[U-Boot] [PATCH v5 1/3] h2200: Add support for iPAQ h2200 palmtop
Add basic support for HP iPAQ h2200 palmtop. h2200 palmtop was targeted to general consumers. It has 64 MB of RAM, 32 MB flash. No intergrated Wi-Fi nor Ethernet. Based on Intel PXA255 processor. It was shipped with Windows CE 4.2 operating system.
Signed-off-by: Lukasz Dalek luk0104@gmail.com --- Changes for v5: - Fixed Makefile to use $(obj)
board/h2200/Makefile | 49 ++++++++++++++ board/h2200/h2200-header.S | 27 ++++++++ board/h2200/h2200.c | 53 +++++++++++++++ boards.cfg | 1 + include/configs/h2200.h | 156 ++++++++++++++++++++++++++++++++++++++++++++ 5 files changed, 286 insertions(+), 0 deletions(-) create mode 100644 board/h2200/Makefile create mode 100644 board/h2200/h2200-header.S create mode 100644 board/h2200/h2200.c create mode 100644 include/configs/h2200.h
diff --git a/board/h2200/Makefile b/board/h2200/Makefile new file mode 100644 index 0000000..51b1a9e --- /dev/null +++ b/board/h2200/Makefile @@ -0,0 +1,49 @@ +# +# h2200 Support +# +# Copyright (C) 2012 Lukasz Dalek luk0104@gmail.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := h2200.o + +SRCS := $(COBJS:.o=.c) h2200-header.S +OBJS := $(addprefix $(obj),$(COBJS)) + +all: $(LIB) $(obj)h2200-header.bin + +$(obj)h2200-header.o: h2200-header.S + $(CC) $(CFLAGS) -c -o $@ $< + +$(obj)h2200-header.bin: $(obj)h2200-header.o + $(OBJCOPY) -O binary $< $@ + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/h2200/h2200-header.S b/board/h2200/h2200-header.S new file mode 100644 index 0000000..c335bfe --- /dev/null +++ b/board/h2200/h2200-header.S @@ -0,0 +1,27 @@ +/* + * iPAQ h2200 header + * + * Copyright (C) 2012 Lukasz Dalek luk0104@gmail.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ + + .word 0xea0003fe /* b 0x1000 */ + + .org 0x40 + .ascii "ECEC" + + .org 0x1000 - 1 + .byte 0x0 diff --git a/board/h2200/h2200.c b/board/h2200/h2200.c new file mode 100644 index 0000000..3076306 --- /dev/null +++ b/board/h2200/h2200.c @@ -0,0 +1,53 @@ +/* + * iPAQ h2200 board configuration + * + * Copyright (C) 2012 Lukasz Dalek luk0104@gmail.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/pxa.h> +#include <asm/arch/pxa-regs.h> +#include <asm/io.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_init(void) +{ + /* We have RAM, disable cache */ + dcache_disable(); + icache_disable(); + + gd->bd->bi_arch_number = MACH_TYPE_H2200; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = 0xa0000100; + + return 0; +} + +int dram_init(void) +{ + /* + * Everything except MSC0 was already set up by + * 1st stage bootloader. + * + * This setting enables access to companion chip. + */ + clrsetbits_le32(MSC0, 0xffffffff, CONFIG_SYS_MSC0_VAL); + gd->ram_size = CONFIG_SYS_SDRAM_SIZE; + return 0; +} diff --git a/boards.cfg b/boards.cfg index b4e0d3c..ab10938 100644 --- a/boards.cfg +++ b/boards.cfg @@ -282,6 +282,7 @@ dvlhost arm ixp pdnb3 arm ixp pdnb3 prodrive scpu arm ixp pdnb3 prodrive - pdnb3:SCPU balloon3 arm pxa +h2200 arm pxa lubbock arm pxa palmld arm pxa palmtc arm pxa diff --git a/include/configs/h2200.h b/include/configs/h2200.h new file mode 100644 index 0000000..de5299b --- /dev/null +++ b/include/configs/h2200.h @@ -0,0 +1,156 @@ +/* + * iPAQ h2200 board configuration + * + * Copyright (C) 2012 Lukasz Dalek luk0104@gmail.