[PATCH v4 0/5] Add support for booting EFI FIT images
Currently the only way to run an EFI binary like GRUB2 is via the 'bootefi' command, which cannot be used in a verified boot scenario.
The obvious solution to this limitation is to add support for booting FIT images containing those EFI binaries.
The implementation relies on a new image type - IH_OS_EFI - which can be created by using 'os = "efi"' inside an ITS file:
/ { #address-cells = <1>;
images { efi-grub { description = "GRUB EFI"; data = /incbin/("bootarm.efi"); type = "kernel_noload"; arch = "arm"; os = "efi"; compression = "none"; load = <0x0>; entry = <0x0>; hash-1 { algo = "sha256"; }; }; };
configurations { default = "config-grub"; config-grub { kernel = "efi-grub"; signature-1 { algo = "sha256,rsa2048"; sign-images = "kernel"; }; }; }; };
The bootm command has been extended to handle the IH_OS_EFI images. To enable this feature, a new configuration option has been added: BOOTM_EFI
I tested the solution using the 'qemu_arm' board:
=> load scsi 0:1 ${kernel_addr_r} efi-image.fit => bootm ${kernel_addr_r}#config-grub
Changes in v4: * Extend the python test to also run on real hardware, currently tested on qemu_arm
Changes in v3: * Rebase patches on Heinrich Schuchardt's patch series v3: efi_loader: prepare for FIT images https://lists.denx.de/pipermail/u-boot/2019-December/393677.html This fixes implicitly the sandbox issue 'phys_to_virt: Cannot map sandbox address' since efi_install_fdt() is now expecting a pointer to addressable memory instead of a physical address. * Get rid of 'EFI/BOOT/' prefix used in ITS samples * Add a python test to verify the implementation in sandbox environment
Changes in v2: * Rebase patches on Heinrich Schuchardt's patch series: efi_loader: prepare for FIT images https://lists.denx.de/pipermail/u-boot/2019-December/393192.html * Add sample configuration: doc/uImage.FIT/uefi.its * Update uefi documentation: doc/uefi/uefi.rst
Cristian Ciocaltea (5): image: Add IH_OS_EFI for EFI chain-load boot bootm: Add a bootm command for type IH_OS_EFI doc: Add sample uefi.its image description file doc: uefi.rst: Document launching UEFI binaries from FIT images test/py: Create a test for launching UEFI binaries from FIT images
cmd/Kconfig | 7 + common/bootm_os.c | 56 +++++ common/image-fit.c | 3 +- common/image.c | 1 + doc/uImage.FIT/uefi.its | 67 +++++ doc/uefi/uefi.rst | 34 +++ include/image.h | 1 + test/py/tests/test_efi_fit.py | 459 ++++++++++++++++++++++++++++++++++ 8 files changed, 627 insertions(+), 1 deletion(-) create mode 100644 doc/uImage.FIT/uefi.its create mode 100644 test/py/tests/test_efi_fit.py
Add a new OS type to be used for chain-loading an EFI compatible firmware or boot loader like GRUB2, possibly in a verified boot scenario.
Bellow is sample ITS file that generates a FIT image supporting secure boot. Please note the presence of 'os = "efi";' line, which identifies the currently introduced OS type:
Signed-off-by: Cristian Ciocaltea cristian.ciocaltea@gmail.com Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de --- common/image-fit.c | 3 ++- common/image.c | 1 + include/image.h | 1 + 3 files changed, 4 insertions(+), 1 deletion(-)
diff --git a/common/image-fit.c b/common/image-fit.c index c52f945120..231612ff5f 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -1926,7 +1926,8 @@ int fit_image_load(bootm_headers_t *images, ulong addr, image_type == IH_TYPE_FPGA || fit_image_check_os(fit, noffset, IH_OS_LINUX) || fit_image_check_os(fit, noffset, IH_OS_U_BOOT) || - fit_image_check_os(fit, noffset, IH_OS_OPENRTOS); + fit_image_check_os(fit, noffset, IH_OS_OPENRTOS) || + fit_image_check_os(fit, noffset, IH_OS_EFI);
/* * If either of the checks fail, we should report an error, but diff --git a/common/image.c b/common/image.c index eb626dcac9..75d5dd944f 100644 --- a/common/image.c +++ b/common/image.c @@ -137,6 +137,7 @@ static const table_entry_t uimage_os[] = { { IH_OS_OPENRTOS, "openrtos", "OpenRTOS", }, #endif { IH_OS_OPENSBI, "opensbi", "RISC-V OpenSBI", }, + { IH_OS_EFI, "efi", "EFI Firmware" },
{ -1, "", "", }, }; diff --git a/include/image.h b/include/image.h index f4d2aaf53e..4a280b78e7 100644 --- a/include/image.h +++ b/include/image.h @@ -157,6 +157,7 @@ enum { IH_OS_ARM_TRUSTED_FIRMWARE, /* ARM Trusted Firmware */ IH_OS_TEE, /* Trusted Execution Environment */ IH_OS_OPENSBI, /* RISC-V OpenSBI */ + IH_OS_EFI, /* EFI Firmware (e.g. GRUB2) */
IH_OS_COUNT, };
Add support for booting EFI binaries contained in FIT images. A typical usage scenario is chain-loading GRUB2 in a verified boot environment.
