[U-Boot] Pull request: nand-flash
These patches are from the testing/mtd-2.6.22.1 branch of u-boot-nand-flash.
Note that this is a significant change to the NAND subsystem (importing a newer upstream version) that affects the driver interface. If your board has NAND, please test.
The following changes since commit cd82919e6c8a73b363a26f34b734923844e52d1c: Wolfgang Denk (1): Coding style cleanup, update CHANGELOG, prepare release
git://www.denx.de/git/u-boot-nand-flash.git master
Anton Vorontsov (2): fsl_elbc_nand: workaround for hangs during nand write nand: fsl_upm: convert to updated MTD NAND infrastructure
Fathi BOUDRA (1): OneNAND: Fill in MTD function pointers for OneNAND.
Guennadi Liakhovetski (2): NAND: Do not write or read a whole block if it is larger than the environment nand_spl: Support page-aligned read in nand_load, use chipselect
Ilya Yanok (1): NAND: Scan bad blocks lazily.
Marcel Ziswiler (1): NAND: chip->state does not always get set.
Scott Wood (8): Don't panic if a controller driver does ecc its own way. Freescale eLBC FCM NAND driver fsl_elbc_nand: Hard-code the FBAR/FPAR split. NAND: Always skip blocks on read/write/boot. NAND read/write fix mpc8313erdb: Enable NAND in config. NAND boot: MPC8313ERDB support NAND boot: Update large page support for current API.
Sergey Kubushyn (1): NAND: Davinci driver updates
Stefan Roese (5): NAND: Change nand_wait_ready() to not call nand_wait() NAND: Update 4xx NDFC driver to match updated nand subsystem NAND: Update nand_spl driver to match updated nand subsystem NAND: Fix compilation warning and small coding style issue NAND: Make NAND driver less verbose per default
William Juul (10): Update MTD to that of Linux 2.6.22.1 Remove white space at end. Fixing coding style issues Whitespace cleanup and marking broken code. YAFFS2 import Incorporate yaffs2 into U-boot Create symlinks from yaffs2/direct to yaffs2 Clean out unneeded files moving files from yaffs2/direct/ to yaffs2/ and deleting all symlinks make nand dump and nand dump.oob work
Makefile | 13 +- board/bf537-stamp/nand.c | 43 +- board/dave/PPChameleonEVB/nand.c | 49 +- board/delta/nand.c | 41 +- board/esd/common/esd405ep_nand.c | 42 +- board/freescale/m5329evb/nand.c | 42 +- board/freescale/mpc8313erdb/config.mk | 6 + board/freescale/mpc8313erdb/mpc8313erdb.c | 32 + board/freescale/mpc8313erdb/sdram.c | 5 +- board/nc650/nand.c | 78 +- board/netstar/nand.c | 20 +- board/prodrive/alpr/nand.c | 57 +- board/prodrive/pdnb3/nand.c | 53 +- board/sc3/sc3nand.c | 44 +- board/tqc/tqm8272/tqm8272.c | 34 +- board/zylonite/nand.c | 39 +- common/Makefile | 1 + common/cmd_doc.c | 9 + common/cmd_nand.c | 253 +- common/cmd_onenand.c | 2 +- common/cmd_yaffs2.c | 215 + common/env_nand.c | 18 +- cpu/arm926ejs/davinci/nand.c | 58 +- cpu/mpc83xx/nand_init.c | 112 + cpu/mpc83xx/start.S | 152 +- cpu/ppc4xx/ndfc.c | 112 +- doc/README.nand | 37 +- drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/diskonchip.c | 546 +- drivers/mtd/nand/fsl_elbc_nand.c | 767 +++ drivers/mtd/nand/fsl_upm.c | 68 +- drivers/mtd/nand/nand_base.c | 3503 ++++++----- drivers/mtd/nand/nand_bbt.c | 549 ++- drivers/mtd/nand/nand_ecc.c | 21 +- drivers/mtd/nand/nand_ids.c | 91 +- drivers/mtd/nand/nand_util.c | 723 +-- drivers/mtd/onenand/onenand_base.c | 24 +- fs/Makefile | 2 +- fs/yaffs2/Makefile | 56 + fs/yaffs2/README-linux | 201 + fs/yaffs2/devextras.h | 275 + fs/yaffs2/yaffs_checkptrw.c | 405 ++ fs/yaffs2/yaffs_checkptrw.h | 35 + fs/yaffs2/yaffs_ecc.c | 333 + fs/yaffs2/yaffs_ecc.h | 44 + fs/yaffs2/yaffs_flashif.h | 31 + fs/yaffs2/yaffs_guts.c | 7491 +++++++++++++++++++++++ fs/yaffs2/yaffs_guts.h | 908 +++ fs/yaffs2/yaffs_malloc.h | 26 + fs/yaffs2/yaffs_mtdif.c | 246 + fs/yaffs2/yaffs_mtdif.h | 27 + fs/yaffs2/yaffs_mtdif2.c | 235 + fs/yaffs2/yaffs_mtdif2.h | 29 + fs/yaffs2/yaffs_nand.c | 