[U-Boot] [PATCH 1/2] XPedite5200 board support cleanup
Signed-off-by: Peter Tyser ptyser@xes-inc.com --- This should be applied to the 85xx repository and depends on the currently applied "XPedite5200 board support" patch.
board/xes/common/actl_nand.c | 65 ++++ board/xes/common/fsl_85xx_pci.c | 6 +- board/xes/xpedite5200/Makefile | 55 ++++ board/xes/xpedite5200/config.mk | 34 +++ board/xes/xpedite5200/ddr.c | 91 ++++++ board/xes/xpedite5200/law.c | 51 ++++ board/xes/xpedite5200/tlb.c | 85 ++++++ board/xes/xpedite5200/u-boot.lds | 145 +++++++++ board/xes/xpedite5200/xpedite5200.c | 125 ++++++++ include/configs/XPEDITE5200.h | 546 +++++++++++++++++++++++++++++++++++ 10 files changed, 1200 insertions(+), 3 deletions(-) create mode 100644 board/xes/common/actl_nand.c create mode 100644 board/xes/xpedite5200/Makefile create mode 100644 board/xes/xpedite5200/config.mk create mode 100644 board/xes/xpedite5200/ddr.c create mode 100644 board/xes/xpedite5200/law.c create mode 100644 board/xes/xpedite5200/tlb.c create mode 100644 board/xes/xpedite5200/u-boot.lds create mode 100644 board/xes/xpedite5200/xpedite5200.c create mode 100644 include/configs/XPEDITE5200.h
diff --git a/board/xes/common/actl_nand.c b/board/xes/common/actl_nand.c new file mode 100644 index 0000000..465aeb0 --- /dev/null +++ b/board/xes/common/actl_nand.c @@ -0,0 +1,65 @@ +/* + * Copyright 2008 Extreme Engineering Solutions, Inc. + * + * This driver support NAND devices which have address lines + * connected as ALE and CLE inputs. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <nand.h> +#include <asm/io.h> + +/* + * Hardware specific access to control-lines + */ +static void nand_addr_hwcontrol(struct mtd_info *mtd, int cmd, uint ctrl) +{ + struct nand_chip *this = mtd->priv; + ulong IO_ADDR_W; + + if (ctrl & NAND_CTRL_CHANGE) { + IO_ADDR_W = (ulong)this->IO_ADDR_W; + + IO_ADDR_W &= ~(CONFIG_SYS_NAND_ACTL_CLE | + CONFIG_SYS_NAND_ACTL_ALE | + CONFIG_SYS_NAND_ACTL_NCE); + if (ctrl & NAND_CLE) + IO_ADDR_W |= CONFIG_SYS_NAND_ACTL_CLE; + if (ctrl & NAND_ALE) + IO_ADDR_W |= CONFIG_SYS_NAND_ACTL_ALE; + if (ctrl & NAND_NCE) + IO_ADDR_W |= CONFIG_SYS_NAND_ACTL_NCE; + + this->IO_ADDR_W = (void *)IO_ADDR_W; + } + + if (cmd != NAND_CMD_NONE) + writeb(cmd, this->IO_ADDR_W); +} + +int board_nand_init(struct nand_chip *nand) +{ + nand->ecc.mode = NAND_ECC_SOFT; + nand->cmd_ctrl = nand_addr_hwcontrol; + nand->chip_delay = CONFIG_SYS_NAND_ACTL_DELAY; + + return 0; +} diff --git a/board/xes/common/fsl_85xx_pci.c b/board/xes/common/fsl_85xx_pci.c index 56f3447..cd65a73 100644 --- a/board/xes/common/fsl_85xx_pci.c +++ b/board/xes/common/fsl_85xx_pci.c @@ -179,7 +179,7 @@ void pci_init_board(void)
fsl_pci_init(hose);
- first_free_busno = hose->last_busno+1; + first_free_busno = hose->last_busno + 1; printf(" PCI1 on bus %02x - %02x\n", hose->first_busno, hose->last_busno); } else { @@ -289,7 +289,7 @@ void pci_init_board(void) if (!host) fsl_pci_config_unlock(hose);
- first_free_busno = hose->last_busno+1; + first_free_busno = hose->last_busno + 1; printf(" PCIE2 on bus %02x - %02x\n", hose->first_busno, hose->last_busno); } @@ -343,7 +343,7 @@ void pci_init_board(void) if (!host) fsl_pci_config_unlock(hose);
- first_free_busno = hose->last_busno+1; + first_free_busno = hose->last_busno + 1; printf(" PCIE3 on bus %02x - %02x\n", hose->first_busno, hose->last_busno); } diff --git a/board/xes/xpedite5200/Makefile b/board/xes/xpedite5200/Makefile new file mode 100644 index 0000000..02fe8fc --- /dev/null +++ b/board/xes/xpedite5200/Makefile @@ -0,0 +1,55 @@ +# +# Copyright 2008 Extreme Engineering Solutions, Inc. +# Copyright 2004 Freescale Semiconductor. +# (C) Copyright 2001-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS-y += $(BOARD).o +COBJS-y += ddr.o +COBJS-y += law.o +COBJS-y += tlb.o + +SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS-y)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +clean: + rm -f $(OBJS) $(SOBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/xes/xpedite5200/config.mk b/board/xes/xpedite5200/config.mk new file mode 100644 index 0000000..be5a5c3 --- /dev/null +++ b/board/xes/xpedite5200/config.mk @@ -0,0 +1,34 @@ +# +# Copyright 2008 Extreme Engineering Solutions, Inc. +# Copyright 2004, 2007 Freescale Semiconductor. