[U-Boot] [PATCH 1/1] network: set timeline for CONFIG_DM_ETH conversion
The driver model has been supported for network drivers since 2015. It is time to convert the remaining boards. Set July 2020 as a timeline.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- Makefile | 11 +++++++++++ doc/driver-model/migration.rst | 8 ++++++++ 2 files changed, 19 insertions(+)
diff --git a/Makefile b/Makefile index 8513db94e3..4d42602b3b 100644 --- a/Makefile +++ b/Makefile @@ -1025,6 +1025,17 @@ ifneq ($(CONFIG_WDT),y) @echo >&2 "See doc/driver-model/MIGRATION.txt for more info." @echo >&2 "====================================================" endif +endif +ifneq ($(CONFIG_NET),) +ifneq ($(CONFIG_DM_ETH),y) + @echo >&2 "===================== WARNING ======================" + @echo >&2 "This board does not use CONFIG_DM_ETH (Driver Model" + @echo >&2 "for Ethernet drivers). Please update the board to use" + @echo >&2 "CONFIG_DM_ETH before the v2020.07 release. Failure to" + @echo >&2 "update by the deadline may result in board removal." + @echo >&2 "See doc/driver-model/migration.rst for more info." + @echo >&2 "====================================================" +endif endif @# Check that this build does not use CONFIG options that we do not @# know about unless they are in Kconfig. All the existing CONFIG diff --git a/doc/driver-model/migration.rst b/doc/driver-model/migration.rst index a26e7ab7e1..75b85235ef 100644 --- a/doc/driver-model/migration.rst +++ b/doc/driver-model/migration.rst @@ -97,3 +97,11 @@ Deadline: 2019.07 The video subsystem has supported driver model since early 2016. Maintainers should submit patches switching over to using CONFIG_DM_VIDEO and other base driver model options in time for inclusion in the 2019.07 release. + +CONFIG_DM_ETH +------------- +Deadline: 2020.07 + +The network subsystem has supported the driver model since early 2015. +Maintainers should submit patches switching over to using CONFIG_DM_ETH and +other base driver model options in time for inclusion in the 2020.07 release. -- 2.20.1
Hi Heinrich,
https://patchwork.ozlabs.org/patch/1144982/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
Joe Hershberger