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define MACH_TYPE_H2200 341 +#define CONFIG_MACH_TYPE MACH_TYPE_H2200 + +#define CONFIG_CPU_PXA25X 1 +#define CONFIG_BOARD_H2200 + +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x04000000 /* 64 MB */ + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_SDRAM_SIZE PHYS_SDRAM_1_SIZE + +#define CONFIG_SYS_INIT_SP_ADDR 0xfffff800 + +#define CONFIG_ENV_SIZE 0x00040000 +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) + +#define CONFIG_ENV_IS_NOWHERE +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_LOAD_ADDR 0xa3000000 /* default load address */ + +/* + * iPAQ 1st stage bootloader loads 2nd stage bootloader + * at address 0xa0040000 but bootloader requires header + * which is 0x1000 long. + * + * --- Header begin --- + * .word 0xea0003fe ; b 0x1000 + * + * .org 0x40 + * .ascii "ECEC" + * + * .org 0x1000 + * --- Header end --- + */ + +#define CONFIG_SYS_TEXT_BASE 0xa0041000 + +/* + * Static chips + */ + +#define CONFIG_SYS_MSC0_VAL 0x246c7ffc +#define CONFIG_SYS_MSC1_VAL 0x7ff07ff0 +#define CONFIG_SYS_MSC2_VAL 0x7ff07ff0 + +/* + * PCMCIA and CF Interfaces + */ + +#define CONFIG_SYS_MECR_VAL 0x00000000 +#define CONFIG_SYS_MCMEM0_VAL 0x00000000 +#define CONFIG_SYS_MCMEM1_VAL 0x00000000 +#define CONFIG_SYS_MCATT0_VAL 0x00000000 +#define CONFIG_SYS_MCATT1_VAL 0x00000000 +#define CONFIG_SYS_MCIO0_VAL 0x00000000 +#define CONFIG_SYS_MCIO1_VAL 0x00000000 + +#define CONFIG_SYS_FLYCNFG_VAL 0x00000000 +#define CONFIG_SYS_SXCNFG_VAL 0x00040004 + +#define CONFIG_SYS_MDREFR_VAL 0x0099E018 +#define CONFIG_SYS_MDCNFG_VAL 0x01C801CB +#define CONFIG_SYS_MDMRS_VAL 0x00220022 + +#define CONFIG_SYS_PSSR_VAL 0x00000000 +#define CONFIG_SYS_CKEN 0x00004840 +#define CONFIG_SYS_CCCR 0x00000161 + +/* + * GPIOs + */ + +#define CONFIG_SYS_GPSR0_VAL 0x01000000 +#define CONFIG_SYS_GPSR1_VAL 0x00000000 +#define CONFIG_SYS_GPSR2_VAL 0x00010000 + +#define CONFIG_SYS_GPCR0_VAL 0x00000000 +#define CONFIG_SYS_GPCR1_VAL 0x00000000 +#define CONFIG_SYS_GPCR2_VAL 0x00000000 + +#define CONFIG_SYS_GPDR0_VAL 0xF7E38C00 +#define CONFIG_SYS_GPDR1_VAL 0xBCFFBF83 +#define CONFIG_SYS_GPDR2_VAL 0x000157FF + +#define CONFIG_SYS_GAFR0_L_VAL 0x80401000 +#define CONFIG_SYS_GAFR0_U_VAL 0x00000112 +#define CONFIG_SYS_GAFR1_L_VAL 0x600A9550 +#define CONFIG_SYS_GAFR1_U_VAL 0x0005AAAA +#define CONFIG_SYS_GAFR2_L_VAL 0x20000000 +#define CONFIG_SYS_GAFR2_U_VAL 0x00000000 + +/* + * Serial port + */ + +#define CONFIG_PXA_SERIAL +#define CONFIG_FFUART + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 38400, 115200 } + +#define CONFIG_CMD_IMPORTENV 1 +#define CONFIG_CMD_LOADB +#define CONFIG_CMD_SOURCE +#define CONFIG_CMD_RUN +#define CONFIG_CMD_IMI + +#define CONFIG_FIT +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_CMDLINE_TAG +#define CONFIG_INITRD_TAG + +/* Monitor Command Prompt */ +#define CONFIG_SYS_PROMPT "> " +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "$ " + +/* Console I/O Buffer Size */ +#define CONFIG_SYS_CBSIZE 256 + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) + +#define CONFIG_BOOTARGS "root=/dev/ram0 ro console=ttyS0,115200n8" + +#endif /* __CONFIG_H */
Add function which return CPU model and revision which can be used for cpu detection.
