[U-Boot] [Patch v3 06/11] powerpc/T4240EMU: Add T4240EMU target
Add emulator support for T4240. Emulator has limited peripherals and interfaces. Difference between emulator and T4240QDS includes: ECC for DDR is disabled due the procedure to load images No board FPGA (QIXIS) NOR flash has 32-bit port for higher loading speed IFC and I2C timing don't really matter, so set them fast No ethernet
Signed-off-by: York Sun yorksun@freescale.com --- Change since v2: Fixt entry in MAINTAINERS, _sorted_ Change since v1: Added entry to MAINTAINERS Fixed checkpatch warning
MAINTAINERS | 4 + board/freescale/t4qds/Makefile | 3 +- board/freescale/t4qds/ddr.c | 73 +--- board/freescale/t4qds/ddr.h | 122 ++++++ board/freescale/t4qds/law.c | 2 + board/freescale/t4qds/t4240emu.c | 96 +++++ board/freescale/t4qds/t4240qds.c | 854 ++++++++++++++++++++++++++++++++++++++ board/freescale/t4qds/t4qds.c | 853 ------------------------------------- board/freescale/t4qds/tlb.c | 3 +- boards.cfg | 1 + include/configs/T4240EMU.h | 185 +++++++++ include/configs/T4240QDS.h | 539 ++++++++++++++++++++++++ include/configs/t4qds.h | 482 +-------------------- 13 files changed, 1810 insertions(+), 1407 deletions(-) create mode 100644 board/freescale/t4qds/ddr.h create mode 100644 board/freescale/t4qds/t4240emu.c create mode 100644 board/freescale/t4qds/t4240qds.c delete mode 100644 board/freescale/t4qds/t4qds.c create mode 100644 include/configs/T4240EMU.h
diff --git a/MAINTAINERS b/MAINTAINERS index 7820375..94b1922 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -471,6 +471,10 @@ Ira W. Snyder iws@ovro.caltech.edu
P2020COME P2020
+York Sun yorksun@freescale.com + + T4240EMU T4240 + Timur Tabi timur@freescale.com
MPC8349E-mITX MPC8349 diff --git a/board/freescale/t4qds/Makefile b/board/freescale/t4qds/Makefile index ff09ffa..1923a47 100644 --- a/board/freescale/t4qds/Makefile +++ b/board/freescale/t4qds/Makefile @@ -24,7 +24,8 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).o
-COBJS-y += $(BOARD).o +COBJS-$(CONFIG_T4240QDS) += t4240qds.o +COBJS-$(CONFIG_T4240EMU) += t4240emu.o COBJS-y += ddr.o COBJS-$(CONFIG_T4240QDS)+= eth.o COBJS-$(CONFIG_PCI) += pci.o diff --git a/board/freescale/t4qds/ddr.c b/board/freescale/t4qds/ddr.c index 058d625..26ac2a5 100644 --- a/board/freescale/t4qds/ddr.c +++ b/board/freescale/t4qds/ddr.c @@ -13,81 +13,10 @@ #include <asm/fsl_ddr_sdram.h> #include <asm/fsl_ddr_dimm_params.h> #include <asm/fsl_law.h> +#include "ddr.h"
DECLARE_GLOBAL_DATA_PTR;
-struct board_specific_parameters { - u32 n_ranks; - u32 datarate_mhz_high; - u32 rank_gb; - u32 clk_adjust; - u32 wrlvl_start; - u32 wrlvl_ctl_2; - u32 wrlvl_ctl_3; - u32 cpo; - u32 write_data_delay; - u32 force_2T; -}; - -/* - * This table contains all valid speeds we want to override with board - * specific parameters. datarate_mhz_high values need to be in ascending order - * for each n_ranks group. - */ -static const struct board_specific_parameters udimm0[] = { - /* - * memory controller 0 - * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | cpo |wrdata|2T - * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | |delay | - */ - {2, 1350, 4, 4, 8, 0x0809090b, 0x0c0c0d0a, 0xff, 2, 0}, - {2, 1350, 0, 5, 7, 0x0709090b, 0x0c0c0d09, 0xff, 2, 0}, - {2, 1666, 4, 4, 8, 0x080a0a0d, 0x0d10100b, 0xff, 2, 0}, - {2, 1666, 0, 5, 7, 0x080a0a0c, 0x0d0d0e0a, 0xff, 2, 0}, - {2, 1900, 0, 4, 8, 0x090a0b0e, 0x0f11120c, 0xff, 2, 0}, - {2, 2140, 0, 4, 8, 0x090a0b0e, 0x0f11120c, 0xff, 2, 0}, - {1, 1350, 0, 5, 8, 0x0809090b, 0x0c0c0d0a, 0xff, 2, 0}, - {1, 1700, 0, 5, 8, 0x080a0a0c, 0x0c0d0e0a, 0xff, 2, 0}, - {1, 1900, 0, 4, 8, 0x080a0a0c, 0x0e0e0f0a, 0xff, 2, 0}, - {1, 2140, 0, 4, 8, 0x090a0b0c, 0x0e0f100b, 0xff, 2, 0}, - {} -}; - -/* - * The three slots have slightly different timing. The center values are good - * for all slots. We use identical speed tables for them. In future use, if - * DIMMs require separated tables, make more entries as needed. - */ -static const struct board_specific_parameters *udimms[] = { - udimm0, -}; - -static const struct board_specific_parameters rdimm0[] = { - /* - * memory controller 0 - * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | cpo |wrdata|2T - * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | |delay | - */ - {4, 1350, 0, 5, 9, 0x08070605, 0x07080805, 0xff, 2, 0}, - {4, 1666, 0, 5, 8, 0x08070605, 0x07080805, 0xff, 2, 0}, - {4, 2140, 0, 5, 8, 0x08070605, 0x07081805, 0xff, 2, 0}, - {2, 1350, 0, 5, 7, 0x0809090b, 0x0c0c0d09, 0xff, 2, 0}, - {2, 1666, 0, 5, 8, 0x080a0a0c, 0x0c0d0e0a, 0xff, 2, 0}, - {2, 2140, 0, 5, 8, 0x090a0b0c, 0x0e0f100b, 0xff, 2, 0}, - {1, 1350, 0, 5, 8, 0x0809090b, 0x0c0c0d0a, 0xff, 2, 0}, - {1, 1700, 0, 5, 8, 0x080a0a0c, 0x0c0d0e0a, 0xff, 2, 0}, - {1, 1900, 0, 4, 8, 0x080a0a0c, 0x0e0e0f0a, 0xff, 2, 0}, - {1, 2140, 0, 4, 8, 0x090a0b0c, 0x0e0f100b, 0xff, 2, 0}, - {} -}; - -/* - * The three slots have slightly different timing. See comments above. - */ -static const struct board_specific_parameters *rdimms[] = { - rdimm0, -}; - void fsl_ddr_board_options(memctl_options_t *popts, dimm_params_t *pdimm, unsigned int ctrl_num) diff --git a/board/freescale/t4qds/ddr.h b/board/freescale/t4qds/ddr.h new file mode 100644 index 0000000..cde0785 --- /dev/null +++ b/board/freescale/t4qds/ddr.h @@ -0,0 +1,122 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __DDR_H__ +#define __DDR_H__ +struct board_specific_parameters { + u32 n_ranks; + u32 datarate_mhz_high; + u32 rank_gb; + u32 clk_adjust; + u32 wrlvl_start; + u32 wrlvl_ctl_2; + u32 wrlvl_ctl_3; + u32 cpo; + u32 write_data_delay; + u32 force_2T; +}; + +/* + * These tables contain all valid speeds we want to override with board + * specific parameters. datarate_mhz_high values need to be in ascending order + * for each n_ranks group. + */ + +#ifdef CONFIG_T4240QDS +static const struct board_specific_parameters udimm0[] = { + /* + * memory controller 0 + * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | cpo |wrdata|2T + * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | |delay | + */ + {2, 1350, 4, 4, 8, 0x0809090b, 0x0c0c0d0a, 0xff, 2, 0}, + {2, 1350, 0, 5, 7, 0x0709090b, 0x0c0c0d09, 0xff, 2, 0}, + {2, 1666, 4, 4, 8, 0x080a0a0d, 0x0d10100b, 0xff, 2, 0}, + {2, 1666, 0, 5, 7, 0x080a0a0c, 0x0d0d0e0a, 0xff, 2, 0}, + {2, 1900, 0, 4, 8, 0x090a0b0e, 0x0f11120c, 0xff, 2, 0}, + {2, 2140, 0, 4, 8, 0x090a0b0e, 0x0f11120c, 0xff, 2, 0}, + {1, 1350, 0, 5, 8, 0x0809090b, 0x0c0c0d0a, 0xff, 2, 0}, + {1, 1700, 0, 5, 8, 0x080a0a0c, 0x0c0d0e0a, 0xff, 2, 0}, + {1, 1900, 0, 4, 8, 0x080a0a0c, 0x0e0e0f0a, 0xff, 2, 0}, + {1, 2140, 0, 4, 8, 0x090a0b0c, 0x0e0f100b, 0xff, 2, 0}, + {} +}; + +static const struct board_specific_parameters rdimm0[] = { + /* + * memory controller 0 + * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | cpo |wrdata|2T + * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | |delay | + */ + {4, 1350, 0, 5, 9, 0x08070605, 0x07080805, 0xff, 2, 0}, + {4, 1666, 0, 5, 8, 0x08070605, 0x07080805, 0xff, 2, 0}, + {4, 2140, 0, 5, 8, 0x08070605, 0x07081805, 0xff, 2, 0}, + {2, 1350, 0, 5, 7, 0x0809090b, 0x0c0c0d09, 0xff, 2, 0}, + {2, 1666, 0, 5, 8, 0x080a0a0c, 0x0c0d0e0a, 0xff, 2, 0}, + {2, 2140, 0, 5, 8, 0x090a0b0c, 0x0e0f100b, 0xff, 2, 0}, + {1, 1350, 0, 5, 8, 0x0809090b, 0x0c0c0d0a, 0xff, 2, 0}, + {1, 1700, 0, 5, 8, 0x080a0a0c, 0x0c0d0e0a, 0xff, 2, 0}, + {1, 1900, 0, 4, 8, 0x080a0a0c, 0x0e0e0f0a, 0xff, 2, 0}, + {1, 2140, 0, 4, 8, 0x090a0b0c, 0x0e0f100b, 0xff, 2, 0}, + {} +}; + +#else /* CONFIG_T4240EMU */ +static const struct board_specific_parameters udimm0[] = { + /* + * memory controller 0 + * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | cpo |wrdata|2T + * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | |delay | + */ + {2, 2140, 0, 4, 8, 0x0, 0x0, 0xff, 2, 0}, + {1, 2140, 0, 4, 8, 0x0, 0x0, 0xff, 2, 0}, + {} +}; + +static const struct board_specific_parameters rdimm0[] = { + /* + * memory controller 0 + * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | cpo |wrdata|2T + * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | |delay | + */ + {4, 2140, 0, 5, 8, 0x0, 0x0, 0xff, 2, 0}, + {2, 2140, 0, 5, 8, 0x0, 0x0, 0xff, 2, 0}, + {1, 2140, 0, 4, 8, 0x0, 0x0, 0xff, 2, 0}, + {} +}; +#endif /* CONFIG_T4240EMU */ + +/* + * The three slots have slightly different timing. The center values are good + * for all slots. We use identical speed tables for them. In future use, if + * DIMMs require separated tables, make more entries as needed. + */ +static const struct board_specific_parameters *udimms[] = { + udimm0, +}; + +/* + * The three slots have slightly different timing. See comments above. + */ +static const struct board_specific_parameters *rdimms[] = { + rdimm0, +}; + + +#endif diff --git a/board/freescale/t4qds/law.c b/board/freescale/t4qds/law.c index f3848f3..7e41556 100644 --- a/board/freescale/t4qds/law.c +++ b/board/freescale/t4qds/law.c @@ -35,7 +35,9 @@ struct law_entry law_table[] = { #ifdef CONFIG_SYS_QMAN_MEM_PHYS SET_LAW(CONFIG_SYS_QMAN_MEM_PHYS, LAW_SIZE_32M, LAW_TRGT_IF_QMAN), #endif +#ifdef QIXIS_BASE_PHYS SET_LAW(QIXIS_BASE_PHYS, LAW_SIZE_4K, LAW_TRGT_IF_IFC), +#endif #ifdef CONFIG_SYS_DCSRBAR_PHYS /* Limit DCSR to 32M to access NPC Trace Buffer */ SET_LAW(CONFIG_SYS_DCSRBAR_PHYS, LAW_SIZE_32M, LAW_TRGT_IF_DCSR), diff --git a/board/freescale/t4qds/t4240emu.c b/board/freescale/t4qds/t4240emu.c new file mode 100644 index 0000000..589a2ae --- /dev/null +++ b/board/freescale/t4qds/t4240emu.c @@ -0,0 +1,96 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <i2c.h> +#include <netdev.h> +#include <linux/compiler.h> +#include <asm/mmu.h> +#include <asm/processor.h> +#include <asm/cache.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_law.h> +#include <asm/fsl_serdes.h> +#include <asm/fsl_portals.h> +#include <asm/fsl_liodn.h> + +DECLARE_GLOBAL_DATA_PTR; + +int checkboard(void) +{ + struct cpu_type *cpu = gd->arch.cpu; + + printf("Board: %sEMU\n", cpu->name); + + return 0; +} + +int board_early_init_r(void) +{ + const unsigned int flashbase = CONFIG_SYS_FLASH_BASE; + const u8 flash_esel = find_tlb_idx((void *)flashbase, 1); + + /* + * Remap Boot flash + PROMJET region to caching-inhibited + * so that flash can be erased properly. + */ + + /* Flush d-cache and invalidate i-cache of any FLASH data */ + flush_dcache(); + invalidate_icache(); + + /* invalidate existing TLB entry for flash */ + disable_tlb(flash_esel); + + set_tlb(1, flashbase, CONFIG_SYS_FLASH_BASE_PHYS, + MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, flash_esel, BOOKE_PAGESZ_256M, 1); + + set_liodns(); +#ifdef CONFIG_SYS_DPAA_QBMAN + setup_portals(); +#endif + + return 0; +} + +int misc_init_r(void) +{ + return 0; +} + +void ft_board_setup(void *blob, bd_t *bd) +{ + phys_addr_t base; + phys_size_t size; + + ft_cpu_setup(blob, bd); + + base = getenv_bootm_low(); + size = getenv_bootm_size(); + + fdt_fixup_memory(blob, (u64)base, (u64)size); + + fdt_fixup_liodn(blob); + fdt_fixup_dr_usb(blob, bd); +} diff --git a/board/freescale/t4qds/t4240qds.c b/board/freescale/t4qds/t4240qds.c new file mode 100644 index 0000000..89e56a3 --- /dev/null +++ b/board/freescale/t4qds/t4240qds.c @@ -0,0 +1,854 @@ +/* + * Copyright 2009-2012 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <i2c.h> +#include <netdev.h> +#include <linux/compiler.h> +#include <asm/mmu.h> +#include <asm/processor.h> +#include <asm/cache.