[U-Boot] [PATCH 1/2] sun8i_emac: add support for setting EMAC TX/RX delay
Some boards have the EMAC TX/RX lanes wired with a different length with the clock lane, which can be workarounded by setting a TX/RX delay in the EMAC.
This kind of delays are already defined in the newest device tree binding of dwmac-sun8i, which has already entered linux-next.
Add support for setting these delays.
Signed-off-by: Icenowy Zheng icenowy@aosc.io --- drivers/net/sun8i_emac.c | 31 +++++++++++++++++++++++++++++-- 1 file changed, 29 insertions(+), 2 deletions(-)
diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index 3ba3a1ff8b..230ff045d5 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -60,6 +60,10 @@ #define SC_ETCS_MASK GENMASK(1, 0) #define SC_ETCS_EXT_GMII 0x1 #define SC_ETCS_INT_GMII 0x2 +#define SC_ETXDC_MASK GENMASK(12, 10) +#define SC_ETXDC_OFFSET 10 +#define SC_ERXDC_MASK GENMASK(9, 5) +#define SC_ERXDC_OFFSET 5
#define CONFIG_MDIO_TIMEOUT (3 * CONFIG_SYS_HZ)
@@ -140,6 +144,8 @@ struct emac_eth_dev { struct sun8i_eth_pdata { struct eth_pdata eth_pdata; u32 reset_delays[3]; + int tx_delay_ps; + int rx_delay_ps; };
@@ -273,7 +279,8 @@ static int sun8i_emac_set_syscon_ephy(struct emac_eth_dev *priv, u32 *reg) return 0; }
-static int sun8i_emac_set_syscon(struct emac_eth_dev *priv) +static int sun8i_emac_set_syscon(struct sun8i_eth_pdata *pdata, + struct emac_eth_dev *priv) { int ret; u32 reg; @@ -312,6 +319,14 @@ static int sun8i_emac_set_syscon(struct emac_eth_dev *priv) return -EINVAL; }
+ if (pdata->tx_delay_ps) + reg |= ((pdata->tx_delay_ps / 100) << SC_ETXDC_OFFSET) + & SC_ETXDC_MASK; + + if (pdata->rx_delay_ps) + reg |= ((pdata->rx_delay_ps / 100) << SC_ERXDC_OFFSET) + & SC_ERXDC_MASK; + writel(reg, priv->sysctl_reg + 0x30);
return 0; @@ -790,7 +805,7 @@ static int sun8i_emac_eth_probe(struct udevice *dev) priv->mac_reg = (void *)pdata->iobase;
sun8i_emac_board_setup(priv); - sun8i_emac_set_syscon(priv); + sun8i_emac_set_syscon((struct sun8i_eth_pdata *)pdata, priv);
sun8i_mdio_init(dev->name, dev); priv->bus = miiphy_get_dev_by_name(dev->name); @@ -891,6 +906,18 @@ static int sun8i_emac_eth_ofdata_to_platdata(struct udevice *dev) if (!priv->use_internal_phy) parse_phy_pins(dev);
+ sun8i_pdata->tx_delay_ps = fdtdec_get_int(gd->fdt_blob, node, + "allwinner,tx-delay-ps", 0); + if (sun8i_pdata->tx_delay_ps < 0 || sun8i_pdata->tx_delay_ps > 700) + printf("%s: Invalid TX delay value %d\n", __func__, + sun8i_pdata->tx_delay_ps); + + sun8i_pdata->rx_delay_ps = fdtdec_get_int(gd->fdt_blob, node, + "allwinner,rx-delay-ps", 0); + if (sun8i_pdata->rx_delay_ps < 0 || sun8i_pdata->rx_delay_ps > 3100) + printf("%s: Invalid RX delay value %d\n", __func__, + sun8i_pdata->rx_delay_ps); + #ifdef CONFIG_DM_GPIO if (fdtdec_get_bool(gd->fdt_blob, dev_of_offset(dev), "snps,reset-active-low"))
Add Ethernet nodes to OLinuXino DT to enable Gigabit Ethernet [ commit 21eac6f33e68ae778e9d1c910606452abf058d3d in Linux ]
Set PHY TX delay of 600ps [ commit 679294497be31596e1c9c61507746d72b6b05f26 in Linux ]
