[PATCH v2 0/5] Update Microchip PolarFire SoC support
This patch set updates Microchip PolarFire SoC Icicle Kit support of RISC-V U-Boot.
The patches are based upon latest U-Boot tree (https://source.denx.de/u-boot/u-boot) at commit id 3144ba23bf4649f699078259fdf2e5cb4eab8f53
The device tree split into .dtsi and .dts files, UART1 uses for console instead of UART0, UART0 is reserved for Hart Software Services, common device node for eMMC/SD, add Microchip I2C driver and default build for SBI_V02.
Changes in v2: - Fix some typos - Remove Microchip macb compatible string - Add compatible "cdns,macb" at ethernet device node - Update MACB driver to support 32-bit and 64-bit DMA
Padmarao Begari (5): net: macb: Remove Microchip compatible string i2c: Add Microchip PolarFire SoC I2C driver riscv: dts: Split Microchip device tree riscv: Update Microchip MPFS Icicle Kit support doc: board: Update Microchip MPFS Icicle Kit doc
arch/riscv/dts/microchip-mpfs-icicle-kit.dts | 518 ++++------------ arch/riscv/dts/microchip-mpfs.dtsi | 571 ++++++++++++++++++ board/microchip/mpfs_icicle/Kconfig | 5 + board/microchip/mpfs_icicle/mpfs_icicle.c | 17 +- configs/microchip_mpfs_icicle_defconfig | 1 - doc/board/microchip/mpfs_icicle.rst | 7 +- drivers/i2c/Kconfig | 6 + drivers/i2c/Makefile | 1 + drivers/i2c/i2c-microchip.c | 482 +++++++++++++++ drivers/net/macb.c | 18 +- .../microchip-mpfs-plic.h | 196 ++++++ .../interrupt-controller/riscv-hart.h | 17 + 12 files changed, 1435 insertions(+), 404 deletions(-) create mode 100644 arch/riscv/dts/microchip-mpfs.dtsi create mode 100644 drivers/i2c/i2c-microchip.c create mode 100644 include/dt-bindings/interrupt-controller/microchip-mpfs-plic.h create mode 100644 include/dt-bindings/interrupt-controller/riscv-hart.h
Remove the microchip compatible string and default compatible "cdns,macb" support both 32-bit and 64-bit DMA access.
Signed-off-by: Padmarao Begari padmarao.begari@microchip.com --- drivers/net/macb.c | 18 +++++++----------- 1 file changed, 7 insertions(+), 11 deletions(-)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index 8c6461e717..37eed59a69 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -1348,7 +1348,7 @@ static const struct macb_usrio_cfg macb_default_usrio = { .clken = MACB_BIT(CLKEN), };
-static const struct macb_config default_gem_config = { +static struct macb_config default_gem_config = { .dma_burst_length = 16, .hw_dma_cap = HW_DMA_CAP_32B, .clk_init = NULL, @@ -1383,8 +1383,13 @@ static int macb_eth_probe(struct udevice *dev) macb->is_big_endian = (cpu_to_be32(0x12345678) == 0x12345678);
macb->config = (struct macb_config *)dev_get_driver_data(dev); - if (!macb->config) + if (!macb->config) { + if (IS_ENABLED(CONFIG_DMA_ADDR_T_64BIT)) { + if (GEM_BFEXT(DAW64, gem_readl(macb, DCFG6))) + default_gem_config.hw_dma_cap = HW_DMA_CAP_64B; + } macb->config = &default_gem_config; + }
#ifdef CONFIG_CLK ret = macb_enable_clk(dev); @@ -1453,13 +1458,6 @@ static const struct macb_usrio_cfg sama7g5_usrio = { .clken = BIT(2), };
-static const struct macb_config microchip_config = { - .dma_burst_length = 16, - .hw_dma_cap = HW_DMA_CAP_64B, - .clk_init = NULL, - .usrio = &macb_default_usrio, -}; - static const struct macb_config sama5d4_config = { .dma_burst_length = 4, .hw_dma_cap = HW_DMA_CAP_32B, @@ -1502,8 +1500,6 @@ static const struct udevice_id macb_eth_ids[] = { { .compatible = "cdns,zynq-gem" }, { .compatible = "sifive,fu540-c000-gem", .data = (ulong)&sifive_config }, - { .compatible = "microchip,mpfs-mss-gem", - .data = (ulong)µchip_config }, { } };
Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com
Add I2C driver code for the Microchip PolarFire SoC. This driver supports I2C data transfer and probe for I2C slave addresses.
Signed-off-by: Padmarao Begari padmarao.begari@microchip.com Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com --- drivers/i2c/Kconfig | 6 + drivers/i2c/Makefile | 1 + drivers/i2c/i2c-microchip.c | 482 ++++++++++++++++++++++++++++++++++++ 3 files changed, 489 insertions(+) create mode 100644 drivers/i2c/i2c-microchip.c
diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index 7c447a8aa0..5482a4a470 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -250,6 +250,12 @@ config SYS_I2C_MESON internal buffer holding up to 8 bytes for transfers and supports both 7-bit and 10-bit addresses.
+config SYS_I2C_MICROCHIP + bool "Microchip I2C driver" + help + Add support for the Microchip I2C driver. This is operating on + standard mode up to 100 kbits/s and fast mode up to 400 kbits/s. + config SYS_I2C_MXC bool "NXP MXC I2C driver" help diff --git a/drivers/i2c/Makefile b/drivers/i2c/Makefile index fca6b157f8..9d41f379bb 100644 --- a/drivers/i2c/Makefile +++ b/drivers/i2c/Makefile @@ -28,6 +28,7 @@ obj-$(CONFIG_SYS_I2C_IPROC) += iproc_i2c.o obj-$(CONFIG_SYS_I2C_KONA) += kona_i2c.o obj-$(CONFIG_SYS_I2C_LPC32XX) += lpc32xx_i2c.o obj-$(CONFIG_SYS_I2C_MESON) += meson_i2c.o +obj-$(CONFIG_SYS_I2C_MICROCHIP) += i2c-microchip.o obj-$(CONFIG_SYS_I2C_MV) += mv_i2c.o obj-$(CONFIG_SYS_I2C_MVTWSI) += mvtwsi.o obj-$(CONFIG_SYS_I2C_MXC) += mxc_i2c.o diff --git a/drivers/i2c/i2c-microchip.c b/drivers/i2c/i2c-microchip.c new file mode 100644 index 0000000000..12f65d0af7 --- /dev/null +++ b/drivers/i2c/i2c-microchip.c @@ -0,0 +1,482 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Microchip I2C controller driver + * + * Copyright (C) 2021 Microchip Technology Inc. + * Padmarao Begari padmarao.begari@microchip.com + */ +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <i2c.h> +#include <asm/io.h> +#include <dm/device_compat.h> +#include <linux/bitops.h> +#include <linux/delay.h> +#include <linux/err.h> + +#define MICROCHIP_I2C_TIMEOUT (1000 * 60) + +#define MPFS_I2C_CTRL (0x00) +#define CTRL_CR0 (0x00) +#define CTRL_CR1 (0x01) +#define CTRL_AA BIT(2) +#define CTRL_SI BIT(3) +#define CTRL_STO BIT(4) +#define CTRL_STA BIT(5) +#define CTRL_ENS1 BIT(6) +#define CTRL_CR2 (0x07) +#define MPFS_I2C_STATUS (0x04) +#define STATUS_BUS_ERROR (0x00) +#define STATUS_M_START_SENT (0x08) +#define STATUS_M_REPEATED_START_SENT (0x10) +#define STATUS_M_SLAW_ACK (0x18) +#define STATUS_M_SLAW_NACK (0x20) +#define STATUS_M_TX_DATA_ACK (0x28) +#define STATUS_M_TX_DATA_NACK (0x30) +#define STATUS_M_ARB_LOST (0x38) +#define STATUS_M_SLAR_ACK (0x40) +#define STATUS_M_SLAR_NACK (0x48) +#define STATUS_M_RX_DATA_ACKED (0x50) +#define STATUS_M_RX_DATA_NACKED (0x58) +#define STATUS_S_SLAW_ACKED (0x60) +#define STATUS_S_ARB_LOST_SLAW_ACKED (0x68) +#define STATUS_S_GENERAL_CALL_ACKED (0x70) +#define STATUS_S_ARB_LOST_GENERAL_CALL_ACKED (0x78) +#define STATUS_S_RX_DATA_ACKED (0x80) +#define STATUS_S_RX_DATA_NACKED (0x88) +#define STATUS_S_GENERAL_CALL_RX_DATA_ACKED (0x90) +#define STATUS_S_GENERAL_CALL_RX_DATA_NACKED (0x98) +#define STATUS_S_RX_STOP (0xA0) +#define STATUS_S_SLAR_ACKED (0xA8) +#define STATUS_S_ARB_LOST_SLAR_ACKED (0xB0) +#define STATUS_S_TX_DATA_ACK (0xb8) +#define