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_law.h> +#include <asm/fsl_serdes.h> +#include <asm/fsl_portals.h> +#include <asm/fsl_liodn.h> +#include <fm_eth.h> + +#include "../common/qixis.h" +#include "../common/vsc3316_3308.h" +#include "t4qds.h" +#include "t4240qds_qixis.h" + +DECLARE_GLOBAL_DATA_PTR; + +static const int8_t vsc3316_fsm1_tx[8][2] = { {0, 0}, {1, 1}, {6, 6}, {7, 7}, + {8, 8}, {9, 9}, {14, 14}, {15, 15} }; + +static const int8_t vsc3316_fsm2_tx[8][2] = { {2, 2}, {3, 3}, {4, 4}, {5, 5}, + {10, 10}, {11, 11}, {12, 12}, {13, 13} }; + +static const int8_t vsc3316_fsm1_rx[8][2] = { {2, 12}, {3, 13}, {4, 5}, {5, 4}, + {10, 11}, {11, 10}, {12, 2}, {13, 3} }; + +static const int8_t vsc3316_fsm2_rx[8][2] = { {0, 15}, {1, 14}, {6, 7}, {7, 6}, + {8, 9}, {9, 8}, {14, 1}, {15, 0} }; + +int checkboard(void) +{ + char buf[64]; + u8 sw; + struct cpu_type *cpu = gd->arch.cpu; + unsigned int i; + + printf("Board: %sQDS, ", cpu->name); + printf("Sys ID: 0x%02x, Sys Ver: 0x%02x, ", + QIXIS_READ(id), QIXIS_READ(arch)); + + sw = QIXIS_READ(brdcfg[0]); + sw = (sw & QIXIS_LBMAP_MASK) >> QIXIS_LBMAP_SHIFT; + + if (sw < 0x8) + printf("vBank: %d\n", sw); + else if (sw == 0x8) + puts("Promjet\n"); + else if (sw == 0x9) + puts("NAND\n"); + else + printf("invalid setting of SW%u\n", QIXIS_LBMAP_SWITCH); + + printf("FPGA: v%d (%s), build %d", + (int)QIXIS_READ(scver), qixis_read_tag(buf), + (int)qixis_read_minor()); + /* the timestamp string contains "\n" at the end */ + printf(" on %s", qixis_read_time(buf)); + + /* + * Display the actual SERDES reference clocks as configured by the + * dip switches on the board. Note that the SWx registers could + * technically be set to force the reference clocks to match the + * values that the SERDES expects (or vice versa). For now, however, + * we just display both values and hope the user notices when they + * don't match. + */ + puts("SERDES Reference Clocks: "); + sw = QIXIS_READ(brdcfg[2]); + for (i = 0; i < MAX_SERDES; i++) { + static const char * const freq[] = { + "100", "125", "156.25", "161.1328125"}; + unsigned int clock = (sw >> (6 - 2 * i)) & 3; + + printf("SERDES%u=%sMHz ", i+1, freq[clock]); + } + puts("\n"); + + return 0; +} + +int select_i2c_ch_pca9547(u8 ch) +{ + int ret; + + ret = i2c_write(I2C_MUX_PCA_ADDR_PRI, 0, 1, &ch, 1); + if (ret) { + puts("PCA: failed to select proper channel\n"); + return ret; + } + + return 0; +} + +/* + * read_voltage from sensor on I2C bus + * We use average of 4 readings, waiting for 532us befor another reading + */ +#define NUM_READINGS 4 /* prefer to be power of 2 for efficiency */ +#define WAIT_FOR_ADC 532 /* wait for 532 microseconds for ADC */ + +static inline int read_voltage(void) +{ + int i, ret, voltage_read = 0; + u16 vol_mon; + + for (i = 0; i < NUM_READINGS; i++) { + ret = i2c_read(I2C_VOL_MONITOR_ADDR, + I2C_VOL_MONITOR_BUS_V_OFFSET, 1, (void *)&vol_mon, 2); + if (ret) { + printf("VID: failed to read core voltage\n"); + return ret; + } + if (vol_mon & I2C_VOL_MONITOR_BUS_V_OVF) { + printf("VID: Core voltage sensor error\n"); + return -1; + } + debug("VID: bus voltage reads 0x%04x\n", vol_mon); + /* LSB = 4mv */ + voltage_read += (vol_mon >> I2C_VOL_MONITOR_BUS_V_SHIFT) * 4; + udelay(WAIT_FOR_ADC); + } + /* calculate the average */ + voltage_read /= NUM_READINGS; + + return voltage_read; +} + +/* + * We need to calculate how long before the voltage starts to drop or increase + * It returns with the loop count. Each loop takes several readings (532us) + */ +static inline int wait_for_voltage_change(int vdd_last) +{ + int timeout, vdd_current; + + vdd_current = read_voltage(); + /* wait until voltage starts to drop */ + for (timeout = 0; abs(vdd_last - vdd_current) <= 4 && + timeout < 100; timeout++) { + vdd_current = read_voltage(); + } + if (timeout >= 100) { + printf("VID: Voltage adjustment timeout\n"); + return -1; + } + return timeout; +} + +/* + * argument 'wait' is the time we know the voltage difference can be measured + * this function keeps reading the voltage until it is stable + */ +static inline int wait_for_voltage_stable(int wait) +{ + int timeout, vdd_current, vdd_last; + + vdd_last = read_voltage(); + udelay(wait * NUM_READINGS * WAIT_FOR_ADC); + /* wait until voltage is stable */ + vdd_current = read_voltage(); + for (timeout = 0; abs(vdd_last - vdd_current) >= 4 && + timeout < 100; timeout++) { + vdd_last = vdd_current; + udelay(wait * NUM_READINGS * WAIT_FOR_ADC); + vdd_current = read_voltage(); + } + if (timeout >= 100) { + printf("VID: Voltage adjustment timeout\n"); + return -1; + } + + return vdd_current; +} + +static inline int set_voltage(u8 vid) +{ + int wait, vdd_last; + + vdd_last = read_voltage(); + QIXIS_WRITE(brdcfg[6], vid); + wait = wait_for_voltage_change(vdd_last); + if (wait < 0) + return -1; + debug("VID: Waited %d us\n", wait * NUM_READINGS * WAIT_FOR_ADC); + wait = wait ? wait : 1; + + vdd_last = wait_for_voltage_stable(wait); + if (vdd_last < 0) + return -1; + debug("VID: Current voltage is %d mV\n", vdd_last); + + return vdd_last; +} + + +static int adjust_vdd(ulong vdd_override) +{ + int re_enable = disable_interrupts(); + ccsr_gur_t __iomem *gur = + (void __iomem *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 fusesr; + u8 vid, vid_current; + int vdd_target, vdd_current, vdd_last; + int ret; + unsigned long vdd_string_override; + char *vdd_string; + static const uint16_t vdd[32] = { + 0, /* unused */ + 9875, /* 0.9875V */ + 9750, + 9625, + 9500, + 9375, + 9250, + 9125, + 9000, + 8875, + 8750, + 8625, + 8500, + 8375, + 8250, + 8125, + 10000, /* 1.0000V */ + 10125, + 10250, + 10375, + 10500, + 10625, + 10750, + 10875, + 11000, + 0, /* reserved */ + }; + struct vdd_drive { + u8 vid; + unsigned voltage; + }; + + ret = select_i2c_ch_pca9547(I2C_MUX_CH_VOL_MONITOR); + if (ret) { + debug("VID: I2c failed to switch channel\n"); + ret = -1; + goto exit; + } + + /* get the voltage ID from fuse status register */ + fusesr = in_be32(&gur->dcfg_fusesr); + vid = (fusesr >> FSL_CORENET_DCFG_FUSESR_VID_SHIFT) & + FSL_CORENET_DCFG_FUSESR_VID_MASK; + if (vid == FSL_CORENET_DCFG_FUSESR_VID_MASK) { + vid = (fusesr >> FSL_CORENET_DCFG_FUSESR_ALTVID_SHIFT) & + FSL_CORENET_DCFG_FUSESR_ALTVID_MASK; + } + vdd_target = vdd[vid]; + + /* check override variable for overriding VDD */ + vdd_string = getenv("t4240qds_vdd_mv"); + if (vdd_override == 0 && vdd_string && + !strict_strtoul(vdd_string, 10, &vdd_string_override)) + vdd_override = vdd_string_override; + if (vdd_override >= 819 && vdd_override <= 1212) { + vdd_target = vdd_override * 10; /* convert to 1/10 mV */ + debug("VDD override is %lu\n", vdd_override); + } else if (vdd_override != 0) { + printf("Invalid value.\n"); + } + + if (vdd_target == 0) { + debug("VID: VID not used\n"); + ret = 0; + goto exit; + } else { + /* round up and divice by 10 to get a value in mV */ + vdd_target = DIV_ROUND_UP(vdd_target, 10); + debug("VID: vid = %d mV\n", vdd_target); + } + + /* + * Check current board VID setting + * Voltage regulator support output to 6.250mv step + * The highes voltage allowed for this board is (vid=0x40) 1.21250V + * the lowest is (vid=0x7f) 0.81875V + */ + vid_current = QIXIS_READ(brdcfg[6]); + vdd_current = 121250 - (vid_current - 0x40) * 625; + debug("VID: Current vid setting is (0x%x) %d mV\n", + vid_current, vdd_current/100); + + /* + * Read voltage monitor to check real voltage. + * Voltage monitor LSB is 4mv. + */ + vdd_last = read_voltage(); + if (vdd_last < 0) { + printf("VID: Could not read voltage sensor abort VID adjustment\n"); + ret = -1; + goto exit; + } + debug("VID: Core voltage is at %d mV\n", vdd_last); + /* + * Adjust voltage to at or 8mV above target. + * Each step of adjustment is 6.25mV. + * Stepping down too fast may cause over current. + */ + while (vdd_last > 0 && vid_current < 0x80 && + vdd_last > (vdd_target + 8)) { + vid_current++; + vdd_last = set_voltage(vid_current); + } + /* + * Check if we need to step up + * This happens when board voltage switch was set too low + */ + while (vdd_last > 0 && vid_current >= 0x40 && + vdd_last < vdd_target + 2) { + vid_current--; + vdd_last = set_voltage(vid_current); + } + if (vdd_last > 0) + printf("VID: Core voltage %d mV\n", vdd_last); + else + ret = -1; + +exit: + if (re_enable) + enable_interrupts(); + return ret; +} + +/* Configure Crossbar switches for Front-Side SerDes Ports */ +int config_frontside_crossbar_vsc3316(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 srds_prtcl_s1, srds_prtcl_s2; + int ret; + + ret = select_i2c_ch_pca9547(I2C_MUX_CH_VSC3316_FS); + if (ret) + return ret; + + srds_prtcl_s1 = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS1_PRTCL; + srds_prtcl_s1 >>= FSL_CORENET2_RCWSR4_SRDS1_PRTCL_SHIFT; + if (srds_prtcl_s1) { + ret = vsc3316_config(VSC3316_FSM_TX_ADDR, vsc3316_fsm1_tx, 8); + if (ret) + return ret; + ret = vsc3316_config(VSC3316_FSM_RX_ADDR, vsc3316_fsm1_rx, 8); + if (ret) + return ret; + } + + srds_prtcl_s2 = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS2_PRTCL; + srds_prtcl_s2 >>= FSL_CORENET2_RCWSR4_SRDS2_PRTCL_SHIFT; + if (srds_prtcl_s2) { + ret = vsc3316_config(VSC3316_FSM_TX_ADDR, vsc3316_fsm2_tx, 8); + if (ret) + return ret; + ret = vsc3316_config(VSC3316_FSM_RX_ADDR, vsc3316_fsm2_rx, 8); + if (ret) + return ret; + } + + return 0; +} + +int config_backside_crossbar_mux(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 srds_prtcl_s3, srds_prtcl_s4; + u8 brdcfg; + + srds_prtcl_s3 = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS3_PRTCL; + srds_prtcl_s3 >>= FSL_CORENET2_RCWSR4_SRDS3_PRTCL_SHIFT; + switch (srds_prtcl_s3) { + case 0: + /* SerDes3 is not enabled */ + break; + case 2: + case 9: + case 10: + /* SD3(0:7) => SLOT5(0:7) */ + brdcfg = QIXIS_READ(brdcfg[12]); + brdcfg &= ~BRDCFG12_SD3MX_MASK; + brdcfg |= BRDCFG12_SD3MX_SLOT5; + QIXIS_WRITE(brdcfg[12], brdcfg); + break; + case 4: + case 6: + case 8: + case 12: + case 14: + case 16: + case 17: + case 19: + case 20: + /* SD3(4:7) => SLOT6(0:3) */ + brdcfg = QIXIS_READ(brdcfg[12]); + brdcfg &= ~BRDCFG12_SD3MX_MASK; + brdcfg |= BRDCFG12_SD3MX_SLOT6; + QIXIS_WRITE(brdcfg[12], brdcfg); + break; + default: + printf("WARNING: unsupported for SerDes3 Protocol %d\n", + srds_prtcl_s3); + return -1; + } + + srds_prtcl_s4 = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS4_PRTCL; + srds_prtcl_s4 >>= FSL_CORENET2_RCWSR4_SRDS4_PRTCL_SHIFT; + switch (srds_prtcl_s4) { + case 0: + /* SerDes4 is not enabled */ + break; + case 2: + /* 10b, SD4(0:7) => SLOT7(0:7) */ + brdcfg = QIXIS_READ(brdcfg[12]); + brdcfg &= ~BRDCFG12_SD4MX_MASK; + brdcfg |= BRDCFG12_SD4MX_SLOT7; + QIXIS_WRITE(brdcfg[12], brdcfg); + break; + case 4: + case 6: + case 8: + /* x1b, SD4(4:7) => SLOT8(0:3) */ + brdcfg = QIXIS_READ(brdcfg[12]); + brdcfg &= ~BRDCFG12_SD4MX_MASK; + brdcfg |= BRDCFG12_SD4MX_SLOT8; + QIXIS_WRITE(brdcfg[12], brdcfg); + break; + case 10: + case 12: + case 14: + case 16: + case 18: + /* 00b, SD4(4:5) => AURORA, SD4(6:7) => SATA */ + brdcfg = QIXIS_READ(brdcfg[12]); + brdcfg &= ~BRDCFG12_SD4MX_MASK; + brdcfg |= BRDCFG12_SD4MX_AURO_SATA; + QIXIS_WRITE(brdcfg[12], brdcfg); + break; + default: + printf("WARNING: unsupported for SerDes4 Protocol %d\n", + srds_prtcl_s4); + return -1; + } + + return 0; +} + +int board_early_init_r(void) +{ + const unsigned int flashbase = CONFIG_SYS_FLASH_BASE; + const u8 flash_esel = find_tlb_idx((void *)flashbase, 1); + + /* + * Remap Boot flash + PROMJET region to caching-inhibited + * so that flash can be erased properly. + */ + + /* Flush d-cache and invalidate i-cache of any FLASH data */ + flush_dcache(); + invalidate_icache(); + + /* invalidate existing TLB entry for flash + promjet */ + disable_tlb(flash_esel); + + set_tlb(1, flashbase, CONFIG_SYS_FLASH_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, flash_esel, BOOKE_PAGESZ_256M, 1); + + set_liodns(); +#ifdef CONFIG_SYS_DPAA_QBMAN + setup_portals(); +#endif + + /* Disable remote I2C connection to qixis fpga */ + QIXIS_WRITE(brdcfg[5], QIXIS_READ(brdcfg[5]) & ~BRDCFG5_IRE); + + /* + * Adjust core voltage according to voltage ID + * This function changes I2C mux to channel 2. + */ + if (adjust_vdd(0)) + printf("Warning: Adjusting core voltage failed.