[U-Boot] [PATCH 1/9] wandboard: Return error if the SDHC port index is invalid
When the SDHC port number index is invalid we should return an error code immediately.
Currently we return 'status', which has a value of zero, causing board_mmc_init() to incorrectly return sucess.
Fix this by returning -EINVAL instead.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/wandboard/wandboard.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/wandboard/wandboard.c b/board/wandboard/wandboard.c index bb98352..70e070c 100644 --- a/board/wandboard/wandboard.c +++ b/board/wandboard/wandboard.c @@ -164,7 +164,7 @@ int board_mmc_init(bd_t *bis) printf("Warning: you configured more USDHC controllers" "(%d) then supported by the board (%d)\n", index + 1, CONFIG_SYS_FSL_USDHC_NUM); - return status; + return -EINVAL; }
status |= fsl_esdhc_initialize(bis, &usdhc_cfg[index]);
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx53loco/mx53loco.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/freescale/mx53loco/mx53loco.c b/board/freescale/mx53loco/mx53loco.c index 10e9d36..f1b2c40 100644 --- a/board/freescale/mx53loco/mx53loco.c +++ b/board/freescale/mx53loco/mx53loco.c @@ -204,7 +204,7 @@ int board_mmc_init(bd_t *bis) printf("Warning: you configured more ESDHC controller" "(%d) as supported by the board(2)\n", CONFIG_SYS_FSL_ESDHC_NUM); - return status; + return -EINVAL; } status |= fsl_esdhc_initialize(bis, &esdhc_cfg[index]); }
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx51evk/mx51evk.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/freescale/mx51evk/mx51evk.c b/board/freescale/mx51evk/mx51evk.c index 369da6d..80749eb 100644 --- a/board/freescale/mx51evk/mx51evk.c +++ b/board/freescale/mx51evk/mx51evk.c @@ -356,7 +356,7 @@ int board_mmc_init(bd_t *bis) printf("Warning: you configured more ESDHC controller" "(%d) as supported by the board(2)\n", CONFIG_SYS_FSL_ESDHC_NUM); - return status; + return -EINVAL; } status |= fsl_esdhc_initialize(bis, &esdhc_cfg[index]); }
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx53ard/mx53ard.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/freescale/mx53ard/mx53ard.c b/board/freescale/mx53ard/mx53ard.c index e2dbf63..1813bf5 100644 --- a/board/freescale/mx53ard/mx53ard.c +++ b/board/freescale/mx53ard/mx53ard.c @@ -201,7 +201,7 @@ int board_mmc_init(bd_t *bis) printf("Warning: you configured more ESDHC controller" "(%d) as supported by the board(2)\n", CONFIG_SYS_FSL_ESDHC_NUM); - return status; + return -EINVAL; } status |= fsl_esdhc_initialize(bis, &esdhc_cfg[index]); }
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx53evk/mx53evk.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/freescale/mx53evk/mx53evk.c b/board/freescale/mx53evk/mx53evk.c index 727ad65..6e9f62c 100644 --- a/board/freescale/mx53evk/mx53evk.c +++ b/board/freescale/mx53evk/mx53evk.c @@ -230,7 +230,7 @@ int board_mmc_init(bd_t *bis) printf("Warning: you configured more ESDHC controller" "(%d) as supported by the board(2)\n", CONFIG_SYS_FSL_ESDHC_NUM); - return status; + return -EINVAL; } status |= fsl_esdhc_initialize(bis, &esdhc_cfg[index]); }
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx53smd/mx53smd.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/freescale/mx53smd/mx53smd.c b/board/freescale/mx53smd/mx53smd.c index d04f44f..a6a6bbe 100644 --- a/board/freescale/mx53smd/mx53smd.c +++ b/board/freescale/mx53smd/mx53smd.c @@ -137,7 +137,7 @@ int board_mmc_init(bd_t *bis) printf("Warning: you configured more ESDHC controller" "(%d) as supported by the board(1)\n", CONFIG_SYS_FSL_ESDHC_NUM); - return status; + return -EINVAL; } status |= fsl_esdhc_initialize(bis, &esdhc_cfg[index]); }
