 0x0 }, + { 0x1108c1, 0x0 }, + { 0x2108c1, 0x0 }, + { 0x110c1, 0x0 }, + { 0x1110c1, 0x0 }, + { 0x2110c1, 0x0 }, + { 0x111c1, 0x0 }, + { 0x1111c1, 0x0 }, + { 0x2111c1, 0x0 }, + { 0x112c1, 0x0 }, + { 0x1112c1, 0x0 }, + { 0x2112c1, 0x0 }, + { 0x113c1, 0x0 }, + { 0x1113c1, 0x0 }, + { 0x2113c1, 0x0 }, + { 0x114c1, 0x0 }, + { 0x1114c1, 0x0 }, + { 0x2114c1, 0x0 }, + { 0x115c1, 0x0 }, + { 0x1115c1, 0x0 }, + { 0x2115c1, 0x0 }, + { 0x116c1, 0x0 }, + { 0x1116c1, 0x0 }, + { 0x2116c1, 0x0 }, + { 0x117c1, 0x0 }, + { 0x1117c1, 0x0 }, + { 0x2117c1, 0x0 }, + { 0x118c1, 0x0 }, + { 0x1118c1, 0x0 }, + { 0x2118c1, 0x0 }, + { 0x120c1, 0x0 }, + { 0x1120c1, 0x0 }, + { 0x2120c1, 0x0 }, + { 0x121c1, 0x0 }, + { 0x1121c1, 0x0 }, + { 0x2121c1, 0x0 }, + { 0x122c1, 0x0 }, + { 0x1122c1, 0x0 }, + { 0x2122c1, 0x0 }, + { 0x123c1, 0x0 }, + { 0x1123c1, 0x0 }, + { 0x2123c1, 0x0 }, + { 0x124c1, 0x0 }, + { 0x1124c1, 0x0 }, + { 0x2124c1, 0x0 }, + { 0x125c1, 0x0 }, + { 0x1125c1, 0x0 }, + { 0x2125c1, 0x0 }, + { 0x126c1, 0x0 }, + { 0x1126c1, 0x0 }, + { 0x2126c1, 0x0 }, + { 0x127c1, 0x0 }, + { 0x1127c1, 0x0 }, + { 0x2127c1, 0x0 }, + { 0x128c1, 0x0 }, + { 0x1128c1, 0x0 }, + { 0x2128c1, 0x0 }, + { 0x130c1, 0x0 }, + { 0x1130c1, 0x0 }, + { 0x2130c1, 0x0 }, + { 0x131c1, 0x0 }, + { 0x1131c1, 0x0 }, + { 0x2131c1, 0x0 }, + { 0x132c1, 0x0 }, + { 0x1132c1, 0x0 }, + { 0x2132c1, 0x0 }, + { 0x133c1, 0x0 }, + { 0x1133c1, 0x0 }, + { 0x2133c1, 0x0 }, + { 0x134c1, 0x0 }, + { 0x1134c1, 0x0 }, + { 0x2134c1, 0x0 }, + { 0x135c1, 0x0 }, + { 0x1135c1, 0x0 }, + { 0x2135c1, 0x0 }, + { 0x136c1, 0x0 }, + { 0x1136c1, 0x0 }, + { 0x2136c1, 0x0 }, + { 0x137c1, 0x0 }, + { 0x1137c1, 0x0 }, + { 0x2137c1, 0x0 }, + { 0x138c1, 0x0 }, + { 0x1138c1, 0x0 }, + { 0x2138c1, 0x0 }, + { 0x10020, 0x0 }, + { 0x110020, 0x0 }, + { 0x210020, 0x0 }, + { 0x11020, 0x0 }, + { 0x111020, 0x0 }, + { 0x211020, 0x0 }, + { 0x12020, 0x0 }, + { 0x112020, 0x0 }, + { 0x212020, 0x0 }, + { 0x13020, 0x0 }, + { 0x113020, 0x0 }, + { 0x213020, 0x0 }, + { 0x20072, 0x0 }, + { 0x20073, 0x0 }, + { 0x20074, 0x0 }, + { 0x100aa, 0x0 }, + { 0x110aa, 0x0 }, + { 0x120aa, 0x0 }, + { 0x130aa, 0x0 }, + { 0x20010, 0x0 }, + { 0x120010, 0x0 }, + { 0x220010, 0x0 }, + { 0x20011, 0x0 }, + { 0x120011, 0x0 }, + { 0x220011, 0x0 }, + { 0x100ae, 0x0 }, + { 0x1100ae, 0x0 }, + { 0x2100ae, 0x0 }, + { 0x100af, 0x0 }, + { 0x1100af, 0x0 }, + { 0x2100af, 0x0 }, + { 0x110ae, 0x0 }, + { 0x1110ae, 0x0 }, + { 0x2110ae, 0x0 }, + { 0x110af, 0x0 }, + { 0x1110af, 0x0 }, + { 0x2110af, 0x0 }, + { 0x120ae, 0x0 }, + { 0x1120ae, 0x0 }, + { 0x2120ae, 0x0 }, + { 0x120af, 0x0 }, + { 0x1120af, 0x0 }, + { 0x2120af, 0x0 }, + { 0x130ae, 0x0 }, + { 0x1130ae, 0x0 }, + { 0x2130ae, 0x0 }, + { 0x130af, 0x0 }, + { 0x1130af, 0x0 }, + { 0x2130af, 0x0 }, + { 0x20020, 0x0 }, + { 0x120020, 0x0 }, + { 0x220020, 0x0 }, + { 0x100a0, 0x0 }, + { 0x100a1, 0x0 }, + { 0x100a2, 0x0 }, + { 0x100a3, 0x0 }, + { 0x100a4, 0x0 }, + { 0x100a5, 0x0 }, + { 0x100a6, 0x0 }, + { 0x100a7, 0x0 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x0 }, + { 0x110a2, 0x0 }, + { 0x110a3, 0x0 }, + { 0x110a4, 0x0 }, + { 0x110a5, 0x0 }, + { 0x110a6, 0x0 }, + { 0x110a7, 0x0 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x0 }, + { 0x120a2, 0x0 }, + { 0x120a3, 0x0 }, + { 0x120a4, 0x0 }, + { 0x120a5, 0x0 }, + { 0x120a6, 0x0 }, + { 0x120a7, 0x0 }, + { 0x130a0, 0x0 }, + { 0x130a1, 0x0 }, + { 0x130a2, 0x0 }, + { 0x130a3, 0x0 }, + { 0x130a4, 0x0 }, + { 0x130a5, 0x0 }, + { 0x130a6, 0x0 }, + { 0x130a7, 0x0 }, + { 0x2007c, 0x0 }, + { 0x12007c, 0x0 }, + { 0x22007c, 0x0 }, + { 0x2007d, 0x0 }, + { 0x12007d, 0x0 }, + { 0x22007d, 0x0 }, + { 0x400fd, 0x0 }, + { 0x400c0, 0x0 }, + { 0x90201, 0x0 }, + { 0x190201, 0x0 }, + { 0x290201, 0x0 }, + { 0x90202, 0x0 }, + { 0x190202, 0x0 }, + { 0x290202, 0x0 }, + { 0x90203, 0x0 }, + { 0x190203, 0x0 }, + { 0x290203, 0x0 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x90205, 0x0 }, + { 0x190205, 0x0 }, + { 0x290205, 0x0 }, + { 0x90206, 0x0 }, + { 0x190206, 0x0 }, + { 0x290206, 0x0 }, + { 0x90207, 0x0 }, + { 0x190207, 0x0 }, + { 0x290207, 0x0 }, + { 0x90208, 0x0 }, + { 0x190208, 0x0 }, + { 0x290208, 0x0 }, + { 0x10062, 0x0 }, + { 0x10162, 0x0 }, + { 0x10262, 0x0 }, + { 0x10362, 0x0 }, + { 0x10462, 0x0 }, + { 0x10562, 0x0 }, + { 0x10662, 0x0 }, + { 0x10762, 0x0 }, + { 0x10862, 0x0 }, + { 0x11062, 0x0 }, + { 0x11162, 0x0 }, + { 0x11262, 0x0 }, + { 0x11362, 0x0 }, + { 0x11462, 0x0 }, + { 0x11562, 0x0 }, + { 0x11662, 0x0 }, + { 0x11762, 0x0 }, + { 0x11862, 0x0 }, + { 0x12062, 0x0 }, + { 0x12162, 0x0 }, + { 0x12262, 0x0 }, + { 0x12362, 0x0 }, + { 0x12462, 0x0 }, + { 0x12562, 0x0 }, + { 0x12662, 0x0 }, + { 0x12762, 0x0 }, + { 0x12862, 0x0 }, + { 0x13062, 0x0 }, + { 0x13162, 0x0 }, + { 0x13262, 0x0 }, + { 0x13362, 0x0 }, + { 0x13462, 0x0 }, + { 0x13562, 0x0 }, + { 0x13662, 0x0 }, + { 0x13762, 0x0 }, + { 0x13862, 0x0 }, + { 0x20077, 0x0 }, + { 0x10001, 0x0 }, + { 0x11001, 0x0 }, + { 0x12001, 0x0 }, + { 0x13001, 0x0 }, + { 0x10040, 0x0 }, + { 0x10140, 0x0 }, + { 0x10240, 0x0 }, + { 0x10340, 0x0 }, + { 0x10440, 0x0 }, + { 0x10540, 0x0 }, + { 0x10640, 0x0 }, + { 0x10740, 0x0 }, + { 0x10840, 0x0 }, + { 0x10030, 0x0 }, + { 0x10130, 0x0 }, + { 0x10230, 0x0 }, + { 0x10330, 0x0 }, + { 0x10430, 0x0 }, + { 0x10530, 0x0 }, + { 0x10630, 0x0 }, + { 0x10730, 0x0 }, + { 0x10830, 0x0 }, + { 0x11040, 0x0 }, + { 0x11140, 0x0 }, + { 0x11240, 0x0 }, + { 0x11340, 0x0 }, + { 0x11440, 0x0 }, + { 0x11540, 0x0 }, + { 0x11640, 0x0 }, + { 0x11740, 0x0 }, + { 0x11840, 0x0 }, + { 0x11030, 0x0 }, + { 0x11130, 0x0 }, + { 0x11230, 0x0 }, + { 0x11330, 0x0 }, + { 0x11430, 0x0 }, + { 0x11530, 0x0 }, + { 0x11630, 0x0 }, + { 0x11730, 0x0 }, + { 0x11830, 0x0 }, + { 0x12040, 0x0 }, + { 0x12140, 0x0 }, + { 0x12240, 0x0 }, + { 0x12340, 0x0 }, + { 0x12440, 0x0 }, + { 0x12540, 0x0 }, + { 0x12640, 0x0 }, + { 0x12740, 0x0 }, + { 0x12840, 0x0 }, + { 0x12030, 0x0 }, + { 0x12130, 0x0 }, + { 0x12230, 0x0 }, + { 0x12330, 0x0 }, + { 0x12430, 0x0 }, + { 0x12530, 0x0 }, + { 0x12630, 0x0 }, + { 0x12730, 0x0 }, + { 0x12830, 0x0 }, + { 0x13040, 0x0 }, + { 0x13140, 0x0 }, + { 0x13240, 0x0 }, + { 0x13340, 0x0 }, + { 0x13440, 0x0 }, + { 0x13540, 0x0 }, + { 0x13640, 0x0 }, + { 0x13740, 0x0 }, + { 0x13840, 0x0 }, + { 0x13030, 0x0 }, + { 0x13130, 0x0 }, + { 0x13230, 0x0 }, + { 0x13330, 0x0 }, + { 0x13430, 0x0 }, + { 0x13530, 0x0 }, + { 0x13630, 0x0 }, + { 0x13730, 0x0 }, + { 0x13830, 0x0 }, +}; + +/* P0 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xbb8 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x131f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x54012, 0x110 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x1 }, + { 0x54032, 0xd400 }, + { 0x54033, 0x312d }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0xd400 }, + { 0x54039, 0x312d }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P1 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp1_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x101 }, + { 0x54003, 0x190 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x54012, 0x110 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x1 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3100 }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3100 }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P2 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp2_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x102 }, + { 0x54003, 0x64 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x54012, 0x110 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x1 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3100 }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3100 }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P0 2D message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xbb8 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x61 }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54010, 0x1f7f }, + { 0x54012, 0x110 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x1 }, + { 0x54032, 0xd400 }, + { 0x54033, 0x312d }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0xd400 }, + { 0x54039, 0x312d }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +static struct dram_cfg_param ddr_phy_pie[] = { + { 0xd0000, 0x0 }, + { 0x90000, 0x10 }, + { 0x90001, 0x400 }, + { 0x90002, 0x10e }, + { 0x90003, 0x0 }, + { 0x90004, 0x0 }, + { 0x90005, 0x8 }, + { 0x90029, 0xb }, + { 0x9002a, 0x480 }, + { 0x9002b, 0x109 }, + { 0x9002c, 0x8 }, + { 0x9002d, 0x448 }, + { 0x9002e, 0x139 }, + { 0x9002f, 0x8 }, + { 0x90030, 0x478 }, + { 0x90031, 0x109 }, + { 0x90032, 0x0 }, + { 0x90033, 0xe8 }, + { 0x90034, 0x109 }, + { 0x90035, 0x2 }, + { 0x90036, 0x10 }, + { 0x90037, 0x139 }, + { 0x90038, 0xf }, + { 0x90039, 0x7c0 }, + { 0x9003a, 0x139 }, + { 0x9003b, 0x44 }, + { 0x9003c, 0x630 }, + { 0x9003d, 0x159 }, + { 0x9003e, 0x14f }, + { 0x9003f, 0x630 }, + { 0x90040, 0x159 }, + { 0x90041, 0x47 }, + { 0x90042, 0x630 }, + { 0x90043, 0x149 }, + { 0x90044, 0x4f }, + { 0x90045, 0x630 }, + { 0x90046, 0x179 }, + { 0x90047, 0x8 }, + { 0x90048, 0xe0 }, + { 0x90049, 0x109 }, + { 0x9004a, 0x0 }, + { 0x9004b, 0x7c8 }, + { 0x9004c, 0x109 }, + { 0x9004d, 0x0 }, + { 0x9004e, 0x1 }, + { 0x9004f, 0x8 }, + { 0x90050, 0x0 }, + { 0x90051, 0x45a }, + { 