[PATCH] xilinx: versal: Fix sdhci node name as per DT
Fix the sdhci node name in versal board file as per the name in device tree and also check for sdhci node as part of backward compatibility.
Signed-off-by: T Karthik Reddy t.karthik.reddy@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
board/xilinx/versal/board.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/board/xilinx/versal/board.c b/board/xilinx/versal/board.c index 6045eb2baa84..03604d730a0b 100644 --- a/board/xilinx/versal/board.c +++ b/board/xilinx/versal/board.c @@ -151,6 +151,8 @@ int board_late_init(void) case EMMC_MODE: puts("EMMC_MODE\n"); if (uclass_get_device_by_name(UCLASS_MMC, + "mmc@f1050000", &dev) && + uclass_get_device_by_name(UCLASS_MMC, "sdhci@f1050000", &dev)) { puts("Boot from EMMC but without SD1 enabled!\n"); return -1; @@ -162,6 +164,8 @@ int board_late_init(void) case SD_MODE: puts("SD_MODE\n"); if (uclass_get_device_by_name(UCLASS_MMC, + "mmc@f1040000", &dev) && + uclass_get_device_by_name(UCLASS_MMC, "sdhci@f1040000", &dev)) { puts("Boot from SD0 but without SD0 enabled!\n"); return -1; @@ -177,6 +181,8 @@ int board_late_init(void) case SD_MODE1: puts("SD_MODE1\n"); if (uclass_get_device_by_name(UCLASS_MMC, + "mmc@f1050000", &dev) && + uclass_get_device_by_name(UCLASS_MMC, "sdhci@f1050000", &dev)) { puts("Boot from SD1 but without SD1 enabled!\n"); return -1;
čt 18. 11. 2021 v 12:57 odesílatel Michal Simek michal.simek@xilinx.com napsal:
-- 2.33.1
Applied. M
Michal Simek
Michal Simek