STATUS_S_TX_DATA_NACK (0xC0) +#define STATUS_LAST_DATA_ACK (0xC8) +#define STATUS_M_SMB_MASTER_RESET (0xD0) +#define STATUS_S_SCL_LOW_TIMEOUT (0xD8) +#define STATUS_NO_STATE_INFO (0xF8) +#define MPFS_I2C_DATA (0x08) +#define MPFS_I2C_SLAVE0_ADDR (0x0c) +#define MPFS_I2C_SMBUS (0x10) +#define MPFS_I2C_FREQ (0x14) +#define MPFS_I2C_GLITCHREG (0x18) +#define MPFS_I2C_SLAVE1_ADDR (0x1c) + +#define PCLK_DIV_256 ((0 << CTRL_CR0) | (0 << CTRL_CR1) | (0 << CTRL_CR2)) +#define PCLK_DIV_224 ((1 << CTRL_CR0) | (0 << CTRL_CR1) | (0 << CTRL_CR2)) +#define PCLK_DIV_192 ((0 << CTRL_CR0) | (1 << CTRL_CR1) | (0 << CTRL_CR2)) +#define PCLK_DIV_160 ((1 << CTRL_CR0) | (1 << CTRL_CR1) | (0 << CTRL_CR2)) +#define PCLK_DIV_960 ((0 << CTRL_CR0) | (0 << CTRL_CR1) | (1 << CTRL_CR2)) +#define PCLK_DIV_120 ((1 << CTRL_CR0) | (0 << CTRL_CR1) | (1 << CTRL_CR2)) +#define PCLK_DIV_60 ((0 << CTRL_CR0) | (1 << CTRL_CR1) | (1 << CTRL_CR2)) +#define BCLK_DIV_8 ((1 << CTRL_CR0) | (1 << CTRL_CR1) | (1 << CTRL_CR2)) +#define CLK_MASK ((1 << CTRL_CR0) | (1 << CTRL_CR1) | (1 << CTRL_CR2)) + +/* + * mpfs_i2c_bus - I2C bus context + * @base: pointer to register struct + * @msg_len: number of bytes transferred in msg + * @msg_err: error code for completed message + * @i2c_clk: clock reference for i2c input clock + * @clk_rate: current i2c bus clock rate + * @buf: ptr to msg buffer for easier use. + * @addr: i2c address. + * @isr_status: cached copy of local ISR status. + */ +struct mpfs_i2c_bus { + void __iomem *base; + size_t msg_len; + int msg_err; + struct clk i2c_clk; + u32 clk_rate; + u8 *buf; + u8 addr; + u32 isr_status; +}; + +static inline u8 i2c_8bit_addr_from_msg(const struct i2c_msg *msg) +{ + return (msg->addr << 1) | (msg->flags & I2C_M_RD ? 1 : 0); +} + +static void mpfs_i2c_int_clear(struct mpfs_i2c_bus *bus) +{ + u8 ctrl = readl(bus->base + MPFS_I2C_CTRL); + + ctrl &= ~CTRL_SI; + writel(ctrl, bus->base + MPFS_I2C_CTRL); +} + +static void mpfs_i2c_core_disable(struct mpfs_i2c_bus *bus) +{ + u8 ctrl = readl(bus->base + MPFS_I2C_CTRL); + + ctrl &= ~CTRL_ENS1; + writel(ctrl, bus->base + MPFS_I2C_CTRL); +} + +static void mpfs_i2c_core_enable(struct mpfs_i2c_bus *bus) +{ + u8 ctrl = readl(bus->base + MPFS_I2C_CTRL); + + ctrl |= CTRL_ENS1; + writel(ctrl, bus->base + MPFS_I2C_CTRL); +} + +static void mpfs_i2c_reset(struct mpfs_i2c_bus *bus) +{ + mpfs_i2c_core_disable(bus); + mpfs_i2c_core_enable(bus); +} + +static inline void mpfs_i2c_stop(struct mpfs_i2c_bus *bus) +{ + u8 ctrl = readl(bus->base + MPFS_I2C_CTRL); + + ctrl |= CTRL_STO; + writel(ctrl, bus->base + MPFS_I2C_CTRL); +} + +static inline int mpfs_generate_divisor(u32 rate, u8 *code) +{ + int ret = 0; + + if (rate >= 960) + *code = PCLK_DIV_960; + else if (rate >= 256) + *code = PCLK_DIV_256; + else if (rate >= 224) + *code = PCLK_DIV_224; + else if (rate >= 192) + *code = PCLK_DIV_192; + else if (rate >= 160) + *code = PCLK_DIV_160; + else if (rate >= 120) + *code = PCLK_DIV_120; + else if (rate >= 60) + *code = PCLK_DIV_60; + else if (rate >= 8) + *code = BCLK_DIV_8; + else + ret = -EINVAL; + + return ret; +} + +static int mpfs_i2c_init(struct mpfs_i2c_bus *bus, struct udevice *dev) +{ + u32 clk_rate, divisor; + u8 clkval, ctrl; + int ret; + + ret = clk_get_by_index(dev, 0, &bus->i2c_clk); + if (ret) + return -EINVAL; + + ret = clk_enable(&bus->i2c_clk); + if (ret) + return ret; + + clk_rate = clk_get_rate(&bus->i2c_clk); + if (!clk_rate) + return -EINVAL; + + clk_free(&bus->i2c_clk); + + divisor = clk_rate / bus->clk_rate; + + ctrl = readl(bus->base + MPFS_I2C_CTRL); + + ctrl &= ~CLK_MASK; + + ret = mpfs_generate_divisor(divisor, &clkval); + if (ret) + return -EINVAL; + + ctrl |= clkval; + + writel(ctrl, bus->base + MPFS_I2C_CTRL); + + ctrl = readl(bus->base + MPFS_I2C_CTRL); + + /* Reset I2C core */ + mpfs_i2c_reset(bus); + + return 0; +} + +static void mpfs_i2c_transfer(struct mpfs_i2c_bus *bus, u32 data) +{ + if (bus->msg_len > 0) + writel(data, bus->base + MPFS_I2C_DATA); +} + +static void mpfs_i2c_empty_rx(struct mpfs_i2c_bus *bus) +{ + u8 ctrl; + u8 data_read; + + if (bus->msg_len > 0) { + data_read = readl(bus->base + MPFS_I2C_DATA); + *bus->buf++ = data_read; + bus->msg_len--; + } + + if (bus->msg_len == 0) { + ctrl = readl(bus->base + MPFS_I2C_CTRL); + ctrl &= ~CTRL_AA; + writel(ctrl, bus->base + MPFS_I2C_CTRL); + } +} + +static int mpfs_i2c_fill_tx(struct mpfs_i2c_bus *bus) +{ + mpfs_i2c_transfer(bus, *bus->buf++); + bus->msg_len--; + + return 0; +} + +static int mpfs_i2c_service_handler(struct mpfs_i2c_bus *bus) +{ + bool finish = false; + u32 status; + u8 ctrl; + + status = bus->isr_status; + + switch (status) { + case STATUS_M_START_SENT: + case STATUS_M_REPEATED_START_SENT: + ctrl = readl(bus->base + MPFS_I2C_CTRL); + ctrl &= ~CTRL_STA; + writel(bus->addr, bus->base + MPFS_I2C_DATA); + writel(ctrl, bus->base + MPFS_I2C_CTRL); + break; + case STATUS_M_SLAW_ACK: + case STATUS_M_TX_DATA_ACK: + if (bus->msg_len > 0) { + mpfs_i2c_fill_tx(bus); + } else { + /* On the last byte to be transmitted, send STOP */ + mpfs_i2c_stop(bus); + finish = true; + } + break; + case STATUS_M_SLAR_ACK: + ctrl = readl(bus->base + MPFS_I2C_CTRL); + ctrl |= CTRL_AA; + writel(ctrl, bus->base + MPFS_I2C_CTRL); + if (bus->msg_len == 0) { + /* On the last byte to be transmitted, send STOP */ + mpfs_i2c_stop(bus); + finish = true; + } + break; + case STATUS_M_RX_DATA_ACKED: + mpfs_i2c_empty_rx(bus); + if (bus->msg_len == 0) { + /* On the last byte to be transmitted, send STOP */ + mpfs_i2c_stop(bus); + finish = true; + } + break; + case STATUS_M_TX_DATA_NACK: + case STATUS_M_RX_DATA_NACKED: + case STATUS_M_SLAR_NACK: + case STATUS_M_SLAW_NACK: + bus->msg_err = -ENXIO; + mpfs_i2c_stop(bus); + finish = true; + break; + + case STATUS_M_ARB_LOST: + /* Handle Lost Arbitration */ + bus->msg_err = -EAGAIN; + finish = true; + break; + default: + break; + } + + if (finish) { + ctrl = readl(bus->base + MPFS_I2C_CTRL); + ctrl &= ~CTRL_AA; + writel(ctrl, bus->base + MPFS_I2C_CTRL); + return 0; + } + + return 1; +} + +static int mpfs_i2c_service(struct mpfs_i2c_bus *bus) +{ + int ret = 0; + int si_bit; + + si_bit = readl(bus->base + MPFS_I2C_CTRL); + if (si_bit & CTRL_SI) { + bus->isr_status = readl(bus->base + MPFS_I2C_STATUS); + ret = mpfs_i2c_service_handler(bus); + } + /* Clear the si flag */ + mpfs_i2c_int_clear(bus); + si_bit = readl(bus->base + MPFS_I2C_CTRL); + + return ret; +} + +static int mpfs_i2c_check_service_change(struct mpfs_i2c_bus *bus) +{ + u8 ctrl; + u32 count = 0; + + while (1) { + ctrl = readl(bus->base + MPFS_I2C_CTRL); + if (ctrl & CTRL_SI) + break; + udelay(1); + count += 1; + if (count == MICROCHIP_I2C_TIMEOUT) + return -ETIMEDOUT; + } + return 0; +} + +static int mpfs_i2c_poll_device(struct mpfs_i2c_bus *bus) +{ + int ret; + + while (1) { + ret = mpfs_i2c_check_service_change(bus); + if (ret) + return ret; + + ret = mpfs_i2c_service(bus); + if (!ret) + /* all messages have been