[U-Boot] [PATCH] efi_stub: Fix GDT_NOTSYS check
The get_codeseg32() wants to know if a passed in descriptor has flag GDT_NOTSYS set (desc & GDT_NOTSYS), not whether desc and GDT_NOTSYS are not != 0 (desk && GDT_NOTSYS).
This is an obvious typo. Fix it up.
Signed-off-by: Alexander Graf agraf@suse.de --- lib/efi/efi_stub.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/efi/efi_stub.c b/lib/efi/efi_stub.c index 1814960572..9788dedba7 100644 --- a/lib/efi/efi_stub.c +++ b/lib/efi/efi_stub.c @@ -182,7 +182,7 @@ static int get_codeseg32(void) << 16; base <<= 12; /* 4KB granularity */ limit <<= 12; - if ((desc & GDT_PRESENT) && (desc && GDT_NOTSYS) && + if ((desc & GDT_PRESENT) && (desc & GDT_NOTSYS) && !(desc & GDT_LONG) && (desc & GDT_4KB) && (desc & GDT_32BIT) && (desc & GDT_CODE) && CONFIG_SYS_TEXT_BASE > base &&
Hi Alexander,
Looks this one is applied nowhere?
Regards, Bin
On 12.02.18 07:26, Bin Meng wrote:
Hi Alexander,
lib/efi is something you maintain, no?
I only want to run U-Boot as UEFI firmware, I don't particularly care about running U-Boot as UEFI payload :).
Alex
Hi Alex,
Hi Alexander,
Since I see on patchwork, this patch was assigned to you so I did not take it. I will pick this patch to x86. Thanks.
applied to u-boot-x86, thanks!
Regards, Bin
Alexander Graf
Bin Meng
