[U-Boot] [PATCH] arm: at91: gardena-smart-gateway-at91sam: Enable CONFIG_SYS_NAND_USE_FLASH_BBT
This patch enables the BBT in NAND on the AT91SAM based GARDENA smart Gateway. This is especially important, since the Linux driver also enables this option and uses the BBT table pages. Without setting this option, U-Boot will try to re-use these pages again (e.g. UBI).
Signed-off-by: Stefan Roese sr@denx.de Cc: Eugen Hristev eugen.hristev@microchip.com Cc: Tom Rini trini@konsulko.com --- Eugen, I would advise you to double-check, if your AT91 based boards using NAND also have this BBT option enabled in Linux. If yes, its definitely necessary to enable it in U-Boot as well to match the same layout.
configs/gardena-smart-gateway-at91sam_defconfig | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/configs/gardena-smart-gateway-at91sam_defconfig b/configs/gardena-smart-gateway-at91sam_defconfig index c495ba4612..4a2cc331a6 100644 --- a/configs/gardena-smart-gateway-at91sam_defconfig +++ b/configs/gardena-smart-gateway-at91sam_defconfig @@ -17,6 +17,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_SMBIOS_PRODUCT_NAME="at91sam9x5ek" CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x300000 CONFIG_FIT=y CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 @@ -24,7 +25,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,768k(uboot)ro,256k(env_redundant),256k(env),512k(dtb),6M(kernel)ro,-(rootfs) rootfstype=ubifs ubi.mtd=6 root=ubi0:rootfs rw" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_SPL_TEXT_BASE=0x300000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set @@ -66,7 +66,6 @@ CONFIG_AT91_GPIO=y CONFIG_LED=y CONFIG_LED_GPIO=y # CONFIG_MMC is not set -# CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_DM_ETH=y
Hi Stefan,
Thank you for the patch. I will look into it with help of Tudor and provide some feedback.
Eugen
Hi Eugen,
Hi Stefan,
Do you have any updates on this?
Would it be possible to apply this patch for the upcoming release?
Thanks, Stefan
Eugen
Viele Grüße, Stefan
On 11.09.2019 16:13, Stefan Roese wrote:
Hi Eugen,
Hi Stefan,
Thanks, Stefan
Applied to u-boot-atmel/master
Will queue it before release in a PR. Have to check if more at91 boards need the same kind of patch.
Eugen
Hi Eugen,
Hi Stefan,
Thanks, Stefan
Thanks.
As mentioned before, I'm pretty sure that most (all) at91 boards with NAND need this patch.
Thanks, Stefan
Hei hei,
Am Dienstag, 27. August 2019, 08:14:50 CEST schrieb Stefan Roese:
Does the Linux kernel driver use those unconditionally or is that a kernel config option? Which one? (Search in 5.2 kernel config for BBT is inconclusive.)
Greets Alex
Hi Alex,
Linux uses the DT property "nand-on-flash-bbt" for this decision. But please be aware - this is only for raw NAND and not SPI NAND (IIRC).
And yes, we should definitely move to this DT property instead of the Kconfig symbol in U-Boot as well. To automatically match the configuration of such boards in U-Boot and Linux. But such a change it too intrusive at this time of release cycle.
Thanks, Stefan
Alexander Dahl
Stefan Roese