transferred */ + return ret; + } +} + +static int mpfs_i2c_xfer_msg(struct mpfs_i2c_bus *bus, struct i2c_msg *msg) +{ + u8 ctrl; + int ret; + + if (!msg->len || !msg->buf) + return -EINVAL; + + bus->addr = i2c_8bit_addr_from_msg(msg); + bus->msg_len = msg->len; + bus->buf = msg->buf; + bus->msg_err = 0; + + mpfs_i2c_core_enable(bus); + + ctrl = readl(bus->base + MPFS_I2C_CTRL); + + ctrl |= CTRL_STA; + + writel(ctrl, bus->base + MPFS_I2C_CTRL); + + ret = mpfs_i2c_poll_device(bus); + if (ret) + return ret; + + return bus->msg_err; +} + +static int mpfs_i2c_xfer(struct udevice *dev, struct i2c_msg *msgs, int num_msgs) +{ + struct mpfs_i2c_bus *bus = dev_get_priv(dev); + int idx, ret; + + if (!msgs || !num_msgs) + return -EINVAL; + + for (idx = 0; idx < num_msgs; idx++) { + ret = mpfs_i2c_xfer_msg(bus, msgs++); + if (ret) + return ret; + } + + return ret; +} + +static int mpfs_i2c_probe_chip(struct udevice *dev, uint addr, uint flags) +{ + struct mpfs_i2c_bus *bus = dev_get_priv(dev); + int ret; + u8 ctrl, reg = 0; + + /* + * Send the chip address and verify that the + * address was <ACK>ed. + */ + bus->addr = addr << 1 | I2C_M_RD; + bus->buf = ® + bus->msg_len = 0; + bus->msg_err = 0; + + mpfs_i2c_core_enable(bus); + + ctrl = readl(bus->base + MPFS_I2C_CTRL); + + ctrl |= CTRL_STA; + + writel(ctrl, bus->base + MPFS_I2C_CTRL); + + ret = mpfs_i2c_poll_device(bus); + if (ret) + return ret; + + return bus->msg_err; +} + +static int mpfs_i2c_probe(struct udevice *dev) +{ + int ret; + u32 val; + struct mpfs_i2c_bus *bus = dev_get_priv(dev); + + bus->base = dev_read_addr_ptr(dev); + if (!bus->base) + return -EINVAL; + + val = dev_read_u32(dev, "clock-frequency", &bus->clk_rate); + if (val) { + printf("Default to 100kHz\n"); + /* default clock rate */ + bus->clk_rate = 100000; + } + + if (bus->clk_rate > 400000 || bus->clk_rate <= 0) { + printf("Invalid clock-frequency %d\n", bus->clk_rate); + return -EINVAL; + } + + ret = mpfs_i2c_init(bus, dev); + + return ret; +} + +static const struct dm_i2c_ops mpfs_i2c_ops = { + .xfer = mpfs_i2c_xfer, + .probe_chip = mpfs_i2c_probe_chip, +}; + +static const struct udevice_id mpfs_i2c_ids[] = { + {.compatible = "microchip,mpfs-i2c"}, + {} +}; + +U_BOOT_DRIVER(mpfs_i2c) = { + .name = "mpfs_i2c", + .id = UCLASS_I2C, + .of_match = mpfs_i2c_ids, + .ops = &mpfs_i2c_ops, + .probe = mpfs_i2c_probe, + .priv_auto = sizeof(struct mpfs_i2c_bus), +};
The device tree split into .dtsi and .dts files, common device node for eMMC/SD, enable I2C1, UART1 for console instead of UART0, enable the DDR 2GB memory and in that 288MB memory is reserved for fabric buffer.
Signed-off-by: Padmarao Begari padmarao.begari@microchip.com Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com --- arch/riscv/dts/microchip-mpfs-icicle-kit.dts | 518 ++++------------ arch/riscv/dts/microchip-mpfs.dtsi | 571 ++++++++++++++++++ .../microchip-mpfs-plic.h | 196 ++++++ .../interrupt-controller/riscv-hart.h | 17 + 4 files changed, 913 insertions(+), 389 deletions(-) create mode 100644 arch/riscv/dts/microchip-mpfs.dtsi create mode 100644 include/dt-bindings/interrupt-controller/microchip-mpfs-plic.h create mode 100644 include/dt-bindings/interrupt-controller/riscv-hart.h
diff --git a/arch/riscv/dts/microchip-mpfs-icicle-kit.dts b/arch/riscv/dts/microchip-mpfs-icicle-kit.dts index 89c4cf5fb2..287ef3d23b 100644 --- a/arch/riscv/dts/microchip-mpfs-icicle-kit.dts +++ b/arch/riscv/dts/microchip-mpfs-icicle-kit.dts @@ -1,417 +1,157 @@ -// SPDX-License-Identifier: (GPL-2.0 OR MIT) -/* Copyright (c) 2020 Microchip Technology Inc */ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2021 Microchip Technology Inc. + * Padmarao Begari padmarao.begari@microchip.com + */
/dts-v1/; -#include "dt-bindings/clock/microchip-mpfs-clock.h" + +#include "microchip-mpfs.dtsi"
/* Clock frequency (in Hz) of the rtcclk */ #define RTCCLK_FREQ 1000000
/ { - #address-cells = <2>; - #size-cells = <2>; - model = "Microchip MPFS Icicle Kit"; - compatible = "microchip,mpfs-icicle-kit"; + model = "Microchip PolarFire-SoC Icicle Kit"; + compatible = "microchip,mpfs-icicle-kit", "microchip,mpfs";
aliases { - serial0 = &uart0; - ethernet0 = &emac1; + serial1 = &uart1; + ethernet0 = &mac1; };
chosen { - stdout-path = "serial0"; + stdout-path = "serial1"; };
- cpucomplex: cpus { - #address-cells = <1>; - #size-cells = <0>; + cpus { timebase-frequency = <RTCCLK_FREQ>; - cpu0: cpu@0 { - clocks = <&clkcfg CLK_CPU>; - compatible = "sifive,e51", "sifive,rocket0", "riscv"; - device_type = "cpu"; - i-cache-block-size = <64>; - i-cache-sets = <128>; - i-cache-size = <16384>; - reg = <0>; - riscv,isa = "rv64imac"; - status = "disabled"; - operating-points = < - /* kHz uV */ - 600000 1100000 - 300000 950000 - 150000 750000 - >; - cpu0intc: interrupt-controller { - #interrupt-cells = <1>; - compatible = "riscv,cpu-intc"; - interrupt-controller; - }; - }; - cpu1: cpu@1 { - clocks = <&clkcfg CLK_CPU>; - compatible = "sifive,u54-mc", "sifive,rocket0", "riscv"; - d-cache-block-size = <64>; - d-cache-sets = <64>; - d-cache-size = <32768>; - d-tlb-sets = <1>; - d-tlb-size = <32>; - device_type = "cpu"; - i-cache-block-size = <64>; - i-cache-sets = <64>; - i-cache-size = <32768>; - i-tlb-sets = <1>; - i-tlb-size = <32>; - mmu-type = "riscv,sv39"; - reg = <1>; - riscv,isa = "rv64imafdc"; - tlb-split; - status = "okay"; - operating-points = < - /* kHz uV */ - 600000 1100000 - 300000 950000 - 150000 750000 - >; - cpu1intc: interrupt-controller { - #interrupt-cells = <1>; - compatible = "riscv,cpu-intc"; - interrupt-controller; - }; - }; - cpu2: cpu@2 { - clocks = <&clkcfg CLK_CPU>; - compatible = "sifive,u54-mc", "sifive,rocket0", "riscv"; - d-cache-block-size = <64>; - d-cache-sets = <64>; - d-cache-size = <32768>; - d-tlb-sets = <1>; - d-tlb-size = <32>; - device_type = "cpu"; - i-cache-block-size = <64>; - i-cache-sets = <64>; - i-cache-size = <32768>; - i-tlb-sets = <1>; - i-tlb-size = <32>; - mmu-type = "riscv,sv39"; - reg = <2>; - riscv,isa = "rv64imafdc"; - tlb-split; - status = "okay"; - operating-points = < - /* kHz uV */ - 600000 1100000 - 300000 950000 - 150000 750000 - >; - cpu2intc: interrupt-controller { - #interrupt-cells = <1>; - compatible = "riscv,cpu-intc"; - interrupt-controller; - }; + }; + + reserved-memory { + ranges; + #size-cells = <2>; + #address-cells = <2>; + + fabricbuf0: fabricbuf@0 { + compatible = "shared-dma-pool"; + reg = <0x0 0xae000000 0x0 0x2000000>; + label = "fabricbuf0-ddr-c"; }; - cpu3: cpu@3 { - clocks = <&clkcfg CLK_CPU>; - compatible = "sifive,u54-mc", "sifive,rocket0", "riscv"; - d-cache-block-size = <64>; - d-cache-sets = <64>; - d-cache-size = <32768>; - d-tlb-sets = <1>; - d-tlb-size = <32>; - device_type = "cpu"; - i-cache-block-size = <64>; - i-cache-sets = <64>; - i-cache-size = <32768>; - i-tlb-sets = <1>; - i-tlb-size = <32>; - mmu-type = "riscv,sv39"; - reg = <3>; - riscv,isa = "rv64imafdc"; - tlb-split; - status = "okay"; - operating-points = < - /* kHz uV */ - 600000 1100000 - 300000 950000 - 150000 750000 - >; - cpu3intc: interrupt-controller { - #interrupt-cells = <1>; - compatible = "riscv,cpu-intc"; - interrupt-controller; - }; + + fabricbuf1: fabricbuf@1 { + compatible = "shared-dma-pool"; + reg = <0x0 0xc0000000 0x0 0x8000000>; + label = "fabricbuf1-ddr-nc"; }; - cpu4: cpu@4 { - clocks = <&clkcfg CLK_CPU>; - compatible = "sifive,u54-mc", "sifive,rocket0", "riscv"; - d-cache-block-size = <64>; - d-cache-sets = <64>; - d-cache-size = <32768>; - d-tlb-sets = <1>; - d-tlb-size = <32>; - device_type = "cpu"; - i-cache-block-size = <64>; - i-cache-sets = <64>; - i-cache-size = <32768>; - i-tlb-sets = <1>; - i-tlb-size = <32>; - mmu-type = "riscv,sv39"; - reg = <4>; - riscv,isa = "rv64imafdc"; - tlb-split; - status = "okay"; - operating-points = < - /* kHz uV */ - 600000 1100000 - 300000 950000 - 150000 750000 - >; - cpu4intc: interrupt-controller { - #interrupt-cells = <1>; - compatible = "riscv,cpu-intc"; - interrupt-controller; - }; + + fabricbuf2: fabricbuf@2 { + compatible = "shared-dma-pool"; + reg = <0x0 0xd8000000 0x0 0x8000000>; + label = "fabricbuf2-ddr-nc-wcb"; }; }; - refclk: refclk { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <600000000>; - clock-output-names = "msspllclk"; + + udmabuf0 { + compatible = "ikwzm,u-dma-buf"; + device-name = "udmabuf-ddr-c0"; + minor-number = <0>; + size = <0x0 0x2000000>; + memory-region = <&fabricbuf0>; + sync-mode = <3>; + }; + + udmabuf1 { + compatible = "ikwzm,u-dma-buf"; + device-name = "udmabuf-ddr-nc0"; + minor-number = <1>; + size = <0x0 0x8000000>; + memory-region = <&fabricbuf1>; + sync-mode = <3>; + }; + + udmabuf2 { + compatible = "ikwzm,u-dma-buf"; + device-name = "udmabuf-ddr-nc-wcb0"; + minor-number = <2>; + size = <0x0 0x8000000>; + memory-region = <&fabricbuf2>; + sync-mode = <3>; }; - ddr: memory@80000000 { + + ddrc_cache_lo: memory@80000000 { device_type = "memory"; - reg = <0x0 0x80000000 0x0 0x40000000>; + reg = <0x0 0x80000000 0x0 0x2e000000>; clocks = <&clkcfg CLK_DDRC>; + status = "okay"; }; - soc: soc { - #address-cells = <2>; - #size-cells = <2>; - compatible = "microchip,mpfs-icicle-kit", "simple-bus"; - ranges; - clint0: clint@2000000 { - compatible = "riscv,clint0"; - interrupts-extended = <&cpu0intc 3 &cpu0intc 7 - &cpu1intc 3 &cpu1intc 7 - &cpu2intc 3 &cpu2intc 7 - &cpu3intc 3 &cpu3intc 7 - &cpu4intc 3 &cpu4intc 7>; - reg = <0x0 0x2000000 0x0 0x10000>; - reg-names = "control"; - clock-frequency = <RTCCLK_FREQ>; - }; - cachecontroller: cache-controller@2010000 { - compatible = "sifive,fu540-c000-ccache", "cache"; - cache-block-size = <64>; - cache-level = <2>; - cache-sets = <1024>; - cache-size = <2097152>; - cache-unified; - interrupt-parent = <&plic>; - interrupts = <1 2 3>; - reg = <0x0 0x2010000 0x0 0x1000>; - }; - plic: interrupt-controller@c000000 { - #interrupt-cells = <1>; - compatible = "sifive,plic-1.0.0"; - reg = <0x0 0xc000000 0x0 0x4000000>; - riscv,max-priority = <7>; - riscv,ndev = <186>; - interrupt-controller; - interrupts-extended = < - &cpu0intc 11 - &cpu1intc 11 &cpu1intc 9 - &cpu2intc 11 &cpu2intc 9 - &cpu3intc 11 &cpu3intc 9 - &cpu4intc 11 &cpu4intc 9>; - }; - uart0: serial@20000000 { - compatible = "ns16550a"; - reg = <0x0 0x20000000 0x0 0x400>; - reg-io-width = <4>; - reg-shift = <2>; - interrupt-parent = <&plic>; - interrupts = <90>; - clocks = <&clkcfg CLK_MMUART0>; - status = "okay"; - }; - clkcfg: clkcfg@20002000 { - compatible = "microchip,mpfs-clkcfg"; - reg = <0x0 0x20002000 0x0 0x1000>; - reg-names = "mss_sysreg"; - clocks = <&refclk>; - #clock-cells = <1>; - clock-output-names = "cpu", "axi", "ahb", "envm", - "mac0", "mac1", "mmc", "timer", - "mmuart0", "mmuart1", "mmuart2", - "mmuart3", "mmuart4", "spi0", "spi1", - "i2c0", "i2c1", "can0", "can1", "usb", - "reserved", "rtc", "qspi", "gpio0", - "gpio1", "gpio2", "ddrc", "fic0", - "fic1", "fic2", "fic3", "athena", - "cfm"; - }; - emmc: mmc@20008000 { - compatible = "cdns,sd4hc"; - reg = <0x0 0x20008000 0x0 0x1000>; - interrupt-parent = <&plic>; - interrupts = <88 89>; - pinctrl-names = "default"; - clocks = <&clkcfg CLK_MMC>; - bus-width = <4>; - cap-mmc-highspeed; - mmc-ddr-3_3v; - max-frequency = <200000000>; - non-removable; - no-sd; - no-sdio; - voltage-ranges = <3300 3300>; - status = "okay"; - }; - sdcard: sd@20008000 { - compatible = "cdns,sd4hc"; - reg = <0x0 0x20008000 0x0 0x1000>; - interrupt-parent = <&plic>; - interrupts = <88>; - pinctrl-names = "default"; - clocks = <&clkcfg CLK_MMC>; - bus-width = <4>; - disable-wp; - cap-sd-highspeed; - card-detect-delay = <200>; - sd-uhs-sdr12; - sd-uhs-sdr25; - sd-uhs-sdr50; - sd-uhs-sdr104; - max-frequency = <200000000>; - status = "disabled"; - }; - uart1: serial@20100000 { - compatible = "ns16550a"; - reg = <0x0 0x20100000 0x0 0x400>; - reg-io-width = <4>; - reg-shift = <2>; - interrupt-parent = <&plic>; - interrupts = <91>; - clocks = <&clkcfg CLK_MMUART1>; - status = "okay"; - }; - uart2: serial@20102000 { - compatible = "ns16550a"; - reg = <0x0 0x20102000 0x0 0x400>; - reg-io-width = <4>; - reg-shift = <2>; - interrupt-parent = <&plic>; - interrupts = <92>; - clocks = <&clkcfg CLK_MMUART2>; - status = "okay"; - }; - uart3: serial@20104000 { - compatible = "ns16550a"; - reg = <0x0 0x20104000 0x0 0x400>; - reg-io-width = <4>; - reg-shift = <2>; - interrupt-parent = <&plic>; - interrupts = <93>; - clocks = <&clkcfg CLK_MMUART3>; - status = "okay"; - }; - i2c0: i2c@2010a000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "microchip,mpfs-mss-i2c"; - reg = <0x0 0x2010a000 0x0 0x1000>; - interrupt-parent = <&plic>; - interrupts = <58>; - clocks = <&clkcfg CLK_I2C0>; - status = "disabled"; - }; - i2c1: i2c@2010b000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "microchip,mpfs-mss-i2c"; - reg = <0x0 0x2010b000 0x0 0x1000>; - interrupt-parent = <&plic>; - interrupts = <61>; - clocks = <&clkcfg CLK_I2C1>; - status = "disabled"; - pac193x@10 { - compatible = "microchip,pac1934"; - reg = <0x10>; - samp-rate = <64>; - status = "disabled"; - ch1: channel0 { - uohms-shunt-res = <10000>; - rail-name = "VDD"; - channel_enabled; - }; - ch2: channel1 { - uohms-shunt-res = <10000>; - rail-name = "VDDA25"; - channel_enabled; - }; - ch3: channel2 { - uohms-shunt-res = <10000>; - rail-name = "VDD25"; - channel_enabled; - }; - ch4: channel3 { - uohms-shunt-res = <10000>; - rail-name = "VDDA"; - channel_enabled; - }; - }; - }; - emac0: ethernet@20110000 { - compatible = "microchip,mpfs-mss-gem"; - reg = <0x0 0x20110000 0x0 0x2000>; - interrupt-parent = <&plic>; - interrupts = <64 65 66 67>; - local-mac-address = [56 34 00 FC 00 02]; - phy-mode = "sgmii"; - clocks = <&clkcfg CLK_MAC0>, <&clkcfg CLK_AXI>; - clock-names = "pclk", "hclk"; - status = "disabled";