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +# +# xpedite5200 board +# +ifndef TEXT_BASE +TEXT_BASE = 0xfff80000 +endif + +PLATFORM_CPPFLAGS += -DCONFIG_E500=1 +PLATFORM_CPPFLAGS += -DCONFIG_MPC85xx=1 +PLATFORM_CPPFLAGS += -DCONFIG_MPC8548=1 +PLATFORM_CPPFLAGS += -mrelocatable diff --git a/board/xes/xpedite5200/ddr.c b/board/xes/xpedite5200/ddr.c new file mode 100644 index 0000000..c5616d5 --- /dev/null +++ b/board/xes/xpedite5200/ddr.c @@ -0,0 +1,91 @@ +/* + * Copyright 2008 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * Version 2 as published by the Free Software Foundation. + */ + +#include <common.h> +#include <i2c.h> + +#include <asm/fsl_ddr_sdram.h> +#include <asm/fsl_ddr_dimm_params.h> + +static void +get_spd(ddr2_spd_eeprom_t *spd, unsigned char i2c_address) +{ + i2c_read(i2c_address, 0, 1, (uchar *)spd, sizeof(ddr2_spd_eeprom_t)); + + /* We use soldered memory, but use an SPD EEPROM to describe it. + * The SPD has an unspecified dimm type, but the DDR2 initialization + * code requires a specific type to be specified. This sets the type + * as a standard unregistered SO-DIMM. */ + if (spd->dimm_type == 0) { + spd->dimm_type = 0x4; + ((uchar *)spd)[63] += 0x4; + } +} + +unsigned int fsl_ddr_get_mem_data_rate(void) +{ + return get_ddr_freq(0); +} + +void fsl_ddr_get_spd(ddr2_spd_eeprom_t *ctrl_dimms_spd, + unsigned int ctrl_num) +{ + unsigned int i; + + if (ctrl_num) { + printf("%s: invalid ctrl_num = %d\n", __func__, ctrl_num); + return; + } + + for (i = 0; i < CONFIG_DIMM_SLOTS_PER_CTLR; i++) + get_spd(&(ctrl_dimms_spd[i]), SPD_EEPROM_ADDRESS); +} + +void fsl_ddr_board_options(memctl_options_t *popts, + dimm_params_t *pdimm, + unsigned int ctrl_num) +{ + /* + * Factors to consider for clock adjust: + * - number of chips on bus + * - position of slot + * - DDR1 vs. DDR2? + * - ??? + * + * This needs to be determined on a board-by-board basis. + * 0110 3/4 cycle late + * 0111 7/8 cycle late + */ + popts->clk_adjust = 7; + + /* + * Factors to consider for CPO: + * - frequency + * - ddr1 vs. ddr2 + */ + popts->cpo_override = 9; + + /* + * Factors to consider for write data delay: + * - number of DIMMs + * + * 1 = 1/4 clock delay + * 2 = 1/2 clock delay + * 3 = 3/4 clock delay + * 4 = 1 clock delay + * 5 = 5/4 clock delay + * 6 = 3/2 clock delay + */ + popts->write_data_delay = 3; + + /* + * Factors to consider for half-strength driver enable: + * - number of DIMMs installed + */ + popts->half_strength_driver_enable = 0; +} diff --git a/board/xes/xpedite5200/law.c b/board/xes/xpedite5200/law.c new file mode 100644 index 0000000..386f9c5 --- /dev/null +++ b/board/xes/xpedite5200/law.c @@ -0,0 +1,51 @@ +/* + * Copyright 2008 Extreme Engineering Solutions, Inc. + * Copyright 2008 Freescale Semiconductor, Inc. + * + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_law.h> +#include <asm/mmu.h> + +/* + * Notes: + * CCSRBAR and L2-as-SRAM don't need a configured Local Access Window. + * If flash is 8M at default position (last 8M), no LAW needed. + */ + +struct law_entry law_table[] = { + /* LBC window - maps 256M 0xf0000000 -> 0xffffffff */ + SET_LAW(CONFIG_SYS_FLASH_BASE2, LAW_SIZE_256M, LAW_TRGT_IF_LBC), + SET_LAW(CONFIG_SYS_NAND_BASE, LAW_SIZE_1M, LAW_TRGT_IF_LBC), +#if CONFIG_SYS_PCI1_MEM_PHYS + SET_LAW(CONFIG_SYS_PCI1_MEM_PHYS, LAW_SIZE_1G, LAW_TRGT_IF_PCI_1), + SET_LAW(CONFIG_SYS_PCI1_IO_PHYS, LAWAR_SIZE_8M, LAW_TRGT_IF_PCI_1), +#endif +#if CONFIG_SYS_PCI2_MEM_PHYS + SET_LAW(CONFIG_SYS_PCI2_MEM_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_PCI_2), + SET_LAW(CONFIG_SYS_PCI2_IO_PHYS, LAW_SIZE_8M, LAW_TRGT_IF_PCI_2), +#endif +}; + +int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/xes/xpedite5200/tlb.c b/board/xes/xpedite5200/tlb.c new file mode 100644 index 0000000..bd7bff8 --- /dev/null +++ b/board/xes/xpedite5200/tlb.c @@ -0,0 +1,85 @@ +/* + * Copyright 2008 Extreme Engineering Solutions, Inc. + * Copyright 2008 Freescale Semiconductor, Inc. + * + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/mmu.h> + +struct fsl_e_tlb_entry tlb_table[] = { + /* TLB 0 - for temp stack in cache */ + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR, CONFIG_SYS_INIT_RAM_ADDR, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + + /* W**G* - NOR flashes */ + /* This will be changed to *I*G* after relocation to RAM. */ + SET_TLB_ENTRY(1, CONFIG_SYS_FLASH_BASE2, CONFIG_SYS_FLASH_BASE2, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_W|MAS2_G, + 0, 0, BOOKE_PAGESZ_256M, 1), + + SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 1, BOOKE_PAGESZ_1M, 1), + + /* *I*G* - NAND flash */ + SET_TLB_ENTRY(1, CONFIG_SYS_NAND_BASE, CONFIG_SYS_NAND_BASE, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 2, BOOKE_PAGESZ_1M, 1), + +#if CONFIG_PCI1 + /* *I*G* - PCI MEM */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCI1_MEM_PHYS, CONFIG_SYS_PCI1_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 3, BOOKE_PAGESZ_1G, 1), +#endif + +#if CONFIG_PCI2 + /* *I*G* - PCI MEM */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCI2_MEM_PHYS, CONFIG_SYS_PCI2_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 4, BOOKE_PAGESZ_256M, 1), +#endif + +#if defined(CONFIG_PCI1) || defined(CONFIG_PCI2) + /* *I*G* - PCI IO */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCI1_IO_PHYS, CONFIG_SYS_PCI1_IO_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 5, BOOKE_PAGESZ_16M, 1), +#endif +}; + +int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/board/xes/xpedite5200/u-boot.lds b/board/xes/xpedite5200/u-boot.lds new file mode 100644 index 0000000..bd952d2 --- /dev/null +++ b/board/xes/xpedite5200/u-boot.lds @@ -0,0 +1,145 @@ +/* + * Copyright 2008 Extreme Engineering Solutions, Inc. + * Copyright 2004, 2007-2008 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_ARCH(powerpc) +/* Do we need any of these for elf? + __DYNAMIC = 0; */ +PHDRS +{ + text PT_LOAD; + bss PT_LOAD; +} + +SECTIONS +{ + /* Read-only sections, merged into text segment: */ + . = + SIZEOF_HEADERS; + .interp : { *(.interp) } + .hash : { *(.hash) } + .dynsym : { *(.dynsym) } + .dynstr : { *(.dynstr) } + .rel.text : { *(.rel.text) } + .rela.text : { *(.rela.text) } + .rel.data : { *(.rel.data) } + .rela.data : { *(.rela.data) } + .rel.rodata : { *(.rel.rodata) } + .rela.rodata : { *(.rela.rodata) } + .rel.got : { *(.rel.got) } + .rela.got : { *(.rela.got) } + .rel.ctors : { *(.rel.ctors) } + .rela.ctors : { *(.rela.ctors) } + .rel.dtors : { *(.rel.dtors) } + .rela.dtors : { *(.rela.dtors) } + .rel.bss : { *(.rel.bss) } + .rela.bss : { *(.rela.bss) } + .rel.plt : { *(.rel.plt) } + .rela.plt : { *(.rela.plt) } + .init : { *(.init) } + .plt : { *(.plt) } + .text : + { + *(.text) + *(.got1) + } :text + _etext = .; + PROVIDE (etext = .); + .rodata : + { + *(.rodata) + *(.rodata1) + *(.rodata.str1.4) + *(.eh_frame) + } :text + .fini : { *(.fini) } =0 + .ctors : { *(.ctors) } + .dtors : { *(.dtors) } + + /* Read-write section, merged into data segment: */ + . = (. + 0x00FF) & 0xFFFFFF00; + _erotext = .; + PROVIDE (erotext = .); + .reloc : + { + *(.got) + _GOT2_TABLE_ = .; + *(.got2) + _FIXUP_TABLE_ = .; + *(.fixup) + } + __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >> 2; + __fixup_entries = (. - _FIXUP_TABLE_) >> 2; + + .data : + { + *(.data) + *(.data1) + *(.sdata) + *(.sdata2) + *(.dynamic) + CONSTRUCTORS + } + _edata = .; + PROVIDE (edata = .); + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = .; + __start___ex_table = .; + __ex_table : { *(__ex_table) } + __stop___ex_table = .; + + . = ALIGN(256); + __init_begin = .; + .text.init : { *(.text.init) } + .data.init : { *(.data.init) } + . = ALIGN(256); + __init_end = .; + + .bootpg ADDR(.text) + 0x7f000 : + { + cpu/mpc85xx/start.o (.bootpg) + } :text = 0xffff + + .resetvec ADDR(.text) + 0x7fffc : + { + *(.resetvec) + } :text = 