[PATCH v9 0/5] Add RZ/G2[HMN] board support
This patch series adds the required SoC/Board support to boot HopeRun HiHope RZ/G2[HMN] boards. Board identification support for supporting multidtb is derived from TF-A blob.
V8-->v9 * Use tf-a blob for identifying board type.
Biju Das (5): arm: dts: rmobile: r8a774b1: Synchronize DTs with Linux 5.11 arm: dts: rmobile: r8a774e1: Synchronize DTs with Linux 5.11 arm: rmobile: Add HopeRun HiHope RZ/G2M board support arm: rmobile: Add HopeRun HiHope RZ/G2N board support arm: rmobile: Add HopeRun HiHope RZ/G2H board support
arch/arm/dts/Makefile | 3 + arch/arm/dts/r8a774b1-hihope-rzg2n-ex.dts | 21 ++++ arch/arm/dts/r8a774b1-hihope-rzg2n-u-boot.dts | 27 +++++ arch/arm/dts/r8a774b1-hihope-rzg2n.dts | 41 +++++++ arch/arm/dts/r8a774b1-u-boot.dtsi | 53 ++++++++ arch/arm/dts/r8a774e1-hihope-rzg2h-ex.dts | 20 ++++ arch/arm/dts/r8a774e1-hihope-rzg2h-u-boot.dts | 27 +++++ arch/arm/dts/r8a774e1-hihope-rzg2h.dts | 41 +++++++ arch/arm/dts/r8a774e1-u-boot.dtsi | 59 +++++++++ arch/arm/mach-rmobile/Kconfig.64 | 16 +++ board/hoperun/hihope-rzg2/Kconfig | 15 +++ board/hoperun/hihope-rzg2/MAINTAINERS | 6 + board/hoperun/hihope-rzg2/Makefile | 9 ++ board/hoperun/hihope-rzg2/hihope-rzg2.c | 113 ++++++++++++++++++ configs/hihope_rzg2_defconfig | 82 +++++++++++++ include/configs/hihope-rzg2.h | 20 ++++ 16 files changed, 553 insertions(+) create mode 100644 arch/arm/dts/r8a774b1-hihope-rzg2n-ex.dts create mode 100644 arch/arm/dts/r8a774b1-hihope-rzg2n-u-boot.dts create mode 100644 arch/arm/dts/r8a774b1-hihope-rzg2n.dts create mode 100644 arch/arm/dts/r8a774b1-u-boot.dtsi create mode 100644 arch/arm/dts/r8a774e1-hihope-rzg2h-ex.dts create mode 100644 arch/arm/dts/r8a774e1-hihope-rzg2h-u-boot.dts create mode 100644 arch/arm/dts/r8a774e1-hihope-rzg2h.dts create mode 100644 arch/arm/dts/r8a774e1-u-boot.dtsi create mode 100644 board/hoperun/hihope-rzg2/Kconfig create mode 100644 board/hoperun/hihope-rzg2/MAINTAINERS create mode 100644 board/hoperun/hihope-rzg2/Makefile create mode 100644 board/hoperun/hihope-rzg2/hihope-rzg2.c create mode 100644 configs/hihope_rzg2_defconfig create mode 100644 include/configs/hihope-rzg2.h
Synchronize r8a774b1 device trees with Linux 5.11, commit f40ddce88593482919 ("Linux 5.11")
Signed-off-by: Biju Das biju.das.jz@bp.renesas.com --- * New patch --- arch/arm/dts/r8a774b1-hihope-rzg2n-ex.dts | 21 ++++++++++++ arch/arm/dts/r8a774b1-hihope-rzg2n.dts | 41 +++++++++++++++++++++++ 2 files changed, 62 insertions(+) create mode 100644 arch/arm/dts/r8a774b1-hihope-rzg2n-ex.dts create mode 100644 arch/arm/dts/r8a774b1-hihope-rzg2n.dts
diff --git a/arch/arm/dts/r8a774b1-hihope-rzg2n-ex.dts b/arch/arm/dts/r8a774b1-hihope-rzg2n-ex.dts new file mode 100644 index 0000000000..60d7c8adea --- /dev/null +++ b/arch/arm/dts/r8a774b1-hihope-rzg2n-ex.dts @@ -0,0 +1,21 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for the HiHope RZ/G2N Rev.3.0/4.0 connected to + * sub board + * + * Copyright (C) 2020 Renesas Electronics Corp. + */ + +#include "r8a774b1-hihope-rzg2n.dts" +#include "hihope-rzg2-ex.dtsi" + +/ { + model = "HopeRun HiHope RZ/G2N with sub board"; + compatible = "hoperun,hihope-rzg2-ex", "hoperun,hihope-rzg2n", + "renesas,r8a774b1"; +}; + +/* Set SW43 = ON and SW1001[7] = OFF for SATA port to be activated */ +&sata { + status = "okay"; +}; diff --git a/arch/arm/dts/r8a774b1-hihope-rzg2n.dts