\n"); + + /* Configure board SERDES ports crossbar */ + config_frontside_crossbar_vsc3316(); + config_backside_crossbar_mux(); + select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); + + return 0; +} + +unsigned long get_board_sys_clk(void) +{ + u8 sysclk_conf = QIXIS_READ(brdcfg[1]); +#ifdef CONFIG_FSL_QIXIS_CLOCK_MEASUREMENT + /* use accurate clock measurement */ + int freq = QIXIS_READ(clk_freq[0]) << 8 | QIXIS_READ(clk_freq[1]); + int base = QIXIS_READ(clk_base[0]) << 8 | QIXIS_READ(clk_base[1]); + u32 val; + + val = freq * base; + if (val) { + debug("SYS Clock measurement is: %d\n", val); + return val; + } else { + printf("Warning: SYS clock measurement is invalid, using value from brdcfg1.\n"); + } +#endif + + switch (sysclk_conf & 0x0F) { + case QIXIS_SYSCLK_83: + return 83333333; + case QIXIS_SYSCLK_100: + return 100000000; + case QIXIS_SYSCLK_125: + return 125000000; + case QIXIS_SYSCLK_133: + return 133333333; + case QIXIS_SYSCLK_150: + return 150000000; + case QIXIS_SYSCLK_160: + return 160000000; + case QIXIS_SYSCLK_166: + return 166666666; + } + return 66666666; +} + +unsigned long get_board_ddr_clk(void) +{ + u8 ddrclk_conf = QIXIS_READ(brdcfg[1]); +#ifdef CONFIG_FSL_QIXIS_CLOCK_MEASUREMENT + /* use accurate clock measurement */ + int freq = QIXIS_READ(clk_freq[2]) << 8 | QIXIS_READ(clk_freq[3]); + int base = QIXIS_READ(clk_base[0]) << 8 | QIXIS_READ(clk_base[1]); + u32 val; + + val = freq * base; + if (val) { + debug("DDR Clock measurement is: %d\n", val); + return val; + } else { + printf("Warning: DDR clock measurement is invalid, using value from brdcfg1.\n"); + } +#endif + + switch ((ddrclk_conf & 0x30) >> 4) { + case QIXIS_DDRCLK_100: + return 100000000; + case QIXIS_DDRCLK_125: + return 125000000; + case QIXIS_DDRCLK_133: + return 133333333; + } + return 66666666; +} + +static const char *serdes_clock_to_string(u32 clock) +{ + switch (clock) { + case SRDS_PLLCR0_RFCK_SEL_100: + return "100"; + case SRDS_PLLCR0_RFCK_SEL_125: + return "125"; + case SRDS_PLLCR0_RFCK_SEL_156_25: + return "156.25"; + case SRDS_PLLCR0_RFCK_SEL_161_13: + return "161.1328125"; + default: + return "???"; + } +} + +int misc_init_r(void) +{ + u8 sw; + serdes_corenet_t *srds_regs = + (void *)CONFIG_SYS_FSL_CORENET_SERDES_ADDR; + u32 actual[MAX_SERDES]; + unsigned int i; + + sw = QIXIS_READ(brdcfg[2]); + for (i = 0; i < MAX_SERDES; i++) { + unsigned int clock = (sw >> (6 - 2 * i)) & 3; + switch (clock) { + case 0: + actual[i] = SRDS_PLLCR0_RFCK_SEL_100; + break; + case 1: + actual[i] = SRDS_PLLCR0_RFCK_SEL_125; + break; + case 2: + actual[i] = SRDS_PLLCR0_RFCK_SEL_156_25; + break; + case 3: + actual[i] = SRDS_PLLCR0_RFCK_SEL_161_13; + break; + } + } + + for (i = 0; i < MAX_SERDES; i++) { + u32 pllcr0 = srds_regs->bank[i].pllcr0; + u32 expected = pllcr0 & SRDS_PLLCR0_RFCK_SEL_MASK; + if (expected != actual[i]) { + printf("Warning: SERDES%u expects reference clock %sMHz, but actual is %sMHz\n", + i + 1, serdes_clock_to_string(expected), + serdes_clock_to_string(actual[i])); + } + } + + return 0; +} + +void ft_board_setup(void *blob, bd_t *bd) +{ + phys_addr_t base; + phys_size_t size; + + ft_cpu_setup(blob, bd); + + base = getenv_bootm_low(); + size = getenv_bootm_size(); + + fdt_fixup_memory(blob, (u64)base, (u64)size); + +#ifdef CONFIG_PCI + pci_of_setup(blob, bd); +#endif + + fdt_fixup_liodn(blob); + fdt_fixup_dr_usb(blob, bd); + +#ifdef CONFIG_SYS_DPAA_FMAN + fdt_fixup_fman_ethernet(blob); + fdt_fixup_board_enet(blob); +#endif +} + +/* + * This function is called by bdinfo to print detail board information. + * As an exmaple for future board, we organize the messages into + * several sections. If applicable, the message is in the format of + * <name> = <value> + * It should aligned with normal output of bdinfo command. + * + * Voltage: Core, DDR and another configurable voltages + * Clock : Critical clocks which are not printed already + * RCW : RCW source if not printed already + * Misc : Other important information not in above catagories + */ +void board_detail(void) +{ + int i; + u8 brdcfg[16], dutcfg[16], rst_ctl; + int vdd, rcwsrc; + static const char * const clk[] = {"66.67", "100", "125", "133.33"}; + + for (i = 0; i < 16; i++) { + brdcfg[i] = qixis_read(offsetof(struct qixis, brdcfg[0]) + i); + dutcfg[i] = qixis_read(offsetof(struct qixis, dutcfg[0]) + i); + } + + /* Voltage secion */ + if (!select_i2c_ch_pca9547(I2C_MUX_CH_VOL_MONITOR)) { + vdd = read_voltage(); + if (vdd > 0) + printf("Core voltage= %d mV\n", vdd); + select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); + } + + printf("XVDD = 1.%d V\n", ((brdcfg[8] & 0xf) - 4) * 5 + 25); + + /* clock section */ + printf("SYSCLK = %s MHz\nDDRCLK = %s MHz\n", + clk[(brdcfg[11] >> 2) & 0x3], clk[brdcfg[11] & 3]); + + /* RCW section */ + rcwsrc = (dutcfg[0] << 1) + (dutcfg[1] & 1); + puts("RCW source = "); + switch (rcwsrc) { + case 0x017: + case 0x01f: + puts("8-bit NOR\n"); + break; + case 0x027: + case 0x02F: + puts("16-bit NOR\n"); + break; + case 0x040: + puts("SDHC/eMMC\n"); + break; + case 0x044: + puts("SPI 16-bit addressing\n"); + break; + case 0x045: + puts("SPI 24-bit addressing\n"); + break; + case 0x048: + puts("I2C normal addressing\n"); + break; + case 0x049: + puts("I2C extended addressing\n"); + break; + case 0x108: + case 0x109: + case 0x10a: + case 0x10b: + puts("8-bit NAND, 2KB\n"); + break; + default: + if ((rcwsrc >= 0x080) && (rcwsrc <= 0x09f)) + puts("Hard-coded RCW\n"); + else if ((rcwsrc >= 0x110) && (rcwsrc <= 0x11f)) + puts("8-bit NAND, 4KB\n"); + else + puts("unknown\n"); + break; + } + + /* Misc section */ + rst_ctl = QIXIS_READ(rst_ctl); + puts("HRESET_REQ = "); + switch (rst_ctl & 0x30) { + case 0x00: + puts("Ignored\n"); + break; + case 0x10: + puts("Assert HRESET\n"); + break; + case 0x30: + puts("Reset system\n"); + break; + default: + puts("N/A\n"); + break; + } +} + +/* + * Reverse engineering switch settings. + * Some bits cannot be figured out. They will be displayed as + * underscore in binary format. mask[] has those bits. + * Some bits are calculated differently than the actual switches + * if booting with overriding by FPGA. + */ +void qixis_dump_switch(void) +{ + int i; + u8 sw[9]; + + /* + * Any bit with 1 means that bit cannot be reverse engineered. + * It will be displayed as _ in binary format. + */ + static const u8 mask[] = {0, 0, 0, 0, 0, 0x1, 0xcf, 0x3f, 0x1f}; + char buf[10]; + u8 brdcfg[16], dutcfg[16]; + + for (i = 0; i < 16; i++) { + brdcfg[i] = qixis_read(offsetof(struct qixis, brdcfg[0]) + i); + dutcfg[i] = qixis_read(offsetof(struct qixis, dutcfg[0]) + i); + } + + sw[0] = dutcfg[0]; + sw[1] = (dutcfg[1] << 0x07) | + ((dutcfg[12] & 0xC0) >> 1) | + ((dutcfg[11] & 0xE0) >> 3) | + ((dutcfg[6] & 0x80) >> 6) | + ((dutcfg[1] & 0x80) >> 7); + sw[2] = ((brdcfg[1] & 0x0f) << 4) | + ((brdcfg[1] & 0x30) >> 2) | + ((brdcfg[1] & 0x40) >> 5) | + ((brdcfg[1] & 0x80) >> 7); + sw[3] = brdcfg[2]; + sw[4] = ((dutcfg[2] & 0x01) << 7) | + ((dutcfg[2] & 0x06) << 4) | + ((~QIXIS_READ(present)) & 0x10) | + ((brdcfg[3] & 0x80) >> 4) | + ((brdcfg[3] & 0x01) << 2) | + ((brdcfg[6] == 0x62) ? 3 : + ((brdcfg[6] == 0x5a) ? 2 : + ((brdcfg[6] == 0x5e) ? 1 : 0))); + sw[5] = ((brdcfg[0] & 0x0f) << 4) | + ((QIXIS_READ(rst_ctl) & 0x30) >> 2) | + ((brdcfg[0] & 0x40) >> 5); + sw[6] = (brdcfg[11] & 0x20) | + ((brdcfg[5] & 0x02) << 3); + sw[7] = (((~QIXIS_READ(rst_ctl)) & 0x40) << 1) | + ((brdcfg[5] & 0x10) << 2); + sw[8] = ((brdcfg[12] & 0x08) << 4) | + ((brdcfg[12] & 0x03) << 5); + + puts("DIP switch (reverse-engineering)\n"); + for (i = 0; i < 9; i++) { + printf("SW%d = 0b%s (0x%02x)\n", + i + 1, byte_to_binary_mask(sw[i], mask[i], buf), sw[i]); + } +} + +static int do_vdd_adjust(cmd_tbl_t *cmdtp, + int flag, int argc, + char * const argv[]) +{ + ulong override; + + if (argc < 2) + return CMD_RET_USAGE; + if (!strict_strtoul(argv[1], 10, &override)) + adjust_vdd(override); /* the value is checked by callee */ + else + return CMD_RET_USAGE; + + return 0; +} + +U_BOOT_CMD( + vdd_override, 2, 0, do_vdd_adjust, + "Override VDD", + "- override with the voltage specified in mV, eg. 1050" +); diff --git a/board/freescale/t4qds/t4qds.c b/board/freescale/t4qds/t4qds.c deleted file mode 100644 index 67de0ea..0000000 --- a/board/freescale/t4qds/t4qds.c +++ /dev/null @@ -1,853 +0,0 @@ -/* - * Copyright 2009-2012 Freescale Semiconductor, Inc. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <command.h> -#include <i2c.h> -#include <netdev.h> -#include <linux/compiler.h> -#include <asm/mmu.h> -#include <asm/processor.h> -#include <asm/cache.h> -#include <asm/immap_85xx.h> -#include <asm/fsl_law.h> -#include <asm/fsl_serdes.h> -#include <asm/fsl_portals.h> -#include <asm/fsl_liodn.h> -#include <fm_eth.h> - -#include "../common/qixis.h" -#include "../common/vsc3316_3308.h" -#include "t4qds.h" -#include "t4240qds_qixis.h" - -DECLARE_GLOBAL_DATA_PTR; - -static const int8_t vsc3316_fsm1_tx[8][2] = { {0, 0}, {1, 1}, {6, 6}, {7, 7}, - {8, 8}, {9, 9}, {14, 14}, {15, 15} }; - -static const int8_t vsc3316_fsm2_tx[8][2] = { {2, 2}, {3, 3}, {4, 4}, {5, 5}, - {10, 10}, {11, 11}, {12, 12}, {13, 13} }; - -static const int8_t vsc3316_fsm1_rx[8][2] = { {2, 12}, {3, 13}, {4, 5}, {5, 4}, - {10, 11}, {11, 10}, {12, 2}, {13, 3} }; - -static const int8_t vsc3316_fsm2_rx[8][2] = { {0, 15}, {1, 14}, {6, 7}, {7, 6}, - {8, 9}, {9, 8}, {14, 1}, {15, 0} }; - -int checkboard(void) -{ - char buf[64]; - u8 sw; - struct cpu_type *cpu = gd->arch.cpu; - unsigned int i; - - printf("Board: %sQDS, ", cpu->name); - printf("Sys ID: 0x%02x, Sys Ver: 0x%02x, ", - QIXIS_READ(id), QIXIS_READ(arch)); - - sw = QIXIS_READ(brdcfg[0]); - sw = (sw & QIXIS_LBMAP_MASK) >> QIXIS_LBMAP_SHIFT; - - if (sw < 0x8) - printf("vBank: %d\n", sw); - else if (sw == 0x8) - puts("Promjet\n"); - else if (sw == 0x9) - puts("NAND\n"); - else - printf("invalid setting of SW%u\n", QIXIS_LBMAP_SWITCH); - - printf("FPGA: v%d (%s), build %d", - (int)QIXIS_READ(scver), qixis_read_tag(buf), - (int)qixis_read_minor()); - /* the timestamp string contains "\n" at the end */ - printf(" on %s", qixis_read_time(buf)); - - /* - * Display the actual SERDES reference clocks as configured by the - * dip switches on the board. Note that the SWx registers could - * technically be set to force the reference clocks to match the - * values that the SERDES expects (or vice versa). For now, however, - * we just display both values and hope the user notices when they - * don't match. - */ - puts("SERDES Reference Clocks: "); - sw = QIXIS_READ(brdcfg[2]); - for (i = 0; i < MAX_SERDES; i++) { - static const char *freq[] = { - "100", "125", "156.25", "161.1328125"}; - unsigned int clock = (sw >> (6 - 2 * i)) & 3; - - printf("SERDES%u=%sMHz ", i+1, freq[clock]); - } - puts("\n"); - - return 0; -} - -int select_i2c_ch_pca9547(u8 ch) -{ - int ret; - - ret = i2c_write(I2C_MUX_PCA_ADDR_PRI, 0, 1, &ch, 1); - if (ret) { - puts("PCA: failed to select proper channel\n"); - return ret; - } - - return 0; -} - -/* - * read_voltage from sensor on I2C bus - * We use average of 4 readings, waiting for 532us befor another reading - */ -#define NUM_READINGS 4 /* prefer to be power of 2 for efficiency */ -#define WAIT_FOR_ADC 532 /* wait for 532 microseconds for ADC */ - -static inline int read_voltage(void) -{ - int i, ret, voltage_read = 0; - u16 vol_mon; - - for (i = 0; i < NUM_READINGS; i++) { - ret = i2c_read(I2C_VOL_MONITOR_ADDR, - I2C_VOL_MONITOR_BUS_V_OFFSET, 1, (void *)&vol_mon, 2); - if (ret) { - printf("VID: failed to read core voltage\n"); - return ret; - } - if (vol_mon & I2C_VOL_MONITOR_BUS_V_OVF) { - printf("VID: Core voltage sensor error\n"); - return -1; - } - debug("VID: bus voltage reads 0x%04x\n", vol_mon); - /* LSB = 4mv */ - voltage_read += (vol_mon >> I2C_VOL_MONITOR_BUS_V_SHIFT) * 4; - udelay(WAIT_FOR_ADC); - } - /* calculate the average */ - voltage_read /= NUM_READINGS; - - return voltage_read; -} - -/* - * We need to calculate how long before the voltage starts to drop or increase - * It returns with the loop count. Each loop takes several readings (532us) - */ -static inline int wait_for_voltage_change(int vdd_last) -{ - int timeout, vdd_current; - - vdd_current = read_voltage(); - /* wait until voltage starts to drop */ - for (timeout = 0; abs(vdd_last - vdd_current) <= 4 && - timeout < 100; timeout++) { - vdd_current = read_voltage(); - } - if (timeout >= 100) { - printf("VID: Voltage adjustment timeout\n"); - return -1; - } - return timeout; -} - -/* - * argument 'wait' is the time we know the voltage difference can be measured - * this function keeps reading the voltage until it is stable - */ -static inline int wait_for_voltage_stable(int wait) -{ - int timeout, vdd_current, vdd_last; - - vdd_last = read_voltage(); - udelay(wait * NUM_READINGS * WAIT_FOR_ADC); - /* wait until voltage is stable */ - vdd_current = read_voltage(); - for (timeout = 0; abs(vdd_last - vdd_current) >= 4 && - timeout < 100; timeout++) { - vdd_last = vdd_current; - udelay(wait * NUM_READINGS * WAIT_FOR_ADC); - vdd_current = read_voltage(); - } - if (timeout >= 100) { - printf("VID: Voltage adjustment timeout\n"); - return -1; - } - - return vdd_current; -} - -static inline int set_voltage(u8 vid) -{ - int wait, vdd_last; - - vdd_last = read_voltage(); - QIXIS_WRITE(brdcfg[6], vid); - wait = wait_for_voltage_change(vdd_last); - if (wait < 0) - return -1; - debug("VID: Waited %d us\n", wait * NUM_READINGS * WAIT_FOR_ADC); - wait = wait ? wait : 1; - - vdd_last = wait_for_voltage_stable(wait); - if (vdd_last < 0) - return -1; - debug("VID: Current voltage is %d mV\n", vdd_last); - - return vdd_last; -} - - -static int adjust_vdd(ulong vdd_override) -{ - int re_enable = disable_interrupts(); - ccsr_gur_t __iomem *gur = - (void __iomem *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - u32 fusesr; - u8 vid, vid_current; - int vdd_target, vdd_current, vdd_last; - int ret; - unsigned long vdd_string_override; - char *vdd_string; - static const uint16_t vdd[32] = { - 0, /* unused */ - 9875, /* 0.9875V */ - 9750, - 9625, - 9500, - 9375, - 9250, - 9125, - 9000, - 8875, - 8750, - 8625, - 8500, - 8375, - 8250, - 8125, - 10000, /* 1.0000V */ - 10125, - 10250, - 10375, - 10500, - 10625, - 10750, - 10875, - 11000, - 0, /* reserved */ - }; - struct vdd_drive { - u8 vid; - unsigned voltage; - }; - - ret = select_i2c_ch_pca9547(I2C_MUX_CH_VOL_MONITOR); - if (ret) { - debug("VID: I2c failed to switch channel\n"); - ret = -1; - goto exit; - } - - /* get the voltage ID from fuse status register */ - fusesr = in_be32(&gur->dcfg_fusesr); - vid = (fusesr >> FSL_CORENET_DCFG_FUSESR_VID_SHIFT) & - FSL_CORENET_DCFG_FUSESR_VID_MASK; - if (vid == FSL_CORENET_DCFG_FUSESR_VID_MASK) { - vid = (fusesr >> FSL_CORENET_DCFG_FUSESR_ALTVID_SHIFT) & - FSL_CORENET_DCFG_FUSESR_ALTVID_MASK; - } - vdd_target = vdd[vid]; - - /* check override variable for overriding VDD */ - vdd_string = getenv("t4240qds_vdd_mv"); - if (vdd_override == 0 && vdd_string && - !strict_strtoul(vdd_string, 10, &vdd_string_override)) - vdd_override = vdd_string_override; - if (vdd_override >= 819 && vdd_override <= 1212) { - vdd_target = vdd_override * 10; /* convert to 1/10 mV */ - debug("VDD override is %lu\n", vdd_override); - } else if (vdd_override != 0) { - printf("Invalid value.\n"); - } - - if (vdd_target == 0) { - debug("VID: VID not used\n"); - ret = 0; - goto exit; - } else { - /* round up and divice by 10 to get a value in mV */ - vdd_target = DIV_ROUND_UP(vdd_target, 10); - debug("VID: vid = %d mV\n", vdd_target); - } - - /* - * Check current board VID setting - * Voltage regulator support output to 6.250mv step - * The highes voltage allowed for this board is (vid=0x40) 1.21250V - * the lowest is (vid=0x7f) 0.81875V - */ - vid_current = QIXIS_READ(brdcfg[6]); - vdd_current = 121250 - (vid_current - 0x40) * 625; - debug("VID: Current vid setting is (0x%x) %d mV\n", - vid_current, vdd_current/100); - - /* - * Read voltage monitor to check real voltage. - * Voltage monitor LSB is 4mv. - */ - vdd_last = read_voltage(); - if (vdd_last < 0) { - printf("VID: Could not read voltage sensor abort VID adjustment\n"); - ret = -1; - goto exit; - } - debug("VID: Core voltage is at %d mV\n", vdd_last); - /* - * Adjust voltage to at or 8mV above target. - * Each step of adjustment is 6.25mV. - * Stepping down too fast may cause over current. - */ - while (vdd_last > 0 && vid_current < 0x80 && - vdd_last > (vdd_target + 8)) { - vid_current++; - vdd_last = set_voltage(vid_current); - } - /* - * Check if we need to step up - * This happens when board voltage switch was set too low - */ - while (vdd_last > 0 && vid_current >= 0x40 && - vdd_last < vdd_target + 2) { - vid_current--; - vdd_last = set_voltage(vid_current); - } - if (vdd_last > 0) - printf("VID: Core voltage %d mV\n", vdd_last); - else - ret = -1; - -exit: - if (re_enable) - enable_interrupts(); - return ret; -} - -/* Configure Crossbar switches for Front-Side SerDes Ports */ -int config_frontside_crossbar_vsc3316(void) -{ - ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - u32 srds_prtcl_s1, srds_prtcl_s2; - int ret; - - ret = select_i2c_ch_pca9547(I2C_MUX_CH_VSC3316_FS); - if (ret) - return ret; - - srds_prtcl_s1 = in_be32(&gur->rcwsr[4]) & - FSL_CORENET2_RCWSR4_SRDS1_PRTCL; - srds_prtcl_s1 >>= FSL_CORENET2_RCWSR4_SRDS1_PRTCL_SHIFT; - if (srds_prtcl_s1) { - ret = vsc3316_config(VSC3316_FSM_TX_ADDR, vsc3316_fsm1_tx, 8); - if (ret) - return ret; - ret = vsc3316_config(VSC3316_FSM_RX_ADDR, vsc3316_fsm1_rx, 8); - if (ret) - return ret; - } - - srds_prtcl_s2 = in_be32(&gur->rcwsr[4]) & - FSL_CORENET2_RCWSR4_SRDS2_PRTCL; - srds_prtcl_s2 >>= FSL_CORENET2_RCWSR4_SRDS2_PRTCL_SHIFT; - if (srds_prtcl_s2) { - ret = vsc3316_config(VSC3316_FSM_TX_ADDR, vsc3316_fsm2_tx, 8); - if (ret) - return ret; - ret = vsc3316_config(VSC3316_FSM_RX_ADDR, vsc3316_fsm2_rx, 8); - if (ret) - return ret; - } - - return 0; -} - -int config_backside_crossbar_mux(void) -{ - ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - u32 srds_prtcl_s3, srds_prtcl_s4; - u8 brdcfg; - - srds_prtcl_s3 = in_be32(&gur->rcwsr[4]) & - FSL_CORENET2_RCWSR4_SRDS3_PRTCL; - srds_prtcl_s3 >>= FSL_CORENET2_RCWSR4_SRDS3_PRTCL_SHIFT; - switch (srds_prtcl_s3) { - case 0: - /* SerDes3 is not enabled */ - break; - case 2: - case 9: - case 10: - /* SD3(0:7) => SLOT5(0:7) */ - brdcfg = QIXIS_READ(brdcfg[12]); - brdcfg &= ~BRDCFG12_SD3MX_MASK; - brdcfg |= BRDCFG12_SD3MX_SLOT5; - QIXIS_WRITE(brdcfg[12], brdcfg); - break; - case 4: - case 6: - case 8: - case 12: - case 14: - case 16: - case 17: - case 19: - case 20: - /* SD3(4:7) => SLOT6(0:3) */ - brdcfg = QIXIS_READ(brdcfg[12]); - brdcfg &= ~BRDCFG12_SD3MX_MASK; - brdcfg |= BRDCFG12_SD3MX_SLOT6; - QIXIS_WRITE(brdcfg[12], brdcfg); - break; - default: - printf("WARNING: unsupported for SerDes3 Protocol %d\n", - srds_prtcl_s3); - return -1; - } - - srds_prtcl_s4 = in_be32(&gur->rcwsr[4]) & - FSL_CORENET2_RCWSR4_SRDS4_PRTCL; - srds_prtcl_s4 >>= FSL_CORENET2_RCWSR4_SRDS4_PRTCL_SHIFT; - switch (srds_prtcl_s4) { - case 0: - /* SerDes4 is not enabled */ - break; - case 2: - /* 10b, SD4(0:7) => SLOT7(0:7) */ - brdcfg = QIXIS_READ(brdcfg[12]); - brdcfg &= ~BRDCFG12_SD4MX_MASK; - brdcfg |= BRDCFG12_SD4MX_SLOT7; - QIXIS_WRITE(brdcfg[12], brdcfg); - break; - case 4: - case 6: - case 8: - /* x1b, SD4(4:7) => SLOT8(0:3) */ - brdcfg = QIXIS_READ(brdcfg[12]); - brdcfg &= ~BRDCFG12_SD4MX_MASK; - brdcfg |= BRDCFG12_SD4MX_SLOT8; - QIXIS_WRITE(brdcfg[12], brdcfg); - break; - case 10: - case 12: - case 14: - case 16: - case 18: - /* 00b, SD4(4:5) => AURORA, SD4(6:7) => SATA */ - brdcfg = QIXIS_READ(brdcfg[12]); - brdcfg &= ~BRDCFG12_SD4MX_MASK; - brdcfg |= BRDCFG12_SD4MX_AURO_SATA; - QIXIS_WRITE(brdcfg[12], brdcfg); - break; - default: - printf("WARNING: unsupported for SerDes4 Protocol %d\n", - srds_prtcl_s4); - return -1; - } - - return 0; -} - -int board_early_init_r(void) -{ - const unsigned int flashbase = CONFIG_SYS_FLASH_BASE; - const u8 flash_esel = find_tlb_idx((void *)flashbase, 1); - - /* - * Remap Boot flash + PROMJET region to caching-inhibited - * so that flash can be erased properly. - */ - - /* Flush d-cache and invalidate i-cache of any FLASH data */ - flush_dcache(); - invalidate_icache(); - - /* invalidate existing TLB entry for flash + promjet */ - disable_tlb(flash_esel); - - set_tlb(1, flashbase, CONFIG_SYS_FLASH_BASE_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, flash_esel, BOOKE_PAGESZ_256M, 1); - - set_liodns(); -#ifdef CONFIG_SYS_DPAA_QBMAN - setup_portals(); -#endif - - /* Disable remote I2C connection to qixis fpga */ - QIXIS_WRITE(brdcfg[5], QIXIS_READ(brdcfg[5]) & ~BRDCFG5_IRE); - - /* - * Adjust core voltage according to voltage ID - * This function changes I2C mux to channel 2. - */ - if (adjust_vdd(0)) - printf("Warning: Adjusting core voltage failed.\n"); - - /* Configure board SERDES ports crossbar */ - config_frontside_crossbar_vsc3316(); - config_backside_crossbar_mux(); - select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); - - return 0; -} - -unsigned long get_board_sys_clk(void) -{ - u8 sysclk_conf = QIXIS_READ(brdcfg[1]); -#ifdef CONFIG_FSL_QIXIS_CLOCK_MEASUREMENT - /* use accurate clock measurement */ - int freq = QIXIS_READ(clk_freq[0]) << 8 | QIXIS_READ(clk_freq[1]); - int base = QIXIS_READ(clk_base[0]) << 8 | QIXIS_READ(clk_base[1]); - u32 val; - - val = freq * base; - if (val) { - debug("SYS Clock measurement is: %d\n", val); - return val; - } else { - printf("Warning: SYS clock measurement is invalid, using value from brdcfg1.\n"); - } -#endif - - switch (sysclk_conf & 0x0F) { - case QIXIS_SYSCLK_83: - return 83333333; - case QIXIS_SYSCLK_100: - return 100000000; - case QIXIS_SYSCLK_125: - return 125000000; - case QIXIS_SYSCLK_133: - return 133333333; - case QIXIS_SYSCLK_150: - return 150000000; - case QIXIS_SYSCLK_160: - return 160000000; - case QIXIS_SYSCLK_166: - return 166666666; - } - return 66666666; -} - -unsigned long get_board_ddr_clk(void) -{ - u8 ddrclk_conf = QIXIS_READ(brdcfg[1]); -#ifdef CONFIG_FSL_QIXIS_CLOCK_MEASUREMENT - /* use accurate clock measurement */ - int freq = QIXIS_READ(clk_freq[2]) << 8 | QIXIS_READ(clk_freq[3]); - int base = QIXIS_READ(clk_base[0]) << 8 | QIXIS_READ(clk_base[1]); - u32 val; - - val = freq * base; - if (val) { - debug("DDR Clock measurement is: %d\n", val); - return val; - } else { - printf("Warning: DDR clock measurement is invalid, using value from brdcfg1.