Signed-off-by: Lukasz Dalek luk0104@gmail.com --- Changes for v5: - Changed commit message
arch/arm/cpu/pxa/cpuinfo.c | 11 +++++++++-- arch/arm/include/asm/arch-pxa/pxa.h | 13 +++++++++++++ 2 files changed, 22 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/pxa/cpuinfo.c b/arch/arm/cpu/pxa/cpuinfo.c index f1cdd40..bab6340 100644 --- a/arch/arm/cpu/pxa/cpuinfo.c +++ b/arch/arm/cpu/pxa/cpuinfo.c @@ -24,9 +24,11 @@ #include <errno.h> #include <linux/compiler.h>
-#define CPU_MASK_PXA_REVID 0x00f +#define CPU_MASK_PXA_PRODID 0x000003f0 +#define CPU_MASK_PXA_REVID 0x0000000f + +#define CPU_MASK_PRODREV (CPU_MASK_PXA_PRODID | CPU_MASK_PXA_REVID)
-#define CPU_MASK_PXA_PRODID 0x3f0 #define CPU_VALUE_PXA25X 0x100 #define CPU_VALUE_PXA27X 0x110
@@ -51,6 +53,11 @@ int cpu_is_pxa27x(void) return id == CPU_VALUE_PXA27X; }
+uint32_t pxa_get_cpu_revision(void) +{ + return pxa_get_cpuid() & CPU_MASK_PRODREV; +} + #ifdef CONFIG_DISPLAY_CPUINFO static const char *pxa25x_get_revision(void) { diff --git a/arch/arm/include/asm/arch-pxa/pxa.h b/arch/arm/include/asm/arch-pxa/pxa.h index 49c6552..b67d8f2 100644 --- a/arch/arm/include/asm/arch-pxa/pxa.h +++ b/arch/arm/include/asm/arch-pxa/pxa.h @@ -22,8 +22,21 @@ #ifndef __PXA_H__ #define __PXA_H__
+#define PXA255_A0 0x00000106 +#define PXA250_C0 0x00000105 +#define PXA250_B2 0x00000104 +#define PXA250_B1 0x00000103 +#define PXA250_B0 0x00000102 +#define PXA250_A1 0x00000101 +#define PXA250_A0 0x00000100 +#define PXA210_C0 0x00000125 +#define PXA210_B2 0x00000124 +#define PXA210_B1 0x00000123 +#define PXA210_B0 0x00000122 + int cpu_is_pxa25x(void); int cpu_is_pxa27x(void); +uint32_t pxa_get_cpu_revision(void); void pxa2xx_dram_init(void);
#endif /* __PXA_H__ */
Add support for ethernet over USB which can be used for e.g. booting process. It works with tftp and dhcp clients code.
Signed-off-by: Lukasz Dalek luk0104@gmail.com --- Changes for v5: - Surrendered #include <usb.h> with CONFIGs
board/h2200/h2200.c | 17 +++++++++++++++++ boards.cfg | 1 + include/configs/h2200.h | 27 +++++++++++++++++++++++++++ 3 files changed, 45 insertions(+), 0 deletions(-)
diff --git a/board/h2200/h2200.c b/board/h2200/h2200.c index 3076306..617bb04 100644 --- a/board/h2200/h2200.c +++ b/board/h2200/h2200.c @@ -22,9 +22,20 @@ #include <asm/arch/pxa.h> #include <asm/arch/pxa-regs.h> #include <asm/io.h> +#ifdef CONFIG_H2200_USBETH +# include <usb.h> +#endif
+#ifdef CONFIG_H2200_USBETH +int board_eth_init(bd_t *bis) +{ + usb_eth_initialize(bis); + return 0; +} +#endif + int board_init(void) { /* We have RAM, disable cache */ @@ -36,6 +47,12 @@ int board_init(void) /* adress of boot parameters */ gd->bd->bi_boot_params = 0xa0000100;
+ /* Let host see that device is disconnected */ +#if defined(CONFIG_H2200_USBETH) + udc_disconnect(); + mdelay(500); +#endif + return 0; }
diff --git a/boards.cfg b/boards.cfg index ab10938..a03a469 100644 --- a/boards.cfg +++ b/boards.cfg @@ -283,6 +283,7 @@ pdnb3 arm ixp pdnb3 prodriv scpu arm ixp pdnb3 prodrive - pdnb3:SCPU balloon3 arm pxa h2200 arm pxa +h2200_usbeth arm pxa h2200 - - h2200:H2200_USBETH lubbock arm pxa palmld arm pxa palmtc arm pxa diff --git a/include/configs/h2200.h b/include/configs/h2200.h index de5299b..4c5a1ae 100644 --- a/include/configs/h2200.h +++ b/include/configs/h2200.h @@ -153,4 +153,31 @@