0x90052, 0x9 }, + { 0x90053, 0x0 }, + { 0x90054, 0x448 }, + { 0x90055, 0x109 }, + { 0x90056, 0x40 }, + { 0x90057, 0x630 }, + { 0x90058, 0x179 }, + { 0x90059, 0x1 }, + { 0x9005a, 0x618 }, + { 0x9005b, 0x109 }, + { 0x9005c, 0x40c0 }, + { 0x9005d, 0x630 }, + { 0x9005e, 0x149 }, + { 0x9005f, 0x8 }, + { 0x90060, 0x4 }, + { 0x90061, 0x48 }, + { 0x90062, 0x4040 }, + { 0x90063, 0x630 }, + { 0x90064, 0x149 }, + { 0x90065, 0x0 }, + { 0x90066, 0x4 }, + { 0x90067, 0x48 }, + { 0x90068, 0x40 }, + { 0x90069, 0x630 }, + { 0x9006a, 0x149 }, + { 0x9006b, 0x10 }, + { 0x9006c, 0x4 }, + { 0x9006d, 0x18 }, + { 0x9006e, 0x0 }, + { 0x9006f, 0x4 }, + { 0x90070, 0x78 }, + { 0x90071, 0x549 }, + { 0x90072, 0x630 }, + { 0x90073, 0x159 }, + { 0x90074, 0xd49 }, + { 0x90075, 0x630 }, + { 0x90076, 0x159 }, + { 0x90077, 0x94a }, + { 0x90078, 0x630 }, + { 0x90079, 0x159 }, + { 0x9007a, 0x441 }, + { 0x9007b, 0x630 }, + { 0x9007c, 0x149 }, + { 0x9007d, 0x42 }, + { 0x9007e, 0x630 }, + { 0x9007f, 0x149 }, + { 0x90080, 0x1 }, + { 0x90081, 0x630 }, + { 0x90082, 0x149 }, + { 0x90083, 0x0 }, + { 0x90084, 0xe0 }, + { 0x90085, 0x109 }, + { 0x90086, 0xa }, + { 0x90087, 0x10 }, + { 0x90088, 0x109 }, + { 0x90089, 0x9 }, + { 0x9008a, 0x3c0 }, + { 0x9008b, 0x149 }, + { 0x9008c, 0x9 }, + { 0x9008d, 0x3c0 }, + { 0x9008e, 0x159 }, + { 0x9008f, 0x18 }, + { 0x90090, 0x10 }, + { 0x90091, 0x109 }, + { 0x90092, 0x0 }, + { 0x90093, 0x3c0 }, + { 0x90094, 0x109 }, + { 0x90095, 0x18 }, + { 0x90096, 0x4 }, + { 0x90097, 0x48 }, + { 0x90098, 0x18 }, + { 0x90099, 0x4 }, + { 0x9009a, 0x58 }, + { 0x9009b, 0xa }, + { 0x9009c, 0x10 }, + { 0x9009d, 0x109 }, + { 0x9009e, 0x2 }, + { 0x9009f, 0x10 }, + { 0x900a0, 0x109 }, + { 0x900a1, 0x5 }, + { 0x900a2, 0x7c0 }, + { 0x900a3, 0x109 }, + { 0x900a4, 0x10 }, + { 0x900a5, 0x10 }, + { 0x900a6, 0x109 }, + { 0x40000, 0x811 }, + { 0x40020, 0x880 }, + { 0x40040, 0x0 }, + { 0x40060, 0x0 }, + { 0x40001, 0x4008 }, + { 0x40021, 0x83 }, + { 0x40041, 0x4f }, + { 0x40061, 0x0 }, + { 0x40002, 0x4040 }, + { 0x40022, 0x83 }, + { 0x40042, 0x51 }, + { 0x40062, 0x0 }, + { 0x40003, 0x811 }, + { 0x40023, 0x880 }, + { 0x40043, 0x0 }, + { 0x40063, 0x0 }, + { 0x40004, 0x720 }, + { 0x40024, 0xf }, + { 0x40044, 0x1740 }, + { 0x40064, 0x0 }, + { 0x40005, 0x16 }, + { 0x40025, 0x83 }, + { 0x40045, 0x4b }, + { 0x40065, 0x0 }, + { 0x40006, 0x716 }, + { 0x40026, 0xf }, + { 0x40046, 0x2001 }, + { 0x40066, 0x0 }, + { 0x40007, 0x716 }, + { 0x40027, 0xf }, + { 0x40047, 0x2800 }, + { 0x40067, 0x0 }, + { 0x40008, 0x716 }, + { 0x40028, 0xf }, + { 0x40048, 0xf00 }, + { 0x40068, 0x0 }, + { 0x40009, 0x720 }, + { 0x40029, 0xf }, + { 0x40049, 0x1400 }, + { 0x40069, 0x0 }, + { 0x4000a, 0xe08 }, + { 0x4002a, 0xc15 }, + { 0x4004a, 0x0 }, + { 0x4006a, 0x0 }, + { 0x4000b, 0x623 }, + { 0x4002b, 0x15 }, + { 0x4004b, 0x0 }, + { 0x4006b, 0x0 }, + { 0x4000c, 0x4028 }, + { 0x4002c, 0x80 }, + { 0x4004c, 0x0 }, + { 0x4006c, 0x0 }, + { 0x4000d, 0xe08 }, + { 0x4002d, 0xc1a }, + { 0x4004d, 0x0 }, + { 0x4006d, 0x0 }, + { 0x4000e, 0x623 }, + { 0x4002e, 0x1a }, + { 0x4004e, 0x0 }, + { 0x4006e, 0x0 }, + { 0x4000f, 0x4040 }, + { 0x4002f, 0x80 }, + { 0x4004f, 0x0 }, + { 0x4006f, 0x0 }, + { 0x40010, 0x2604 }, + { 0x40030, 0x15 }, + { 0x40050, 0x0 }, + { 0x40070, 0x0 }, + { 0x40011, 0x708 }, + { 0x40031, 0x5 }, + { 0x40051, 0x0 }, + { 0x40071, 0x2002 }, + { 0x40012, 0x8 }, + { 0x40032, 0x80 }, + { 0x40052, 0x0 }, + { 0x40072, 0x0 }, + { 0x40013, 0x2604 }, + { 0x40033, 0x1a }, + { 0x40053, 0x0 }, + { 0x40073, 0x0 }, + { 0x40014, 0x708 }, + { 0x40034, 0xa }, + { 0x40054, 0x0 }, + { 0x40074, 0x2002 }, + { 0x40015, 0x4040 }, + { 0x40035, 0x80 }, + { 0x40055, 0x0 }, + { 0x40075, 0x0 }, + { 0x40016, 0x60a }, + { 0x40036, 0x15 }, + { 0x40056, 0x1200 }, + { 0x40076, 0x0 }, + { 0x40017, 0x61a }, + { 0x40037, 0x15 }, + { 0x40057, 0x1300 }, + { 0x40077, 0x0 }, + { 0x40018, 0x60a }, + { 0x40038, 0x1a }, + { 0x40058, 0x1200 }, + { 0x40078, 0x0 }, + { 0x40019, 0x642 }, + { 0x40039, 0x1a }, + { 0x40059, 0x1300 }, + { 0x40079, 0x0 }, + { 0x4001a, 0x4808 }, + { 0x4003a, 0x880 }, + { 0x4005a, 0x0 }, + { 0x4007a, 0x0 }, + { 0x900a7, 0x0 }, + { 0x900a8, 0x790 }, + { 0x900a9, 0x11a }, + { 0x900aa, 0x8 }, + { 0x900ab, 0x7aa }, + { 0x900ac, 0x2a }, + { 0x900ad, 0x10 }, + { 0x900ae, 0x7b2 }, + { 0x900af, 0x2a }, + { 0x900b0, 0x0 }, + { 0x900b1, 0x7c8 }, + { 0x900b2, 0x109 }, + { 0x900b3, 0x10 }, + { 0x900b4, 0x2a8 }, + { 0x900b5, 0x129 }, + { 0x900b6, 0x8 }, + { 0x900b7, 0x370 }, + { 0x900b8, 0x129 }, + { 0x900b9, 0xa }, + { 0x900ba, 0x3c8 }, + { 0x900bb, 0x1a9 }, + { 0x900bc, 0xc }, + { 0x900bd, 0x408 }, + { 0x900be, 0x199 }, + { 0x900bf, 0x14 }, + { 0x900c0, 0x790 }, + { 0x900c1, 0x11a }, + { 0x900c2, 0x8 }, + { 0x900c3, 0x4 }, + { 0x900c4, 0x18 }, + { 0x900c5, 0xe }, + { 0x900c6, 0x408 }, + { 0x900c7, 0x199 }, + { 0x900c8, 0x8 }, + { 0x900c9, 0x8568 }, + { 0x900ca, 0x108 }, + { 0x900cb, 0x18 }, + { 0x900cc, 0x790 }, + { 0x900cd, 0x16a }, + { 0x900ce, 0x8 }, + { 0x900cf, 0x1d8 }, + { 0x900d0, 0x169 }, + { 0x900d1, 0x10 }, + { 0x900d2, 0x8558 }, + { 0x900d3, 0x168 }, + { 0x900d4, 0x70 }, + { 0x900d5, 0x788 }, + { 0x900d6, 0x16a }, + { 0x900d7, 0x1ff8 }, + { 0x900d8, 0x85a8 }, + { 0x900d9, 0x1e8 }, + { 0x900da, 0x50 }, + { 0x900db, 0x798 }, + { 0x900dc, 0x16a }, + { 0x900dd, 0x60 }, + { 0x900de, 0x7a0 }, + { 0x900df, 0x16a }, + { 0x900e0, 0x8 }, + { 0x900e1, 0x8310 }, + { 0x900e2, 0x168 }, + { 0x900e3, 0x8 }, + { 0x900e4, 0xa310 }, + { 0x900e5, 0x168 }, + { 0x900e6, 0xa }, + { 0x900e7, 0x408 }, + { 0x900e8, 0x169 }, + { 0x900e9, 0x6e }, + { 0x900ea, 0x0 }, + { 0x900eb, 0x68 }, + { 0x900ec, 0x0 }, + { 0x900ed, 0x408 }, + { 0x900ee, 0x169 }, + { 0x900ef, 0x0 }, + { 0x900f0, 0x8310 }, + { 0x900f1, 0x168 }, + { 0x900f2, 0x0 }, + { 0x900f3, 0xa310 }, + { 0x900f4, 0x168 }, + { 0x900f5, 0x1ff8 }, + { 0x900f6, 0x85a8 }, + { 0x900f7, 0x1e8 }, + { 0x900f8, 0x68 }, + { 0x900f9, 0x798 }, + { 0x900fa, 0x16a }, + { 0x900fb, 0x78 }, + { 0x900fc, 0x7a0 }, + { 0x900fd, 0x16a }, + { 0x900fe, 0x68 }, + { 0x900ff, 0x790 }, + { 0x90100, 0x16a }, + { 0x90101, 0x8 }, + { 0x90102, 0x8b10 }, + { 0x90103, 0x168 }, + { 0x90104, 0x8 }, + { 0x90105, 0xab10 }, + { 0x90106, 0x168 }, + { 0x90107, 0xa }, + { 0x90108, 0x408 }, + { 0x90109, 0x169 }, + { 0x9010a, 0x58 }, + { 0x9010b, 0x0 }, + { 0x9010c, 0x68 }, + { 0x9010d, 0x0 }, + { 0x9010e, 0x408 }, + { 0x9010f, 0x169 }, + { 0x90110, 0x0 }, + { 0x90111, 0x8b10 }, + { 0x90112, 0x168 }, + { 0x90113, 0x0 }, + { 0x90114, 0xab10 }, + { 0x90115, 0x168 }, + { 0x90116, 0x0 }, + { 0x90117, 0x1d8 }, + { 0x90118, 0x169 }, + { 0x90119, 0x80 }, + { 0x9011a, 0x790 }, + { 0x9011b, 0x16a }, + { 0x9011c, 0x18 }, + { 0x9011d, 0x7aa }, + { 0x9011e, 0x6a }, + { 0x9011f, 0xa }, + { 0x90120, 0x0 }, + { 0x90121, 0x1e9 }, + { 0x90122, 0x8 }, + { 0x90123, 0x8080 }, + { 0x90124, 0x108 }, + { 0x90125, 0xf }, + { 0x90126, 0x408 }, + { 0x90127, 0x169 }, + { 0x90128, 0xc }, + { 0x90129, 0x0 }, + { 0x9012a, 0x68 }, + { 0x9012b, 0x9 }, + { 0x9012c, 0x0 }, + { 0x9012d, 0x1a9 }, + { 0x9012e, 0x0 }, + { 0x9012f, 0x408 }, + { 0x90130, 0x169 }, + { 0x90131, 0x0 }, + { 0x90132, 0x8080 }, + { 0x90133, 0x108 }, + { 0x90134, 0x8 }, + { 0x90135, 0x7aa }, + { 0x90136, 0x6a }, + { 0x90137, 0x0 }, + { 0x90138, 0x8568 }, + { 0x90139, 0x108 }, + { 0x9013a, 0xb7 }, + { 0x9013b, 0x790 }, + { 0x9013c, 0x16a }, + { 0x9013d, 0x1f }, + { 0x9013e, 0x0 }, + { 0x9013f, 0x68 }, + { 0x90140, 0x8 }, + { 0x90141, 0x8558 }, + { 0x90142, 0x168 }, + { 0x90143, 0xf }, + { 0x90144, 0x408 }, + { 0x90145, 0x169 }, + { 0x90146, 0xc }, + { 0x90147, 0x0 }, + { 0x90148, 0x68 }, + { 0x90149, 0x0 }, + { 0x9014a, 0x408 }, + { 0x9014b, 0x169 }, + { 0x9014c, 0x0 }, + { 0x9014d, 0x8558 }, + { 0x9014e, 0x168 }, + { 0x9014f, 0x8 }, + { 0x90150, 0x3c8 }, + { 0x90151, 0x1a9 }, + { 0x90152, 0x3 }, + { 0x90153, 0x370 }, + { 0x90154, 0x129 }, + { 0x90155, 0x20 }, + { 0x90156, 0x2aa }, + { 0x90157, 0x9 }, + { 0x90158, 0x0 }, + { 0x90159, 0x400 }, + { 0x9015a, 0x10e }, + { 0x9015b, 0x8 }, + { 0x9015c, 0xe8 }, + { 0x9015d, 0x109 }, + { 0x9015e, 0x0 }, + { 0x9015f, 0x8140 }, + { 0x90160, 0x10c }, + { 0x90161, 0x10 }, + { 0x90162, 0x8138 }, + { 0x90163, 0x10c }, + { 0x90164, 0x8 }, + { 0x90165, 0x7c8 }, + { 0x90166, 0x101 }, + { 0x90167, 0x8 }, + { 0x90168, 0x0 }, + { 0x90169, 0x8 }, + { 0x9016a, 0x8 }, + { 0x9016b, 0x448 }, + { 0x9016c, 0x109 }, + { 0x9016d, 0xf }, + { 0x9016e, 0x7c0 }, + { 0x9016f, 0x109 }, + { 0x90170, 0x0 }, + { 0x90171, 0xe8 }, + { 0x90172, 0x109 }, + { 0x90173, 0x47 }, + { 0x90174, 0x630 }, + { 0x90175, 0x109 }, + { 0x90176, 0x8 }, + { 0x90177, 0x618 }, + { 0x90178, 0x109 }, + { 0x90179, 0x8 }, + { 0x9017a, 0xe0 }, + { 0x9017b, 0x109 }, + { 0x9017c, 0x0 }, + { 0x9017d, 0x7c8 }, + { 0x9017e, 0x109 }, + { 0x9017f, 0x8 }, + { 0x90180, 0x8140 }, + { 0x90181, 0x10c }, + { 0x90182, 0x0 }, + { 0x90183, 0x1 }, + { 0x90184, 0x8 }, + { 0x90185, 0x8 }, + { 0x90186, 0x4 }, + { 0x90187, 0x8 }, + { 0x90188, 0x8 }, + { 0x90189, 0x7c8 }, + { 0x9018a, 0x101 }, + { 0x90006, 0x0 }, + { 0x90007, 0x0 }, + { 0x90008, 0x8 }, + { 0x90009, 0x0 }, + { 0x9000a, 0x0 }, + { 0x9000b, 0x0 }, + { 0xd00e7, 0x400 }, + { 0x90017, 0x0 }, + { 0x9001f, 0x2a }, + { 0x90026, 0x6a }, + { 0x400d0, 0x0 }, + { 0x400d1, 0x101 }, + { 0x400d2, 0x105 }, + { 0x400d3, 0x107 }, + { 0x400d4, 0x10f }, + { 0x400d5, 0x202 }, + { 0x400d6, 0x20a }, + { 0x400d7, 0x20b }, + { 0x2003a, 0x2 }, + { 0x2000b, 0x5d }, + { 0x2000c, 0xbb }, + { 0x2000d, 0x753 }, + { 0x2000e, 0x2c }, + { 0x12000b, 0xc }, + { 0x12000c, 0x19 }, + { 0x12000d, 0xfa }, + { 0x12000e, 0x10 }, + { 0x22000b, 0x3 }, + { 0x22000c, 0x6 }, + { 0x22000d, 0x3e }, + { 0x22000e, 0x10 }, + { 0x9000c, 0x0 }, + { 0x9000d, 0x173 }, + { 0x9000e, 0x60 }, + { 0x9000f, 0x6110 }, + { 0x90010, 0x2152 }, + { 0x90011, 0xdfbd }, + { 0x90012, 0x60 }, + { 0x90013, 0x6152 }, + { 0x20010, 0x5a }, + { 0x20011, 0x3 }, + { 0x120010, 0x5a }, + { 0x120011, 0x3 }, + { 0x220010, 0x5a }, + { 0x220011, 0x3 }, + { 0x40080, 0xe0 }, + { 0x40081, 0x12 }, + { 0x40082, 0xe0 }, + { 0x40083, 0x12 }, + { 0x40084, 0xe0 }, + { 0x40085, 0x12 }, + { 0x140080, 0xe0 }, + { 0x140081, 0x12 }, + { 0x140082, 0xe0 }, + { 0x140083, 0x12 }, + { 0x140084, 0xe0 }, + { 0x140085, 0x12 }, + { 0x240080, 0xe0 }, + { 0x240081, 0x12 }, + { 0x240082, 0xe0 }, + { 0x240083, 0x12 }, + { 0x240084, 0xe0 }, + { 0x240085, 0x12 }, + { 0x400fd, 0xf }, + { 0x10011, 0x1 }, + { 0x10012, 0x1 }, + { 0x10013, 0x180 }, + { 0x10018, 0x1 }, + { 0x10002, 0x6209 }, + { 0x100b2, 0x1 }, + { 0x101b4, 0x1 }, + { 0x102b4, 0x1 }, + { 0x103b4, 0x1 }, + { 0x104b4, 0x1 }, + { 0x105b4, 0x1 }, + { 0x106b4, 0x1 }, + { 0x107b4, 0x1 }, + { 0x108b4, 0x1 }, + { 0x11011, 0x1 }, + { 0x11012, 0x1 }, + { 0x11013, 0x180 }, + { 0x11018, 0x1 }, + { 0x11002, 0x6209 }, + { 0x110b2, 0x1 }, + { 0x111b4, 0x1 }, + { 0x112b4, 0x1 }, + { 0x113b4, 0x1 }, + { 0x114b4, 0x1 }, + { 0x115b4, 0x1 }, + { 0x116b4, 0x1 }, + { 0x117b4, 0x1 }, + { 0x118b4, 0x1 }, + { 0x12011, 0x1 }, + { 0x12012, 0x1 }, + { 0x12013, 0x180 }, + { 0x12018, 0x1 }, + { 0x12002, 0x6209 }, + { 0x120b2, 0x1 }, + { 0x121b4, 0x1 }, + { 0x122b4, 0x1 }, + { 0x123b4, 0x1 }, + { 0x124b4, 0x1 }, + { 0x125b4, 0x1 }, + { 0x126b4, 0x1 }, + { 0x127b4, 0x1 }, + { 0x128b4, 0x1 }, + { 0x13011, 0x1 }, + { 0x13012, 0x1 }, + { 0x13013, 0x180 }, + { 0x13018, 0x1 }, + { 0x13002, 0x6209 }, + { 0x130b2, 0x1 }, + { 0x131b4, 0x1 }, + { 0x132b4, 0x1 }, + { 0x133b4, 0x1 }, + { 0x134b4, 0x1 }, + { 0x135b4, 0x1 }, + { 0x136b4, 0x1 }, + { 0x137b4, 0x1 }, + { 0x138b4, 0x1 }, + { 0x2003a, 0x2 }, + { 0xc0080, 0x2 }, + { 0xd0000, 0x1 } +}; + +static struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 3000mts 1D */ + .drate = 3000, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 400mts 1D */ + .drate = 400, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P2 100mts 1D */ + .drate = 100, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp2_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg), + }, + { + /* P0 3000mts 2D */ + .drate = 3000, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dmo_imx8mm_sbc_dram_timing_16_32 = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 3000, 400, 100, }, +}; diff --git a/board/data_modul/imx8mm_edm_sbc/lpddr4_timing_4G_32.c b/board/data_modul/imx8mm_edm_sbc/lpddr4_timing_4G_32.c new file mode 100644 index 00000000000..e44c1ea2772 --- /dev/null +++ b/board/data_modul/imx8mm_edm_sbc/lpddr4_timing_4G_32.c @@ -0,0 +1,1842 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 NXP + * + * Generated code from MX8M_DDR_tool + * Align with uboot version: + * imx_v2018.03_4.14.78_1.0.0_ga ~ imx_v2018.04_4.19.35_1.0.0_ga + */ + +#include <linux/kernel.h> +#include <asm/arch/ddr.h> + +static struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + { 0x3d400304, 0x1 }, + { 0x3d400030, 0x1 }, + { 0x3d400000, 0xa3080020 }, + { 0x3d400020, 0x203 }, + { 0x3d400024, 0x3a980 }, + { 0x3d400064, 0x5b00d2 }, + { 0x3d4000d0, 0xc00305ba }, + { 0x3d4000d4, 0x940000 }, + { 0x3d4000dc, 0xd4002d }, + { 0x3d4000e0, 0x310000 }, + { 0x3d4000e8, 0x66004d }, + { 0x3d4000ec, 0x16004d }, + { 0x3d400100, 0x191e1920 }, + { 0x3d400104, 0x60630 }, + { 0x3d40010c, 0xb0b000 }, + { 0x3d400110, 0xe04080e }, + { 0x3d400114, 0x2040c0c }, + { 0x3d400118, 0x1010007 }, + { 0x3d40011c, 0x401 }, + { 0x3d400130, 0x20600 }, + { 0x3d400134, 0xc100002 }, + { 0x3d400138, 0xd8 }, + { 0x3d400144, 0x96004b }, + { 0x3d400180, 0x2ee0017 }, + { 0x3d400184, 0x2605b8e }, + { 0x3d400188, 0x0 }, + { 0x3d400190, 0x497820a }, + { 0x3d400194, 0x80303 }, + { 0x3d4001b4, 0x170a }, + { 0x3d4001a0, 0xe0400018 }, + { 0x3d4001a4, 0xdf00e4 }, + { 0x3d4001a8, 0x80000000 }, + { 0x3d4001b0, 0x11 }, + { 0x3d4001c0, 0x1 }, + { 0x3d4001c4, 0x1 }, + { 0x3d4000f4, 0xc99 }, + { 0x3d400108, 0x70e1617 }, + { 0x3d400200, 0x17 }, + { 0x3d40020c, 0x0 }, + { 0x3d400210, 0x1f1f }, + { 0x3d400204, 0x80808 }, + { 0x3d400214, 0x7070707 }, + { 0x3d400218, 0x7070707 }, + { 0x3d400250, 0x29001701 }, + { 0x3d400254, 0x2c }, + { 0x3d40025c, 0x4000030 }, + { 0x3d400264, 0x900093e7 }, + { 0x3d40026c, 0x2005574 }, + { 0x3d400400, 0x111 }, + { 0x3d400408, 0x72ff }, + { 0x3d400494, 0x2100e07 }, + { 0x3d400498, 0x620096 }, + { 0x3d40049c, 0x1100e07 }, + { 0x3d4004a0, 0xc8012c }, + { 0x3d402020, 0x1 }, + { 0x3d402024, 0x7d00 }, + { 0x3d402050, 0x20d040 }, + { 0x3d402064, 0xc001c }, + { 0x3d4020dc, 0x840000 }, + { 0x3d4020e0, 0x310000 }, + { 0x3d4020e8, 0x66004d }, + { 0x3d4020ec, 0x16004d }, + { 0x3d402100, 0xa040305 }, + { 0x3d402104, 0x30407 }, + { 0x3d402108, 0x203060b }, + { 0x3d40210c, 0x505000 }, + { 0x3d402110, 0x2040202 }, + { 0x3d402114, 0x2030202 }, + { 0x3d402118, 0x1010004 }, + { 0x3d40211c, 0x301 }, + { 0x3d402130, 0x20300 }, + { 0x3d402134, 0xa100002 }, + { 0x3d402138, 0x1d }, + { 0x3d402144, 0x14000a }, + { 0x3d402180, 0x640004 }, + { 0x3d402190, 0x3818200 }, + { 0x3d402194, 0x80303 }, + { 0x3d4021b4, 0x100 }, + { 0x3d4020f4, 0xc99 }, + { 0x3d403020, 0x1 }, + { 0x3d403024, 0x1f40 }, + { 0x3d403050, 0x20d040 }, + { 0x3d403064, 0x30007 }, + { 0x3d4030dc, 0x840000 }, + { 0x3d4030e0, 0x310000 }, + { 0x3d4030e8, 0x66004d }, + { 0x3d4030ec, 0x16004d }, + { 0x3d403100, 0xa010102 }, + { 0x3d403104, 0x30404 }, + { 0x3d403108, 0x203060b }, + { 0x3d40310c, 0x505000 }, + { 0x3d403110, 0x2040202 }, + { 0x3d403114, 0x2030202 }, + { 0x3d403118, 0x1010004 }, + { 0x3d40311c, 0x301 }, + { 0x3d403130, 0x20300 }, + { 0x3d403134, 0xa100002 }, + { 0x3d403138, 0x8 }, + { 0x3d403144, 0x50003 }, + { 0x3d403180, 0x190004 }, + { 0x3d403190, 0x3818200 }, + { 0x3d403194, 0x80303 }, + { 0x3d4031b4, 0x100 }, + { 0x3d4030f4, 0xc99 }, + { 0x3d400028, 0x0 }, +}; + +/* PHY Initialize Configuration */ +static struct dram_cfg_param ddr_ddrphy_cfg[] = { + { 0x100a0, 0x6 }, + { 0x100a1, 0x7 }, + { 0x100a2, 0x0 }, + { 0x100a3, 0x1 }, + { 0x100a4, 0x3 }, + { 0x100a5, 0x2 }, + { 0x100a6, 0x4 }, + { 0x100a7, 0x5 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x1 }, + { 0x110a2, 0x5 }, + { 0x110a3, 0x3 }, + { 0x110a4, 0x2 }, + { 0x110a5, 0x4 }, + { 0x110a6, 0x6 }, + { 0x110a7, 0x7 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x1 }, + { 0x120a2, 0x5 }, + { 0x120a3, 0x3 }, + { 0x120a4, 0x2 }, + { 0x120a5, 0x4 }, + { 0x120a6, 0x6 }, + { 0x120a7, 0x7 }, + { 0x130a0, 0x6 }, + { 0x130a1, 0x7 }, + { 0x130a2, 0x0 }, + { 0x130a3, 0x1 }, + { 0x130a4, 0x3 }, + { 0x130a5, 0x2 }, + { 0x130a6, 0x4 }, + { 0x130a7, 0x5 }, + { 0x1005f, 0x1ff }, + { 0x1015f, 0x1ff }, + { 0x1105f, 0x1ff }, + { 0x1115f, 0x1ff }, + { 0x1205f, 0x1ff }, + { 0x1215f, 0x1ff }, + { 0x1305f, 0x1ff }, + { 0x1315f, 0x1ff }, + { 0x11005f, 0x1ff }, + { 0x11015f, 0x1ff }, + { 0x11105f, 0x1ff }, + { 0x11115f, 0x1ff }, + { 0x11205f, 0x1ff }, + { 0x11215f, 0x1ff }, + { 0x11305f, 0x1ff }, + { 0x11315f, 0x1ff }, + { 0x21005f, 0x1ff }, + { 0x21015f, 0x1ff }, + { 0x21105f, 0x1ff }, + { 0x21115f, 0x1ff }, + { 0x21205f, 0x1ff }, + { 0x21215f, 0x1ff }, + { 0x21305f, 0x1ff }, + { 0x21315f, 0x1ff }, + { 0x55, 0x1ff }, + { 0x1055, 0x1ff }, + { 0x2055, 0x1ff }, + { 0x3055, 0x1ff }, + { 0x4055, 0x1ff }, + { 0x5055, 0x1ff }, + { 0x6055, 0x1ff }, + { 0x7055, 0x1ff }, + { 0x8055, 0x1ff }, + { 0x9055, 0x1ff }, + { 0x200c5, 0x19 }, + { 0x1200c5, 0x7 }, + { 0x2200c5, 0x7 }, + { 0x2002e, 0x2 }, + { 0x12002e, 0x2 }, + { 0x22002e, 0x2 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x20024, 0x1ab }, + { 0x2003a, 0x0 }, + { 0x120024, 0x1ab }, + { 0x2003a, 0x0 }, + { 0x220024, 0x1ab }, + { 0x2003a, 0x0 }, + { 0x20056, 0x3 }, + { 0x120056, 0x3 }, + { 0x220056, 0x3 }, + { 0x1004d, 0xe00 }, + { 0x1014d, 0xe00 }, + { 0x1104d, 0xe00 }, + { 0x1114d, 0xe00 }, + { 0x1204d, 0xe00 }, + { 0x1214d, 0xe00 }, + { 0x1304d, 0xe00 }, + { 0x1314d, 0xe00 }, + { 0x11004d, 0xe00 }, + { 0x11014d, 0xe00 }, + { 0x11104d, 0xe00 }, + { 0x11114d, 0xe00 }, + { 0x11204d, 0xe00 }, + { 0x11214d, 0xe00 }, + { 0x11304d, 0xe00 }, + { 0x11314d, 0xe00 }, + { 0x21004d, 0xe00 }, + { 0x21014d, 0xe00 }, + { 0x21104d, 0xe00 }, + { 0x21114d, 0xe00 }, + { 0x21204d, 0xe00 }, + { 0x21214d, 0xe00 }, + { 0x21304d, 0xe00 }, + { 0x21314d, 0xe00 }, + { 0x10049, 0xeba }, + { 0x10149, 0xeba }, + { 0x11049, 0xeba }, + { 0x11149, 0xeba }, + { 0x12049, 0xeba }, + { 0x12149, 0xeba }, + { 0x13049, 0xeba }, + { 0x13149, 0xeba }, + { 0x110049, 0xeba }, + { 0x110149, 0xeba }, + { 0x111049, 0xeba }, + { 0x111149, 0xeba }, + { 0x112049, 0xeba }, + { 0x112149, 0xeba }, + { 0x113049, 0xeba }, + { 0x113149, 0xeba }, + { 0x210049, 0xeba }, + { 0x210149, 0xeba }, + { 