[PATCH] rockchip: make_fit_atf: use correct fdt_x references in config nodes
From: Heiko Stuebner heiko.stuebner@theobroma-systems.com
The script iterates over the given devicetrees and creates both fdt_x node as well as a conf-node for each passed dt.
But there is a slight bug in that it always references fdt_1 in each conf node instead of the matching fdt_x as expected.
So fix that by referencing the number of the current dt similar to how the fdt_x nodes gets created.
Signed-off-by: Heiko Stuebner heiko.stuebner@theobroma-systems.com --- arch/arm/mach-rockchip/make_fit_atf.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-rockchip/make_fit_atf.py b/arch/arm/mach-rockchip/make_fit_atf.py index 3c045a5e17..aaec2cd270 100755 --- a/arch/arm/mach-rockchip/make_fit_atf.py +++ b/arch/arm/mach-rockchip/make_fit_atf.py @@ -107,7 +107,7 @@ def append_conf_section(file, cnt, dtname, segments): file.write(';\n') if segments <= 1: file.write(';\n') - file.write('\t\t\tfdt = "fdt_1";\n') + file.write('\t\t\tfdt = "fdt_%d";\n' % cnt) file.write('\t\t};\n') file.write('\n')
Reviewed-by: Kever Yang kever.yang@rock-chips.com kever.yang@rock-chips.com
Thanks, - Kever
Heiko Stuebner heiko@sntech.de 于2020年1月18日周六 上午4:26写道:
- file.write('\t\t\tfdt = "fdt_%d";\n' % cnt) file.write('\t\t};\n') file.write('\n')
-- 2.24.1
Heiko Stuebner
Kever Yang