0xffff + + . = ADDR(.text) + 0x80000; + + __bss_start = .; + .bss (NOLOAD) : + { + *(.sbss) *(.scommon) + *(.dynbss) + *(.bss) + *(COMMON) + } :bss + + . = ALIGN(4); + _end = . ; + PROVIDE (end = .); +} diff --git a/board/xes/xpedite5200/xpedite5200.c b/board/xes/xpedite5200/xpedite5200.c new file mode 100644 index 0000000..e266d1d --- /dev/null +++ b/board/xes/xpedite5200/xpedite5200.c @@ -0,0 +1,125 @@ +/* + * Copyright 2008 Extreme Engineering Solutions, Inc. + * Copyright 2004, 2007 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <pci.h> +#include <asm/processor.h> +#include <asm/immap_85xx.h> +#include <asm/immap_fsl_pci.h> +#include <asm/io.h> +#include <asm/cache.h> +#include <asm/mmu.h> +#include <libfdt.h> +#include <fdt_support.h> +#include <pca953x.h> + +extern void ft_board_pci_setup(void *blob, bd_t *bd); + +int checkboard(void) +{ + volatile ccsr_lbc_t *lbc = (void *)(CONFIG_SYS_MPC85xx_LBC_ADDR); + volatile ccsr_local_ecm_t *ecm = (void *)(CONFIG_SYS_MPC85xx_ECM_ADDR); + + char *s; + + printf("Board: X-ES %s PMC\n", CONFIG_SYS_BOARD_NAME); + printf(" "); + s = getenv("board_rev"); + if (s) + printf("Rev %s, ", s); + s = getenv("serial#"); + if (s) + printf("Serial# %s, ", s); + s = getenv("board_cfg"); + if (s) + printf("Cfg %s", s); + printf("\n"); + + lbc->ltesr = 0xffffffff; /* Clear LBC error interrupts */ + lbc->lteir = 0xffffffff; /* Enable LBC error interrupts */ + ecm->eedr = 0xffffffff; /* Clear ecm errors */ + ecm->eeer = 0xffffffff; /* Enable ecm errors */ + + return 0; +} + +static void flash_cs_fixup(void) +{ + volatile ccsr_lbc_t *lbc = (void *)(CONFIG_SYS_MPC85xx_LBC_ADDR); + int flash_sel; + + /* + * Print boot dev and swap flash flash chip selects if booted from 2nd + * flash. Swapping chip selects presents user with a common memory + * map regardless of which flash was booted from. + */ + flash_sel = !((pca953x_get_val(CONFIG_SYS_I2C_PCA953X_ADDR0) & + CONFIG_SYS_PCA953X_FLASH_PASS_CS)); + printf("FLASH: Executed from FLASH%d\n", flash_sel ? 2 : 1); + + if (flash_sel) { + lbc->br0 = CONFIG_SYS_BR1_PRELIM; + lbc->or0 = CONFIG_SYS_OR1_PRELIM; + + lbc->br1 = CONFIG_SYS_BR0_PRELIM; + lbc->or1 = CONFIG_SYS_OR0_PRELIM; + } +} + +int board_early_init_r(void) +{ + /* Initialize PCA9557 devices */ + pca953x_set_pol(CONFIG_SYS_I2C_PCA953X_ADDR0, 0xff, 0); + pca953x_set_pol(CONFIG_SYS_I2C_PCA953X_ADDR1, 0xff, 0); + + /* + * Remap NOR flash region to caching-inhibited + * so that flash can be erased/programmed properly. + */ + + /* Flush d-cache and invalidate i-cache of any FLASH data */ + flush_dcache(); + invalidate_icache(); + + /* Invalidate existing TLB entry for NOR flash */ + disable_tlb(0); + set_tlb(1, (CONFIG_SYS_FLASH_BASE2 & 0xf0000000), + (CONFIG_SYS_FLASH_BASE2 & 0xf0000000), + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 0, BOOKE_PAGESZ_256M, 1); + + flash_cs_fixup(); + + return 0; +} + +#if defined(CONFIG_OF_BOARD_SETUP) +void ft_board_setup(void *blob, bd_t *bd) +{ +#ifdef CONFIG_PCI + ft_board_pci_setup(blob, bd); +#endif + ft_cpu_setup(blob, bd); +} +#endif diff --git a/include/configs/XPEDITE5200.h b/include/configs/XPEDITE5200.h new file mode 100644 index 0000000..1df6855 --- /dev/null +++ b/include/configs/XPEDITE5200.h @@ -0,0 +1,546 @@ +/* + * Copyright 2008 Extreme Engineering Solutions, Inc. + * Copyright 2004-2008 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * xpedite5200 board configuration file + */ +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Configuration Options + */ +#define CONFIG_BOOKE 1 /* BOOKE */ +#define CONFIG_E500 1 /* BOOKE e500 family */ +#define CONFIG_MPC85xx 1 /* MPC8540/60/55/41/48 */ +#define CONFIG_MPC8548 1 +#define CONFIG_XPEDITE5200 1 +#define CONFIG_SYS_BOARD_NAME "XPedite5200" +#define CONFIG_BOARD_EARLY_INIT_R /* Call board_pre_init */ +#define CONFIG_RELOC_FIXUP_WORKS /* Fully relocate to SDRAM */ + +#define CONFIG_PCI 1 /* Enable PCI/PCIE */ +#define CONFIG_PCI_PNP 1 /* do pci plug-and-play */ +#define CONFIG_PCI_SCAN_SHOW 1 /* show pci devices on startup */ +#define CONFIG_PCI1 1 /* PCI controller 1 */ +#define CONFIG_FSL_PCI_INIT 1 /* Use common FSL init code */ +#define CONFIG_SYS_PCI_64BIT 1 /* enable 64-bit PCI resources */ +#define CONFIG_FSL_LAW 1 /* Use common FSL init code */ + +/* + * DDR config + */ +#define CONFIG_FSL_DDR2 +#undef CONFIG_FSL_DDR_INTERACTIVE +#define CONFIG_SPD_EEPROM /* Use SPD EEPROM for DDR setup */ +#define CONFIG_DDR_SPD +#define CONFIG_MEM_INIT_VALUE 0xdeadbeef +#define SPD_EEPROM_ADDRESS 0x54 +#define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 +#define CONFIG_CHIP_SELECTS_PER_CTRL 2 +#define CONFIG_DDR_ECC +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER +#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE +#define CONFIG_VERY_BIG_RAM + +#define CONFIG_SYS_CLK_FREQ 66666666 + +/* + * These can be toggled for performance analysis, otherwise use default. + */ +#define CONFIG_L2_CACHE /* toggle L2 cache */ +#define CONFIG_BTB /* toggle branch predition */ +#define CONFIG_ENABLE_36BIT_PHYS 1 + +/* + * Base addresses -- Note these are effective addresses where the + * actual resources get mapped (not physical addresses) + */ +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 /* CCSRBAR Default */ +#define CONFIG_SYS_CCSRBAR 0xef000000 /* relocated CCSRBAR */ +#define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR /* physical addr of CCSRBAR */ +#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR /* PQII uses CONFIG_SYS_IMMR */ +#define CONFIG_SYS_PCI1_ADDR (CONFIG_SYS_CCSRBAR + 0x8000) + +/* + * Diagnostics + */ +#define CONFIG_SYS_ALT_MEMTEST +#define CONFIG_SYS_MEMTEST_START 0x10000000 +#define CONFIG_SYS_MEMTEST_END 0x20000000 + +/* + * Memory map + * 0x0000_0000 0x7fff_ffff DDR 2G Cacheable + * 0x8000_0000 0xbfff_ffff PCI1 Mem 1G non-cacheable + * 0xe000_0000 0xe7ff_ffff SRAM/SSRAM/L1 Cache 128M non-cacheable + * 0xe800_0000 0xe87f_ffff PCI1 IO 8M non-cacheable + * 0xef00_0000 0xef0f_ffff CCSR/IMMR 1M non-cacheable + * 0xef80_0000 0xef8f_ffff NAND Flash 1M non-cacheable + * 0xf800_0000 0xfbff_ffff NOR Flash 2 64M non-cacheable + * 0xfc00_0000 0xffff_ffff NOR Flash 1 64M non-cacheable + */ + +#define CONFIG_SYS_LBC_LCRR (LCRR_CLKDIV_4 | LCRR_EADC_3) + +/* + * NAND flash configuration + */ +#define CONFIG_SYS_NAND_BASE 0xef800000 +#define CONFIG_SYS_NAND_BASE2 0xef840000 /* Unused at this time */ +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_NAND_ACTL +#define CONFIG_SYS_NAND_ACTL_CLE (1 << 3) /* ADDR3 is CLE */ +#define CONFIG_SYS_NAND_ACTL_ALE (1 << 4) /* ADDR4 is ALE */ +#define CONFIG_SYS_NAND_ACTL_NCE (0) /* NCE not controlled by ADDR */ +#define CONFIG_SYS_NAND_ACTL_DELAY 25 + +/* + * NOR flash configuration + */ +#define CONFIG_SYS_FLASH_BASE 0xfc000000 +#define CONFIG_SYS_FLASH_BASE2 0xf8000000 +#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE2} +#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_AUTOPROTECT_LIST { {0xfff40000, 0xc0000}, \ + {0xfbf40000, 0xc0000} } +#define CONFIG_SYS_MONITOR_BASE TEXT_BASE /* start of monitor */ + +/* + * Chip select configuration + */ +/* NOR Flash 0 on CS0 */ +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | \ + BR_PS_16 | \ + BR_V) +#define CONFIG_SYS_OR0_PRELIM (OR_AM_64MB | \ + OR_GPCM_ACS_DIV4 | \ + OR_GPCM_SCY_8) + +/* NOR Flash 1 on CS1 */ +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_FLASH_BASE2 | \ + BR_PS_16 | \ + BR_V) +#define CONFIG_SYS_OR1_PRELIM CONFIG_SYS_OR0_PRELIM + +/* NAND flash on CS2 */ +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_NAND_BASE | \ + BR_PS_8 | \ + BR_V) + +/* NAND flash on CS2 */ +#define CONFIG_SYS_OR2_PRELIM (OR_AM_256KB | \ + OR_GPCM_BCTLD | \ + OR_GPCM_CSNT | \ + OR_GPCM_ACS_DIV4 | \ + OR_GPCM_SCY_4 | \ + OR_GPCM_TRLX | \ + OR_GPCM_EHTR) + +/* NAND flash on CS3 */ +#define CONFIG_SYS_BR3_PRELIM (CONFIG_SYS_NAND_BASE2 | \ + BR_PS_8 | \ + BR_V) +#define CONFIG_SYS_OR3_PRELIM CONFIG_SYS_OR2_PRELIM + +/* + * Use L1 as initial stack + */ +#define CONFIG_SYS_INIT_RAM_LOCK 1 +#define CONFIG_SYS_INIT_RAM_ADDR 0xe0000000 +#define