[PATCH 1/2] mvebu: eDPU: disable SCSI support
eDPU does not use SCSI nor it has SATA exposed, and commit arm: mvebu: a3720: Set BOOT_TARGET_DEVICES list to enabled peripherals now allows compiling U-boot wihout all of the BOOT_TARGET_DEVICES since not all boards have all of the listed peripherals exposed.
So, disable SCSI support in defconfig for eDPU.
Signed-off-by: Robert Marko robert.marko@sartura.hr --- configs/eDPU_defconfig | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/configs/eDPU_defconfig b/configs/eDPU_defconfig index e2e593ad21..9c124bf147 100644 --- a/configs/eDPU_defconfig +++ b/configs/eDPU_defconfig @@ -32,7 +32,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_MTD=y -# CONFIG_CMD_SCSI is not set CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set @@ -78,7 +77,7 @@ CONFIG_PINCTRL=y CONFIG_PINCTRL_ARMADA_37XX=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y -CONFIG_DM_SCSI=y +# CONFIG_SCSI is not set CONFIG_MVEBU_A3700_UART=y CONFIG_MVEBU_A3700_SPI=y CONFIG_SYSINFO=y
uDPU like eDPU does not expose SCSI based peripherals like SATA nor PCI and for sure it does not have the Intel E1000 PCI card.
So, like for eDPU remove those from the defconfig.
Signed-off-by: Robert Marko robert.marko@sartura.hr --- configs/uDPU_defconfig | 7 +------ 1 file changed, 1 insertion(+), 6 deletions(-)
diff --git a/configs/uDPU_defconfig b/configs/uDPU_defconfig index f7cd1a0589..ec7cda6a29 100644 --- a/configs/uDPU_defconfig +++ b/configs/uDPU_defconfig @@ -12,7 +12,6 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-3720-uDPU" CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_SYS_LOAD_ADDR=0x6000000 CONFIG_DEBUG_UART=y -CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y @@ -33,7 +32,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_MTD=y -CONFIG_CMD_PCI=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set @@ -49,7 +47,6 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ARP_TIMEOUT=200 CONFIG_NET_RETRY_COUNT=50 CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_AHCI_MVEBU=y CONFIG_CLK=y CONFIG_CLK_MVEBU=y CONFIG_DM_I2C=y @@ -72,17 +69,15 @@ CONFIG_PHYLIB_10G=y CONFIG_PHY_MARVELL=y CONFIG_PHY_FIXED=y CONFIG_PHY_GIGE=y -CONFIG_E1000=y CONFIG_MVNETA=y CONFIG_MVMDIO=y -CONFIG_PCI=y -CONFIG_PCI_AARDVARK=y CONFIG_PHY=y CONFIG_MVEBU_COMPHY_SUPPORT=y CONFIG_PINCTRL=y CONFIG_PINCTRL_ARMADA_37XX=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +# CONFIG_SCSI is not set CONFIG_MVEBU_A3700_UART=y CONFIG_MVEBU_A3700_SPI=y CONFIG_SYSINFO=y
Reviewed-by: Pali Rohár pali@kernel.org
diff --git a/configs/uDPU_defconfig b/configs/uDPU_defconfig index f7cd1a0589..ec7cda6a29 100644 --- a/configs/uDPU_defconfig +++ b/configs/uDPU_defconfig @@ -12,7 +12,6 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-3720-uDPU" CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_SYS_LOAD_ADDR=0x6000000 CONFIG_DEBUG_UART=y -CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y @@ -33,7 +32,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_MTD=y -CONFIG_CMD_PCI=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set @@ -49,7 +47,6 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ARP_TIMEOUT=200 CONFIG_NET_RETRY_COUNT=50 CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_AHCI_MVEBU=y CONFIG_CLK=y CONFIG_CLK_MVEBU=y CONFIG_DM_I2C=y @@ -72,17 +69,15 @@ CONFIG_PHYLIB_10G=y CONFIG_PHY_MARVELL=y CONFIG_PHY_FIXED=y CONFIG_PHY_GIGE=y -CONFIG_E1000=y CONFIG_MVNETA=y CONFIG_MVMDIO=y -CONFIG_PCI=y -CONFIG_PCI_AARDVARK=y CONFIG_PHY=y CONFIG_MVEBU_COMPHY_SUPPORT=y CONFIG_PINCTRL=y CONFIG_PINCTRL_ARMADA_37XX=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +# CONFIG_SCSI is not set CONFIG_MVEBU_A3700_UART=y CONFIG_MVEBU_A3700_SPI=y CONFIG_SYSINFO=y -- 2.36.1
Thanks, Stefan
Viele Grüße, Stefan Roese
Applied to u-boot-marvell/master
Thanks, Stefan
diff --git a/configs/eDPU_defconfig b/configs/eDPU_defconfig index e2e593ad21..9c124bf147 100644 --- a/configs/eDPU_defconfig +++ b/configs/eDPU_defconfig @@ -32,7 +32,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_MTD=y -# CONFIG_CMD_SCSI is not set CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set @@ -78,7 +77,7 @@ CONFIG_PINCTRL=y CONFIG_PINCTRL_ARMADA_37XX=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y -CONFIG_DM_SCSI=y +# CONFIG_SCSI is not set CONFIG_MVEBU_A3700_UART=y CONFIG_MVEBU_A3700_SPI=y CONFIG_SYSINFO=y -- 2.36.1
Thanks, Stefan
Thanks, Stefan
Pali Rohár
Robert Marko
Stefan Roese