b/arch/arm/dts/r8a774b1-hihope-rzg2n.dts new file mode 100644 index 0000000000..f1883cbd1a --- /dev/null +++ b/arch/arm/dts/r8a774b1-hihope-rzg2n.dts @@ -0,0 +1,41 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for the HiHope RZ/G2N main board Rev.3.0/4.0 + * + * Copyright (C) 2020 Renesas Electronics Corp. + */ + +/dts-v1/; +#include "r8a774b1.dtsi" +#include "hihope-rev4.dtsi" + +/ { + model = "HopeRun HiHope RZ/G2N main board based on r8a774b1"; + compatible = "hoperun,hihope-rzg2n", "renesas,r8a774b1"; + + memory@48000000 { + device_type = "memory"; + /* first 128MB is reserved for secure area. */ + reg = <0x0 0x48000000 0x0 0x78000000>; + }; + + memory@480000000 { + device_type = "memory"; + reg = <0x4 0x80000000 0x0 0x80000000>; + }; +}; + +&du { + clocks = <&cpg CPG_MOD 724>, + <&cpg CPG_MOD 723>, + <&cpg CPG_MOD 721>, + <&versaclock5 1>, + <&x302_clk>, + <&versaclock5 2>; + clock-names = "du.0", "du.1", "du.3", + "dclkin.0", "dclkin.1", "dclkin.3"; +}; + +&sdhi3 { + mmc-hs400-1_8v; +};
Synchronize r8a774e1 device trees with Linux 5.11, commit f40ddce88593482919 ("Linux 5.11").
Signed-off-by: Biju Das biju.das.jz@bp.renesas.com --- * New patch --- arch/arm/dts/r8a774e1-hihope-rzg2h-ex.dts | 20 +++++++++++ arch/arm/dts/r8a774e1-hihope-rzg2h.dts | 41 +++++++++++++++++++++++ 2 files changed, 61 insertions(+) create mode 100644 arch/arm/dts/r8a774e1-hihope-rzg2h-ex.dts create mode 100644 arch/arm/dts/r8a774e1-hihope-rzg2h.dts
diff --git a/arch/arm/dts/r8a774e1-hihope-rzg2h-ex.dts b/arch/arm/dts/r8a774e1-hihope-rzg2h-ex.dts new file mode 100644 index 0000000000..8129959398 --- /dev/null +++ b/arch/arm/dts/r8a774e1-hihope-rzg2h-ex.dts @@ -0,0 +1,20 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for the HiHope RZ/G2H sub board + * + * Copyright (C) 2020 Renesas Electronics Corp. + */ + +#include "r8a774e1-hihope-rzg2h.dts" +#include "hihope-rzg2-ex.dtsi" + +/ { + model = "HopeRun HiHope RZ/G2H with sub board"; + compatible = "hoperun,hihope-rzg2-ex", "hoperun,hihope-rzg2h", + "renesas,r8a774e1"; +}; + +/* Set SW43 = ON and SW1001[7] = OFF for SATA port to be activated */ +&sata { + status = "okay"; +}; diff --git a/arch/arm/dts/r8a774e1-hihope-rzg2h.dts b/arch/arm/dts/r8a774e1-hihope-rzg2h.dts new file mode 100644 index 0000000000..9525d5ed6f --- /dev/null +++ b/arch/arm/dts/r8a774e1-hihope-rzg2h.dts @@ -0,0 +1,41 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for the HiHope RZ/G2H main board + * + * Copyright (C) 2020 Renesas Electronics Corp. + */ + +/dts-v1/; +#include "r8a774e1.dtsi" +#include "hihope-rev4.dtsi" + +/ { + model = "HopeRun HiHope RZ/G2H main board based on r8a774e1"; + compatible = "hoperun,hihope-rzg2h", "renesas,r8a774e1"; + + memory@48000000 { + device_type = "memory"; + /* first 128MB is reserved for secure area. */ + reg = <0x0 0x48000000 0x0 0x78000000>; + }; + + memory@500000000 { + device_type = "memory"; + reg = <0x5 0x00000000 0x0 0x80000000>; + }; +}; + +&du { + clocks = <&cpg CPG_MOD 724>, + <&cpg CPG_MOD 723>, + <&cpg CPG_MOD 721>, + <&versaclock5 1>, + <&x302_clk>, + <&versaclock5 2>; + clock-names = "du.0", "du.1", "du.3", + "dclkin.0", "dclkin.1", "dclkin.3"; +}; + +&sdhi3 { + mmc-hs400-1_8v; +};
The HiHope RZ/G2M board from HopeRun consists of main board (HopeRun HiHope RZ/G2M main board) and sub board(HopeRun HiHope RZ/G2M sub board). The HiHope RZ/G2M sub board sits below the HiHope RZ/G2M main board.