Signed-off-by: Cristian Ciocaltea cristian.ciocaltea@gmail.com Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de --- cmd/Kconfig | 7 ++++++ common/bootm_os.c | 56 +++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 63 insertions(+)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 1e4cf146c5..87f2335a3c 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -263,6 +263,13 @@ config CMD_BOOTI help Boot an AArch64 Linux Kernel image from memory.
+config BOOTM_EFI + bool "Support booting EFI OS images" + depends on CMD_BOOTEFI + default y + help + Support booting EFI images via the bootm command. + config BOOTM_LINUX bool "Support booting Linux OS images" depends on CMD_BOOTM || CMD_BOOTZ || CMD_BOOTI diff --git a/common/bootm_os.c b/common/bootm_os.c index d89ddc32b0..1d58462509 100644 --- a/common/bootm_os.c +++ b/common/bootm_os.c @@ -7,10 +7,12 @@ #include <common.h> #include <bootm.h> #include <cpu_func.h> +#include <efi_loader.h> #include <env.h> #include <fdt_support.h> #include <linux/libfdt.h> #include <malloc.h> +#include <mapmem.h> #include <vxworks.h> #include <tee/optee.h>
@@ -498,6 +500,57 @@ static int do_bootm_tee(int flag, int argc, char * const argv[], } #endif
+#ifdef CONFIG_BOOTM_EFI +static int do_bootm_efi(int flag, int argc, char * const argv[], + bootm_headers_t *images) +{ + int ret; + efi_status_t efi_ret; + void *image_buf; + + if (flag != BOOTM_STATE_OS_GO) + return 0; + + /* Locate FDT, if provided */ + ret = bootm_find_images(flag, argc, argv); + if (ret) + return ret; + + /* Initialize EFI drivers */ + efi_ret = efi_init_obj_list(); + if (efi_ret != EFI_SUCCESS) { + printf("## Failed to initialize UEFI sub-system: r = %lu\n", + efi_ret & ~EFI_ERROR_MASK); + return 1; + } + + /* Install device tree */ + efi_ret = efi_install_fdt(images->ft_len + ? images->ft_addr : EFI_FDT_USE_INTERNAL); + if (efi_ret != EFI_SUCCESS) { + printf("## Failed to install device tree: r = %lu\n", + efi_ret & ~EFI_ERROR_MASK); + return 1; + } + + /* Run EFI image */ + printf("## Transferring control to EFI (at address %08lx) ...\n", + images->ep); + bootstage_mark(BOOTSTAGE_ID_RUN_OS); + + image_buf = map_sysmem(images->ep, images->os.image_len); + + efi_ret = efi_run_image(image_buf, images->os.image_len); + if (efi_ret != EFI_SUCCESS) { + printf("## Failed to run EFI image: r = %lu\n", + efi_ret & ~EFI_ERROR_MASK); + return 1; + } + + return 0; +} +#endif + static boot_os_fn *boot_os[] = { [IH_OS_U_BOOT] = do_bootm_standalone, #ifdef CONFIG_BOOTM_LINUX @@ -534,6 +587,9 @@ static boot_os_fn *boot_os[] = { #ifdef CONFIG_BOOTM_OPTEE [IH_OS_TEE] = do_bootm_tee, #endif +#ifdef CONFIG_BOOTM_EFI + [IH_OS_EFI] = do_bootm_efi, +#endif };
/* Allow for arch specific config before we boot */
+config BOOTM_EFI
- bool "Support booting EFI OS images"
Shouldn't this be "Support booting UEFI FIT images"?
- depends on CMD_BOOTEFI
depends on BOOTM
is missing here.
- default y
- help
Should we say:
Support booting UEFI FIT images via the bootm command.
Best regards
Heinrich
- config BOOTM_LINUX bool "Support booting Linux OS images" depends on CMD_BOOTM || CMD_BOOTZ || CMD_BOOTI
- int ret;
- efi_status_t efi_ret;
- void *image_buf;
- if (flag != BOOTM_STATE_OS_GO)
- /* Locate FDT, if provided */
- ret = bootm_find_images(flag, argc, argv);
- if (ret)
return ret;
- /* Initialize EFI drivers */
- efi_ret = efi_init_obj_list();
- if (efi_ret != EFI_SUCCESS) {
return 1;
- /* Install device tree */
- efi_ret = efi_install_fdt(images->ft_len
return 1;
- /* Run EFI image */
- printf("## Transferring control to EFI (at address %08lx) ...\n",
images->ep);
- bootstage_mark(BOOTSTAGE_ID_RUN_OS);
- image_buf = map_sysmem(images->ep, images->os.image_len);
- efi_ret = efi_run_image(image_buf, images->os.image_len);
return 1;
+} +#endif
- static boot_os_fn *boot_os[] = { [IH_OS_U_BOOT] = do_bootm_standalone, #ifdef CONFIG_BOOTM_LINUX
- [IH_OS_EFI] = do_bootm_efi,
+#endif };
depends on BOOTM
The patch series compiles without CONFIG_FIT. But shouldn't this also be a dependency?
If we place the definition directly after CMD_BOOTM, it will be indented so that it is evident that this is a sub-feature of CMD_BOOTM.