+#ifdef CONFIG_H2200_USBETH +# define CONFIG_SYS_CONSOLE_IS_IN_ENV +# define CONFIG_USB_DEV_PULLUP_GPIO 33 +/* USB VBUS GPIO 3 */ + +# define CONFIG_CMD_NET +# define CONFIG_CMD_PING + +# define CONFIG_BOOTDELAY 2 +# define CONFIG_BOOTCOMMAND \ + "setenv downloaded 0 ; while test $downloaded -eq 0 ; do " \ + "if bootp ; then setenv downloaded 1 ; fi ; done ; " \ + "source :script ; " \ + "bootm ; " + +# define CONFIG_USB_GADGET_PXA2XX +# define CONFIG_USB_ETHER +# define CONFIG_USB_ETH_SUBSET + +# define CONFIG_USBNET_DEV_ADDR "de:ad:be:ef:00:01" +# define CONFIG_USBNET_HOST_ADDR "de:ad:be:ef:00:02" +# define CONFIG_EXTRA_ENV_SETTINGS \ + "stdin=serial\0" \ + "stdout=serial\0" \ + "stderr=serial\0" +#endif + #endif /* __CONFIG_H */
Dear Lukasz Dalek,
Changes for v5:
I told you to enable the USB ethernet by default, so why do you add this board?
btw. http://www.denx.de/wiki/U-Boot/Patches esp. the In-reply-to part.
Best regards, Marek Vasut
On 03.10.2012 02:06, Marek Vasut wrote:
Dear Lukasz Dalek,
Signed-off-by: Lukasz Dalekluk0104@gmail.com
Changes for v5:
- Surrendered #include<usb.h> with CONFIGs
I don't understand. We agreed to split h2200 support into two parts. First one adding basic support for device, second one adding support for usb ethernet for h2200.
Łukasz Dałek
Dear Łukasz Dałek,
Dear Lukasz Dalek,
Changes for v5:
h2200 arm pxa
Yes, but I fail to understand why you need TWO board entries for that. Adding the USB ethernet support is just a feature, you don't need additional board entry for that ... so what is the idea behind adding it?
On 03.10.2012 02:18, Marek Vasut wrote:
Dear Łukasz Dałek,
Dear Lukasz Dalek,
Changes for v5:
h2200 arm pxa
Because easier is to type make h2200_usbeth_config than modifiy config.
Łukasz Dałek
Dear Łukasz Dałek,
Dear Łukasz Dałek,
Dear Lukasz Dalek,
Changes for v5:
h2200 arm pxa
Why don't you enable the USB ethernet by default for "h2200" target then?
On 03.10.2012 02:25, Marek Vasut wrote:
Dear Łukasz Dałek,
Dear Łukasz Dałek,
Dear Lukasz Dalek,
Changes for v5:
I will enable. This two entries really look weird.
Łukasz Dałek
Dear Łukasz Dałek,
Dear Łukasz Dałek,
Dear Łukasz Dałek,
Dear Lukasz Dalek,
> Add support for ethernet over USB which can be used for e.g. booting > process. It works with tftp and dhcp clients code. > > Signed-off-by: Lukasz Dalekluk0104@gmail.com > --- > > Changes for v5: > - Surrendered #include<usb.h> with CONFIGs > > board/h2200/h2200.c | 17 +++++++++++++++++ > boards.cfg | 1 + > include/configs/h2200.h | 27 +++++++++++++++++++++++++++ > 3 files changed, 45 insertions(+), 0 deletions(-)
> diff --git a/boards.cfg b/boards.cfg > index ab10938..a03a469 100644 > --- a/boards.cfg > +++ b/boards.cfg > @@ -283,6 +283,7 @@ pdnb3 arm ixp > pdnb3 prodriv scpu arm > ixp > > pdnb3 prodrive - pdnb3:SCPU > balloon3 > > arm pxa > > h2200 arm pxa > > +h2200_usbeth arm pxa h2200 > > -
Ok, so we're clear there'll be one entry with ethernet enabled called "h2200", yes?