This patch adds the required board support to boot HopeRun HiHope RZ/G2M board.
Signed-off-by: Biju Das biju.das.jz@bp.renesas.com Reviewed-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com --- v8->v9 * Board idenitty for multidtb is derived from TF-A blob. v7->v8 * Seperated DT patches V6->V7 * Seperated driver patches from board support patches.
v5->v6 * Rebased to U-boot-sh/master * Changed the logic for USB0 channel0 Host support. * Enabled CONFIG_SOC_DEVICE_RENESAS option
V4->V5 * Rebased to U-boot-sh/next
V3->V4 * Added USB0 channel0 Host support
V2->V3 * Reworked as per Marek's suggestion * Added rzg2_get_cpu_type function to get cpu_type by matching TFA compatible string * Removed SoC family type Enum
V1->V2 * Fixed indentation for R8A774A1 config * Used GPIO hog for setting WLAN/BT REG ON * Removed USB related initialization
V1:- * New Patch
--- arch/arm/dts/Makefile | 1 + arch/arm/mach-rmobile/Kconfig.64 | 14 ++++ board/hoperun/hihope-rzg2/Kconfig | 15 ++++ board/hoperun/hihope-rzg2/MAINTAINERS | 6 ++ board/hoperun/hihope-rzg2/Makefile | 9 ++ board/hoperun/hihope-rzg2/hihope-rzg2.c | 105 ++++++++++++++++++++++++ configs/hihope_rzg2_defconfig | 82 ++++++++++++++++++ include/configs/hihope-rzg2.h | 20 +++++ 8 files changed, 252 insertions(+) create mode 100644 board/hoperun/hihope-rzg2/Kconfig create mode 100644 board/hoperun/hihope-rzg2/MAINTAINERS create mode 100644 board/hoperun/hihope-rzg2/Makefile create mode 100644 board/hoperun/hihope-rzg2/hihope-rzg2.c create mode 100644 configs/hihope_rzg2_defconfig create mode 100644 include/configs/hihope-rzg2.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 33e483f4fb..26633fad57 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -811,6 +811,7 @@ dtb-$(CONFIG_RCAR_GEN3) += \ r8a774a1-beacon-rzg2m-kit.dtb \ r8a774b1-beacon-rzg2n-kit.dtb \ r8a774e1-beacon-rzg2h-kit.dtb \ + r8a774a1-hihope-rzg2m-u-boot.dtb \ r8a77950-ulcb-u-boot.dtb \ r8a77950-salvator-x-u-boot.dtb \ r8a77960-ulcb-u-boot.dtb \ diff --git a/arch/arm/mach-rmobile/Kconfig.64 b/arch/arm/mach-rmobile/Kconfig.64 index b95c8e8d29..2c2c60385d 100644 --- a/arch/arm/mach-rmobile/Kconfig.64 +++ b/arch/arm/mach-rmobile/Kconfig.64 @@ -4,6 +4,8 @@ menu "Select Target SoC"
config R8A774A1 bool "Renesas SoC R8A774A1" + imply CLK_R8A774A1 + imply PINCTRL_PFC_R8A774A1
config R8A774B1 bool "Renesas SoC R8A774B1" @@ -99,6 +101,15 @@ config TARGET_EBISU help Support for Renesas R-Car Gen3 Ebisu platform
+config TARGET_HIHOPE_RZG2 + bool "HiHope RZ/G2 board" + imply R8A774A1 + imply SYS_MALLOC_F + imply MULTI_DTB_FIT + imply MULTI_DTB_FIT_USER_DEFINED_AREA + help + Support for RZG2 HiHope platform + config TARGET_SALVATOR_X bool "Salvator-X board" imply R8A7795 @@ -133,12 +144,15 @@ source "board/renesas/ebisu/Kconfig" source "board/renesas/salvator-x/Kconfig" source "board/renesas/ulcb/Kconfig" source "board/beacon/beacon-rzg2m/Kconfig" +source "board/hoperun/hihope-rzg2/Kconfig"
config MULTI_DTB_FIT_UNCOMPRESS_SZ + default 0x80000 if TARGET_HIHOPE_RZG2 default 0x80000 if TARGET_SALVATOR_X default 0x80000 if TARGET_ULCB
config MULTI_DTB_FIT_USER_DEF_ADDR + default 0x49000000 if TARGET_HIHOPE_RZG2 default 0x49000000 if TARGET_SALVATOR_X default 0x49000000 if TARGET_ULCB