0x211049, 0xeba }, + { 0x211149, 0xeba }, + { 0x212049, 0xeba }, + { 0x212149, 0xeba }, + { 0x213049, 0xeba }, + { 0x213149, 0xeba }, + { 0x43, 0x63 }, + { 0x1043, 0x63 }, + { 0x2043, 0x63 }, + { 0x3043, 0x63 }, + { 0x4043, 0x63 }, + { 0x5043, 0x63 }, + { 0x6043, 0x63 }, + { 0x7043, 0x63 }, + { 0x8043, 0x63 }, + { 0x9043, 0x63 }, + { 0x20018, 0x3 }, + { 0x20075, 0x4 }, + { 0x20050, 0x0 }, + { 0x20008, 0x2ee }, + { 0x120008, 0x64 }, + { 0x220008, 0x19 }, + { 0x20088, 0x9 }, + { 0x200b2, 0xdc }, + { 0x10043, 0x5a1 }, + { 0x10143, 0x5a1 }, + { 0x11043, 0x5a1 }, + { 0x11143, 0x5a1 }, + { 0x12043, 0x5a1 }, + { 0x12143, 0x5a1 }, + { 0x13043, 0x5a1 }, + { 0x13143, 0x5a1 }, + { 0x1200b2, 0xdc }, + { 0x110043, 0x5a1 }, + { 0x110143, 0x5a1 }, + { 0x111043, 0x5a1 }, + { 0x111143, 0x5a1 }, + { 0x112043, 0x5a1 }, + { 0x112143, 0x5a1 }, + { 0x113043, 0x5a1 }, + { 0x113143, 0x5a1 }, + { 0x2200b2, 0xdc }, + { 0x210043, 0x5a1 }, + { 0x210143, 0x5a1 }, + { 0x211043, 0x5a1 }, + { 0x211143, 0x5a1 }, + { 0x212043, 0x5a1 }, + { 0x212143, 0x5a1 }, + { 0x213043, 0x5a1 }, + { 0x213143, 0x5a1 }, + { 0x200fa, 0x1 }, + { 0x1200fa, 0x1 }, + { 0x2200fa, 0x1 }, + { 0x20019, 0x1 }, + { 0x120019, 0x1 }, + { 0x220019, 0x1 }, + { 0x200f0, 0x660 }, + { 0x200f1, 0x0 }, + { 0x200f2, 0x4444 }, + { 0x200f3, 0x8888 }, + { 0x200f4, 0x5665 }, + { 0x200f5, 0x0 }, + { 0x200f6, 0x0 }, + { 0x200f7, 0xf000 }, + { 0x20025, 0x0 }, + { 0x2002d, 0x0 }, + { 0x12002d, 0x0 }, + { 0x22002d, 0x0 }, + { 0x200c7, 0x21 }, + { 0x1200c7, 0x21 }, + { 0x2200c7, 0x21 }, + { 0x200ca, 0x24 }, + { 0x1200ca, 0x24 }, + { 0x2200ca, 0x24 }, +}; + +/* ddr phy trained csr */ +static struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + { 0x200b2, 0x0 }, + { 0x1200b2, 0x0 }, + { 0x2200b2, 0x0 }, + { 0x200cb, 0x0 }, + { 0x10043, 0x0 }, + { 0x110043, 0x0 }, + { 0x210043, 0x0 }, + { 0x10143, 0x0 }, + { 0x110143, 0x0 }, + { 0x210143, 0x0 }, + { 0x11043, 0x0 }, + { 0x111043, 0x0 }, + { 0x211043, 0x0 }, + { 0x11143, 0x0 }, + { 0x111143, 0x0 }, + { 0x211143, 0x0 }, + { 0x12043, 0x0 }, + { 0x112043, 0x0 }, + { 0x212043, 0x0 }, + { 0x12143, 0x0 }, + { 0x112143, 0x0 }, + { 0x212143, 0x0 }, + { 0x13043, 0x0 }, + { 0x113043, 0x0 }, + { 0x213043, 0x0 }, + { 0x13143, 0x0 }, + { 0x113143, 0x0 }, + { 0x213143, 0x0 }, + { 0x80, 0x0 }, + { 0x100080, 0x0 }, + { 0x200080, 0x0 }, + { 0x1080, 0x0 }, + { 0x101080, 0x0 }, + { 0x201080, 0x0 }, + { 0x2080, 0x0 }, + { 0x102080, 0x0 }, + { 0x202080, 0x0 }, + { 0x3080, 0x0 }, + { 0x103080, 0x0 }, + { 0x203080, 0x0 }, + { 0x4080, 0x0 }, + { 0x104080, 0x0 }, + { 0x204080, 0x0 }, + { 0x5080, 0x0 }, + { 0x105080, 0x0 }, + { 0x205080, 0x0 }, + { 0x6080, 0x0 }, + { 0x106080, 0x0 }, + { 0x206080, 0x0 }, + { 0x7080, 0x0 }, + { 0x107080, 0x0 }, + { 0x207080, 0x0 }, + { 0x8080, 0x0 }, + { 0x108080, 0x0 }, + { 0x208080, 0x0 }, + { 0x9080, 0x0 }, + { 0x109080, 0x0 }, + { 0x209080, 0x0 }, + { 0x10080, 0x0 }, + { 0x110080, 0x0 }, + { 0x210080, 0x0 }, + { 0x10180, 0x0 }, + { 0x110180, 0x0 }, + { 0x210180, 0x0 }, + { 0x11080, 0x0 }, + { 0x111080, 0x0 }, + { 0x211080, 0x0 }, + { 0x11180, 0x0 }, + { 0x111180, 0x0 }, + { 0x211180, 0x0 }, + { 0x12080, 0x0 }, + { 0x112080, 0x0 }, + { 0x212080, 0x0 }, + { 0x12180, 0x0 }, + { 0x112180, 0x0 }, + { 0x212180, 0x0 }, + { 0x13080, 0x0 }, + { 0x113080, 0x0 }, + { 0x213080, 0x0 }, + { 0x13180, 0x0 }, + { 0x113180, 0x0 }, + { 0x213180, 0x0 }, + { 0x10081, 0x0 }, + { 0x110081, 0x0 }, + { 0x210081, 0x0 }, + { 0x10181, 0x0 }, + { 0x110181, 0x0 }, + { 0x210181, 0x0 }, + { 0x11081, 0x0 }, + { 0x111081, 0x0 }, + { 0x211081, 0x0 }, + { 0x11181, 0x0 }, + { 0x111181, 0x0 }, + { 0x211181, 0x0 }, + { 0x12081, 0x0 }, + { 0x112081, 0x0 }, + { 0x212081, 0x0 }, + { 0x12181, 0x0 }, + { 0x112181, 0x0 }, + { 0x212181, 0x0 }, + { 0x13081, 0x0 }, + { 0x113081, 0x0 }, + { 0x213081, 0x0 }, + { 0x13181, 0x0 }, + { 0x113181, 0x0 }, + { 0x213181, 0x0 }, + { 0x100d0, 0x0 }, + { 0x1100d0, 0x0 }, + { 0x2100d0, 0x0 }, + { 0x101d0, 0x0 }, + { 0x1101d0, 0x0 }, + { 0x2101d0, 0x0 }, + { 0x110d0, 0x0 }, + { 0x1110d0, 0x0 }, + { 0x2110d0, 0x0 }, + { 0x111d0, 0x0 }, + { 0x1111d0, 0x0 }, + { 0x2111d0, 0x0 }, + { 0x120d0, 0x0 }, + { 0x1120d0, 0x0 }, + { 0x2120d0, 0x0 }, + { 0x121d0, 0x0 }, + { 0x1121d0, 0x0 }, + { 0x2121d0, 0x0 }, + { 0x130d0, 0x0 }, + { 0x1130d0, 0x0 }, + { 0x2130d0, 0x0 }, + { 0x131d0, 0x0 }, + { 0x1131d0, 0x0 }, + { 0x2131d0, 0x0 }, + { 0x100d1, 0x0 }, + { 0x1100d1, 0x0 }, + { 0x2100d1, 0x0 }, + { 0x101d1, 0x0 }, + { 0x1101d1, 0x0 }, + { 0x2101d1, 0x0 }, + { 0x110d1, 0x0 }, + { 0x1110d1, 0x0 }, + { 0x2110d1, 0x0 }, + { 0x111d1, 0x0 }, + { 0x1111d1, 0x0 }, + { 0x2111d1, 0x0 }, + { 0x120d1, 0x0 }, + { 0x1120d1, 0x0 }, + { 0x2120d1, 0x0 }, + { 0x121d1, 0x0 }, + { 0x1121d1, 0x0 }, + { 0x2121d1, 0x0 }, + { 0x130d1, 0x0 }, + { 0x1130d1, 0x0 }, + { 0x2130d1, 0x0 }, + { 0x131d1, 0x0 }, + { 0x1131d1, 0x0 }, + { 0x2131d1, 0x0 }, + { 0x10068, 0x0 }, + { 0x10168, 0x0 }, + { 0x10268, 0x0 }, + { 0x10368, 0x0 }, + { 0x10468, 0x0 }, + { 0x10568, 0x0 }, + { 0x10668, 0x0 }, + { 0x10768, 0x0 }, + { 0x10868, 0x0 }, + { 0x11068, 0x0 }, + { 0x11168, 0x0 }, + { 0x11268, 0x0 }, + { 0x11368, 0x0 }, + { 0x11468, 0x0 }, + { 0x11568, 0x0 }, + { 0x11668, 0x0 }, + { 0x11768, 0x0 }, + { 0x11868, 0x0 }, + { 0x12068, 0x0 }, + { 0x12168, 0x0 }, + { 0x12268, 0x0 }, + { 0x12368, 0x0 }, + { 0x12468, 0x0 }, + { 0x12568, 0x0 }, + { 0x12668, 0x0 }, + { 0x12768, 0x0 }, + { 0x12868, 0x0 }, + { 0x13068, 0x0 }, + { 0x13168, 0x0 }, + { 0x13268, 0x0 }, + { 0x13368, 0x0 }, + { 0x13468, 0x0 }, + { 0x13568, 0x0 }, + { 0x13668, 0x0 }, + { 0x13768, 0x0 }, + { 0x13868, 0x0 }, + { 0x10069, 0x0 }, + { 0x10169, 0x0 }, + { 0x10269, 0x0 }, + { 0x10369, 0x0 }, + { 0x10469, 0x0 }, + { 0x10569, 0x0 }, + { 0x10669, 0x0 }, + { 0x10769, 0x0 }, + { 0x10869, 0x0 }, + { 0x11069, 0x0 }, + { 0x11169, 0x0 }, + { 0x11269, 0x0 }, + { 0x11369, 0x0 }, + { 0x11469, 0x0 }, + { 0x11569, 0x0 }, + { 0x11669, 0x0 }, + { 0x11769, 0x0 }, + { 0x11869, 0x0 }, + { 0x12069, 0x0 }, + { 0x12169, 0x0 }, + { 0x12269, 0x0 }, + { 0x12369, 0x0 }, + { 0x12469, 0x0 }, + { 0x12569, 0x0 }, + { 0x12669, 0x0 }, + { 0x12769, 0x0 }, + { 0x12869, 0x0 }, + { 0x13069, 0x0 }, + { 0x13169, 0x0 }, + { 0x13269, 0x0 }, + { 0x13369, 0x0 }, + { 0x13469, 0x0 }, + { 0x13569, 0x0 }, + { 0x13669, 0x0 }, + { 0x13769, 0x0 }, + { 0x13869, 0x0 }, + { 0x1008c, 0x0 }, + { 0x11008c, 0x0 }, + { 0x21008c, 0x0 }, + { 0x1018c, 0x0 }, + { 0x11018c, 0x0 }, + { 0x21018c, 0x0 }, + { 0x1108c, 0x0 }, + { 0x11108c, 0x0 }, + { 0x21108c, 0x0 }, + { 0x1118c, 0x0 }, + { 0x11118c, 0x0 }, + { 0x21118c, 0x0 }, + { 0x1208c, 0x0 }, + { 0x11208c, 0x0 }, + { 0x21208c, 0x0 }, + { 0x1218c, 0x0 }, + { 0x11218c, 0x0 }, + { 0x21218c, 0x0 }, + { 0x1308c, 0x0 }, + { 0x11308c, 0x0 }, + { 0x21308c, 0x0 }, + { 0x1318c, 0x0 }, + { 0x11318c, 0x0 }, + { 0x21318c, 0x0 }, + { 0x1008d, 0x0 }, + { 0x11008d, 0x0 }, + { 0x21008d, 0x0 }, + { 0x1018d, 0x0 }, + { 0x11018d, 0x0 }, + { 0x21018d, 0x0 }, + { 0x1108d, 0x0 }, + { 0x11108d, 0x0 }, + { 0x21108d, 0x0 }, + { 0x1118d, 0x0 }, + { 0x11118d, 0x0 }, + { 0x21118d, 0x0 }, + { 0x1208d, 0x0 }, + { 0x11208d, 0x0 }, + { 0x21208d, 0x0 }, + { 0x1218d, 0x0 }, + { 0x11218d, 0x0 }, + { 0x21218d, 0x0 }, + { 0x1308d, 0x0 }, + { 0x11308d, 0x0 }, + { 0x21308d, 0x0 }, + { 0x1318d, 0x0 }, + { 0x11318d, 0x0 }, + { 0x21318d, 0x0 }, + { 0x100c0, 0x0 }, + { 0x1100c0, 0x0 }, + { 0x2100c0, 0x0 }, + { 0x101c0, 0x0 }, + { 0x1101c0, 0x0 }, + { 0x2101c0, 0x0 }, + { 0x102c0, 0x0 }, + { 0x1102c0, 0x0 }, + { 0x2102c0, 0x0 }, + { 0x103c0, 0x0 }, + { 0x1103c0, 0x0 }, + { 0x2103c0, 0x0 }, + { 0x104c0, 0x0 }, + { 0x1104c0, 0x0 }, + { 0x2104c0, 0x0 }, + { 0x105c0, 0x0 }, + { 0x1105c0, 0x0 }, + { 0x2105c0, 0x0 }, + { 0x106c0, 0x0 }, + { 0x1106c0, 0x0 }, + { 0x2106c0, 0x0 }, + { 0x107c0, 0x0 }, + { 0x1107c0, 0x0 }, + { 0x2107c0, 0x0 }, + { 0x108c0, 0x0 }, + { 0x1108c0, 0x0 }, + { 0x2108c0, 0x0 }, + { 0x110c0, 0x0 }, + { 0x1110c0, 0x0 }, + { 0x2110c0, 0x0 }, + { 0x111c0, 0x0 }, + { 0x1111c0, 0x0 }, + { 0x2111c0, 0x0 }, + { 0x112c0, 0x0 }, + { 0x1112c0, 0x0 }, + { 0x2112c0, 0x0 }, + { 0x113c0, 0x0 }, + { 0x1113c0, 0x0 }, + { 0x2113c0, 0x0 }, + { 0x114c0, 0x0 }, + { 0x1114c0, 0x0 }, + { 0x2114c0, 0x0 }, + { 0x115c0, 0x0 }, + { 0x1115c0, 0x0 }, + { 0x2115c0, 0x0 }, + { 0x116c0, 0x0 }, + { 0x1116c0, 0x0 }, + { 0x2116c0, 0x0 }, + { 0x117c0, 0x0 }, + { 0x1117c0, 0x0 }, + { 0x2117c0, 0x0 }, + { 0x118c0, 0x0 }, + { 0x1118c0, 0x0 }, + { 0x2118c0, 0x0 }, + { 0x120c0, 0x0 }, + { 0x1120c0, 0x0 }, + { 0x2120c0, 0x0 }, + { 0x121c0, 0x0 }, + { 0x1121c0, 0x0 }, + { 0x2121c0, 0x0 }, + { 0x122c0, 0x0 }, + { 0x1122c0, 0x0 }, + { 0x2122c0, 0x0 }, + { 0x123c0, 0x0 }, + { 0x1123c0, 0x0 }, + { 0x2123c0, 0x0 }, + { 0x124c0, 0x0 }, + { 0x1124c0, 0x0 }, + { 0x2124c0, 0x0 }, + { 0x125c0, 0x0 }, + { 0x1125c0, 0x0 }, + { 0x2125c0, 0x0 }, + { 0x126c0, 0x0 }, + { 0x1126c0, 0x0 }, + { 0x2126c0, 0x0 }, + { 0x127c0, 0x0 }, + { 0x1127c0, 0x0 }, + { 0x2127c0, 0x0 }, + { 0x128c0, 0x0 }, + { 0x1128c0, 0x0 }, + { 0x2128c0, 0x0 }, + { 0x130c0, 0x0 }, + { 0x1130c0, 0x0 }, + { 0x2130c0, 0x0 }, + { 0x131c0, 0x0 }, + { 0x1131c0, 0x0 }, + { 0x2131c0, 0x0 }, + { 0x132c0, 0x0 }, + { 0x1132c0, 0x0 }, + { 0x2132c0, 0x0 }, + { 0x133c0, 0x0 }, + { 0x1133c0, 0x0 }, + { 0x2133c0, 0x0 }, + { 0x134c0, 0x0 }, + { 0x1134c0, 0x0 }, + { 0x2134c0, 0x0 }, + { 0x135c0, 0x0 }, + { 0x1135c0, 0x0 }, + { 0x2135c0, 0x0 }, + { 0x136c0, 0x0 }, + { 0x1136c0, 0x0 }, + { 0x2136c0, 0x0 }, + { 0x137c0, 0x0 }, + { 0x1137c0, 0x0 }, + { 0x2137c0, 0x0 }, + { 0x138c0, 0x0 }, + { 0x1138c0, 0x0 }, + { 0x2138c0, 0x0 }, + { 0x100c1, 0x0 }, + { 0x1100c1, 0x0 }, + { 0x2100c1, 0x0 }, + { 0x101c1, 0x0 }, + { 0x1101c1, 0x0 }, + { 0x2101c1, 0x0 }, + { 0x102c1, 0x0 }, + { 0x1102c1, 0x0 }, + { 0x2102c1, 0x0 }, + { 0x103c1, 0x0 }, + { 0x1103c1, 0x0 }, + { 0x2103c1, 0x0 }, + { 0x104c1, 0x0 }, + { 0x1104c1, 0x0 }, + { 0x2104c1, 0x0 }, + { 0x105c1, 0x0 }, + { 0x1105c1, 0x0 }, + { 0x2105c1, 0x0 }, + { 0x106c1, 0x0 }, + { 0x1106c1, 0x0 }, + { 0x2106c1, 0x0 }, + { 0x107c1, 0x0 }, + { 0x1107c1, 0x0 }, + { 0x2107c1, 0x0 }, + { 0x108c1, 0x0 }, + { 0x1108c1, 0x0 }, + { 0x2108c1, 0x0 }, + { 0x110c1, 0x0 }, + { 0x1110c1, 0x0 }, + { 0x2110c1, 0x0 }, + { 0x111c1, 0x0 }, + { 0x1111c1, 0x0 }, + { 0x2111c1, 0x0 }, + { 0x112c1, 0x0 }, + { 0x1112c1, 0x0 }, + { 0x2112c1, 0x0 }, + { 0x113c1, 0x0 }, + { 0x1113c1, 0x0 }, + { 0x2113c1, 0x0 }, + { 0x114c1, 0x0 }, + { 0x1114c1, 0x0 }, + { 0x2114c1, 0x0 }, + { 0x115c1, 0x0 }, + { 0x1115c1, 0x0 }, + { 0x2115c1, 0x0 }, + { 0x116c1, 0x0 }, + { 0x1116c1, 0x0 }, + { 0x2116c1, 0x0 }, + { 0x117c1, 0x0 }, + { 0x1117c1, 0x0 }, + { 0x2117c1, 0x0 }, + { 0x118c1, 0x0 }, + { 0x1118c1, 0x0 }, + { 0x2118c1, 0x0 }, + { 0x120c1, 0x0 }, + { 0x1120c1, 0x0 }, + { 0x2120c1, 0x0 }, + { 0x121c1, 0x0 }, + { 0x1121c1, 0x0 }, + { 0x2121c1, 0x0 }, + { 0x122c1, 0x0 }, + { 0x1122c1, 0x0 }, + { 0x2122c1, 0x0 }, + { 0x123c1, 0x0 }, + { 0x1123c1, 0x0 }, + { 0x2123c1, 0x0 }, + { 0x124c1, 0x0 }, + { 0x1124c1, 0x0 }, + { 0x2124c1, 0x0 }, + { 0x125c1, 0x0 }, + { 0x1125c1, 0x0 }, + { 0x2125c1, 0x0 }, + { 0x126c1, 0x0 }, + { 0x1126c1, 0x0 }, + { 0x2126c1, 0x0 }, + { 0x127c1, 0x0 }, + { 0x1127c1, 0x0 }, + { 0x2127c1, 0x0 }, + { 0x128c1, 0x0 }, + { 0x1128c1, 0x0 }, + { 0x2128c1, 0x0 }, + { 0x130c1, 0x0 }, + { 0x1130c1, 0x0 }, + { 0x2130c1, 0x0 }, + { 0x131c1, 0x0 }, + { 0x1131c1, 0x0 }, + { 0x2131c1, 0x0 }, + { 0x132c1, 0x0 }, + { 0x1132c1, 0x0 }, + { 0x2132c1, 0x0 }, + { 0x133c1, 0x0 }, + { 0x1133c1, 0x0 }, + { 0x2133c1, 0x0 }, + { 0x134c1, 0x0 }, + { 0x1134c1, 0x0 }, + { 0x2134c1, 0x0 }, + { 0x135c1, 0x0 }, + { 0x1135c1, 0x0 }, + { 0x2135c1, 0x0 }, + { 0x136c1, 0x0 }, + { 0x1136c1, 0x0 }, + { 0x2136c1, 0x0 }, + { 0x137c1, 0x0 }, + { 0x1137c1, 0x0 }, + { 0x2137c1, 0x0 }, + { 0x138c1, 0x0 }, + { 0x1138c1, 0x0 }, + { 0x2138c1, 0x0 }, + { 0x10020, 0x0 }, + { 0x110020, 0x0 }, + { 0x210020, 0x0 }, + { 0x11020, 0x0 }, + { 0x111020, 0x0 }, + { 0x211020, 0x0 }, + { 0x12020, 0x0 }, + { 0x112020, 0x0 }, + { 0x212020, 0x0 }, + { 0x13020, 0x0 }, + { 0x113020, 0x0 }, + { 0x213020, 0x0 }, + { 0x20072, 0x0 }, + { 0x20073, 0x0 }, + { 0x20074, 0x0 }, + { 0x100aa, 0x0 }, + { 0x110aa, 0x0 }, + { 0x120aa, 0x0 }, + { 0x130aa, 0x0 }, + { 0x20010, 0x0 }, + { 0x120010, 0x0 }, + { 0x220010, 0x0 }, + { 0x20011, 0x0 }, + { 0x120011, 0x0 }, + { 0x220011, 0x0 }, + { 0x100ae, 0x0 }, + { 0x1100ae, 0x0 }, + { 0x2100ae, 0x0 }, + { 0x100af, 0x0 }, + { 0x1100af, 0x0 }, + { 0x2100af, 0x0 }, + { 0x110ae, 0x0 }, + { 0x1110ae, 0x0 }, + { 0x2110ae, 0x0 }, + { 0x110af, 0x0 }, + { 0x1110af, 0x0 }, + { 0x2110af, 0x0 }, + { 0x120ae, 0x0 }, + { 0x1120ae, 0x0 }, + { 0x2120ae, 0x0 }, + { 0x120af, 0x0 }, + { 0x1120af, 0x0 }, + { 0x2120af, 0x0 }, + { 0x130ae, 0x0 }, + { 0x1130ae, 0x0 }, + { 0x2130ae, 0x0 }, + { 0x130af, 0x0 }, + { 0x1130af, 0x0 }, + { 0x2130af, 0x0 }, + { 0x20020, 0x0 }, + { 0x120020, 0x0 }, + { 0x220020, 0x0 }, + { 0x100a0, 0x0 }, + { 0x100a1, 0x0 }, + { 0x100a2, 0x0 }, + { 0x100a3, 0x0 }, + { 0x100a4, 0x0 }, + { 0x100a5, 0x0 }, + { 0x100a6, 0x0 }, + { 0x100a7, 0x0 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x0 }, + { 0x110a2, 0x0 }, + { 0x110a3, 0x0 }, + { 0x110a4, 0x0 }, + { 0x110a5, 0x0 }, + { 0x110a6, 0x0 }, + { 0x110a7, 0x0 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x0 }, + { 0x120a2, 0x0 }, + { 0x120a3, 0x0 }, + { 0x120a4, 0x0 }, + { 0x120a5, 0x0 }, + { 0x120a6, 0x0 }, + { 0x120a7, 0x0 }, + { 0x130a0, 0x0 }, + { 0x130a1, 0x0 }, + { 0x130a2, 0x0 }, + { 0x130a3, 0x0 }, + { 0x130a4, 0x0 }, + { 0x130a5, 0x0 }, + { 0x130a6, 0x0 }, + { 0x130a7, 0x0 }, + { 0x2007c, 0x0 }, + { 0x12007c, 0x0 }, + { 0x22007c, 0x0 }, + { 0x2007d, 0x0 }, + { 0x12007d, 0x0 }, + { 0x22007d, 0x0 }, + { 0x400fd, 0x0 }, + { 0x400c0, 0x0 }, + { 0x90201, 0x0 }, + { 0x190201, 0x0 }, + { 0x290201, 0x0 }, + { 0x90202, 0x0 }, + { 0x190202, 0x0 }, + { 0x290202, 0x0 }, + { 0x90203, 0x0 }, + { 0x190203, 0x0 }, + { 0x290203, 0x0 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x90205, 0x0 }, + { 0x190205, 0x0 }, + { 0x290205, 0x0 }, + { 0x90206, 0x0 }, + { 0x190206, 0x0 }, + { 0x290206, 0x0 }, + { 0x90207, 0x0 }, + { 0x190207, 0x0 }, + { 0x290207, 0x0 }, + { 0x90208, 0x0 }, + { 0x190208, 0x0 }, + { 0x290208, 0x0 }, + { 0x10062, 0x0 }, + { 0x10162, 0x0 }, + { 0x10262, 0x0 }, + { 0x10362, 0x0 }, + { 0x10462, 0x0 }, + { 0x10562, 0x0 }, + { 0x10662, 0x0 }, + { 0x10762, 0x0 }, + { 0x10862, 0x0 }, + { 0x11062, 0x0 }, + { 0x11162, 0x0 }, + { 0x11262, 0x0 }, + { 0x11362, 0x0 }, + { 0x11462, 0x0 }, + { 0x11562, 0x0 }, + { 0x11662, 0x0 }, + { 0x11762, 0x0 }, + { 0x11862, 0x0 }, + { 0x12062, 0x0 }, + { 0x12162, 0x0 }, + { 0x12262, 0x0 }, + { 0x12362, 0x0 }, + { 0x12462, 0x0 }, + { 0x12562, 0x0 }, + { 0x12662, 0x0 }, + { 0x12762, 0x0 }, + { 0x12862, 0x0 }, + { 0x13062, 0x0 }, + { 0x13162, 0x0 }, + { 0x13262, 0x0 }, + { 0x13362, 0x0 }, + { 0x13462, 0x0 }, + { 0x13562, 0x0 }, + { 0x13662, 0x0 }, + { 0x13762, 0x0 }, + { 0x13862, 0x0 }, + { 0x20077, 0x0 }, + { 0x10001, 0x0 }, + { 0x11001, 0x0 }, + { 0x12001, 0x0 }, + { 0x13001, 0x0 }, + { 0x10040, 0x0 }, + { 0x10140, 0x0 }, + { 0x10240, 0x0 }, + { 0x10340, 0x0 }, + { 0x10440, 0x0 }, + { 0x10540, 0x0 }, + { 0x10640, 0x0 }, + { 0x10740, 0x0 }, + { 0x10840, 0x0 }, + { 0x10030, 0x0 }, + { 0x10130, 0x0 }, + { 0x10230, 0x0 }, + { 0x10330, 0x0 }, + { 0x10430, 0x0 }, + { 0x10530, 0x0 }, + { 0x10630, 0x0 }, + { 0x10730, 0x0 }, + { 0x10830, 0x0 }, + { 0x11040, 0x0 }, + { 0x11140, 0x0 }, + { 0x11240, 0x0 }, + { 0x11340, 0x0 }, + { 0x11440, 0x0 }, + { 0x11540, 0x0 }, + { 0x11640, 0x0 }, + { 0x11740, 0x0 }, + { 0x11840, 0x0 }, + { 0x11030, 0x0 }, + { 0x11130, 0x0 }, + { 0x11230, 0x0 }, + { 0x11330, 0x0 }, + { 0x11430, 0x0 }, + { 0x11530, 0x0 }, + { 0x11630, 0x0 }, + { 0x11730, 0x0 }, + { 0x11830, 0x0 }, + { 0x12040, 0x0 }, + { 0x12140, 0x0 }, + { 0x12240, 0x0 }, + { 0x12340, 0x0 }, + { 0x12440, 0x0 }, + { 0x12540, 0x0 }, + { 0x12640, 0x0 }, + { 0x12740, 0x0 }, + { 0x12840, 0x0 }, + { 0x12030, 0x0 }, + { 0x12130, 0x0 }, + { 0x12230, 0x0 }, + { 0x12330, 0x0 }, + { 0x12430, 0x0 }, + { 0x12530, 0x0 }, + { 0x12630, 0x0 }, + { 0x12730, 0x0 }, + { 0x12830, 0x0 }, + { 0x13040, 0x0 }, + { 0x13140, 0x0 }, + { 0x13240, 0x0 }, + { 0x13340, 0x0 }, + { 0x13440, 0x0 }, + { 0x13540, 0x0 }, + { 0x13640, 0x0 }, + { 0x13740, 0x0 }, + { 0x13840, 0x0 }, + { 0x13030, 0x0 }, + { 0x13130, 0x0 }, + { 0x13230, 0x0 }, + { 0x13330, 0x0 }, + { 0x13430, 0x0 }, + { 0x13530, 0x0 }, + { 0x13630, 0x0 }, + { 0x13730, 0x0 }, + { 0x13830, 0x0 }, +}; + +/* P0 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xbb8 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x131f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x54012, 0x310 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x54032, 0xd400 }, + { 0x54033, 0x312d }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0xd400 }, + { 0x54039, 0x312d }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P1 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp1_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x101 }, + { 0x54003, 0x190 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x54012, 0x310 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3100 }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3100 }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P2 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp2_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x102 }, + { 0x54003, 0x64 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x54012, 0x310 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3100 }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3100 }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P0 2D message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xbb8 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x61 }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400d, 0x100 }, + { 0x5400f, 0x100 }, + { 0x54010, 0x1f7f }, + { 0x54012, 0x310 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x54032, 0xd400 }, + { 0x54033, 0x312d }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0xd400 }, + { 0x54039, 0x312d }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +static struct dram_cfg_param ddr_phy_pie[] = { + { 0xd0000, 0x0 }, + { 0x90000, 0x10 }, + { 0x90001, 0x400 }, + { 0x90002, 0x10e }, + { 0x90003, 0x0 }, + { 0x90004, 0x0 }, + { 0x90005, 0x8 }, + { 0x90029, 0xb }, + { 0x9002a, 0x480 }, + { 0x9002b, 0x109 }, + { 0x9002c, 0x8 }, + { 0x9002d, 0x448 }, + { 0x9002e, 0x139 }, + { 0x9002f, 0x8 }, + { 0x90030, 0x478 }, + { 0x90031, 0x109 }, + { 0x90032, 0x0 }, + { 0x90033, 0xe8 }, + { 0x90034, 0x109 }, + { 0x90035, 0x2 }, + { 0x90036, 0x10 }, + { 0x90037, 0x139 }, + { 0x90038, 0xf }, + { 0x90039, 0x7c0 }, + { 0x9003a, 0x139 }, + { 0x9003b, 0x44 }, + { 0x9003c, 0x630 }, + { 0x9003d, 0x159 }, + { 0x9003e, 0x14f }, + { 0x9003f, 0x630 }, + { 0x90040, 0x159 }, + { 0x90041, 0x47 }, + { 0x90042, 0x630 }, + { 0x90043, 0x149 }, + { 0x90044, 0x4f }, + { 0x90045, 0x630 }, + { 0x90046, 0x179 }, + { 0x90047, 0x8 }, + { 0x90048, 0xe0 }, + { 0x90049, 0x109 }, + { 0x9004a, 0x0 }, + { 0x9004b, 0x7c8 }, + { 0x9004c, 0x109 }, + { 0x9004d, 0x0 }, + { 0x9004e, 0x1 }, + { 0x9004f, 0x8 }, + { 0x90050, 0x0 }, + { 0x90051, 0x45a }, + { 0x90052, 0x9 }, + { 0x90053, 0x0 }, + { 0x90054, 0x448 }, + { 0x90055, 0x109 }, + { 0x90056, 0x40 }, + { 0x90057, 0x630 }, + { 0x90058, 0x179 }, + { 0x90059, 0x1 }, + { 0x9005a, 0x618 }, + { 0x9005b, 0x109 }, + { 0x9005c, 0x40c0 }, + { 0x9005d, 0x630 }, + { 0x9005e, 0x149 }, + { 0x9005f, 0x8 }, + { 0x90060, 0x4 }, + { 0x90061, 0x48 }, + { 0x90062, 0x4040 }, + { 0x90063, 0x630 }, + { 0x90064, 0x149 }, + { 0x90065, 0x0 }, + { 0x90066, 0x4 }, + { 0x90067, 0x48 }, + { 0x90068, 0x40 }, + { 0x90069, 0x630 }, + { 0x9006a, 0x149 }, + { 0x9006b, 0x10 }, + { 0x9006c, 0x4 }, + { 0x9006d, 0x18 }, + { 0x9006e, 0x0 }, + { 0x9006f, 0x4 }, + { 0x90070, 0x78 }, + { 0x90071, 0x549 }, + { 0x90072, 0x630 }, + { 0x90073, 0x159 }, + { 0x90074, 0xd49 }, + { 0x90075, 0x630 }, + { 0x90076, 0x159 }, + { 0x90077, 0x94a }, + { 0x90078, 0x630 }, + { 0x90079, 0x159 }, + { 0x9007a, 0x441 }, + { 0x9007b, 0x630 }, + { 0x9007c, 0x149 }, + { 0x9007d, 0x42 }, + { 0x9007e, 0x630 }, + { 0x9007f, 0x149 }, + { 0x90080, 0x1 }, + { 0x90081, 0x630 }, + { 0x90082, 0x149 }, + { 0x90083, 0x0 }, + { 0x90084, 0xe0 }, + { 0x90085, 0x109 }, + { 0x90086, 0xa }, + { 0x90087, 0x10 }, + { 0x90088, 0x109 }, + { 0x90089, 0x9 }, + { 0x9008a, 0x3c0 }, + { 0x9008b, 0x149 }, + { 0x9008c, 0x9 }, + { 0x9008d, 0x3c0 }, + { 0x9008e, 0x159 }, + { 0x9008f, 0x18 }, + { 0x90090, 0x10 }, + { 0x90091, 0x109 }, + { 0x90092, 0x0 }, + { 0x90093, 0x3c0 }, + { 0x90094, 0x109 }, + { 0x90095, 0x18 }, + { 0x90096, 0x4 }, + { 0x90097, 0x48 }, + { 0x90098, 0x18 }, + { 0x90099, 0x4 }, + { 0x9009a, 0x58 }, + { 0x9009b, 0xa }, + { 0x9009c, 0x10 }, + { 0x9009d, 0x109 }, + { 0x9009e, 0x2 }, + { 0x9009f, 0x10 }, + { 0x900a0, 0x109 }, + { 0x900a1, 0x5 }, + { 0x900a2, 0x7c0 }, + { 0x900a3, 0x109 }, + { 0x900a4, 0x10 }, + { 0x900a5, 0x10 }, + { 0x900a6, 0x109 }, + { 0x40000, 0x811 }, + { 0x40020, 0x880 }, + { 0x40040, 0x0 }, + { 0x40060, 0x0 }, + { 0x40001, 0x4008 }, + { 0x40021, 0x83 }, + { 0x40041, 0x4f }, + { 0x40061, 0x0 }, + { 0x40002, 0x4040 }, + { 0x40022, 0x83 }, + { 0x40042, 0x51 }, + { 0x40062, 0x0 }, + { 0x40003, 0x811 }, + { 0x40023, 0x880 }, + { 0x40043, 0x0 }, + { 0x40063, 0x0 }, + { 0x40004, 0x720 }, + { 0x40024, 0xf }, + { 0x40044, 0x1740 }, + { 0x40064, 0x0 }, + { 0x40005, 0x16 }, + { 0x40025, 0x83 }, + { 0x40045, 0x4b }, + { 0x40065, 0x0 }, + { 0x40006, 0x716 }, + { 0x40026, 0xf }, + { 0x40046, 0x2001 }, + { 0x40066, 0x0 }, + { 0x40007, 0x716 }, + { 0x40027, 0xf }, + { 0x40047, 0x2800 }, + { 0x40067, 0x0 }, + { 0x40008, 0x716 }, + { 0x40028, 0xf }, + { 0x40048, 0xf00 }, + { 0x40068, 0x0 }, + { 0x40009, 0x720 }, + { 0x40029, 0xf }, + { 0x40049, 0x1400 }, + { 0x40069, 0x0 }, + { 0x4000a, 0xe08 }, + { 0x4002a, 0xc15 }, + { 0x4004a, 0x0 }, + { 0x4006a, 0x0 }, + { 0x4000b, 0x623 }, + { 0x4002b, 0x15 }, + { 0x4004b, 0x0 }, + { 0x4006b, 0x0 }, + { 0x4000c, 0x4028 }, + { 0x4002c, 0x80 }, + { 0x4004c, 0x0 }, + { 0x4006c, 0x0 }, + { 0x4000d, 0xe08 }, + { 0x4002d, 0xc1a }, + { 0x4004d, 0x0 }, + { 0x4006d, 0x0 }, + { 0x4000e, 0x623 }, + { 0x4002e, 0x1a }, + { 0x4004e, 0x0 }, + { 0x4006e, 0x0 }, + { 0x4000f, 0x4040 }, + { 0x4002f, 0x80 }, + { 0x4004f, 0x0 }, + { 0x4006f, 0x0 }, + { 0x40010, 0x2604 }, + { 0x40030, 0x15 }, + { 0x40050, 0x0 }, + { 0x40070, 0x0 }, + { 0x40011, 0x708 }, + { 0x40031, 0x5 }, + { 0x40051, 0x0 }, + { 0x40071, 0x2002 }, + { 0x40012, 0x8 }, + { 0x40032, 0x80 }, + { 0x40052, 0x0 }, + { 0x40072, 0x0 }, + { 0x40013, 0x2604 }, + { 0x40033, 0x1a }, + { 0x40053, 0x0 }, + { 0x40073, 0x0 }, + { 0x40014, 0x708 }, + { 0x40034, 0xa }, + { 0x40054, 0x0 }, + { 0x40074, 0x2002 }, + { 0x40015, 0x4040 }, + { 0x40035, 0x80 }, + { 0x40055, 0x0 }, + { 0x40075, 0x0 }, + { 0x40016, 0x60a }, + { 0x40036, 0x15 }, + { 0x40056, 0x1200 }, + { 0x40076, 0x0 }, + { 0x40017, 0x61a }, + { 0x40037, 0x15 }, + { 0x40057, 0x1300 }, + { 0x40077, 0x0 }, + { 0x40018, 0x60a }, + { 0x40038, 0x1a }, + { 0x40058, 0x1200 }, + { 0x40078, 0x0 }, + { 0x40019, 0x642 }, + { 0x40039, 0x1a }, + { 0x40059, 0x1300 }, + { 0x40079, 0x0 }, + { 0x4001a, 0x4808 }, + { 0x4003a, 0x880 }, + { 0x4005a, 0x0 }, + { 0x4007a, 0x0 }, + { 0x900a7, 0x0 }, + { 0x900a8, 0x790 }, + { 0x900a9, 0x11a }, + { 0x900aa, 0x8 }, + { 0x900ab, 0x7aa }, + { 0x900ac, 0x2a }, + { 0x900ad, 0x10 }, + { 0x900ae, 0x7b2 }, + { 0x900af, 0x2a }, + { 0x900b0, 0x0 }, + { 0x900b1, 0x7c8 }, + { 0x900b2, 0x109 }, + { 0x900b3, 0x10 }, + { 0x900b4, 0x2a8 }, + { 0x900b5, 0x129 }, + { 0x900b6, 0x8 }, + { 0x900b7, 0x370 }, + { 0x900b8, 0x129 }, + { 0x900b9, 0xa }, + { 0x900ba, 0x3c8 }, + { 0x900bb, 0x1a9 }, + { 0x900bc, 0xc }, + { 0x900bd, 0x408 }, + { 0x900be, 0x199 }, + { 0x900bf, 0x14 }, + { 0x900c0, 0x790 }, + { 0x900c1, 0x11a }, + { 0x900c2, 0x8 }, + { 0x900c3, 0x4 }, + { 0x900c4, 0x18 }, + { 0x900c5, 0xe }, + { 0x900c6, 0x408 }, + { 0x900c7, 0x199 }, + { 0x900c8, 0x8 }, + { 0x900c9, 0x8568 }, + { 0x900ca, 0x108 }, + { 0x900cb, 0x18 }, + { 0x900cc, 0x790 }, + { 0x900cd, 0x16a }, + { 0x900ce, 0x8 }, + { 0x900cf, 0x1d8 }, + { 0x900d0, 0x169 }, + { 0x900d1, 0x10 }, + { 0x900d2, 0x8558 }, + { 0x900d3, 0x168 }, + { 0x900d4, 0x70 }, + { 0x900d5, 0x788 }, + { 0x900d6, 0x16a }, + { 0x900d7, 0x1ff8 }, + { 0x900d8, 0x85a8 }, + { 0x900d9, 0x1e8 }, + { 0x900da, 0x50 }, + { 0x900db, 0x798 }, + { 0x900dc, 0x16a }, + { 0x900dd, 0x60 }, + { 0x900de, 0x7a0 }, + { 0x900df, 0x16a }, + { 0x900e0, 0x8 }, + { 0x900e1, 0x8310 }, + { 0x900e2, 0x168 }, + { 0x900e3, 0x8 }, + { 0x900e4, 0xa310 }, + { 0x900e5, 0x168 }, + { 0x900e6, 0xa }, + { 0x900e7, 0x408 }, + { 0x900e8, 0x169 }, + { 0x900e9, 0x6e }, + { 0x900ea, 0x0 }, + { 0x900eb, 0x68 }, + { 0x900ec, 0x0 }, + { 0x900ed, 0x408 }, + { 0x900ee, 0x169 }, + { 0x900ef, 0x0 }, + { 0x900f0, 0x8310 }, + { 0x900f1, 0x168 }, + { 0x900f2, 0x0 }, + { 0x900f3, 0xa310 }, + { 0x900f4, 0x168 }, + { 0x900f5, 0x1ff8 }, + { 0x900f6, 0x85a8 }, + { 0x900f7, 0x1e8 }, + { 0x900f8, 0x68 }, + { 0x900f9, 0x798 }, + { 0x900fa, 0x16a }, + { 0x900fb, 0x78 }, + { 0x900fc, 0x7a0 }, + { 0x900fd, 0x16a }, + { 0x900fe, 0x68 }, + { 0x900ff, 0x790 }, + { 0x90100, 0x16a }, + { 0x90101, 0x8 }, + { 0x90102, 0x8b10 }, + { 0x90103, 0x168 }, + { 0x90104, 0x8 }, + { 0x90105, 0xab10 }, + { 0x90106, 0x168 }, + { 0x90107, 0xa }, + { 0x90108, 0x408 }, + { 0x90109, 0x169 }, + { 0x9010a, 0x58 }, + { 0x9010b, 0x0 }, + { 0x9010c, 0x68 }, + { 0x9010d, 0x0 }, + { 0x9010e, 0x408 }, + { 0x9010f, 0x169 }, + { 0x90110, 0x0 }, + { 0x90111, 0x8b10 }, + { 0x90112, 0x168 }, + { 0x90113, 0x0 }, + { 0x90114, 0xab10 }, + { 0x90115, 0x168 }, + { 0x90116, 0x0 }, + { 0x90117, 0x1d8 }, + { 0x90118, 0x169 }, + { 0x90119, 0x80 }, + { 0x9011a, 0x790 }, + { 0x9011b, 0x16a }, + { 0x9011c, 0x18 }, + { 0x9011d, 0x7aa }, + { 0x9011e, 0x6a }, + { 0x9011f, 0xa }, + { 0x90120, 0x0 }, + { 0x90121, 0x1e9 }, + { 0x90122, 0x8 }, + { 0x90123, 0x8080 }, + { 0x90124, 0x108 }, + { 0x90125, 0xf }, + { 0x90126, 0x408 }, + { 0x90127, 0x169 }, + { 0x90128, 0xc }, + { 0x90129, 0x0 }, + { 0x9012a, 0x68 }, + { 0x9012b, 0x9 }, + { 0x9012c, 0x0 }, + { 0x9012d, 0x1a9 }, + { 0x9012e, 0x0 }, + { 0x9012f, 0x408 }, + { 0x90130, 0x169 }, + { 0x90131, 0x0 }, + { 0x90132, 0x8080 }, + { 0x90133, 0x108 }, + { 0x90134, 0x8 }, + { 0x90135, 0x7aa }, + { 0x90136, 0x6a }, + { 0x90137, 0x0 }, + { 0x90138, 0x8568 }, + { 0x90139, 0x108 }, + { 0x9013a, 0xb7 }, + { 0x9013b, 0x790 }, + { 0x9013c, 0x16a }, + { 0x9013d, 0x1f }, + { 0x9013e, 0x0 }, + { 0x9013f, 0x68 }, + { 0x90140, 0x8 }, + { 0x90141, 0x8558 }, + { 0x90142, 0x168 }, + { 0x90143, 0xf }, + { 0x90144, 0x408 }, + { 0x90145, 0x169 }, + { 0x90146, 0xc }, + { 0x90147, 0x0 }, + { 0x90148, 0x68 }, + { 0x90149, 0x0 }, + { 0x9014a, 0x408 }, + { 0x9014b, 0x169 }, + { 0x9014c, 0x0 }, + { 0x9014d, 0x8558 }, + { 0x9014e, 0x168 }, + { 0x9014f, 0x8 }, + { 0x90150, 0x3c8 }, + { 0x90151, 0x1a9 }, + { 0x90152, 0x3 }, + { 0x90153, 0x370 }, + { 0x90154, 0x129 }, + { 0x90155, 0x20 }, + { 0x90156, 0x2aa }, + { 0x90157, 0x9 }, + { 0x90158, 0x0 }, + { 0x90159, 0x400 }, + { 0x9015a, 0x10e }, + { 0x9015b, 0x8 }, + { 0x9015c, 0xe8 }, + { 0x9015d, 0x109 }, + { 0x9015e, 0x0 }, + { 0x9015f, 0x8140 }, + { 0x90160, 0x10c }, + { 0x90161, 0x10 }, + { 0x90162, 0x8138 }, + { 0x90163, 0x10c }, + { 0x90164, 0x8 }, + { 0x90165, 0x7c8 }, + { 0x90166, 0x101 }, + { 0x90167, 0x8 }, + { 0x90168, 0x0 }, + { 0x90169, 0x8 }, + { 0x9016a, 0x8 }, + { 0x9016b, 0x448 }, + { 0x9016c, 0x109 }, + { 0x9016d, 0xf }, + { 0x9016e, 0x7c0 }, + { 0x9016f, 0x109 }, + { 0x90170, 0x0 }, + { 0x90171, 0xe8 }, + { 0x90172, 0x109 }, + { 0x90173, 0x47 }, + { 0x90174, 0x630 }, + { 0x90175, 0x109 }, + { 0x90176, 0x8 }, + { 0x90177, 0x618 }, + { 0x90178, 0x109 }, + { 0x90179, 0x8 }, + { 0x9017a, 0xe0 }, + { 0x9017b, 0x109 }, + { 0x9017c, 0x0 }, + { 0x9017d, 0x7c8 }, + { 0x9017e, 0x109 }, + { 0x9017f, 0x8 }, + { 0x90180, 0x8140 }, + { 0x90181, 0x10c }, + { 0x90182, 0x0 }, + { 0x90183, 0x1 }, + { 0x90184, 0x8 }, + { 0x90185, 0x8 }, + { 0x90186, 0x4 }, + { 0x90187, 0x8 }, + { 0x90188, 0x8 }, + { 0x90189, 0x7c8 }, + { 0x9018a, 0x101 }, + { 0x90006, 0x0 }, + { 0x90007, 0x0 }, + { 0x90008, 0x8 }, + { 0x90009, 0x0 }, + { 0x9000a, 0x0 }, + { 0x9000b, 0x0 }, + { 0xd00e7, 0x400 }, + { 0x90017, 0x0 }, + { 0x9001f, 0x2a }, + { 0x90026, 0x6a }, + { 0x400d0, 0x0 }, + { 0x400d1, 0x101 }, + { 0x400d2, 0x105 }, + { 0x400d3, 0x107 }, + { 0x400d4, 0x10f }, + { 0x400d5, 0x202 }, + { 0x400d6, 0x20a }, + { 0x400d7, 0x20b }, + { 0x2003a, 0x2 }, + { 0x2000b, 0x5d }, + { 0x2000c, 0xbb }, + { 0x2000d, 0x753 }, + { 0x2000e, 0x2c }, + { 0x12000b, 0xc }, + { 0x12000c, 0x19 }, + { 0x12000d, 0xfa }, + { 0x12000e, 0x10 }, + { 0x22000b, 0x3 }, + { 0x22000c, 0x6 }, + { 0x22000d, 0x3e }, + { 0x22000e, 0x10 }, + { 0x9000c, 0x0 }, + { 0x9000d, 0x173 }, + { 0x9000e, 0x60 }, + { 0x9000f, 0x6110 }, + { 0x90010, 0x2152 }, + { 0x90011, 0xdfbd }, + { 0x90012, 0x60 }, + { 0x90013, 0x6152 }, + { 0x20010, 0x5a }, + { 0x20011, 0x3 }, + { 0x40080, 0xe0 }, + { 0x40081, 0x12 }, + { 0x40082, 0xe0 }, + { 0x40083, 0x12 }, + { 0x40084, 0xe0 }, + { 0x40085, 0x12 }, + { 0x140080, 0xe0 }, + { 0x140081, 0x12 }, + { 0x140082, 0xe0 }, + { 0x140083, 0x12 }, + { 0x140084, 0xe0 }, + { 0x140085, 0x12 }, + { 0x240080, 0xe0 }, + { 0x240081, 0x12 }, + { 0x240082, 0xe0 }, + { 0x240083, 0x12 }, + { 0x240084, 0xe0 }, + { 0x240085, 0x12 }, + { 0x400fd, 0xf }, + { 0x10011, 0x1 }, + { 0x10012, 0x1 }, + { 0x10013, 0x180 }, + { 0x10018, 0x1 }, + { 0x10002, 0x6209 }, + { 0x100b2, 0x1 }, + { 0x101b4, 0x1 }, + { 0x102b4, 0x1 }, + { 0x103b4, 0x1 }, + { 0x104b4, 0x1 }, + { 0x105b4, 0x1 }, + { 0x106b4, 0x1 }, + { 0x107b4, 0x1 }, + { 0x108b4, 0x1 }, + { 0x11011, 0x1 }, + { 0x11012, 0x1 }, + { 0x11013, 0x180 }, + { 0x11018, 0x1 }, + { 0x11002, 0x6209 }, + { 0x110b2, 0x1 }, + { 0x111b4, 0x1 }, + { 0x112b4, 0x1 }, + { 0x113b4, 0x1 }, + { 0x114b4, 0x1 }, + { 0x115b4, 0x1 }, + { 0x116b4, 0x1 }, + { 0x117b4, 0x1 }, + { 0x118b4, 0x1 }, + { 0x12011, 0x1 }, + { 0x12012, 0x1 }, + { 0x12013, 0x180 }, + { 0x12018, 0x1 }, + { 0x12002, 0x6209 }, + { 0x120b2, 0x1 }, + { 0x121b4, 0x1 }, + { 0x122b4, 0x1 }, + { 0x123b4, 0x1 }, + { 0x124b4, 0x1 }, + { 0x125b4, 0x1 }, + { 0x126b4, 0x1 }, + { 0x127b4, 0x1 }, + { 0x128b4, 0x1 }, + { 0x13011, 0x1 }, + { 0x13012, 0x1 }, + { 0x13013, 0x180 }, + { 0x13018, 0x1 }, + { 0x13002, 0x6209 }, + { 0x130b2, 0x1 }, + { 0x131b4, 0x1 }, + { 0x132b4, 0x1 }, + { 0x133b4, 0x1 }, + { 0x134b4, 0x1 }, + { 0x135b4, 0x1 }, + { 0x136b4, 0x1 }, + { 0x137b4, 0x1 }, + { 0x138b4, 0x1 }, + { 0x2003a, 0x2 }, + { 0xc0080, 0x2 }, + { 0xd0000, 0x1 } +}; + +static struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 3000mts 1D */ + .drate = 3000, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 400mts 1D */ + .drate = 400, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P2 100mts 1D */ + .drate = 100, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp2_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg), + }, + { + /* P0 3000mts 2D */ + .drate = 3000, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dmo_imx8mm_sbc_dram_timing_32_32 = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 3000, 400, 100, }, +}; diff --git a/board/data_modul/imx8mm_edm_sbc/spl.c b/board/data_modul/imx8mm_edm_sbc/spl.c new file mode 100644 index 00000000000..36cad14fc41 --- /dev/null +++ b/board/data_modul/imx8mm_edm_sbc/spl.c @@ -0,0 +1,179 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2022 Marek Vasut marex@denx.de + */ + +#include <common.h> +#include <hang.h> +#include <image.h> +#include <init.h> +#include <spl.h> +#include <asm/io.h> +#include <asm-generic/gpio.h> +#include <asm/arch/clock.h> +#include <asm/arch/imx8mm_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/ddr.h> +#include <asm/mach-imx/boot_mode.h> + +#include <dm/uclass.h> +#include <dm/device.h> +#include <dm/uclass-internal.h> +#include <dm/device-internal.h> + +#include <power/pmic.h> +#include <power/bd71837.h> + +#include "lpddr4_timing.h" + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) +#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) + +static const iomux_v3_cfg_t uart_pads[] = { + IMX8MM_PAD_UART3_RXD_UART3_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + IMX8MM_PAD_UART3_TXD_UART3_TX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static const iomux_v3_cfg_t wdog_pads[] = { + IMX8MM_PAD_GPIO1_IO02_WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), +}; + +static void data_modul_imx8mm_edm_sbc_early_init_f(void) +{ + struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; + + imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); + + set_wdog_reset(wdog); + + imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); +} + +static int data_modul_imx8mm_edm_sbc_board_power_init(void) +{ + struct udevice *dev; + int ret; + + ret = pmic_get("pmic@4b", &dev); + if (ret == -ENODEV) { + puts("Failed to get PMIC\n"); + return 0; + } + if (ret != 0) + return ret; + + /* Unlock the PMIC regs */ + pmic_reg_write(dev, BD718XX_REGLOCK, 0x1); + + /* Increase VDD_SOC to typical value 0.85V before first DRAM access */ + pmic_reg_write(dev, BD718XX_BUCK1_VOLT_RUN, 0x0f); + + /* Increase VDD_DRAM to 0.975V for 3GHz DDR */ + pmic_reg_write(dev, BD718XX_1ST_NODVS_BUCK_VOLT, 0x83); + + /* Lock the PMIC regs */ + pmic_reg_write(dev, BD718XX_REGLOCK, 0x11); + + return 0; +} + +int spl_board_boot_device(enum boot_device boot_dev_spl) +{ + if (boot_dev_spl == MMC3_BOOT) + return BOOT_DEVICE_MMC2; /* eMMC */ + else + return BOOT_DEVICE_MMC1; /* SD */ +} + +void board_boot_order(u32 *spl_boot_list) +{ + int boot_device = spl_boot_device(); + + spl_boot_list[0] = boot_device; /* 1:SD 2:eMMC */ + + if (boot_device == BOOT_DEVICE_MMC1) + spl_boot_list[1] = BOOT_DEVICE_MMC2; /* eMMC */ + else + spl_boot_list[1] = BOOT_DEVICE_MMC1; /* SD */ + + spl_boot_list[2] = BOOT_DEVICE_UART; /* YModem */ + spl_boot_list[3] = BOOT_DEVICE_NONE; +} + +static struct dram_timing_info *dram_timing_info[8] = { + &dmo_imx8mm_sbc_dram_timing_32_32, /* 32 Gbit x32 */ + NULL, /* 32 Gbit x16 */ + &dmo_imx8mm_sbc_dram_timing_16_32, /* 16 Gbit x32 */ + NULL, /* 16 Gbit x16 */ + NULL, /* 8 Gbit x32 */ + NULL, /* 8 Gbit x16 */ + NULL, /* INVALID */ + NULL, /* INVALID */ +}; + +static void spl_dram_init(void) +{ + u8 memcfg = dmo_get_memcfg(); + int i; + + printf("DDR: %d GiB x%d [0x%x]\n", + /* 0..4 GiB, 1..2 GiB, 0..1 GiB */ + 4 >> ((memcfg >> 1) & 0x3), + /* 0..x32, 1..x16 */ + 32 >> (memcfg & BIT(0)), + memcfg); + + if (!dram_timing_info[memcfg]) { + printf("Unsupported DRAM strapping, trying lowest supported. MEMCFG=0x%x\n", + memcfg); + for (i = ARRAY_SIZE(dram_timing_info) - 1; i >= 0; i--) + if (dram_timing_info[i]) /* Configuration found */ + break; + } + + ddr_init(dram_timing_info[memcfg]); +} + +void board_init_f(ulong dummy) +{ + struct udevice *dev; + int ret; + + icache_enable(); + + arch_cpu_init(); + + init_uart_clk(2); + + data_modul_imx8mm_edm_sbc_early_init_f(); + + preloader_console_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + ret = spl_early_init(); + if (ret) { + debug("spl_early_init() failed: %d\n", ret); + hang(); + } + + ret = uclass_get_device_by_name(UCLASS_CLK, + "clock-controller@30380000", + &dev); + if (ret < 0) { + printf("Failed to find clock node. Check device tree\n"); + hang(); + } + + enable_tzc380(); + + data_modul_imx8mm_edm_sbc_board_power_init(); + + /* DDR initialization */ + spl_dram_init(); + + board_init_r(NULL, 0); +} diff --git a/configs/imx8mm_data_modul_edm_sbc_defconfig b/configs/imx8mm_data_modul_edm_sbc_defconfig new file mode 100644 index 00000000000..dc9aeb92c50 --- /dev/null +++ b/configs/imx8mm_data_modul_edm_sbc_defconfig @@ -0,0 +1,227 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX8M=y +CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_SYS_MALLOC_LEN=0x1000000 +CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0xFFFC0000 +CONFIG_IMX_CONFIG="board/data_modul/imx8mm_edm_sbc/imximage.cfg" +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mm-data-modul-edm-sbc" +CONFIG_SPL_TEXT_BASE=0x7E1000 +CONFIG_TARGET_IMX8MM_DATA_MODUL_EDM_SBC=y +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_BOOTCOUNT_BOOTLIMIT=3 +CONFIG_SYS_BOOTCOUNT_ADDR=0x30370090 +CONFIG_SPL=y +CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y +CONFIG_ENV_OFFSET_REDUND=0xFFFC0000 +CONFIG_IMX_BOOTAUX=y +CONFIG_SYS_LOAD_ADDR=0x60000000 +CONFIG_ENV_VARS_UBOOT_CONFIG=y +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x44000000 +# CONFIG_USE_SPL_FIT_GENERATOR is not set +CONFIG_SUPPORT_RAW_INITRD=y +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_USE_BOOTARGS=y +CONFIG_USE_BOOTCOMMAND=y +CONFIG_BOOTCOMMAND="run dmo_update_env ; load ${devtype} ${devnum}:${devpart} ${loadaddr} boot/fitImage && source ${loadaddr}:bootscr-boot.cmd ; reset" +CONFIG_USE_PREBOOT=y +CONFIG_PREBOOT="run dmo_preboot" +CONFIG_DEFAULT_FDT_FILE="imx8mm-data-modul-edm-sbc.dtb" +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y +CONFIG_ARCH_MISC_INIT=y +CONFIG_BOARD_LATE_INIT=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_LEGACY_IMAGE_SUPPORT=y +CONFIG_SPL_LEGACY_IMAGE_CRC_CHECK=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 +CONFIG_SPL_I2C=y +CONFIG_SPL_POWER=y +CONFIG_SPL_RAM_SUPPORT=y +CONFIG_SPL_RAM_DEVICE=y +CONFIG_SPL_WATCHDOG=y +CONFIG_SPL_YMODEM_SUPPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="u-boot=> " +# CONFIG_BOOTM_NETBSD is not set +# CONFIG_BOOTM_PLAN9 is not set +# CONFIG_BOOTM_RTEMS is not set +# CONFIG_BOOTM_VXWORKS is not set +CONFIG_CMD_ASKENV=y +# CONFIG_CMD_EXPORTENV is not set +CONFIG_CMD_ERASEENV=y +CONFIG_CRC32_VERIFY=y +CONFIG_CMD_EEPROM=y +CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 +CONFIG_SYS_EEPROM_SIZE=16384 +CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=6 +CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=20 +CONFIG_CMD_MD5SUM=y +CONFIG_MD5SUM_VERIFY=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_SHA1SUM=y +CONFIG_SHA1SUM_VERIFY=y +CONFIG_CMD_CLK=y +CONFIG_CMD_DFU=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_GPT_RENAME=y +CONFIG_CMD_I2C=y +CONFIG_CMD_LSBLK=y +CONFIG_CMD_MBR=y +CONFIG_CMD_MMC=y +CONFIG_CMD_BKOPS_ENABLE=y +CONFIG_CMD_MTD=y +CONFIG_CMD_PART=y +CONFIG_CMD_READ=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_SDP=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_PXE=y +CONFIG_CMD_BOOTCOUNT=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_GETTIME=y +CONFIG_CMD_SYSBOOT=y +CONFIG_CMD_UUID=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_HASH=y +CONFIG_CMD_SMC=y +CONFIG_HASH_VERIFY=y +CONFIG_CMD_BTRFS=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_FS_UUID=y +CONFIG_CMD_MTDPARTS=y +CONFIG_CMD_MTDPARTS_SHOW_NET_SIZES=y +CONFIG_MTDIDS_DEFAULT="nor0=flash@0" +CONFIG_MTDPARTS_DEFAULT="mtdparts=flash@0:-(sf)" +CONFIG_MMC_SPEED_MODE_SET=y +CONFIG_PARTITION_TYPE_GUID=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_PART=1 +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_VERSION_VARIABLE=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_NETCONSOLE=y +CONFIG_IP_DEFRAG=y +CONFIG_TFTP_TSIZE=y +CONFIG_SPL_DM=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y +CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_SYS_BOOTCOUNT_MAGIC=0xB0C40000 +CONFIG_SPL_CLK_COMPOSITE_CCF=y +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_SPL_CLK_IMX8MM=y +CONFIG_CLK_IMX8MM=y +CONFIG_SAVED_DRAM_TIMING_BASE=0x40000000 +CONFIG_DFU_TFTP=y +CONFIG_DFU_TIMEOUT=y +CONFIG_DFU_MMC=y +CONFIG_DFU_MTD=y +CONFIG_DFU_RAM=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x42800000 +CONFIG_FASTBOOT_BUF_SIZE=0x20000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_GPIO_HOG=y +CONFIG_MXC_GPIO=y +CONFIG_DM_I2C=y +# CONFIG_INPUT is not set +CONFIG_MISC=y +CONFIG_I2C_EEPROM=y +CONFIG_SYS_I2C_EEPROM_ADDR=0x50 +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_SPL_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_ES_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_FSL_USDHC=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=50000000 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +# CONFIG_SPI_FLASH_UNLOCK_ALL is not set +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_PHYLIB=y +CONFIG_PHY_ATHEROS=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_DM_ETH_PHY=y +CONFIG_FEC_MXC=y +CONFIG_RGMII=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX8M_POWER_DOMAIN=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_BD71837=y +CONFIG_SPL_DM_PMIC_BD71837=y +CONFIG_DM_REGULATOR=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_DM_REGULATOR_BD71837=y +CONFIG_SPL_DM_REGULATOR_BD71837=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_RESET=y +CONFIG_DM_RTC=y +CONFIG_RTC_M41T62=y +CONFIG_CONS_INDEX=2 +CONFIG_DM_SERIAL=y +# CONFIG_SPL_DM_SERIAL is not set +CONFIG_MXC_UART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_MXC_SPI=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_PSCI=y +CONFIG_SYSRESET_WATCHDOG=y +CONFIG_DM_THERMAL=y +CONFIG_IMX_TMU=y +CONFIG_USB=y +# CONFIG_SPL_DM_USB is not set +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Data Modul" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_CI_UDC=y +CONFIG_SDP_LOADADDR=0x0 +CONFIG_USB_FUNCTION_ACM=y +CONFIG_IMX_WATCHDOG=y +CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/include/configs/imx8mm_data_modul_edm_sbc.h b/include/configs/imx8mm_data_modul_edm_sbc.h new file mode 100644 index 00000000000..4923c18d756 --- /dev/null +++ b/include/configs/imx8mm_data_modul_edm_sbc.h @@ -0,0 +1,130 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2022 Marek Vasut marex@denx.de + */ + +#ifndef __IMX8MM_DATA_MODUL_EDM_SBC_H +#define __IMX8MM_DATA_MODUL_EDM_SBC_H + +#include <linux/sizes.h> +#include <linux/stringify.h> +#include <asm/arch/imx-regs.h> + +#define CONFIG_SYS_BOOTM_LEN SZ_128M + +#define CONFIG_SPL_MAX_SIZE (148 * 1024) +#define CONFIG_SYS_MONITOR_LEN SZ_1M + +#define CONFIG_SPL_STACK 0x920000 +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_BSS_START_ADDR 0x910000 +#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K /* 8 kiB */ +#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 +#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_16M /* 16 MiB */ + +#define CONFIG_MALLOC_F_ADDR 0x930000 + +/* For RAW image gives a error info not panic */ +#define CONFIG_SPL_ABORT_ON_RAW_IMAGE + +#endif + +/* Link Definitions */ +#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x200000 +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +#define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define PHYS_SDRAM 0x40000000 +#define PHYS_SDRAM_SIZE 0x40000000 /* Minimum 1 GiB DDR */ + +#define CONFIG_MXC_UART_BASE UART3_BASE_ADDR + +/* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 2048 +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) + +/* PHY needs a longer autonegotiation timeout after reset */ +#define PHY_ANEG_TIMEOUT 20000 +#define FEC_QUIRK_ENET_MAC + +/* USDHC */ +#define CONFIG_SYS_FSL_USDHC_NUM 2 +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define CONFIG_SYS_MMC_IMG_LOAD_PART 1 + +#if !defined(CONFIG_SPL_BUILD) + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "altbootcmd=setenv devpart 2 && run bootcmd ; reset\0" \ + "bootlimit=3\0" \ + "devtype=mmc\0" \ + "devpart=1\0" \ + /* Give slow devices beyond USB HUB chance to come up. */ \ + "usb_pgood_delay=2000\0" \ + "dfu_alt_info=" \ + /* RAM block at DRAM offset 256..768 MiB */ \ + "ram ram0=ram ram 0x50000000 0x20000000&" \ + /* 16 MiB SPI NOR */ \ + "mtd nor0=sf raw 0x0 0x1000000\0" \ + "dmo_preboot=" \ + "sf probe ; " /* Scan for SPI NOR, needed by DFU */ \ + "run dmo_usb_start_hub ; " \ + /* Attempt to start USB and Network console */ \ + "run dmo_usb_cdc_acm_start ; " \ + "run dmo_netconsole_start\0" \ + "dmo_update_env=" \ + "setenv dmo_update_env true ; saveenv ; saveenv\0" \ + "dmo_usb_cdc_acm_start=" \ + "if test "${dmo_usb_cdc_acm_enabled}" = "true" ; then "\ + /* Ungate IMX8MM_CLK_USB1_CTRL_ROOT */ \ + "mw 0x303844d0 3 ; " \ + /* Read USBNC_n_PHY_STATUS BIT(4) VBUS_VLD */ \ + "setexpr.l usbnc_n_phy_status *0x32e4023c \\& 0x8 ; " \ + /* If USB OTG has valid VBUS, enable CDC ACM */ \ + "if test "${usbnc_n_phy_status}" -eq 8 ; then "\ + "usb start && " \ + "setenv stderr ${stderr},usbacm && " \ + "setenv stdout ${stdout},usbacm && " \ + "setenv stdin ${stdin},usbacm ; " \ + "fi ; " \ + "fi\0" \ + "dmo_usb_start_hub=" \ + "i2c dev 1 ; " \ + /* Reset the USB USB */ \ + "gpio clear GPIO5_2 ; sleep 0.01 ; " /* t1 > 1us */ \ + "gpio set GPIO5_2 ; sleep 0.01 ; " /* t5 > 3us */ \ + /* Write chunks of descriptor into the USB HUB */ \ + "mw.l 0x7e1000 0x14042417 ; mw.l 0x7e1004 0x9b0bb325 ; "\ + "mw.l 0x7e1008 0x00000220 ; mw.l 0x7e100c 0x01320100 ; "\ + "mw.l 0x7e1010 0x00003232 ; mw.l 0x7e1014 0x4d000909 ; "\ + "i2c write 0x7e1000 0x2c 0x00 0x18 -s ; " \ + "mw.l 0x7e1000 0x6300690f ; mw.l 0x7e1004 0x6f007200 ; "\ + "mw.l 0x7e1008 0x68006300 ; mw.l 0x7e100c 0x70006900 ; "\ + "i2c write 0x7e1000 0x2c 0x18 0x10 -s ; " \ + "mw.l 0x7e1000 0x53005511 ; mw.l 0x7e1004 0x32004200 ; "\ + "mw.l 0x7e1008 0x31003500 ; mw.l 0x7e100c 0x42003400 ; "\ + "mw.l 0x7e1010 0x00006900 ; " \ + "i2c write 0x7e1000 0x2c 0x54 0x12 -s ; " \ + "mw.l 0x7e1000 0x00000101 ; " \ + "i2c write 0x7e1000 0x2c 0xff 0x2 -s\0" \ + "dmo_netconsole_start=" \ + "if test "${dmo_netconsole_enabled}" = "true" ; then "\ + "setenv autoload false && " \ + "dhcp && " \ + "setenv autoload && " \ + "setenv ncip ${serverip} && " \ + "setenv stderr ${stderr},nc && " \ + "setenv stdout ${stdout},nc && " \ + "setenv stdin ${stdin},nc ; " \ + "fi" + +#endif + +#endif
Add support for Data Modul i.MX8M Mini eDM SBC board. This is an evaluation board for various custom display units. Currently supported are serial console, ethernet, eMMC, SD, SPI NOR, USB host and USB OTG. Reviewed-by: Fabio Estevam festevam@denx.de Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
sbabic@denx.de