\n"); - } -#endif - - switch ((ddrclk_conf & 0x30) >> 4) { - case QIXIS_DDRCLK_100: - return 100000000; - case QIXIS_DDRCLK_125: - return 125000000; - case QIXIS_DDRCLK_133: - return 133333333; - } - return 66666666; -} - -static const char *serdes_clock_to_string(u32 clock) -{ - switch (clock) { - case SRDS_PLLCR0_RFCK_SEL_100: - return "100"; - case SRDS_PLLCR0_RFCK_SEL_125: - return "125"; - case SRDS_PLLCR0_RFCK_SEL_156_25: - return "156.25"; - case SRDS_PLLCR0_RFCK_SEL_161_13: - return "161.1328125"; - default: - return "???"; - } -} - -int misc_init_r(void) -{ - u8 sw; - serdes_corenet_t *srds_regs = - (void *)CONFIG_SYS_FSL_CORENET_SERDES_ADDR; - u32 actual[MAX_SERDES]; - unsigned int i; - - sw = QIXIS_READ(brdcfg[2]); - for (i = 0; i < MAX_SERDES; i++) { - unsigned int clock = (sw >> (6 - 2 * i)) & 3; - switch (clock) { - case 0: - actual[i] = SRDS_PLLCR0_RFCK_SEL_100; - break; - case 1: - actual[i] = SRDS_PLLCR0_RFCK_SEL_125; - break; - case 2: - actual[i] = SRDS_PLLCR0_RFCK_SEL_156_25; - break; - case 3: - actual[i] = SRDS_PLLCR0_RFCK_SEL_161_13; - break; - } - } - - for (i = 0; i < MAX_SERDES; i++) { - u32 pllcr0 = srds_regs->bank[i].pllcr0; - u32 expected = pllcr0 & SRDS_PLLCR0_RFCK_SEL_MASK; - if (expected != actual[i]) { - printf("Warning: SERDES%u expects reference clock" - " %sMHz, but actual is %sMHz\n", i + 1, - serdes_clock_to_string(expected), - serdes_clock_to_string(actual[i])); - } - } - - return 0; -} - -void ft_board_setup(void *blob, bd_t *bd) -{ - phys_addr_t base; - phys_size_t size; - - ft_cpu_setup(blob, bd); - - base = getenv_bootm_low(); - size = getenv_bootm_size(); - - fdt_fixup_memory(blob, (u64)base, (u64)size); - -#ifdef CONFIG_PCI - pci_of_setup(blob, bd); -#endif - - fdt_fixup_liodn(blob); - fdt_fixup_dr_usb(blob, bd); - -#ifdef CONFIG_SYS_DPAA_FMAN - fdt_fixup_fman_ethernet(blob); - fdt_fixup_board_enet(blob); -#endif -} - -/* - * This function is called by bdinfo to print detail board information. - * As an exmaple for future board, we organize the messages into - * several sections. If applicable, the message is in the format of - * <name> = <value> - * It should aligned with normal output of bdinfo command. - * - * Voltage: Core, DDR and another configurable voltages - * Clock : Critical clocks which are not printed already - * RCW : RCW source if not printed already - * Misc : Other important information not in above catagories - */ -void board_detail(void) -{ - int i; - u8 brdcfg[16], dutcfg[16], rst_ctl; - int vdd, rcwsrc; - static const char * const clk[] = {"66.67", "100", "125", "133.33"}; - - for (i = 0; i < 16; i++) { - brdcfg[i] = qixis_read(offsetof(struct qixis, brdcfg[0]) + i); - dutcfg[i] = qixis_read(offsetof(struct qixis, dutcfg[0]) + i); - } - - /* Voltage secion */ - if (!select_i2c_ch_pca9547(I2C_MUX_CH_VOL_MONITOR)) { - vdd = read_voltage(); - if (vdd > 0) - printf("Core voltage= %d mV\n", vdd); - select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); - } - - printf("XVDD = 1.%d V\n", ((brdcfg[8] & 0xf) - 4) * 5 + 25); - - /* clock section */ - printf("SYSCLK = %s MHz\nDDRCLK = %s MHz\n", - clk[(brdcfg[11] >> 2) & 0x3], clk[brdcfg[11] & 3]); - - /* RCW section */ - rcwsrc = (dutcfg[0] << 1) + (dutcfg[1] & 1); - puts("RCW source = "); - switch (rcwsrc) { - case 0x017: - case 0x01f: - puts("8-bit NOR\n"); - break; - case 0x027: - case 0x02F: - puts("16-bit NOR\n"); - break; - case 0x040: - puts("SDHC/eMMC\n"); - break; - case 0x044: - puts("SPI 16-bit addressing\n"); - break; - case 0x045: - puts("SPI 24-bit addressing\n"); - break; - case 0x048: - puts("I2C normal addressing\n"); - break; - case 0x049: - puts("I2C extended addressing\n"); - break; - case 0x108: - case 0x109: - case 0x10a: - case 0x10b: - puts("8-bit NAND, 2KB\n"); - break; - default: - if ((rcwsrc >= 0x080) && (rcwsrc <= 0x09f)) - puts("Hard-coded RCW\n"); - else if ((rcwsrc >= 0x110) && (rcwsrc <= 0x11f)) - puts("8-bit NAND, 4KB\n"); - else - puts("unknown\n"); - break; - } - - /* Misc section */ - rst_ctl = QIXIS_READ(rst_ctl); - puts("HRESET_REQ = "); - switch (rst_ctl & 0x30) { - case 0x00: - puts("Ignored\n"); - break; - case 0x10: - puts("Assert HRESET\n"); - break; - case 0x30: - puts("Reset system\n"); - break; - default: - puts("N/A\n"); - break; - } -} - -/* - * Reverse engineering switch settings. - * Some bits cannot be figured out. They will be displayed as - * underscore in binary format. mask[] has those bits. - * Some bits are calculated differently than the actual switches - * if booting with overriding by FPGA. - */ -void qixis_dump_switch(void) -{ - int i; - u8 sw[9]; - - /* - * Any bit with 1 means that bit cannot be reverse engineered. - * It will be displayed as _ in binary format. - */ - static const u8 mask[] = {0, 0, 0, 0, 0, 0x1, 0xcf, 0x3f, 0x1f}; - char buf[10]; - u8 brdcfg[16], dutcfg[16]; - - for (i = 0; i < 16; i++) { - brdcfg[i] = qixis_read(offsetof(struct qixis, brdcfg[0]) + i); - dutcfg[i] = qixis_read(offsetof(struct qixis, dutcfg[0]) + i); - } - - sw[0] = dutcfg[0]; - sw[1] = (dutcfg[1] << 0x07) | \ - ((dutcfg[12] & 0xC0) >> 1) | \ - ((dutcfg[11] & 0xE0) >> 3) | \ - ((dutcfg[6] & 0x80) >> 6) | \ - ((dutcfg[1] & 0x80) >> 7); - sw[2] = ((brdcfg[1] & 0x0f) << 4) | \ - ((brdcfg[1] & 0x30) >> 2) | \ - ((brdcfg[1] & 0x40) >> 5) | \ - ((brdcfg[1] & 0x80) >> 7); - sw[3] = brdcfg[2]; - sw[4] = ((dutcfg[2] & 0x01) << 7) | \ - ((dutcfg[2] & 0x06) << 4) | \ - ((~QIXIS_READ(present)) & 0x10) | \ - ((brdcfg[3] & 0x80) >> 4) | \ - ((brdcfg[3] & 0x01) << 2) | \ - ((brdcfg[6] == 0x62) ? 3 : \ - ((brdcfg[6] == 0x5a) ? 2 : \ - ((brdcfg[6] == 0x5e) ? 1 : 0))); - sw[5] = ((brdcfg[0] & 0x0f) << 4) | \ - ((QIXIS_READ(rst_ctl) & 0x30) >> 2) | \ - ((brdcfg[0] & 0x40) >> 5); - sw[6] = (brdcfg[11] & 0x20) | - ((brdcfg[5] & 0x02) << 3); - sw[7] = (((~QIXIS_READ(rst_ctl)) & 0x40) << 1) | \ - ((brdcfg[5] & 0x10) << 2); - sw[8] = ((brdcfg[12] & 0x08) << 4) | \ - ((brdcfg[12] & 0x03) << 5); - - puts("DIP switch (reverse-engineering)\n"); - for (i = 0; i < 9; i++) { - printf("SW%d = 0b%s (0x%02x)\n", - i + 1, byte_to_binary_mask(sw[i], mask[i], buf), sw[i]); - } -} - -static int do_vdd_adjust(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - ulong override; - - if (argc < 2) - return CMD_RET_USAGE; - if (!strict_strtoul(argv[1], 10, &override)) - adjust_vdd(override); /* the value is checked by callee */ - else - return CMD_RET_USAGE; - - return 0; -} - -U_BOOT_CMD( - vdd_override, 2, 0, do_vdd_adjust, - "Override VDD", - "- override with the voltage specified in mV, eg. 1050" -); diff --git a/board/freescale/t4qds/tlb.c b/board/freescale/t4qds/tlb.c index 92c01cf..08bf1f0 100644 --- a/board/freescale/t4qds/tlb.c +++ b/board/freescale/t4qds/tlb.c @@ -127,10 +127,11 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 16, BOOKE_PAGESZ_64K, 1), #endif +#ifdef QIXIS_BASE_PHYS SET_TLB_ENTRY(1, QIXIS_BASE, QIXIS_BASE_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 17, BOOKE_PAGESZ_4K, 1), - +#endif };
int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/boards.cfg b/boards.cfg index 1e598cb..6a1d56b 100644 --- a/boards.cfg +++ b/boards.cfg @@ -910,6 +910,7 @@ stxgp3 powerpc mpc85xx stxgp3 stx stxssa powerpc mpc85xx stxssa stx - stxssa stxssa_4M powerpc mpc85xx stxssa stx - stxssa:STXSSA_4M T4240QDS powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4240 +T4240EMU powerpc mpc85xx t4qds freescale - T4240EMU:PPC_T4240 T4240QDS_SDCARD powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4240,RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 T4240QDS_SPIFLASH powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4240,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 T4160QDS powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4160 diff --git a/include/configs/T4240EMU.h b/include/configs/T4240EMU.h new file mode 100644 index 0000000..399e878 --- /dev/null +++ b/include/configs/T4240EMU.h @@ -0,0 +1,185 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * T4240 EMU board configuration file + */ +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_T4240EMU +#define CONFIG_PHYS_64BIT + +#define CONFIG_SYS_NO_FLASH 1 +#define CONFIG_SYS_FSL_DDR_EMU 1 +#define CONFIG_SYS_FSL_NO_QIXIS 1 +#define CONFIG_SYS_FSL_NO_SERDES 1 + +#include "t4qds.h" + +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_CACHE_FLUSH + +#define CONFIG_ENV_IS_NOWHERE +#define CONFIG_ENV_SIZE 0x2000 + +#define CONFIG_SYS_CLK_FREQ 100000000 +#define CONFIG_DDR_CLK_FREQ 133333333 +#define CONFIG_FSL_TBCLK_EXTRA_DIV 100 + + +/* + * DDR Setup + */ +#define CONFIG_SYS_SPD_BUS_NUM 1 +#define SPD_EEPROM_ADDRESS1 0x51 +#define SPD_EEPROM_ADDRESS2 0x52 +#define SPD_EEPROM_ADDRESS3 0x53 +#define SPD_EEPROM_ADDRESS4 0x54 +#define SPD_EEPROM_ADDRESS5 0x55 +#define SPD_EEPROM_ADDRESS6 0x56 +#define SPD_EEPROM_ADDRESS SPD_EEPROM_ADDRESS1 /* for p3041/p5010 */ +#define CONFIG_SYS_SDRAM_SIZE 4096 /* for fixed parameter use */ + +/* + * IFC Definitions + */ +#define CONFIG_SYS_NOR0_CSPR_EXT (0xf) +#define CONFIG_SYS_NOR_AMASK IFC_AMASK(128*1024*1024) +/* NOR Flash Timing Params */ +#define CONFIG_SYS_NOR0_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS \ + + 0x8000000) | \ + CSPR_PORT_SIZE_32 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR_CSOR CSOR_NOR_ADM_SHIFT(0) +#define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x1) | \ + FTIM0_NOR_TEADC(0x1) | \ + FTIM0_NOR_TEAHC(0x1)) +#define CONFIG_SYS_NOR_FTIM1 (FTIM1_NOR_TACO(0x1) | \ + FTIM1_NOR_TRAD_NOR(0x1)) +#define CONFIG_SYS_NOR_FTIM2 (FTIM2_NOR_TCS(0x0) | \ + FTIM2_NOR_TCH(0x0) | \ + FTIM2_NOR_TWP(0x1)) +#define CONFIG_SYS_NOR_FTIM3 0x04000000 +#define CONFIG_SYS_IFC_CCR 0x01000000 + +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR0_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3 + + +/* I2C */ +#define CONFIG_SYS_I2C_SPEED 4000000 /* faster speed for emulator */ + + +/* Qman/Bman */ +#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ +#define CONFIG_SYS_BMAN_NUM_PORTALS 50 +#define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 +#define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull +#define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_QMAN_NUM_PORTALS 50 +#define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 +#define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull +#define CONFIG_SYS_QMAN_MEM_SIZE 0x02000000 + +#define CONFIG_SYS_DPAA_FMAN +#define CONFIG_SYS_DPAA_PME +#define CONFIG_SYS_PMAN +#define CONFIG_SYS_DPAA_DCE +#define CONFIG_SYS_INTERLAKEN + +#define CONFIG_SYS_QE_FMAN_FW_IN_NOR +#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF40000 +#define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 +#define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) + + + +#define CONFIG_BOOTDELAY 0 + +/* + * T4240 has 3 DDR controllers. Default to 3-way interleaving. It can be + * 3way_1KB, 3way_4KB, 3way_8KB. T4160 has 2 DDR controllers. Default to 2-way + * interleaving. It can be cacheline, page, bank, superbank. + * See doc/README.fsl-ddr for details. + */ +#ifdef CONFIG_PPC_T4240 +#define CTRL_INTLV_PREFERED 3way_4KB +#else +#define CTRL_INTLV_PREFERED cacheline +#endif + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:" \ + "ctlr_intlv=" __stringify(CTRL_INTLV_PREFERED) "," \ + "bank_intlv=auto;" \ + "netdev=eth0\0" \ + "uboot=" __stringify(CONFIG_UBOOTPATH) "\0" \ + "ubootaddr=" __stringify(CONFIG_SYS_TEXT_BASE) "\0" \ + "consoledev=ttyS0\0" \ + "ramdiskaddr=2000000\0" \ + "ramdiskfile=t4240emu/ramdisk.uboot\0" \ + "fdtaddr=c00000\0" \ + "fdtfile=t4240emu/t4240emu.dtb\0" \ + "bdev=sda3\0" \ + "c=ffe\0" + +/* + * For emulation this causes u-boot to jump to the start of the proof point + * app code automatically + */ +#define CONFIG_PROOF_POINTS \ + "setenv bootargs root=/dev/$bdev rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "cpu 1 release 0x29000000 - - -;" \ + "cpu 2 release 0x29000000 - - -;" \ + "cpu 3 release 0x29000000 - - -;" \ + "cpu 4 release 0x29000000 - - -;" \ + "cpu 5 release 0x29000000 - - -;" \ + "cpu 6 release 0x29000000 - - -;" \ + "cpu 7 release 0x29000000 - - -;" \ + "go 0x29000000" + +#define CONFIG_HVBOOT \ + "setenv bootargs config-addr=0x60000000; " \ + "bootm 0x01000000 - 0x00f00000" + +#define CONFIG_LINUX \ + "errata;" \ + "setenv othbootargs ignore_loglevel;" \ + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "setenv ramdiskaddr 0x02000000;" \ + "setenv fdtaddr 0x00c00000;" \ + "setenv loadaddr 0x1000000;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr" + +#define CONFIG_BOOTCOMMAND CONFIG_LINUX + +#endif /* __CONFIG_H */ diff --git a/include/configs/T4240QDS.h b/include/configs/T4240QDS.h index 6dd5c0d..6294f2b 100644 --- a/include/configs/T4240QDS.h +++ b/include/configs/T4240QDS.h @@ -23,6 +23,9 @@ /* * T4240 QDS board configuration file */ +#ifndef __CONFIG_H +#define __CONFIG_H + #define CONFIG_T4240QDS #define CONFIG_PHYS_64BIT
