[U-Boot] [STATUS] v2009.06-rc1 is out
Hi everybody...
v2009.06-rc1 has just been released.
Please help testing, and submit fixes to the remaining problems. Things still missing should be submitted ASAP. I would like to have a -rc2 by the end of next week, and strictly only bug fixes after this.
v2009.06-rc1 will also be the base for the "next" branch which I will create soon.
Please use the "next" branch as base for any new work. Note: Please keep in mind that it will be rebased against master every now and then without warning.
It is difficult to use as a base a branch that is itself being rebased.
Why not just merge unless there's something that absolutely cannot stay in the history?
Will you be pulling things into the next branch periodically (by request?), or is it just for things that aren't going into custodian next branches? When the next merge window opens, will next beecome master, or is it just an integration test as in linux-next?
-Scott
Dear Scott,
Yes, I am aware of this problem.
I can do that. But it might happen that I decide to rebase, and I wanted you to warn in advance that this might happen.
I will pull into next if anybody sends me a pull request (and I appreciate if that happens as it reduces the amount of pending patches).
Before the merge window opens, I will merge next into master.
If integration tests are needed, we use u-boot-testing for this purpose.
Scott Wood