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx6qarm2/mx6qarm2.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/freescale/mx6qarm2/mx6qarm2.c b/board/freescale/mx6qarm2/mx6qarm2.c index e336746..e3e0b76 100644 --- a/board/freescale/mx6qarm2/mx6qarm2.c +++ b/board/freescale/mx6qarm2/mx6qarm2.c @@ -156,7 +156,7 @@ int board_mmc_init(bd_t *bis) printf("Warning: you configured more USDHC controllers" "(%d) then supported by the board (%d)\n", index + 1, CONFIG_SYS_FSL_USDHC_NUM); - return status; + return -EINVAL; }
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx6qsabrelite/mx6qsabrelite.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/freescale/mx6qsabrelite/mx6qsabrelite.c b/board/freescale/mx6qsabrelite/mx6qsabrelite.c index 8ce054e..8a2e4b3 100644 --- a/board/freescale/mx6qsabrelite/mx6qsabrelite.c +++ b/board/freescale/mx6qsabrelite/mx6qsabrelite.c @@ -287,7 +287,7 @@ int board_mmc_init(bd_t *bis) printf("Warning: you configured more USDHC controllers" "(%d) then supported by the board (%d)\n", index + 1, CONFIG_SYS_FSL_USDHC_NUM); - return status; + return -EINVAL; }
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx6qsabresd/mx6qsabresd.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/freescale/mx6qsabresd/mx6qsabresd.c b/board/freescale/mx6qsabresd/mx6qsabresd.c index 2529826..094382b 100644 --- a/board/freescale/mx6qsabresd/mx6qsabresd.c +++ b/board/freescale/mx6qsabresd/mx6qsabresd.c @@ -198,7 +198,7 @@ int board_mmc_init(bd_t *bis) printf("Warning: you configured more USDHC controllers" "(%d) then supported by the board (%d)\n", i + 1, CONFIG_SYS_FSL_USDHC_NUM); - return status; + return -EINVAL; }
status |= fsl_esdhc_initialize(bis, &usdhc_cfg[i]);
On Tue, May 21, 2013 at 2:32 PM, Fabio Estevam fabio.estevam@freescale.comwrote:
When I looked at this code I didn't change it because it raises a warning. So it returns the status if any failed.
On Tue, May 21, 2013 at 3:26 PM, Otavio Salvador otavio@ossystems.com.br wrote:
Which warning are you talking about? Build warning or run-time warning?
I did not see any of these here.
status is zero at that point of code, so we should not 'return 0' on failure.
warning.
In the loop; it does:
status |= fsl...
so it gets the output of it. In case any fails it won't be 0.
On Tue, May 21, 2013 at 3:44 PM, Otavio Salvador otavio@ossystems.com.br wrote:
status |= fsl...
It's good practice to return immediately when an error condition happens.
status |= fsl...
Well the idea of the code was to return in case anything goes wrong. So it outputs a 'WARN'. If you wish to change this, please change to ERROR.
Dear Fabio Estevam,
In message 1369157542-25734-1-git-send-email-fabio.estevam@freescale.com you wrote:
Can we _please_ remove all this code? A _runtime_ check for a _build_ _time_ _detectable_ situation makes no sense to me.
For such a misconfiguration, the build should fail.
Handling this at runtime is the wrong approach.
This comment applies for the whole series.
Actually - are you not surprised that you have to fix the same issue for all boards? This is a clear indication of duplicated code that needs to be factored out.
Hi Wolfgang,
For the wandboard file, would the code bellow be better?
for (index = 0; index < CONFIG_SYS_FSL_USDHC_NUM; ++index) { switch (index) { case 0: imx_iomux_v3_setup_multiple_pads( usdhc3_pads, ARRAY_SIZE(usdhc3_pads)); usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); usdhc_cfg[0].max_bus_width = 4; gpio_direction_input(USDHC3_CD_GPIO); break; case 1: imx_iomux_v3_setup_multiple_pads( usdhc1_pads, ARRAY_SIZE(usdhc1_pads)); usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); usdhc_cfg[1].max_bus_width = 4; gpio_direction_input(USDHC1_CD_GPIO); break; }
status = fsl_esdhc_initialize(bis, &usdhc_cfg[index]); if (status) return status; }
I will try factor out.
Regards,
Fabio Estevam
Fabio Estevam
Fabio Estevam
Otavio Salvador
