[PATCH 0/4] Various i.MXRT bug/typo fixes
Hi Anatolij, Stefano, Fabio, All,
this patchset fix 2 bugs preventing from LCDIF to work when booting from sd-card. There are also 2 little typo fixes for boards READMEs.
Giulio Benetti (4): imxrt1050-evk: README: fix dd command destination imxrt1020-evk: README: fix dd command destination video: mxsfb: add clk_enable() clk: imx: clk-imxrt1050: fix lcdif clock gate
board/freescale/imxrt1020-evk/README | 2 +- board/freescale/imxrt1050-evk/README | 2 +- drivers/clk/imx/clk-imxrt1050.c | 2 +- drivers/video/mxsfb.c | 6 ++++++ 4 files changed, 9 insertions(+), 3 deletions(-)
Make "of=" the same for the 2 commands since we're writing to the same sd-card.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- board/freescale/imxrt1050-evk/README | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/freescale/imxrt1050-evk/README b/board/freescale/imxrt1050-evk/README index f7e2894025..55b6a0877a 100644 --- a/board/freescale/imxrt1050-evk/README +++ b/board/freescale/imxrt1050-evk/README @@ -11,7 +11,7 @@ This will generate the SPL image called SPL and the u-boot.img.
- Flash the SPL image into the micro SD card:
-sudo dd if=SPL of=/dev/mmcblk0 bs=1k seek=1; sync +sudo dd if=SPL of=/dev/sdb bs=1k seek=1; sync
- Flash the u-boot.img image into the micro SD card:
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- board/freescale/imxrt1020-evk/README | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/freescale/imxrt1020-evk/README b/board/freescale/imxrt1020-evk/README index 3da72fdad2..bcb3683163 100644 --- a/board/freescale/imxrt1020-evk/README +++ b/board/freescale/imxrt1020-evk/README @@ -11,7 +11,7 @@ This will generate the SPL image called SPL and the u-boot.img.
BROM doesn't enable lcdif by default so add clk_enable() before clk_set_rate().
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- drivers/video/mxsfb.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/drivers/video/mxsfb.c b/drivers/video/mxsfb.c index 8a5a61c9fb..7eab8835b0 100644 --- a/drivers/video/mxsfb.c +++ b/drivers/video/mxsfb.c @@ -72,6 +72,12 @@ static void mxs_lcd_init(struct udevice *dev, u32 fb_addr, return; }
+ ret = clk_enable(&per_clk); + if (ret < 0) { + dev_err(dev, "Failed to enable mxs clk: %d\n", ret); + return; + } + ret = clk_set_rate(&per_clk, timings->pixelclock.typ); if (ret < 0) { dev_err(dev, "Failed to set mxs clk: %d\n", ret);
Hi Giulio,
On Sun, Apr 26, 2020 at 8:43 PM Giulio Benetti giulio.benetti@benettiengineering.com wrote:
if (ret < 0) {
return;
Usually it is safer to configure the clock rate first and then enable the clock to avoid glitches.
Could you try to call clk_enable() after clk_set_rate() here?
Hi Fabio,
On 4/27/20 1:48 AM, Fabio Estevam wrote:
Hi Giulio,
if (ret < 0) {
return;
Sure, I'm going to send it for V2.
Thanks for reviewing
LCDIF clock gate was wrong so set it according to RM.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- drivers/clk/imx/clk-imxrt1050.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/clk/imx/clk-imxrt1050.c b/drivers/clk/imx/clk-imxrt1050.c index 329f4580c5..8279e784fe 100644 --- a/drivers/clk/imx/clk-imxrt1050.c +++ b/drivers/clk/imx/clk-imxrt1050.c @@ -255,7 +255,7 @@ static int imxrt1050_clk_probe(struct udevice *dev) clk_dm(IMXRT1050_CLK_SEMC, imx_clk_gate2("semc", "semc_podf", base + 0x74, 4)); clk_dm(IMXRT1050_CLK_LCDIF, - imx_clk_gate2("lcdif", "lcdif_podf", base + 0x70, 28)); + imx_clk_gate2("lcdif", "lcdif_podf", base + 0x74, 10));
struct clk *clk, *clk1;
forgotten Lukasz, sorry.
Fabio Estevam
Giulio Benetti