So how about the following?
config CMD_BOOTM bool "bootm" default y help Boot an application image from the memory.
config BOOTM_EFI bool "Support booting UEFI FIT images" depends on CMD_BOOTEFI && CMD_BOOTM && FIT default y help Support booting UEFI FIT images via the bootm command.
Best regards
Heinrich
is missing here.
Should we say:
Best regards
Heinrich
- const argv[],
} #endif
depends on BOOTM
Indeed, thanks.
In this case, we should probably also move CMD_BOOTZ, CMD_BOOTI and BOOTM_LINUX right after CMD_BOOTEFI_HELLO, since those commands do not depend on CMD_BOOTM, while all BOOTM_* features, except BOOTM_LINUX, depend exclusively on CMD_BOOTM.
Best regards
Heinrich
is missing here.
Should we say:
Best regards
Heinrich
- const argv[],
} #endif
+config BOOTM_EFI
Done.
depends on BOOTM
is missing here.
Right, thanks. Added 'CMD_BOOTEFI && CMD_BOOTM'.
- default y
- help
Should we say:
Done.
Best regards
Heinrich
- int ret;
- void *image_buf;
- if (ret)
return ret;
return 1;
return 1;
images->ep);
return 1;
+} +#endif
+#endif };
This patch adds an example FIT image description file demonstrating the usage of bootm command to securely launch UEFI binaries.
Signed-off-by: Cristian Ciocaltea cristian.ciocaltea@gmail.com Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de --- doc/uImage.FIT/uefi.its | 67 +++++++++++++++++++++++++++++++++++++++++ 1 file changed, 67 insertions(+) create mode 100644 doc/uImage.FIT/uefi.its
diff --git a/doc/uImage.FIT/uefi.its b/doc/uImage.FIT/uefi.its new file mode 100644 index 0000000000..378ca4ed8d --- /dev/null +++ b/doc/uImage.FIT/uefi.its @@ -0,0 +1,67 @@ +/* + * Example FIT image description file demonstrating the usage of the + * bootm command to launch UEFI binaries. + * + * Two boot configurations are available to enable booting GRUB2 on QEMU, + * the former uses a FDT blob contained in the FIT image, while the later + * relies on the FDT provided by the board emulator. + */ + +/dts-v1/; + +/ { + description = "GRUB2 EFI and QEMU FDT blob"; + #address-cells = <1>; + + images { + efi-grub { + description = "GRUB EFI Firmware"; + data = /incbin/("bootarm.efi"); + type = "kernel_noload"; + arch = "arm"; + os = "efi"; + compression = "none"; + load = <0x0>; + entry = <0x0>; + hash-1 { + algo = "sha256"; + }; + }; + + fdt-qemu { + description = "QEMU DTB"; + data = /incbin/("qemu-arm.dtb"); + type = "flat_dt"; + arch = "arm"; + compression = "none"; + hash-1 { + algo = "sha256"; + }; + }; + }; + + configurations { + default = "config-grub-fdt"; + + config-grub-fdt { + description = "GRUB EFI Boot w/ FDT"; + kernel = "efi-grub"; + fdt = "fdt-qemu"; + signature-1 { + algo = "sha256,rsa2048"; + key-name-hint = "dev"; + sign-images = "kernel", "fdt"; + }; + }; + + config-grub-nofdt { + description = "GRUB EFI Boot w/o FDT"; + kernel = "efi-grub"; + signature-1 { + algo = "sha256,rsa2048"; + key-name-hint = "dev"; + sign-images = "kernel"; + }; + }; + }; +};
This patch adds a new section "Launching a UEFI binary from a FIT image" documenting the usage of the CONFIG_BOOTM_EFI extension to bootm command that offers a verified boot alternative for UEFI binaries such as GRUB2.
Signed-off-by: Cristian Ciocaltea cristian.ciocaltea@gmail.com Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de --- doc/uefi/uefi.rst | 34 ++++++++++++++++++++++++++++++++++ 1 file changed, 34 insertions(+)
diff --git a/doc/uefi/uefi.rst b/doc/uefi/uefi.rst index db942df694..a8fd886d6b 100644 --- a/doc/uefi/uefi.rst +++ b/doc/uefi/uefi.rst @@ -63,6 +63,40 @@ The environment variable 'bootargs' is passed as load options in the UEFI system table. The Linux kernel EFI stub uses the load options as command line arguments.
+Launching a UEFI binary from a FIT image +~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + +A signed FIT image can be used to securely boot a UEFI image via the +bootm command. This feature is available if U-Boot is configured with:: + + CONFIG_BOOTM_EFI=y + +A sample configuration is provided as file doc/uImage.FIT/uefi.its. + +Below you find the output of an example session starting GRUB:: + + => load mmc 0:1 ${kernel_addr_r} image.fit + 4620426 bytes read in 83 ms (53.1 MiB/s) + => bootm ${kernel_addr_r}#config-grub-nofdt + ## Loading kernel from FIT Image at 40400000 ... + Using 'config-grub-nofdt' configuration + Verifying Hash Integrity ... sha256,rsa2048:dev+ OK + Trying 'efi-grub' kernel subimage + Description: GRUB EFI Firmware + Created: 2019-11-20 8:18:16 UTC + Type: Kernel Image (no loading done) + Compression: uncompressed + Data Start: 0x404000d0 + Data Size: 450560 Bytes = 440 KiB + Hash algo: sha256 + Hash value: 4dbee00021112df618f58b3f7cf5e1595533d543094064b9ce991e8b054a9eec + Verifying Hash Integrity ... sha256+ OK + XIP Kernel Image (no loading done) + ## Transferring control to EFI (at address 404000d0) ... + Welcome to GRUB! + +See doc/uImage.FIT/howto.txt for an introduction to FIT images. + Executing the boot manager ~~~~~~~~~~~~~~~~~~~~~~~~~~
This test verifies the implementation of the 'bootm' extension that handles UEFI binaries inside FIT images (enabled via CONFIG_BOOTM_EFI).