@@ -31,4 +34,540 @@
#define CONFIG_ICS307_REFCLK_HZ 25000000 /* ICS307 ref clk freq */
+#ifdef CONFIG_RAMBOOT_PBL +#define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE +#define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc +#define CONFIG_PBLPBI_CONFIG $(SRCTREE)/board/freescale/t4qds/t4_pbi.cfg +#define CONFIG_PBLRCW_CONFIG $(SRCTREE)/board/freescale/t4qds/t4_rcw.cfg +#endif + +#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE +/* Set 1M boot space */ +#define CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR (CONFIG_SYS_TEXT_BASE & 0xfff00000) +#define CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR_PHYS \ + (0x300000000ull | CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR) +#define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc +#define CONFIG_SYS_NO_FLASH +#endif + +#define CONFIG_SRIO_PCIE_BOOT_MASTER +#define CONFIG_DDR_ECC + #include "t4qds.h" + +#ifdef CONFIG_SYS_NO_FLASH +#if !defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) && !defined(CONFIG_RAMBOOT_PBL) +#define CONFIG_ENV_IS_NOWHERE +#endif +#else +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE +#endif + +#if defined(CONFIG_SPIFLASH) +#define CONFIG_SYS_EXTRA_ENV_RELOC +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SPI_BUS 0 +#define CONFIG_ENV_SPI_CS 0 +#define CONFIG_ENV_SPI_MAX_HZ 10000000 +#define CONFIG_ENV_SPI_MODE 0 +#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ +#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ +#define CONFIG_ENV_SECT_SIZE 0x10000 +#elif defined(CONFIG_SDCARD) +#define CONFIG_SYS_EXTRA_ENV_RELOC +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_OFFSET (512 * 1097) +#elif defined(CONFIG_NAND) +#define CONFIG_SYS_EXTRA_ENV_RELOC +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE +#define CONFIG_ENV_OFFSET (5 * CONFIG_SYS_NAND_BLOCK_SIZE) +#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) +#define CONFIG_ENV_IS_IN_REMOTE +#define CONFIG_ENV_ADDR 0xffe20000 +#define CONFIG_ENV_SIZE 0x2000 +#elif defined(CONFIG_ENV_IS_NOWHERE) +#define CONFIG_ENV_SIZE 0x2000 +#else +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ +#endif + +#define CONFIG_SYS_CLK_FREQ get_board_sys_clk() +#define CONFIG_DDR_CLK_FREQ get_board_ddr_clk() + +#ifndef __ASSEMBLY__ +unsigned long get_board_sys_clk(void); +unsigned long get_board_ddr_clk(void); +#endif + +/* EEPROM */ +#define CONFIG_ID_EEPROM +#define CONFIG_SYS_I2C_EEPROM_NXID +#define CONFIG_SYS_EEPROM_BUS_NUM 0 +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x57 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 + +/* + * DDR Setup + */ +#define CONFIG_SYS_SPD_BUS_NUM 0 +#define SPD_EEPROM_ADDRESS1 0x51 +#define SPD_EEPROM_ADDRESS2 0x52 +#define SPD_EEPROM_ADDRESS3 0x53 +#define SPD_EEPROM_ADDRESS4 0x54 +#define SPD_EEPROM_ADDRESS5 0x55 +#define SPD_EEPROM_ADDRESS6 0x56 +#define SPD_EEPROM_ADDRESS SPD_EEPROM_ADDRESS1 /* for p3041/p5010 */ +#define CONFIG_SYS_SDRAM_SIZE 4096 /* for fixed parameter use */ + +/* + * IFC Definitions + */ +#define CONFIG_SYS_NOR0_CSPR_EXT (0xf) +#define CONFIG_SYS_NOR0_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS \ + + 0x8000000) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR1_CSPR_EXT (0xf) +#define CONFIG_SYS_NOR1_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR_AMASK IFC_AMASK(128*1024*1024) +/* NOR Flash Timing Params */ +#define CONFIG_SYS_NOR_CSOR CSOR_NAND_TRHZ_80 + +#define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x4) | \ + FTIM0_NOR_TEADC(0x5) | \ + FTIM0_NOR_TEAHC(0x5)) +#define CONFIG_SYS_NOR_FTIM1 (FTIM1_NOR_TACO(0x35) | \ + FTIM1_NOR_TRAD_NOR(0x1A) |\ + FTIM1_NOR_TSEQRAD_NOR(0x13)) +#define CONFIG_SYS_NOR_FTIM2 (FTIM2_NOR_TCS(0x4) | \ + FTIM2_NOR_TCH(0x4) | \ + FTIM2_NOR_TWPH(0x0E) | \ + FTIM2_NOR_TWP(0x1c)) +#define CONFIG_SYS_NOR_FTIM3 0x0 + +#define CONFIG_SYS_FLASH_QUIET_TEST +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ + +#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ + +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS \ + + 0x8000000, CONFIG_SYS_FLASH_BASE_PHYS} + +#define CONFIG_FSL_QIXIS /* use common QIXIS code */ +#define QIXIS_BASE 0xffdf0000 +#define QIXIS_LBMAP_SWITCH 6 +#define QIXIS_LBMAP_MASK 0x0f +#define QIXIS_LBMAP_SHIFT 0 +#define QIXIS_LBMAP_DFLTBANK 0x00 +#define QIXIS_LBMAP_ALTBANK 0x04 +#define QIXIS_RST_CTL_RESET 0x83 +#define QIXIS_RCFG_CTL_RECONFIG_IDLE 0x20 +#define QIXIS_RCFG_CTL_RECONFIG_START 0x21 +#define QIXIS_RCFG_CTL_WATCHDOG_ENBLE 0x08 +#define QIXIS_BASE_PHYS (0xf00000000ull | QIXIS_BASE) + +#define CONFIG_SYS_CSPR3_EXT (0xf) +#define CONFIG_SYS_CSPR3 (CSPR_PHYS_ADDR(QIXIS_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 \ + | CSPR_MSEL_GPCM \ + | CSPR_V) +#define CONFIG_SYS_AMASK3 IFC_AMASK(4*1024) +#define CONFIG_SYS_CSOR3 0x0 +/* QIXIS Timing parameters for IFC CS3 */ +#define CONFIG_SYS_CS3_FTIM0 (FTIM0_GPCM_TACSE(0x0e) | \ + FTIM0_GPCM_TEADC(0x0e) | \ + FTIM0_GPCM_TEAHC(0x0e)) +#define CONFIG_SYS_CS3_FTIM1 (FTIM1_GPCM_TACO(0xff) | \ + FTIM1_GPCM_TRAD(0x3f)) +#define CONFIG_SYS_CS3_FTIM2 (FTIM2_GPCM_TCS(0x0e) | \ + FTIM2_GPCM_TCH(0x0) | \ + FTIM2_GPCM_TWP(0x1f)) +#define CONFIG_SYS_CS3_FTIM3 0x0 + +/* NAND Flash on IFC */ +#define CONFIG_NAND_FSL_IFC +#define CONFIG_SYS_NAND_BASE 0xff800000 +#define CONFIG_SYS_NAND_BASE_PHYS (0xf00000000ull | CONFIG_SYS_NAND_BASE) + +#define CONFIG_SYS_NAND_CSPR_EXT (0xf) +#define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 /* Port Size = 8 bit */ \ + | CSPR_MSEL_NAND /* MSEL = NAND */ \ + | CSPR_V) +#define CONFIG_SYS_NAND_AMASK IFC_AMASK(64*1024) + +#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ + | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ + | CSOR_NAND_ECC_MODE_4 /* 4-bit ECC */ \ + | CSOR_NAND_RAL_3 /* RAL = 2Byes */ \ + | CSOR_NAND_PGS_2K /* Page Size = 2K */ \ + | CSOR_NAND_SPRZ_64/* Spare size = 64 */ \ + | CSOR_NAND_PB(64)) /*Pages Per Block = 64*/ + +#define CONFIG_SYS_NAND_ONFI_DETECTION + +/* ONFI NAND Flash mode0 Timing Params */ +#define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x07) | \ + FTIM0_NAND_TWP(0x18) | \ + FTIM0_NAND_TWCHT(0x07) | \ + FTIM0_NAND_TWH(0x0a)) +#define CONFIG_SYS_NAND_FTIM1 (FTIM1_NAND_TADLE(0x32) | \ + FTIM1_NAND_TWBE(0x39) | \ + FTIM1_NAND_TRR(0x0e) | \ + FTIM1_NAND_TRP(0x18)) +#define CONFIG_SYS_NAND_FTIM2 (FTIM2_NAND_TRAD(0x0f) | \ + FTIM2_NAND_TREH(0x0a) | \ + FTIM2_NAND_TWHRE(0x1e)) +#define CONFIG_SYS_NAND_FTIM3 0x0 + +#define CONFIG_SYS_NAND_DDR_LAW 11 + +#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_MTD_NAND_VERIFY_WRITE +#define CONFIG_CMD_NAND + +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) + +#if defined(CONFIG_NAND) +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3 +#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR2 CONFIG_SYS_NOR0_CSPR +#define CONFIG_SYS_AMASK2 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR2 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NOR_FTIM3 +#else +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR0_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3 +#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR2 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK2 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR2 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NAND_FTIM3 +#endif +#define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NOR1_CSPR_EXT +#define CONFIG_SYS_CSPR1 CONFIG_SYS_NOR1_CSPR +#define CONFIG_SYS_AMASK1 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR1 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS1_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NOR_FTIM3 + +#if defined(CONFIG_RAMBOOT_PBL) +#define CONFIG_SYS_RAMBOOT +#endif + + +/* I2C */ +#define CONFIG_SYS_I2C_SPEED 100000 /* I2C speed */ +#define I2C_MUX_PCA_ADDR_PRI 0x77 /* I2C bus multiplexer,primary */ +#define I2C_MUX_PCA_ADDR_SEC 0x76 /* I2C bus multiplexer,secondary */ + +#define I2C_MUX_CH_DEFAULT 0x8 +#define I2C_MUX_CH_VOL_MONITOR 0xa +#define I2C_MUX_CH_VSC3316_FS 0xc +#define I2C_MUX_CH_VSC3316_BS 0xd + +/* Voltage monitor on channel 2*/ +#define I2C_VOL_MONITOR_ADDR 0x40 +#define I2C_VOL_MONITOR_BUS_V_OFFSET 0x2 +#define I2C_VOL_MONITOR_BUS_V_OVF 0x1 +#define I2C_VOL_MONITOR_BUS_V_SHIFT 3 + +/* VSC Crossbar switches */ +#define CONFIG_VSC_CROSSBAR +#define VSC3316_FSM_TX_ADDR 0x70 +#define VSC3316_FSM_RX_ADDR 0x71 + +/* + * RapidIO + */ + +/* + * for slave u-boot IMAGE instored in master memory space, + * PHYS must be aligned based on the SIZE + */ +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_PHYS 0xfef080000ull +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS1 0xfff80000ull +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_SIZE 0x80000 /* 512K */ +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS2 0x3fff80000ull +/* + * for slave UCODE and ENV instored in master memory space, + * PHYS must be aligned based on the SIZE + */ +#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_PHYS 0xfef040000ull +#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_BUS 0x3ffe00000ull +#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_SIZE 0x40000 /* 256K */ + +/* slave core release by master*/ +#define CONFIG_SRIO_PCIE_BOOT_BRR_OFFSET 0xe00e4 +#define CONFIG_SRIO_PCIE_BOOT_RELEASE_MASK 0x00000001 /* release core 0 */ + +/* + * SRIO_PCIE_BOOT - SLAVE + */ +#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE +#define CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR 0xFFE00000 +#define CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR_PHYS \ + (0x300000000ull | CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR) +#endif +/* + * eSPI - Enhanced SPI + */ +#define CONFIG_FSL_ESPI +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_SST +#define CONFIG_CMD_SF +#define CONFIG_SF_DEFAULT_SPEED 10000000 +#define CONFIG_SF_DEFAULT_MODE 0 + + +/* Qman/Bman */ +#ifndef CONFIG_NOBQFMAN +#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ +#define CONFIG_SYS_BMAN_NUM_PORTALS 50 +#define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 +#define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull +#define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_QMAN_NUM_PORTALS 50 +#define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 +#define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull +#define CONFIG_SYS_QMAN_MEM_SIZE 0x02000000 + +#define CONFIG_SYS_DPAA_FMAN +#define CONFIG_SYS_DPAA_PME +#define CONFIG_SYS_PMAN +#define CONFIG_SYS_DPAA_DCE +#define CONFIG_SYS_INTERLAKEN + +/* Default address of microcode for the Linux Fman driver */ +#if defined(CONFIG_SPIFLASH) +/* + * env is stored at 0x100000, sector size is 0x10000, ucode is stored after + * env, so we got 0x110000. + */ +#define CONFIG_SYS_QE_FW_IN_SPIFLASH +#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 +#elif defined(CONFIG_SDCARD) +/* + * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is + * about 545KB (1089 blocks), Env is stored after the image, and the env size is + * 0x2000 (16 blocks), 8 + 1089 + 16 = 1113, enlarge it to 1130. + */ +#define CONFIG_SYS_QE_FMAN_FW_IN_MMC +#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1130) +#elif defined(CONFIG_NAND) +#define CONFIG_SYS_QE_FMAN_FW_IN_NAND +#define CONFIG_SYS_QE_FMAN_FW_ADDR (6 * CONFIG_SYS_NAND_BLOCK_SIZE) +#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) +/* + * Slave has no ucode locally, it can fetch this from remote. When implementing + * in two corenet boards, slave's ucode could be stored in master's memory + * space, the address can be mapped from slave TLB->slave LAW-> + * slave SRIO or PCIE outbound window->master inbound window-> + * master LAW->the ucode address in master's memory