[U-Boot] [BUG] incorrect crash dump output for thumbs mode
Hello Marek,
please, have a look at arch/arm/lib/interrupts.c.
If the processor is in thumbs mode when crashing the output is formatted in a different way than when not in thumbs mode, cf. dump_instr(). Is there something wrong with the thumbs mode detection?
Well, try maybe objdump ?
What is more plausible, that the above completely nonsensical disassembly actually works and the CPU triggers undefined instruction -- or that the CPU is actually in thumb mode (hint: imx6 u-boot builds are built in thumb2) and there's a bug in efi_device_path.c ? I think the later.
I think maybe you should slow down and consider this option.
On a Wandboard which is also imx I had a look at the output of exceptions:
=> exception unaligned
data abort
pc : [<8f7a2b1a>] lr : [<8f7ab1b7>]
reloc pc : [<1780cb1a>] lr : [<178151b7>]
sp : 8ed8c3f8 ip : 8f7a2b15 fp : 00000002
r10: 8f7f81f0 r9 : 8ed95ea8 r8 : 8ed99488
r7 : 8f7ab109 r6 : 00000000 r5 : 8ed8c3f9 r4 : 8f7f6358 r3 : 8ed9948c r2 : 00000001 r1 : 00000000 r0 : 8f7f6358 Flags: nzCv IRQs off FIQs off Mode SVC_32 Code: 8f7e1907 8f7e191f 8f7e193d f105466d (e9d50501) Resetting CPU ...
cat u-boot.map
.text.do_unaligned 0x1780cb14 0xe cmd/built-in.o
objdump -S -D cmd/arm/exception.o
00000000 <do_unaligned>: /* * The LDRD instruction requires the data source to be four byte aligned * even if strict alignment fault checking is disabled in the system * control register. */ asm volatile ( 0: 466d mov r5, sp 2: f105 0501 add.w r5, r5, #1 6: e9d5 6700 ldrd r6, r7, [r5] "MOV r5, sp\n" "ADD r5, #1\n" "LDRD r6, r7, [r5]\n"); return CMD_RET_FAILURE; } a: 2001 movs r0, #1 c: 4770 bx lr
So there is a bug in arch/arm/lib/interrupts.c such that it does not detect thumb mode and outputs the code arround PC incorrectly.
Macro thumb_mode(regs) returns 0 though the thumbs flag is set:
CPSR: 200001f3 THUMBS_FLAG: 00000020
The reason is that in arch/arm/include/asm/proc-armv/ptrace.h we are checking non-existent CONFIG_ARM_THUMB. We should check CONFIG_IS_ENABLED(SYS_THUMB_BUILD).
I will send a patch to correct this. With the patch applied the output is correct:
data abort
pc : [<8f7a2b52>] lr : [<8f7ab1ef>]
reloc pc : [<1780cb52>] lr : [<178151ef>]
sp : 8ed8c3f8 ip : 8f7a2b4d fp : 00000002
r10: 8f7f8228 r9 : 8ed95ea8 r8 : 8ed99488
r7 : 8f7ab141 r6 : 00000000 r5 : 8ed8c3f9 r4 : 8f7f6390
r3 : 8ed9948c r2 : 00000001 r1 : 00000000 r0 : 8f7f6390 Flags: nzCv IRQs off FIQs off Mode SVC_32 (T) Code: 8f7e 466d f105 0501 (e9d5) 6700 Resetting CPU ...
Thanks for rubbing my nose into it.
Regards
Heinrich
On 6/23/19 8:06 AM, Heinrich Schuchardt wrote:
Hello Marek,
data abort
cat u-boot.map
data abort
No problem.