Signed-off-by: Cristian Ciocaltea cristian.ciocaltea@gmail.com --- test/py/tests/test_efi_fit.py | 459 ++++++++++++++++++++++++++++++++++ 1 file changed, 459 insertions(+) create mode 100644 test/py/tests/test_efi_fit.py
diff --git a/test/py/tests/test_efi_fit.py b/test/py/tests/test_efi_fit.py new file mode 100644 index 0000000000..e1f0e42694 --- /dev/null +++ b/test/py/tests/test_efi_fit.py @@ -0,0 +1,459 @@ +# SPDX-License-Identifier: GPL-2.0 +# Copyright (c) 2019, Cristian Ciocaltea cristian.ciocaltea@gmail.com +# +# Work based on: +# - test_net.py +# Copyright (c) 2016, NVIDIA CORPORATION. All rights reserved. +# - test_fit.py +# Copyright (c) 2013, Google Inc. +# +# Test launching UEFI binaries from FIT images. + +import os.path +import pytest +import u_boot_utils as util + +""" +Note: This test relies on boardenv_* containing configuration values to define +which network environment is available for testing. Without this, the parts +that rely on network will be automatically skipped. + +For example: + +# Boolean indicating whether the Ethernet device is attached to USB, and hence +# USB enumeration needs to be performed prior to network tests. +# This variable may be omitted if its value is False. +env__net_uses_usb = False + +# Boolean indicating whether the Ethernet device is attached to PCI, and hence +# PCI enumeration needs to be performed prior to network tests. +# This variable may be omitted if its value is False. +env__net_uses_pci = True + +# True if a DHCP server is attached to the network, and should be tested. +# If DHCP testing is not possible or desired, this variable may be omitted or +# set to False. +env__net_dhcp_server = True + +# A list of environment variables that should be set in order to configure a +# static IP. If solely relying on DHCP, this variable may be omitted or set to +# an empty list. +env__net_static_env_vars = [ + ('ipaddr', '10.0.0.100'), + ('netmask', '255.255.255.0'), + ('serverip', '10.0.0.1'), +] + +# Details regarding a file that may be read from a TFTP server. This variable +# may be omitted or set to None if TFTP testing is not possible or desired. +# Additionally, when the 'size' is not available, the file will be generated +# automatically in the TFTP root directory, as specified by the 'dn' field. +env__efi_fit_tftp_file = { + 'fn': 'test-efi-fit.img', # File path relative to TFTP root + 'size': 3831, # File size + 'crc32': '9fa3f79c', # Checksum using CRC-32 algorithm, optional + 'addr': '$kernel_addr_r', # Loading address, optional + 'dn': 'tftp/root/dir', # TFTP root directory path, optional +} +""" + +# Define the parametrized ITS data to be used for FIT images generation. +its_data = ''' +/dts-v1/; + +/ { + description = "EFI image with FDT blob"; + #address-cells = <1>; + + images { + efi { + description = "Test EFI"; + data = /incbin/("%(efi-bin)s"); + type = "%(kernel-type)s"; + arch = "%(sys-arch)s"; + os = "efi"; + compression = "%(efi-comp)s"; + load = <0x0>; + entry = <0x0>; + }; + fdt { + description = "Test FDT"; + data = /incbin/("%(fdt-bin)s"); + type = "flat_dt"; + arch = "%(sys-arch)s"; + compression = "%(fdt-comp)s"; + }; + }; + + configurations { + default = "config-efi-fdt"; + config-efi-fdt { + description = "EFI FIT w/ FDT"; + kernel = "efi"; + fdt = "fdt"; + }; + config-efi-nofdt { + description = "EFI FIT w/o FDT"; + kernel = "efi"; + }; + }; +}; +''' + +# Define the parametrized FDT data to be used for DTB images generation. +fdt_data = ''' +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <0>; + + model = "%(sys-arch)s %(fdt_type)s EFI FIT Boot Test"; + compatible = "%(sys-arch)s"; + + reset@0 { + compatible = "%(sys-arch)s,reset"; + reg = <0>; + }; +}; +''' + +@pytest.mark.buildconfigspec('bootm_efi') +@pytest.mark.buildconfigspec('cmd_bootefi_hello_compile') +@pytest.mark.buildconfigspec('fit') +@pytest.mark.notbuildconfigspec('generate_acpi_table') +@pytest.mark.requiredtool('dtc') +def test_efi_fit_launch(u_boot_console): + """Test handling of UEFI binaries inside FIT images. + + The tests are trying to launch U-Boot's helloworld.efi embedded into + FIT images, in uncompressed or gzip compressed format. + + Additionally, a sample FDT blob is created and embedded into the above + mentioned FIT images, in uncompressed or gzip compressed format. + + For more details, see launch_efi(). + + The following test cases are currently defined and enabled: + - Launch uncompressed FIT EFI & internal FDT + - Launch uncompressed FIT EFI & FIT FDT + - Launch compressed FIT EFI & internal FDT + - Launch compressed FIT EFI & FIT FDT + """ + + def net_pre_commands(): + """Execute any