diff --git a/board/hoperun/hihope-rzg2/Kconfig b/board/hoperun/hihope-rzg2/Kconfig new file mode 100644 index 0000000000..ee422ba6c8 --- /dev/null +++ b/board/hoperun/hihope-rzg2/Kconfig @@ -0,0 +1,15 @@ +if TARGET_HIHOPE_RZG2 + +config SYS_SOC + default "rmobile" + +config SYS_BOARD + default "hihope-rzg2" + +config SYS_VENDOR + default "hoperun" + +config SYS_CONFIG_NAME + default "hihope-rzg2" + +endif diff --git a/board/hoperun/hihope-rzg2/MAINTAINERS b/board/hoperun/hihope-rzg2/MAINTAINERS new file mode 100644 index 0000000000..e3702fd12e --- /dev/null +++ b/board/hoperun/hihope-rzg2/MAINTAINERS @@ -0,0 +1,6 @@ +HIHOPE_RZG2 BOARD +M: Biju Das biju.das.jz@bp.renesas.com +S: Maintained +F: board/hoperun/hihope-rzg2/ +F: include/configs/hihope-rzg2.h +F: configs/hihope_rzg2_defconfig diff --git a/board/hoperun/hihope-rzg2/Makefile b/board/hoperun/hihope-rzg2/Makefile new file mode 100644 index 0000000000..e989e7aacc --- /dev/null +++ b/board/hoperun/hihope-rzg2/Makefile @@ -0,0 +1,9 @@ +# +# board/hoperun/hihope-rzg2/Makefile +# +# Copyright (C) 2021 Renesas Electronics Corporation +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := hihope-rzg2.o ../../renesas/rcar-common/common.o diff --git a/board/hoperun/hihope-rzg2/hihope-rzg2.c b/board/hoperun/hihope-rzg2/hihope-rzg2.c new file mode 100644 index 0000000000..a60529f780 --- /dev/null +++ b/board/hoperun/hihope-rzg2/hihope-rzg2.c @@ -0,0 +1,105 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * board/hoperun/hihope-rzg2/hihope-rzg2.c + * This file is HiHope RZ/G2M board support. + * + * Copyright (C) 2021 Renesas Electronics Corporation + */ + +#include <common.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm/processor.h> +#include <asm/arch/rmobile.h> +#include <asm/arch/rcar-mstp.h> +#include <linux/bitops.h> +#include <linux/delay.h> +#include <linux/libfdt.h> + +#define RST_BASE 0xE6160000 +#define RST_CA57RESCNT (RST_BASE + 0x40) +#define RST_CA53RESCNT (RST_BASE + 0x44) +#define RST_CA57_CODE 0xA5A5000F +#define RST_CA53_CODE 0x5A5A000F + +DECLARE_GLOBAL_DATA_PTR; +#define HSUSB_MSTP704 BIT(4) /* HSUSB */ + +/* HSUSB block registers */ +#define HSUSB_REG_LPSTS 0xE6590102 +#define HSUSB_REG_LPSTS_SUSPM_NORMAL BIT(14) +#define HSUSB_REG_UGCTRL2 0xE6590184 +#define HSUSB_REG_UGCTRL2_USB0SEL_EHCI 0x10 +#define HSUSB_REG_UGCTRL2_RESERVED_3 0x1 /* bit[3:0] should be B'0001 */ + +#define PRR_REGISTER (0xFFF00044) + +int board_init(void) +{ + u32 i; + + /* address of boot parameters */ + gd->bd->bi_boot_params = CONFIG_SYS_TEXT_BASE + 0x50000; + + /* Configure the HSUSB block */ + mstp_clrbits_le32(SMSTPCR7, SMSTPCR7, HSUSB_MSTP704); + /* + * We need to add a barrier instruction after HSUSB module stop release. + * This barrier instruction can be either reading back the same MSTP + * register or any other register in the same IP block. So like linux + * adding check for MSTPSR register, which indicates the clock has been + * started. + */ + for (i = 1000; i > 0; --i) { + if (!(readl(MSTPSR7) & HSUSB_MSTP704)) + break; + cpu_relax(); + } + + /* Select EHCI/OHCI host module for USB2.0 ch0 */ + writel(HSUSB_REG_UGCTRL2_USB0SEL_EHCI | HSUSB_REG_UGCTRL2_RESERVED_3, + HSUSB_REG_UGCTRL2); + /* low power status */ + setbits_le16(HSUSB_REG_LPSTS, HSUSB_REG_LPSTS_SUSPM_NORMAL); + + return 0; +} + +void reset_cpu(ulong addr) +{ + unsigned long midr, cputype; + + asm volatile("mrs %0, midr_el1" : "=r" (midr)); + cputype = (midr >> 4) & 0xfff; + + if (cputype == 0xd03) + writel(RST_CA53_CODE, RST_CA53RESCNT); + else + writel(RST_CA57_CODE, RST_CA57RESCNT); +} + +#if defined(CONFIG_MULTI_DTB_FIT) +/* If the firmware passed a device tree, use it for board identification. */ +extern u64 rcar_atf_boot_args[]; + +static bool is_hoperun_hihope_rzg2_board(const char *board_name) +{ + void *atf_fdt_blob = (void *)(rcar_atf_boot_args[1]); + bool ret = false; + + if ((fdt_magic(atf_fdt_blob) == FDT_MAGIC) && + (fdt_node_check_compatible(atf_fdt_blob, 0, board_name) == 0)) + ret = true; + + return ret; +} + +int board_fit_config_name_match(const char *name) +{ + if (is_hoperun_hihope_rzg2_board("hoperun,hihope-rzg2m") && + !strcmp(name, "r8a774a1-hihope-rzg2m-u-boot")) + return 0; + + return -1; +} +#endif diff --git a/configs/hihope_rzg2_defconfig b/configs/hihope_rzg2_defconfig new file mode 100644 index 0000000000..bc40445b5e --- /dev/null +++ b/configs/hihope_rzg2_defconfig @@ -0,0 +1,82 @@ +CONFIG_ARM=y +CONFIG_ARCH_CPU_INIT=y +CONFIG_ARCH_RMOBILE=y +CONFIG_SYS_TEXT_BASE=0x50000000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xFFFE0000 +CONFIG_DM_GPIO=y +CONFIG_RCAR_GEN3=y +CONFIG_TARGET_HIHOPE_RZG2=y +# CONFIG_SPL is not set +CONFIG_DEFAULT_DEVICE_TREE="r8a774a1-hihope-rzg2m-u-boot" +CONFIG_FIT=y +CONFIG_SUPPORT_RAW_INITRD=y +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" +CONFIG_DEFAULT_FDT_FILE="r8a774a1-hihope-rzg2m.dtb" +# CONFIG_BOARD_EARLY_INIT_F is not set +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_OF_CONTROL=y +CONFIG_OF_LIST="r8a774a1-hihope-rzg2m-u-boot" +CONFIG_MULTI_DTB_FIT_LZO=y +CONFIG_MULTI_DTB_FIT_USER_DEFINED_AREA=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=1 +CONFIG_SYS_MMC_ENV_PART=2 +CONFIG_VERSION_VARIABLE=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y +CONFIG_CLK=y +CONFIG_CLK_RENESAS=y +CONFIG_GPIO_HOG=y +CONFIG_RCAR_GPIO=y +CONFIG_DM_PCA953X=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_RCAR_I2C=y +CONFIG_SYS_I2C_RCAR_IIC=y +CONFIG_DM_MMC=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_RENESAS_SDHI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_USE_4K_SECTORS=y +CONFIG_BITBANGMII=y +CONFIG_PHY_REALTEK=y +CONFIG_DM_ETH=y +CONFIG_RENESAS_RAVB=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_SCIF_CONSOLE=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_RENESAS_RPC_SPI=y +CONFIG_TEE=y +CONFIG_OPTEE=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_STORAGE=y +CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/include/configs/hihope-rzg2.h b/include/configs/hihope-rzg2.h new file mode 100644 index 0000000000..68a51176e3 --- /dev/null +++ b/include/configs/hihope-rzg2.h @@ -0,0 +1,20 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * include/configs/hihope-rzg2.h + * This file is HOPERUN HiHope RZ/G2 board configuration. + * + * Copyright (C) 2020 Renesas Electronics Corporation + */ + +#ifndef __HIHOPE_RZG2_H +#define __HIHOPE_RZG2_H + +#include "rcar-gen3-common.h" + +/* Ethernet RAVB */ +#define CONFIG_BITBANGMII_MULTI + +/* Generic Timer Definitions (use in assembler source) */ +#define COUNTER_FREQUENCY 0xFE502A /* 16.66MHz from CPclk */ + +#endif /* __HIHOPE_RZG2_H */
The HiHope RZ/G2N board from HopeRun consists of main board (HopeRun HiHope RZ/G2N main board) and sub board(HopeRun HiHope RZ/G2N sub board). The HiHope RZ/G2N sub board sits below the HiHope RZ/G2N main board.
This patch adds the required board support to boot HopeRun HiHope RZ/G2N board.
