[U-Boot-Users] Re: board.c patch got undone
Perhaps this is an even better patch:
=================================================================== RCS file: /cvsroot/u-boot/u-boot/README,v retrieving revision 1.79 diff -p -u -r1.79 README --- README 14 Mar 2004 14:09:05 -0000 1.79 +++ README 16 Mar 2004 04:12:44 -0000 @@ -441,8 +441,8 @@ The following options need to be configu (RTS/CTS) and UART's built-in FIFO. Set the number of bytes the interrupt driven input buffer should have.
- Set to 0 to disable this feature (this is the default). - This will also disable hardware handshake. + Leave undefined to disable this feature, including + disable the buffer and hardware handshake.
- Console UART Number: CONFIG_UART1_CONSOLE
Stephen Williams wrote:
It looks like in the last wave of changes, a patch got undone:
wing % cvs diff -r1.35 board.c Index: board.c =================================================================== RCS file: /cvsroot/u-boot/u-boot/lib_ppc/board.c,v retrieving revision 1.35 retrieving revision 1.36 diff -r1.35 -r1.36 877c877
< #if CONFIG_SERIAL_SOFTWARE_FIFO
#ifdef CONFIG_SERIAL_SOFTWARE_FIFO
The "#if CONFIG_SERIAL_SOFTWARE_FIFO" is the right version, if one assumes the documentation is correct that setting CONFIG_SERIAL_SOFTWARE_FIFO=0 causes the serial port to become insensitive to CTS.
Perhaps it would be even better to change it to:
#if defined(CONFIG_SERIAL_SOFTWARE_FIFO) && CONFIG_SOFTWARE_FIFO>0 ... #endif
Thanks, added.
Stephen Williams