commands required to enable network hardware. + + These commands are provided by the boardenv_* file; see the comment + at the beginning of this file. + """ + + init_usb = cons.config.env.get('env__net_uses_usb', False) + if init_usb: + cons.run_command('usb start') + + init_pci = cons.config.env.get('env__net_uses_pci', False) + if init_pci: + cons.run_command('pci enum') + + def net_dhcp(): + """Execute the dhcp command. + + The boardenv_* file may be used to enable/disable DHCP; see the + comment at the beginning of this file. + """ + + has_dhcp = cons.config.buildconfig.get('config_cmd_dhcp', 'n') == 'y' + if not has_dhcp: + cons.log.warning('CONFIG_CMD_DHCP != y: Skipping DHCP network setup') + return False + + test_dhcp = cons.config.env.get('env__net_dhcp_server', False) + if not test_dhcp: + cons.log.info('No DHCP server available') + return False + + cons.run_command('setenv autoload no') + output = cons.run_command('dhcp') + assert 'DHCP client bound to address ' in output + return True + + def net_setup_static(): + """Set up a static IP configuration. + + The configuration is provided by the boardenv_* file; see the comment at + the beginning of this file. + """ + + has_dhcp = cons.config.buildconfig.get('config_cmd_dhcp', 'n') == 'y' + if not has_dhcp: + cons.log.warning('CONFIG_NET != y: Skipping static network setup') + return False + + env_vars = cons.config.env.get('env__net_static_env_vars', None) + if not env_vars: + cons.log.info('No static network configuration is defined') + return False + + for (var, val) in env_vars: + cons.run_command('setenv %s %s' % (var, val)) + return True + + def make_fpath(fname): + """Compute the path of a given (temporary) file. + + Args: + fname: The name of a file within U-Boot build dir. + Return: + The computed file path. + """ + + return os.path.join(cons.config.build_dir, fname) + + def make_efi(fname, comp): + """Create an UEFI binary. + + This simply copies lib/efi_loader/helloworld.efi into U-Boot + build dir and, optionally, compresses the file using gzip. + + Args: + fname: The target file name within U-Boot build dir. + comp: Flag to enable gzip compression. + Return: + The path of the created file. + """ + + bin_path = make_fpath(fname) + util.run_and_log(cons, + ['cp', make_fpath('lib/efi_loader/helloworld.efi'), bin_path]) + if comp: + util.run_and_log(cons, ['gzip', '-f', bin_path]) + bin_path += '.gz' + return bin_path + + def make_dtb(fdt_type, comp): + """Create a sample DTB file. + + Creates a DTS file and compiles it to a DTB. + + Args: + fdt_type: The type of the FDT, i.e. internal, user. + comp: Flag to enable gzip compression. + Return: + The path of the created file. + """ + + # Generate resources referenced by FDT. + fdt_params = { + 'sys-arch': sys_arch, + 'fdt_type' : fdt_type, + } + + # Generate a test FDT file. + dts = make_fpath('test-efi-fit-%s.dts' % fdt_type) + with open(dts, 'w') as fd: + fd.write(fdt_data % fdt_params) + + # Build the test FDT. + dtb = make_fpath('test-efi-fit-%s.dtb' % fdt_type) + util.run_and_log(cons, ['dtc', '-I', 'dts', '-O', 'dtb', '-o', dtb, dts]) + if comp: + util.run_and_log(cons, ['gzip', '-f', dtb]) + dtb += '.gz' + return dtb + + def make_fit(comp): + """Create a sample FIT image. + + Runs 'mkimage' to create a FIT image within U-Boot build dir. + Args: + comp: Enable gzip compression for the EFI binary and FDT blob. + Return: + The path of the created file. + """ + + # Generate resources referenced by ITS. + its_params = { + 'sys-arch': sys_arch, + 'efi-bin': os.path.basename(make_efi('test-efi-fit-helloworld.efi', comp)), + 'kernel-type': 'kernel' if comp else 'kernel_noload', + 'efi-comp': 'gzip' if comp else 'none', + 'fdt-bin': os.path.basename(make_dtb('user', comp)), + 'fdt-comp': 'gzip' if comp else 'none', + } + + # Generate a test ITS file. + its_path = make_fpath('test-efi-fit-helloworld.its') + with open(its_path, 'w') as fd: + fd.write(its_data % its_params) + + # Build the test ITS. + fit_path = make_fpath('test-efi-fit-helloworld.fit') + util.run_and_log( + cons, [make_fpath('tools/mkimage'), '-f', its_path, fit_path]) + return fit_path + + def load_fit_from_host(f): + """Load the FIT image using the 'host load' command and return its address. + + Args: + f: Dictionary describing the FIT image to load, see env__efi_fit_test_file + in the comment at the beginning of this file. + Return: + The address where the file has been loaded. + """ + + addr = f.get('addr', None) + if not addr: + addr = u_boot_utils.find_ram_base(cons) + + output = cons.run_command( + 'host load hostfs - %s %s/%s' % (addr, f['dn'], f['fn'])) + expected_text = ' bytes read' + sz = f.get('size', None) + if sz: + expected_text = '%d' % sz + expected_text + assert(expected_text in output) + + return addr + + def load_fit_from_tftp(f): + """Load the FIT image using the tftpboot command and return its address. + + The file is downloaded from the TFTP server, its size and optionally its + CRC32 are validated. + + Args: + f: Dictionary describing the FIT image to load, see env__efi_fit_tftp_file + in the comment at the beginning of this file. + Return: + The address where the file has been loaded. + """ + + addr = f.get('addr', None) + if not addr: + addr = u_boot_utils.find_ram_base(cons) + + fn = f['fn'] + output = cons.run_command('tftpboot %s %s' % (addr, fn)) + expected_text = 'Bytes transferred = ' + sz = f.get('size', None) + if sz: + expected_text += '%d' % sz + assert expected_text in output + + expected_crc = f.get('crc32', None) + if not expected_crc: + return addr + + if cons.config.buildconfig.get('config_cmd_crc32', 'n') != 'y': + return addr + + output = cons.run_command('crc32 $fileaddr $filesize') + assert expected_crc in output + + return addr + + def launch_efi(enable_fdt, enable_comp): + """Launch U-Boot's helloworld.efi binary from a FIT image. + + An external image file can be downloaded from TFTP, when related + details are provided by the boardenv_* file; see the comment at the + beginning of this file. + + If the size of the TFTP file is not provided within env__efi_fit_tftp_file, + the test image is generated automatically and placed in the TFTP root + directory specified via the 'dn' field. + + When running the tests on Sandbox, the image file is loaded directly + from the host filesystem. + + Once the load address is available on U-Boot console, the 'bootm' + command is executed for either 'config-efi-fdt' or 'config-efi-nofdt' + FIT configuration, depending on the value of the 'enable_fdt' function + argument. + + Eventually the 'Hello, world' message is expected in the U-Boot console. + + Args: + enable_fdt: Flag to enable using the FDT blob inside FIT image. + enable_comp: Flag to enable GZIP compression on EFI and FDT + generated content. + """ + + with cons.log.section('FDT=%s;COMP=%s' % (enable_fdt, enable_comp)): + if is_sandbox: + fit = { + 'dn': cons.config.build_dir, + 'addr': '${kernel_addr_r}', + } + else: + # Init networking. + net_pre_commands() + net_set_up = net_dhcp() + net_set_up = net_setup_static() or net_set_up + if not net_set_up: + pytest.skip('Network not initialized') + + fit = cons.config.env.get('env__efi_fit_tftp_file', None) + if not fit: + pytest.skip('No env__efi_fit_tftp_file binary specified in environment') + + sz = fit.get('size', None) + if not sz: + if not fit.get('dn', None): + pytest.skip('Neither "size", nor "dn" info provided in env__efi_fit_tftp_file') + + # Create test FIT image. + fit_path = make_fit(enable_comp) + fit['fn'] = os.path.basename(fit_path) + fit['size'] = os.path.getsize(fit_path) + + # Copy image to TFTP root directory. + if fit['dn'] != cons.config.build_dir: + util.run_and_log(cons, ['mv', '-f', fit_path, '%s/' % fit['dn']]) + + # Load FIT image. + addr = load_fit_from_host(fit) if is_sandbox else load_fit_from_tftp(fit) + + # Select boot configuration. + fit_config = 'config-efi-fdt' if enable_fdt else 'config-efi-nofdt' + + # Try booting. + cons.run_command( + 'bootm %s#%s' % (addr, fit_config), wait_for_prompt=False) + if enable_fdt: + cons.wait_for('Booting using the fdt blob') + cons.wait_for('Hello, world') + cons.wait_for('## Application terminated, r = 0') + cons.restart_uboot(); + + cons = u_boot_console + # Array slice removes leading/trailing quotes. + sys_arch = cons.config.buildconfig.get('config_sys_arch', '"sandbox"')[1:-1] + is_sandbox = sys_arch == 'sandbox' + + try: + if is_sandbox: + # Use our own device tree file, will be restored afterwards. + control_dtb = make_dtb('internal', False) + old_dtb = cons.config.dtb + cons.config.dtb = control_dtb + + # Run tests + # - fdt OFF, gzip OFF + launch_efi(False, False) + # - fdt ON, gzip OFF + launch_efi(True, False) + + if is_sandbox: + # - fdt OFF, gzip ON + launch_efi(False, True) + # - fdt ON, gzip ON + launch_efi(True, True) + + finally: + if is_sandbox: + # Go back to the original U-Boot with the correct dtb. + cons.config.dtb = old_dtb + cons.restart_uboot()
Thanks a lot for devising this test.
You are using variable env__efi_fit_tftp_file. To run the test on Gitlab and Travis CI a patch will be needed for:
https://github.com/swarren/uboot-test-hooks.git
I hope
https://github.com/xypron/uboot-test-hooks/commit/20dcd721437dd5f7d7d3d235f7...
will do the job.