Signed-off-by: Biju Das biju.das.jz@bp.renesas.com Reviewed-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com --- v4-v9: * Board identity for multidtb support derived from TF-A blob. v3: * Seperated DT patches v1->v2: * No Change. rebased on u-boot-sh/next v1: * New patch --- arch/arm/dts/Makefile | 1 + arch/arm/dts/r8a774b1-hihope-rzg2n-u-boot.dts | 27 ++++++++++ arch/arm/dts/r8a774b1-u-boot.dtsi | 53 +++++++++++++++++++ arch/arm/mach-rmobile/Kconfig.64 | 1 + board/hoperun/hihope-rzg2/hihope-rzg2.c | 6 ++- configs/hihope_rzg2_defconfig | 2 +- 6 files changed, 88 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/r8a774b1-hihope-rzg2n-u-boot.dts create mode 100644 arch/arm/dts/r8a774b1-u-boot.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 26633fad57..2e16adcc76 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -812,6 +812,7 @@ dtb-$(CONFIG_RCAR_GEN3) += \ r8a774b1-beacon-rzg2n-kit.dtb \ r8a774e1-beacon-rzg2h-kit.dtb \ r8a774a1-hihope-rzg2m-u-boot.dtb \ + r8a774b1-hihope-rzg2n-u-boot.dtb \ r8a77950-ulcb-u-boot.dtb \ r8a77950-salvator-x-u-boot.dtb \ r8a77960-ulcb-u-boot.dtb \ diff --git a/arch/arm/dts/r8a774b1-hihope-rzg2n-u-boot.dts b/arch/arm/dts/r8a774b1-hihope-rzg2n-u-boot.dts new file mode 100644 index 0000000000..0bdc6909bf --- /dev/null +++ b/arch/arm/dts/r8a774b1-hihope-rzg2n-u-boot.dts @@ -0,0 +1,27 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source extras for U-Boot for the Hihope RZ/G2N board + * + * Copyright (C) 2021 Renesas Electronics Corp. + */ + +#include "r8a774b1-hihope-rzg2n-ex.dts" +#include "r8a774b1-u-boot.dtsi" + +&gpio3 { + bt_reg_on{ + gpio-hog; + gpios = <13 GPIO_ACTIVE_HIGH>; + output-low; + line-name = "bt-reg-on"; + }; +}; + +&gpio4 { + wlan_reg_on{ + gpio-hog; + gpios = <6 GPIO_ACTIVE_HIGH>; + output-low; + line-name = "wlan-reg-on"; + }; +}; diff --git a/arch/arm/dts/r8a774b1-u-boot.dtsi b/arch/arm/dts/r8a774b1-u-boot.dtsi new file mode 100644 index 0000000000..6fab78e776 --- /dev/null +++ b/arch/arm/dts/r8a774b1-u-boot.dtsi @@ -0,0 +1,53 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source extras for U-Boot on RZ/G2 R8A774B1 SoC + * + * Copyright (C) 2021 Renesas Electronics Corp. + */ + +#include "r8a779x-u-boot.dtsi" + +&extalr_clk { + u-boot,dm-pre-reloc; +}; + +/delete-node/ &audma0; +/delete-node/ &audma1; +/delete-node/ &can0; +/delete-node/ &can1; +/delete-node/ &canfd; +/delete-node/ &csi20; +/delete-node/ &csi40; +/delete-node/ &du; +/delete-node/ &fcpf0; +/delete-node/ &fcpvb0; +/delete-node/ &fcpvd0; +/delete-node/ &fcpvd1; +/delete-node/ &fcpvi0; +/delete-node/ &hdmi0; +/delete-node/ &lvds0; +/delete-node/ &rcar_sound; +/delete-node/ &sdhi2; +/delete-node/ &sound_card; +/delete-node/ &vin0; +/delete-node/ &vin1; +/delete-node/ &vin2; +/delete-node/ &vin3; +/delete-node/ &vin4; +/delete-node/ &vin5; +/delete-node/ &vin6; +/delete-node/ &vin7; +/delete-node/ &vspb; +/delete-node/ &vspd0; +/delete-node/ &vspd1; +/delete-node/ &vspi0; + +/ { + /delete-node/ hdmi0-out; +}; + +/ { + soc { + /delete-node/ fdp1@fe940000; + }; +}; diff --git a/arch/arm/mach-rmobile/Kconfig.64 b/arch/arm/mach-rmobile/Kconfig.64 index 2c2c60385d..03b99864ee 100644 --- a/arch/arm/mach-rmobile/Kconfig.64 +++ b/arch/arm/mach-rmobile/Kconfig.64 @@ -104,6 +104,7 @@ config TARGET_EBISU config