test_efi_selftest occasionally fails on qemu-x86?
Please check the log: https://dev.azure.com/bmeng/GitHub/_build/results?buildId=302&view=logs&...
Re-run the pipeline with the same commit, the tests pass. https://dev.azure.com/bmeng/GitHub/_build/results?buildId=304&view=logs&...
There might be some instability on qemu-x86 with efi_selftest. Any ideas?
Regards, Bin
Regards, Bin
Hello Bin,
The failing routine is
u_boot_console.restart_uboot()
after the UEFI tests were completed successfully.
This is the function:
def restart_uboot(self): """Shut down and restart U-Boot.""" self.cleanup_spawn() self.ensure_spawned()
In ensure_spawned() we get the exception:
Exception: Bad pattern found on console: main_signon
ensure_spawned() complains because it sees the main_signon message a second time.
This is the console output:
U-Boot 2021.01-rc4-23431-g6ef1b75087 (Dec 22 2020 - 03:07:46 +0000)
CPU: QEMU Virtual CPU version 2.5+ DRAM: 128 MiB unable to find cpus device Warning: MP init failure
So obviously U-Boot is crashing during the boot process after x86_mp_init().
The same error has shown up on Gitlab as reported by Simon. Cf.
https://gitlab.denx.de/u-boot/custodians/u-boot-dm/-/jobs/190746/raw
I suggest that you add
#define DEBUG 1
at the top of common.h to close in on the location of the crash.
Best regards
Heinrich
Regards, Bin
Hello Bin,
#define DEBUG 1
Best regards
Heinrich
Here is a log with DEBUG set: https://gitlab.denx.de/u-boot/custodians/u-boot-efi/-/jobs/192520/raw
This is the interesting part:
+u-boot-test-reset qemu-x86 na initcall: fff6ef31 U-Boot 2021.01-rc4-00037-ge528c1d3e3 (Dec 22 2020 - 08:16:58 +0000) initcall: fff150c7 U-Boot code: FFF00000 -> FFFA880C BSS: -> FFFB5404
VBE: Setting VESA mode 0x144 <<<<CRASH occurs here >>>> initcall: fff6ef31 U-Boot 2021.01-rc4-00037-ge528c1d3e3 (Dec 22 2020 - 08:16:58 +0000)
On my local system I see:
VBE: framebuffer: d0000000 VBE: Setting VESA mode 0x144 Final vesa mode 0x144 base = d0000000, copy_base = 0
So the crash occurs before pci_rom_probe() is finished.
Best regards
Heinrich
Hi Heinrich,
Regards, Bin
Hello Bin,
U-Boot 2021.01-rc4-23431-g6ef1b75087 (Dec 22 2020 - 03:07:46 +0000) CPU: QEMU Virtual CPU version 2.5+ DRAM: 128 MiB unable to find cpus device Warning: MP init failure U-Boot 2021.01-rc4-23431-g6ef1b75087 (Dec 22 2020 - 03:07:46 +0000)
#define DEBUG 1
Best regards
Heinrich
This may be related to the MP changes I made recently. If I recall correctly, MP init isn't really needed on qemu, but I'm not sure.
Bin Meng