134 + fs/yaffs2/yaffs_nand.h | 44 + fs/yaffs2/yaffs_nandemul2k.h | 39 + fs/yaffs2/yaffs_packedtags1.c | 55 + fs/yaffs2/yaffs_packedtags1.h | 37 + fs/yaffs2/yaffs_packedtags2.c | 185 + fs/yaffs2/yaffs_packedtags2.h | 38 + fs/yaffs2/yaffs_qsort.c | 163 + fs/yaffs2/yaffs_qsort.h | 23 + fs/yaffs2/yaffs_ramdisk.h | 32 + fs/yaffs2/yaffs_tagscompat.c | 533 ++ fs/yaffs2/yaffs_tagscompat.h | 40 + fs/yaffs2/yaffs_tagsvalidity.c | 31 + fs/yaffs2/yaffs_tagsvalidity.h | 24 + fs/yaffs2/yaffscfg.c | 417 ++ fs/yaffs2/yaffscfg.h | 46 + fs/yaffs2/yaffsfs.c | 1510 +++++ fs/yaffs2/yaffsfs.h | 233 + fs/yaffs2/yaffsinterface.h | 21 + fs/yaffs2/ydirectenv.h | 94 + fs/yaffs2/yportenv.h | 193 + include/common.h | 2 + include/configs/MPC8313ERDB.h | 84 +- include/linux/err.h | 45 + include/linux/mtd/blktrans.h | 81 + include/linux/mtd/compat.h | 7 +- include/linux/mtd/doc2000.h | 217 +- include/linux/mtd/fsl_upm.h | 3 + include/linux/mtd/inftl-user.h | 91 + include/linux/mtd/jffs2-user.h | 35 + include/linux/mtd/mtd-abi.h | 137 +- include/linux/mtd/mtd.h | 150 +- include/linux/mtd/nand.h | 449 +- include/linux/mtd/nftl-user.h | 76 + include/linux/mtd/nftl.h | 93 +- include/linux/mtd/ubi-header.h | 360 ++ include/linux/mtd/ubi-user.h | 161 + include/mpc83xx.h | 2 + include/nand.h | 10 +- include/onenand_uboot.h | 2 +- lib_ppc/time.c | 4 +- nand_spl/board/freescale/mpc8313erdb/Makefile | 101 + nand_spl/board/freescale/mpc8313erdb/u-boot.lds | 52 + nand_spl/nand_boot.c | 98 +- nand_spl/nand_boot_fsl_elbc.c | 150 + 98 files changed, 20605 insertions(+), 3901 deletions(-) create mode 100644 common/cmd_yaffs2.c create mode 100644 cpu/mpc83xx/nand_init.c create mode 100644 drivers/mtd/nand/fsl_elbc_nand.c create mode 100644 fs/yaffs2/Makefile create mode 100644 fs/yaffs2/README-linux create mode 100644 fs/yaffs2/devextras.h create mode 100644 fs/yaffs2/yaffs_checkptrw.c create mode 100644 fs/yaffs2/yaffs_checkptrw.h create mode 100644 fs/yaffs2/yaffs_ecc.c create mode 100644 fs/yaffs2/yaffs_ecc.h create mode 100644 fs/yaffs2/yaffs_flashif.h create mode 100644 fs/yaffs2/yaffs_guts.c create mode 100644 fs/yaffs2/yaffs_guts.h create mode 100644 fs/yaffs2/yaffs_malloc.h create mode 100644 fs/yaffs2/yaffs_mtdif.c create mode 100644 fs/yaffs2/yaffs_mtdif.h create mode 100644 fs/yaffs2/yaffs_mtdif2.c create mode 100644 fs/yaffs2/yaffs_mtdif2.h create mode 100644 fs/yaffs2/yaffs_nand.c create mode 100644 fs/yaffs2/yaffs_nand.h create mode 100644 fs/yaffs2/yaffs_nandemul2k.h create mode 100644 fs/yaffs2/yaffs_packedtags1.c create mode 100644 fs/yaffs2/yaffs_packedtags1.h create mode 100644 fs/yaffs2/yaffs_packedtags2.c create mode 100644 fs/yaffs2/yaffs_packedtags2.h create mode 100644 fs/yaffs2/yaffs_qsort.c create mode 100644 fs/yaffs2/yaffs_qsort.h create mode 100644 fs/yaffs2/yaffs_ramdisk.h create mode 100644 fs/yaffs2/yaffs_tagscompat.c create mode 100644 fs/yaffs2/yaffs_tagscompat.h create mode 100644 fs/yaffs2/yaffs_tagsvalidity.c create mode 100644 fs/yaffs2/yaffs_tagsvalidity.h create mode 100644 fs/yaffs2/yaffscfg.c create mode 100644 fs/yaffs2/yaffscfg.h create mode 100644 fs/yaffs2/yaffsfs.c create mode 100644 fs/yaffs2/yaffsfs.h create mode 100644 fs/yaffs2/yaffsinterface.h create mode 100644 fs/yaffs2/ydirectenv.h create mode 100644 fs/yaffs2/yportenv.h create mode 100644 include/linux/err.h create mode 100644 include/linux/mtd/blktrans.h create mode 100644 include/linux/mtd/inftl-user.h create mode 100644 include/linux/mtd/jffs2-user.h create mode 100644 include/linux/mtd/nftl-user.h create mode 100644 include/linux/mtd/ubi-header.h create mode 100644 include/linux/mtd/ubi-user.h create mode 100644 nand_spl/board/freescale/mpc8313erdb/Makefile create mode 100644 nand_spl/board/freescale/mpc8313erdb/u-boot.lds create mode 100644 nand_spl/nand_boot_fsl_elbc.c
Dear Scott Wood,
Done. Thanks.