On 03.10.2012 03:04, Marek Vasut wrote:
Dear Łukasz Dałek,
Dear Łukasz Dałek,
Dear Łukasz Dałek,
On 03.10.2012 02:06, Marek Vasut wrote: > Dear Lukasz Dalek, > >> Add support for ethernet over USB which can be used for e.g. booting >> process. It works with tftp and dhcp clients code. >> >> Signed-off-by: Lukasz Dalekluk0104@gmail.com >> --- >> >> Changes for v5: >> - Surrendered #include<usb.h> with CONFIGs >> >> board/h2200/h2200.c | 17 +++++++++++++++++ >> boards.cfg | 1 + >> include/configs/h2200.h | 27 +++++++++++++++++++++++++++ >> 3 files changed, 45 insertions(+), 0 deletions(-) > [...] > >> diff --git a/boards.cfg b/boards.cfg >> index ab10938..a03a469 100644 >> --- a/boards.cfg >> +++ b/boards.cfg >> @@ -283,6 +283,7 @@ pdnb3 arm ixp >> pdnb3 prodriv scpu arm >> ixp >> >> pdnb3 prodrive - pdnb3:SCPU >> balloon3 >> >> arm pxa >> >> h2200 arm pxa >> >> +h2200_usbeth arm pxa h2200 >> >> - > I told you to enable the USB ethernet by default, so why do you add > this board? I don't understand. We agreed to split h2200 support into two parts. First one adding basic support for device, second one adding support for usb ethernet for h2200.
Yes
Łukasz Dałek
Signed-off-by: Lukasz Dalek luk0104@gmail.com --- Changes for v6: - Defined only one entire for board Changes for v5: - Surrendered #include <usb.h> with CONFIGs
board/h2200/h2200.c | 17 +++++++++++++++++ boards.cfg | 2 +- include/configs/h2200.h | 27 +++++++++++++++++++++++++++ 3 files changed, 45 insertions(+), 1 deletions(-)
diff --git a/boards.cfg b/boards.cfg index ab10938..f557c2b 100644 --- a/boards.cfg +++ b/boards.cfg @@ -282,7 +282,7 @@ dvlhost arm ixp pdnb3 arm ixp pdnb3 prodrive scpu arm ixp pdnb3 prodrive - pdnb3:SCPU balloon3 arm pxa -h2200 arm pxa +h2200 arm pxa h2200 - - h2200:H2200_USBETH lubbock arm pxa palmld arm pxa palmtc arm pxa diff --git a/include/configs/h2200.h b/include/configs/h2200.h index de5299b..4c5a1ae 100644 --- a/include/configs/h2200.h +++ b/include/configs/h2200.h @@ -153,4 +153,31 @@
Dear Lukasz Dalek,
Changes for v6:
Changes for v5:
It's always defined, remove it.
- usb_eth_initialize(bis);
+} +#endif
- /* Let host see that device is disconnected */
- udc_disconnect();
- mdelay(500);
This change isn't needed if you remove CONFIG_H2200_USBETH
ifdef - endif not needed, otherwise good.
- "setenv downloaded 0 ; while test $downloaded -eq 0 ; do " \
- "if bootp ; then setenv downloaded 1 ; fi ; done ; " \
- "source :script ; " \
- "bootm ; "
- "stdin=serial\0" \
- "stdout=serial\0" \
- "stderr=serial\0"
On 03.10.2012 20:34, Marek Vasut wrote:
Dear Lukasz Dalek,
Changes for v6:
Changes for v5:
diff --git a/board/h2200/h2200.c b/board/h2200/h2200.c index 3076306..617bb04 100644 --- a/board/h2200/h2200.c +++ b/board/h2200/h2200.c @@ -22,9 +22,20 @@ #include<asm/arch/pxa.h> #include<asm/arch/pxa-regs.h> #include<asm/io.h> +#ifdef CONFIG_H2200_USBETH
+# include<usb.h> +#endif
+} +#endif
- int board_init(void) { /* We have RAM, disable cache */
- udc_disconnect();
- mdelay(500);
- return 0; }
- "bootm ; "
- "stderr=serial\0"
- #endif /* __CONFIG_H */
Why do I have to remove CONFIG_H2200_USBETH? If I do so, I'm not be able to disable USB ethernet support.