TARGET_HIHOPE_RZG2 bool "HiHope RZ/G2 board" imply R8A774A1 + imply R8A774B1 imply SYS_MALLOC_F imply MULTI_DTB_FIT imply MULTI_DTB_FIT_USER_DEFINED_AREA diff --git a/board/hoperun/hihope-rzg2/hihope-rzg2.c b/board/hoperun/hihope-rzg2/hihope-rzg2.c index a60529f780..2a61268c69 100644 --- a/board/hoperun/hihope-rzg2/hihope-rzg2.c +++ b/board/hoperun/hihope-rzg2/hihope-rzg2.c @@ -1,7 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * board/hoperun/hihope-rzg2/hihope-rzg2.c - * This file is HiHope RZ/G2M board support. + * This file is HiHope RZ/G2[MN] board support. * * Copyright (C) 2021 Renesas Electronics Corporation */ @@ -100,6 +100,10 @@ int board_fit_config_name_match(const char *name) !strcmp(name, "r8a774a1-hihope-rzg2m-u-boot")) return 0;
+ if (is_hoperun_hihope_rzg2_board("hoperun,hihope-rzg2n") && + !strcmp(name, "r8a774b1-hihope-rzg2n-u-boot")) + return 0; + return -1; } #endif diff --git a/configs/hihope_rzg2_defconfig b/configs/hihope_rzg2_defconfig index bc40445b5e..73245d9cfc 100644 --- a/configs/hihope_rzg2_defconfig +++ b/configs/hihope_rzg2_defconfig @@ -32,7 +32,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y -CONFIG_OF_LIST="r8a774a1-hihope-rzg2m-u-boot" +CONFIG_OF_LIST="r8a774a1-hihope-rzg2m-u-boot r8a774b1-hihope-rzg2n-u-boot" CONFIG_MULTI_DTB_FIT_LZO=y CONFIG_MULTI_DTB_FIT_USER_DEFINED_AREA=y CONFIG_ENV_OVERWRITE=y
The HiHope RZ/G2H board from HopeRun consists of main board (HopeRun HiHope RZ/G2H main board) and sub board(HopeRun HiHope RZ/G2H sub board). The HiHope RZ/G2H sub board sits below the HiHope RZ/G2H main board.
This patch adds the required board support to boot HopeRun HiHope RZ/G2H board.
Signed-off-by: Biju Das biju.das.jz@bp.renesas.com Reviewed-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com --- v4-v9: * Board identity for multidtb support derived from TF-A blob. v3: * Seperated DT patches v1->v2: * No Change. rebased on u-boot-sh/next v1: * New patch --- arch/arm/dts/Makefile | 1 + arch/arm/dts/r8a774e1-hihope-rzg2h-u-boot.dts | 27 +++++++++ arch/arm/dts/r8a774e1-u-boot.dtsi | 59 +++++++++++++++++++ arch/arm/mach-rmobile/Kconfig.64 | 1 + board/hoperun/hihope-rzg2/hihope-rzg2.c | 6 +- configs/hihope_rzg2_defconfig | 2 +- 6 files changed, 94 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/r8a774e1-hihope-rzg2h-u-boot.dts create mode 100644 arch/arm/dts/r8a774e1-u-boot.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 2e16adcc76..6cdd4a9c48 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -813,6 +813,7 @@ dtb-$(CONFIG_RCAR_GEN3) += \ r8a774e1-beacon-rzg2h-kit.dtb \ r8a774a1-hihope-rzg2m-u-boot.dtb \ r8a774b1-hihope-rzg2n-u-boot.dtb \ + r8a774e1-hihope-rzg2h-u-boot.dtb \ r8a77950-ulcb-u-boot.dtb \ r8a77950-salvator-x-u-boot.dtb \ r8a77960-ulcb-u-boot.dtb \ diff --git a/arch/arm/dts/r8a774e1-hihope-rzg2h-u-boot.dts b/arch/arm/dts/r8a774e1-hihope-rzg2h-u-boot.dts new file mode 100644 index 0000000000..03a17bac7e --- /dev/null +++ b/arch/arm/dts/r8a774e1-hihope-rzg2h-u-boot.dts @@ -0,0 +1,27 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source extras for U-Boot for the Hihope RZ/G2H board + * + * Copyright (C) 2020 Renesas Electronics Corp. + */ + +#include "r8a774e1-hihope-rzg2h-ex.dts" +#include "r8a774e1-u-boot.dtsi" + +&gpio3 { + bt_reg_on{ + gpio-hog; + gpios = <13 