With this patchset, a lot of arm board are broken
nand.c: In function 'at91cap9adk_nand_hwcontrol': nand.c:47: error: 'NAND_CTL_SETCLE' undeclared (first use in this function) nand.c:47: error: (Each undeclared identifier is reported only once nand.c:47: error: for each function it appears in.) nand.c:50: error: 'NAND_CTL_SETALE' undeclared (first use in this function) nand.c:53: error: 'NAND_CTL_CLRNCE' undeclared (first use in this function) nand.c:56: error: 'NAND_CTL_SETNCE' undeclared (first use in this function) nand.c: In function 'board_nand_init': nand.c:65: error: 'struct nand_chip' has no member named 'eccmode' nand.c:69: error: incompatible types in assignment make[1]: *** [nand.o] Error 1
Configuring for apollon board... onenand_base.c: In function 'onenand_bufferram_offset': onenand_base.c:331: error: 'struct mtd_info' has no member named 'oobblock' onenand_base.c: In function 'onenand_read_ecc': onenand_base.c:541: error: 'struct mtd_info' has no member named 'oobblock' onenand_base.c:543: error: 'struct mtd_info' has no member named 'oobblock' onenand_base.c:544: error: 'struct mtd_info' has no member named 'oobblock' onenand_base.c:545: error: 'struct mtd_info' has no member named 'oobblock' onenand_base.c:549: error: 'struct mtd_info' has no member named 'oobblock' onenand_base.c: In function 'onenand_read_oob': onenand_base.c:664: error: 'struct mtd_info' has no member named 'oobblock' onenand_base.c: In function 'onenand_write_ecc': onenand_base.c:749: error: 'struct mtd_info' has no member named 'oobblock' onenand_base.c:749: error: 'struct mtd_info' has no member named 'oobblock' onenand_base.c:760: error: 'struct mtd_info' has no member named 'oobblock' onenand_base.c:762: error: 'struct mtd_info' has no member named 'oobblock' onenand_base.c:768: error: 'struct mtd_info' has no member named 'oobblock' onenand_base.c: In function 'onenand_probe': onenand_base.c:1212: error: 'struct mtd_info' has no member named 'oobblock' onenand_base.c:1214: error: 'struct mtd_info' has no member named 'oobblock' onenand_base.c:1216: error: 'struct mtd_info' has no member named 'oobblock' onenand_base.c:1219: error: 'struct mtd_info' has no member named 'oobblock' onenand_base.c:1221: error: 'struct mtd_info' has no member named 'oobblock' onenand_base.c:1243: error: 'struct mtd_info' has no member named 'read_ecc' onenand_base.c:1244: error: 'struct mtd_info' has no member named 'write_ecc' onenand_base.c:1245: warning: assignment from incompatible pointer type onenand_base.c:1246: warning: assignment from incompatible pointer type make[1]: *** [onenand_base.o] Error 1
etc...
what do we do?
Best Regards, J.
On Wed, Aug 13, 2008 at 01:06:33AM +0200, Jean-Christophe PLAGNIOL-VILLARD wrote:
They need to be updated to the new API (existing drivers were converted when mtd-2.6.22.1 was brought in on a branch, but there have been new drivers added in mainline since then). I'll post a patch later today, though I can't test it due to lack of hardware.
I've applied a patch from Kyungmin Park to fix this one (though there's still an API mismatch in OneNAND that needs to be fixed).
-Scott
Scott Wood
