[PULL u-boot] Please pull u-boot-amlogic-202107810
Hi Tom,
Here's a bunch of changes concerning: - single fix for odroid-n2+ detection - HW reboot_reason drop in favor of BCB for Android boot state tracking - meson64_android config cleanups and support for A/V, AVB and fastbootd via recovery
While the actual meson64_android config removes distro defaults targets and makes booting non-Android possible but complex, we are working toward either adding back the default targets or trying to leverage boot_android at some point to avoid building android-only u-boot binaries.
The CI job is at https://gitlab.denx.de/u-boot/custodians/u-boot-amlogic/pipelines/8655
Thanks, Neil
The following changes since commit bbcacdf4cd23f2e5deb9ef916096c956c955243d:
Merge branch '2021-07-28-build-improvements' (2021-07-28 18:51:16 -0400)
https://source.denx.de/u-boot/custodians/u-boot-amlogic.git tags/u-boot-amlogic-20210810
for you to fetch changes up to 33b51765583e6cbe1888f068da795bea599bad18:
configs: sei510/610: android bootflow via abootimg (2021-08-10 10:43:54 +0200)
---------------------------------------------------------------- - odroid-n2: fix fdtfile suffix for n2-plus - sei610 & meson64_android cleanups to prepare android 11 boot support - use Android BCB mechanism for reboot reason instead of HW reboot flag - Switch meson64_android boot flow to use abootimg for A/B, AVB and DTBO support
---------------------------------------------------------------- Christian Hewitt (1): board: amlogic: odroid-n2: fix fdtfile suffix for n2-plus
Guillaume La Roque (2): configs: meson64_android: boot android via abootimg configs: sei510/610: android bootflow via abootimg
Mattijs Korpershoek (18): configs: sei610: fix typo in header comment configs: meson64_android: fix bad indent in EXTRA_ENV_SETTINGS configs: meson64_android: use CONFIG_FASTBOOT_USB_DEV configs: meson64_android: use boot part label instead of index configs: meson64_android: use logo part label instead of index configs: meson64_android: don't set console bootargs configs: meson64_android: use BCB for reboot to bootloader configs: meson64_android: implement recovery boot via BCB configs: meson64_android: reboot to fastbootd from bootloader configs: sei610/sei510: set CONFIG_CMD_BCB=y Revert "ARM: meson: Add support for fastboot_set_reboot_flag()" configs: meson64: permit redefining SYS_MALLOC_LEN configs: meson64_android: increase SYS_MALLOC_LEN to 128M for AVB configs: meson64_android: implement AVB support configs: meson64_android: implement A/B slot support configs: meson64_android: define BOOT_CMD macro configs: sei510/sei610: reformat PARTS_default configs: sei510/sei610: don't use hard-coded gpt uuids
arch/arm/mach-meson/board-common.c | 34 ------ board/amlogic/odroid-n2/odroid-n2.c | 2 +- configs/odroid-n2_defconfig | 2 +- configs/sei510_defconfig | 6 + configs/sei610_defconfig | 6 + include/configs/meson64.h | 2 + include/configs/meson64_android.h | 215 ++++++++++++++++++++++++++++++------ include/configs/sei510.h | 23 ++-- include/configs/sei610.h | 25 ++--- 9 files changed, 220 insertions(+), 95 deletions(-)
On Wed, Aug 11, 2021 at 09:41:21AM +0200, Neil Armstrong wrote:
Hi Tom,
Thanks, Neil
Neil Armstrong