GPIO_ACTIVE_HIGH>; + output-low; + line-name = "bt-reg-on"; + }; +}; + +&gpio4 { + wlan_reg_on{ + gpio-hog; + gpios = <6 GPIO_ACTIVE_HIGH>; + output-low; + line-name = "wlan-reg-on"; + }; +}; diff --git a/arch/arm/dts/r8a774e1-u-boot.dtsi b/arch/arm/dts/r8a774e1-u-boot.dtsi new file mode 100644 index 0000000000..74758dfedf --- /dev/null +++ b/arch/arm/dts/r8a774e1-u-boot.dtsi @@ -0,0 +1,59 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source extras for U-Boot on RZ/G2 R8A774E1 SoC + * + * Copyright (C) 2020 Renesas Electronics Corp. + */ + +#include "r8a779x-u-boot.dtsi" + +&extalr_clk { + u-boot,dm-pre-reloc; +}; + +/delete-node/ &audma0; +/delete-node/ &audma1; +/delete-node/ &can0; +/delete-node/ &can1; +/delete-node/ &canfd; +/delete-node/ &csi20; +/delete-node/ &csi40; +/delete-node/ &du; +/delete-node/ &fcpf0; +/delete-node/ &fcpf1; +/delete-node/ &fcpvb0; +/delete-node/ &fcpvb1; +/delete-node/ &fcpvd0; +/delete-node/ &fcpvd1; +/delete-node/ &fcpvi0; +/delete-node/ &fcpvi1; +/delete-node/ &hdmi0; +/delete-node/ &lvds0; +/delete-node/ &rcar_sound; +/delete-node/ &sdhi2; +/delete-node/ &sound_card; +/delete-node/ &vin0; +/delete-node/ &vin1; +/delete-node/ &vin2; +/delete-node/ &vin3; +/delete-node/ &vin4; +/delete-node/ &vin5; +/delete-node/ &vin6; +/delete-node/ &vin7; +/delete-node/ &vspbc; +/delete-node/ &vspbd; +/delete-node/ &vspd0; +/delete-node/ &vspd1; +/delete-node/ &vspi0; +/delete-node/ &vspi1; + +/ { + /delete-node/ hdmi0-out; +}; + +/ { + soc { + /delete-node/ fdp1@fe940000; + /delete-node/ fdp1@fe944000; + }; +}; diff --git a/arch/arm/mach-rmobile/Kconfig.64 b/arch/arm/mach-rmobile/Kconfig.64 index 03b99864ee..7eec65d8ea 100644 --- a/arch/arm/mach-rmobile/Kconfig.64 +++ b/arch/arm/mach-rmobile/Kconfig.64 @@ -105,6 +105,7 @@ config TARGET_HIHOPE_RZG2 bool "HiHope RZ/G2 board" imply R8A774A1 imply R8A774B1 + imply R8A774E1 imply SYS_MALLOC_F imply MULTI_DTB_FIT imply MULTI_DTB_FIT_USER_DEFINED_AREA diff --git a/board/hoperun/hihope-rzg2/hihope-rzg2.c b/board/hoperun/hihope-rzg2/hihope-rzg2.c index 2a61268c69..c1bfdcbc1d 100644 --- a/board/hoperun/hihope-rzg2/hihope-rzg2.c +++ b/board/hoperun/hihope-rzg2/hihope-rzg2.c @@ -1,7 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * board/hoperun/hihope-rzg2/hihope-rzg2.c - * This file is HiHope RZ/G2[MN] board support. + * This file is HiHope RZ/G2[HMN] board support. * * Copyright (C) 2021 Renesas Electronics Corporation */ @@ -104,6 +104,10 @@ int board_fit_config_name_match(const char *name) !strcmp(name, "r8a774b1-hihope-rzg2n-u-boot")) return 0;
+ if (is_hoperun_hihope_rzg2_board("hoperun,hihope-rzg2h") && + !strcmp(name, "r8a774e1-hihope-rzg2h-u-boot")) + return 0; + return -1; } #endif diff --git a/configs/hihope_rzg2_defconfig b/configs/hihope_rzg2_defconfig index 73245d9cfc..69eaab073e 100644 --- a/configs/hihope_rzg2_defconfig +++ b/configs/hihope_rzg2_defconfig @@ -32,7 +32,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y -CONFIG_OF_LIST="r8a774a1-hihope-rzg2m-u-boot r8a774b1-hihope-rzg2n-u-boot" +CONFIG_OF_LIST="r8a774a1-hihope-rzg2m-u-boot r8a774b1-hihope-rzg2n-u-boot r8a774e1-hihope-rzg2h-u-boot" CONFIG_MULTI_DTB_FIT_LZO=y CONFIG_MULTI_DTB_FIT_USER_DEFINED_AREA=y CONFIG_ENV_OVERWRITE=y
V8-->v9
- Use tf-a blob for identifying board type.
Applied all, thanks.
Biju Das