Once we have this applied we will have to adjust the config files for QEMU.
I have been trying to run the test on qemu_arm64_defconfig using the following lines in u_boot_boardenv_qemu_arm64.py:
env__efi_fit_tftp_file = { "fn": "helloworld.efi", "size": 4480, "crc32": "19f9c0ab", }
I got an error:
test/py/tests/test_efi_fit.py:417: in launch_efi addr = load_fit_from_host(fit) if is_sandbox else load_fit_from_tftp(fit) _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ addr = f.get('addr', None) if not addr:
E NameError: name 'u_boot_utils' is not defined
When I provided addr:
env__efi_fit_tftp_file = { "fn": "helloworld.efi", "size": 4480, "crc32": "19f9c0ab", "addr": 0x40400000, }
I got the following error:
=> tftpboot 1073741824 helloworld.efi TFTP error: trying to overwrite reserved memory...
I would have expected a command
tftpboot 40400000 helloworld.efi
to be issued.
Same error with bootm:
=> bootm 1077936128#config-efi-nofdt "Synchronous Abort" handler, esr 0x96000010 elr: 000000000001c36c lr : 00000000000140f4 (reloc)
Please, fix the lines indicated below and verify that you can actually execute this test on the QEMU platform.
https://github.com/xypron/u-boot-build/tree/qemu-arm64/u-boot-test
contains the files I use to run Python tests on qemu_arm64_defconfig.
"as util" causes an error if you use u_boot_utils.* below. Below I indicate the places to change.
+For example:
- ('ipaddr', '10.0.0.100'),
- ('netmask', '255.255.255.0'),
- ('serverip', '10.0.0.1'),
- 'fn': 'test-efi-fit.img', # File path relative to TFTP root
- 'size': 3831, # File size
- 'crc32': '9fa3f79c', # Checksum using CRC-32 algorithm, optional
- 'addr': '$kernel_addr_r', # Loading address, optional
- 'dn': 'tftp/root/dir', # TFTP root directory path, optional
- description = "EFI image with FDT blob";
- #address-cells = <1>;
- images {
efi {
os = "efi";
load = <0x0>;
entry = <0x0>;
fdt {
type = "flat_dt";
- configurations {
config-efi-fdt {
kernel = "efi";
fdt = "fdt";
config-efi-nofdt {
kernel = "efi";
- #size-cells = <0>;
- model = "%(sys-arch)s %(fdt_type)s EFI FIT Boot Test";
- compatible = "%(sys-arch)s";
- reset@0 {
reg = <0>;
- """Test handling of UEFI binaries inside FIT images.
- The tests are trying to launch U-Boot's helloworld.efi embedded into
- FIT images, in uncompressed or gzip compressed format.
- Additionally, a sample FDT blob is created and embedded into the above
- mentioned FIT images, in uncompressed or gzip compressed format.
- For more details, see launch_efi().
- The following test cases are currently defined and enabled:
- def net_pre_commands():
if init_usb:
if init_pci:
- def net_dhcp():
if not has_dhcp:
return False
if not test_dhcp:
return False
return True
- def net_setup_static():
if not has_dhcp:
return False
if not env_vars:
return False
return True
- def make_fpath(fname):
Args:
Return:
- def make_efi(fname, comp):
Args:
Return:
if comp:
bin_path += '.gz'
return bin_path
- def make_dtb(fdt_type, comp):
Args:
Return:
fdt_params = {
if comp:
dtb += '.gz'
return dtb
- def make_fit(comp):
Args:
Return:
its_params = {
util.run_and_log(
return fit_path
- def load_fit_from_host(f):
Args:
Return:
if not addr:
%s/u_boot_utils/util/
if sz:
return addr
- def load_fit_from_tftp(f):
Args:
Return:
if not addr:
fn = f['fn']
You have to pass addr as hexadecimal number.
output = cons.run_command('tftpboot %x %s' % (addr, fn))
if sz:
return addr
return addr
return addr
- def launch_efi(enable_fdt, enable_comp):
argument.
Args:
generated content.
if is_sandbox:
fit = {
else:
# Init networking.
net_pre_commands()
if not net_set_up:
if not fit:
if not sz:
# Load FIT image.
# Try booting.
cons.run_command(
You have to pass the address as hexadecimal number.
'bootm %x#%s' % (addr, fit_config), wait_for_prompt=False)
Best regards
Heinrich
if enable_fdt:
- cons = u_boot_console
- # Array slice removes leading/trailing quotes.
- sys_arch = cons.config.buildconfig.get('config_sys_arch', '"sandbox"')[1:-1]
- is_sandbox = sys_arch == 'sandbox'
- try:
if is_sandbox:
# Run tests
if is_sandbox:
# - fdt ON, gzip ON
- finally:
if is_sandbox:
I hope
will do the job.
I got an error:
to be issued.
+For example:
addr must be an integer not a string. Otherwise this does not match your function call
addr = util.find_ram_base(cons)
Best regards
Heinrich
+ return addr
+ return addr
Best regards
Heinrich
I hope
will do the job.
I got an error:
to be issued.
Thank you for the detailed report!
Unfortunately I have only tested on qemu_arm and somehow I missed the check of having the address computed by the test suite. It used to work before I changed the address data type to string - the reason was to allow for more flexibility, e.g. providing values like '$kernel_addr_r' instead of just precomputed numbers.