CONFIG_SYS_INIT_RAM_END 0x4000 + +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */ +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +#define CONFIG_SYS_MONITOR_LEN (512 * 1024) /* Reserve 512 KB for Mon */ +#define CONFIG_SYS_MALLOC_LEN (1024 * 1024) /* Reserved for malloc */ + +/* + * Serial Port + */ +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK get_bus_freq(0) +#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) +#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600) +#define CONFIG_SYS_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 115200} +#define CONFIG_BAUDRATE 115200 +#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ +#define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ + +/* + * Use the HUSH parser + */ +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +/* + * Pass open firmware flat tree + */ +#define CONFIG_OF_LIBFDT 1 +#define CONFIG_OF_BOARD_SETUP 1 +#define CONFIG_OF_STDOUT_VIA_ALIAS 1 + +#define CONFIG_SYS_64BIT_VSPRINTF 1 +#define CONFIG_SYS_64BIT_STRTOUL 1 + +/* + * I2C + */ +#define CONFIG_FSL_I2C /* Use FSL common I2C driver */ +#define CONFIG_HARD_I2C /* I2C with hardware support */ +#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SYS_I2C_OFFSET 0x3000 +#define CONFIG_SYS_I2C2_OFFSET 0x3100 +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_I2C_CMD_TREE + +/* I2C EEPROM */ +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 6 /* 64 byte pages */ +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* take up to 10 msec */ + +/* I2C RTC */ +#define CONFIG_RTC_M41T11 1 +#define CONFIG_SYS_I2C_RTC_ADDR 0x68 +#define CONFIG_SYS_M41T11_BASE_YEAR 2000 + +/* GPIO */ +#define CONFIG_PCA953X +#define CONFIG_SYS_I2C_PCA953X_ADDR0 0x18 +#define CONFIG_SYS_I2C_PCA953X_ADDR1 0x19 +#define CONFIG_SYS_I2C_PCA953X_ADDR CONFIG_SYS_I2C_PCA953X_ADDR0 + +/* PCA957 @ 0x18 */ +#define CONFIG_SYS_PCA953X_BRD_CFG0 0x01 +#define CONFIG_SYS_PCA953X_BRD_CFG1 0x02 +#define CONFIG_SYS_PCA953X_BRD_CFG2 0x04 +#define CONFIG_SYS_PCA953X_XMC_ROOT0 0x08 +#define CONFIG_SYS_PCA953X_FLASH_PASS_CS 0x10 +#define CONFIG_SYS_PCA953X_FLASH_WP 0x20 +#define CONFIG_SYS_PCA953X_MONARCH 0x40 +#define CONFIG_SYS_PCA953X_EREADY 0x80 + +/* PCA957 @ 0x19 */ +#define CONFIG_SYS_PCA953X_P14_IO0 0x01 +#define CONFIG_SYS_PCA953X_P14_IO1 0x02 +#define CONFIG_SYS_PCA953X_P14_IO2 0x04 +#define CONFIG_SYS_PCA953X_P14_IO3 0x08 +#define CONFIG_SYS_PCA953X_P14_IO4 0x10 +#define CONFIG_SYS_PCA953X_P14_IO5 0x20 +#define CONFIG_SYS_PCA953X_P14_IO6 0x40 +#define CONFIG_SYS_PCA953X_P14_IO7 0x80 + +/* + * General PCI + * Memory space is mapped 1-1, but I/O space must start from 0. + */ +#define CONFIG_SYS_PCI1_MEM_BASE 0x80000000 +#define CONFIG_SYS_PCI1_MEM_PHYS CONFIG_SYS_PCI1_MEM_BASE +#define CONFIG_SYS_PCI1_MEM_SIZE 0x40000000 /* 1G */ +#define CONFIG_SYS_PCI1_IO_BASE 0x00000000 +#define CONFIG_SYS_PCI1_IO_PHYS 0xe8000000 +#define CONFIG_SYS_PCI1_IO_SIZE 0x00800000 /* 1M */ + +/* + * Networking options + */ +#define CONFIG_TSEC_ENET /* tsec ethernet support */ +#define CONFIG_PHY_GIGE 1 /* Include GbE speed/duplex detection */ +#define CONFIG_NET_MULTI 1 +#define CONFIG_MII 1 /* MII PHY management */ +#define CONFIG_ETHPRIME "eTSEC1" + +#define CONFIG_TSEC1 1 +#define CONFIG_TSEC1_NAME "eTSEC1" +#define TSEC1_FLAGS TSEC_GIGABIT +#define TSEC1_PHY_ADDR 1 +#define TSEC1_PHYIDX 0 +#define CONFIG_HAS_ETH0 + +#define CONFIG_TSEC2 1 +#define CONFIG_TSEC2_NAME "eTSEC2" +#define TSEC2_FLAGS TSEC_GIGABIT +#define TSEC2_PHY_ADDR 2 +#define TSEC2_PHYIDX 0 +#define CONFIG_HAS_ETH1 + +#define CONFIG_TSEC3 1 +#define CONFIG_TSEC3_NAME "eTSEC3" +#define TSEC3_FLAGS TSEC_GIGABIT +#define TSEC3_PHY_ADDR 3 +#define TSEC3_PHYIDX 0 +#define CONFIG_HAS_ETH2 + +#define CONFIG_TSEC4 1 +#define CONFIG_TSEC4_NAME "eTSEC4" +#define TSEC4_FLAGS TSEC_GIGABIT +#define TSEC4_PHY_ADDR 4 +#define TSEC4_PHYIDX 0 +#define CONFIG_HAS_ETH3 + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY + +/* + * Command configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_ELF +#define