Signed-off-by: Alexander Weidinger alexander.weidinger@tum.de --- arch/arm/dts/sun50i-a64-olinuxino.dts | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+)
diff --git a/arch/arm/dts/sun50i-a64-olinuxino.dts b/arch/arm/dts/sun50i-a64-olinuxino.dts index 3b3081b10e..d29695a7d0 100644 --- a/arch/arm/dts/sun50i-a64-olinuxino.dts +++ b/arch/arm/dts/sun50i-a64-olinuxino.dts @@ -51,6 +51,7 @@ compatible = "olimex,a64-olinuxino", "allwinner,sun50i-a64";
aliases { + ethernet0 = &emac; serial0 = &uart0; };
@@ -64,6 +65,23 @@ }; };
+&emac { + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + phy-mode = "rgmii"; + phy-handle = <&ext_rgmii_phy>; + phy-supply = <®_dcdc1>; + allwinner,tx-delay-ps = <600>; + status = "okay"; +}; + +&mdio { + ext_rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + }; +}; + &mmc0 { pinctrl-names = "default"; pinctrl-0 = <&mmc0_pins>;
On Fri, Nov 16, 2018 at 9:09 PM Alexander Weidinger alexander.weidinger@tum.de wrote:
Reviewed-by: Jagan Teki jagan@openedev.com
On Fri, Nov 16, 2018 at 9:08 PM Alexander Weidinger alexander.weidinger@tum.de wrote:
int tx_delay_ps;
int rx_delay_ps;
& SC_ETXDC_MASK;
& SC_ERXDC_MASK;
writel(reg, priv->sysctl_reg + 0x30); return 0;
We can get the platdata using dev_get_platdata instead of this type casting.
Signed-off-by: Icenowy Zheng icenowy@aosc.io --- Changes for v2: - Make use of `dev_get_platdata` instead of type casting - Patch 2/2 is superseded [ commit 1b39a1834ed182bbd8036a5cd74a9ea111fa4691 ]
drivers/net/sun8i_emac.c | 34 +++++++++++++++++++++++++++++++--- 1 file changed, 31 insertions(+), 3 deletions(-)
diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index 3ba3a1ff8b..c9798445c7 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -60,6 +60,10 @@ #define SC_ETCS_MASK GENMASK(1, 0) #define SC_ETCS_EXT_GMII 0x1 #define SC_ETCS_INT_GMII 0x2 +#define SC_ETXDC_MASK GENMASK(12, 10) +#define SC_ETXDC_OFFSET 10 +#define SC_ERXDC_MASK GENMASK(9, 5) +#define SC_ERXDC_OFFSET 5
return 0; @@ -784,13 +799,14 @@ static void sun8i_emac_eth_stop(struct udevice *dev)
static int sun8i_emac_eth_probe(struct udevice *dev) { - struct eth_pdata *pdata = dev_get_platdata(dev); + struct sun8i_eth_pdata *sun8i_pdata = dev_get_platdata(dev); + struct eth_pdata *pdata = &sun8i_pdata->eth_pdata; struct emac_eth_dev *priv = dev_get_priv(dev);
sun8i_emac_board_setup(priv); - sun8i_emac_set_syscon(priv); + sun8i_emac_set_syscon(sun8i_pdata, priv);
sun8i_mdio_init(dev->name, dev); priv->bus = miiphy_get_dev_by_name(dev->name); @@ -891,6 +907,18 @@ static int sun8i_emac_eth_ofdata_to_platdata(struct udevice *dev) if (!priv->use_internal_phy) parse_phy_pins(dev);
On Fri, Nov 23, 2018 at 5:08 AM Alexander Weidinger alexander.weidinger@tum.de wrote:
Note, that the DT patch for emac enable is already synced, check it on master.
Applied to u-boot-sunxi/master
Saw it while updating the patch with the requested change. I made a note about this in the change description and only send one patch in the v2 version of this series.
I'm a first time contributor to U-Boot, so I hope I did this correctly.
Alexander Weidinger
Jagan Teki