space. + */ +#define CONFIG_SYS_QE_FMAN_FW_IN_REMOTE +#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xFFE00000 +#else +#define CONFIG_SYS_QE_FMAN_FW_IN_NOR +#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF40000 +#endif +#define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 +#define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) +#endif /* CONFIG_NOBQFMAN */ + +#ifdef CONFIG_SYS_DPAA_FMAN +#define CONFIG_FMAN_ENET +#define CONFIG_PHYLIB_10G +#define CONFIG_PHY_VITESSE +#define CONFIG_PHY_TERANETICS +#define SGMII_CARD_PORT1_PHY_ADDR 0x1C +#define SGMII_CARD_PORT2_PHY_ADDR 0x1D +#define SGMII_CARD_PORT3_PHY_ADDR 0x1E +#define SGMII_CARD_PORT4_PHY_ADDR 0x1F +#define FM1_10GEC1_PHY_ADDR 0x0 +#define FM1_10GEC2_PHY_ADDR 0x1 +#define FM2_10GEC1_PHY_ADDR 0x2 +#define FM2_10GEC2_PHY_ADDR 0x3 +#endif + + +/* SATA */ +#ifdef CONFIG_FSL_SATA_V2 +#define CONFIG_LIBATA +#define CONFIG_FSL_SATA + +#define CONFIG_SYS_SATA_MAX_DEVICE 2 +#define CONFIG_SATA1 +#define CONFIG_SYS_SATA1 CONFIG_SYS_MPC85xx_SATA1_ADDR +#define CONFIG_SYS_SATA1_FLAGS FLAGS_DMA +#define CONFIG_SATA2 +#define CONFIG_SYS_SATA2 CONFIG_SYS_MPC85xx_SATA2_ADDR +#define CONFIG_SYS_SATA2_FLAGS FLAGS_DMA + +#define CONFIG_LBA48 +#define CONFIG_CMD_SATA +#define CONFIG_DOS_PARTITION +#define CONFIG_CMD_EXT2 +#endif + +#ifdef CONFIG_FMAN_ENET +#define CONFIG_MII /* MII PHY management */ +#define CONFIG_ETHPRIME "FM1@DTSEC1" +#define CONFIG_PHY_GIGE /* Include GbE speed/duplex detection */ +#endif + +/* +* USB +*/ +#define CONFIG_CMD_USB +#define CONFIG_USB_STORAGE +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_FSL +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET +#define CONFIG_CMD_EXT2 +#define CONFIG_HAS_FSL_DR_USB + +#define CONFIG_MMC + +#ifdef CONFIG_MMC +#define CONFIG_FSL_ESDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR +#define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION +#endif + +#define CONFIG_BOOTDELAY 10 /* -1 disables auto-boot */ + +#define __USB_PHY_TYPE utmi + +/* + * T4240 has 3 DDR controllers. Default to 3-way interleaving. It can be + * 3way_1KB, 3way_4KB, 3way_8KB. T4160 has 2 DDR controllers. Default to 2-way + * interleaving. It can be cacheline, page, bank, superbank. + * See doc/README.fsl-ddr for details. + */ +#ifdef CONFIG_PPC_T4240 +#define CTRL_INTLV_PREFERED 3way_4KB +#else +#define CTRL_INTLV_PREFERED cacheline +#endif + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:" \ + "ctlr_intlv=" __stringify(CTRL_INTLV_PREFERED) "," \ + "bank_intlv=auto;" \ + "usb1:dr_mode=host,phy_type=" __stringify(__USB_PHY_TYPE) "\0"\ + "netdev=eth0\0" \ + "uboot=" __stringify(CONFIG_UBOOTPATH) "\0" \ + "ubootaddr=" __stringify(CONFIG_SYS_TEXT_BASE) "\0" \ + "tftpflash=tftpboot $loadaddr $uboot && " \ + "protect off $ubootaddr +$filesize && " \ + "erase $ubootaddr +$filesize && " \ + "cp.b $loadaddr $ubootaddr $filesize && " \ + "protect on $ubootaddr +$filesize && " \ + "cmp.b $loadaddr $ubootaddr $filesize\0" \ + "consoledev=ttyS0\0" \ + "ramdiskaddr=2000000\0" \ + "ramdiskfile=t4240qds/ramdisk.uboot\0" \ + "fdtaddr=c00000\0" \ + "fdtfile=t4240qds/t4240qds.dtb\0" \ + "bdev=sda3\0" \ + "c=ffe\0" + +#define CONFIG_HVBOOT \ + "setenv bootargs config-addr=0x60000000; " \ + "bootm 0x01000000 - 0x00f00000" + +#define CONFIG_ALU \ + "setenv bootargs root=/dev/$bdev rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "cpu 1 release 0x01000000 - - -;" \ + "cpu 2 release 0x01000000 - - -;" \ + "cpu 3 release 0x01000000 - - -;" \ + "cpu 4 release 0x01000000 - - -;" \ + "cpu 5 release 0x01000000 - - -;" \ + "cpu 6 release 0x01000000 - - -;" \ + "cpu 7 release 0x01000000 - - -;" \ + "go 0x01000000" + +#define CONFIG_LINUX \ + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "setenv ramdiskaddr 0x02000000;" \ + "setenv fdtaddr 0x00c00000;" \ + "setenv loadaddr 0x1000000;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr" + +#define CONFIG_HDBOOT \ + "setenv bootargs root=/dev/$bdev rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr - $fdtaddr" + +#define CONFIG_NFSBOOTCOMMAND \ + "setenv bootargs root=/dev/nfs rw " \ + "nfsroot=$serverip:$rootpath " \ + "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr - $fdtaddr" + +#define CONFIG_RAMBOOTCOMMAND \ + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $ramdiskaddr $ramdiskfile;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr" + +#define CONFIG_BOOTCOMMAND CONFIG_LINUX + +#ifdef CONFIG_SECURE_BOOT +#include <asm/fsl_secure_boot.h> +#endif + +#endif /* __CONFIG_H */ diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h index 3f7b82d..c3fa3b7 100644 --- a/include/configs/t4qds.h +++ b/include/configs/t4qds.h @@ -23,15 +23,8 @@ /* * Corenet DS style board configuration file */ -#ifndef __CONFIG_H -#define __CONFIG_H - -#ifdef CONFIG_RAMBOOT_PBL -#define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc -#define CONFIG_PBLPBI_CONFIG $(SRCTREE)/board/freescale/t4qds/t4_pbi.cfg -#define CONFIG_PBLRCW_CONFIG $(SRCTREE)/board/freescale/t4qds/t4_rcw.cfg -#endif +#ifndef __T4QDS_H +#define __T4QDS_H
#define CONFIG_CMD_REGINFO
@@ -69,63 +62,12 @@
#define CONFIG_ENV_OVERWRITE
-#ifdef CONFIG_SYS_NO_FLASH -#define CONFIG_ENV_IS_NOWHERE -#else -#define CONFIG_FLASH_CFI_DRIVER -#define CONFIG_SYS_FLASH_CFI -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE -#endif - -#ifndef CONFIG_SYS_NO_FLASH -#if defined(CONFIG_SPIFLASH) -#define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 10000000 -#define CONFIG_ENV_SPI_MODE 0 -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ -#define CONFIG_ENV_SECT_SIZE 0x10000 -#elif defined(CONFIG_SDCARD) -#define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_MMC -#define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET (512 * 1097) -#elif defined(CONFIG_NAND) -#define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_NAND -#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE -#define CONFIG_ENV_OFFSET (5 * CONFIG_SYS_NAND_BLOCK_SIZE) -#else -#define CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ -#endif -#else /* CONFIG_SYS_NO_FLASH */ -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ -#endif - - - -#define CONFIG_SYS_CLK_FREQ get_board_sys_clk() -#define CONFIG_DDR_CLK_FREQ get_board_ddr_clk() - -#ifndef __ASSEMBLY__ -unsigned long get_board_sys_clk(void); -unsigned long get_board_ddr_clk(void); -#endif
/* * These can be toggled for performance analysis, otherwise use default. */ #define CONFIG_SYS_CACHE_STASHING #define CONFIG_BTB /* toggle branch predition */ -#define CONFIG_DDR_ECC #ifdef CONFIG_DDR_ECC #define CONFIG_ECC_INIT_VIA_DDRCONTROLLER #define CONFIG_MEM_INIT_VALUE 0xdeadbeef @@ -149,13 +91,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_DCSRBAR 0xf0000000 #define CONFIG_SYS_DCSRBAR_PHYS 0xf00000000ull
-/* EEPROM */ -#define CONFIG_ID_EEPROM -#define CONFIG_SYS_I2C_EEPROM_NXID -#define CONFIG_SYS_EEPROM_BUS_NUM 0 -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x57 -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 - /* * DDR Setup */ @@ -171,15 +106,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_DDR_SPD #define CONFIG_FSL_DDR3
-#define CONFIG_SYS_SPD_BUS_NUM 0 -#define SPD_EEPROM_ADDRESS1 0x51 -#define SPD_EEPROM_ADDRESS2 0x52 -#define SPD_EEPROM_ADDRESS3 0x53 -#define SPD_EEPROM_ADDRESS4 0x54 -#define SPD_EEPROM_ADDRESS5 0x55 -#define SPD_EEPROM_ADDRESS6 0x56 -#define SPD_EEPROM_ADDRESS SPD_EEPROM_ADDRESS1 /* for p3041/p5010 */ -#define CONFIG_SYS_SDRAM_SIZE 4096 /* for fixed parameter use */
/* * IFC Definitions @@ -187,171 +113,9 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_FLASH_BASE 0xe0000000 #define CONFIG_SYS_FLASH_BASE_PHYS (0xf00000000ull | CONFIG_SYS_FLASH_BASE)
-#define CONFIG_SYS_NOR0_CSPR_EXT (0xf) -#define CONFIG_SYS_NOR0_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS \ - + 0x8000000) | \ - CSPR_PORT_SIZE_16 | \ - CSPR_MSEL_NOR | \ - CSPR_V) -#define CONFIG_SYS_NOR1_CSPR_EXT (0xf) -#define CONFIG_SYS_NOR1_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | \ - CSPR_PORT_SIZE_16 | \ - CSPR_MSEL_NOR | \ - CSPR_V) -#define CONFIG_SYS_NOR_AMASK IFC_AMASK(128*1024*1024) -/* NOR Flash Timing Params */ -#define CONFIG_SYS_NOR_CSOR CSOR_NAND_TRHZ_80 - -#define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x4) | \ - FTIM0_NOR_TEADC(0x5) | \ - FTIM0_NOR_TEAHC(0x5)) -#define CONFIG_SYS_NOR_FTIM1 (FTIM1_NOR_TACO(0x35) | \ - FTIM1_NOR_TRAD_NOR(0x1A) |\ - FTIM1_NOR_TSEQRAD_NOR(0x13)) -#define CONFIG_SYS_NOR_FTIM2 (FTIM2_NOR_TCS(0x4) | \ - FTIM2_NOR_TCH(0x4) | \ - FTIM2_NOR_TWPH(0x0E) | \ - FTIM2_NOR_TWP(0x1c)) -#define CONFIG_SYS_NOR_FTIM3 0x0 - -#define CONFIG_SYS_FLASH_QUIET_TEST -#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ - -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* number of banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ -#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ - -#define CONFIG_SYS_FLASH_EMPTY_INFO -#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS \ - + 0x8000000, CONFIG_SYS_FLASH_BASE_PHYS} - -#define CONFIG_FSL_QIXIS /* use common QIXIS code */ -#define QIXIS_BASE 0xffdf0000 -#define QIXIS_LBMAP_SWITCH 6 -#define QIXIS_LBMAP_MASK 0x0f -#define QIXIS_LBMAP_SHIFT 0 -#define QIXIS_LBMAP_DFLTBANK 0x00 -#define QIXIS_LBMAP_ALTBANK 0x04 -#define QIXIS_RST_CTL_RESET 0x83 -#define QIXIS_RCFG_CTL_RECONFIG_IDLE 0x20 -#define QIXIS_RCFG_CTL_RECONFIG_START 0x21 -#define QIXIS_RCFG_CTL_WATCHDOG_ENBLE 0x08 -#define QIXIS_BASE_PHYS (0xf00000000ull | QIXIS_BASE) - -#define CONFIG_SYS_CSPR3_EXT (0xf) -#define CONFIG_SYS_CSPR3 (CSPR_PHYS_ADDR(QIXIS_BASE_PHYS) \ - | CSPR_PORT_SIZE_8 \ - | CSPR_MSEL_GPCM \ - | CSPR_V) -#define CONFIG_SYS_AMASK3 IFC_AMASK(4 * 1024) -#define CONFIG_SYS_CSOR3 0x0 -/* QIXIS Timing parameters for IFC CS3 */ -#define CONFIG_SYS_CS3_FTIM0 (FTIM0_GPCM_TACSE(0x0e) | \ - FTIM0_GPCM_TEADC(0x0e) | \ - FTIM0_GPCM_TEAHC(0x0e)) -#define CONFIG_SYS_CS3_FTIM1 (FTIM1_GPCM_TACO(0xff) | \ - FTIM1_GPCM_TRAD(0x3f)) -#define CONFIG_SYS_CS3_FTIM2 (FTIM2_GPCM_TCS(0x0e) | \ - FTIM2_GPCM_TCH(0x0) | \ - FTIM2_GPCM_TWP(0x1f)) -#define CONFIG_SYS_CS3_FTIM3 0x0 - -/* NAND Flash on IFC */ -#define CONFIG_NAND_FSL_IFC -#define CONFIG_SYS_NAND_BASE 0xff800000 -#define CONFIG_SYS_NAND_BASE_PHYS (0xf00000000ull | CONFIG_SYS_NAND_BASE) - -#define CONFIG_SYS_NAND_CSPR_EXT (0xf) -#define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ - | CSPR_PORT_SIZE_8 /* Port Size = 8 bit */ \ - | CSPR_MSEL_NAND /* MSEL = NAND */ \ - | CSPR_V) -#define CONFIG_SYS_NAND_AMASK IFC_AMASK(64*1024) - -#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ - | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ - | CSOR_NAND_ECC_MODE_4 /* 4-bit ECC */ \ - | CSOR_NAND_RAL_3 /* RAL = 2Byes */ \ - | CSOR_NAND_PGS_2K /* Page Size = 2K */ \ - | CSOR_NAND_SPRZ_64/* Spare size = 64 */ \ - | CSOR_NAND_PB(64)) /*Pages Per Block = 64*/ - -#define CONFIG_SYS_NAND_ONFI_DETECTION - -/* ONFI NAND Flash mode0 Timing Params */ -#define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x07) | \ - FTIM0_NAND_TWP(0x18) | \ - FTIM0_NAND_TWCHT(0x07) | \ - FTIM0_NAND_TWH(0x0a)) -#define CONFIG_SYS_NAND_FTIM1 (FTIM1_NAND_TADLE(0x32) | \ - FTIM1_NAND_TWBE(0x39) | \ - FTIM1_NAND_TRR(0x0e) | \ - FTIM1_NAND_TRP(0x18)) -#define CONFIG_SYS_NAND_FTIM2 (FTIM2_NAND_TRAD(0x0f) | \ - FTIM2_NAND_TREH(0x0a) | \ - FTIM2_NAND_TWHRE(0x1e)) -#define CONFIG_SYS_NAND_FTIM3 0x0 - -#define CONFIG_SYS_NAND_DDR_LAW 11 - -#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } -#define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_MTD_NAND_VERIFY_WRITE -#define CONFIG_CMD_NAND - -#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) - -#if defined(CONFIG_NAND) -#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT -#define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR -#define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK -#define CONFIG_SYS_CSOR0 CONFIG_SYS_NAND_CSOR -#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NAND_FTIM0 -#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NAND_FTIM1 -#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 -#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3 -#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_NOR0_CSPR_EXT -#define CONFIG_SYS_CSPR2 CONFIG_SYS_NOR0_CSPR -#define CONFIG_SYS_AMASK2 CONFIG_SYS_NOR_AMASK -#define CONFIG_SYS_CSOR2 CONFIG_SYS_NOR_CSOR -#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_NOR_FTIM0 -#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NOR_FTIM1 -#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NOR_FTIM2 -#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NOR_FTIM3 -#else -#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT -#define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR0_CSPR -#define CONFIG_SYS_AMASK0 CONFIG_SYS_NOR_AMASK -#define CONFIG_SYS_CSOR0 CONFIG_SYS_NOR_CSOR -#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NOR_FTIM0 -#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NOR_FTIM1 -#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NOR_FTIM2 -#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3 -#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_NAND_CSPR_EXT -#define CONFIG_SYS_CSPR2 CONFIG_SYS_NAND_CSPR -#define CONFIG_SYS_AMASK2 CONFIG_SYS_NAND_AMASK -#define CONFIG_SYS_CSOR2 CONFIG_SYS_NAND_CSOR -#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_NAND_FTIM0 -#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NAND_FTIM1 -#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NAND_FTIM2 -#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NAND_FTIM3 -#endif -#define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NOR1_CSPR_EXT -#define CONFIG_SYS_CSPR1 CONFIG_SYS_NOR1_CSPR -#define CONFIG_SYS_AMASK1 CONFIG_SYS_NOR_AMASK -#define CONFIG_SYS_CSOR1 CONFIG_SYS_NOR_CSOR -#define CONFIG_SYS_CS1_FTIM0 CONFIG_SYS_NOR_FTIM0 -#define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NOR_FTIM1 -#define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NOR_FTIM2 -#define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NOR_FTIM3
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE
-#if defined(CONFIG_RAMBOOT_PBL) -#define CONFIG_SYS_RAMBOOT -#endif - #define CONFIG_BOARD_EARLY_INIT_R /* call board_early_init_r function */ #define CONFIG_MISC_INIT_R
@@ -412,28 +176,9 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_HARD_I2C /* I2C with hardware support */ #define CONFIG_I2C_MULTI_BUS #define CONFIG_I2C_CMD_TREE -#define CONFIG_SYS_I2C_SPEED 100000 /* I2C speed */ #define CONFIG_SYS_I2C_SLAVE 0x7F #define CONFIG_SYS_I2C_OFFSET 0x118000 #define CONFIG_SYS_I2C2_OFFSET 0x118100 -#define I2C_MUX_PCA_ADDR_PRI 0x77 /* I2C bus multiplexer,primary */ -#define I2C_MUX_PCA_ADDR_SEC 0x76 /* I2C bus multiplexer,secondary */ - -#define I2C_MUX_CH_DEFAULT 0x8 -#define I2C_MUX_CH_VOL_MONITOR 0xa -#define I2C_MUX_CH_VSC3316_FS 0xc -#define I2C_MUX_CH_VSC3316_BS 0xd - -/* Voltage monitor on channel 2*/ -#define I2C_VOL_MONITOR_ADDR 0x40 -#define I2C_VOL_MONITOR_BUS_V_OFFSET 0x2 -#define I2C_VOL_MONITOR_BUS_V_OVF 0x1 -#define I2C_VOL_MONITOR_BUS_V_SHIFT 3 - -/* VSC Crossbar switches */ -#define CONFIG_VSC_CROSSBAR -#define VSC3316_FSM_TX_ADDR 0x70 -#define VSC3316_FSM_RX_ADDR 0x71
/* * RapidIO @@ -447,44 +192,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_SRIO2_MEM_SIZE 0x10000000 /* 256M */
/* - * for slave u-boot IMAGE instored in master memory space, - * PHYS must be aligned based on the SIZE - */ -#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_PHYS 0xfef080000ull -#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS1 0xfff80000ull -#define CONFIG_SRIO_PCIE_BOOT_IMAGE_SIZE 0x80000 /* 512K */ -#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS2 0x3fff80000ull -/* - * for slave UCODE and ENV instored in master memory space, - * PHYS must be aligned based on the SIZE - */ -#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_PHYS 0xfef040000ull -#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_BUS 0x3ffe00000ull -#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_SIZE 0x40000 /* 256K */ - -/* slave core release by master*/ -#define CONFIG_SRIO_PCIE_BOOT_BRR_OFFSET 0xe00e4 -#define CONFIG_SRIO_PCIE_BOOT_RELEASE_MASK 0x00000001 /* release core 0 */ - -/* - * SRIO_PCIE_BOOT - SLAVE - */ -#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE -#define CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR 0xFFE00000 -#define CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR_PHYS \ - (0x300000000ull | CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR) -#endif -/* - * eSPI - Enhanced SPI - */ -#define CONFIG_FSL_ESPI -#define CONFIG_SPI_FLASH -#define CONFIG_SPI_FLASH_SST -#define CONFIG_CMD_SF -#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE 0 - -/* * General PCI * Memory space is mapped 1-1, but I/O space must start from 0. */ @@ -527,66 +234,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_PCIE4_IO_PHYS 0xff8030000ull #define CONFIG_SYS_PCIE4_IO_SIZE 0x00010000 /* 64k */
-/* Qman/Bman */ -#ifndef CONFIG_NOBQFMAN -#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ -#define CONFIG_SYS_BMAN_NUM_PORTALS 50 -#define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 -#define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull -#define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 -#define CONFIG_SYS_QMAN_NUM_PORTALS 50 -#define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 -#define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull -#define CONFIG_SYS_QMAN_MEM_SIZE 0x02000000 - -#define CONFIG_SYS_DPAA_FMAN -#define CONFIG_SYS_DPAA_PME -#define CONFIG_SYS_PMAN -#define CONFIG_SYS_DPAA_DCE -#define CONFIG_SYS_INTERLAKEN - -/* Default address of microcode for the Linux Fman driver */ -#if defined(CONFIG_SPIFLASH) -/* - * env is stored at 0x100000, sector size is 0x10000, ucode is stored after - * env, so we got 0x110000. - */ -#define CONFIG_SYS_QE_FW_IN_SPIFLASH -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 -#elif defined(CONFIG_SDCARD) -/* - * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is - * about 545KB (1089 blocks), Env is stored after the image, and the env size is - * 0x2000 (16 blocks), 8 + 1089 + 16 = 1113, enlarge it to 1130. - */ -#define CONFIG_SYS_QE_FMAN_FW_IN_MMC -#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1130) -#elif defined(CONFIG_NAND) -#define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_QE_FMAN_FW_ADDR (6 * CONFIG_SYS_NAND_BLOCK_SIZE) -#else -#define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF40000 -#endif -#define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 -#define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) -#endif /* CONFIG_NOBQFMAN */ - -#ifdef CONFIG_SYS_DPAA_FMAN -#define CONFIG_FMAN_ENET -#define CONFIG_PHYLIB_10G -#define CONFIG_PHY_VITESSE -#define CONFIG_PHY_TERANETICS -#define SGMII_CARD_PORT1_PHY_ADDR 0x1C -#define SGMII_CARD_PORT2_PHY_ADDR 0x1D -#define SGMII_CARD_PORT3_PHY_ADDR 0x1E -#define SGMII_CARD_PORT4_PHY_ADDR 0x1F -#define FM1_10GEC1_PHY_ADDR 0x0 -#define FM1_10GEC2_PHY_ADDR 0x1 -#define FM2_10GEC1_PHY_ADDR 0x2 -#define FM2_10GEC2_PHY_ADDR 0x3 -#endif - #ifdef CONFIG_PCI #define CONFIG_PCI_INDIRECT_BRIDGE #define CONFIG_NET_MULTI @@ -649,30 +296,6 @@ unsigned long get_board_ddr_clk(void); #endif
/* -* USB -*/ -#define CONFIG_CMD_USB -#define CONFIG_USB_STORAGE -#define CONFIG_USB_EHCI -#define CONFIG_USB_EHCI_FSL -#define CONFIG_EHCI_HCD_INIT_AFTER_RESET -#define CONFIG_CMD_EXT2 -#define CONFIG_HAS_FSL_DR_USB - -#define CONFIG_MMC - -#ifdef CONFIG_MMC -#define CONFIG_FSL_ESDHC -#define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR -#define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT -#define CONFIG_CMD_MMC -#define CONFIG_GENERIC_MMC -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT -#define CONFIG_DOS_PARTITION -#endif - -/* * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ @@ -713,112 +336,11 @@ unsigned long get_board_ddr_clk(void); /* default location for tftp and bootm */ #define CONFIG_LOADADDR 1000000
-#define CONFIG_BOOTDELAY 10 /* -1 disables auto-boot */
#define CONFIG_BAUDRATE 115200
-#define __USB_PHY_TYPE utmi - -/* - * T4240 has 3 DDR controllers. Default to 3way_4KB interleaving. It can be - * 3way_1KB, 3way_4KB, 3way_8KB. T4160 has 2 DDR controllers. Default to - * cacheline interleaving. It can be cacheline, page, bank, superbank. - * See doc/README.fsl-ddr for details. - */ -#ifdef CONFIG_PPC_T4240 -#define CTRL_INTLV_PREFERED 3way_4KB -#else -#define CTRL_INTLV_PREFERED cacheline -#endif - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "hwconfig=fsl_ddr:" \ - "ctlr_intlv=" __stringify(CTRL_INTLV_PREFERED) "," \ - "bank_intlv=auto;" \ - "usb1:dr_mode=host,phy_type=" __stringify(__USB_PHY_TYPE) "\0"\ - "netdev=eth0\0" \ - "uboot=" __stringify(CONFIG_UBOOTPATH) "\0" \ - "ubootaddr=" __stringify(CONFIG_SYS_TEXT_BASE) "\0" \ - "tftpflash=tftpboot $loadaddr $uboot && " \ - "protect off $ubootaddr +$filesize && " \ - "erase $ubootaddr +$filesize && " \ - "cp.b $loadaddr $ubootaddr $filesize && " \ - "protect on $ubootaddr +$filesize && " \ - "cmp.b $loadaddr $ubootaddr $filesize\0" \ - "consoledev=ttyS0\0" \ - "ramdiskaddr=2000000\0" \ - "ramdiskfile=t4240qds/ramdisk.uboot\0" \ - "fdtaddr=c00000\0" \ - "fdtfile=t4240qds/t4240qds.dtb\0" \ - "bdev=sda3\0" \ - "c=ffe\0" - -/* For emulation this causes u-boot to jump to the start of the proof point - app code automatically */ -#define CONFIG_PROOF_POINTS \ - "setenv bootargs root=/dev/$bdev rw " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "cpu 1 release 0x29000000 - - -;" \ - "cpu 2 release 0x29000000 - - -;" \ - "cpu 3 release 0x29000000 - - -;" \ - "cpu 4 release 0x29000000 - - -;" \ - "cpu 5 release 0x29000000 - - -;" \ - "cpu 6 release 0x29000000 - - -;" \ - "cpu 7 release 0x29000000 - - -;" \ - "go 0x29000000" - #define CONFIG_HVBOOT \ "setenv bootargs config-addr=0x60000000; " \ "bootm 0x01000000 - 0x00f00000"
-#define CONFIG_ALU \ - "setenv bootargs root=/dev/$bdev rw " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "cpu 1 release 0x01000000 - - -;" \ - "cpu 2 release 0x01000000 - - -;" \ - "cpu 3 release 0x01000000 - - -;" \ - "cpu 4 release 0x01000000 - - -;" \ - "cpu 5 release 0x01000000 - - -;" \ - "cpu 6 release 0x01000000 - - -;" \ - "cpu 7 release 0x01000000 - - -;" \ - "go 0x01000000" - -#define CONFIG_LINUX \ - "setenv bootargs root=/dev/ram rw " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "setenv ramdiskaddr 0x02000000;" \ - "setenv fdtaddr 0x00c00000;" \ - "setenv loadaddr 0x1000000;" \ - "bootm $loadaddr $ramdiskaddr $fdtaddr" - -#define CONFIG_HDBOOT \ - "setenv bootargs root=/dev/$bdev rw " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "tftp $loadaddr $bootfile;" \ - "tftp $fdtaddr $fdtfile;" \ - "bootm $loadaddr - $fdtaddr" - -#define CONFIG_NFSBOOTCOMMAND \ - "setenv bootargs root=/dev/nfs rw " \ - "nfsroot=$serverip:$rootpath " \ - "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "tftp $loadaddr $bootfile;" \ - "tftp $fdtaddr $fdtfile;" \ - "bootm $loadaddr - $fdtaddr" - -#define CONFIG_RAMBOOTCOMMAND \ - "setenv bootargs root=/dev/ram rw " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "tftp $ramdiskaddr $ramdiskfile;" \ - "tftp $loadaddr $bootfile;" \ - "tftp $fdtaddr $fdtfile;" \ - "bootm $loadaddr $ramdiskaddr $fdtaddr" - -#define CONFIG_BOOTCOMMAND CONFIG_LINUX - -#ifdef CONFIG_SECURE_BOOT -#include <asm/fsl_secure_boot.h> -#endif - #endif /* __CONFIG_H */
York Sun
