[U-Boot] [PATCH] 8641HPCN: Config file cleanup
There are several items in the config file that were hardcoded but that should really be based on other config options, since the regions are contiguous and depend on being so. This cleans that up a bit. Also, add BR_PHYS_ADDR() macro to convert addresses into the proper format for BR registers.
Signed-off-by: Becky Bruce becky.bruce@freescale.com --- include/configs/MPC8641HPCN.h | 20 +++++++++++++++----- 1 files changed, 15 insertions(+), 5 deletions(-)
diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index 542877b..abf2a58 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -162,21 +162,26 @@ extern unsigned long get_board_sys_clk(unsigned long dummy);
#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE2}
+/* Convert an address into the right format for the BR registers */ +#define BR_PHYS_ADDR(x) (x & 0xffff8000) + #define CONFIG_SYS_BR0_PRELIM 0xff001001 /* port size 16bit */ #define CONFIG_SYS_OR0_PRELIM 0xff006ff7 /* 16MB Boot Flash area*/
#define CONFIG_SYS_BR1_PRELIM 0xfe001001 /* port size 16bit */ #define CONFIG_SYS_OR1_PRELIM 0xff006ff7 /* 16MB Alternate Boot Flash area*/
-#define CONFIG_SYS_BR2_PRELIM 0xf8201001 /* port size 16bit */ +#define CONFIG_SYS_BR2_PRELIM (BR_PHYS_ADDR(CF_BASE) \ + | 0x000001001) /* port size 16bit */ #define CONFIG_SYS_OR2_PRELIM 0xfff06ff7 /* 1MB Compact Flash area*/
-#define CONFIG_SYS_BR3_PRELIM 0xf8100801 /* port size 8bit */ +#define CONFIG_SYS_BR3_PRELIM (BR_PHYS_ADDR(PIXIS_BASE) \ + | 0x00000801) /* port size 8bit */ #define CONFIG_SYS_OR3_PRELIM 0xfff06ff7 /* 1MB PIXIS area*/
#define CONFIG_FSL_PIXIS 1 /* use common PIXIS code */ -#define PIXIS_BASE 0xf8100000 /* PIXIS registers */ +#define PIXIS_BASE (CONFIG_SYS_CCSRBAR + 0x00100000) /* PIXIS registers */ #define PIXIS_ID 0x0 /* Board ID at offset 0 */ #define PIXIS_VER 0x1 /* Board version at offset 1 */ #define PIXIS_PVER 0x2 /* PIXIS FPGA version at offset 2 */ @@ -193,6 +198,9 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define PIXIS_VCLKL 0x1A /* VELA VCLKL register */ #define CONFIG_SYS_PIXIS_VBOOT_MASK 0x40 /* Reset altbank mask*/
+/* Compact flash shares a BAT with PIXIS; make sure they're contiguous */ +#define CF_BASE (PIXIS_BASE + 0x00100000) + #define CONFIG_SYS_MAX_FLASH_BANKS 2 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 128 /* sectors per device */
@@ -298,11 +306,13 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define KSEG1ADDR(x) ({u32 _x=le32_to_cpu(*(u32 *)(x)); (&_x);}) #define _IO_BASE 0x00000000
-#define CONFIG_SYS_PCI2_MEM_BASE 0xa0000000 +#define CONFIG_SYS_PCI2_MEM_BASE (CONFIG_SYS_PCI1_MEM_BASE \ + + CONFIG_SYS_PCI1_MEM_SIZE) #define CONFIG_SYS_PCI2_MEM_PHYS CONFIG_SYS_PCI2_MEM_BASE #define CONFIG_SYS_PCI2_MEM_SIZE 0x20000000 /* 512M */ #define CONFIG_SYS_PCI2_IO_BASE 0x00000000 -#define CONFIG_SYS_PCI2_IO_PHYS 0xe3000000 +#define CONFIG_SYS_PCI2_IO_PHYS (CONFIG_SYS_PCI1_IO_PHYS \ + + CONFIG_SYS_PCI1_IO_SIZE) #define CONFIG_SYS_PCI2_IO_SIZE 0x00100000 /* 1M */
#if defined(CONFIG_PCI)
Applied to u-boot-mpc86xx.
Thanks, jdl
Becky Bruce
Jon Loeliger