Łukasz Dałek
Dear Łukasz Dałek,
Dear Lukasz Dalek,
Changes for v6:
Changes for v5:
+} +#endif
- udc_disconnect();
- mdelay(500);
pdnb3 arm ixp pdnb3
- "bootm ; "
- "stderr=serial\0"
Why would you disable it?
On 03.10.2012 21:22, Marek Vasut wrote:
Dear Łukasz Dałek,
Dear Lukasz Dalek,
Changes for v6:
Changes for v5:
+} +#endif
- udc_disconnect();
- mdelay(500);
pdnb3 arm ixp pdnb3
- "bootm ; "
- "stderr=serial\0"
Because of other gadgets, e.g. ttyACM
Łukasz Dałek
Dear Łukasz Dałek,
Can't these co-exist?
On 03.10.2012 21:40, Marek Vasut wrote:
Dear Łukasz Dałek,
No they can't.
Łukasz Dałek
Dear Łukasz Dałek,
Dear Łukasz Dałek,
No they can't.
Not even with the composite driver ? What's ttyacm and where is it in u-boot btw ?
On 03.10.2012 22:02, Marek Vasut wrote:
Dear Łukasz Dałek,
Dear Łukasz Dałek,
No they can't.
As far as I know they can't exists on pxa25x. I don't know how about pxa27x.
ttyacm is a serial over usb.
Driver exists in u-boot for pxa27x (gadget/usb/pxa27x_udc.c) but I have my own for pxa25x not published.
Łukasz Dałek
Dear Łukasz Dałek,
Dear Łukasz Dałek,
Dear Łukasz Dałek,
> Why do I have to remove CONFIG_H2200_USBETH? If I do so, I'm not be > able to disable USB ethernet support.
No they can't.
Your own... what? Check the composite driver, add the ifdefs when you need them, not prematurely.
Signed-off-by: Lukasz Dalek luk0104@gmail.com --- Changes for v7: - Removed CONFIG_H2200_USBETH Changes for v6: - Defined only one entire for board Changes for v5: - Surrendered #include <usb.h> with CONFIGs
board/h2200/h2200.c | 11 +++++++++++ include/configs/h2200.h | 25 +++++++++++++++++++++++++ 2 files changed, 36 insertions(+), 0 deletions(-)
diff --git a/board/h2200/h2200.c b/board/h2200/h2200.c index 3076306..720b06e 100644 --- a/board/h2200/h2200.c +++ b/board/h2200/h2200.c @@ -22,9 +22,16 @@ #include <asm/arch/pxa.h> #include <asm/arch/pxa-regs.h> #include <asm/io.h> +#include <usb.h>
+int board_eth_init(bd_t *bis) +{ + usb_eth_initialize(bis); + return 0; +} + int board_init(void) { /* We have RAM, disable cache */ @@ -36,6 +43,10 @@ int board_init(void) /* adress of boot parameters */ gd->bd->bi_boot_params = 0xa0000100;
+ /* Let host see that device is disconnected */ + udc_disconnect(); + mdelay(500); + return 0; }
diff --git a/include/configs/h2200.h b/include/configs/h2200.h index de5299b..db406e5 100644 --- a/include/configs/h2200.h +++ b/include/configs/h2200.h @@ -153,4 +153,29 @@
+#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define CONFIG_USB_DEV_PULLUP_GPIO 33 +/* USB VBUS GPIO 3 */ + +#define CONFIG_CMD_NET +#define CONFIG_CMD_PING + +#define CONFIG_BOOTDELAY 2 +#define CONFIG_BOOTCOMMAND \ + "setenv downloaded 0 ; while test $downloaded -eq 0 ; do " \ + "if bootp ; then setenv downloaded 1 ; fi ; done ; " \ + "source :script ; " \ + "bootm ; " + +#define CONFIG_USB_GADGET_PXA2XX +#define CONFIG_USB_ETHER +#define CONFIG_USB_ETH_SUBSET + +#define CONFIG_USBNET_DEV_ADDR "de:ad:be:ef:00:01" +#define CONFIG_USBNET_HOST_ADDR "de:ad:be:ef:00:02" +#define CONFIG_EXTRA_ENV_SETTINGS \ + "stdin=serial\0" \ + "stdout=serial\0" \ + "stderr=serial\0" + #endif /* __CONFIG_H */
Dear Lukasz Dalek,
I'll apply once -pxa is pulled into -next. Thanks [...] Best regards, Marek Vasut
Lukasz Dalek
Łukasz Dałek