CONFIG_CMD_ENV +#define CONFIG_CMD_FLASH +#define CONFIG_CMD_I2C +#define CONFIG_CMD_JFFS2 +#define CONFIG_CMD_MII +#define CONFIG_CMD_NAND +#define CONFIG_CMD_NET +#define CONFIG_CMD_PCA953X +#define CONFIG_CMD_PCA953X_INFO +#define CONFIG_CMD_PCI +#define CONFIG_CMD_PING +#define CONFIG_CMD_SNTP + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */ +#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ +#define CONFIG_LOADADDR 0x1000000 /* default location for tftp and bootm */ +#define CONFIG_BOOTDELAY 3 /* -1 disables auto-boot */ +#define CONFIG_PANIC_HANG /* do not reset board on panic */ +#define CONFIG_PREBOOT /* enable preboot variable */ +#define CONFIG_FIT 1 +#define CONFIG_FIT_VERBOSE 1 +#define CONFIG_INTEGRITY /* support booting INTEGRITY OS */ +#define CONFIG_INTERRUPTS /* enable pci, srio, ddr interrupts */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 16 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ (16 << 20) /* Initial Memory map for Linux*/ + +/* + * Boot Flags + */ +#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ +#define BOOTFLAG_WARM 0x02 /* Software reboot */ + +/* + * Environment Configuration + */ +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128k (one sector) for env */ +#define CONFIG_ENV_SIZE 0x8000 +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - (256 * 1024)) + +/* + * Flash memory map: + * fff80000 - ffffffff Pri U-Boot (512 KB) + * fff40000 - fff7ffff Pri U-Boot Environment (256 KB) + * fff00000 - fff3ffff Pri FDT (256KB) + * fef00000 - ffefffff Pri OS image (16MB) + * fc000000 - feefffff Pri OS Use/Filesystem (47MB) + * + * fbf80000 - fbffffff Sec U-Boot (512 KB) + * fbf40000 - fbf7ffff Sec U-Boot Environment (256 KB) + * fbf00000 - fbf3ffff Sec FDT (256KB) + * faf00000 - fbefffff Sec OS image (16MB) + * f8000000 - faefffff Sec OS Use/Filesystem (47MB) + */ +#define CONFIG_UBOOT1_ENV_ADDR MK_STR(0xfff80000) +#define CONFIG_UBOOT2_ENV_ADDR MK_STR(0xfbf80000) +#define CONFIG_FDT1_ENV_ADDR MK_STR(0xfff00000) +#define CONFIG_FDT2_ENV_ADDR MK_STR(0xfbf00000) +#define CONFIG_OS1_ENV_ADDR MK_STR(0xfef00000) +#define CONFIG_OS2_ENV_ADDR MK_STR(0xfaf00000) + +#define CONFIG_PROG_UBOOT1 \ + "$download_cmd $loadaddr $ubootfile; " \ + "if test $? -eq 0; then " \ + "protect off "CONFIG_UBOOT1_ENV_ADDR" +80000; " \ + "erase "CONFIG_UBOOT1_ENV_ADDR" +80000; " \ + "cp.w $loadaddr "CONFIG_UBOOT1_ENV_ADDR" 40000; " \ + "protect on "CONFIG_UBOOT1_ENV_ADDR" +80000; " \ + "cmp.b $loadaddr "CONFIG_UBOOT1_ENV_ADDR" 80000; " \ + "if test $? -ne 0; then " \ + "echo PROGRAM FAILED; " \ + "else; " \ + "echo PROGRAM SUCCEEDED; " \ + "fi; " \ + "else; " \ + "echo DOWNLOAD FAILED; " \ + "fi;" + +#define CONFIG_PROG_UBOOT2 \ + "$download_cmd $loadaddr $ubootfile; " \ + "if test $? -eq 0; then " \ + "protect off "CONFIG_UBOOT2_ENV_ADDR" +80000; " \ + "erase "CONFIG_UBOOT2_ENV_ADDR" +80000; " \ + "cp.w $loadaddr "CONFIG_UBOOT2_ENV_ADDR" 40000; " \ + "protect on "CONFIG_UBOOT2_ENV_ADDR" +80000; " \ + "cmp.b $loadaddr "CONFIG_UBOOT2_ENV_ADDR" 80000; " \ + "if test $? -ne 0; then " \ + "echo PROGRAM FAILED; " \ + "else; " \ + "echo PROGRAM SUCCEEDED; " \ + "fi; " \ + "else; " \ + "echo DOWNLOAD FAILED; " \ + "fi;" + +#define CONFIG_BOOT_OS_NET \ + "$download_cmd $osaddr $osfile; " \ + "if test $? -eq 0; then " \ + "if test -n $fdtaddr; then " \ + "$download_cmd $fdtaddr $fdtfile; " \ + "if test $? -eq 0; then " \ + "bootm $osaddr - $fdtaddr; " \ + "else; " \ + "echo FDT DOWNLOAD FAILED; " \ + "fi; " \ + "else; " \ + "bootm $osaddr; " \ + "fi; " \ + "else; " \ + "echo OS DOWNLOAD FAILED; " \ + "fi;" + +#define CONFIG_PROG_OS1 \ + "$download_cmd $osaddr $osfile; " \ + "if test $? -eq 0; then " \ + "erase "CONFIG_OS1_ENV_ADDR" +$filesize; " \ + "cp.b $osaddr "CONFIG_OS1_ENV_ADDR" $filesize; " \ + "cmp.b $osaddr "CONFIG_OS1_ENV_ADDR" $filesize; " \ + "if test $? -ne 0; then " \ + "echo OS PROGRAM FAILED; " \ + "else; " \ + "echo OS PROGRAM SUCCEEDED; " \ + "fi; " \ + "else; " \ + "echo OS DOWNLOAD FAILED; " \ + "fi;" + +#define