[PATCH] arm: mvebu: a37xx: Add support for writing Security OTP values
Implement write support for Security OTP values via mailbox API commands MBOX_CMD_OTP_WRITE_32B and MBOX_CMD_OTP_WRITE.
Write support for North and South Bridge OTPs are not implemented as these OTPs are already burned in factory with some data.
Signed-off-by: Pali Rohár pali@kernel.org --- This patch depends on series which implements read support for A3720 OTP: https://patchwork.ozlabs.org/project/uboot/list/?series=287578&state=*
Stefan, what do you think, should be enable write support by default. Or should it be hidden under some other CONFIG option? Becaue currently CONFIG_CMD_FUSE enable both read and write support (or what driver implements). --- arch/arm/mach-mvebu/armada3700/efuse.c | 50 ++++++++++++++++++++++++-- 1 file changed, 48 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-mvebu/armada3700/efuse.c b/arch/arm/mach-mvebu/armada3700/efuse.c index 50c73f36c565..07d5f394354c 100644 --- a/arch/arm/mach-mvebu/armada3700/efuse.c +++ b/arch/arm/mach-mvebu/armada3700/efuse.c @@ -113,6 +113,41 @@ static int rwtm_otp_read(u8 row, u32 word, u32 *data) return res; }
+static int rwtm_otp_write(u8 row, u32 word, u32 data) +{ + u32 in[4]; + int res = -EINVAL; + + if (word < 2) { + /* + * MBOX_CMD_OTP_WRITE_32B command is supported by Marvell + * fuse.bin firmware and also by new CZ.NIC wtmi firmware. + * This command writes only selected bits to OTP and does + * not calculate ECC bits. It does not allow to write the + * lock bit. + */ + in[0] = row; + in[1] = word * 32; + in[2] = data; + res = mbox_do_cmd(MBOX_CMD_OTP_WRITE_32B, in, 3, NULL, 0); + } else if (word == 2 && !(data & ~0x1)) { + /* + * MBOX_CMD_OTP_WRITE command is supported only by new CZ.NIC + * wtmi firmware and allows to write any bit to OTP, including + * the lock bit. It does not calculate or write ECC bits too. + * For compatibility with Marvell fuse.bin firmware, use this + * command only for writing the lock bit. + */ + in[0] = row; + in[1] = 0; + in[2] = 0; + in[3] = data; + res = mbox_do_cmd(MBOX_CMD_OTP_WRITE, in, 4, NULL, 0); + } + + return res; +} + /* * Banks 0-43 are used for accessing Security OTP (44 rows with 67 bits via 44 banks and words 0-2) * Bank 44 is used for accessing North Bridge OTP (69 bits via words 0-2) @@ -154,8 +189,19 @@ int fuse_read(u32 bank, u32 word, u32 *val)
int fuse_prog(u32 bank, u32 word, u32 val) { - /* TODO: not implemented yet */ - return -ENOSYS; + if (bank <= RWTM_MAX_BANK) { + if (word >= RWTM_ROW_WORDS) + return -EINVAL; + return rwtm_otp_write(bank, word, val); + } else if (bank == OTP_NB_BANK) { + /* TODO: not implemented yet */ + return -ENOSYS; + } else if (bank == OTP_SB_BANK) { + /* TODO: not implemented yet */ + return -ENOSYS; + } else { + return -EINVAL; + } }
int fuse_sense(u32 bank, u32 word, u32 *val)
- u32 in[4];
- int res = -EINVAL;
- if (word < 2) {
* lock bit.
in[0] = row;
in[1] = word * 32;
in[2] = data;
- } else if (word == 2 && !(data & ~0x1)) {
in[0] = row;
in[1] = 0;
in[2] = 0;
in[3] = data;
- return res;
- Banks 0-43 are used for accessing Security OTP (44 rows with 67 bits via 44 banks and words 0-2)
- Bank 44 is used for accessing North Bridge OTP (69 bits via words 0-2)
- return -ENOSYS;
- if (bank <= RWTM_MAX_BANK) {
return -EINVAL;
- } else if (bank == OTP_NB_BANK) {
return -ENOSYS;
- } else if (bank == OTP_SB_BANK) {
return -ENOSYS;
- } else {
return -EINVAL;
Reviewed-by: Marek Behún marek.behun@nic.cz
Frankly, I missed answering this question until now. Yes, let's enable write support:
Applied to u-boot-marvell/master
Thanks, Stefan
- u32 in[4];
- if (word < 2) {
* lock bit.
in[0] = row;
in[1] = word * 32;
in[2] = data;
in[0] = row;
in[1] = 0;
in[2] = 0;
in[3] = data;
- return res;
- return -ENOSYS;
return -EINVAL;
return -ENOSYS;
return -ENOSYS;
} else {
return -EINVAL;
Viele Grüße, Stefan Roese
Marek Behún
Pali Rohár
Stefan Roese