I'm going to extend the tests on qemu_arm64 as well.
Fixed, thanks.
+For example:
- images {
efi {
os = "efi";
load = <0x0>;
entry = <0x0>;
fdt {
type = "flat_dt";
- configurations {
config-efi-fdt {
kernel = "efi";
fdt = "fdt";
config-efi-nofdt {
kernel = "efi";
- reset@0 {
reg = <0>;
if init_usb:
if init_pci:
- def net_dhcp():
if not has_dhcp:
return False
if not test_dhcp:
return False
return True
if not has_dhcp:
return False
if not env_vars:
return False
return True
Args:
Return:
Args:
Return:
if comp:
bin_path += '.gz'
return bin_path
Args:
Return:
fdt_params = {
if comp:
dtb += '.gz'
return dtb
Args:
Return:
its_params = {
util.run_and_log(
return fit_path
Args:
Return:
if not addr:
if sz:
return addr
Args:
Return:
if not addr:
fn = f['fn']
As explained before, I eventually converted 'addr' to string in order to allow values like '$kernel_addr_r' to be passed from the environment (this is what I actually used during my local tests). What I missed was the following:
addr = '%x' % util.find_ram_base(cons)
If this is not desired, I can revert to numbers only.
if sz:
return addr
return addr
return addr
argument.
Args:
generated content.
if is_sandbox:
fit = {
else:
# Init networking.
net_pre_commands()
if not net_set_up:
if not fit:
if not sz:
# Load FIT image.
# Try booting.
cons.run_command(
Please see comments above.
Best regards
Heinrich
if enable_fdt:
- try:
if is_sandbox:
# Run tests
if is_sandbox:
# - fdt ON, gzip ON
- finally:
if is_sandbox:
I hope
will do the job.
I got an error:
to be issued.
Fixed, thanks.
+For example:
- images {
efi {
os = "efi";
load = <0x0>;
entry = <0x0>;
fdt {
type = "flat_dt";
- configurations {
config-efi-fdt {
kernel = "efi";
fdt = "fdt";
config-efi-nofdt {
kernel = "efi";
- reset@0 {
reg = <0>;
if init_usb:
if init_pci:
- def net_dhcp():
if not has_dhcp:
return False
if not test_dhcp:
return False
return True
if not has_dhcp:
return False
if not env_vars:
return False
return True
Args:
Return:
Args:
Return:
if comp:
bin_path += '.gz'
return bin_path
Args:
Return:
fdt_params = {
if comp:
dtb += '.gz'
return dtb
Args:
Return:
its_params = {
util.run_and_log(
return fit_path
Args:
Return:
if not addr:
if sz:
return addr
Args:
Return:
if not addr:
fn = f['fn']
I suggest to use the following instead of referring to $kernel_addr_r:
with cons.log.section('FDT=%s;COMP=%s' % (enable_fdt, enable_comp)): if is_sandbox: addr = util.find_ram_base(cons) fit = { 'dn': cons.config.build_dir, 'addr': addr, } else:
Best regards
Heinrich
if sz:
return addr
return addr
return addr
argument.
Args:
generated content.
if is_sandbox:
fit = {
else:
# Init networking.
net_pre_commands()
if not net_set_up:
if not fit:
if not sz:
# Load FIT image.
# Try booting.
cons.run_command(
Best regards
Heinrich
if enable_fdt:
- try:
if is_sandbox:
# Run tests
if is_sandbox:
# - fdt ON, gzip ON
- finally:
if is_sandbox:
I hope
will do the job.
I got an error:
to be issued.
Fixed, thanks.
+For example:
- images {
efi {
os = "efi";
load = <0x0>;
entry = <0x0>;
fdt {
type = "flat_dt";
- configurations {
config-efi-fdt {
kernel = "efi";
fdt = "fdt";
config-efi-nofdt {
kernel = "efi";
- reset@0 {
reg = <0>;
if init_usb:
if init_pci:
- def net_dhcp():
if not has_dhcp:
return False
if not test_dhcp:
return False
return True
if not has_dhcp:
return False
if not env_vars:
return False
return True
Args:
Return:
Args:
Return:
if comp:
bin_path += '.gz'
return bin_path
Args:
Return:
fdt_params = {
if comp:
dtb += '.gz'
return dtb
Args:
Return:
its_params = {
util.run_and_log(
return fit_path
Args:
Return:
if not addr:
if sz:
return addr
Args:
Return:
if not addr:
fn = f['fn']
Actually this is already performed by 'load_fit_from_host()', all we need here is to avoid setting 'addr' in the dictionary.
Thanks again for the whole feedback, I'll send a new patch series with all the changes agreed so far.
Best regards
Heinrich
if sz:
return addr
return addr
return addr
argument.
Args:
generated content.
if is_sandbox:
fit = {
else:
# Init networking.
net_pre_commands()
if not net_set_up:
if not fit:
if not sz:
# Load FIT image.
# Try booting.
cons.run_command(
Best regards
Heinrich
if enable_fdt:
- try:
if is_sandbox:
# Run tests
if is_sandbox:
# - fdt ON, gzip ON
- finally:
if is_sandbox:
Cristian Ciocaltea