- #address-cells = <1>; - #size-cells = <0>; - phy-handle = <&phy0>; - phy0: ethernet-phy@8 { - reg = <8>; - ti,fifo-depth = <0x01>; - }; - }; - emac1: ethernet@20112000 { - compatible = "microchip,mpfs-mss-gem"; - reg = <0x0 0x20112000 0x0 0x2000>; - interrupt-parent = <&plic>; - interrupts = <70 71 72 73>; - local-mac-address = [00 00 00 00 00 00]; - phy-mode = "sgmii"; - clocks = <&clkcfg CLK_MAC1>, <&clkcfg CLK_AHB>; - clock-names = "pclk", "hclk"; - status = "okay"; + ddrc_cache_hi: memory@1000000000 { + device_type = "memory"; + reg = <0x10 0x0 0x0 0x40000000>; + clocks = <&clkcfg CLK_DDRC>; + status = "okay"; + }; +};
- #address-cells = <1>; - #size-cells = <0>; - phy-handle = <&phy1>; - phy1: ethernet-phy@9 { - reg = <9>; - ti,fifo-depth = <0x01>; - }; - }; - gpio: gpio@20122000 { - compatible = "microchip,mpfs-mss-gpio"; - interrupt-parent = <&plic>; - interrupts = <13 14 15 16 17 18 19 20 21 22 23 24 25 26 - 27 28 29 30 31 32 33 34 35 36 37 38 39 - 40 41 42 43 44>; - gpio-controller; - clocks = <&clkcfg CLK_GPIO2>; - reg = <0x00 0x20122000 0x0 0x1000>; - reg-names = "control"; - #gpio-cells = <2>; - status = "disabled"; +&uart1 { + status = "okay"; +}; + +&mmc { + status = "okay"; + + bus-width = <4>; + disable-wp; + cap-mmc-highspeed; + cap-sd-highspeed; + card-detect-delay = <200>; + mmc-ddr-1_8v; + mmc-hs200-1_8v; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + sd-uhs-sdr104; +}; + +&i2c1 { + status = "okay"; + clock-frequency = <100000>; + + pac193x: pac193x@10 { + compatible = "microchip,pac1934"; + reg = <0x10>; + samp-rate = <64>; + status = "okay"; + ch1: channel0 { + uohms-shunt-res = <10000>; + rail-name = "VDDREG"; + channel_enabled; + }; + ch2: channel1 { + uohms-shunt-res = <10000>; + rail-name = "VDDA25"; + channel_enabled; + }; + ch3: channel2 { + uohms-shunt-res = <10000>; + rail-name = "VDD25"; + channel_enabled; + }; + ch4: channel3 { + uohms-shunt-res = <10000>; + rail-name = "VDDA_REG"; + channel_enabled; }; }; }; + +&mac1 { + status = "okay"; + phy-mode = "sgmii"; + phy-handle = <&phy1>; + phy1: ethernet-phy@9 { + reg = <9>; + ti,fifo-depth = <0x1>; + }; +}; diff --git a/arch/riscv/dts/microchip-mpfs.dtsi b/arch/riscv/dts/microchip-mpfs.dtsi new file mode 100644 index 0000000000..4f449a3a93 --- /dev/null +++ b/arch/riscv/dts/microchip-mpfs.dtsi @@ -0,0 +1,571 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* Copyright (c) 2020-2021 Microchip Technology Inc */ + +#include "dt-bindings/clock/microchip-mpfs-clock.h" +#include "dt-bindings/interrupt-controller/microchip-mpfs-plic.h" +#include "dt-bindings/interrupt-controller/riscv-hart.h" + +/ { + #address-cells = <2>; + #size-cells = <2>; + model = "Microchip PolarFire SoC"; + compatible = "microchip,mpfs"; + + chosen { + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu0: cpu@0 { + compatible = "sifive,e51", "sifive,rocket0", "riscv"; + device_type = "cpu"; + i-cache-block-size = <64>; + i-cache-sets = <128>; + i-cache-size = <16384>; + reg = <0>; + riscv,isa = "rv64imac"; + clocks = <&clkcfg CLK_CPU>; + status = "disabled"; + operating-points = < + /* kHz uV */ + 600000 1100000 + 300000 950000 + 150000 750000 + >; + cpu0_intc: interrupt-controller { + #interrupt-cells = <1>; + compatible = "riscv,cpu-intc"; + interrupt-controller; + }; + }; + + cpu1: cpu@1 { + compatible = "sifive,u54-mc", "sifive,rocket0", "riscv"; + d-cache-block-size = <64>; + d-cache-sets = <64>; + d-cache-size = <32768>; + d-tlb-sets = <1>; + d-tlb-size = <32>; + device_type = "cpu"; + i-cache-block-size = <64>; + i-cache-sets = <64>; + i-cache-size = <32768>; + i-tlb-sets = <1>; + i-tlb-size = <32>; + mmu-type = "riscv,sv39"; + reg = <1>; + riscv,isa = "rv64imafdc"; + clocks = <&clkcfg CLK_CPU>; + tlb-split; + status = "okay"; + operating-points = < + /* kHz uV */ + 600000 1100000 + 300000 950000 + 150000 750000 + >; + cpu1_intc: interrupt-controller { + #interrupt-cells = <1>; + compatible = "riscv,cpu-intc"; + interrupt-controller; + }; + }; + + cpu2: cpu@2 { + compatible = "sifive,u54-mc", "sifive,rocket0", "riscv"; + d-cache-block-size = <64>; + d-cache-sets = <64>; + d-cache-size = <32768>; + d-tlb-sets = <1>; + d-tlb-size = <32>; + device_type = "cpu"; + i-cache-block-size = <64>; + i-cache-sets = <64>; + i-cache-size = <32768>; + i-tlb-sets = <1>; + i-tlb-size = <32>; + mmu-type = "riscv,sv39"; + reg = <2>; + riscv,isa = "rv64imafdc"; + clocks = <&clkcfg CLK_CPU>; + tlb-split; + status = "okay"; + operating-points = < + /* kHz uV */ + 600000 1100000 + 300000 950000 + 150000 750000 + >; + cpu2_intc: interrupt-controller { + #interrupt-cells = <1>; + compatible = "riscv,cpu-intc"; + interrupt-controller; + }; + }; + + cpu3: cpu@3 { + compatible = "sifive,u54-mc", "sifive,rocket0", "riscv"; + d-cache-block-size = <64>; + d-cache-sets = <64>; + d-cache-size = <32768>; + d-tlb-sets = <1>; + d-tlb-size = <32>; + device_type = "cpu"; + i-cache-block-size = <64>; + i-cache-sets = <64>; + i-cache-size = <32768>; + i-tlb-sets = <1>; + i-tlb-size = <32>; + mmu-type = "riscv,sv39"; + reg = <3>; + riscv,isa = "rv64imafdc"; + clocks = <&clkcfg CLK_CPU>; + tlb-split; + status = "okay"; + operating-points = < + /* kHz uV */ + 600000 1100000 + 300000 950000 + 150000 750000 + >; + cpu3_intc: interrupt-controller { + #interrupt-cells = <1>; + compatible = "riscv,cpu-intc"; + interrupt-controller; + }; + }; + + cpu4: cpu@4 { + compatible = "sifive,u54-mc", "sifive,rocket0", "riscv"; + d-cache-block-size = <64>; + d-cache-sets = <64>; + d-cache-size = <32768>; + d-tlb-sets = <1>; + d-tlb-size = <32>; + device_type = "cpu"; + i-cache-block-size = <64>; + i-cache-sets = <64>; + i-cache-size = <32768>; + i-tlb-sets = <1>; + i-tlb-size = <32>; + mmu-type = "riscv,sv39"; + reg = <4>; + riscv,isa = "rv64imafdc"; + clocks = <&clkcfg CLK_CPU>; + tlb-split; + status = "okay"; + operating-points = < + /* kHz uV */ + 600000 1100000 + 300000 950000 + 150000 750000 + >; + cpu4_intc: interrupt-controller { + #interrupt-cells = <1>; + compatible = "riscv,cpu-intc"; + interrupt-controller; + }; + }; + }; + + soc { + #address-cells = <2>; + #size-cells = <2>; + compatible = "microchip,mpfs-soc", "simple-bus"; + ranges; + + clint: clint@2000000 { + compatible = "sifive,clint0"; + reg = <0x0 0x2000000 0x0 0xC000>; + interrupts-extended = + <&cpu0_intc HART_INT_M_SOFT &cpu0_intc HART_INT_M_TIMER + &cpu1_intc HART_INT_M_SOFT &cpu1_intc HART_INT_M_TIMER + &cpu2_intc HART_INT_M_SOFT &cpu2_intc HART_INT_M_TIMER + &cpu3_intc HART_INT_M_SOFT &cpu3_intc HART_INT_M_TIMER + &cpu4_intc HART_INT_M_SOFT &cpu4_intc HART_INT_M_TIMER>; + }; + + cachecontroller: cache-controller@2010000 { + compatible = "sifive,fu540-c000-ccache", "cache"; + reg = <0x0 0x2010000 0x0 0x1000>; + interrupt-parent = <&plic>; + interrupts = <PLIC_INT_L2_METADATA_CORR + PLIC_INT_L2_METADATA_UNCORR + PLIC_INT_L2_DATA_CORR>; + cache-block-size = <64>; + cache-level = <2>; + cache-sets = <1024>; + cache-size = <2097152>; + cache-unified; + }; + + pdma: pdma@3000000 { + compatible = "microchip,mpfs-pdma-uio","sifive,fu540-c000-pdma"; + reg = <0x0 0x3000000 0x0 0x8000>; + interrupt-parent = <&plic>; + interrupts = <PLIC_INT_DMA_CH0_DONE PLIC_INT_DMA_CH0_ERR + PLIC_INT_DMA_CH1_DONE PLIC_INT_DMA_CH1_ERR + PLIC_INT_DMA_CH2_DONE PLIC_INT_DMA_CH2_ERR + PLIC_INT_DMA_CH3_DONE PLIC_INT_DMA_CH3_ERR>; + #dma-cells = <1>; + }; + + plic: interrupt-controller@c000000 { + compatible = "sifive,plic-1.0.0"; + reg = <0x0 0xc000000 0x0 0x4000000>; + #interrupt-cells = <1>; + riscv,ndev = <186>; + interrupt-controller; + interrupts-extended = <&cpu0_intc HART_INT_M_EXT + &cpu1_intc HART_INT_M_EXT &cpu1_intc HART_INT_S_EXT + &cpu2_intc HART_INT_M_EXT &cpu2_intc HART_INT_S_EXT + &cpu3_intc HART_INT_M_EXT &cpu3_intc HART_INT_S_EXT + &cpu4_intc HART_INT_M_EXT &cpu4_intc HART_INT_S_EXT>; + }; + + refclk: refclk { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <600000000>; + clock-output-names = "msspllclk"; + }; + + clkcfg: clkcfg@20002000 { + compatible = "microchip,mpfs-clkcfg"; + reg = <0x0 0x20002000 0x0 0x1000>; + reg-names = "mss_sysreg"; + clocks = <&refclk>; + #clock-cells = <1>; + clock-output-names = "cpu", "axi", "ahb", "envm", /* 0-3 */ + "mac0", "mac1", "mmc", "timer", /* 4-7 */ + "mmuart0", "mmuart1", "mmuart2", "mmuart3", /* 8-11 */ + "mmuart4", "spi0", "spi1", "i2c0", /* 12-15 */ + "i2c1", "can0", "can1", "usb", /* 16-19 */ + "rsvd", "rtc", "qspi", "gpio0", /* 20-23 */ + "gpio1", "gpio2", "ddrc", "fic0", /* 24-27 */ + "fic1", "fic2", "fic3", "athena", "cfm"; /* 28-32 */ + }; + + /* Common node entry for eMMC/SD */ + mmc: mmc@20008000 { + compatible = "microchip,mpfs-sd4hc","cdns,sd4hc"; + reg = <0x0 0x20008000 0x0 0x1000>; + clocks = <&clkcfg CLK_MMC>; + interrupt-parent = <&plic>; + interrupts = <PLIC_INT_MMC_MAIN PLIC_INT_MMC_WAKEUP>; + max-frequency = <200000000>; + status = "disabled"; + }; + + uart0: serial@20000000 { + compatible = "ns16550a"; + reg = <0x0 0x20000000 0x0 0x400>; + reg-io-width = <4>; + reg-shift = <2>; + interrupt-parent = <&plic>; + interrupts = <PLIC_INT_MMUART0>; + clocks = <&clkcfg CLK_MMUART0>; + status = "disabled"; /* Reserved for the HSS */ + }; + + uart1: serial@20100000 { + compatible = "ns16550a"; + reg = <0x0 0x20100000 0x0 0x400>; + reg-io-width = <4>; + reg-shift = <2>; + interrupt-parent = <&plic>; + interrupts = <PLIC_INT_MMUART1>; + clocks = <&clkcfg CLK_MMUART1>; + status = "disabled"; + }; + + uart2: serial@20102000 { + compatible = "ns16550a"; + reg = <0x0 0x20102000 0x0 0x400>; + reg-io-width = <4>; + reg-shift = <2>; + interrupt-parent = <&plic>; + interrupts = <PLIC_INT_MMUART2>; + clocks = <&clkcfg CLK_MMUART2>; + status = "disabled"; + }; + + uart3: serial@20104000 { + compatible = "ns16550a"; + reg = <0x0 0x20104000 0x0 0x400>; + reg-io-width = <4>; + reg-shift = <2>; + interrupt-parent = <&plic>; + interrupts = <PLIC_INT_MMUART3>; + clocks = <&clkcfg CLK_MMUART3>; + status = "disabled"; + }; + + uart4: serial@20106000 { + compatible = "ns16550a"; + reg = <0x0 0x20106000 0x0 0x400>; + reg-io-width = <4>; + reg-shift = <2>; + interrupt-parent = <&plic>; + interrupts = <PLIC_INT_MMUART4>; + clocks = <&clkcfg CLK_MMUART4>; + status = "disabled"; + }; + + spi0: spi@20108000 { + compatible = "microchip,mpfs-spi"; + reg = <0x0 0x20108000 0x0 0x1000>; + clocks = <&clkcfg CLK_SPI0>; + interrupt-parent = <&plic>; + interrupts = <PLIC_INT_SPI0>; + num-cs = <8>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi1: spi@20109000 { + compatible = "microchip,mpfs-spi"; + reg = <0x0 0x20109000 0x0 0x1000>; + clocks = <&clkcfg CLK_SPI1>; + interrupt-parent = <&plic>; + interrupts = <PLIC_INT_SPI1>; + num-cs = <8>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c0: i2c@2010a000 { + compatible = "microchip,mpfs-i2c"; + reg = <0x0 0x2010a000 0x0 0x1000>; + clocks = <&clkcfg CLK_I2C0>; + interrupt-parent = <&plic>; + interrupts = <PLIC_INT_I2C0_MAIN>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c1: i2c@2010b000 { + compatible = "microchip,mpfs-i2c"; + reg = <0x0 0x2010b000 0x0 0x1000>; + clocks = <&clkcfg CLK_I2C1>; + interrupt-parent = <&plic>; + interrupts = <PLIC_INT_I2C1_MAIN>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + can0: can@2010c000 { + compatible = "microchip,mpfs-can-uio"; + reg = <0x0 0x2010c000 0x0 0x1000>; + clocks = <&clkcfg CLK_CAN0>; + interrupt-parent = <&plic>; + interrupts = <PLIC_INT_CAN0>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + can1: can@2010d000 { + compatible = "microchip,mpfs-can-uio"; + reg = <0x0 0x2010d000 0x0 0x1000>; + clocks = <&clkcfg CLK_CAN1>; + interrupt-parent = <&plic>; + interrupts = <PLIC_INT_CAN1>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + mac0: ethernet@20110000 { + compatible = "cdns,macb"; + reg = <0x0 0x20110000 0x0 0x2000>; + clocks = <&clkcfg CLK_MAC0>, <&clkcfg CLK_AHB>; + clock-names = "pclk", "hclk"; + interrupt-parent = <&plic>; + interrupts = <PLIC_INT_MAC0_INT + PLIC_INT_MAC0_QUEUE1 + PLIC_INT_MAC0_QUEUE2 + PLIC_INT_MAC0_QUEUE3 + PLIC_INT_MAC0_EMAC + PLIC_INT_MAC0_MMSL>; + local-mac-address = [00 00 00 00 00 00]; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + mac1: ethernet@20112000 { + compatible = "cdns,macb"; + reg = <0x0 0x20112000 0x0 0x2000>; + clocks = <&clkcfg CLK_MAC1>, <&clkcfg CLK_AHB>; + clock-names = "pclk", "hclk"; + interrupt-parent = <&plic>; + interrupts = <PLIC_INT_MAC1_INT + PLIC_INT_MAC1_QUEUE1 + PLIC_INT_MAC1_QUEUE2 + PLIC_INT_MAC1_QUEUE3 + PLIC_INT_MAC1_EMAC + PLIC_INT_MAC1_MMSL>; + local-mac-address = [00 00 00 00 00 00]; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + gpio0: gpio@20120000 { + compatible = "microchip,mpfs-gpio"; + reg = <0x0 0x20120000 0x0 0x1000>; + reg-names = "control"; + clocks = <&clkcfg CLK_GPIO0>; + interrupt-parent = <&plic>; + gpio-controller; + #gpio-cells = <2>; + status = "disabled"; + }; + + gpio1: gpio@20121000 { + compatible = "microchip,mpfs-gpio"; + reg = <000 0x20121000 0x0 0x1000>; + reg-names = "control"; + clocks = <&clkcfg CLK_GPIO1>; + interrupt-parent = <&plic>; + gpio-controller; + #gpio-cells = <2>; + status = "disabled"; + }; + + gpio2: gpio@20122000 { + compatible = "microchip,mpfs-gpio"; + reg = <0x0 0x20122000 0x0 0x1000>; + reg-names = "control"; + clocks = <&clkcfg CLK_GPIO2>; + interrupt-parent = <&plic>; + gpio-controller; + #gpio-cells = <2>; + status = "disabled"; + }; + + rtc: rtc@20124000 { + compatible = "microchip,mpfs-rtc"; + reg = <0x0 0x20124000 0x0 0x1000>; + clocks = <&clkcfg CLK_RTC>; + clock-names = "rtc"; + interrupt-parent = <&plic>; + interrupts = <PLIC_INT_RTC_WAKEUP PLIC_INT_RTC_MATCH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + usb: usb@20201000 { + compatible = "microchip,mpfs-usb-host"; + reg = <0x0 0x20201000 0x0 0x1000>; + reg-names = "mc","control"; + clocks = <&clkcfg CLK_USB>; + interrupt-parent = <&plic>; + interrupts = <PLIC_INT_USB_DMA PLIC_INT_USB_MC>; + interrupt-names = "dma","mc"; + dr_mode = "host"; + status = "disabled"; + }; + + qspi: qspi@21000000 { + compatible = "microchip,mpfs-qspi"; + reg = <0x0 0x21000000 0x0 0x1000>; + clocks = <&clkcfg CLK_QSPI>; + interrupt-parent = <&plic>; + interrupts = <PLIC_INT_QSPI>; + num-cs = <8>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + mbox: mailbox@37020000 { + compatible = "microchip,mpfs-mailbox"; + reg = <0x0 0x37020000 0x0 0x1000>, <0x0 0x2000318C 0x0 0x40>; + interrupt-parent = <&plic>; + interrupts = <PLIC_INT_G5C_MESSAGE>; + #mbox-cells = <1>; + status = "disabled"; + }; + + pcie: pcie@2000000000 { + compatible = "microchip,pcie-host-1.0"; + #address-cells = <0x3>; + #interrupt-cells = <0x1>; + #size-cells = <0x2>; + device_type = "pci"; + reg = <0x20 0x0 0x0 0x8000000 0x0 0x43000000 0x0 0x10000>; + reg-names = "cfg", "apb"; + clocks = <&clkcfg CLK_FIC0>, <&clkcfg CLK_FIC1>, <&clkcfg CLK_FIC3>; + clock-names = "fic0", "fic1", "fic3"; + bus-range = <0x0 0x7f>; + interrupt-parent = <&plic>; + interrupts = <PLIC_INT_FABRIC_F2H_2>; + interrupt-map = <0 0 0 1 &pcie_intc 0>, + <0 0 0 2 &pcie_intc 1>, + <0 0 0 3 &pcie_intc 2>, + <0 0 0 4 &pcie_intc 3>; + interrupt-map-mask = <0 0 0 7>; + ranges = <0x3000000 0x0 0x8000000 0x20 0x8000000 0x0 0x80000000>; + msi-parent = <&pcie>; + msi-controller; + mchp,axi-m-atr0 = <0x10 0x0>; + status = "disabled"; + pcie_intc: legacy-interrupt-controller { + #address-cells = <0>; + #interrupt-cells = <1>; + interrupt-controller; + }; + }; + + syscontroller: syscontroller { + compatible = "microchip,mpfs-sys-controller"; + #address-cells = <1>; + #size-cells = <1>; + mboxes = <&mbox 0>; + }; + + hwrandom: hwrandom { + compatible = "microchip,mpfs-rng"; + #address-cells = <1>; + #size-cells = <1>; + syscontroller = <&syscontroller>; + }; + + serialnum: serialnum { + compatible = "microchip,mpfs-serial-number"; + #address-cells = <1>; + #size-cells = <1>; + syscontroller = <&syscontroller>; + }; + + fpgadigest: fpgadigest { + compatible = "microchip,mpfs-digest"; + #address-cells = <1>; + #size-cells = <1>; + syscontroller = <&syscontroller>; + }; + + devicecert: cert { + compatible = "microchip,mpfs-device-cert"; + #address-cells = <1>; + #size-cells = <1>; + syscontroller = <&syscontroller>; + }; + + signature: signature { + compatible = "microchip,mpfs-signature"; + #address-cells = <1>; + #size-cells = <1>; + syscontroller = <&syscontroller>; + }; + }; +}; diff --git a/include/dt-bindings/interrupt-controller/microchip-mpfs-plic.h b/include/dt-bindings/interrupt-controller/microchip-mpfs-plic.h new file mode 100644 index 0000000000..eba1bac7df --- /dev/null +++ b/include/dt-bindings/interrupt-controller/microchip-mpfs-plic.h @@ -0,0 +1,196 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ +/* Copyright (c) 2020-2021 Microchip Technology Inc */ + +#ifndef _DT_BINDINGS_INTERRUPT_CONTROLLER_MICROCHIP_MPFS_PLIC_H +#define _DT_BINDINGS_INTERRUPT_CONTROLLER_MICROCHIP_MPFS_PLIC_H + +#define PLIC_INT_INVALID 0 +#define PLIC_INT_L2_METADATA_CORR 1 +#define PLIC_INT_L2_METADATA_UNCORR 2 +#define PLIC_INT_L2_DATA_CORR 3 +#define PLIC_INT_L2_DATA_UNCORR 4 +#define PLIC_INT_DMA_CH0_DONE 5 +#define PLIC_INT_DMA_CH0_ERR 6 +#define PLIC_INT_DMA_CH1_DONE 7 +#define PLIC_INT_DMA_CH1_ERR 8 +#define PLIC_INT_DMA_CH2_DONE 9 +#define PLIC_INT_DMA_CH2_ERR 10 +#define PLIC_INT_DMA_CH3_DONE 11 +#define PLIC_INT_DMA_CH3_ERR 12 + +#define PLIC_INT_GPIO0_BIT0_OR_GPIO2_BIT0 13 +#define PLIC_INT_GPIO0_BIT1_OR_GPIO2_BIT1 14 +#define PLIC_INT_GPIO0_BIT2_OR_GPIO2_BIT2 15 +#define PLIC_INT_GPIO0_BIT3_OR_GPIO2_BIT3 16 +#define PLIC_INT_GPIO0_BIT4_OR_GPIO2_BIT4 17 +#define PLIC_INT_GPIO0_BIT5_OR_GPIO2_BIT5 18 +#define PLIC_INT_GPIO0_BIT6_OR_GPIO2_BIT6 19 +#define PLIC_INT_GPIO0_BIT7_OR_GPIO2_BIT7 20 +#define PLIC_INT_GPIO0_BIT8_OR_GPIO2_BIT8 21 +#define PLIC_INT_GPIO0_BIT9_OR_GPIO2_BIT9 22 +#define PLIC_INT_GPIO0_BIT10_OR_GPIO2_BIT10 23 +#define PLIC_INT_GPIO0_BIT11_OR_GPIO2_BIT11 24 +#define PLIC_INT_GPIO0_BIT12_OR_GPIO2_BIT12 25 +#define PLIC_INT_GPIO0_BIT13_OR_GPIO2_BIT13 26 +#define PLIC_INT_GPIO1_BIT0_OR_GPIO2_BIT14 27 +#define PLIC_INT_GPIO1_BIT1_OR_GPIO2_BIT15 28 +#define PLIC_INT_GPIO1_BIT2_OR_GPIO2_BIT16 29 +#define PLIC_INT_GPIO1_BIT3_OR_GPIO2_BIT17 30 +#define PLIC_INT_GPIO1_BIT4_OR_GPIO2_BIT18 31 +#define PLIC_INT_GPIO1_BIT5_OR_GPIO2_BIT19 32 +#define PLIC_INT_GPIO1_BIT6_OR_GPIO2_BIT20 33 +#define PLIC_INT_GPIO1_BIT7_OR_GPIO2_BIT21 34 +#define PLIC_INT_GPIO1_BIT8_OR_GPIO2_BIT22 35 +#define PLIC_INT_GPIO1_BIT9_OR_GPIO2_BIT23 36 +#define PLIC_INT_GPIO1_BIT10_OR_GPIO2_BIT24 37 +#define PLIC_INT_GPIO1_BIT11_OR_GPIO2_BIT25 38 +#define PLIC_INT_GPIO1_BIT12_OR_GPIO2_BIT26 39 +#define PLIC_INT_GPIO1_BIT13_OR_GPIO2_BIT27 40 +#define PLIC_INT_GPIO1_BIT14_OR_GPIO2_BIT28 41 +#define PLIC_INT_GPIO1_BIT15_OR_GPIO2_BIT29 42 +#define PLIC_INT_GPIO1_BIT16_OR_GPIO2_BIT30 43 +#define PLIC_INT_GPIO1_BIT17_OR_GPIO2_BIT31 44 +#define PLIC_INT_GPIO1_BIT18 45 +#define PLIC_INT_GPIO1_BIT19 46 +#define PLIC_INT_GPIO1_BIT20 47 +#define PLIC_INT_GPIO1_BIT21 48 +#define PLIC_INT_GPIO1_BIT22 49 +#define PLIC_INT_GPIO1_BIT23 50 +#define PLIC_INT_GPIO0_NON_DIRECT 51 +#define PLIC_INT_GPIO1_NON_DIRECT 52 +#define PLIC_INT_GPIO2_NON_DIRECT 53 +#define PLIC_INT_SPI0 54 +#define PLIC_INT_SPI1 55 +#define PLIC_INT_CAN0 56 +#define PLIC_INT_CAN1 57 +#define PLIC_INT_I2C0_MAIN 58 +#define PLIC_INT_I2C0_ALERT 59 +#define PLIC_INT_I2C0_SUS 60 +#define PLIC_INT_I2C1_MAIN 61 +#define PLIC_INT_I2C1_ALERT 62 +#define PLIC_INT_I2C1_SUS 63 +#define PLIC_INT_MAC0_INT 64 +#define PLIC_INT_MAC0_QUEUE1 65 +#define PLIC_INT_MAC0_QUEUE2 66 +#define PLIC_INT_MAC0_QUEUE3 67 +#define PLIC_INT_MAC0_EMAC 68 +#define PLIC_INT_MAC0_MMSL 69 +#define PLIC_INT_MAC1_INT 70 +#define PLIC_INT_MAC1_QUEUE1 71 +#define PLIC_INT_MAC1_QUEUE2 72 +#define PLIC_INT_MAC1_QUEUE3 73 +#define PLIC_INT_MAC1_EMAC 74 +#define PLIC_INT_MAC1_MMSL 75 +#define PLIC_INT_DDRC_TRAIN 76 +#define PLIC_INT_SCB_INTERRUPT 77 +#define PLIC_INT_ECC_ERROR 78 +#define PLIC_INT_ECC_CORRECT 79 +#define PLIC_INT_RTC_WAKEUP 80 +#define PLIC_INT_RTC_MATCH 81 +#define PLIC_INT_TIMER1 82 +#define PLIC_INT_TIMER2 83 +#define PLIC_INT_ENVM 84 +#define PLIC_INT_QSPI 85 +#define PLIC_INT_USB_DMA 86 +#define PLIC_INT_USB_MC 87 +#define PLIC_INT_MMC_MAIN 88 +#define PLIC_INT_MMC_WAKEUP 89 +#define PLIC_INT_MMUART0 90 +#define PLIC_INT_MMUART1 91 +#define PLIC_INT_MMUART2 92 +#define PLIC_INT_MMUART3 93 +#define PLIC_INT_MMUART4 94 +#define PLIC_INT_G5C_DEVRST 95 +#define PLIC_INT_G5C_MESSAGE 96 +#define PLIC_INT_USOC_VC_INTERRUPT 97 +#define PLIC_INT_USOC_SMB_INTERRUPT 98 +#define PLIC_INT_E51_0_MAINTENACE 99 +#define PLIC_INT_WDOG0_MRVP 100 +#define PLIC_INT_WDOG1_MRVP 101 +#define PLIC_INT_WDOG2_MRVP 102 +#define PLIC_INT_WDOG3_MRVP 103 +#define PLIC_INT_WDOG4_MRVP 104 +#define PLIC_INT_WDOG0_TOUT 105 +#define PLIC_INT_WDOG1_TOUT 106 +#define PLIC_INT_WDOG2_TOUT 107 +#define PLIC_INT_WDOG3_TOUT 108 +#define PLIC_INT_WDOG4_TOUT 109 +#define PLIC_INT_G5C_MSS_SPI 110 +#define PLIC_INT_VOLT_TEMP_ALARM 111 +#define PLIC_INT_ATHENA_COMPLETE 112 +#define PLIC_INT_ATHENA_ALARM 113 +#define PLIC_INT_ATHENA_BUS_ERROR 114 +#define PLIC_INT_USOC_AXIC_US 115 +#define PLIC_INT_USOC_AXIC_DS 116 +#define PLIC_INT_SPARE 117 +#define PLIC_INT_FABRIC_F2H_0 118 +#define PLIC_INT_FABRIC_F2H_1 119 +#define PLIC_INT_FABRIC_F2H_2 120 +#define PLIC_INT_FABRIC_F2H_3 121 +#define PLIC_INT_FABRIC_F2H_4 122 +#define PLIC_INT_FABRIC_F2H_5 123 +#define PLIC_INT_FABRIC_F2H_6 124 +#define PLIC_INT_FABRIC_F2H_7 125 +#define PLIC_INT_FABRIC_F2H_8 126 +#define PLIC_INT_FABRIC_F2H_9 127 +#define PLIC_INT_FABRIC_F2H_10 128 +#define PLIC_INT_FABRIC_F2H_11 129 +#define PLIC_INT_FABRIC_F2H_12 130 +#define PLIC_INT_FABRIC_F2H_13 131 +#define PLIC_INT_FABRIC_F2H_14 132 +#define PLIC_INT_FABRIC_F2H_15 133 +#define PLIC_INT_FABRIC_F2H_16 134 +#define PLIC_INT_FABRIC_F2H_17 135 +#define PLIC_INT_FABRIC_F2H_18 136 +#define PLIC_INT_FABRIC_F2H_19 137 +#define PLIC_INT_FABRIC_F2H_20 138 +#define PLIC_INT_FABRIC_F2H_21 139 +#define PLIC_INT_FABRIC_F2H_22 140 +#define PLIC_INT_FABRIC_F2H_23 141 +#define PLIC_INT_FABRIC_F2H_24 142 +#define PLIC_INT_FABRIC_F2H_25 143 +#define PLIC_INT_FABRIC_F2H_26 144 +#define PLIC_INT_FABRIC_F2H_27 145 +#define PLIC_INT_FABRIC_F2H_28 146 +#define PLIC_INT_FABRIC_F2H_29 147 +#define PLIC_INT_FABRIC_F2H_30 148 +#define PLIC_INT_FABRIC_F2H_31 149 +#define PLIC_INT_FABRIC_F2H_32 150 +#define PLIC_INT_FABRIC_F2H_33 151 +#define PLIC_INT_FABRIC_F2H_34 152 +#define PLIC_INT_FABRIC_F2H_35 153 +#define PLIC_INT_FABRIC_F2H_36 154 +#define PLIC_INT_FABRIC_F2H_37 155 +#define PLIC_INT_FABRIC_F2H_38 156 +#define PLIC_INT_FABRIC_F2H_39 157 +#define PLIC_INT_FABRIC_F2H_40 158 +#define PLIC_INT_FABRIC_F2H_41 159 +#define PLIC_INT_FABRIC_F2H_42 160 +#define PLIC_INT_FABRIC_F2H_43 161 +#define PLIC_INT_FABRIC_F2H_44 162 +#define PLIC_INT_FABRIC_F2H_45 163 +#define PLIC_INT_FABRIC_F2H_46 164 +#define PLIC_INT_FABRIC_F2H_47 165 +#define PLIC_INT_FABRIC_F2H_48 166 +#define PLIC_INT_FABRIC_F2H_49 167 +#define PLIC_INT_FABRIC_F2H_50 168 +#define PLIC_INT_FABRIC_F2H_51 169 +#define PLIC_INT_FABRIC_F2H_52 170 +#define PLIC_INT_FABRIC_F2H_53 171 +#define PLIC_INT_FABRIC_F2H_54 172 +#define PLIC_INT_FABRIC_F2H_55 173 +#define PLIC_INT_FABRIC_F2H_56 174 +#define PLIC_INT_FABRIC_F2H_57 175 +#define PLIC_INT_FABRIC_F2H_58 176 +#define PLIC_INT_FABRIC_F2H_59 177 +#define PLIC_INT_FABRIC_F2H_60 178 +#define PLIC_INT_FABRIC_F2H_61 179 +#define PLIC_INT_FABRIC_F2H_62 180 +#define PLIC_INT_FABRIC_F2H_63 181 +#define PLIC_INT_BUS_ERROR_UNIT_HART_0 182 +#define PLIC_INT_BUS_ERROR_UNIT_HART_1 183 +#define PLIC_INT_BUS_ERROR_UNIT_HART_2 184 +#define PLIC_INT_BUS_ERROR_UNIT_HART_3 185 +#define PLIC_INT_BUS_ERROR_UNIT_HART_4 186 + +#endif /* _DT_BINDINGS_INTERRUPT_CONTROLLER_MICROCHIP_MPFS_PLIC_H */ diff --git a/include/dt-bindings/interrupt-controller/riscv-hart.h b/include/dt-bindings/interrupt-controller/riscv-hart.h new file mode 100644 index 0000000000..c4331b8521 --- /dev/null +++ b/include/dt-bindings/interrupt-controller/riscv-hart.h @@ -0,0 +1,17 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ +/* Copyright (c) 2020-2021 Microchip Technology Inc */ + +#ifndef _DT_BINDINGS_INTERRUPT_CONTROLLER_RISCV_HART_H +#define _DT_BINDINGS_INTERRUPT_CONTROLLER_RISCV_HART_H + +#define HART_INT_U_SOFT 0 +#define HART_INT_S_SOFT 1 +#define HART_INT_M_SOFT 3 +#define HART_INT_U_TIMER 4 +#define HART_INT_S_TIMER 5 +#define HART_INT_M_TIMER 7 +#define HART_INT_U_EXT 8 +#define HART_INT_S_EXT 9 +#define HART_INT_M_EXT 11 + +#endif /* _DT_BINDINGS_INTERRUPT_CONTROLLER_RISCV_HART_H */
This patch updates Microchip MPFS Icicle Kit support. For now, add Microchip I2C driver, set environment variables for mac addresses and default build for SBI_V02.
Signed-off-by: Padmarao Begari padmarao.begari@microchip.com Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com --- board/microchip/mpfs_icicle/Kconfig | 5 +++++ board/microchip/mpfs_icicle/mpfs_icicle.c | 17 ++++++++++++++++- configs/microchip_mpfs_icicle_defconfig | 1 - 3 files changed, 21 insertions(+), 2 deletions(-)
diff --git a/board/microchip/mpfs_icicle/Kconfig b/board/microchip/mpfs_icicle/Kconfig index 4678462378..092e411215 100644 --- a/board/microchip/mpfs_icicle/Kconfig +++ b/board/microchip/mpfs_icicle/Kconfig @@ -45,5 +45,10 @@ config BOARD_SPECIFIC_OPTIONS # dummy imply MMC_WRITE imply MMC_SDHCI imply MMC_SDHCI_CADENCE + imply MMC_SDHCI_ADMA + imply MMC_HS200_SUPPORT + imply CMD_I2C + imply DM_I2C + imply SYS_I2C_MICROCHIP
endif diff --git a/board/microchip/mpfs_icicle/mpfs_icicle.c b/board/microchip/mpfs_icicle/mpfs_icicle.c index afef719dff..e74c9fb03c 100644 --- a/board/microchip/mpfs_icicle/mpfs_icicle.c +++ b/board/microchip/mpfs_icicle/mpfs_icicle.c @@ -119,7 +119,22 @@ int board_late_init(void) if (icicle_mac_addr[idx] == ':') icicle_mac_addr[idx] = ' '; } - env_set("icicle_mac_addr", icicle_mac_addr); + env_set("icicle_mac_addr0", icicle_mac_addr); + + mac_addr[5] = device_serial_number[0] + 1; + + icicle_mac_addr[0] = '['; + + sprintf(&icicle_mac_addr[1], "%pM", mac_addr); + + icicle_mac_addr[18] = ']'; + icicle_mac_addr[19] = '\0'; + + for (idx = 0; idx < 20; idx++) { + if (icicle_mac_addr[idx] == ':') + icicle_mac_addr[idx] = ' '; + } + env_set("icicle_mac_addr1", icicle_mac_addr);
return 0; } diff --git a/configs/microchip_mpfs_icicle_defconfig b/configs/microchip_mpfs_icicle_defconfig index 54458b7823..e51afc17e2 100644 --- a/configs/microchip_mpfs_icicle_defconfig +++ b/configs/microchip_mpfs_icicle_defconfig @@ -6,7 +6,6 @@ CONFIG_DEFAULT_DEVICE_TREE="microchip-mpfs-icicle-kit" CONFIG_TARGET_MICROCHIP_ICICLE=y CONFIG_ARCH_RV64I=y CONFIG_RISCV_SMODE=y -CONFIG_SBI_V01=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_LOAD_ADDR=0x80200000 CONFIG_FIT=y
UART1 use for U-Boot and Linux console instead of UART0 and UART0 is reserved for Hart Software Services(HSS).
Signed-off-by: Padmarao Begari padmarao.begari@microchip.com Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com Reviewed-by: Bin Meng bmeng.cn@gmail.com --- doc/board/microchip/mpfs_icicle.rst | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/doc/board/microchip/mpfs_icicle.rst b/doc/board/microchip/mpfs_icicle.rst index c71c2f3cab..a4b10c6bd7 100644 --- a/doc/board/microchip/mpfs_icicle.rst +++ b/doc/board/microchip/mpfs_icicle.rst @@ -20,6 +20,7 @@ The support for following drivers are already enabled: 2. Microchip Clock Driver. 3. Cadence MACB ethernet driver for networking support. 4. Cadence MMC Driver for eMMC/SD support. +5. Microchip I2C Driver.
Booting from eMMC using HSS --------------------------- @@ -214,7 +215,8 @@ GPT partition. Booting ~~~~~~~
-You should see the U-Boot prompt on UART0. +You should see the U-Boot prompt on UART1. +(Note: UART0 is reserved for HSS)
Sample boot log from MPFS Icicle Kit '''''''''''''''''''''''''''''''''''' @@ -451,7 +453,8 @@ copied payload and Linux image.
sudo dd if=<payload_binary> of=/dev/sdX2 bs=512
GUID type ~~~~~~~~~
Leo Liang
Padmarao Begari