CONFIG_PROG_OS2 \ + "$download_cmd $osaddr $osfile; " \ + "if test $? -eq 0; then " \ + "erase "CONFIG_OS2_ENV_ADDR" +$filesize; " \ + "cp.b $osaddr "CONFIG_OS2_ENV_ADDR" $filesize; " \ + "cmp.b $osaddr "CONFIG_OS2_ENV_ADDR" $filesize; " \ + "if test $? -ne 0; then " \ + "echo OS PROGRAM FAILED; " \ + "else; " \ + "echo OS PROGRAM SUCCEEDED; " \ + "fi; " \ + "else; " \ + "echo OS DOWNLOAD FAILED; " \ + "fi;" + +#define CONFIG_PROG_FDT1 \ + "$download_cmd $fdtaddr $fdtfile; " \ + "if test $? -eq 0; then " \ + "erase "CONFIG_FDT1_ENV_ADDR" +$filesize;" \ + "cp.b $fdtaddr "CONFIG_FDT1_ENV_ADDR" $filesize; " \ + "cmp.b $fdtaddr "CONFIG_FDT1_ENV_ADDR" $filesize; " \ + "if test $? -ne 0; then " \ + "echo FDT PROGRAM FAILED; " \ + "else; " \ + "echo FDT PROGRAM SUCCEEDED; " \ + "fi; " \ + "else; " \ + "echo FDT DOWNLOAD FAILED; " \ + "fi;" + +#define CONFIG_PROG_FDT2 \ + "$download_cmd $fdtaddr $fdtfile; " \ + "if test $? -eq 0; then " \ + "erase "CONFIG_FDT2_ENV_ADDR" +$filesize;" \ + "cp.b $fdtaddr "CONFIG_FDT2_ENV_ADDR" $filesize; " \ + "cmp.b $fdtaddr "CONFIG_FDT2_ENV_ADDR" $filesize; " \ + "if test $? -ne 0; then " \ + "echo FDT PROGRAM FAILED; " \ + "else; " \ + "echo FDT PROGRAM SUCCEEDED; " \ + "fi; " \ + "else; " \ + "echo FDT DOWNLOAD FAILED; " \ + "fi;" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "autoload=yes\0" \ + "download_cmd=tftp\0" \ + "console_args=console=ttyS0,115200\0" \ + "root_args=root=/dev/nfs rw\0" \ + "misc_args=ip=on\0" \ + "set_bootargs=setenv bootargs ${console_args} ${root_args} ${misc_args}\0" \ + "bootfile=/home/user/file\0" \ + "osfile=/home/user/uImage-XPedite5200\0" \ + "fdtfile=/home/user/xpedite5200.dtb\0" \ + "ubootfile=/home/user/u-boot.bin\0" \ + "fdtaddr=c00000\0" \ + "osaddr=0x1000000\0" \ + "loadaddr=0x1000000\0" \ + "prog_uboot1="CONFIG_PROG_UBOOT1"\0" \ + "prog_uboot2="CONFIG_PROG_UBOOT2"\0" \ + "prog_os1="CONFIG_PROG_OS1"\0" \ + "prog_os2="CONFIG_PROG_OS2"\0" \ + "prog_fdt1="CONFIG_PROG_FDT1"\0" \ + "prog_fdt2="CONFIG_PROG_FDT2"\0" \ + "bootcmd_net=run set_bootargs; "CONFIG_BOOT_OS_NET"\0" \ + "bootcmd_flash1=run set_bootargs; " \ + "bootm "CONFIG_OS1_ENV_ADDR" - "CONFIG_FDT1_ENV_ADDR"\0"\ + "bootcmd_flash2=run set_bootargs; " \ + "bootm "CONFIG_OS2_ENV_ADDR" - "CONFIG_FDT2_ENV_ADDR"\0"\ + "bootcmd=run bootcmd_flash1\0" +#endif /* __CONFIG_H */
Signed-off-by: Peter Tyser ptyser@xes-inc.com --- This should be applied to the 85xx repository and depends on the currently applied "85xx: Enable inbound PCI config cycles for X-ES boards" and "XPedite5200 board support".
board/xes/common/fsl_85xx_pci.c | 4 ++++ 1 files changed, 4 insertions(+), 0 deletions(-)
diff --git a/board/xes/common/fsl_85xx_pci.c b/board/xes/common/fsl_85xx_pci.c index cd65a73..9673a02 100644 --- a/board/xes/common/fsl_85xx_pci.c +++ b/board/xes/common/fsl_85xx_pci.c @@ -179,6 +179,10 @@ void pci_init_board(void)
fsl_pci_init(hose);
+ /* Unlock inbound PCI configuration cycles */ + if (!host) + fsl_pci_config_unlock(hose); + first_free_busno = hose->last_busno + 1; printf(" PCI1 on bus %02x - %02x\n", hose->first_busno, hose->last_busno);
Um...This doesn't appear to be true. It looks like you just respun the patches. Could you rebase your patches off the top of the 85xx tree?
Thanks, Andy
These 2 patches should apply cleanly, I just successfully retried on a clean 85xx tree to be sure. What errors are you getting?
The original "XPedite5200 board support" patch that is currently applied to the 85xx tree only modified existing files (eg Makefile, MAINTAINERS)- this "cleanup" patch adds all the new files that the original application of "XPedite5200 board support" missed. So there shouldn't be any overlap between the currently applied "XPedite5200 board support" and this patch.
The "85xx: Enable inbound PCI config cycles for X-ES boards cleanup" patch also looks legitimate. It adds code that was lost in the original patch due to incorrect order of patch application.
Let me know if you're seeing something different.
Thanks, Peter
Andy Fleming
Peter Tyser
